commit 4ac2813cc867ae563a1ba5a9414bfb554e5796fa upstream.
Ensure the SSID element is bounds-checked prior to invoking memcpy()
with its length field, when copying to userspace.
Cc: <stable@vger.kernel.org>
Reported-by: Nicolas Waisman <nico@semmle.com>
Signed-off-by: Will Deacon <will@kernel.org>
Link: https://lore.kernel.org/r/20191004095132.15777-2-will@kernel.org
[adjust commit log a bit]
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
There is not a valid reason to attempt setting the monitor channel
while in managed mode. Since this code path only deals with this mode,
remove the code block.
Johannes: I'll note that the comment indicated it was for backward
compatibility, but the code wasn't functional since switching the
monitor channel isn't supported (any more?) when in managed mode, as
that mode owns the channel configuration. Additionally, since monitor
can't be done on a managed mode interface, this would only have had
any effect to start with if a separate monitor interface is present,
in which case it's better to change the channel through that anyway,
if even possible.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
Add support for drivers that implement static WEP internally, i.e.
expose connection keys to the driver in connect flow and don't
upload the keys after the connection.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
There's no point in allowing connect keys when one of them
isn't also configured as the TX key, it would just confuse
drivers and probably cause them to pick something for TX.
Disallow this confusing and erroneous configuration.
As wpa_supplicant will always send NL80211_ATTR_KEYS, even
when there are no keys inside, allow that and treat it as
though the attribute isn't present at all.
After the previous patches, connect keys can only (correctly)
be used for storing static WEP keys. Therefore, remove all the
data for dealing with key index 4/5 and reduce the size of the
key material to the maximum for WEP keys.
Use the built-in function instead of memset.
When freeing the connect keys, clear the memory to avoid
having the key material stick around in memory "forever".
Name wiphy_to_rdev is more accurate to describe what the function
does, i.e., return a pointer pointing to struct
cfg80211_registered_device.
Signed-off-by: Zhao, Gang <gamerh2o@gmail.com>
cfg80211_wext_freq() is declared in wext-compat.h, but its
parameter struct wiphy's declaration is not included there.
As the parameter isn't used, just remove it.
[remove parameter instead of changing to netdev]
Macro ASSERT_RDEV_LOCK(rdev) is equal to ASSERT_RTNL(), so replace it
with ASSERT_RTNL() and remove it.
The current internal SME implementation in cfg80211 is
very mixed up with the MLME handling, which has been
causing issues for a long time. There are three things
that the implementation has to provide:
* a basic SME implementation for nl80211's connect()
call (for drivers implementing auth/assoc, which is
really just mac80211) and wireless extensions
* MLME events for the userspace SME
* SME events (connected, disconnected etc.) for all
different SME implementation possibilities (driver,
cfg80211 and userspace)
To achieve these goals it isn't necessary to track the
software SME's connection status outside of it's state
(which is the part that caused many issues.) Instead,
track it only in the SME data (wdev->conn) and in the
general case only track whether the wdev is connected
or not (via wdev->current_bss.)
Also separate the internal implementation to not have
callbacks from the SME events, but rather call it from
the API functions that the driver (or rather mac80211)
calls. This separates the code better.
By making all the API functions require wdev locking we
can clean up the API a bit, getting rid of the locking
version of each function. This also decreases the size
of cfg80211 by a small amount.
Virtually all code paths in cfg80211 already (need to) hold
the RTNL. As such, there's little point in having another
four mutexes for various parts of the code, they just cause
lock ordering issues (and much of the time, the RTNL and a
few of the others need thus be held.)
Simplify all this by getting rid of the extra four mutexes
and just use the RTNL throughout. Only a few code changes
were needed to do this and we can get rid of a work struct
for bonus points.
If a P2P device wdev is removed while it has a scan, then the
scan completion might crash later as it is already freed by
that time. To avoid the crash always check the scan completion
when the P2P device is being removed for some reason. If the
driver already canceled it, don't want and free it, otherwise
warn and leak it to avoid later crashes.
In order to do this, locking needs to be changed away from the
rdev mutex (which can't always be guaranteed). For now, use
the sched_scan_mtx instead, I'll rename it to just scan_mtx in
a later patch.
When a BSS struct is updated, the IEs are currently
overwritten or freed. This can lead to races if some
other CPU is accessing the BSS struct and using the
IEs concurrently.
Fix this by always allocating the IEs in a new struct
that holds the data and length and protecting access
to this new struct with RCU.
Change nl80211 to support specifying a VHT (or HT)
using the control channel frequency (as before) and
new attributes for the channel width and first and
second center frequency. The old channel type is of
course still supported for HT.
Also change the cfg80211 channel definition struct
to support these by adding the relevant fields to
it (and removing the _type field.)
