[ Upstream commit efdfce7270de85a8706d1ea051bef3a7486809ff ]
Use the NL80211_KEY_IDX attribute inside the NL80211_ATTR_KEY in
NL80211_CMD_GET_KEY responses to comply with nl80211_key_policy.
This is unlikely to affect existing userspace.
Signed-off-by: Andrew Zaborowski <andrew.zaborowski@intel.com>
commit 1fab1b89e2e8f01204a9c05a39fd0b6411a48593 upstream.
Mesh path nexthop should be a ethernet address, but current validation
checks against 4 byte integers.
Cc: stable@vger.kernel.org
Fixes: 2ec600d672e74 ("nl80211/cfg80211: support for mesh, sta dumping")
Signed-off-by: Markus Theil <markus.theil@tu-ilmenau.de>
Link: https://lore.kernel.org/r/20191029093003.10355-1-markus.theil@tu-ilmenau.de
[ Upstream commit b501426cf86e70649c983c52f4c823b3c40d72a3 ]
If the interface is not in MESH mode, the command 'iw wlanx mpath del'
will cause kernel panic.
The root cause is null pointer access in mpp_flush_by_proxy(), as the
pointer 'sdata->u.mesh.mpp_paths' is NULL for non MESH interface.
Unable to handle kernel NULL pointer dereference at virtual address 00000068
PC is at _raw_spin_lock_bh+0x20/0x5c
LR is at mesh_path_del+0x1c/0x17c [mac80211]
Process iw (pid: 4537, stack limit = 0xd83e0238)
[<c021211c>] (_raw_spin_lock_bh) from [<bf8c7648>] (mesh_path_del+0x1c/0x17c [mac80211])
[<bf8c7648>] (mesh_path_del [mac80211]) from [<bf6cdb7c>] (extack_doit+0x20/0x68 [compat])
[<bf6cdb7c>] (extack_doit [compat]) from [<c05c309c>] (genl_rcv_msg+0x274/0x30c)
[<c05c309c>] (genl_rcv_msg) from [<c05c25d8>] (netlink_rcv_skb+0x58/0xac)
[<c05c25d8>] (netlink_rcv_skb) from [<c05c2e14>] (genl_rcv+0x20/0x34)
[<c05c2e14>] (genl_rcv) from [<c05c1f90>] (netlink_unicast+0x11c/0x204)
[<c05c1f90>] (netlink_unicast) from [<c05c2420>] (netlink_sendmsg+0x30c/0x370)
[<c05c2420>] (netlink_sendmsg) from [<c05886d0>] (sock_sendmsg+0x70/0x84)
[<c05886d0>] (sock_sendmsg) from [<c0589f4c>] (___sys_sendmsg.part.3+0x188/0x228)
[<c0589f4c>] (___sys_sendmsg.part.3) from [<c058add4>] (__sys_sendmsg+0x4c/0x70)
[<c058add4>] (__sys_sendmsg) from [<c0208c80>] (ret_fast_syscall+0x0/0x44)
Code: e2822c02 e2822001 e5832004 f590f000 (e1902f9f)
---[ end trace bbd717600f8f884d ]---
Signed-off-by: Miaoqing Pan <miaoqing@codeaurora.org>
Link: https://lore.kernel.org/r/1569485810-761-1-git-send-email-miaoqing@codeaurora.org
[trim useless data from commit message]
commit f88eb7c0d002a67ef31aeb7850b42ff69abc46dc upstream.
We currently don't validate the beacon head, i.e. the header,
fixed part and elements that are to go in front of the TIM
element. This means that the variable elements there can be
malformed, e.g. have a length exceeding the buffer size, but
most downstream code from this assumes that this has already
been checked.
Add the necessary checks to the netlink policy.
Fixes: ed1b6cc7f80f ("cfg80211/nl80211: add beacon settings")
Link: https://lore.kernel.org/r/1569009255-I7ac7fbe9436e9d8733439eab8acbbd35e55c74ef@changeid
commit f43e5210c739fe76a4b0ed851559d6902f20ceb1 upstream.
In a few places we don't properly initialize on-stack chandefs,
resulting in EDMG data to be non-zero, which broke things.
Additionally, in a few places we rely on the driver to init the
data completely, but perhaps we shouldn't as non-EDMG drivers
may not initialize the EDMG data, also initialize it there.
