path: root/net/wireless/core.c
2010-10-11Revert "wireless: Use first phyX name available when registering phy devices."Johannes Berg
This reverts commit 5a254ffe3ffdfa84fe076009bd8e88da412180d2. The commit failed to take into account that allocated wireless devices (wiphys) are not added into the device list upon allocation, but only when they are registered. Therefore, it opened up a race between allocating and registering a name, so that if two processes allocate and register concurrently ("alloc, alloc, register, register" rather than "alloc, register, alloc, register") the code will attempt to use the same name twice. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2010-10-05wireless: Use first phyX name available when registering phy devices.Ben Greear
Choose first available phyX name when creating phy devices. This means that reloading a wifi driver will not cause a change in the name of it's phy device. Also, allow users to rename a phy to any un-used name, including phy%d. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/ath/ath5k/base.c net/mac80211/main.c
2010-09-16cfg80211/nl80211: introduce p2p device typesJohannes Berg
This adds P2P-STA and P2P-GO as device types so we can distinguish between those and normal STA or AP (respectively) type interfaces. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-16include/net/cfg80211.h: wiphy_<level> messages use dev_printkJoe Perches
The output becomes: [ 41.261941] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-31wireless: register wiphy rfkill w/o holding cfg80211_mutexJohn W. Linville
Otherwise lockdep complains... https://bugzilla.kernel.org/show_bug.cgi?id=17311 [ INFO: possible circular locking dependency detected ] 2.6.36-rc2-git4 #12 ------------------------------------------------------- kworker/0:3/3630 is trying to acquire lock: (rtnl_mutex){+.+.+.}, at: [<ffffffff813396c7>] rtnl_lock+0x12/0x14 but task is already holding lock: (rfkill_global_mutex){+.+.+.}, at: [<ffffffffa014b129>] rfkill_switch_all+0x24/0x49 [rfkill] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (rfkill_global_mutex){+.+.+.}: [<ffffffff81079ad7>] lock_acquire+0x120/0x15b [<ffffffff813ae869>] __mutex_lock_common+0x54/0x52e [<ffffffff813aede9>] mutex_lock_nested+0x34/0x39 [<ffffffffa014b4ab>] rfkill_register+0x2b/0x29c [rfkill] [<ffffffffa0185ba0>] wiphy_register+0x1ae/0x270 [cfg80211] [<ffffffffa0206f01>] ieee80211_register_hw+0x1b4/0x3cf [mac80211] [<ffffffffa0292e98>] iwl_ucode_callback+0x9e9/0xae3 [iwlagn] [<ffffffff812d3e9d>] request_firmware_work_func+0x54/0x6f [<ffffffff81065d15>] kthread+0x8c/0x94 [<ffffffff8100ac24>] kernel_thread_helper+0x4/0x10 -> #1 (cfg80211_mutex){+.+.+.}: [<ffffffff81079ad7>] lock_acquire+0x120/0x15b [<ffffffff813ae869>] __mutex_lock_common+0x54/0x52e [<ffffffff813aede9>] mutex_lock_nested+0x34/0x39 [<ffffffffa018605e>] cfg80211_get_dev_from_ifindex+0x1b/0x7c [cfg80211] [<ffffffffa0189f36>] cfg80211_wext_giwscan+0x58/0x990 [cfg80211] [<ffffffff8139a3ce>] ioctl_standard_iw_point+0x1a8/0x272 [<ffffffff8139a529>] ioctl_standard_call+0x91/0xa7 [<ffffffff8139a687>] T.723+0xbd/0x12c [<ffffffff8139a727>] wext_handle_ioctl+0x31/0x6d [<ffffffff8133014e>] dev_ioctl+0x63d/0x67a [<ffffffff8131afd9>] sock_ioctl+0x48/0x21d [<ffffffff81102abd>] do_vfs_ioctl+0x4ba/0x509 [<ffffffff81102b5d>] sys_ioctl+0x51/0x74 [<ffffffff81009e02>] system_call_fastpath+0x16/0x1b -> #0 (rtnl_mutex){+.+.+.}: [<ffffffff810796b0>] __lock_acquire+0xa93/0xd9a [<ffffffff81079ad7>] lock_acquire+0x120/0x15b [<ffffffff813ae869>] __mutex_lock_common+0x54/0x52e [<ffffffff813aede9>] mutex_lock_nested+0x34/0x39 [<ffffffff813396c7>] rtnl_lock+0x12/0x14 [<ffffffffa0185cb5>] cfg80211_rfkill_set_block+0x1a/0x7b [cfg80211] [<ffffffffa014aed0>] rfkill_set_block+0x80/0xd5 [rfkill] [<ffffffffa014b07e>] __rfkill_switch_all+0x3f/0x6f [rfkill] [<ffffffffa014b13d>] rfkill_switch_all+0x38/0x49 [rfkill] [<ffffffffa014b821>] rfkill_op_handler+0x105/0x136 [rfkill] [<ffffffff81060708>] process_one_work+0x248/0x403 [<ffffffff81062620>] worker_thread+0x139/0x214 [<ffffffff81065d15>] kthread+0x8c/0x94 [<ffffffff8100ac24>] kernel_thread_helper+0x4/0x10 Signed-off-by: John W. Linville <linville@tuxdriver.com> Acked-by: Johannes Berg <johannes@sipsolutions.net>
