path: root/net/wireless/nl80211.c
2010-07-28nl80211: Fix memory leaksYuri Ershov
In case of errors during message composing msg should be freed after canceling. Signed-off-by: Yuri Kululin <ext-yuri.kululin@nokia.com> Signed-off-by: Yuri Ershov <ext-yuri.ershov@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/wl12xx/wl1271_cmd.h
2010-07-07NET: nl80211, fix lock imbalance and netdev referencingJiri Slaby
Stanse found that nl80211_set_wiphy imporperly handles a lock and netdev reference and contains unreachable code. It is because there return statement isntead of assignment to result variable. Fix that. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jouni Malinen <j@w1.fi> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-01Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/libertas/host.h
2010-06-24nl80211: Add option to adjust transmit powerJuuso Oikarinen
This patch adds transmit power setting type and transmit power level attributes to NL80211_CMD_SET_WIPHY in order to facilitate adjusting of the transmit power level of the device. The added attributes allow selection of automatic, limited or fixed transmit power level, with the level definable in signed mBm format. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-17Merge branch 'master' of ↵David S. Miller
2010-06-15bridge: use rx_handler_data pointer to store net_bridge_port pointerJiri Pirko
Register net_bridge_port pointer as rx_handler data pointer. As br_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a bridge port. Also rcuized pointers are now correctly dereferenced in br_fdb.c and in netfilter parts. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-14mac80211: Set basic rates while joining ibss networkTeemu Paasikivi
This patch adds support to nl80211 and mac80211 to set basic rates when joining/creating ibss network. Original patch was posted by Johannes Berg on the linux-wireless posting list. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Teemu Paasikivi <ext-teemu.3.paasikivi@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-14cfg80211/mac80211: allow action frame TX/RX in IBSSJohannes Berg
When in IBSS mode, currently action frame TX and RX cannot be used. Allow using it to talk to any peer, or for public action frames. Also, while at it, restructure the code in mac80211 to make it easier to add this for other interface types in the future. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-02cfg80211: make action channel type optionalJohannes Berg
When sending action frames, we want to verify that we do that on the correct channel. However, checking the channel type in addition can get in the way, since the channel type could change on the fly during an association, and it's not useful to have the channel type anyway since it has no effect on the transmission. Therefore, make it optional to specify so that if wanted, it can still be checked, but is not required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-21cfg80211: add missing bracesJohannes Berg
Specifying a valid channel type will get goto out rather than continuing, due to missing braces. This affects both remain on channel and action frame TX commands. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-11Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/ath/ar9170/main.c
2010-05-07cfg80211/mac80211: better channel handlingJohannes Berg
Currently (all tested with hwsim) you can do stupid things like setting up an AP on a certain channel, then adding another virtual interface and making that associate on another channel -- this will make the beaconing to move channel but obviously without the necessary IEs data update. In order to improve this situation, first make the configuration APIs (cfg80211 and nl80211) aware of multi-channel operation -- we'll eventually need that in the future anyway. There's one userland API change and one API addition. The API change is that now SET_WIPHY must be called with virtual interface index rather than only wiphy index in order to take effect for that interface -- luckily all current users (hostapd) do that. For monitor interfaces, the old setting is preserved, but monitors are always slaved to other devices anyway so no guarantees. The second userland API change is the introduction of a per virtual interface SET_CHANNEL command, that hostapd should use going forward to make it easier to understand what's going on (it can automatically detect a kernel with this command). Other than mac80211, no existing cfg80211 drivers are affected by this change because they only allow a single virtual interface. mac80211, however, now needs to be aware that the channel settings are per interface now, and needs to disallow (for now) real multi-channel operation, which is another important part of this patch. One of the immediate benefits is that you can now start hostapd to operate on a hardware that already has a connection on another virtual interface, as long as you specify the same channel. Note that two things are left unhandled (this is an improvement -- not a complete fix): * different HT/no-HT modes currently you could start an HT AP and then connect to a non-HT network on the same channel which would configure the hardware for no HT; that can be fixed fairly easily * CSA An AP we're connected to on a virtual interface might indicate switching channels, and in that case we would follow it, regardless of how many other interfaces are operating; this requires more effort to fix but is pretty rare after all Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-04-27cfg80211: add ap isolation supportFelix Fietkau
