commit 9236d838c920e90708570d9bbd7bb82d30a38130 upstream.
When operating in a mode that initiates communication and using
HT40 we should fail if we cannot use both primary and secondary
channels to initiate communication. Our current ht40 allowmap
only covers STA mode of operation, for beaconing modes we need
a check on the fly as the mode of operation is dynamic and
there other flags other than disable which we should read
to check if we can initiate communication.
Do not allow for initiating communication if our secondary HT40
channel has is either disabled, has a passive scan flag, a
no-ibss flag or is a radar channel. Userspace now has similar
checks but this is also needed in-kernel.
Reported-by: Jouni Malinen <jouni.malinen@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit a171fba491f54216e356efa46096171a7ed01d10 upstream.
The patch 4f366c5:
wireless: only use alpha2 regulatory information from country IE
removed some complex intersection we were always doing between the AP's
country IE info and what we got from CRDA. When CRDA sent us back a
regulatory domain we would do some sanity checks on that regulatory
domain response we just got. Part of these sanity checks included
checking that we already had performed an intersection for the
request of NL80211_REGDOM_SET_BY_COUNTRY_IE type.
This mean that cfg80211 was only processing country IEs for cases
where we already had an intersection, but since we removed enforcing
this this is no longer required, we should just apply the country
IE country hint with the data received from CRDA.
This patch has fixes intended for kernels >= 2.6.36.
Reported-by: Easwar Krishnan <easwar.krishnan@atheros.com>
commit 2234362c427e2ef667595b9b81c0125003ac5607 upstream.
Add missing unlocking of the wiphy in set_channel,
and don't try to unlock a non-existing wiphy in
set_cqm.
commit 3207390a8b58bfc1335750f91cf6783c48ca19ca upstream.
When multiple interfaces are actively trying
to associate with the same BSS, they may both
find that the BSS isn't there and then try to
unlink it. This can cause errors since the
unlinking code can't currently deal with items
that have already been unlinked.
Normally this doesn't happen as most people
don't try to use multiple station interfaces
that associate at the same time too.
Fix this by using the list entry as a flag to
see if the item is still on a list.
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Hun-Kyi Wynn <hkwynn@candelatech.com>
When a driver doesn't fill the entire buffer, old
heap contents may remain, and if it also doesn't
update the length properly, this old heap content
will be copied back to userspace.
It is very unlikely that this happens in any of
the drivers using private ioctls since it would
show up as junk being reported by iwpriv, but it
seems better to be safe here, so use kzalloc.
Reported-by: Jeff Mahoney <jeffm@suse.com>
Cc: stable@kernel.org
Otherwise lockdep complains...
https://bugzilla.kernel.org/show_bug.cgi?id=17311
[ INFO: possible circular locking dependency detected ]
2.6.36-rc2-git4 #12
kworker/0:3/3630 is trying to acquire lock:
(rtnl_mutex){+.+.+.}, at: [<ffffffff813396c7>] rtnl_lock+0x12/0x14
but task is already holding lock:
(rfkill_global_mutex){+.+.+.}, at: [<ffffffffa014b129>]
rfkill_switch_all+0x24/0x49 [rfkill]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (rfkill_global_mutex){+.+.+.}:
[<ffffffff81079ad7>] lock_acquire+0x120/0x15b
[<ffffffff813ae869>] __mutex_lock_common+0x54/0x52e
[<ffffffff813aede9>] mutex_lock_nested+0x34/0x39
[<ffffffffa014b4ab>] rfkill_register+0x2b/0x29c [rfkill]
[<ffffffffa0185ba0>] wiphy_register+0x1ae/0x270 [cfg80211]
[<ffffffffa0206f01>] ieee80211_register_hw+0x1b4/0x3cf [mac80211]
[<ffffffffa0292e98>] iwl_ucode_callback+0x9e9/0xae3 [iwlagn]
[<ffffffff812d3e9d>] request_firmware_work_func+0x54/0x6f
[<ffffffff81065d15>] kthread+0x8c/0x94
[<ffffffff8100ac24>] kernel_thread_helper+0x4/0x10
-> #1 (cfg80211_mutex){+.+.+.}:
[<ffffffffa018605e>] cfg80211_get_dev_from_ifindex+0x1b/0x7c [cfg80211]
[<ffffffffa0189f36>] cfg80211_wext_giwscan+0x58/0x990 [cfg80211]
[<ffffffff8139a3ce>] ioctl_standard_iw_point+0x1a8/0x272
[<ffffffff8139a529>] ioctl_standard_call+0x91/0xa7
[<ffffffff8139a687>] T.723+0xbd/0x12c
[<ffffffff8139a727>] wext_handle_ioctl+0x31/0x6d
[<ffffffff8133014e>] dev_ioctl+0x63d/0x67a
[<ffffffff8131afd9>] sock_ioctl+0x48/0x21d
[<ffffffff81102abd>] do_vfs_ioctl+0x4ba/0x509
[<ffffffff81102b5d>] sys_ioctl+0x51/0x74
[<ffffffff81009e02>] system_call_fastpath+0x16/0x1b
-> #0 (rtnl_mutex){+.+.+.}:
[<ffffffff810796b0>] __lock_acquire+0xa93/0xd9a
[<ffffffffa0185cb5>] cfg80211_rfkill_set_block+0x1a/0x7b [cfg80211]
[<ffffffffa014aed0>] rfkill_set_block+0x80/0xd5 [rfkill]
[<ffffffffa014b07e>] __rfkill_switch_all+0x3f/0x6f [rfkill]
[<ffffffffa014b13d>] rfkill_switch_all+0x38/0x49 [rfkill]
[<ffffffffa014b821>] rfkill_op_handler+0x105/0x136 [rfkill]
[<ffffffff81060708>] process_one_work+0x248/0x403
[<ffffffff81062620>] worker_thread+0x139/0x214
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Wireless extensions have an unfortunate, undocumented
requirement which requires drivers to always fill
iwp->length when returning a successful status. When
a driver doesn't do this, it leads to a kernel heap
content leak when userspace offers a larger buffer
than would have been necessary.
Arguably, this is a driver bug, as it should, if it
returns 0, fill iwp->length, even if it separately
indicated that the buffer contents was not valid.
However, we can also at least avoid the memory content
leak if the driver doesn't do this by setting the iwp
length to max_tokens, which then reflects how big the
buffer is that the driver may fill, regardless of how
big the userspace buffer is.
To illustrate the point, this patch also fixes a
corresponding cfg80211 bug (since this requirement
isn't documented nor was ever pointed out by anyone
during code review, I don't trust all drivers nor
all cfg80211 handlers to implement it correctly).
Cc: stable@kernel.org [all the way back]
Accesses to "wdev->current_bss" must be
locked with the wdev lock, which action
frame transmission is missing.
Cc: stable@kernel.org [2.6.33+]
In some cases there could be possible dereferencing freed pointer. The
update is intended to avoid this issue.
Signed-off-by: Yuri Ershov <ext-yuri.ershov@nokia.com>
In case of errors during message composing msg should be freed after canceling.
Signed-off-by: Yuri Kululin <ext-yuri.kululin@nokia.com>
Save a few bytes of text
(allyesconfig)
$ size drivers/net/wireless/built-in.o*
3924568 100548 871056 4896172 4ab5ac drivers/net/wireless/built-in.o.new
3926520 100548 871464 4898532 4abee4 drivers/net/wireless/built-in.o.old
$ size net/wireless/core.o*
12843 216 3768 16827 41bb net/wireless/core.o.new
12328 216 3656 16200 3f48 net/wireless/core.o
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6
drivers/net/wireless/iwlwifi/iwl-commands.h
When wireless extensions are used to control
an encrypted IBSS, we erroneously can try to
set the default management key. Fix this.
The "rd" variable isn't needed any more since 4f366c5dabcb
"wireless: only use alpha2 regulatory information from country IE"
device_add() is called before adding the phy to the cfg80211 device
list.
So if a userspace program uses sysfs uevents to detect new phy
devices, and queries nl80211 to get phy info, it can get ENODEV even
though the phy exists in sysfs.
An easy workaround is to hold the cfg80211 mutex until the phy is
present in sysfs/cfg80211/debugfs.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
"Might as well remove reg_same_country_ie_hint() completely since we
already dealt with suspend/resume through the regulatory hint
disconnect." -- Luis
Reported-by: Luis R. Rodriguez <mcgrof@gmail.com>
CHECK net/wireless/sme.c
net/wireless/sme.c:38:6: warning: symbol 'cfg80211_is_all_idle' was not declared. Should it be static?