2010-08-24cfg80211/mac80211: extensible frame processingJohannes Berg
Allow userspace to register for more than just action frames by giving the frame subtype, and make it possible to use this in various modes as well. With some tweaks and some added functionality this will, in the future, also be usable in AP mode and be able to replace the cooked monitor interface currently used in that case. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16cfg80211: support sysfs namespacesJohannes Berg
Enable using network namespaces with wireless devices even when sysfs is enabled using the same infrastructure that was built for netdevs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-27wireless: Convert wiphy_debug macro to functionJoe Perches
Save a few bytes of text (allyesconfig) $ size drivers/net/wireless/built-in.o* text data bss dec hex filename 3924568 100548 871056 4896172 4ab5ac drivers/net/wireless/built-in.o.new 3926520 100548 871464 4898532 4abee4 drivers/net/wireless/built-in.o.old $ size net/wireless/core.o* text data bss dec hex filename 12843 216 3768 16827 41bb net/wireless/core.o.new 12328 216 3656 16200 3f48 net/wireless/core.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-21cfg80211: fix race between sysfs and cfg80211Maxime Bizon
device_add() is called before adding the phy to the cfg80211 device list. So if a userspace program uses sysfs uevents to detect new phy devices, and queries nl80211 to get phy info, it can get ENODEV even though the phy exists in sysfs. An easy workaround is to hold the cfg80211 mutex until the phy is present in sysfs/cfg80211/debugfs. Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-18cfg80211: move cfg80211_exit to .exit.textUwe Kleine-König
cfg80211_exit is only used as module_exit function, so it can go to .exit.text saving a few bytes when CONFIG_CFG80211=y. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-04-27cfg80211: Remove default dynamic PS timeout valueJuuso Oikarinen
Now that the mac80211 is choosing dynamic ps timeouts based on the ps-qos network latency configuration, configure a default value of -1 as the dynamic ps timeout in cfg80211. This value allows the mac80211 to determine the value to be used. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-19nl80211: add power save commandsKalle Valo
The most needed command from nl80211, which Wireless Extensions had, is support for power save mode. Add a simple command to make it possible to enable and disable power save via nl80211. I was also planning about extending the interface, for example adding the timeout value, but after thinking more about this I decided not to do it. Basically there were three reasons: Firstly, the parameters for power save are very much hardware dependent. Trying to find a unified interface which would work with all hardware, and still make sense to users, will be very difficult. Secondly, IEEE 802.11 power save implementation in Linux is still in state of flux. We have a long way to still to go and there is no way to predict what kind of implementation we will have after few years. And because we need to support nl80211 interface a long time, practically forever, adding now parameters to nl80211 might create maintenance problems later on. Third issue are the users. Power save parameters are mostly used for debugging, so debugfs is better, more flexible, interface for this. For example, wpa_supplicant currently doesn't configure anything related to power save mode. It's better to strive that kernel can automatically optimise the power save parameters, like with help of pm qos network and other traffic parameters. Later on, when we have better understanding of power save, we can extend this command with more features, if there's a need for that. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-15cfg80211/mac80211: allow registering for and sending action framesJouni Malinen
