path: root/net/x25
2009-03-27af_rose/x25: Sanity check the maximum user frame sizeAlan Cox
Otherwise we can wrap the sizes and end up sending garbage. Closes #10423 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13x25: '< 0' and '>= 0' test on unsignedRoel Kluin
skb->len is an unsigned int, so the test in x25_rx_call_request() always evaluates to true. len in x25_sendmsg() is unsigned as well. so -ERRORS returned by x25_output() are not noticed. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17x25: Use sock_orphan() instead of open-coded (and buggy) variant.David S. Miller
It doesn't grab the sk_callback_lock, it doesn't NULL out the sk->sk_sleep waitqueue pointer, etc. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17x25: Use sock_graft() and remove bogus sk_socket and sk_sleep init.David S. Miller
This is the x25 variant of changeset 9375cb8a1232d2a15fe34bec4d3474872e02faec ("ax25: Use sock_graft() and remove bogus sk_socket and sk_sleep init.") Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-28[X25]: Use proc_create() to setup ->proc_fops firstWang Chen
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[AX25]: Beautify x25_init() version printk.maximilian attems
kill ref to old version and dup Linux. Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[AF_X25]: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[X25]: Avoid divides and sparse warningsEric Dumazet
CHECK net/x25/af_x25.c net/x25/af_x25.c:117:46: warning: expensive signed divide CHECK net/x25/x25_facilities.c net/x25/x25_facilities.c:209:30: warning: expensive signed divide CHECK net/x25/x25_in.c net/x25/x25_in.c:250:26: warning: expensive signed divide CHECK net/x25/x25_proc.c net/x25/x25_proc.c:48:11: warning: context imbalance in 'x25_seq_route_start' - wrong count at exit net/x25/x25_proc.c:72:13: warning: context imbalance in 'x25_seq_route_stop' - unexpected unlock net/x25/x25_proc.c:112:11: warning: context imbalance in 'x25_seq_socket_start' - wrong count at exit net/x25/x25_proc.c:129:13: warning: context imbalance in 'x25_seq_socket_stop' - unexpected unlock net/x25/x25_proc.c:190:11: warning: context imbalance in 'x25_seq_forward_start' - wrong count at exit net/x25/x25_proc.c:215:13: warning: context imbalance in 'x25_seq_forward_stop' - unexpected unlock CHECK net/x25/x25_subr.c net/x25/x25_subr.c:362:57: warning: expensive signed divide Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Simple ctl_table to ctl_path conversions.Pavel Emelyanov
This patch includes many places, that only required replacing the ctl_table-s with appropriate ctl_paths and call register_sysctl_paths(). Nothing special was done with them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[X25]: use LIST_HEAD instead of LIST_HEAD_INITDenis Cheng
single list_head variable initialized with LIST_HEAD_INIT could almost always can be replaced with LIST_HEAD declaration, this shrinks the code and looks better. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-04[X25]: Add missing x25_neigh_putJulia Lawall
The function x25_get_neigh increments a reference count. At the point of the second goto out, the result of calling x25_get_neigh is only stored in a local variable, and thus no one outside the function will be able to decrease the reference count. Thus, x25_neigh_put should be called before the return in this case. The problem was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T,T1,T2; identifier E; statement S; expression x1,x2,x3; int ret; @@ T E; ... * if ((E = x25_get_neigh(...)) == NULL) S ... when != x25_neigh_put(...,(T1)E,...) when != if (E != NULL) { ... x25_neigh_put(...,(T1)E,...); ...} when != x1 = (T1)E when != E = x3; when any if (...) { ... when != x25_neigh_put(...,(T2)E,...) when != if (E != NULL) { ... x25_neigh_put(...,(T2)E,...); ...} when != x2 = (T2)E ( * return; | * return ret; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Some more conversions to skb_copy_from_linear_dataArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: More skb_put related conversions to skb_reset_transport_headerArnaldo Carvalho de Melo
This is similar to the skb_reset_network_header(), i.e. at the point we reset the transport header pointer/offset skb->tail is equal to skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-20[X25] x25_forward_call(): fix NULL dereferencesAdrian Bunk
This patch fixes two NULL dereferences spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: x25: remove unnecessary insert_at_head from ↵Eric W. Biederman
register_sysctl_table There has not been much maintenance on sysctl in years, and as a result is there is a lot to do to allow future interesting work to happen, and being ambitious I'm trying to do it all at once :) The patches in this series fall into several general categories. - Removal of useless attempts to override the standard sysctls - Registers of sysctl numbers in sysctl.h so someone else does not use the magic number and conflict. - C99 conversions so it becomes possible to change the layout of struct ctl_table without breaking everything. - Removal of useless claims of module ownership, in the proc dir entries - Removal of sys_sysctl support where people had used conflicting sysctl numbers. Trying to break glibc or other applications by changing the ABI is not cool. 9 instances of this in the kernel seems a little extreme. - General enhancements when I got the junk I could see out. This patch: Since x25 uses unique binary numbers inserting yourself at the head of the search list for sysctls so you can override already registered sysctls is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] X25: Fix whitespace errors.YOSHIFUJI Hideaki