It is not used elsewhere, so mark it static.
CHECK net/wireless/regdb.c
net/wireless/regdb.c:8:34: warning: symbol 'reg_regdb' was not declared. Should it be static?
net/wireless/regdb.c:11:5: warning: symbol 'reg_regdb_size' was not declared. Should it be static?
Simply include the also generated regdb.h.
CHECK net/wireless/wext-compat.c
net/wireless/wext-compat.c:1434:5: warning: symbol 'cfg80211_wext_siwpmksa' was not declared. Should it be static?
Add declaration in cfg80211.h. Also add an EXPORT_SYMBOL_GPL, since all
the peer functions have it.
CHECK net/wireless/lib80211_crypt_tkip.c
net/wireless/lib80211_crypt_tkip.c:581:27: warning: cast to restricted __le16
Caused by dereferencing a "u8 *" and passing it to le16_to_cpu...
The meaning and/or usage of the country IE is somewhat poorly defined.
In practice, this means that regulatory rulesets in a country IE are
often incomplete and might be untrustworthy. This removes the code
associated with interpreting those rulesets while preserving respect
for country "alpha2" codes also contained in the country IE.
When kernel-internal users use cfg80211_get_bss()
to get a reference to a BSS struct, they may end
up getting one that would have been removed from
the list if there had been any userspace access
to the list. This leads to inconsistencies and
problems.
Fix it by making cfg80211_get_bss() ignore BSSes
that cfg80211_bss_expire() would remove.
Fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2180
Reported-by: Jiajia Zheng <jiajia.zheng@intel.com>
Tested-by: Jiajia Zheng <jiajia.zheng@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/wl12xx/wl1271_cmd.h
Ever since mac80211/drivers are no longer
fully in charge of keeping track of the
auth status, trying to make them do so will
fail. Instead of warning and reporting the
deauthentication to userspace, cfg80211 must
simply ignore it so that spurious
deauthentications, e.g. before starting
authentication, aren't seen by userspace as
actual deauthentications.
Reported-by: Paul Stewart <pstew@google.com>
Stanse found that nl80211_set_wiphy imporperly handles a lock and netdev
reference and contains unreachable code. It is because there return statement
isntead of assignment to result variable. Fix that.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Jouni Malinen <j@w1.fi>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
drivers/net/wireless/libertas/host.h
This patch adds transmit power setting type and transmit power level attributes
to NL80211_CMD_SET_WIPHY in order to facilitate adjusting of the transmit power
level of the device.
The added attributes allow selection of automatic, limited or fixed transmit
power level, with the level definable in signed mBm format.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
In preparation for a TX power setting interface in the nl80211, change the
.set_tx_power function to use mBm units instead of dBm for greater accuracy and
smaller power levels.
Also, already in advance move the tx_power_setting enumeration to nl80211.
This change affects the .tx_set_power function prototype. As a result, the
corresponding changes are needed to modules using it. These are mac80211,
iwmc3200wifi and rndis_wlan.
Cc: Samuel Ortiz <samuel.ortiz@intel.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Acked-by: Samuel Ortiz <samuel.ortiz@intel.com>
Acked-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
regulatory_init is only called by cfg80211_init which is in .init.text,
too.
cfg80211_exit is only used as module_exit function, so it can go to
.exit.text saving a few bytes when CONFIG_CFG80211=y.
Register net_bridge_port pointer as rx_handler data pointer. As br_port is
removed from struct net_device, another netdev priv_flag is added to indicate
the device serves as a bridge port. Also rcuized pointers are now correctly
dereferenced in br_fdb.c and in netfilter parts.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This patch adds support to nl80211 and mac80211 to set basic rates when
joining/creating ibss network.
Original patch was posted by Johannes Berg on the linux-wireless posting list.
Signed-off-by: Teemu Paasikivi <ext-teemu.3.paasikivi@nokia.com>
When in IBSS mode, currently action frame TX and RX
cannot be used. Allow using it to talk to any peer,
or for public action frames. Also, while at it,
restructure the code in mac80211 to make it easier
to add this for other interface types in the future.
