path: root/net/wireless
2009-09-24cfg80211: fix looping soft lockup in find_ie()Bob Copeland
commit fcc6cb0c13555e78c2d47257b6d1b5e59b0c419a upstream. The find_ie() function uses a size_t for the len parameter, and directly uses len as a loop variable. If any received packets are malformed, it is possible for the decrease of len to overflow, and since the result is unsigned, the loop will not terminate. Change it to a signed int so the loop conditional works for negative values. This fixes the following soft lockup: [38573.102007] BUG: soft lockup - CPU#0 stuck for 61s! [phy0:2230] [38573.102007] Modules linked in: aes_i586 aes_generic fuse af_packet ipt_REJECT xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 xt_state iptable_filter ip_tables x_tables acpi_cpufreq binfmt_misc dm_mirror dm_region_hash dm_log dm_multipath dm_mod kvm_intel kvm uinput i915 arc4 ecb drm snd_hda_codec_idt ath5k snd_hda_intel hid_apple mac80211 usbhid appletouch snd_hda_codec snd_pcm ath cfg80211 snd_timer i2c_algo_bit ohci1394 video snd processor ieee1394 rfkill ehci_hcd sg sky2 backlight snd_page_alloc uhci_hcd joydev output ac thermal button battery sr_mod applesmc cdrom input_polldev evdev unix [last unloaded: scsi_wait_scan] [38573.102007] irq event stamp: 2547724535 [38573.102007] hardirqs last enabled at (2547724534): [<c1002ffc>] restore_all_notrace+0x0/0x18 [38573.102007] hardirqs last disabled at (2547724535): [<c10038f4>] apic_timer_interrupt+0x28/0x34 [38573.102007] softirqs last enabled at (92950144): [<c103ab48>] __do_softirq+0x108/0x210 [38573.102007] softirqs last disabled at (92950274): [<c1348e74>] _spin_lock_bh+0x14/0x80 [38573.102007] [38573.102007] Pid: 2230, comm: phy0 Tainted: G W (2.6.31-rc7-wl #8) MacBook1,1 [38573.102007] EIP: 0060:[<f8ea2d50>] EFLAGS: 00010292 CPU: 0 [38573.102007] EIP is at cmp_ies+0x30/0x180 [cfg80211] [38573.102007] EAX: 00000082 EBX: 00000000 ECX: ffffffc1 EDX: d8efd014 [38573.102007] ESI: ffffff7c EDI: 0000004d EBP: eee2dc50 ESP: eee2dc3c [38573.102007] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 [38573.102007] CR0: 8005003b CR2: d8efd014 CR3: 01694000 CR4: 000026d0 [38573.102007] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [38573.102007] DR6: ffff0ff0 DR7: 00000400 [38573.102007] Call Trace: [38573.102007] [<f8ea2f8d>] cmp_bss+0xed/0x100 [cfg80211] [38573.102007] [<f8ea33e4>] cfg80211_bss_update+0x84/0x410 [cfg80211] [38573.102007] [<f8ea3884>] cfg80211_inform_bss_frame+0x114/0x180 [cfg80211] [38573.102007] [<f97255ff>] ieee80211_bss_info_update+0x4f/0x180 [mac80211] [38573.102007] [<f972b118>] ieee80211_rx_bss_info+0x88/0xf0 [mac80211] [38573.102007] [<f9739297>] ? ieee802_11_parse_elems+0x27/0x30 [mac80211] [38573.102007] [<f972b224>] ieee80211_rx_mgmt_probe_resp+0xa4/0x1c0 [mac80211] [38573.102007] [<f972bc59>] ieee80211_sta_rx_queued_mgmt+0x919/0xc50 [mac80211] [38573.102007] [<c1009707>] ? sched_clock+0x27/0xa0 [38573.102007] [<c1009707>] ? sched_clock+0x27/0xa0 [38573.102007] [<c105ffd0>] ? mark_held_locks+0x60/0x80 [38573.102007] [<c1348be5>] ? _spin_unlock_irqrestore+0x55/0x70 [38573.102007] [<c134baa5>] ? sub_preempt_count+0x85/0xc0 [38573.102007] [<c1348bce>] ? _spin_unlock_irqrestore+0x3e/0x70 [38573.102007] [<c12c1c0f>] ? skb_dequeue+0x4f/0x70 [38573.102007] [<f972c021>] ieee80211_sta_work+0x91/0xb80 [mac80211] [38573.102007] [<c1009707>] ? sched_clock+0x27/0xa0 [38573.102007] [<c134baa5>] ? sub_preempt_count+0x85/0xc0 [38573.102007] [<c10479af>] worker_thread+0x18f/0x320 [38573.102007] [<c104794e>] ? worker_thread+0x12e/0x320 [38573.102007] [<c1348be5>] ? _spin_unlock_irqrestore+0x55/0x70 [38573.102007] [<f972bf90>] ? ieee80211_sta_work+0x0/0xb80 [mac80211] [38573.102007] [<c104cbb0>] ? autoremove_wake_function+0x0/0x50 [38573.102007] [<c1047820>] ? worker_thread+0x0/0x320 [38573.102007] [<c104c854>] kthread+0x84/0x90 [38573.102007] [<c104c7d0>] ? kthread+0x0/0x90 [38573.102007] [<c1003ab7>] kernel_thread_helper+0x7/0x10 Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-03cfg80211: fix regression on beacon world roaming featureLuis R. Rodriguez