This implements a new command to register for action frames that userspace wants to handle instead of the in-kernel rejection. It is then responsible for rejecting ones that it decided not to handle. There is no unregistration, but the socket can be closed for that. Frames that are not registered for will not be forwarded to userspace and will be rejected by the kernel, the cfg80211 API helps implementing that. Additionally, this patch adds a new command that allows doing action frame transmission from userspace. It can be used either to exchange action frames on the current operational channel (e.g., with the AP with which we are currently associated) or to exchange off-channel Public Action frames with the remain-on-channel command. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-22cfg80211: export multiple MAC addresses in sysfsJohannes Berg
If a device has multiple MAC addresses, userspace will need to know about that. Similarly, if it allows the MAC addresses to vary by a bitmask. If a driver exports multiple addresses, it is assumed that it will be able to deal with that many different addresses, which need not necessarily match the ones programmed into the device; if a mask is set then the device should deal addresses within that mask based on an arbitrary "base address". To test it all and show how it is used, add support to hwsim even though it can't actually deal with addresses different from the default. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19cfg80211: rcu-ify rdev and wdevJohannes Berg
Future code will need to look up rdev and wdev within atomic sections, but currently we need to lock a mutex for such lookups. Change the list handling for both to be RCU-safe so that we can look them up in rcu sections instead in the future. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6John W. Linville
2010-01-12nl80211: Add new WIPHY attribute COVERAGE_CLASSLukáš Turek
The new attribute NL80211_ATTR_WIPHY_COVERAGE_CLASS sets IEEE 802.11 Coverage Class, which depends on maximum distance of nodes in a wireless network. It's required for long distance links (more than a few hundred meters). The attribute is now ignored by two non-mac80211 drivers, rndis and iwmc3200wifi, together with WIPHY_PARAM_RETRY_SHORT and WIPHY_PARAM_RETRY_LONG. If it turns out to be a problem, we could split set_wiphy_params callback or add new capability bits. Signed-off-by: Lukas Turek <8an@praha12.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-11cfg80211: fix refcount imbalance when wext is disabledJohannes Berg
When CONFIG_CFG80211_WEXT is not set, there is a refcount imbalance with rdev->opencount, fix that by moving it out of the ifdef. Reported-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-28wireless : use a dedicated workqueue for cfg80211.Alban Browaeys
This patch moves the works cleanup, scan and events to a cfg80211 dedicated workqueue. Platform driver like eeepc-laptop ought to use works to rfkill (as new rfkill does lock in rfkill_unregister and the platform driver is called from rfkill_switch_all which also lock the same mutex). This raise a new issue in itself that the work scheduled by the platform driver to the global worqueue calls wiphy_unregister which flush_work scan and event works (which thus flush works on the global workqueue inside a work on the global workqueue) and also put on hold the wdev_cleanup_work (which prevents the dev_put on netdev thus indefinite Usage count error on wifi device). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Alban Browaeys <prahal@yahoo.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-24Merge branch 'master' of ↵David S. Miller
2009-11-19cfg80211: disallow bridging managed/adhoc interfacesJohannes Berg
