The error unwinding code in set_netns has a bug
that will make it run into a BUG_ON if passed a
bad wiphy index, fix by not trying to unlock a
wiphy that doesn't exist.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Jump to out_err when the iftype is not supported.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
When the interface type changes while connected, and the
driver does not require the interface to be down for a
type change, it is currently possible to get very strange
results unless the driver takes special care, which it
shouldn't have to.
To fix this, take care to disconnect/leave IBSS when
changing the interface type -- even if the driver may fail
the call. Also process all events that may be pending to
avoid running into a situation where an event is reported
but only processed after the type has already changed,
which would lead to missing events and warnings.
A side effect of this is that you will have disconnected
or left the IBSS even if the mode change ultimately fails,
but since the intention was to change it and thus leave or
disconnect, this is not a problem.
"cfg80211: validate channel settings across interfaces"
contained a locking bug -- in the managed-mode SIWFREQ
call it would end up running into a lock recursion.
This fixes it by not checking that particular interface
for a channel that it needs to stay on, which is as it
should be as that's the interface we're setting the
channel for.
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Reported-by: Kalle Valo <kalle.valo@iki.fi>
Tested-by: Kalle Valo <kalle.valo@iki.fi>
Tested-by: Reinette Chatre <reinette.chatre@intel.com>
The memory layout for scan requests was rather wrong,
we put the scan SSIDs before the channels which could
lead to the channel pointers being unaligned in memory.
It turns out that using a pointer to the channel array
isn't necessary anyway since we can embed a zero-length
array into the struct.
In order for userspace to be able to figure out whether
it obtained a consistent snapshot of data or not when
using netlink dumps, we need to have a generation number
in each dump message that indicates whether the list has
changed or not -- its value is arbitrary.
This patch adds such a number to all dumps, this needs
some mac80211 involvement to keep track of a generation
number to start with when adding/removing mesh paths or
stations.
The wiphy and netdev lists can be fully handled within
cfg80211, of course, but generation numbers need to be
stored there as well.
Currently, there's a problem that affects regulatory
enforcement and connection stability, in that it is
possible to switch the channel while connected to a
network or joined to an IBSS.
The problem comes from the fact that we only validate
the channel against the current interface's type, not
against any other interface. Thus, you have any type
of interface up, additionally bring up a monitor mode
interface and switch the channel on the monitor. This
will obviously also switch the channel on the other
interface.
The problem now is that if you do that while sending
beacons for IBSS mode, you can switch to a disabled
channel or a channel that doesn't allow beaconing.
Combined with a managed mode interface connected to
an AP instead of an IBSS interface, you can easily
break the connection that way.
To fix this, this patch validates any channel change
with all available interfaces, and disallows such
changes on secondary interfaces if another interface
is connected to an AP or joined to an IBSS.
Until now we implemented iwfreq for managed mode, we
needed to keep the implementations separate, but now
that we have all versions implemented we can combine
them and export just one handler.
Jouni and Maxim reported an oops when using wpa_supplicant -Dnl80211,
which seems to be due to random data being contained in the crypto
settings for the assoc() command. This seems to be due to the missing
memset here, so add it -- it's certainly missing but I'm not 100%
certain that it will fix the problem.
Luis reported this lockdep complaint, that he had also
reported earlier but when trying to analyse I had been
locking at the wrong code, and never saw the problem:
(slightly abridged)
[ INFO: possible circular locking dependency detected ]
2.6.31-rc4-wl #6
wpa_supplicant/3799 is trying to acquire lock:
(cfg80211_mutex){+.+.+.}, at: [<ffffffffa009246a>] cfg80211_get_dev_from_ifindex+0x1a/0x90 [cfg80211]
but task is already holding lock:
(rtnl_mutex){+.+.+.}, at: [<ffffffff81400ff2>] rtnl_lock+0x12/0x20
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (rtnl_mutex){+.+.+.}:
[<ffffffff810857b6>] __lock_acquire+0xd76/0x12b0
[<ffffffff81085dd3>] lock_acquire+0xe3/0x120
[<ffffffff814ee7a4>] mutex_lock_nested+0x44/0x350
[<ffffffffa009f6a5>] nl80211_send_reg_change_event+0x1f5/0x2a0 [cfg80211]
[<ffffffffa009529e>] set_regdom+0x28e/0x4c0 [cfg80211]
-> #0 (cfg80211_mutex){+.+.+.}:
[<ffffffff8108587b>] __lock_acquire+0xe3b/0x12b0
[<ffffffffa009813f>] get_rdev_dev_by_info_ifindex+0x6f/0xa0 [cfg80211]
[<ffffffffa009b12b>] nl80211_set_interface+0x3b/0x260 [cfg80211]
When looking at the correct code, the problem is quite
obvious. I'm not entirely sure which code paths lead
here, so until I can analyse it better let's just use
RCU to avoid the problem.
