[ Upstream commit 79e48650320e6fba48369fccf13fd045315b19b8 ]
Stack object "dte_facilities" is allocated in x25_rx_call_request(),
which is supposed to be initialized in x25_negotiate_facilities.
However, 5 fields (8 bytes in total) are not initialized. This
object is then copied to userland via copy_to_user, thus infoleak
occurs.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
use pr_<level> instead of printk(LEVEL)
Suggested-by: Joe Perches <joe@perches.com>
Signed-off-by: Wang Weidong <wangweidong1@huawei.com>
This was found with a manual audit and I don't have a reproducer. We
limit ->calling_len and ->called_len when we get them from
copy_from_user() in x25_ioctl() so when they come from skb->data then
we should cap them there as well.
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
There are multiple locations in the X.25 packet layer where a skb is
assumed to be of at least a certain size and that all its data is
currently available at skb->data. These assumptions are not checked,
hence buffer overreads may occur. Use pskb_may_pull to check these
minimal size assumptions and ensure that data is available at skb->data
when necessary, as well as use skb_copy_bits where needed.
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Cc: stable <stable@kernel.org>
Acked-by: Andrew Hendry <andrew.hendry@gmail.com>
Originally x25_parse_facilities returned
-1 for an error
0 meaning 0 length facilities
>0 the length of the facilities parsed.
5ef41308f94dc ("x25: Prevent crashing when parsing bad X.25 facilities") introduced more
error checking in x25_parse_facilities however used 0 to indicate bad parsing
a6331d6f9a429 ("memory corruption in X.25 facilities parsing") followed this further for
DTE facilities, again using 0 for bad parsing.
The meaning of 0 got confused in the callers.
If the facilities are messed up we can't determine where the data starts.
So patch makes all parsing errors return -1 and ensures callers close and don't use the skb further.
Reported-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com>
Now with improved comma support.
On parsing malformed X.25 facilities, decrementing the remaining length
may cause it to underflow. Since the length is an unsigned integer,
this will result in the loop continuing until the kernel crashes.
This patch adds checks to ensure decrementing the remaining length does
not cause it to wrap around.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-of-by: Andrew Hendry <andrew.hendry@gmail.com>
The current X.25 code has some bugs in throughput negotiation:
1. It does negotiation in all cases, usually there is no need
2. It incorrectly attempts to negotiate the throughput class in one
direction only. There are separate throughput classes for input
and output and if either is negotiated both mist be negotiates.
This is bug https://bugzilla.kernel.org/show_bug.cgi?id=15681
This bug was first reported by Daniel Ferenci to the linux-x25 mailing
list on 6/8/2004, but is still present.
The current (2.6.34) x.25 code doesn't seem to know that the X.25
throughput facility includes two values, one for the required
throughput outbound, one for inbound.
This causes it to attempt to negotiate throughput 0x0A, which is
throughput 9600 inbound and the illegal value "0" for inbound
throughput.
Because of this some X.25 devices (e.g. Cisco 1600) refuse to connect
to Linux X.25.
The following patch fixes this behaviour. Unless the user specifies a
required throughput it does not attempt to negotiate. If the user
does not specify a throughput it accepts the suggestion of the remote
X.25 system. If the user requests a throughput then it validates both
the input and output throughputs and correctly negotiates them with
the remote end.
Signed-off-by: John Hughes <john@calva.com>
Tested-by: Andrew Hendry <andrew.hendry@gmail.com>
Here is a patch to stop X.25 examining fields beyond the end of the packet.
For example, when a simple CALL ACCEPTED was received:
10 10 0f
x25_parse_facilities was attempting to decode the FACILITIES field, but this
packet contains no facilities field.