A regression was added through patch a4ed90d6: "cfg80211: respect API on orig_flags on channel for beacon hint" We did indeed respect _orig flags but the intention was not clearly stated in the commit log. This patch fixes firmware issues picked up by iwlwifi when we lift passive scan of beaconing restrictions on channels its EEPROM has been configured to always enable. By doing so though we also disallowed beacon hints on devices registering their wiphy with custom world regulatory domains enabled, this happens to be currently ath5k, ath9k and ar9170. The passive scan and beacon restrictions on those devices would never be lifted even if we did find a beacon and the hardware did support such enhancements when world roaming. Since Johannes indicates iwlwifi firmware cannot be changed to allow beacon hinting we set up a flag now to specifically allow drivers to disable beacon hints for devices which cannot use them. We enable the flag on iwlwifi to disable beacon hints and by default enable it for all other drivers. It should be noted beacon hints lift passive scan flags and beacon restrictions when we receive a beacon from an AP on any 5 GHz non-DFS channels, and channels 12-14 on the 2.4 GHz band. We don't bother with channels 1-11 as those channels are allowed world wide. This should fix world roaming for ath5k, ath9k and ar9170, thereby improving scan time when we receive the first beacon from any AP, and also enabling beaconing operation (AP/IBSS/Mesh) on cards which would otherwise not be allowed to do so. Drivers not using custom regulatory stuff (wiphy_apply_custom_regulatory()) were not affected by this as the orig_flags for the channels would have been cleared upon wiphy registration. I tested this with a world roaming ath5k card. Cc: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-03cfg80211: add two missing NULL pointer checksJohannes Berg
These pointers can be NULL, the is_mesh() case isn't ever hit in the current kernel, but cmp_ies() can be hit under certain conditions. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.29, 2.6.30] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-21cfg80211: double free in __cfg80211_scan_doneChristian Lamparter
This patch fixes a double free corruption in __cfg80211_scan_done: ================================================ BUG kmalloc-512: Object already free ------------------------------------------------ INFO: Allocated in load_elf_binary+0x18b/0x19af age=6 INFO: Freed in load_elf_binary+0x104e/0x19af age=5 INFO: Slab 0xffffea0001bae4c0 objects=14 used=7 INFO: Object 0xffff88007e8a9918 @offset=6424 fp=0xffff88007e8a9488 Bytes b4 0xffff88007e8a9908: 00 00 00 00 00 00 00 00 5a 5a [...] Pid: 28705, comm: rmmod Tainted: P C 2.6.31-rc2-wl #1 Call Trace: [<ffffffff810da9f4>] print_trailer+0x14e/0x16e [<ffffffff810daa56>] object_err+0x42/0x61 [<ffffffff810dbcd9>] __slab_free+0x2af/0x396 [<ffffffffa0ec9694>] ? wiphy_unregister+0x92/0x142 [cfg80211] [<ffffffff810dd5e3>] kfree+0x13c/0x17a [<ffffffffa0ec9694>] ? wiphy_unregister+0x92/0x142 [cfg80211] [<ffffffffa0ec9694>] wiphy_unregister+0x92/0x142 [cfg80211] [<ffffffffa0eed163>] ieee80211_unregister_hw+0xc8/0xff [mac80211] [<ffffffffa0f3fbc8>] p54_unregister_common+0x31/0x66 [p54common] [...] FIX kmalloc-512: Object at 0xffff88007e8a9918 not freed The code path which leads to the *funny* double free: request = rdev->scan_req; dev = dev_get_by_index(&init_net, request->ifidx); /* * the driver was unloaded recently and * therefore dev_get_by_index will return NULL! */ if (!dev) goto out; [...] rdev->scan_req = NULL; /* not executed... */ [...] out: kfree(request); Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-21nl80211: Memory leak fixedNiko Jokinen