In order to make cfg80211/nl80211 aware of network namespaces,
we have to do the following things:
* del_virtual_intf method takes an interface index rather
than a netdev pointer - simply change this
* nl80211 uses init_net a lot, it changes to use the sender's
network namespace
* scan requests use the interface index, hold a netdev pointer
and reference instead
* we want a wiphy and its associated virtual interfaces to be
in one netns together, so
- we need to be able to change ns for a given interface, so
export dev_change_net_namespace()
- for each virtual interface set the NETIF_F_NETNS_LOCAL
flag, and clear that flag only when the wiphy changes ns,
to disallow breaking this invariant
* when a network namespace goes away, we need to reparent the
wiphy to init_net
* cfg80211 users that support creating virtual interfaces must
create them in the wiphy's namespace, currently this affects
only mac80211
The end result is that you can now switch an entire wiphy into
a different network namespace with the new command
iw phy#<idx> set netns <pid>
and all virtual interfaces will follow (or the operation fails).
When connected to a BSS, or joined to an IBSS, we'll want
to know in userspace without using wireless extensions, so
report the BSS status in the BSS list. Userspace can query
the BSS list, display all the information and retrieve the
station information as well.
For example (from hwsim):
$ iw dev wlan1 scan dump
BSS 02:00:00:00:00:00 (on wlan1) -- associated
freq: 2462
beacon interval: 100
capability: ESS ShortSlotTime (0x0401)
signal: -50.00 dBm
SSID: j
Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0
DS Paramater set: channel 11
ERP: <no flags>
Extended supported rates: 24.0 36.0 48.0 54.0
This reworks the key operation in cfg80211, and now only
allows, from userspace, configuring keys (via nl80211)
after the connection has been established (in managed
mode), the IBSS been joined (in IBSS mode), at any time
(in AP[_VLAN] modes) or never for all the other modes.
In order to do shared key authentication correctly, it
is now possible to give a WEP key to the AUTH command.
To configure static WEP keys, these are given to the
CONNECT or IBSS_JOIN command directly, for a userspace
SME it is assumed it will configure it properly after
the connection has been established.
Since mac80211 used to check the default key in IBSS
mode to see whether or not the network is protected,
it needs an update in that area, as well as an update
to make use of the WEP key passed to auth() for shared
key authentication.
We will soon want to nest key attributes into
some new attribute for configuring static WEP
keys at connect() and ibss_join() time, so we
need nested attributes for that. However, key
attributes right now are 'global'. This patch
thus introduces new nested attributes for the
key settings and functions for parsing them.
This fixes two small bugs:
1) the connect variable is already initialised, and the
assignment to auth_type overwrites the previous setting
with a wrong value
2) when all authentication attempts fail, we need to report
that we couldn't connect
drivers/net/wireless/iwmc3200wifi/netdev.c
net/wireless/scan.c
Potential memory leak via msg pointer in nl80211_get_key() function.
Signed-off-by: Niko Jokinen <ext-niko.k.jokinen@nokia.com>
Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
This makes generic netlink network namespace aware. No
generic netlink families except for the controller family
are made namespace aware, they need to be checked one by
one and then set the family->netnsok member to true.
A new function genlmsg_multicast_netns() is introduced to
allow sending a multicast message in a given namespace,
for example when it applies to an object that lives in
that namespace, a new function genlmsg_multicast_allns()
to send a message to all network namespaces (for objects
that do not have an associated netns).