This is used to configure APs to not bridge traffic between connected stations. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/wl12xx/wl1271_main.c
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-07cfg80211: Add local-state-change-only auth/deauth/disassocJouni Malinen
cfg80211 is quite strict on allowing authentication and association commands only in certain states. In order to meet these requirements, user space applications may need to clear authentication or association state in some cases. Currently, this can be done with deauth/disassoc command, but that ends up sending out Deauthentication or Disassociation frame unnecessarily. Add a new nl80211 attribute to allow this sending of the frame be skipped, but with all other deauth/disassoc operations being completed. Similar state change is also needed for IEEE 802.11r FT protocol in the FT-over-DS case which does not use Authentication frame exchange in a transition to another BSS. For this to work with cfg80211, an authentication entry needs to be created for the target BSS without sending out an Authentication frame. The nl80211 authentication command can be used for this purpose, too, with the new attribute to indicate that the command is only for changing local state. This enables wpa_supplicant to complete FT-over-DS transition successfully. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-31nl80211: reenable station del for meshMarco Porsch
iw dev <devname> station del <MAC address> is quiet useful in mesh mode and should be possible. Signed-off-by: Marco Porsch <marco.porsch@siemens.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24cfg80211: Add connection quality monitoring support to nl80211Juuso Oikarinen
Add support for basic configuration of a connection quality monitoring to the nl80211 interface, and basic support for notifying about triggered monitoring events. Via this interface a user-space connection manager may configure and receive pre-warning events of deteriorating WLAN connection quality, and start preparing for roaming in advance, before the connection is already lost. An example usage of such a trigger is starting scanning for nearby AP's in an attempt to find one with better connection quality, and associate to it before the connection characteristics of the existing connection become too bad or the association is even lost, leading in a prolonged delay in connectivity. The interface currently supports only RSSI, but it could be later extended to include other parameters, such as signal-to-noise ratio, if need for that arises. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-25Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h drivers/net/wireless/rt2x00/rt2800pci.c
2010-02-19nl80211: add power save commandsKalle Valo
The most needed command from nl80211, which Wireless Extensions had, is support for power save mode. Add a simple command to make it possible to enable and disable power save via nl80211. I was also planning about extending the interface, for example adding the timeout value, but after thinking more about this I decided not to do it. Basically there were three reasons: Firstly, the parameters for power save are very much hardware dependent. Trying to find a unified interface which would work with all hardware, and still make sense to users, will be very difficult. Secondly, IEEE 802.11 power save implementation in Linux is still in state of flux. We have a long way to still to go and there is no way to predict what kind of implementation we will have after few years. And because we need to support nl80211 interface a long time, practically forever, adding now parameters to nl80211 might create maintenance problems later on. Third issue are the users. Power save parameters are mostly used for debugging, so debugfs is better, more flexible, interface for this. For example, wpa_supplicant currently doesn't configure anything related to power save mode. It's better to strive that kernel can automatically optimise the power save parameters, like with help of pm qos network and other traffic parameters. Later on, when we have better understanding of power save, we can extend this command with more features, if there's a need for that. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-18const: struct nla_policyAlexey Dobriyan
Make remaining netlink policies as const. Fixup coding style where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15cfg80211/mac80211: allow registering for and sending action framesJouni Malinen
This implements a new command to register for action frames that userspace wants to handle instead of the in-kernel rejection. It is then responsible for rejecting ones that it decided not to handle. There is no unregistration, but the socket can be closed for that. Frames that are not registered for will not be forwarded to userspace and will be rejected by the kernel, the cfg80211 API helps implementing that. Additionally, this patch adds a new command that allows doing action frame transmission from userspace. It can be used either to exchange action frames on the current operational channel (e.g., with the AP with which we are currently associated) or to exchange off-channel Public Action frames with the remain-on-channel command. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-15nl80211: does not allow NEW_STATION and DEL_STATION for meshThadeu Lima de Souza Cascardo
