This fix comes from:
https://gerrit.chromium.org/gerrit/#change,5744
https://gerrit.chromium.org/gerrit/#change,5745
So that it can work with the related wpa_supplicant tool.
BUG=895591
Change-Id: Ie81f6d6052bd45dab13c936f9f0c5f4eb277496a
Original-Signed-off-by: Wei Ni <wni@nvidia.com>
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Reviewed-on: http://git-master/r/111333
mac80211 leaves sinfo->assoc_req_ies uninitialized, causing a random
pointer memory access in nl80211_send_station.
Instead of checking if the pointer is null, use sinfo->filled, like
the rest of the fields.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Add a comment pointing out the use of enum station_info_flags for
all new struct station_info fields. In addition, memset the sinfo
buffer to zero before use on all paths in the current tree to avoid
leaving uninitialized pointers in the data.
(cherry picked from commit 87159de9c30dab02b84cbaffa7498140d4ebc1a1 from
android.googlesource.com/common.git)
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
Change-Id: I24301d45108587e66c8421a7f2a94ea98300ebeb
Reviewed-on: http://git-master/r/78887
When user space SME/MLME (e.g., hostapd) is not used in AP mode, the
IEs from the (Re)Association Request frame that was processed in
firmware need to be made available for user space (e.g., RSN IE for
hostapd). Allow this to be done with cfg80211_new_sta().
(cherry picked from commit d692df224b8605095cb7f770c1c99d3150834daf from
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Change-Id: I211171ca4953832cc998402c149ecf3fc429f9e6
Reviewed-on: http://git-master/r/78886
cherry-pick 35047200c401cdd1bb43b5574270d1ac86a47937 from
https://android.googlesource.com/kernel/common.git
Change-Id: I23efd4bab367bf49f7aca34daa19904baf5b9170
Reviewed-on: http://git-master/r/75462
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit 0bac71af6e66dc798bf07d0c0dd14ee5503362f9 upstream.
Johannes' patch for "cfg80211: fix regulatory NULL dereference"
broke user regulaotry hints and it did not address the fact that
last_request was left populated even if the previous regulatory
hint was stale due to the wiphy disappearing.
Fix user reguluatory hints by only bailing out if for those
regulatory hints where a request_wiphy is expected. The stale last_request
considerations are addressed through the previous fixes on last_request
where we reset the last_request to a static world regdom request upon
reset_regdomains(). In this case though we further enhance the effect
by simply restoring reguluatory settings completely.
Cc: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit a042994dd377d86bff9446ee76151ceb6267c9ba upstream.
There is a theoretical race that if hit will trigger
a crash. The race is between when we issue the first
regulatory hint, regulatory_hint_core(), gets processed
by the workqueue and between when the first device
gets registered to the wireless core. This is not easy
to reproduce but it was easy to do so through the
regulatory simulator I have been working on. This
is a port of the fix I implemented there [1].
[1] https://github.com/mcgrof/regsim/commit/a246ccf81f059cb662eee288aa13100f631e4cc8
commit de3584bd62d87b4c250129fbc46ca52c80330add upstream.
By the time userspace returns with a response to
the regulatory domain request, the wiphy causing
the request might have gone away. If this is so,
reject the update but mark the request as having
been processed anyway.
Cc: Luis R. Rodriguez <lrodriguez@qca.qualcomm.com>
commit e007b857e88097c96c45620bf3b04a4e309053d1 upstream.
MAC addresses have a fixed length. The current
policy allows passing < ETH_ALEN bytes, which
might result in reading beyond the buffer.
Signed-off-by: Eliad Peller <eliad@wizery.com>
Change-Id: I6e8d838d91bebc28f4cd09dcb8b9f1de775be13d
Signed-off-by: jun.ho.lee <jun.ho.lee@samsung.com>
commit 58ebacc66bd11be2327edcefc79de94bd6f5bb4a upstream.
Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added
the .uevent() callback for the regulatory device used during
the platform device registration. The change was done to account
for queuing up udev change requests through udevadm triggers.
The change also meant that upon regulatory core exit we will now
send a uevent() but the uevent() callback, reg_device_uevent(),
also accessed last_request. Right before commiting device suicide
we free'd last_request but never set it to NULL so
platform_device_unregister() would lead to bogus kernel paging
request. Fix this and also simply supress uevents right before
we commit suicide as they are pointless.