Fixes: 2a38075cd0be ("nl80211: Add support for EDMG channels")
Reported-by: Dmitry Osipenko <digetx@gmail.com>
Tested-by: Dmitry Osipenko <digetx@gmail.com>
Link: https://lore.kernel.org/r/1569239475-I2dcce394ecf873376c386a78f31c2ec8b538fa25@changeid
commit 4b2c5a14cd8005a900075f7dfec87473c6ee66fb upstream.
commit 1222a1601488 ("nl80211: Fix possible Spectre-v1 for CQM
RSSI thresholds") was incomplete and requires one more fix to
prevent accessing to rssi_thresholds[n] because user can control
rssi_thresholds[i] values to make i reach to n. For example,
rssi_thresholds = {-400, -300, -200, -100} when last is -34.
Fixes: 1222a1601488 ("nl80211: Fix possible Spectre-v1 for CQM RSSI thresholds")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Masashi Honma <masashi.honma@gmail.com>
Link: https://lore.kernel.org/r/20190908005653.17433-1-masashi.honma@gmail.com
[ Upstream commit 5dc8cdce1d722c733f8c7af14c5fb595cfedbfa8 ]
FullMAC STAs have no way to update bss channel after CSA channel switch
completion. As a result, user-space tools may provide inconsistent
channel info. For instance, consider the following two commands:
$ sudo iw dev wlan0 link
$ sudo iw dev wlan0 info
The latter command gets channel info from the hardware, so most probably
its output will be correct. However the former command gets channel info
from scan cache, so its output will contain outdated channel info.
In fact, current bss channel info will not be updated until the
next [re-]connect.
Note that mac80211 STAs have a workaround for this, but it requires
access to internal cfg80211 data, see ieee80211_chswitch_work:
/* XXX: shouldn't really modify cfg80211-owned data! */
ifmgd->associated->channel = sdata->csa_chandef.chan;
This patch suggests to convert mac80211 workaround into cfg80211 behavior
and to update current bss channel in cfg80211_ch_switch_notify.
Signed-off-by: Sergey Matyukevich <sergey.matyukevich.os@quantenna.com>
[ Upstream commit d6db02a88a4aaa1cd7105137c67ddec7f3bdbc05 ]
This commit adds NL80211_FLAG_CLEAR_SKB flag to other NL commands
that carry key data to ensure they do not stick around on heap
after the SKB is freed.
Also introduced this flag for NL80211_CMD_VENDOR as there are sub
commands which configure the keys.
Signed-off-by: Sunil Dutt <usdutt@codeaurora.org>
[ Upstream commit 1222a16014888ed9733c11e221730d4a8196222b ]
Use array_index_nospec() to sanitize i with respect to speculation.
Note that the user doesn't control i directly, but can make it out
of bounds by not finding a threshold in the array.
[add note about user control, as explained by Masashi]
[ Upstream commit 30fe6d50eb088783c8729c7d930f65296b2b3fa7 ]
Use array_index_nospec() to sanitize ridx with respect to speculation.
[ Upstream commit 4f0223bfe9c3e62d8f45a85f1ef1b18a8a263ef9 ]
nl80211_update_ft_ies() tried to validate NL80211_ATTR_IE with
is_valid_ie_attr() before dereferencing it, but that helper function
returns true in case of NULL pointer (i.e., attribute not included).
This can result to dereferencing a NULL pointer. Fix that by explicitly
checking that NL80211_ATTR_IE is included.
Fixes: 355199e02b83 ("cfg80211: Extend support for IEEE 802.11r Fast BSS Transition")
Signed-off-by: Arunk Khandavalli <akhandav@codeaurora.org>
Signed-off-by: Jouni Malinen <jouni@codeaurora.org>
[ Upstream commit 5cf3006cc81d9aa09a10aa781fc065546b12919d ]
I was looking at usually suppressed gcc warnings,
[-Wimplicit-fallthrough=] in this case:
The code definitely looks like a break is missing here.
However I am not able to test the NL80211_IFTYPE_MESH_POINT,
nor do I actually know what might be :)
So please use this patch with caution and only if you are
able to do some testing.
Signed-off-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
[johannes: looks obvious enough to apply as is, interesting
though that it never seems to have been a problem]
[ Upstream commit 95bca62fb723a121954fc7ae5473bb2c1f0d5986 ]
At the very least we should check the return value if
nla_parse_nested() is called with a non-NULL policy.
