(cherry picked from commit 259d8c1e984318497c84eef547bbb6b1d9f4eb05)
Wireless drivers rely on parse_txq_params to validate that txq_params->ac
is less than NL80211_NUM_ACS by the time the low-level driver's ->conf_tx()
handler is called. Use a new helper, array_index_nospec(), to sanitize
txq_params->ac with respect to speculation. I.e. ensure that any
speculation into ->conf_tx() handlers is done with a value of
txq_params->ac that is within the bounds of [0, NL80211_NUM_ACS).
Reported-by: Christian Lamparter <chunkeey@gmail.com>
Reported-by: Elena Reshetova <elena.reshetova@intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Cc: kernel-hardening@lists.openwall.com
Cc: gregkh@linuxfoundation.org
Cc: linux-wireless@vger.kernel.org
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727419584.33451.7700736761686184303.stgit@dwillia2-desk3.amr.corp.intel.com
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[jwang: cherry pick to 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit 59b179b48ce2a6076448a44531242ac2b3f6cef2 upstream.
syzbot reported a warning from rfkill_alloc(), and after a while
I think that the reason is that it was doing fault injection and
the dev_set_name() failed, leaving the name NULL, and we didn't
check the return value and got to rfkill_alloc() with a NULL name.
Since we really don't want a NULL name, we ought to check the
return value.
Fixes: fb28ad35906a ("net: struct device - replace bus_id with dev_name(), dev_set_name()")
Reported-by: syzbot+1ddfb3357e1d7bb5b5d3@syzkaller.appspotmail.com
commit ad670233c9e1d5feb365d870e30083ef1b889177 upstream.
Define a policy for packet pattern attributes in order to fix a
potential read over the end of the buffer during nla_get_u32()
of the NL80211_PKTPAT_OFFSET attribute.
Note that the data there can always be read due to SKB allocation
(with alignment and struct skb_shared_info at the end), but the
data might be uninitialized. This could be used to leak some data
from uninitialized vmalloc() memory, but most drivers don't allow
an offset (so you'd just get -EINVAL if the data is non-zero) or
just allow it with a fixed value - 100 or 128 bytes, so anything
above that would get -EINVAL. With brcmfmac the limit is 1500 so
(at least) one byte could be obtained.
Cc: stable@kernel.org
Signed-off-by: Peng Xu <pxu@qti.qualcomm.com>
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[rewrite description based on SKB allocation knowledge]
commit e785fa0a164aa11001cba931367c7f94ffaff888 upstream.
nl80211_set_rekey_data() does not check if the required attributes
NL80211_REKEY_DATA_{REPLAY_CTR,KEK,KCK} are present when processing
NL80211_CMD_SET_REKEY_OFFLOAD request. This request can be issued by
users with CAP_NET_ADMIN privilege and may result in NULL dereference
and a system crash. Add a check for the required attributes presence.
This patch is based on the patch by bo Zhang.
This fixes CVE-2017-12153.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1491046
Fixes: e5497d766ad ("cfg80211/nl80211: support GTK rekey offload")
Reported-by: bo Zhang <zhangbo5891001@gmail.com>
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
commit 9361df14d1cbf966409d5d6f48bb334384fbe138 upstream.
nla policy checks for only maximum length of the attribute data
when the attribute type is NLA_BINARY. If userspace sends less
data than specified, the wireless drivers may access illegal
memory. When type is NLA_UNSPEC, nla policy check ensures that
userspace sends minimum specified length number of bytes.
Remove type assignment to NLA_BINARY from nla_policy of
NL80211_ATTR_PMKID to make this NLA_UNSPEC and to make sure minimum
WLAN_PMKID_LEN bytes are received from userspace with
NL80211_ATTR_PMKID.
Fixes: 67fbb16be69d ("nl80211: PMKSA caching support")
Signed-off-by: Srinivas Dasari <dasaris@qti.qualcomm.com>
commit d7f13f7450369281a5d0ea463cc69890a15923ae upstream.
validate_scan_freqs() retrieves frequencies from attributes
nested in the attribute NL80211_ATTR_SCAN_FREQUENCIES with
nla_get_u32(), which reads 4 bytes from each attribute
without validating the size of data received. Attributes
nested in NL80211_ATTR_SCAN_FREQUENCIES don't have an nla policy.
