[Patch] Pulling the following commits and some general changes
from custom v3.10 kernel for supporting qcacld2.0 on kernel v4.9.11.
1. cfg80211: Using new wiphy flag WIPHY_FLAG_DFS_OFFLOAD
When flag WIPHY_FLAG_DFS_OFFLOAD is defined, the driver would handle
all the DFS related operations. Therefore the kernel needs to ignore
the DFS state that it uses to block the userspace calls to the driver
through cfg80211 APIs. Also it should treat the userspace calls to
start radar detection as a no-op.
Please note that changes in util.c is not picked up explicitly.
Kernel v4.9.11 uses wrapper cfg80211_get_chans_dfs_required which takes
care of this change.
Change-Id: I9dd2076945581ca67e54dfc96dd3dbc526c6f0a2
IRs-Fixed: 202686
2. New db.txt from git/sforshee/wireless-regdb.git
CONFIG_CFG80211_INTERNAL_REGDB is enabled in build. This causes
kernel warn messages as db.txt is empty. A new db.txt is added
git://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git
IRs-Fixed: 202686
3. Picked up the declaration and definition of the function
cfg80211_is_gratuitous_arp_unsolicited_na
Change-Id: I1e4083a2327c121073226aa6b75bb6b5b97cec00
CRs-fixed: 1079453
Signed-off-by: Nakul Kachhwaha <nkachh@codeaurora.org>
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Sharing DFS channel state across multiple wiphys (radios) could
be useful with multiple radios on the system. When one radio
completes CAC and markes the channel available another radio
can use this information and start beaconing without really doing
CAC.
Whenever there is a state change in dfs channel associated to
a particular wiphy the the same state change is propagated to
other wiphys having the same DFS reg domain configuration.
Also when a new wiphy is created the dfs channel state of
other existing wiphys of same DFS domain is copied.
Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qti.qualcomm.com>
DFS requirement for ETSI domain (section 4.7.1.4 in
ETSI EN 301 893 V1.8.1) is the only one which explicitly
states that once DFS channel is marked as available afer
the CAC, this channel will remain in available state even
moving to a different operating channel. But the same is
not explicitly stated in FCC DFS requirement. Also, Pre-CAC
requriements are not explicitly mentioned in FCC requirement.
Current implementation in keeping DFS channel in available
state is same as described in ETSI domain.
For non-ETSI DFS domain, this patch gives a grace period of 2 seconds
since the completion of successful CAC before moving the channel's
DFS state to 'usable' from 'available' state. The same grace period
is checked against the channel's dfs_state_entered timestamp while
deciding if a DFS channel is available for operation. There is a new
radar event, NL80211_RADAR_PRE_CAC_EXPIRED, reported when DFS channel
is moved from available to usable state after the grace period. Also
make sure the DFS channel state is reset to usable once the beaconing
operation on that channel is brought down (like stop_ap, leave_ibss
and leave_mesh) in non-ETSI domain.
This allows user space to start/stop NAN interface.
A NAN interface is like P2P device in a few aspects: it
doesn't have a netdev associated to it.
Add the new interface type and prevent operations that
can't be executed on NAN interface like scan.
Define several attributes that may be configured by user space
when starting NAN functionality (master preference and dual
band operation)
Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Pull networking fixes from David Miller:
1) Buffers powersave frame test is reversed in cfg80211, fix from Felix
Fietkau.
2) Remove bogus WARN_ON in openvswitch, from Jarno Rajahalme.
3) Fix some tg3 ethtool logic bugs, and one that would cause no
interrupts to be generated when rx-coalescing is set to 0. From
Satish Baddipadige and Siva Reddy Kallam.
4) QLCNIC mailbox corruption and napi budget handling fix from Manish
Chopra.
5) Fix fib_trie logic when walking the trie during /proc/net/route
output than can access a stale node pointer. From David Forster.
6) Several sctp_diag fixes from Phil Sutter.
7) PAUSE frame handling fixes in mlxsw driver from Ido Schimmel.
8) Checksum fixup fixes in bpf from Daniel Borkmann.
9) Memork leaks in nfnetlink, from Liping Zhang.