Potential memory leak via msg pointer in nl80211_get_key() function. Signed-off-by: Niko Jokinen <ext-niko.k.jokinen@nokia.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-07cfg80211: fix refcount leakJohannes Berg
The code in cfg80211's cfg80211_bss_update erroneously grabs a reference to the BSS, which means that it will never be freed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.29, 2.6.30] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-07Wireless: nl80211, fix lock imbalanceJiri Slaby
Don't forget to unlock cfg80211_mutex in one fail path of nl80211_set_wiphy. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19cfg80211: validate station settingsJohannes Berg
When I disallowed interfering with stations on non-AP interfaces, I not only forget mesh but also managed interfaces which need this for the authorized flag. Let's actually validate everything properly. This fixes an nl80211 regression introduced by the interfering, under which wpa_supplicant -Dnl80211 could not properly connect. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19cfg80211: allow setting station parameters in meshAndrey Yurovsky
Mesh Point interfaces can also set parameters, for example plink_open is used to manually establish peer links from user-space (currently via iw). Add Mesh Point to the check in nl80211_set_station. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19cfg80211: allow adding/deleting stations on meshAndrey Yurovsky
Commit b2a151a288 added a check that prevents adding or deleting stations on non-AP interfaces. Adding and deleting stations is supported for Mesh Point interfaces, so add Mesh Point to that check as well. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10cfg80211: fix rfkill locking problemJohannes Berg
rfkill currently requires a global lock within the rfkill_register() function, and holds that lock over calls to the set_block() methods. This means that we cannot hold a lock around rfkill_register() that we also require in set_block(), directly or indirectly. Fix cfg80211 to register rfkill outside the block locked by its global lock. Much of what cfg80211 does in the locked block doesn't need to be locked anyway. Reported-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10cfg80211: fix for duplicate response for driver reg requestLuis R. Rodriguez
As Pavel puts userspace can be stupid and should not cause kernel crashes. In this case Pavel was able to find a crash here but unable to reproduce. Either way lets deal with this. This should fix: ------------[ cut here ]------------ kernel BUG at /home/proski/src/linux-2.6/net/wireless/reg.c:2132! Oops: Exception in kernel mode, sig: 5 [#1] PowerMac Modules linked in: ath5k ath [last unloaded: scsi_wait_scan] NIP: c02f3eac LR: c02f3d08 CTR: 00000000 REGS: ef107aa0 TRAP: 0700 Not tainted (2.6.30-rc8-wl) MSR: 00029032 <EE,ME,CE,IR,DR> CR: 88002442 XER: 20000000 TASK = ef84acb0[834] 'crda' THREAD: ef106000 GPR00: ef953840 ef107b50 ef84acb0 ef1380bc 00000006 c035a5c8 ef107b90 c035a5c8 GPR08: 00080005 efb68980 c0445628 ef130004 28002422 10019ce0 10012d3c 00000001 GPR16: 1070b2ac 00000005 48023558 1070b380 4802304c 00000000 ef107ddc c035a5c8 GPR24: ef107b78 c0443350 ef8bcb00 00000005 ef138080 c04a6a70 c04a0000 ef8bcb00 NIP [c02f3eac] set_regdom+0x4c4/0x4ec LR [c02f3d08] set_regdom+0x320/0x4ec Call Trace: [ef107b50] [c02f3d08] set_regdom+0x320/0x4ec (unreliable) [ef107b70] [c02f9d10] nl80211_set_reg+0x140/0x2d0 [ef107bc0] [c02aa2b8] genl_rcv_msg+0x204/0x228 [ef107c10] [c02a97cc] netlink_rcv_skb+0xe8/0x10c [ef107c30] [c02aa094] genl_rcv+0x3c/0x5c [ef107c40] [c02a9050] netlink_unicast+0x308/0x36c [ef107c80] [c02a92bc] netlink_sendmsg+0x208/0x2f0 [ef107cd0] [c0282048] sock_sendmsg+0xac/0xe4 [ef107db0] [c02822b4] sys_sendmsg+0x234/0x2d8 [ef107f00] [c0283a88] sys_socketcall+0x108/0x258 [ef107f40] [c0012790] ret_from_syscall+0x0/0x38 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: make ieee80211_get_mesh_hdrlen() staticLuis R. Rodriguez