This fix is required for kernels >= v2.6.39
$ git describe --contains 4d9d88d1
v2.6.39-rc1~468^2~25^2^2~21
The impact of not having this present is that a bogus paging
access may occur (only read) upon cfg80211 unload time. You
may also get this BUG complaint below. Although Johannes
could not reproduce the issue this fix is theoretically correct.
mac80211_hwsim: unregister radios
mac80211_hwsim: closing netlink
BUG: unable to handle kernel paging request at ffff88001a06b5ab
IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Modules linked in: cfg80211(-) [last unloaded: mac80211]
Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs
RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc
RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0
RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff
R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0
R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001
FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0
Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780)
Stack:
ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2
000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820
ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189
Call Trace:
[<ffffffff812ff7e5>] dev_uevent+0xc5/0x170
[<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490
[<ffffffff81040189>] ? sub_preempt_count+0x29/0x60
[<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90
[<ffffffff81305307>] ? devres_release_all+0x27/0x60
[<ffffffff8124206b>] kobject_uevent+0xb/0x10
[<ffffffff812fee27>] device_del+0x157/0x1b0
[<ffffffff8130377d>] platform_device_del+0x1d/0x90
[<ffffffff81303b76>] platform_device_unregister+0x16/0x30
[<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211]
[<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211]
[<ffffffff8109a84c>] sys_delete_module+0x16c/0x220
[<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120
[<ffffffff814cba02>] system_call_fastpath+0x16/0x1b
Code: <all your base are belong to me>
RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP <ffff88001c5f9d58>
---[ end trace 147c5099a411e8c0 ]---
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Scott James Remnant <keybuk@google.com>
commit 6c7394197af90f6a332180e33f5d025d3037d883 upstream.
Since the NL80211_ATTR_HT_CAPABILITY attribute is
used as a struct, it needs a minimum, not maximum
length. Enforce that properly. Not doing so could
potentially lead to reading after the buffer.
Incorrect variable was used in validating the akm_suites array from
NL80211_ATTR_AKM_SUITES. In addition, there was no explicit
validation of the array length (we only have room for
NL80211_MAX_NR_AKM_SUITES).
This can result in a buffer write overflow for stack variables with
arbitrary data from user space. The nl80211 commands using the affected
functionality require GENL_ADMIN_PERM, so this is only exposed to admin
users.
Cc: stable@kernel.org
The scan request received from cfg80211_connect do not
have proper rate mast. So the probe request sent on each
channel do not have proper the supported rates ie.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
During the association, the regulatory is updated by country IE
that reaps the previously found beacons. The impact is that
after a STA disconnects *or* when for any reason a regulatory
domain change happens the beacon hint flag is not cleared
therefore preventing future beacon hints to be learned.
This is important as a regulatory domain change or a restore
of regulatory settings would set back the passive scan and no-ibss
flags on the channel. This is the right place to do this given that
it covers any regulatory domain change.
Reviewed-by: Luis R. Rodriguez <mcgrof@gmail.com>
Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Do not call ->suspend, ->resume methods after we unregister wiphy. Also
delete sta_clanup timer after we finish wiphy unregister to avoid this:
WARNING: at lib/debugobjects.c:262 debug_print_object+0x85/0xa0()
Hardware name: 6369CTO
ODEBUG: free active (active state 0) object type: timer_list hint: sta_info_cleanup+0x0/0x180 [mac80211]
Modules linked in: aes_i586 aes_generic fuse bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq mperf ext2 dm_mod uinput thinkpad_acpi hwmon sg arc4 rt2800usb rt2800lib crc_ccitt rt2x00usb rt2x00lib mac80211 cfg80211 i2c_i801 iTCO_wdt iTCO_vendor_support e1000e ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom yenta_socket ahci libahci pata_acpi ata_generic ata_piix i915 drm_kms_helper drm i2c_algo_bit video [last unloaded: microcode]
Pid: 5663, comm: pm-hibernate Not tainted 3.1.0-rc1-wl+ #19
Call Trace:
[<c0454cfd>] warn_slowpath_common+0x6d/0xa0
[<c05e05e5>] ? debug_print_object+0x85/0xa0
[<c0454dae>] warn_slowpath_fmt+0x2e/0x30
[<c05e05e5>] debug_print_object+0x85/0xa0
[<f8a808e0>] ? sta_info_alloc+0x1a0/0x1a0 [mac80211]
[<c05e0bd2>] debug_check_no_obj_freed+0xe2/0x180
[<c051175b>] kfree+0x8b/0x150
[<f8a126ae>] cfg80211_dev_free+0x7e/0x90 [cfg80211]
[<f8a13afd>] wiphy_dev_release+0xd/0x10 [cfg80211]
[<c068d959>] device_release+0x19/0x80
[<c05d06ba>] kobject_release+0x7a/0x1c0
[<c07646a8>] ? rtnl_unlock+0x8/0x10
[<f8a13adb>] ? wiphy_resume+0x6b/0x80 [cfg80211]
[<c05d0640>] ? kobject_del+0x30/0x30
[<c05d1a6d>] kref_put+0x2d/0x60
[<c05d056d>] kobject_put+0x1d/0x50
[<c08015f4>] ? mutex_lock+0x14/0x40
[<c068d60f>] put_device+0xf/0x20
[<c069716a>] dpm_resume+0xca/0x160
[<c04912bd>] hibernation_snapshot+0xcd/0x260
[<c04903df>] ? freeze_processes+0x3f/0x90
[<c049151b>] hibernate+0xcb/0x1e0
[<c048fdc0>] ? pm_async_store+0x40/0x40
[<c048fe60>] state_store+0xa0/0xb0
[<c05d0200>] kobj_attr_store+0x20/0x30
[<c0575ea4>] sysfs_write_file+0x94/0xf0
[<c051e26a>] vfs_write+0x9a/0x160
[<c0575e10>] ? sysfs_open_file+0x200/0x200
[<c051e3fd>] sys_write+0x3d/0x70
[<c080959f>] sysenter_do_call+0x12/0x28
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
The test is off by one so we'd read past the end of the
wiphy->bands[] array on the next line.