10) Use after free in rxrpc, from David Howells.
11) Use after free in new skb_array code of macvtap driver, from Jason
Wang.
12) Calipso resource leak, from Colin Ian King.
13) mediatek bug fixes (missing stats sync init, etc.) from Sean Wang.
14) Fix bpf non-linear packet write helpers, from Daniel Borkmann.
15) Fix lockdep splats in macsec, from Sabrina Dubroca.
16) hv_netvsc bug fixes from Vitaly Kuznetsov, mostly to do with VF
handling.
17) Various tc-action bug fixes, from CONG Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits)
net_sched: allow flushing tc police actions
net_sched: unify the init logic for act_police
net_sched: convert tcf_exts from list to pointer array
net_sched: move tc offload macros to pkt_cls.h
net_sched: fix a typo in tc_for_each_action()
net_sched: remove an unnecessary list_del()
net_sched: remove the leftover cleanup_a()
mlxsw: spectrum: Allow packets to be trapped from any PG
mlxsw: spectrum: Unmap 802.1Q FID before destroying it
mlxsw: spectrum: Add missing rollbacks in error path
mlxsw: reg: Fix missing op field fill-up
mlxsw: spectrum: Trap loop-backed packets
mlxsw: spectrum: Add missing packet traps
mlxsw: spectrum: Mark port as active before registering it
mlxsw: spectrum: Create PVID vPort before registering netdevice
mlxsw: spectrum: Remove redundant errors from the code
mlxsw: spectrum: Don't return upon error in removal path
i40e: check for and deal with non-contiguous TCs
ixgbe: Re-enable ability to toggle VLAN filtering
ixgbe: Force VLNCTRL.VFE to be set in all VMDq paths
The use of config_enabled() against config options is ambiguous. In
practical terms, config_enabled() is equivalent to IS_BUILTIN(), but the
author might have used it for the meaning of IS_ENABLED(). Using
IS_ENABLED(), IS_BUILTIN(), IS_MODULE() etc. makes the intention
clearer.
This commit replaces config_enabled() with IS_ENABLED() where possible.
This commit is only touching bool config options.
I noticed two cases where config_enabled() is used against a tristate
option:
- config_enabled(CONFIG_HWMON)
[ drivers/net/wireless/ath/ath10k/thermal.c ]
- config_enabled(CONFIG_BACKLIGHT_CLASS_DEVICE)
[ drivers/gpu/drm/gma500/opregion.c ]
I did not touch them because they should be converted to IS_BUILTIN()
in order to keep the logic, but I was not sure it was the authors'
intention.
Link: http://lkml.kernel.org/r/1465215656-20569-1-git-send-email-yamada.masahiro@socionext.com
Cc: Stas Sergeev <stsp@list.ru>
Cc: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Joshua Kinard <kumba@gentoo.org>
Cc: Jiri Slaby <jslaby@suse.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: "Dmitry V. Levin" <ldv@altlinux.org>
Cc: yu-cheng yu <yu-cheng.yu@intel.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Will Drewry <wad@chromium.org>
Cc: Nikolay Martynov <mar.kolya@gmail.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Rafal Milecki <zajec5@gmail.com>
Cc: James Cowgill <James.Cowgill@imgtec.com>
Cc: Alex Smith <alex.smith@imgtec.com>
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Mikko Rapeli <mikko.rapeli@iki.fi>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
Cc: "Luis R. Rodriguez" <mcgrof@do-not-panic.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Roland McGrath <roland@hack.frob.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Tony Wu <tung7970@gmail.com>
Cc: Huaitong Han <huaitong.han@intel.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Juergen Gross <jgross@suse.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrea Gelmini <andrea.gelmini@gelma.net>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Rabin Vincent <rabin@rab.in>
Cc: "Maciej W. Rozycki" <macro@imgtec.com>
Cc: David Daney <david.daney@cavium.com>
The switch on chandef->width is missing a break on the
NL8211_CHAN_WIDTH_80P80 case; currently we get a WARN_ON when
center_freq2 is non-zero because of the missing break.
There's no harm in having drivers read the list, since they can
use RCU protection or RTNL locking; allow this to not require
each and every driver to also implement its own bookkeeping.