A number of people have tried to add a wireless interface (in managed mode) to a bridge and then complained that it doesn't work. It cannot work, however, because in 802.11 networks all packets need to be acknowledged and as such need to be sent to the right address. Promiscuous doesn't help here. The wireless address format used for these links has only space for three addresses, the * transmitter, which must be equal to the sender (origin) * receiver (on the wireless medium), which is the AP in the case of managed mode * the recipient (destination), which is on the APs local network segment In an IBSS, it is similar, but the receiver and recipient must match and the third address is used as the BSSID. To avoid such mistakes in the future, disallow adding a wireless interface to a bridge. Felix has recently added a four-address mode to the AP and client side that can be used (after negotiating that it is possible, which must happen out-of-band by setting up both sides) for bridging, so allow that case. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: convert bools into flagsJohannes Berg
We've accumulated a number of options for wiphys which make more sense as flags as we keep adding more. Convert the existing ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-10-30cfg80211/mac80211: use debugfs_remove_recursiveJohannes Berg
We can save a lot of code and pointers in the structs by using debugfs_remove_recursive(). First, change cfg80211 to use debugfs_remove_recursive() so that drivers do not need to clean up any files they added to the per-wiphy debugfs (if and only if they are ok to be accessed until after wiphy_unregister!). Then also make mac80211 use debugfs_remove_recursive() where necessary -- it need not remove per-wiphy files as cfg80211 now removes those, but netdev etc. files still need to be handled but can now be removed without needing struct dentry pointers to all of them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-07wireless: implement basic ethtool support for cfg80211 devicesJohn W. Linville
2009-10-07wext: refactorJohannes Berg
Refactor wext to * split out iwpriv handling * split out iwspy handling * split out procfs support * allow cfg80211 to have wireless extensions compat code w/o CONFIG_WIRELESS_EXT After this, drivers need to - select WIRELESS_EXT - for wext support - select WEXT_PRIV - for iwpriv support - select WEXT_SPY - for iwspy support except cfg80211 -- which gets new hooks in wext-core.c and can then get wext handlers without CONFIG_WIRELESS_EXT. Wireless extensions procfs support is auto-selected based on PROC_FS and anything that requires the wext core (i.e. WIRELESS_EXT or CFG80211_WEXT). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-05cfg80211: assign device type in netdev notifier callbackMarcel Holtmann
Instead of having to modify every non-mac80211 for device type assignment, do this inside the netdev notifier callback of cfg80211. So all drivers that integrate with cfg80211 will export a proper device type. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-28cfg80211: clean up properly on interface type changeJohannes Berg
When the interface type changes while connected, and the driver does not require the interface to be down for a type change, it is currently possible to get very strange results unless the driver takes special care, which it shouldn't have to. To fix this, take care to disconnect/leave IBSS when changing the interface type -- even if the driver may fail the call. Also process all events that may be pending to avoid running into a situation where an event is reported but only processed after the type has already changed, which would lead to missing events and warnings. A side effect of this is that you will have disconnected or left the IBSS even if the mode change ultimately fails, but since the intention was to change it and thus leave or disconnect, this is not a problem. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28cfg80211: check lost scans later, fix bugJohannes Berg
When we lose a scan, cfg80211 tries to clean up after the driver. However, it currently does this too early, it does this in GOING_DOWN already instead of DOWN, so it may happen with mac80211. Besides fixing this, also make it more robust by leaking the scan request so if the driver later actually finishes the scan, it won't crash. Also check in ___cfg80211_scan_done whether a scan request is still pending and exit if not. Reported-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20cfg80211: allow cfg80211_connect_result with bssid == NULLZhu Yi