[ Upstream commit 188f60ab8e787fcbb5ac9d64ede23a0070231f09 ]
Commit 9757235f451c, "nl80211: correct checks for
NL80211_MESHCONF_HT_OPMODE value") relaxed the range for the HT
operation field in meshconf, while also adding checks requiring
the non-greenfield and non-ht-sta bits to be set in certain
circumstances. The latter bit is actually reserved for mesh BSSes
according to Table 9-168 in 802.11-2016, so in fact it should not
be set.
wpa_supplicant sets these bits because the mesh and AP code share
the same implementation, but authsae does not. As a result, some
meshconf updates from authsae which set only the NONHT_MIXED
protection bits were being rejected.
In order to avoid breaking userspace by changing the rules again,
simply accept the values with or without the bits set, and mask
off the reserved bit to match the spec.
While in here, update the 802.11-2012 reference to 802.11-2016.
Fixes: 9757235f451c ("nl80211: correct checks for NL80211_MESHCONF_HT_OPMODE value")
Cc: Masashi Honma <masashi.honma@gmail.com>
Signed-off-by: Bob Copeland <bobcopeland@fb.com>
Reviewed-by: Masashi Honma <masashi.honma@gmail.com>
[ Upstream commit 3ea15452ee85754f70f3b9fa1f23165ef2e77ba7 ]
nl80211_nan_add_func() does not check if the required attribute
NL80211_NAN_FUNC_FOLLOW_UP_DEST is present when processing
NL80211_CMD_ADD_NAN_FUNCTION request. This request can be issued
by users with CAP_NET_ADMIN privilege and may result in NULL dereference
and a system crash. Add a check for the required attribute presence.
Signed-off-by: Hao Chen <flank3rsky@gmail.com>
commit 259d8c1e984318497c84eef547bbb6b1d9f4eb05
Wireless drivers rely on parse_txq_params to validate that txq_params->ac
is less than NL80211_NUM_ACS by the time the low-level driver's ->conf_tx()
handler is called. Use a new helper, array_index_nospec(), to sanitize
txq_params->ac with respect to speculation. I.e. ensure that any
speculation into ->conf_tx() handlers is done with a value of
txq_params->ac that is within the bounds of [0, NL80211_NUM_ACS).
Reported-by: Christian Lamparter <chunkeey@gmail.com>
Reported-by: Elena Reshetova <elena.reshetova@intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Cc: kernel-hardening@lists.openwall.com
Cc: gregkh@linuxfoundation.org
Cc: linux-wireless@vger.kernel.org
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727419584.33451.7700736761686184303.stgit@dwillia2-desk3.amr.corp.intel.com
Define a policy for packet pattern attributes in order to fix a
potential read over the end of the buffer during nla_get_u32()
of the NL80211_PKTPAT_OFFSET attribute.
Note that the data there can always be read due to SKB allocation
(with alignment and struct skb_shared_info at the end), but the
data might be uninitialized. This could be used to leak some data
from uninitialized vmalloc() memory, but most drivers don't allow
an offset (so you'd just get -EINVAL if the data is non-zero) or
just allow it with a fixed value - 100 or 128 bytes, so anything
above that would get -EINVAL. With brcmfmac the limit is 1500 so
(at least) one byte could be obtained.
Cc: stable@kernel.org
Signed-off-by: Peng Xu <pxu@qti.qualcomm.com>
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[rewrite description based on SKB allocation knowledge]
If TX rates are specified during mesh join, the channel must
also be specified. Check the channel pointer to avoid a null
pointer dereference if it isn't.
Reported-by: Jouni Malinen <j@w1.fi>
Fixes: 8564e38206de ("cfg80211: add checks for beacon rate, extend to mesh")
nl80211_set_rekey_data() does not check if the required attributes
NL80211_REKEY_DATA_{REPLAY_CTR,KEK,KCK} are present when processing
NL80211_CMD_SET_REKEY_OFFLOAD request. This request can be issued by
and a system crash. Add a check for the required attributes presence.
This patch is based on the patch by bo Zhang.
This fixes CVE-2017-12153.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1491046
Fixes: e5497d766ad ("cfg80211/nl80211: support GTK rekey offload")
Cc: <stable@vger.kernel.org> # v3.1-rc1
Reported-by: bo Zhang <zhangbo5891001@gmail.com>
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
There are no HT/VHT capabilities in cfg80211_ap_settings::beacon_ies,
these should be looked for in beacon's tail instead.