Fixes spares warning: net/wireless/util.c:261:5: warning: symbol 'ieee80211_get_mesh_hdrlen' was not declared. Should it be static? Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: add rfkill supportJohannes Berg
To be easier on drivers and users, have cfg80211 register an rfkill structure that drivers can access. When soft-killed, simply take down all interfaces; when hard-killed the driver needs to notify us and we will take down the interfaces after the fact. While rfkilled, interfaces cannot be set UP. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: move txpower wext from mac80211Johannes Berg
This patch introduces new cfg80211 API to set the TX power via cfg80211, puts the wext code into cfg80211 and updates mac80211 to use all that. The -ENETDOWN bits are a hack but will go away soon. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03nl80211: use GFP_ATOMIC for michael mic failure messageBob Copeland
nl80211_michael_mic_failure can be called in atomic context but does a GFP_KERNEL allocation. Fixes the error below: [ 126.793225] BUG: sleeping function called from invalid context at mm/slab.c:3055 [ 126.793234] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper [ 126.793241] 2 locks held by swapper/0: [ 126.793246] #0: (&sc->rxbuflock){+.-.+.}, at: [<f94e1b46>] ath5k_tasklet_rx+0x34/0x55e [ath5k] [ 126.793294] #1: (rcu_read_lock){.+.+.+}, at: [<f92872f3>] __ieee80211_rx+0x7e/0x563 [mac80211] [ 126.793342] Pid: 0, comm: swapper Not tainted 2.6.30-rc7-wl #124 [ 126.793347] Call Trace: [ 126.793361] [<c014499d>] ? __debug_show_held_locks+0x1e/0x20 [ 126.793380] [<c011e9a3>] __might_sleep+0x100/0x107 [ 126.793386] [<c018ea99>] kmem_cache_alloc+0x35/0x170 [ 126.793393] [<c02e8bb1>] ? __alloc_skb+0x2e/0x117 [ 126.793397] [<c014517d>] ? mark_held_locks+0x43/0x5b [ 126.793402] [<c02e8bb1>] __alloc_skb+0x2e/0x117 [ 126.793419] [<f851a836>] nl80211_michael_mic_failure+0x2a/0x1fa [cfg80211] [ 126.793425] [<c01453b8>] ? trace_hardirqs_on_caller+0xf6/0x130 [ 126.793430] [<c01453fd>] ? trace_hardirqs_on+0xb/0xd [ 126.793444] [<f851b2b8>] cfg80211_michael_mic_failure+0x30/0x38 [cfg80211] [ 126.793463] [<f928bf69>] mac80211_ev_michael_mic_failure+0xfd/0x108 [mac80211] [ 126.793480] [<f9279fbd>] ieee80211_rx_h_michael_mic_verify+0xd4/0x117 [mac80211] [ 126.793499] [<f9285ef3>] ieee80211_invoke_rx_handlers+0xdde/0x1963 [mac80211] [ 126.793505] [<c0107152>] ? sched_clock+0x3f/0x64 [ 126.793511] [<c0107152>] ? sched_clock+0x3f/0x64 [ 126.793516] [<c01445d7>] ? trace_hardirqs_off+0xb/0xd [ 126.793521] [<c0107152>] ? sched_clock+0x3f/0x64 [ 126.793526] [<c0146454>] ? __lock_acquire+0x62c/0x1271 [ 126.793545] [<f9286fbb>] __ieee80211_rx_handle_packet+0x543/0x564 [mac80211] [ 126.793564] [<f9287757>] __ieee80211_rx+0x4e2/0x563 [mac80211] [ 126.793577] [<f94e1ff6>] ath5k_tasklet_rx+0x4e4/0x55e [ath5k] [ 126.793583] [<c0102b54>] ? restore_nocheck_notrace+0x0/0xe [ 126.793589] [<c0129aa2>] tasklet_action+0x92/0xe5 [ 126.793594] [<c0129f22>] __do_softirq+0xb1/0x182 [ 126.793599] [<c012a023>] do_softirq+0x30/0x48 [ 126.793603] [<c012a19b>] irq_exit+0x3d/0x74 [ 126.793609] [<c0358016>] do_IRQ+0x76/0x8c [ 126.793613] [<c010312e>] common_interrupt+0x2e/0x34 [ 126.793618] [<c014007b>] ? timer_list_show+0x277/0x939 [ 126.793630] [<f88eb321>] ? acpi_idle_enter_bm+0x266/0x291 [processor] [ 126.793636] [<c02d00f6>] cpuidle_idle_call+0x6a/0x9c [ 126.793640] [<c0101cc8>] cpu_idle+0x53/0x87 [ 126.793645] [<c0344510>] rest_init+0x6c/0x6e [ 126.793651] [<c04dd74d>] start_kernel+0x286/0x28b [ 126.793656] [<c04dd037>] __init_begin+0x37/0x3c Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: fix for duplicate userspace repliesLuis R. Rodriguez