Just a typo fix changing regulaotry to regulatory.
Signed-off-by: Mihai Moldovan <ionic@ionic.de>
CC: John W. Linville <linville@tuxdriver.com>
CC: Mohammed Shafi <shafi.wireless@gmail.com>
At the beginning of wiphy_update_regulatory() a check is performed
whether the request is to be ignored. Then the request is sent to
the driver nevertheless. This happens even if last_request points
to NULL, leading to a crash in the driver:
[<bf01d864>] (lbs_set_11d_domain_info+0x28/0x1e4 [libertas]) from [<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4)
[<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4) from [<c03b4008>] (wiphy_register+0x354/0x420)
[<c03b4008>] (wiphy_register+0x354/0x420) from [<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas])
[<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas]) from [<bf020e64>] (lbs_start_card+0x20/0x88 [libertas])
[<bf020e64>] (lbs_start_card+0x20/0x88 [libertas]) from [<bf02cbd8>] (if_sdio_probe+0x898/0x9c0 [libertas_sdio])
Fix this by returning early. Also remove the out: label as it is
not any longer needed.
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com>
Cc: linux-wireless@vger.kernel.org
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Daniel Mack <daniel@zonque.org>
commit 58389c69150e6032504dfcd3edca6b1975c8b5bc
Author: Johannes Berg <johannes.berg@intel.com>
Date: Mon Jul 18 18:08:35 2011 +0200
cfg80211: allow userspace to control supported rates in scan
made single-band cards crash since it would always
access all wiphy->bands[]. Fix this and reject any
attempts in the new helper ieee80211_get_ratemask()
to do the same, rejecting rates configuration for
unsupported bands.
Reported-by: Pavel Roskin <proski@gnu.org>
Tested-by: Pavel Roskin <proski@gnu.org>
cfg80211_netdev_notifier_call() is configuring psm in case
of NL80211_IFTYPE_STATION interface type (on NETDEV_UP).
do the same for NL80211_IFTYPE_P2P_CLIENT interface type.
Some P2P scans are not allowed to advertise
11b rates, but that is a rather special case
so instead of having that, allow userspace
to request the rate sets (per band) that are
advertised in scan probe request frames.
Since it's needed in two places now, factor
out some common code parsing a rate array.
Some chips may support different lengths of user-supplied IEs with a
single scheduled scan command than with a single normal scan command.
To support this, this patch creates a separate hardware description
element that describes the maximum size of user-supplied information
element data supported in scheduled scans.
Signed-off-by: Luciano Coelho <coelho@ti.com>
Some chips can scan more SSIDs with a single scheduled scan command
than with a single normal scan command (eg. wl12xx chips).
element that describes the amount of SSIDs supported in scheduled
scans.
Since we now have the necessary API in place to support
GTK rekeying, applications will need to know whether it
is supported by a device. Add a pseudo-trigger that is
used only to advertise that capability. Also, add some
new triggers that match what iwlagn devices can do.
drivers/net/wireless/ath/ath5k/sysfs.c
net/bluetooth/l2cap_core.c
net/mac80211/wpa.c
If we try to stop a scheduled scan while it is not running, we should
return -ENOENT instead of simply ignoring the command and returning
success. This is more consistent with other parts of the code.
In certain circumstances, like WoWLAN scenarios,
devices may implement (partial) GTK rekeying on
the device to avoid waking up the host for it.
In order to successfully go through GTK rekeying,
the KEK, KCK and the replay counter are required.
Add API to let the supplicant hand the parameters
to the driver which may store it for future GTK
rekey operations.
Note that, of course, if GTK rekeying is done by
the device, the EAP frame must not be passed up
to userspace, instead a rekey event needs to be
sent to let userspace update its replay counter.