The function genlmsg_multicast() is changed to multicast
the message in just init_net, which is currently correct
for all generic netlink families since they only work in
init_net right now. Some will later want to work in all
net namespaces because they do not care about the netns
at all -- those will have to be converted to use one of
the new functions genlmsg_multicast_allns() or
genlmsg_multicast_netns() whenever they are made netns
aware in some way.
After this patch families can easily decide whether or
not they should be available in all net namespaces. Many
genl families us it for objects not related to networking
and should therefore be available in all namespaces, but
that will have to be done on a per family basis.
Note that this doesn't touch on the checkpoint/restart
problem where network namespaces could be used, genl
families and multicast groups are numbered globally and
I see no easy way of changing that, especially since it
must be possible to multicast to all network namespaces
for those families that do not care about netns.
We've named the registered devices 'drv' sometimes,
thinking of "driver", which is not what it is, it's
the internal representation of a wiphy, i.e. a
device. Let's clean up the naming once and and use
'rdev' aka 'registered device' everywhere.
Over time, a lot of locking issues have crept into
the smarts of cfg80211, so e.g. scan completion can
race against a new scan, IBSS join can race against
leaving an IBSS, etc.
Introduce a new per-interface lock that protects
most of the per-interface data that we need to keep
track of, and sprinkle assertions about that lock
everywhere. Some things now need to be offloaded to
work structs so that we don't require being able to
sleep in functions the drivers call. The exception
to that are the MLME callbacks (rx_auth etc.) that
currently only mac80211 calls because it was easier
to do that there instead of in cfg80211, and future
drivers implementing those calls will, if they ever
exist, probably need to use a similar scheme like
mac80211 anyway...
In order to be able to handle _deauth and _disassoc
properly, introduce a cookie passed to it that will
determine locking requirements.
sparse warns about a number of things, and one of them
(use_mfp shadowed variable) actually is a bug, fix all
of them.
Currently we call that cfg80211_put_dev(), but that is
misleading. With the new convention of using 'rdev' for
registered_device variables, also call that function
cfg80211_unlock_rdev().
Since we don't really know that well in the kernel,
let's let the SME control whether it wants to use
reassociation or not, by allowing it to give the
previous BSSID in the associate() parameters.
In this case, only one cipher makes sense, unlike for
connect() where it may be possible to have the card or
driver select.
No changes to mac80211 due to the way the structs are
laid out -- but the loop in net/mac80211/cfg.c will
degrade to just zero or one passes.
In order to avoid problems with BSS structs going away
while they're in use, I've long wanted to make cfg80211
keep track of them. Without the SME, that wasn't doable
but now that we have the SME we can do this too. It can
keep track of up to four separate authentications and
one association, regardless of whether it's controlled
by the cfg80211 SME or the userspace SME.
This adds code to make it possible to use the cfg80211
connect() API with wireless extensions, and because the
previous patch added emulation of that API with auth()
and assoc(), by extension also supports wext on that.
At the same time, removes code from mac80211 for wext,
but doesn't yet clean up mac80211's mlme code more.
Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com>
This adds code to cfg80211 so that drivers (mac80211 right
now) that don't implement connect but rather auth/assoc can
still be used with the nl80211 connect command. This will
also be necessary for the wext compat code.
This patch introduces the cfg80211 connect/disconnect API.
The goal here is to run the AUTH and ASSOC steps in one call.
This is needed for some fullmac cards that run both steps
directly from the target, after the host driver sends a
connect command.
Additionally, all the new crypto parameters for connect()
are now also valid for associate() -- although associate
requires the IEs to be used, the information can be useful
for drivers and should be given.
This introduces a new NL80211_CMD_TESTMODE for testing
and calibration use with nl80211. There's no multiplexing
like like iwpriv had, and the command is not available by
default, it needs to be explicitly enabled in Kconfig and
shouldn't be enabled in most kernels.
The command requires a wiphy index or interface index to
identify the device to operate on, and the new TESTDATA
attribute. There also is API for sending replies to the
command, and testmode multicast messages (on a testmode
multicast group).
I've also updated mac80211 to be able to pass through the
command to the driver, since it itself doesn't implement
the testmode command.