This fixes an incorrect assumption (BUG_ON) made in cfg80211 when handling country IE regulatory requests. The assumption was that we won't try to call_crda() twice for the same event and therefore we will not recieve two replies through nl80211 for the regulatory request. As it turns out it is true we don't call_crda() twice for the same event, however, kobject_uevent_env() *might* send the udev event twice and/or userspace can simply process the udev event twice. We remove the BUG_ON() and simply ignore the duplicate request. For details refer to this thread: http://marc.info/?l=linux-wireless&m=124149987921337&w=2 Cc: stable@kernel.org Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: disallow interfering with stations on non-AP (part 2)Johannes Berg
On non-AP interfaces userspace has no business interfering with the station management, this can confuse mac80211 (and other drivers probably wouldn't support it anyway). Allow adding and removing stations only on AP interfaces. (Reconcile this w/ previous version of patch posted with same subject... -- JWL) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: use key size constantsJohannes Berg
Instead of hardcoding the key length for validation, use the constants Zhu Yi recently added and add one for AES_CMAC too. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03nl80211: bounce scan request back to userspaceJohannes Berg
When a scan finishes only the program that asked for it knows what kind of scan it was; let's tell everybody else about the scan parameters as well so they can evaluate the result of the scan better. Also helps with debugging. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: validate AID of stations being addedJohannes Berg
We have some validation code in mac80211 but said code will force an invalid AID to 0 which isn't a valid AID either; instead require a valid AID (1-2007) to be passed in from userspace in cfg80211 already. Also move the code before the race comment since it can only be executed during STA addition and thus is not racy. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-26nl80211: Eliminate reference to BUS_ID_SIZE.David S. Miller
It's going away. Just leave the constant "20" here so that behavior doesn't change. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/iwlwifi/iwl3945-base.c
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22wext: remove atomic requirement for wireless statsJohannes Berg
The requirement for wireless stats to be atomic is now mostly artificial since we hold the rtnl _and_ the dev_base_lock for iterating the device list. Doing that is not required, just the rtnl is sufficient (and the rtnl is required for other reasons outlined in commit "wext: fix get_wireless_stats locking"). This will fix http://bugzilla.kernel.org/show_bug.cgi?id=13344 and make things easier for drivers. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-21wireless: Use genl_register_family_with_ops()Michał Mirosław
Use genl_register_family_with_ops() instead of a copy. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-20cfg80211: warn when wiphy_apply_custom_regulatory() does nothingLuis R. Rodriguez
Device drivers using wiphy_apply_custom_regulatory() want some regulatory settings applied to their wiphy, if no bands were configured on the wiphy then something went wrong. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: fix compile error with CONFIG_CFG80211_DEBUGFSPavel Roskin
If CONFIG_CFG80211_DEBUGFS is enabled and CONFIG_MAC80211_DEBUGFS is not, compilation fails in net/wireless/debugfs.c: net/wireless/debugfs.c: In function 'cfg80211_debugfs_drv_add': net/wireless/debugfs.c:117: error: 'struct cfg80211_registered_device' has no member named 'debugfs' The debugfs filed is needed if and only if CONFIG_CFG80211_DEBUGFS is enabled, so use that instead of CONFIG_MAC80211_DEBUGFS. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: fix in nl80211_set_reg()Luis R. Rodriguez