In case of connection failure, the bssid info is not a must have. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20cfg80211: fix dangling scan request checkingJohannes Berg
My patch "cfg80211: fix deadlock" broke the code it was supposed to fix, the scan request checking. But it's not trivial to put it back the way it was, since the original patch had a deadlock. Now do it in a completely new way: queue the check off to a work struct, where we can freely lock. But that has some more complications, like needing to wait for it to be done before the wiphy/rdev can be destroyed, so some code is required to handle that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20cfg80211: fix deadlockJohannes Berg
When removing an interface with nl80211, cfg80211 will deadlock in the netdev notifier because we're already holding rdev->mtx and try to acquire it again to verify the scan has been done. This bug was introduced by my patch "cfg80211: check for and abort dangling scan requests". To fix this, move the dangling scan request check into wiphy_unregister(). This will not be able to catch all cases right away, but if the scan problem happens with a manual ifdown or so it will be possible to remedy it by removing the module/device. Additionally, add comments about the deadlock scenario. Reported-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Christian Lamparter <chunkeey@web.de> Tested-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: allow driver to override PS defaultJohannes Berg
Sometimes drivers might have a good reason to override the PS default, like iwlwifi right now where it affects RX performance significantly at this point. This will allow them to override the default, if desired, in a way that users can still change it according to their trade-off choices, not the driver's, like would happen if the driver just disabled PS completely then. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: check for and abort dangling scan requestsJohannes Berg
If you trigger a scan request on an interface and then take it down, or rmmod the module or unplug the device the driver might "forget" to cancel the scan request. That is a bug in the driver, but the current behaviour is that we just hang endlessly waiting for the netdev refcount to become 0 which it never will. To improve robustness, check for this situation in cfg80211, warn about it and clean up behind the driver. I don't just clean up silently because it's likely that the driver also has some internal state it has now leaked. Additionally, this fixes a locking bug, clearing the scan_req pointer should be done under the rdev lock. Finally, we also need to _wait_ for the scan work and not just abort it since it might be pending and wanting to do a cleanup. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: add missing device list lockingJohannes Berg
When calling into the wext code from the NETDEV_UP notifier, we need to hold the devlist_mtx mutex as the wext code ends up calling into channel checks. Reported-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14nl80211: add generation number to all dumpsJohannes Berg
In order for userspace to be able to figure out whether it obtained a consistent snapshot of data or not when using netlink dumps, we need to have a generation number in each dump message that indicates whether the list has changed or not -- its value is arbitrary. This patch adds such a number to all dumps, this needs some mac80211 involvement to keep track of a generation number to start with when adding/removing mesh paths or stations. The wiphy and netdev lists can be fully handled within cfg80211, of course, but generation numbers need to be stored there as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04cfg80211: lower dynamic PS timeout to 100msJohannes Berg
The default of 500ms is pretty high, and leads to the device being awake at least 50% of the time under such light traffic conditions as a simple 1 second interval ping. Reduce to just 100ms -- it should have a similar effect while providing a better sleep time. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04cfg80211: decouple regulatory variables from cfg80211_mutexLuis R. Rodriguez