Fixes: 66cd794e3c30 ("nl80211: add HT/VHT capabilities to AP parameters")
Signed-off-by: Igor Mitsyanko <igor.mitsyanko.os@quantenna.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
Johannes Berg says:
pull-request: mac80211 2017-07-07
Just got a set of fixes in from Jouni/QCA, all netlink validation
fixes. I assume they ran some kind of checker, but I don't know what
kind :)
Please pull and let me know if there's any problem.
validate_scan_freqs() retrieves frequencies from attributes
nested in the attribute NL80211_ATTR_SCAN_FREQUENCIES with
nla_get_u32(), which reads 4 bytes from each attribute
without validating the size of data received. Attributes
nested in NL80211_ATTR_SCAN_FREQUENCIES don't have an nla policy.
Validate size of each attribute before parsing to avoid potential buffer
overread.
Fixes: 2a519311926 ("cfg80211/nl80211: scanning (and mac80211 update to use it)")
Signed-off-by: Srinivas Dasari <dasaris@qti.qualcomm.com>
Buffer overread may happen as nl80211_set_station() reads 4 bytes
from the attribute NL80211_ATTR_LOCAL_MESH_POWER_MODE without
validating the size of data received when userspace sends less
than 4 bytes of data with NL80211_ATTR_LOCAL_MESH_POWER_MODE.
Define nla_policy for NL80211_ATTR_LOCAL_MESH_POWER_MODE to avoid
the buffer overread.
Fixes: 3b1c5a5307f ("{cfg,nl}80211: mesh power mode primitives and userspace access")
nla policy checks for only maximum length of the attribute data when the
attribute type is NLA_BINARY. If userspace sends less data than
specified, cfg80211 may access illegal memory. When type is NLA_UNSPEC,
nla policy check ensures that userspace sends minimum specified length
number of bytes.
Remove type assignment to NLA_BINARY from nla_policy of
NL80211_NAN_FUNC_SERVICE_ID to make these NLA_UNSPEC and to make sure
minimum NL80211_NAN_FUNC_SERVICE_ID_LEN bytes are received from
userspace with NL80211_NAN_FUNC_SERVICE_ID.
Fixes: a442b761b24 ("cfg80211: add add_nan_func / del_nan_func")
when the attribute type is NLA_BINARY. If userspace sends less
data than specified, the wireless drivers may access illegal
memory. When type is NLA_UNSPEC, nla policy check ensures that
userspace sends minimum specified length number of bytes.
NL80211_ATTR_PMKID to make this NLA_UNSPEC and to make sure minimum
WLAN_PMKID_LEN bytes are received from userspace with
NL80211_ATTR_PMKID.
Fixes: 67fbb16be69d ("nl80211: PMKSA caching support")
If NAN interface is created with NL80211_ATTR_SOCKET_OWNER, the socket
that is used to create the interface is used for all NAN operations and
reporting NAN events.
However, it turns out that sending commands and receiving events on
the same socket is not possible in a completely race-free way:
If the socket buffer is overflowed by the events, the command response
will not be sent. In that case the caller will block forever on recv.
Using non-blocking socket for commands is more complicated and still
the command response or ack may not be received.
So, keep unicasting NAN events to the interface creator, but allow
using a different socket for commands.
Signed-off-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Drivers that initiate roaming while being connected to a network that
uses 802.1X authentication need to inform user space if 802.1X
authentication is further required after roaming.
For example, when using the Fast transition protocol, roaming within
the mobility domain does not require new 802.1X authentication, but
roaming to another mobility domain does.
In addition, some drivers may not support 802.1X authentication
(so it has to be done in user space), while other drivers do.
Add a flag to the roaming notification to indicate if user space is
required to do 802.1X authentication after the roaming or not.
This flag will only be used for networks that use 802.1X
authentication. For networks that do not use 802.1X authentication it
is assumed that no further action is required from user space after
the roaming notification.
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
[arend.vanspriel@broadcom.com reuse NL80211_ATTR_PORT_AUTHORIZED]
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
[rebase to apply w/o the flag in CONNECT]
Add API for setting the PMK to the driver. For FT support, allow
setting also the PMK-R0 Name.
This can be used by drivers that support 4-Way handshake offload
while IEEE802.1X authentication is managed by upper layers.