Validate size of each attribute before parsing to avoid potential buffer
overread.
Fixes: 2a519311926 ("cfg80211/nl80211: scanning (and mac80211 update to use it)")
commit 8feb69c7bd89513be80eb19198d48f154b254021 upstream.
Buffer overread may happen as nl80211_set_station() reads 4 bytes
from the attribute NL80211_ATTR_LOCAL_MESH_POWER_MODE without
validating the size of data received when userspace sends less
than 4 bytes of data with NL80211_ATTR_LOCAL_MESH_POWER_MODE.
Define nla_policy for NL80211_ATTR_LOCAL_MESH_POWER_MODE to avoid
the buffer overread.
Fixes: 3b1c5a5307f ("{cfg,nl}80211: mesh power mode primitives and userspace access")
commit ea90e0dc8cecba6359b481e24d9c37160f6f524f upstream.
Sowmini pointed out Dmitry's RTNL deadlock report to me, and it turns out
to be perfectly accurate - there are various error paths that miss unlock
of the RTNL.
To fix those, change the locking a bit to not be conditional in all those
nl80211_prepare_*_dump() functions, but make those require the RTNL to
start with, and fix the buggy error paths. This also let me use sparse
(by appropriately overriding the rtnl_lock/rtnl_unlock functions) to
validate the changes.
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
commit 753aacfd2e95df6a0caf23c03dc309020765bea9 upstream.
A single netlink socket might own multiple interfaces *and* a
scheduled scan request (which might belong to another interface),
so when it goes away both may need to be destroyed.
Remove the schedule_scan_stop indirection to fix this - it's only
needed for interface destruction because of the way this works
right now, with a single work taking care of all interfaces.
Fixes: 93a1e86ce10e4 ("nl80211: Stop scheduled scan if netlink client disappears")
commit e6f462df9acd2a3295e5d34eb29e2823220cf129 upstream.
When mac80211 abandons an association attempt, it may free
all the data structures, but inform cfg80211 and userspace
about it only by sending the deauth frame it received, in
which case cfg80211 has no link to the BSS struct that was
used and will not cfg80211_unhold_bss() it.
Fix this by providing a way to inform cfg80211 of this with
the BSS entry passed, so that it can clean up properly, and
use this ability in the appropriate places in mac80211.
This isn't ideal: some code is more or less duplicated and
tracing is missing. However, it's a fairly small change and
it's thus easier to backport - cleanups can come later.
commit 9853a55ef1bb66d7411136046060bbfb69c714fa upstream.
It's possible to make scanning consume almost arbitrary amounts
of memory, e.g. by sending beacon frames with random BSSIDs at
high rates while somebody is scanning.
Limit the number of BSS table entries we're willing to cache to
1000, limiting maximum memory usage to maybe 4-5MB, but lower
in practice - that would be the case for having both full-sized
beacon and probe response frames for each entry; this seems not
possible in practice, so a limit of 1000 entries will likely be
closer to 0.5 MB.
commit ad5987b47e96a0fb6d13fea250e936aed000093c upstream.
Due to an apparent copy/paste bug, the number of counters for the
beacon configuration were checked twice, instead of checking the
number of probe response counters. Fix this to check the number of
probe response counters before parsing those.
Fixes: 9a774c78e211 ("cfg80211: Support multiple CSA counters")
commit 4d0bd46a4d55383f7b925e6cf7865a77e0f0e020 upstream.
This reverts commit 3d5fdff46c4b2b9534fa2f9fc78e90a48e0ff724.
Ben Hutchings pointed out that the commit isn't safe since it assumes
that the structure used by the driver is iw_point, when in fact there's
no way to know about that.
Fortunately, the only driver in the tree that ever runs this code path
is the wilc1000 staging driver, so it doesn't really matter.