There is a race on access to last_request and its alpha2 through reg_is_valid_request() and us possibly processing first another regulatory request on another CPU. We avoid this improbably race by locking with the cfg80211_mutex as we should have done in the first place. While at it add the assert on locking on reg_is_valid_request(). Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: cleanup return calls on nl80211_set_reg()Luis R. Rodriguez
This has no functional change, but it will make the race fix easier to spot in my next patch. Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: return immediately if num reg rules > NL80211_MAX_SUPP_REG_RULESLuis R. Rodriguez
This has no functional change except we save a kfree(rd) and allows us to clean this code up a bit after this. We do avoid an unnecessary kfree(NULL) but calling that was OK too. Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: allow wext to remove keys that don't existJohannes Berg
Some applications using wireless extensions expect to be able to remove a key that doesn't exist. One example is wpa_supplicant which doesn't actually change behaviour when running into an error while trying to do that, but it prints an error message which users interpret as wpa_supplicant having problems. The safe thing to do is not change the behaviour of wireless extensions any more, so when the driver reports -ENOENT let the wext bridge code return success to userspace. To guarantee this, also document that drivers should return -ENOENT when the key doesn't exist. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: mark ops as pointer to constDavid Kilroy
This allows drivers to mark their cfg80211_ops tables const. Signed-off-by: David Kilroy <kilroyd@googlemail.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20nl80211: Validate NL80211_ATTR_KEY_SEQ lengthJouni Malinen
Validate RSC (NL80211_ATTR_KEY_SEQ) length in nl80211/cfg80211 instead of having to do this in all the drivers. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: add debugfs HT40 allow mapLuis R. Rodriguez
Here's a screenshot of what this looks like with ath9k: mcgrof@pogo /debug/ieee80211/phy0 $ cat ht40allow_map 2412 HT40 + 2417 HT40 + 2422 HT40 + 2427 HT40 + 2432 HT40 -+ 2437 HT40 -+ 2442 HT40 -+ 2447 HT40 - 2452 HT40 - 2457 HT40 - 2462 HT40 - 2467 Disabled 2472 Disabled 2484 Disabled 5180 HT40 + 5200 HT40 -+ 5220 HT40 -+ 5240 HT40 -+ 5260 HT40 -+ 5280 HT40 -+ 5300 HT40 -+ 5320 HT40 - 5500 HT40 + 5520 HT40 -+ 5540 HT40 -+ 5560 HT40 -+ 5580 HT40 -+ 5600 HT40 -+ 5620 HT40 -+ 5640 HT40 -+ 5660 HT40 -+ 5680 HT40 -+ 5700 HT40 - 5745 HT40 + 5765 HT40 -+ 5785 HT40 -+ 5805 HT40 -+ 5825 HT40 - Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20mac80211/cfg80211: move wiphy specific debugfs entries to cfg80211Luis R. Rodriguez
This moves the cfg80211 specific stuff to new cfg80211 debugfs entries. Non-mac80211 will also get these entries now. There were only 4 which we take: rts_threshold fragmentation_threshold short_retry_limit long_retry_limit Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: check allowed channel type upon userspace requestsLuis R. Rodriguez
Thanks to nl80211 userspace can be very specific upon device configuration. Before processing the request for the new HT40 channel types (HT40- or HT40+) we need to ensure we can use them regulatory-wise. This wasn't required with wireless extensions as specifying the channel type wasn't not available and configuration was done towards the end implicitly upon association or reception of beacons from the AP. For the new nl80211 we have to check this when configuring the interfaces explicitly. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20wireless: rename IEEE80211_CHAN_NO_FAT_* to HT40-/+Luis R. Rodriguez
This is more consistent with our nl80211 naming convention for HT40-/+. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: Process regulatory max bandwidth checks for HT40Luis R. Rodriguez