This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
The RTNL is required to check for IR-relaxation conditions that allow
more channels to beacon. Export an RTNL locked version of reg_can_beacon
and use it where possible in AP/STA interface type flows, where
IR-relaxation may be applicable.
Fixes: 06f207fc5418 ("cfg80211: change GO_CONCURRENT to IR_CONCURRENT for STA")
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
The GO_CONCURRENT regulatory definition can be extended to station
interfaces requesting to IR as part of TDLS off-channel operations.
Rename the GO_CONCURRENT flag to IR_CONCURRENT and allow the added
use-case.
Change internal users of GO_CONCURRENT to use the new definition.
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
If a P2P GO was allowed on a channel because of the GO concurrent
relaxation, i.e., another station interface was associated to an AP on
the same channel or the same UNII band, and the station interface
disconnected from the AP, allow the following use cases unless the
channel is marked as indoor only and the device is not operating in an
indoor environment:
1. Allow the P2P GO to stay on its current channel. The rationale behind
this is that if the channel or UNII band were allowed by the AP they
could still be used to continue the P2P GO operation, and avoid connection
breakage.
2. Allow another P2P GO to start on the same channel or another channel
that is in the same UNII band as the previous instantiated P2P GO.
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
The VHT supported channel width field is a two bit integer, not a
bitfield. cfg80211_chandef_usable() was interpreting it incorrectly and
ended up rejecting 160 MHz channel width if the driver indicated support
for both 160 and 80+80 MHz channels.
Cc: stable@vger.kernel.org (3.16+)
Fixes: 3d9d1d6656a73 ("nl80211/cfg80211: support VHT channel configuration")
(however, no real drivers had 160 MHz support it until 3.16)
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
This patch adds new iface type (NL80211_IFTYPE_OCB) representing
the OCB (Outside the Context of a BSS) mode.
When establishing a connection to the network a cfg80211_join_ocb
function is called (particular nl80211_command is added as well).
A mandatory parameters during the ocb_join operation are 'center
frequency' and 'channel width (5/10 MHz)'.
Changes done in mac80211 are minimal possible required to avoid
many warnings (warning: enumeration value 'NL80211_IFTYPE_OCB'
not handled in switch) during compilation. Full functionality
(where needed) is added in the following patch.
Signed-off-by: Rostislav Lisovy <rostislav.lisovy@fel.cvut.cz>
The helper function can't ever create negative values, so use
u32 pointers as the function arguments as the caller does.
Our legal structure changed at some point (see wikipedia), but
we forgot to immediately switch over to the new copyright
notice.
For files that we have modified in the time since the change,
add the proper copyright notice now.
There is no need to pass NL80211_IFTYPE_UNSPECIFIED when calling
cfg80211_chandef_dfs_required() since we always already have the
interface type. So, pass the actual interface type instead.
Additionally, have cfg80211_chandef_dfs_required() WARN if the passed
interface type is NL80211_IFTYPE_UNSPECIFIED, so we can detect
problems more easily.
Tested-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
Reported-by: Eliad Peller <eliad@wizery.com>
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
After patch:
cfg80211/mac80211: refactor cfg80211_chandef_dfs_required()
start_radar_detection always fail with -EINVAL.
Acked-by: Luciano Coelho <luciano.coelho@intel.com>
Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
Since there are frequency bands (e.g. 5.9GHz) allowing channels
with only 10 or 5 MHz bandwidth, this patch adds attributes that
allow keeping track about this information.
When channel attributes are reported to user-space, make sure to
not break old tools, i.e. if the 'split wiphy dump' is enabled,
report the extra attributes (if present) describing the bandwidth
restrictions. If the 'split wiphy dump' is not enabled,
completely omit those channels that have flags set to either
IEEE80211_CHAN_NO_10MHZ or IEEE80211_CHAN_NO_20MHZ.
Add the check for new bandwidth restriction flags in
cfg80211_chandef_usable() to comply with the restrictions.
Name wiphy_to_rdev is more accurate to describe what the function
does, i.e., return a pointer pointing to struct
cfg80211_registered_device.