[arend.vanspriel@broadcom.com: add WANT_1X_4WAY_HS attribute]
[reword NL80211_EXT_FEATURE_4WAY_HANDSHAKE_STA_1X docs a bit to
say that the device may require it]
Let drivers advertise support for station-mode 4-way handshake
offloading with a new NL80211_EXT_FEATURE_4WAY_HANDSHAKE_STA_PSK flag.
Extend use of NL80211_ATTR_PMK attribute indicating it might be passed
as part of NL80211_CMD_CONNECT command, and contain the PSK (which is
the PMK, hence the name.)
The driver/device is assumed to handle the 4-way handshake by
itself in this case (including key derivations, etc.), instead
of relying on the supplicant.
This patch is somewhat based on this one (by Vladimir Kondratiev):
https://patchwork.kernel.org/patch/1309561/.
Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
[arend.vanspriel@broadcom.com rebase dealing with existing ATTR_PMK]
[reword NL80211_EXT_FEATURE_4WAY_HANDSHAKE_STA_PSK docs to indicate
that this offload might be required]
In the case the channel should be switched to one requiring DFS we need
to make sure that userspace will handle radar events when they happen.
For AP mode this is assumed to be the case, as a manager like hostapd
is required. However IBSS and MESH modes can work without further
userspace assistance, so refuse to use DFS channels unless userspace
vouches that it handles DFS.
NOTE: Userspace should have already flagged support earlier during mesh
or IBSS setup. However, this information is not readily accessible
currently.
Signed-off-by: Benjamin Berg <benjamin@sipsolutions.net>
[sw: style cleanups]
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
When joining a mesh network it is not guaranteed that userspace has a
daemon listening for radar events. This is however required for channels
requiring DFS. To flag that userspace will handle radar events, it needs
to set NL80211_ATTR_HANDLE_DFS.
This matches the current mechanism used for IBSS mode.
Since groups 0 and 63 are invalid, we should check for those bits.
Note that the 802.11 spec specifies the *bit* order, but the CPU
doesn't care about bit order since it can't address bits, so it's
always treating BIT(0) as the lowest bit within a byte.
Reported-by: Jan Fuchs <jan.fuchs@lancom.de>
cfg80211_roamed() and cfg80211_roamed_bss() take the same arguments
except that cfg80211_roamed() requires the BSSID and
cfg80211_roamed_bss() requires the bss entry.
Unify the two functions by using a struct for driver initiated
roaming information so that either the BSSID or the bss entry can be
passed as an argument to the unified function.
[modified the ath6k, brcm80211, rndis and wlan-ng drivers accordingly]
[modify brcmfmac to remove the useless cast, spotted by Arend]
This patch allows for the scheduled scan request to specify matchsets
for specific BSSIDs.
Reviewed-by: Hante Meuleman <hante.meuleman@broadcom.com>
Reviewed-by: Pieter-Paul Giesberts <pieter-paul.giesberts@broadcom.com>
Reviewed-by: Franky Lin <franky.lin@broadcom.com>
[docs, netlink policy fix]
This patch implements the idea to have multiple scheduled scan requests
running concurrently. It mainly illustrates how to deal with the incoming
request from user-space in terms of backward compatibility. In order to
use multiple scheduled scans user-space needs to provide a flag attribute
NL80211_ATTR_SCHED_SCAN_MULTI to indicate support. If not the request is
treated as a legacy scan.
Drivers currently supporting scheduled scan are now indicating they support
a single scheduled scan request. This obsoletes WIPHY_FLAG_SUPPORTS_SCHED_SCAN.
[clean up netlink destroy path to avoid allocations, code cleanups]
There's no need to allocate a portid structure and then, for
each of those, walk the interfaces - we can just add a flag
to each interface and walk those directly. Due to padding in
the struct, we can even do it without any memory cost, and
it even simplifies the code.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
My last pull request has been a while, we now have:
* connection quality monitoring with multiple thresholds
* support for FILS shared key authentication offload
* pre-CAC regulatory compliance - only ETSI allows this
* sanity check for some rate confusion that hit ChromeOS
(but nobody else uses it, evidently)
* some documentation updates
* lots of cleanups
rate_flg is of type 'enum nl80211_attrs', however it is assigned with
'enum nl80211_rate_info' values. Change the type of rate_flg accordingly.
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
For multi-scheduled scan support in subsequent patch a request id
will be added. This patch add this request id to the scheduled
scan event messages. For now the request id will always be zero.
