path: root/net/wireless/lib80211.c
2008-11-21lib80211: consolidate crypt init routinesJohn W. Linville
2008-11-21lib80211: absorb crypto bits from net/ieee80211John W. Linville
These bits are shared already between ipw2x00 and hostap, and could probably be shared both more cleanly and with other drivers. This commit simply relocates the code to lib80211 and adjusts the drivers appropriately. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: use individual buffers for printing ssid valuesJohn W. Linville
Also change escape_ssid to print_ssid to match print_mac semantics. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: escape_ssid should handle non-printablesJohn W. Linville
Also use common backslash sequences like \t, \n, \r, and \\ as well as \0. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: remove NETWORK_EMPTY_ESSID flagJohn W. Linville
It is unnecessary and of questionable value. Also remove is_empty_ssid, as it is also unnecessary. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: consolidate on a single escape_essid implementationJohn W. Linville