We change regulatory code to be protected by its own regulatory mutex and alleviate cfg80211_mutex to only be used to protect cfg80211_rdev_list, the registered device list. By doing this we will be able to work on regulatory core components without having to have hog up the cfg80211_mutex. An example here is we no longer need to use the cfg80211_mutex during driver specific wiphy_apply_custom_regulatory(). We also no longer need it for the the country IE regulatory hint; by doing so we end up curing this new lockdep warning: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.31-rc4-wl #12 ------------------------------------------------------- phy1/1709 is trying to acquire lock: (cfg80211_mutex){+.+.+.}, at: [<ffffffffa00af852>] regulatory_hint_11d+0x32/0x3f0 [cfg80211] but task is already holding lock: (&ifmgd->mtx){+.+.+.}, at: [<ffffffffa0144228>] ieee80211_sta_work+0x108/0x10f0 [mac80211] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #3 (&ifmgd->mtx){+.+.+.}: [<ffffffff810857b6>] __lock_acquire+0xd76/0x12b0 [<ffffffff81085dd3>] lock_acquire+0xe3/0x120 [<ffffffff814eeae4>] mutex_lock_nested+0x44/0x350 [<ffffffffa0141bb8>] ieee80211_mgd_auth+0x108/0x1f0 [mac80211] [<ffffffffa0148563>] ieee80211_auth+0x13/0x20 [mac80211] [<ffffffffa00bc3a1>] __cfg80211_mlme_auth+0x1b1/0x2a0 [cfg80211] [<ffffffffa00bc516>] cfg80211_mlme_auth+0x86/0xc0 [cfg80211] [<ffffffffa00b368d>] nl80211_authenticate+0x21d/0x230 [cfg80211] [<ffffffff81416ba6>] genl_rcv_msg+0x1b6/0x1f0 [<ffffffff81415c39>] netlink_rcv_skb+0x89/0xb0 [<ffffffff814169d9>] genl_rcv+0x29/0x40 [<ffffffff8141591d>] netlink_unicast+0x29d/0x2b0 [<ffffffff81416514>] netlink_sendmsg+0x214/0x300 [<ffffffff813e4407>] sock_sendmsg+0x107/0x130 [<ffffffff813e45b9>] sys_sendmsg+0x189/0x320 [<ffffffff81011f82>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff -> #2 (&wdev->mtx){+.+.+.}: [<ffffffff810857b6>] __lock_acquire+0xd76/0x12b0 [<ffffffff81085dd3>] lock_acquire+0xe3/0x120 [<ffffffff814eeae4>] mutex_lock_nested+0x44/0x350 [<ffffffffa00ab304>] cfg80211_netdev_notifier_call+0x1a4/0x390 [cfg80211] [<ffffffff814f3dff>] notifier_call_chain+0x3f/0x80 [<ffffffff81075a91>] raw_notifier_call_chain+0x11/0x20 [<ffffffff813f665a>] dev_open+0x10a/0x120 [<ffffffff813f59bd>] dev_change_flags+0x9d/0x1e0 [<ffffffff8144eb6e>] devinet_ioctl+0x6fe/0x760 [<ffffffff81450204>] inet_ioctl+0x94/0xc0 [<ffffffff813e25fa>] sock_ioctl+0x6a/0x290 [<ffffffff8111e911>] vfs_ioctl+0x31/0xa0 [<ffffffff8111ea9a>] do_vfs_ioctl+0x8a/0x5c0 [<ffffffff8111f069>] sys_ioctl+0x99/0xa0 [<ffffffff81011f82>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff -> #1 (&rdev->mtx){+.+.+.}: [<ffffffff810857b6>] __lock_acquire+0xd76/0x12b0 [<ffffffff81085dd3>] lock_acquire+0xe3/0x120 [<ffffffff814eeae4>] mutex_lock_nested+0x44/0x350 [<ffffffffa00ac4d0>] cfg80211_get_dev_from_ifindex+0x60/0x90 [cfg80211] [<ffffffffa00b21ff>] get_rdev_dev_by_info_ifindex+0x6f/0xa0 [cfg80211] [<ffffffffa00b51eb>] nl80211_set_interface+0x3b/0x260 [cfg80211] [<ffffffff81416ba6>] genl_rcv_msg+0x1b6/0x1f0 [<ffffffff81415c39>] netlink_rcv_skb+0x89/0xb0 [<ffffffff814169d9>] genl_rcv+0x29/0x40 [<ffffffff8141591d>] netlink_unicast+0x29d/0x2b0 [<ffffffff81416514>] netlink_sendmsg+0x214/0x300 [<ffffffff813e4407>] sock_sendmsg+0x107/0x130 [<ffffffff813e45b9>] sys_sendmsg+0x189/0x320 [<ffffffff81011f82>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff other info that might help us debug this: 3 locks held by phy1/1709: #0: ((wiphy_name(local->hw.wiphy))){+.+.+.}, at: [<ffffffff8106b45d>] worker_thread+0x19d/0x340 #1: (&ifmgd->work){+.+.+.}, at: [<ffffffff8106b45d>] worker_thread+0x19d/0x340 #2: (&ifmgd->mtx){+.+.+.}, at: [<ffffffffa0144228>] ieee80211_sta_work+0x108/0x10f0 [mac80211] Reported-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04cfg80211: fix NETDEV_UNREGISTER notifierJohannes Berg
It's possible to get the NETDEV_UNREGISTER callback multiple times (see net/core/dev.c:netdev_wait_allrefs) and this will completely mess up our cleanup code. To avoid that, clean up only when the interface is still on the wiphy interface list from which it's removed on the first NETDEV_UNREGISTER call. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04cfg80211: keep track of current_bss for userspace SMEJohannes Berg