This also adds new helper functions:
- cfg80211_chandef_create to create a channel def
struct given the control channel and channel type,
- cfg80211_chandef_identical to check if two channel
definitions are identical
- cfg80211_chandef_compatible to check if the given
channel definitions are compatible, and return the
wider of the two
This isn't entirely complete, but that doesn't matter
until we have a driver using it. In particular, it's
missing
- regulatory checks on the usable bandwidth (if that
even makes sense)
- regulatory TX power (database can't deal with it)
- a proper channel compatibility calculation for the
new channel types
Instead of passing a channel pointer and channel type
to all functions and driver methods, pass a new channel
definition struct. Right now, this struct contains just
the control channel and channel type, but for VHT this
will change.
Also, add a small inline cfg80211_get_chandef_type() so
that drivers don't need to use the _type field of the
new structure all the time, which will change.
Now that we've removed all uses of the set_channel
API except for the monitor channel and in libertas,
clarify this. Split the libertas mesh use into a
new libertas_set_mesh_channel() operation, just to
keep backward compatibility, and rename the normal
set_channel() to set_monitor_channel().
Also describe the desired set_monitor_channel()
semantics more clearly.
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
I removed a conversion from scan.c/cmp_bss_core
that appears to be a sorting function.
Done via cocci script:
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
Receive background scan period as part of connect
command and pass the same to the driver.
Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com>
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
A lot of code is dedicated to giving drivers the
ability to use cfg80211's wext handlers without
completely converting. However, only orinoco is
currently using this, and it is only partially
using it.
We reduce the size of both the source and binary
by removing those that nobody needs. If a driver
shows up that needs it during conversion, we can
add back those that are needed.
A lot of drivers erroneously use wext constants
and don't notice since cfg80211.h includes them.
Make this more split up so drivers needing wext
compatibility from cfg80211 need to explicitly
include that from cfg80211-wext.h.
Some vendor specified mechanisms for 802.1X-style
functionality use a different protocol than EAP
(even if EAP is vendor-extensible). Allow setting
the ethertype for the protocol when a driver has
support for this. The default if unspecified is
EAP, of course.
Note: This is suitable only for station mode, not
for AP implementation.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/ath/ar9170/main.c
Currently (all tested with hwsim) you can do stupid
things like setting up an AP on a certain channel,
then adding another virtual interface and making
that associate on another channel -- this will make
the beaconing to move channel but obviously without
the necessary IEs data update.
In order to improve this situation, first make the
configuration APIs (cfg80211 and nl80211) aware of
multi-channel operation -- we'll eventually need
that in the future anyway. There's one userland API
change and one API addition. The API change is that
now SET_WIPHY must be called with virtual interface
index rather than only wiphy index in order to take
effect for that interface -- luckily all current
users (hostapd) do that. For monitor interfaces, the
old setting is preserved, but monitors are always
slaved to other devices anyway so no guarantees.
The second userland API change is the introduction
of a per virtual interface SET_CHANNEL command, that
hostapd should use going forward to make it easier
to understand what's going on (it can automatically
detect a kernel with this command).
Other than mac80211, no existing cfg80211 drivers
are affected by this change because they only allow
a single virtual interface.
mac80211, however, now needs to be aware that the
channel settings are per interface now, and needs
to disallow (for now) real multi-channel operation,
which is another important part of this patch.
One of the immediate benefits is that you can now
start hostapd to operate on a hardware that already
has a connection on another virtual interface, as
long as you specify the same channel.
Note that two things are left unhandled (this is an
improvement -- not a complete fix):
* different HT/no-HT modes
currently you could start an HT AP and then
connect to a non-HT network on the same channel
which would configure the hardware for no HT;
that can be fixed fairly easily
* CSA
An AP we're connected to on a virtual interface
might indicate switching channels, and in that
case we would follow it, regardless of how many
other interfaces are operating; this requires
more effort to fix but is pretty rare after all
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
When wpa_supplicant is used to connect to open networks,
it causes the wdev->wext.keys to point to key memory, but
that key memory is all empty. Only use privacy when there
is a default key to be used.
Tested-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Tested-by: Kalle Valo <kalle.valo@iki.fi>
Currently, cfg80211's SIOCGIWAP implementation returns
the BSSID that the user set, even if the connection has
since been dropped due to other changes. It only should
return the current BSSID when actually connected.
Also do a small code cleanup.
Reported-by: Thomas H. Guenther <thomas.h.guenther@intel.com>
Tested-by: Thomas H. Guenther <thomas.h.guenther@intel.com>
When cfg80211 is instructed to connect, it always
uses the default WEP key for the privacy setting,
which clearly is wrong when using wpa_supplicant.
Don't overwrite the setting, and rely on it being
false when wpa_supplicant is not running, instead
set it to true when we have keys.
"cfg80211: validate channel settings across interfaces"
contained a locking bug -- in the managed-mode SIWFREQ
call it would end up running into a lock recursion.
This fixes it by not checking that particular interface
for a channel that it needs to stay on, which is as it
should be as that's the interface we're setting the
channel for.