Signed-off-by: Zhao, Gang <gamerh2o@gmail.com>
At some locations, channels 149-165 are considered a single
bundle, while at some other locations, e.g., Indonesia, channels
149-161 are considered a single bundle, while channel 165 belongs
to a different bundle. This means that:
1. A station interface connection to an AP on channel 165 allows
the instantiation of a P2P GO on channels 149-165.
2. A station interface connection to an AP on channels 149-161
does NOT allow the instantiation of a P2P GO on channel 165.
Fix this.
Some interface types don't require DFS (such as STATION, P2P_CLIENT
etc). In order to centralize these decisions, make
cfg80211_chandef_dfs_required() take the iftype into consideration.
Allow GO operation on a channel marked with IEEE80211_CHAN_INDOOR_ONLY
iff there is a user hint indicating that the platform is operating in
an indoor environment, i.e., the platform is a printer or media center
device.
Allow GO operation on a channel marked with IEEE80211_CHAN_GO_CONCURRENT
iff there is an active station interface that is associated to
an AP operating on the same channel in the 2 GHz band or the same UNII band
(in the 5 GHz band). This relaxation is not allowed if the channel is
marked with IEEE80211_CHAN_RADAR.
Note that this is a permissive approach to the FCC definitions,
that require a clear assessment that the device operating the AP is
an authorized master, i.e., with radar detection and DFS capabilities.
It is assumed that such restrictions are enforced by user space.
Furthermore, it is assumed, that if the conditions that allowed for
the operation of the GO on such a channel change, i.e., the station
interface disconnected from the AP, it is the responsibility of user
space to evacuate the GO from the channel.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
drivers/net/wireless/ath/ath9k/recv.c
Send Channel Availability Check time as a parameter
of start_radar_detection() callback.
Get CAC time from regulatory database.
One of my pet coding style peeves is the practice of
adding extra return; at the end of function.
Kill several instances of this in network code.
I suppose some coccinelle wizardy could do this automatically.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
There's no driver using this flag and consequently no userspace
application is actually looking at it. As it seems unlikely for
any driver to start using it, remove it and the (very little)
code that used it.
It was possible to break interface combinations in
the following way:
combo 1: iftype = AP, num_ifaces = 2, num_chans = 2,
combo 2: iftype = AP, num_ifaces = 1, num_chans = 1, radar = HT20
With the above interface combinations it was
possible to:
step 1. start AP on DFS channel by matching combo 2
step 2. start AP on non-DFS channel by matching combo 1
This was possible beacuse (step 2) did not consider
if other interfaces require radar detection.
The patch changes how cfg80211 tracks channels -
instead of channel itself now a complete chandef
is stored.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
Allow beconing after we pass Channel Availability Check (CAC).
Allow non-DFS and DFS channels mix. All DFS channels have to
be in NL80211_DFS_AVAILABLE state (pass CAC).
Improve readability of the function by adding the break,
there's no functional impact but it's confusing to fall
through.
Check chandef we get in CAC request is usable for CAC.
All channels have to be DFS channels. Allow DFS_USABLE
and DFS_AVAILABLE channels mix. At least one channel
has to be DFS_USABLE (require CAC).
Reviewed-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Add helper fuctions for start/end freq.
These two flags are used for the same purpose, just
combine them into a no-ir flag to annotate no initiating
radiation is allowed.
Old userspace sending either flag will have it treated as
the no-ir flag. To be considerate to older userspace we
also send both the no-ir flag and the old no-ibss flags.
Newer userspace will have to be aware of older kernels.
Update all places in the tree using these flags with the
following semantic patch:
-NL80211_RRF_PASSIVE_SCAN
+NL80211_RRF_NO_IR
-NL80211_RRF_NO_IBSS
+NL80211_RRF_NO_IR
-IEEE80211_CHAN_PASSIVE_SCAN
+IEEE80211_CHAN_NO_IR
-IEEE80211_CHAN_NO_IBSS
-NL80211_RRF_NO_IR | NL80211_RRF_NO_IR
+NL80211_RRF_NO_IR
-IEEE80211_CHAN_NO_IR | IEEE80211_CHAN_NO_IR
-(NL80211_RRF_NO_IR)
+NL80211_RRF_NO_IR
-(IEEE80211_CHAN_NO_IR)
Along with some hand-optimisations in documentation, to
remove duplicates and to fix some indentation.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
[do all the driver updates in one go]
To use DFS in IBSS mode, userspace is required to react to radar events.