When a userspace SME is active, we're currently not keeping track of the BSS properly for reporting the current link and for internal use. Additionally, it looks like there is a possible BSS leak in that the BSS never gets removed from auth_bsses[]. To fix it, pass the BSS struct to __cfg80211_connect_result in this case. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-29cfg80211: self-contained wext handling where possibleJohannes Berg
Finally! This is what you've all been waiting for! This patch makes cfg80211 take care of wext emulation _completely_ by itself, drivers that don't need things cfg80211 doesn't do yet don't even need to be aware of wireless extensions. This means we can also clean up mac80211's and iwm's Kconfig and make it possible to build them w/o wext now! RIP wext. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-27cfg80211: make aware of net namespacesJohannes Berg
In order to make cfg80211/nl80211 aware of network namespaces, we have to do the following things: * del_virtual_intf method takes an interface index rather than a netdev pointer - simply change this * nl80211 uses init_net a lot, it changes to use the sender's network namespace * scan requests use the interface index, hold a netdev pointer and reference instead * we want a wiphy and its associated virtual interfaces to be in one netns together, so - we need to be able to change ns for a given interface, so export dev_change_net_namespace() - for each virtual interface set the NETIF_F_NETNS_LOCAL flag, and clear that flag only when the wiphy changes ns, to disallow breaking this invariant * when a network namespace goes away, we need to reparent the wiphy to init_net * cfg80211 users that support creating virtual interfaces must create them in the wiphy's namespace, currently this affects only mac80211 The end result is that you can now switch an entire wiphy into a different network namespace with the new command iw phy#<idx> set netns <pid> and all virtual interfaces will follow (or the operation fails). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24cfg80211: fix unregistrationJohannes Berg
The work that we cancel there requires the cfg80211_mutex, so we can't cancel it under the mutex, which is fine, we can just move it to after the locked section. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24cfg80211: rework key operationJohannes Berg
This reworks the key operation in cfg80211, and now only allows, from userspace, configuring keys (via nl80211) after the connection has been established (in managed mode), the IBSS been joined (in IBSS mode), at any time (in AP[_VLAN] modes) or never for all the other modes. In order to do shared key authentication correctly, it is now possible to give a WEP key to the AUTH command. To configure static WEP keys, these are given to the CONNECT or IBSS_JOIN command directly, for a userspace SME it is assumed it will configure it properly after the connection has been established. Since mac80211 used to check the default key in IBSS mode to see whether or not the network is protected, it needs an update in that area, as well as an update to make use of the WEP key passed to auth() for shared key authentication. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: disallow configuring unsupported interfacesJohannes Berg
In order to force drivers to advertise their interface types, don't just disallow creating new interfaces with unadvertised types but also disallow setting them UP. Additionally, add some validation on the operations the drivers support. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: clean up naming once and for allJohannes Berg
We've named the registered devices 'drv' sometimes, thinking of "driver", which is not what it is, it's the internal representation of a wiphy, i.e. a device. Let's clean up the naming once and and use 'rdev' aka 'registered device' everywhere. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