We are not correctly listening to the regulatory max bandwidth settings. To actually make use of it we need to redesign things a bit. This patch does the work for that. We do this to so we can obey to regulatory rules accordingly for use of HT40. We end up dealing with HT40 by having two passes for each channel. The first check will see if a 20 MHz channel fits into the channel's center freq on a given frequency range. We check for a 20 MHz banwidth channel as that is the maximum an individual channel will use, at least for now. The first pass will go ahead and check if the regulatory rule for that given center of frequency allows 40 MHz bandwidths and we use this to determine whether or not the channel supports HT40 or not. So to support HT40 you'll need at a regulatory rule that allows you to use 40 MHz channels but you're channel must also be enabled and support 20 MHz by itself. The second pass is done after we do the regulatory checks over an device's supported channel list. On each channel we'll check if the control channel and the extension both: o exist o are enabled o regulatory allows 40 MHz bandwidth on its frequency range This work allows allows us to idependently check for HT40- and HT40+. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20cfg80211: fix race between core hint and driver's custom applyLuis R. Rodriguez
Its possible for cfg80211 to have scheduled the work and for the global workqueue to not have kicked in prior to a cfg80211 driver's regulatory hint or wiphy_apply_custom_regulatory(). Although this is very unlikely its possible and should fix this race. When this race would happen you are expected to have hit a null pointer dereference panic. Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20wext: verify buffer size for SIOCSIWENCODEEXTJohannes Berg
Another design flaw in wireless extensions (is anybody surprised?) in the way it handles the iw_encode_ext structure: The structure is part of the 'extra' memory but contains the key length explicitly, instead of it just being the length of the extra buffer - size of the struct and using the explicit key length only for the get operation (which only writes it). Therefore, we have this layout: extra: +-------------------------+ | struct iw_encode_ext { | | ... | | u16 key_len; | | u8 key[0]; | | }; | +-------------------------+ | key material | +-------------------------+ Now, all drivers I checked use ext->key_len without checking that both key_len and the struct fit into the extra buffer that has been copied from userspace. This leads to a buffer overrun while reading that buffer, depending on the driver it may be possible to specify arbitrary key_len or it may need to be a proper length for the key algorithm specified. Thankfully, this is only exploitable by root, but root can actually cause a segfault or use kernel memory as a key (which you can even get back with siocgiwencode or siocgiwencodeext from the key buffer). Fix this by verifying that key_len fits into the buffer along with struct iw_encode_ext. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-19net: use NLMSG_DEFAULT_SIZE in nlmsg_new() allocationsPablo Neira Ayuso
nlmsg_new() adds the size of the netlink header to the value that has been passed as parameter. If NLMSG_GOODSIZE is selected, we request an allocation of one memory page plus the size of the header. Instead, NLMSG_DEFAULT_SIZE should be used since it already substracts the size of the Netlink header. I have the impression that the similar naming in both constant is error prone when using it with nlmsg_new(). This is already documented in include/net/netlink.h Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-13wext: remove seq_start/stop sparse annotationsJohannes Berg
Even though they are true, they cause sparse to complain because it doesn't see the __acquires(dev_base_lock) on dev_seq_start() because it is only added to the function in net/core/dev.c, not the header file. To keep track of the nesting correctly we should probably annotate those functions publically, but for now let's just remove the annotation I added to wext. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13nl80211: Add RSC configuration for new keysJouni Malinen