Additionally, to give people an idea of how to use the
command, I've added a little code to hwsim that makes use
of the new command to set the powersave mode, this is
currently done via debugfs and should remain there, and
the testmode command only serves as an example of how to
use this best -- with nested netlink attributes in the
TESTDATA attribute. A hwsim testmode tool can be found at
http://git.sipsolutions.net/hwsim.git/. This tool is BSD
licensed so people can easily use it as a basis for their
own internal fabrication and validation tools.
Instead of hardcoding GFP_ATOMIC everywhere, add a
new function parameter that gets the flags from the
caller. Obviously then I need to update all callers
(all of them in mac80211), and it turns out that now
it's ok to use GFP_KERNEL in almost all places.
It isn't very useful to scan the same channel more than once
during a given scan, and some hardware (notably iwlwifi) can
only scan a limited number of channels at a time. To prevent
any overflows, simply disallow scanning any channel multiple
times in a given scan command. This is a small change in the
userspace ABI, but the only user, wpa_supplicant, never asks
for a scan with the same frequency listed twice.
To ease multiple apps working together smoothly,
send a notification when a scan is started.
If there was a reason I'm passing the ifidx I cannot
remember it any more and don't see one now, so let's
just pass the pointer itself.
Don't forget to unlock cfg80211_mutex in one fail path of
nl80211_set_wiphy.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
When I disallowed interfering with stations on non-AP interfaces,
I not only forget mesh but also managed interfaces which need
this for the authorized flag. Let's actually validate everything
properly.
This fixes an nl80211 regression introduced by the interfering,
under which wpa_supplicant -Dnl80211 could not properly connect.
Mesh Point interfaces can also set parameters, for example plink_open is
used to manually establish peer links from user-space (currently via
iw). Add Mesh Point to the check in nl80211_set_station.
Signed-off-by: Andrey Yurovsky <andrey@cozybit.com>
Commit b2a151a288 added a check that prevents adding or deleting
stations on non-AP interfaces. Adding and deleting stations is
supported for Mesh Point interfaces, so add Mesh Point to that check as
well.
nl80211_michael_mic_failure can be called in atomic context but
does a GFP_KERNEL allocation. Fixes the error below:
[ 126.793225] BUG: sleeping function called from invalid context at mm/slab.c:3055
[ 126.793234] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper
[ 126.793241] 2 locks held by swapper/0:
[ 126.793246] #0: (&sc->rxbuflock){+.-.+.}, at: [<f94e1b46>] ath5k_tasklet_rx+0x34/0x55e [ath5k]
[ 126.793294] #1: (rcu_read_lock){.+.+.+}, at: [<f92872f3>] __ieee80211_rx+0x7e/0x563 [mac80211]
[ 126.793342] Pid: 0, comm: swapper Not tainted 2.6.30-rc7-wl #124
[ 126.793347] Call Trace:
[ 126.793361] [<c014499d>] ? __debug_show_held_locks+0x1e/0x20
[ 126.793380] [<c011e9a3>] __might_sleep+0x100/0x107
[ 126.793386] [<c018ea99>] kmem_cache_alloc+0x35/0x170
[ 126.793393] [<c02e8bb1>] ? __alloc_skb+0x2e/0x117
[ 126.793397] [<c014517d>] ? mark_held_locks+0x43/0x5b
[ 126.793402] [<c02e8bb1>] __alloc_skb+0x2e/0x117
[ 126.793419] [<f851a836>] nl80211_michael_mic_failure+0x2a/0x1fa [cfg80211]
[ 126.793425] [<c01453b8>] ? trace_hardirqs_on_caller+0xf6/0x130
[ 126.793430] [<c01453fd>] ? trace_hardirqs_on+0xb/0xd
[ 126.793444] [<f851b2b8>] cfg80211_michael_mic_failure+0x30/0x38 [cfg80211]
[ 126.793463] [<f928bf69>] mac80211_ev_michael_mic_failure+0xfd/0x108 [mac80211]
[ 126.793480] [<f9279fbd>] ieee80211_rx_h_michael_mic_verify+0xd4/0x117 [mac80211]
[ 126.793499] [<f9285ef3>] ieee80211_invoke_rx_handlers+0xdde/0x1963 [mac80211]
[ 126.793505] [<c0107152>] ? sched_clock+0x3f/0x64
[ 126.793511] [<c0107152>] ? sched_clock+0x3f/0x64
[ 126.793516] [<c01445d7>] ? trace_hardirqs_off+0xb/0xd