Clearly I should have investigated this better before applying, sorry.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Fixes: 3d5fdff46c4b ("wext: Fix 32 bit iwpriv compatibility issue with 64 bit Kernel")
commit 3d5fdff46c4b2b9534fa2f9fc78e90a48e0ff724 upstream.
iwpriv app uses iw_point structure to send data to Kernel. The iw_point
structure holds a pointer. For compatibility Kernel converts the pointer
as required for WEXT IOCTLs (SIOCIWFIRST to SIOCIWLAST). Some drivers
may use iw_handler_def.private_args to populate iwpriv commands instead
of iw_handler_def.private. For those case, the IOCTLs from
SIOCIWFIRSTPRIV to SIOCIWLASTPRIV will follow the path ndo_do_ioctl().
Accordingly when the filled up iw_point structure comes from 32 bit
iwpriv to 64 bit Kernel, Kernel will not convert the pointer and sends
it to driver. So, the driver may get the invalid data.
The pointer conversion for the IOCTLs (SIOCIWFIRSTPRIV to
SIOCIWLASTPRIV), which follow the path ndo_do_ioctl(), is mandatory.
This patch adds pointer conversion from 32 bit to 64 bit and vice versa,
if the ioctl comes from 32 bit iwpriv to 64 bit Kernel.
Signed-off-by: Prasun Maiti <prasunmaiti87@gmail.com>
Signed-off-by: Ujjal Roy <royujjal@gmail.com>
Tested-by: Dibyajyoti Ghosh <dibyajyotig@gmail.com>
commit 8f815cdde3e550e10c2736990d791f60c2ce43eb upstream.
A non-privileged user can create a netlink socket with the same port_id as
used by an existing open nl80211 netlink socket (e.g. as used by a hostapd
process) with a different protocol number.
Closing this socket will then lead to the notification going to nl80211's
socket release notification handler, and possibly cause an action such as
removing a virtual interface.
Fix this issue by checking that the netlink protocol is NETLINK_GENERIC.
Since generic netlink has no notifier chain of its own, we can't fix the
problem more generically.
Fixes: 026331c4d9b5 ("cfg80211/mac80211: allow registering for and sending action frames")
Signed-off-by: Dmitry Ivanov <dima@ubnt.com>
[rewrite commit message]
commit cb150b9d23be6ee7f3a0fff29784f1c5b5ac514d upstream.
Since cfg80211 frequently takes actions from its netdev notifier
call, wireless extensions messages could still be ordered badly
since the wext netdev notifier, since wext is built into the
kernel, runs before the cfg80211 netdev notifier. For example,
the following can happen:
5: wlan1: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN group default
link/ether 02:00:00:00:01:00 brd ff:ff:ff:ff:ff:ff
5: wlan1: <BROADCAST,MULTICAST,UP>
link/ether
when setting the interface down causes the wext message.
To also fix this, export the wireless_nlevent_flush() function
and also call it from the cfg80211 notifier.
commit 8bf862739a7786ae72409220914df960a0aa80d8 upstream.
Beniamino reported that he was getting an RTM_NEWLINK message for a
given interface, after the RTM_DELLINK for it. It turns out that the
message is a wireless extensions message, which was sent because the
interface had been connected and disconnection while it was deleted
caused a wext message.
For its netlink messages, wext uses RTM_NEWLINK, but the message is
without all the regular rtnetlink attributes, so "ip monitor link"
prints just rudimentary information:
Deleted 5: wlan1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default
link/ether
(from my hwsim reproduction)
This can cause userspace to get confused since it doesn't expect an
RTM_NEWLINK message after RTM_DELLINK.
The reason for this is that wext schedules a worker to send out the
messages, and the scheduling delay can cause the messages to get out
to userspace in different order.
To fix this, have wext register a netdevice notifier and flush out
any pending messages when netdevice state changes. This fixes any
ordering whenever the original message wasn't sent by a notifier
itself.
Reported-by: Beniamino Galvani <bgalvani@redhat.com>
Free cached keys if the last early return path is taken.
Signed-off-by: Ola Olsson <ola.olsson@sonymobile.com>
Compared to cfg80211_rdev_free_wowlan in core.h,
the error goto label lacks the freeing of nd_config.