When setting a key with NL80211_CMD_NEW_KEY, we should allow the key sequence number (RSC) to be set in order to allow replay protection to work correctly for group keys. This patch documents this use for nl80211 and adds the couple of missing pieces in nl80211/cfg80211 and mac80211 to support this. In addition, WEXT SIOCSIWENCODEEXT compat processing in cfg80211 is extended to handle the RSC (this was already specified in WEXT, but just not implemented in cfg80211/mac80211). Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13nl80211: Add IEEE 802.1X PAE control for station modeJouni Malinen
Add a new NL80211_ATTR_CONTROL_PORT flag for NL80211_CMD_ASSOCIATE to allow user space to indicate that it will control the IEEE 802.1X port in station mode. Previously, mac80211 was always marking the port authorized in station mode. This was enough when drop_unencrypted flag was set. However, drop_unencrypted can currently be controlled only with WEXT and the current nl80211 design does not allow fully secure configuration. Fix this by providing a mechanism for user space to control the IEEE 802.1X port in station mode (i.e., do the same that we are already doing in AP mode). Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13nl80211: improve station flags handlingJohannes Berg
It is currently not possible to modify station flags, but that capability would be very useful. This patch introduces a new nl80211 attribute that contains a set/mask for station flags, and updates the internal API (and mac80211) to mirror that. The new attribute is parsed before falling back to the old so that userspace can specify both (if it can) to work on all kernels. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13nl80211: Validate MFP flag type when parsing STA flagsJouni Malinen
NL80211_STA_FLAG_MFP was forgotten from sta_flags_policy. The previous version added the flag due to the loop used in parse_station_flags, but the proper behavior would be to allow nla_parse_nested() to go through the policy for all flags. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13cfg80211: implement wext key handlingJohannes Berg
Move key handling wireless extension ioctls from mac80211 to cfg80211 so that all drivers that implement the cfg80211 operations get wext compatibility. Note that this drops the SIOCGIWENCODE ioctl support for getting IW_ENCODE_RESTRICTED/IW_ENCODE_OPEN. This means that iwconfig will no longer report "Security mode:open" or "Security mode:restricted" for mac80211. However, what we displayed there (the authentication algo used) was actually wrong -- linux/wireless.h states that this setting is meant to differentiate between "Refuse non-encoded packets" and "Accept non-encoded packets". (Combined with "cfg80211: fix a couple of bugs with key ioctls". -- JWL) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11wext: fix get_wireless_stats lockingJohannes Berg
Currently, get_wireless_stats is racy by _design_. This is because it returns a buffer, which needs to be statically allocated since it cannot be freed if it was allocated dynamically. Also, SIOCGIWSTATS and /proc/net/wireless use no common lock, and /proc/net/wireless accesses are not synchronised against each other. This is a design flaw in get_wireless_stats since the beginning. This patch fixes it by wrapping /proc/net/wireless accesses with the RTNL so they are protected against each other and SIOCGIWSTATS. The more correct method of fixing this would be to pass in the buffer instead of returning it and have the caller take care of synchronisation of the buffer, but even then most drivers probably assume that their callback is protected by the RTNL like all other wext callbacks. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