With multi-scheduled scan its value will inform user-space to which
scan the event relates.
This is an add-on to the previous patch that passes the extended ACK
structure where it's already available by existing genl_info or extack
function arguments.
This was done with this spatch (with some manual adjustment of
indentation):
expression A, B, C, D, E;
identifier fn, info;
fn(..., struct genl_info *info, ...) {
-nlmsg_parse(A, B, C, D, E, NULL)
+nlmsg_parse(A, B, C, D, E, info->extack)
-nla_parse_nested(A, B, C, D, NULL)
+nla_parse_nested(A, B, C, D, info->extack)
identifier fn, extack;
fn(..., struct netlink_ext_ack *extack, ...) {
+nlmsg_parse(A, B, C, D, E, extack)
-nla_parse(A, B, C, D, E, NULL)
+nla_parse(A, B, C, D, E, extack)
expression A, B, C, D;
+nla_parse_nested(A, B, C, D, extack)
-nlmsg_validate(A, B, C, D, NULL)
+nlmsg_validate(A, B, C, D, extack)
-nla_validate(A, B, C, D, NULL)
+nla_validate(A, B, C, D, extack)
expression A, B, C;
-nla_validate_nested(A, B, C, NULL)
+nla_validate_nested(A, B, C, extack)
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
Refactor the parsing of monitor flags and the MU-MIMO options.
This will allow adding more things cleanly in the future and
also allows setting the latter already when creating a monitor
interface.
Instead passing both flags, which can be NULL, and vif_params,
which are never NULL, move the flags into the vif_params and
use BIT(0), which is invalid from userspace, to indicate that
the flags were changed.
While updating all drivers, fix a small bug in wil6210 where
it was setting the flags to 0 instead of leaving them unchanged.
When changing monitor parameters, not setting the MU-MIMO attributes
should mean that they're not changed - it's documented that to turn
the feature off it's necessary to set all-zero group membership and
an invalid follow-address. This isn't implemented.
Fix this by making the parameters pointers, stop reusing the macaddr
struct member, and documenting that NULL pointers mean unchanged.
Enhance nl80211 and cfg80211 connect request and response APIs to
support FILS shared key authentication offload. The new nl80211
attributes can be used to provide additional information to the driver
to establish a FILS connection. Also enhance the set/del PMKSA to allow
support for adding and deleting PMKSA based on FILS cache identifier.
Add a new feature flag that drivers can use to advertize support for
FILS shared key authentication and association in station mode when
using their own SME.
Signed-off-by: Vidyullatha Kanchanapally <vkanchan@qti.qualcomm.com>
Currently the connect event from driver takes all the connection
response parameters as arguments. With support for new features these
response parameters can grow. Use a structure to pass these parameters
rather than passing them as function arguments.
[add to documentation]
The rssi_threshold is defined as s32.
Sowmini pointed out Dmitry's RTNL deadlock report to me, and it turns out
to be perfectly accurate - there are various error paths that miss unlock
of the RTNL.
To fix those, change the locking a bit to not be conditional in all those
nl80211_prepare_*_dump() functions, but make those require the RTNL to
start with, and fix the buggy error paths. This also let me use sparse
(by appropriately overriding the rtnl_lock/rtnl_unlock functions) to
validate the changes.
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
For non-ETSI regulatory domain, CAC result on DFS channel
may not be valid once moving out of that channel (as done
during remain-on-channel, scannning and off-channel tx).
Running CAC on an operating DFS channel after every off-channel
operation will only add complexity and disturb the current
link. Better do not allow any off-channel switch from a DFS
operating channel in non-ETSI domain.
Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qti.qualcomm.com>
Change the SET CQM command's RSSI threshold attribute to accept any
number of thresholds as a sorted array. The API should be backwards
compatible so that if one s32 threshold value is passed, the old
mechanism is enabled. The netlink event generated is the same in both
cases.
cfg80211 handles an arbitrary number of RSSI thresholds but drivers have
to provide a method (set_cqm_rssi_range_config) that configures a range
set by a high and a low value. Drivers have to call back when the RSSI
goes out of that range and there's no additional event for each time the
range is reconfigured as there was with the current one-threshold API.
This method doesn't have a hysteresis parameter because there's no
benefit to the cfg80211 code from having the hysteresis be handled by
hardware/driver in terms of the number of wakeups. At the same time
it would likely be less consistent between drivers if offloaded or
done in the drivers.