As discussed in linux-wireless mailing list, adding and removing stations for mesh topologies is not necessary. Since doing it triggers bugs, the sugestion was to simply disable it. Tested using a custom iw command "station new". Works only after using hostapd. "station del" command also works. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Simon Raffeiner <sturmflut@lieberbiber.de> Cc: Andrey Yurovsky <andrey@cozybit.com> Cc: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-19nl80211: Allow association to change channels during reassociationJouni Malinen
nl80211_associate() was rejecting (re)association attempts with EBUSY in some cases where we are currently associated with an AP that uses different channel from the destination AP. Fix this by passing the current wdev to rdev_fixed_channel() in the same way that was already done for join-IBSS and connect commands. This allows the fixedchan check to skipped for the current wdev and allows the reassociation to proceed. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12cfg80211: Store IEs from both Beacon and Probe Response framesJouni Malinen
Store information elements from Beacon and Probe Response frames in separate buffers to allow both sets to be made available through nl80211. This allows user space applications to get access to IEs from Beacon frames even if we have received Probe Response frames from the BSS. Previously, the IEs from Probe Response frames would have overridden the IEs from Beacon frames. This feature is of somewhat limited use since most protocols include the same (or extended) information in Probe Response frames. However, there are couple of exceptions where the IEs from Beacon frames could be of some use: TIM IE is only included in Beacon frames (and it would be needed to figure out the DTIM period used in the BSS) and at least some implementations of Wireless Provisioning Services seem to include the full IE only in Beacon frames). The new BSS attribute for scan results is added to allow both the IE sets to be delivered. This is done in a way that maintains the previously used behavior for applications that are not aware of the new NL80211_BSS_BEACON_IES attribute. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12nl80211: New command for setting TX rate mask for rate controlJouni Malinen
Add a new NL80211_CMD_SET_TX_BITRATE_MASK command and related attributes to provide support for setting TX rate mask for rate control. This uses the existing cfg80211 set_bitrate_mask operation that was previously used only with WEXT compat code (SIOCSIWRATE). The nl80211 command allows more generic configuration of allowed rates as a mask instead of fixed/max rate. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12nl80211: Add new WIPHY attribute COVERAGE_CLASSLukáš Turek
The new attribute NL80211_ATTR_WIPHY_COVERAGE_CLASS sets IEEE 802.11 Coverage Class, which depends on maximum distance of nodes in a wireless network. It's required for long distance links (more than a few hundred meters). The attribute is now ignored by two non-mac80211 drivers, rndis and iwmc3200wifi, together with WIPHY_PARAM_RETRY_SHORT and WIPHY_PARAM_RETRY_LONG. If it turns out to be a problem, we could split set_wiphy_params callback or add new capability bits. Signed-off-by: Lukas Turek <8an@praha12.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28mac80211/cfg80211: add station eventsJohannes Berg
When, for instance, a new IBSS peer is found, userspace wants to be notified. Add events for all new stations that mac80211 learns about. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28cfg80211: add remain-on-channel commandJouni Malinen
Add new commands for requesting the driver to remain awake on a specified channel for the specified amount of time (and another command to cancel such an operation). This can be used to implement userspace-controlled off-channel operations, like Public Action frame exchange on another channel than the operation channel. The off-channel operation should behave similarly to scan, i.e. the local station (if associated) moves into power save mode to request the AP to buffer frames for it and then moves to the other channel to allow the off-channel operation to be completed. The duration parameter can be used to request enough time to receive a response from the target station. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28wireless: remove CONFIG_WIRELESS_OLD_REGULATORYJohn W. Linville
This is no longer needed with the availability of CONFIG_CFG80211_INTERNAL_REGDB. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21wireless: report reasonable bitrate for MCS rates through wextJohn W. Linville
Previously, cfg80211 had reported "0" for MCS (i.e. 802.11n) bitrates through the wireless extensions interface. However, nl80211 was converting MCS rates into a reasonable bitrate number. This patch moves the nl80211 code to cfg80211 where it is now shared between both the nl80211 interface and the wireless extensions interface. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-28nl80211: PMKSA caching supportSamuel Ortiz
This is an interface to set, delete and flush PMKIDs through nl80211. Main users would be fullmac devices which firmwares are capable of generating the RSN IEs for the re-association requests, e.g. iwmc3200wifi. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: disallow bridging managed/adhoc interfacesJohannes Berg