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Reported-by: Kalle Valo <kalle.valo@iki.fi>
Tested-by: Reinette Chatre <reinette.chatre@intel.com>
With the move of everything related to the SME from
mac80211 to cfg80211, we lost the ability to send
reassociation frames. This adds them back, but only
for wireless extensions. With the userspace SME, it
shall control assoc vs. reassoc (it already can do
so with the nl80211 interface).
I haven't touched the connect() implementation, so
it is not possible to reassociate with the nl80211
connect primitive. I think that should be done with
the NL80211_CMD_ROAM command, but we'll have to see
how that can be handled in the future, especially
with fullmac chips.
This patch addresses only the immediate regression
we had in mac80211, which previously sent reassoc.
Currently, there's a problem that affects regulatory
enforcement and connection stability, in that it is
possible to switch the channel while connected to a
network or joined to an IBSS.
The problem comes from the fact that we only validate
the channel against the current interface's type, not
against any other interface. Thus, you have any type
of interface up, additionally bring up a monitor mode
interface and switch the channel on the monitor. This
will obviously also switch the channel on the other
interface.
The problem now is that if you do that while sending
beacons for IBSS mode, you can switch to a disabled
channel or a channel that doesn't allow beaconing.
Combined with a managed mode interface connected to
an AP instead of an IBSS interface, you can easily
break the connection that way.
To fix this, this patch validates any channel change
with all available interfaces, and disallows such
changes on secondary interfaces if another interface
is connected to an AP or joined to an IBSS.
cfg80211 displays correct link info when connected by wext. But if
the connection is setup by cfg80211, wext cannot display the SSID.
This patch fixed this issue.
Cc: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Since we now have handlers IWESSID for all modes, we can
combine them into one.
Since we now have IWAP handlers for all modes, we can
Until now we implemented iwfreq for managed mode, we
needed to keep the implementations separate, but now
that we have all versions implemented we can combine
them and export just one handler.
In the wext code I tried to not reconnect all the time
when the user wasn't really sure what they were doing,
like setting the BSSID back to the same value it was.
However, this optimisation should only be done while
associated so that setting the BSSID back to the same
value that it was actually triggers a new association
if not currently associated. To achieve, that, put the
relevant code into the !IDLE case instead.
Tested-by: Marcel Holtmann <marcel@holtmann.org>
Pavel reported that you can't set the SSID from "foo" to
"bar". I tried reproducing, but used different values,
with different lengths, and thus never saw the obvious
problem.
Reported-by: Pavel Roskin <proski@gnu.org>
This variable is only used internally, _while_ connected.
If we use it, the sequence
# iwconfig wlan1 essid foo
<connects>
# iwconfig wlan1 essid ""
<disconnects>
# iwconfig
will still display "foo" as the SSID afterwards, which
is obviously quite bogus. Fix this by only displaying
the wext SSID, if present.
This reworks the key operation in cfg80211, and now only
allows, from userspace, configuring keys (via nl80211)
after the connection has been established (in managed
mode), the IBSS been joined (in IBSS mode), at any time
(in AP[_VLAN] modes) or never for all the other modes.
In order to do shared key authentication correctly, it
is now possible to give a WEP key to the AUTH command.
To configure static WEP keys, these are given to the
CONNECT or IBSS_JOIN command directly, for a userspace
SME it is assumed it will configure it properly after
the connection has been established.
Since mac80211 used to check the default key in IBSS
mode to see whether or not the network is protected,
it needs an update in that area, as well as an update
to make use of the WEP key passed to auth() for shared
key authentication.
Over time, a lot of locking issues have crept into
the smarts of cfg80211, so e.g. scan completion can
race against a new scan, IBSS join can race against
leaving an IBSS, etc.
Introduce a new per-interface lock that protects
most of the per-interface data that we need to keep
track of, and sprinkle assertions about that lock
everywhere. Some things now need to be offloaded to
work structs so that we don't require being able to
sleep in functions the drivers call. The exception
to that are the MLME callbacks (rx_auth etc.) that
currently only mac80211 calls because it was easier
to do that there instead of in cfg80211, and future
drivers implementing those calls will, if they ever
exist, probably need to use a similar scheme like
mac80211 anyway...
In order to be able to handle _deauth and _disassoc
properly, introduce a cookie passed to it that will
determine locking requirements.
In order to avoid problems with BSS structs going away
while they're in use, I've long wanted to make cfg80211
keep track of them. Without the SME, that wasn't doable
but now that we have the SME we can do this too. It can
keep track of up to four separate authentications and
one association, regardless of whether it's controlled
by the cfg80211 SME or the userspace SME.
This adds code to make it possible to use the cfg80211
connect() API with wireless extensions, and because the
previous patch added emulation of that API with auth()
and assoc(), by extension also supports wext on that.
At the same time, removes code from mac80211 for wext,
but doesn't yet clean up mac80211's mlme code more.
Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com>