Fix that.
The first leak occurs when entering the default case
in the switch for the initiator in set_regdom.
The second leaks a platform_device struct if the
platform registration in regulatory_init succeeds but
the sub sequent regulatory hint fails due to no memory.
Currently, cfg80211 rejects updates of AID and listen interval parameters
for existing entries. This information is known only at association stage
and as a result it's impossible to update entries that were added
unassociated.
Fix this by allowing updates of these properies for stations that the
driver (or mac80211) assigned unassociated state.
This then fixes mac80211's use of NL80211_FEATURE_FULL_AP_CLIENT_STATE.
Signed-off-by: Ayala Beker <ayala.beker@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
If parse_acl_data succeeds but the subsequent parsing of smps
attributes fails, there will be a memory leak due to early returns.
Fix that by moving the ACL parsing later.
Cc: stable@vger.kernel.org
Fixes: 18998c381b19b ("cfg80211: allow requesting SMPS mode on ap start")
The return type should be enum reg_request_treatment for both
branches of the #ifdef.
The function is void and static, so just ifdef its contents
instead of duplicating the declaration.
Printing "N/A mBi" is strange - print just "N/A" instead.
Also add a missing opening parenthesis.
Instead of having a lot of places that free ignored requests
and then return REG_REQ_OK, make reg_process_hint() process
REG_REQ_IGNORE by freeing the request, and let functions it
calls return that instead of freeing.
This also fixes a leak when a second (different) country IE
hint was ignored.
This function can only deal with treatment values OK and ALREADY_SET
so make the callees not return anything else and warn if they do.
The new name better reflects the functionality.
If there's a built-in regulatory database, there may be little point
in also calling out to CRDA and failing if the system is configured
that way. Allow removing CRDA support to save ~1K kernel size.
When the functions reg_set_rd_driver() and reg_set_rd_country_ie()
return with an error, the calling function already restores data
by calling restore_regulatory_settings(), so there's no need to
also schedule a timeout (which would lead to other side effects
such as indicating CRDA failed, which clearly isn't true.) Remove
the scheduling.
Instead of searching the built-in database only in the worker,
search it directly and return an error if the entry cannot be
found (or memory cannot be allocated.) This means that builtin
database queries no longer rely on the timeout.
The new name is more appropriate since in the case of a built-in
database it may not really rely on CRDA.
The function reg_call_crda() can't actually validly return
REG_REQ_IGNORE as it does now when calling CRDA fails since
that return value isn't handled properly. Fix that.
There's no way that the alpha2 pointer can be NULL, so
no point in checking that it isn't.
There's no "g" prefix, only "G" (1e9) that was clearly intended here.
Add the option to configure multiple 'scan plans' for scheduled scan.
Each 'scan plan' defines the number of scan cycles and the interval
between scans. The scan plans are executed in the order they were
configured. The last scan plan will always run infinitely and thus
defines only the interval between scans.
The maximum number of scan plans supported by the device and the
maximum number of iterations in a single scan plan are advertised
to userspace so it can configure the scan plans appropriately.
When scheduled scan results are received there is no way to know which
scan plan is being currently executed, so there is no way to know when
the next scan iteration will start. This is not a problem, however.
The scan start timestamp is only used for flushing old scan results,
and there is no difference between flushing all results received until
the end of the previous iteration or the start of the current one,
since no results will be received in between.
Signed-off-by: Avraham Stern <avraham.stern@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
For location and connectivity services, userspace would often like
to know the time when the BSS was last seen. The current "last seen"
value is calculated in a way that makes it less useful, especially
if the system suspended in the meantime.
Add the ability for the driver to report a real CLOCK_BOOTTIME stamp
that can then be reported to userspace (if present).
Drivers wishing to use this must be converted to the new API to call
cfg80211_inform_bss_data() or cfg80211_inform_bss_frame_data(). They
need to ensure the reported value is accurate enough even when the
frame might have been buffered in the device (e.g. firmware.)
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
[modified to use struct, inlines]
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
For the current cycle, we have the following right now:
* many internal fixes, API improvements, cleanups, etc.