It can inform nl80211 that it is capable of doing so by adding a
NL80211_ATTR_HANDLE_DFS attribute when joining the IBSS.
This attribute is supplied to let the kernelspace know that the
userspace application can and will handle radar events, e.g. by
intiating channel switches to a valid channel. DFS channels may
only be used if this attribute is supplied and the driver supports
it. Driver support will be checked even if a channel without DFS
will be initially joined, as a DFS channel may be chosen later.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
[fix attribute name in commit message]
It will be used later by the IBSS CSA implementation of mac80211.
Add defines for 5 and 10 MHz channel width and fix channel
handling functions accordingly.
Also check for and report the WIPHY_FLAG_SUPPORTS_5_10_MHZ
capability.
[fix spelling in comment]
Some drivers might support 80 or 160 MHz only on some
channels for whatever reason, so allow them to disable
these channel widths. Also maintain the new flags when
regulatory bandwidth limitations would disable these
wide channels.
Add new NL80211_CMD_RADAR_DETECT, which starts the Channel
Availability Check (CAC). This command will also notify the
usermode about events (CAC finished, CAC aborted, radar
detected, NOP finished).
Once radar detection has started it should continuously
monitor for radars as long as the channel is active.
This patch enables DFS for AP mode in nl80211/cfg80211.
Based on original patch by Victor Goldenshtein <victorg@ti.com>
[remove WIPHY_FLAG_HAS_RADAR_DETECT again -- my mistake]
In that case, it's really a 160 MHz channel, so disallow
this configuration.
For channels wider than 20 MHz OFDM will be used, so when
checking whether or not a channel is usable, check for the
no-OFDM flag if the channel is wider than 20 MHz.
Some of the chandef checking that we do in cfg80211
to check if a channel is supported or not is also
needed in mac80211, so rework that a bit and export
the functions that are needed.
Change nl80211 to support specifying a VHT (or HT)
using the control channel frequency (as before) and
new attributes for the channel width and first and
second center frequency. The old channel type is of
course still supported for HT.
Also change the cfg80211 channel definition struct
to support these by adding the relevant fields to
it (and removing the _type field.)
This also adds new helper functions:
- cfg80211_chandef_create to create a channel def
struct given the control channel and channel type,
- cfg80211_chandef_identical to check if two channel
definitions are identical
- cfg80211_chandef_compatible to check if the given
channel definitions are compatible, and return the
wider of the two
This isn't entirely complete, but that doesn't matter
until we have a driver using it. In particular, it's
missing
- regulatory checks on the usable bandwidth (if that
even makes sense)
- regulatory TX power (database can't deal with it)
- a proper channel compatibility calculation for the
new channel types
Instead of passing a channel pointer and channel type
to all functions and driver methods, pass a new channel
definition struct. Right now, this struct contains just
the control channel and channel type, but for VHT this
will change.
Also, add a small inline cfg80211_get_chandef_type() so
that drivers don't need to use the _type field of the
new structure all the time, which will change.
Also add tracing to the API functions that drivers
(and mac80211) can call in cfg80211.
Signed-off-by: Beni Lev <beni.lev@intel.com>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This will allow adding central tracing like in mac80211.
Signed-off-by: Hila Gonen <hila.gonen@intel.com>
In order to support using a different MAC address
for the P2P Device address we must first have a
P2P Device abstraction that can be assigned a MAC
address.
This abstraction will also be useful to support
offloading P2P operations to the device, e.g.
periodic listen for discoverability.
Currently, the driver is responsible for assigning
a MAC address to the P2P Device, but this could be
changed by allowing a MAC address to be given to
the NEW_INTERFACE command.
As it has no associated netdev, a P2P Device can
only be identified by its wdev identifier but the
previous patches allowed using the wdev identifier
in various APIs, e.g. remain-on-channel.