When sending action frames, we want to verify
that we do that on the correct channel. However,
checking the channel type in addition can get in
the way, since the channel type could change on
the fly during an association, and it's not
useful to have the channel type anyway since it
has no effect on the transmission. Therefore,
make it optional to specify so that if wanted,
it can still be checked, but is not required.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Don't refuse HT20 channels on devices that don't support HT40.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Specifying a valid channel type will get
goto out rather than continuing, due to
missing braces. This affects both remain
on channel and action frame TX commands.
Since wdev can be NULL, check it before dereferencing it
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
signal_type is enum cfg80211_signal_type.
This fixes the gcc warning:
scan.c: In function `cfg80211_inform_bss':
scan.c:518:6: warning: comparison between `enum cfg80211_signal_type' and `enum nl80211_bss'
scan.c: In function `cfg80211_inform_bss_frame':
scan.c:574:6: warning: comparison between `enum cfg80211_signal_type' and `enum nl80211_bss'
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
drivers/net/wireless/ath/ar9170/main.c
Currently (all tested with hwsim) you can do stupid
things like setting up an AP on a certain channel,
then adding another virtual interface and making
that associate on another channel -- this will make
the beaconing to move channel but obviously without
the necessary IEs data update.
In order to improve this situation, first make the
configuration APIs (cfg80211 and nl80211) aware of
multi-channel operation -- we'll eventually need
that in the future anyway. There's one userland API
change and one API addition. The API change is that
now SET_WIPHY must be called with virtual interface
index rather than only wiphy index in order to take
effect for that interface -- luckily all current
users (hostapd) do that. For monitor interfaces, the
old setting is preserved, but monitors are always
slaved to other devices anyway so no guarantees.
The second userland API change is the introduction
of a per virtual interface SET_CHANNEL command, that
hostapd should use going forward to make it easier
to understand what's going on (it can automatically
detect a kernel with this command).
Other than mac80211, no existing cfg80211 drivers
are affected by this change because they only allow
a single virtual interface.
mac80211, however, now needs to be aware that the
channel settings are per interface now, and needs
to disallow (for now) real multi-channel operation,
which is another important part of this patch.
One of the immediate benefits is that you can now
start hostapd to operate on a hardware that already
has a connection on another virtual interface, as
long as you specify the same channel.
Note that two things are left unhandled (this is an
improvement -- not a complete fix):
* different HT/no-HT modes
currently you could start an HT AP and then
connect to a non-HT network on the same channel
which would configure the hardware for no HT;
that can be fixed fairly easily
* CSA
An AP we're connected to on a virtual interface
might indicate switching channels, and in that
case we would follow it, regardless of how many
other interfaces are operating; this requires
more effort to fix but is pretty rare after all
drivers/net/wireless/libertas_tf/cmd.c
drivers/net/wireless/libertas_tf/main.c
Now that the mac80211 is choosing dynamic ps timeouts based on the ps-qos
network latency configuration, configure a default value of -1 as the dynamic
ps timeout in cfg80211. This value allows the mac80211 to determine the value
to be used.
This is used to configure APs to not bridge traffic between connected stations.
drivers/net/wireless/ath/ath9k/phy.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-debugfs.c
event body
In a scenario, where a cfg80211 driver (station mode) does not send assoc request
and assoc response IEs in cfg80211_connect_result after a successful association
to an AP, cfg80211 sends IWEVASSOCREQIE and IWEVASSOCRESPIE to the user space
application with NULL data. This can cause an issue at the event recipient.
An example of this is when cfg80211 sends IWEVASSOCREQIE and IWEVASSOCRESPIE
events with NULL event body to wpa_supplicant. The wpa_supplicant overwrites
the assoc request and assoc response IEs for this station with NULL data.
If the association is WPA/WPA2, the wpa_supplicant is not able to generate
EAPOL handshake messages, since the IEs are NULL.
With the patch, req_ie and resp_ie will be NULL by avoiding the
assignment if the driver has not sent the IEs to cfg80211. The event sending
code sends the events only if resp_ie and req_ie are not NULL. This
will ensure that the events are not sent with NULL event body.
Signed-off-by: Nishant Sarmukadam <nishants@marvell.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