CHECK net/x25/af_x25.c
net/x25/af_x25.c:117:46: warning: expensive signed divide
CHECK net/x25/x25_facilities.c
net/x25/x25_facilities.c:209:30: warning: expensive signed divide
CHECK net/x25/x25_in.c
net/x25/x25_in.c:250:26: warning: expensive signed divide
CHECK net/x25/x25_proc.c
net/x25/x25_proc.c:48:11: warning: context imbalance in 'x25_seq_route_start'
- wrong count at exit
net/x25/x25_proc.c:72:13: warning: context imbalance in 'x25_seq_route_stop' -
unexpected unlock
net/x25/x25_proc.c:112:11: warning: context imbalance in
'x25_seq_socket_start' - wrong count at exit
net/x25/x25_proc.c:129:13: warning: context imbalance in 'x25_seq_socket_stop'
- unexpected unlock
net/x25/x25_proc.c:190:11: warning: context imbalance in
'x25_seq_forward_start' - wrong count at exit
net/x25/x25_proc.c:215:13: warning: context imbalance in
'x25_seq_forward_stop' - unexpected unlock
CHECK net/x25/x25_subr.c
net/x25/x25_subr.c:362:57: warning: expensive signed divide
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Trivial. Newlines missing on the SOCK_DEBUG's for X.25 facility
negotiation.
Allows use of the optional user facility to insert ITU-T
(http://www.itu.int/ITU-T/) specified DTE facilities in call set-up x25
packets. This feature is optional; no facilities will be added if the ioctl
is not used, and call setup packet remains the same as before.
If the ioctls provided by the patch are used, then a facility marker will be
added to the x25 packet header so that the called dte address extension
facility can be differentiated from other types of facilities (as described in
the ITU-T X.25 recommendation) that are also allowed in the x25 packet header.
Facility markers are made up of two octets, and may be present in the x25
packet headers of call-request, incoming call, call accepted, clear request,
and clear indication packets. The first of the two octets represents the
facility code field and is set to zero by this patch. The second octet of the
marker represents the facility parameter field and is set to 0x0F because the
marker will be inserted before ITU-T type DTE facilities.
Since according to ITU-T X.25 Recommendation X.25(10/96)- 7.1 "All networks
will support the facility markers with a facility parameter field set to all
ones or to 00001111", therefore this patch should work with all x.25 networks.
While there are many ITU-T DTE facilities, this patch implements only the
called and calling address extension, with placeholders in the
x25_dte_facilities structure for the rest of the facilities.
Testing:
This patch was tested using a cisco xot router connected on its serial ports
to an X.25 network, and on its lan ports to a host running an xotd daemon.
It is also possible to test this patch using an xotd daemon and an x25tap
patch, where the xotd daemons work back-to-back without actually using an x.25
network. See www.fyonne.net for details on how to do this.
Signed-off-by: Shaun Pereira <spereira@tusc.com.au>
Acked-by: Andrew Hendry <ahendry@tusc.com.au>
This patch is a follow up to patch 1 regarding "Selective Sub Address
matching with call user data". It allows use of the Fast-Select-Acceptance
optional user facility for X.25.
This patch just implements fast select with no restriction on response
(NRR). What this means (according to ITU-T Recomendation 10/96 section
6.16) is that if in an incoming call packet, the relevant facility bits are
set for fast-select-NRR, then the called DTE can issue a direct response to
the incoming packet using a call-accepted packet that contains
call-user-data. This patch allows such a response.
The called DTE can also respond with a clear-request packet that contains
call-user-data. However, this feature is currently not implemented by the
patch.
How is Fast Select Acceptance used?
By default, the system does not allow fast select acceptance (as before).
To enable a response to fast select acceptance,
After a listen socket in created and bound as follows
socket(AF_X25, SOCK_SEQPACKET, 0);
bind(call_soc, (struct sockaddr *)&locl_addr, sizeof(locl_addr));
but before a listen system call is made, the following ioctl should be used.
ioctl(call_soc,SIOCX25CALLACCPTAPPRV);
Now the listen system call can be made
listen(call_soc, 4);
After this, an incoming-call packet will be accepted, but no call-accepted
packet will be sent back until the following system call is made on the socket
that accepts the call
ioctl(vc_soc,SIOCX25SENDCALLACCPT);
The network (or cisco xot router used for testing here) will allow the
application server's call-user-data in the call-accepted packet,
provided the call-request was made with Fast-select NRR.
infrastructure for it.
Let it rip!