If the 'driver_initiated' function argument to
__cfg80211_stop_sched_scan() is not 0 then we'll return an
uninitialized 'err' from the function.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
There was a deadlock when rfkill-blocking a wireless interface,
because we were locking the rdev mutex on NETDEV_GOING_DOWN to stop
sched_scans that were eventually running. The rfkill block code was
already holding a mutex under rdev:
kernel: =======================================================
kernel: [ INFO: possible circular locking dependency detected ]
kernel: 3.0.0-rc1-00049-g1fa7b6a #57
kernel: -------------------------------------------------------
kernel: kworker/0:1/4525 is trying to acquire lock:
kernel: (&rdev->mtx){+.+.+.}, at: [<ffffffff8164c831>] cfg80211_netdev_notifier_call+0x131/0x5b0
kernel:
kernel: but task is already holding lock:
kernel: (&rdev->devlist_mtx){+.+.+.}, at: [<ffffffff8164dcef>] cfg80211_rfkill_set_block+0x4f/0xa0
kernel:
kernel: which lock already depends on the new lock.
To fix this, add a new mutex specifically for sched_scan, to protect
the sched_scan_req element in the rdev struct, instead of using the
global rdev mutex.
Reported-by: Duane Griffin <duaneg@dghda.com>
drivers/net/wireless/iwlwifi/iwl-tx.c
Sometimes when reporting a MIC failure rx->key may be unset. This
code path is hit when receiving a packet meant for a multicast
address, and decryption is performed in HW.
Fortunately, the failing key_idx is not used for anything up to
(and including) usermode, so we allow ourselves to drop it on the
way up when a key cannot be retrieved.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Use the new consistent dump feature from (generic) netlink
to advertise when dumps are incomplete.
Readers may note that this does not initialize the
rdev->bss_generation counter to a non-zero value. This is
still OK since the value is modified only under spinlock
when the list is modified. Since the dump code holds the
spinlock, the value will either be > 0 already, or the
list will still be empty in which case a consistent dump
will actually be made (and be empty).
Downsteram DEAUTH messages do not refer to a current authentication
attempt -- AUTH responses do. Therefore we should not allow DEAUTH
from an AP to void state for an AUTH attempt in progress.
Signed-off-by: Paul Stewart <pstew@chromium.org>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
When one of the SSID's length passed in a scan or sched_scan request
is larger than 255, there will be an overflow in the u8 that is used
to store the length before checking. This causes the check to fail
and we overrun the buffer when copying the SSID.
Fix this by checking the nl80211 attribute length before copying it to
the struct.
This is a follow up for the previous commit
208c72f4fe44fe09577e7975ba0e7fa0278f3d03, which didn't fix the problem
entirely.
Reported-by: Ido Yariv <ido@wizery.com>
The channel survey information will be empy for
disabled channels so simply discard those entries.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This adds dump support to testmode. The testmode
dump support in nl80211 requires using two of the
six cb->args, the rest can be used by the driver
to figure out where the dump position is at or to
store other data across invocations.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Commit 0a35d36 ("cfg80211: Use capability info to detect mesh beacons")
assumed that probe response with both ESS and IBSS bits cleared
means that the frame was sent by a mesh sta.
However, these capabilities are also being used in the p2p_find phase,
and the mesh-validation broke it.
Rename the WLAN_CAPABILITY_IS_MBSS macro, and verify that mesh ies
exist before assuming this frame was sent by a mesh sta.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
In both trigger_scan and sched_scan operations, we were checking for
the SSID length before assigning the value correctly. Since the
memory was just kzalloc'ed, the check was always failing and SSID with
over 32 characters were allowed to go through.
This was causing a buffer overflow when copying the actual SSID to the
proper place.
This bug has been there since 2.6.29-rc4.
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Some stack variables (name *ssid and *channel) are only used to define
the size of the memory block that needs to be allocated for the
request structure in the nl80211_trigger_scan() and
nl80211_start_sched_scan() functions.
This is unnecessary because the sizes of the actual elements in the
structure can be used instead.
cfg80211 scan code adds separate BSS entries if the same BSS shows up
on multiple channels. However, sme implementation does not use the
frequency when fetching the BSS entry. Fix this by adding channel
information to cfg80211_roamed() and include it in cfg80211_get_bss()
calls.
Please note that drivers using cfg80211_roamed() need to be modified to
fully implement this fix. This commit includes only minimal changes to
avoid compilation issues; it maintains the old (broken) behavior for
most drivers. ath6kl was the only one that I could test, so I updated
it to provide the operating frequency in the roamed event.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
drivers/net/wireless/iwlwifi/iwl-agn-tx.c
net/mac80211/sta_info.h