[ 126.793521] [<c0107152>] ? sched_clock+0x3f/0x64
[ 126.793526] [<c0146454>] ? __lock_acquire+0x62c/0x1271
[ 126.793545] [<f9286fbb>] __ieee80211_rx_handle_packet+0x543/0x564 [mac80211]
[ 126.793564] [<f9287757>] __ieee80211_rx+0x4e2/0x563 [mac80211]
[ 126.793577] [<f94e1ff6>] ath5k_tasklet_rx+0x4e4/0x55e [ath5k]
[ 126.793583] [<c0102b54>] ? restore_nocheck_notrace+0x0/0xe
[ 126.793589] [<c0129aa2>] tasklet_action+0x92/0xe5
[ 126.793594] [<c0129f22>] __do_softirq+0xb1/0x182
[ 126.793599] [<c012a023>] do_softirq+0x30/0x48
[ 126.793603] [<c012a19b>] irq_exit+0x3d/0x74
[ 126.793609] [<c0358016>] do_IRQ+0x76/0x8c
[ 126.793613] [<c010312e>] common_interrupt+0x2e/0x34
[ 126.793618] [<c014007b>] ? timer_list_show+0x277/0x939
[ 126.793630] [<f88eb321>] ? acpi_idle_enter_bm+0x266/0x291 [processor]
[ 126.793636] [<c02d00f6>] cpuidle_idle_call+0x6a/0x9c
[ 126.793640] [<c0101cc8>] cpu_idle+0x53/0x87
[ 126.793645] [<c0344510>] rest_init+0x6c/0x6e
[ 126.793651] [<c04dd74d>] start_kernel+0x286/0x28b
[ 126.793656] [<c04dd037>] __init_begin+0x37/0x3c
Signed-off-by: Bob Copeland <me@bobcopeland.com>
On non-AP interfaces userspace has no business interfering with
the station management, this can confuse mac80211 (and other
drivers probably wouldn't support it anyway). Allow adding and
removing stations only on AP interfaces.
(Reconcile this w/ previous version of patch posted with same
subject... -- JWL)
When a scan finishes only the program that asked for it
knows what kind of scan it was; let's tell everybody else
about the scan parameters as well so they can evaluate
the result of the scan better. Also helps with debugging.
We have some validation code in mac80211 but said code will
force an invalid AID to 0 which isn't a valid AID either;
instead require a valid AID (1-2007) to be passed in from
userspace in cfg80211 already. Also move the code before
the race comment since it can only be executed during STA
addition and thus is not racy.
It's going away. Just leave the constant "20" here so that
behavior doesn't change.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Use genl_register_family_with_ops() instead of a copy.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
There is a race on access to last_request and its alpha2
through reg_is_valid_request() and us possibly processing
first another regulatory request on another CPU. We avoid
this improbably race by locking with the cfg80211_mutex as
we should have done in the first place. While at it add
the assert on locking on reg_is_valid_request().
Cc: stable@kernel.org
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This has no functional change, but it will make the race
fix easier to spot in my next patch.
This has no functional change except we save a kfree(rd) and
allows us to clean this code up a bit after this. We do
avoid an unnecessary kfree(NULL) but calling that was OK too.
Validate RSC (NL80211_ATTR_KEY_SEQ) length in nl80211/cfg80211 instead
of having to do this in all the drivers.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
Thanks to nl80211 userspace can be very specific upon device
configuration. Before processing the request for the new HT40
channel types (HT40- or HT40+) we need to ensure we can use them
regulatory-wise. This wasn't required with wireless extensions as
specifying the channel type wasn't not available and configuration
was done towards the end implicitly upon association or reception
of beacons from the AP. For the new nl80211 we have to check this
when configuring the interfaces explicitly.
nlmsg_new() adds the size of the netlink header to the value
that has been passed as parameter. If NLMSG_GOODSIZE is selected,
we request an allocation of one memory page plus the size of the
header. Instead, NLMSG_DEFAULT_SIZE should be used since it
already substracts the size of the Netlink header.
I have the impression that the similar naming in both constant
is error prone when using it with nlmsg_new(). This is already
documented in include/net/netlink.h