* full AP client state tracking in cfg80211/mac80211 from Ayala
* VHT support (in mac80211) for mesh
* some A-MSDU in A-MPDU support from Emmanuel
* show current TX power to userspace (from Rafał)
* support for netlink dump in vendor commands (myself)
Currently, cfg80211 rejects capability updates for existing entries
unassociated, but that is necessary to go through the full station
states from userspace, adding a station before authentication etc.
Fix this by allowing updates to capabilities for stations that the
driver (or mac80211) assigned unassociated state. Drivers setting
the full station state support flag must use the new station type
for proper operation.
Now, PM core supports asynchronous suspend/resume mode for devices
during system suspend/resume, and the power state transition of one
device may be completed in separate kernel thread. PM core ensures
all power state transition timing dependency between devices. This
patch enables wiphy device to suspend/resume asynchronously. This can
take advantage of multicore and improve system suspend/resume speed.
Signed-off-by: Zhonghui Fu <zhonghui.fu@linux.intel.com>
Many drivers implement reading current TX power (using either cfg80211
or ieee80211 op) but userspace can't get it using nl80211. Right now the
only way to access it is to call some wext ioctl.
Let's put TX power in interface info reply (callback is wdev specific)
just like we do with current channel.
To be consistent (e.g. NL80211_CMD_SET_WIPHY) let's use mBm as na unit.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
In order to transfer many items in vendor commands, support the
dumpit netlink method for them.
As pointed out by sparse, this symbol should be static, make it so.
restore_regulatory_settings() should restore alpha2
as computed in restore_alpha2(), not raw user_alpha2 to
behave as described in the comment just above that code.
This fixes endless loop of calling CRDA for "00" and "97"
countries after resume from suspend on my laptop.
Looks like others had the same problem, too:
http://ath9k-devel.ath9k.narkive.com/knY5W6St/ath9k-and-crda-messages-in-logs
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/899335
https://forum.porteus.org/viewtopic.php?t=4975&p=36436
https://forums.opensuse.org/showthread.php/483356-Authentication-Regulatory-Domain-issues-ath5k-12-2
Signed-off-by: Maciej Szmigiero <mail@maciej.szmigiero.name>
Allow setting multicast rate on OCB interfaces.
Current behaviour results in EOPNOTSUPP when attempting this.
Signed-off-by: Bertold Van den Bergh <bertold.vandenbergh@esat.kuleuven.be>
If driver failed to setup wiphy params (e.g. rts
threshold, fragmentation treshold) userspace
wasn't properly notified about this. This could
lead to user confusion who would think the command
succeeded even if that wasn't the case.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
The original assumption of 20MHz wide channels hasn't been true since
the addition of support for 5 and 10 MHz channels.
Change the code to no longer disable all channels that don't fit into
the 20MHz grid, but instead set the appropriate flags to disable
operation on specific bandwidths.
Signed-off-by: Matthias May <matthias.may@neratec.com>
[reword commit message]
This is necessary to merge the new TDLS and mesh patches,
as they depend on some fixes.
Commit eeca9fce1d71 ('cfg80211: Schedule timeout for all CRDA calls')
left behind a superfluous check after it removed some earlier code.
In reg_process_hint, the test of "treatment == REG_REQ_IGNORE ||
treatment == REG_REQ_ALREADY_SET" is superfluous because the code in the
if-then branch is identical to the code after the if statement.
Coverity CID #1295939
I also removed the unnecessary assignment of treatment in this case,
and added a comment reminding any future patch authors to ensure that
treatment is properly assigned before it is used after the switch.
This callback is currently not allowed to sleep, which makes it more
difficult to implement proper driver methods in mac80211 than it has
to be. Instead of doing asynchronous work here in mac80211, make it
possible for the callback to sleep by doing some asynchronous work
in cfg80211. This also enables improvements to other drivers, like
ath6kl, that would like to sleep in this callback.
While at it, also fix the code to call the driver on the implicit
unregistration when an interface is removed, and do that also when
a P2P-Device wdev is destroyed (otherwise we leak the structs.)