2007-02-08[X.25]: Adds /proc/net/x25/forward to view active forwarded calls.Andrew Hendry
View the active forwarded calls cat /proc/net/x25/forward Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[X.25]: Adds /proc/sys/net/x25/x25_forward to control forwarding.Andrew Hendry
echo "1" > /proc/sys/net/x25/x25_forward To turn on x25_forwarding, defaults to off Requires the previous patch. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[X.25]: Add call forwardingAndrew Hendry
Adds call forwarding to X.25, allowing it to operate like an X.25 router. Useful if one needs to manipulate X.25 traffic with tools like tc. This is an update/cleanup based off a patch submitted by Daniel Ferenci a few years ago. Thanks Alan for the feedback. Added the null check to the clones. Moved the skb_clone's into the forwarding functions. Worked ok with Cisco XoT, linux X.25 back to back, and some old NTUs/PADs. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-23[X.25]: Add missing sock_put in x25_receive_dataAndrew Hendry
__x25_find_socket does a sock_hold. This adds a missing sock_put in x25_receive_data. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-09[X25]: Trivial, SOCK_DEBUG's in x25_facilities missing newlinesAndrew Hendry
Trivial. Newlines missing on the SOCK_DEBUG's for X.25 facility negotiation. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-03[X25]: proper prototype for x25_init_timers()Adrian Bunk
This patch adds a proper prototype for x25_init_timers() in include/net/x25.h Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-29[X25]: fix for spinlock recurse and spinlock lockup with timer handlerShaun Pereira
When the sk_timer function x25_heartbeat_expiry() is called by the kernel in a running/terminating process, spinlock-recursion and spinlock-lockup locks up the kernel. This has happened with testing on some distro's and the patch below fixed it. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[X25]: dte facilities 32 64 ioctl conversionShaun Pereira
Allows dte facility patch to use 32 64 bit ioctl conversion mechanism Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[X25]: allow ITU-T DTE facilities for x25Shaun Pereira
Allows use of the optional user facility to insert ITU-T (http://www.itu.int/ITU-T/) specified DTE facilities in call set-up x25 packets. This feature is optional; no facilities will be added if the ioctl is not used, and call setup packet remains the same as before. If the ioctls provided by the patch are used, then a facility marker will be added to the x25 packet header so that the called dte address extension facility can be differentiated from other types of facilities (as described in the ITU-T X.25 recommendation) that are also allowed in the x25 packet header. Facility markers are made up of two octets, and may be present in the x25 packet headers of call-request, incoming call, call accepted, clear request, and clear indication packets. The first of the two octets represents the facility code field and is set to zero by this patch. The second octet of the marker represents the facility parameter field and is set to 0x0F because the marker will be inserted before ITU-T type DTE facilities. Since according to ITU-T X.25 Recommendation X.25(10/96)- 7.1 "All networks will support the facility markers with a facility parameter field set to all ones or to 00001111", therefore this patch should work with all x.25 networks. While there are many ITU-T DTE facilities, this patch implements only the called and calling address extension, with placeholders in the x25_dte_facilities structure for the rest of the facilities. Testing: This patch was tested using a cisco xot router connected on its serial ports to an X.25 network, and on its lan ports to a host running an xotd daemon. It is also possible to test this patch using an xotd daemon and an x25tap patch, where the xotd daemons work back-to-back without actually using an x.25 network. See www.fyonne.net for details on how to do this. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Acked-by: Andrew Hendry <ahendry@tusc.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[X25]: fix kernel error message 64 bit kernelShaun Pereira
Fixes the following error from kernel T2 kernel: schedule_timeout: wrong timeout value ffffffffffffffff from ffffffff88164796 Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[X25]: ioctl conversion 32 bit user to 64 bit kernelShaun Pereira
To allow 32 bit x25 module structures to be passed to a 64 bit kernel via ioctl using the new compat_sock_ioctl registration mechanism instead of the obsolete 'register_ioctl32_conversion into hash table' mechanism Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