A number of people have tried to add a wireless interface (in managed mode) to a bridge and then complained that it doesn't work. It cannot work, however, because in 802.11 networks all packets need to be acknowledged and as such need to be sent to the right address. Promiscuous doesn't help here. The wireless address format used for these links has only space for three addresses, the * transmitter, which must be equal to the sender (origin) * receiver (on the wireless medium), which is the AP in the case of managed mode * the recipient (destination), which is on the APs local network segment In an IBSS, it is similar, but the receiver and recipient must match and the third address is used as the BSSID. To avoid such mistakes in the future, disallow adding a wireless interface to a bridge. Felix has recently added a four-address mode to the AP and client side that can be used (after negotiating that it is possible, which must happen out-of-band by setting up both sides) for bridging, so allow that case. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: introduce capability for 4addr modeJohannes Berg
It's very likely that not many devices will support four-address mode in station or AP mode so introduce capability bits for both modes, set them in mac80211 and check them when userspace tries to use the mode. Also, keep track of 4addr in cfg80211 (wireless_dev) and not in mac80211 any more. mac80211 can also be improved for the VLAN case by not looking at the 4addr flag but maintaining the station pointer for it correctly. However, keep track of use_4addr for station mode in mac80211 to avoid all the derefs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: convert bools into flagsJohannes Berg
We've accumulated a number of options for wiphys which make more sense as flags as we keep adding more. Convert the existing ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13nl80211: only allow adding stations to running vlan interfacesFelix Fietkau
2009-11-13cfg80211: return channel noise via survey APIHolger Schurig
This patch implements the NL80211_CMD_GET_SURVEY command and an get_survey() ops that a driver can implement. The goal of this command is to allow a drivers to report channel survey data (e.g. channel noise, channel occupation). For now, only the mechanism to report back channel noise has been implemented. In future, there will either be a survey-trigger command --- or the existing scan-trigger command will be enhanced. This will allow user-space to request survey for arbitrary channels. Note: any driver that cannot report channel noise should not report any value at all, e.g. made-up -92 dBm. Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13cfg80211: introduce nl80211_get_ifidx()Holger Schurig
... which get's rid of three indentical cut-n-paste sections. Signed-off-by: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: add nl80211/cfg80211 handling of the new mesh root mode option.Rui Paulo
Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: replace "destination" with "target" to follow the specRui Paulo
Resulting object files have the same MD5 as before. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11nl80211: add a parameter for using 4-address frames on virtual interfacesFelix Fietkau
2009-11-02cfg80211: validate scan channelsJohannes Berg
Currently it is possible to request a scan on only disabled channels, which could be problematic for some drivers. Reject such scans, and also ignore disabled channels that are given. This resuls in the scan begin/end event only including channels that are actually used. This makes the mac80211 check for disabled channels superfluous. At the same time, remove the no-IBSS check from mac80211 -- nothing says that we should not find any networks on channels that cannot be used for an IBSS, even when operating in IBSS mode. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-11Merge branch 'master' of ↵David S. Miller
2009-10-08cfg80211: fix netns error unwinding bugJohannes Berg
The error unwinding code in set_netns has a bug that will make it run into a BUG_ON if passed a bad wiphy index, fix by not trying to unlock a wiphy that doesn't exist. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-07wext: refactorJohannes Berg
Refactor wext to * split out iwpriv handling * split out iwspy handling * split out procfs support * allow cfg80211 to have wireless extensions compat code w/o CONFIG_WIRELESS_EXT After this, drivers need to - select WIRELESS_EXT - for wext support - select WEXT_PRIV - for iwpriv support - select WEXT_SPY - for iwspy support except cfg80211 -- which gets new hooks in wext-core.c and can then get wext handlers without CONFIG_WIRELESS_EXT. Wireless extensions procfs support is auto-selected based on PROC_FS and anything that requires the wext core (i.e. WIRELESS_EXT or CFG80211_WEXT). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-07nl80211: report age of scan resultsHolger Schurig
Linux keeps scan results up to 15 seconds. This can be a problem for fast moving clients: they get back stale data. But if the kernel reports the age of the BSS items, then user-space can simply weed out old entries by itself. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28nl80211: jump to out_err upon unsupported iftypeRoel Kluin
Jump to out_err when the iftype is not supported. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
