path: root/net/x25
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[X25]: Fix for broken x25 module.Shaun Pereira
When a user-space server application calls bind on a socket, then in kernel space this bound socket is considered 'x25-linked' and the SOCK_ZAPPED flag is unset.(As in x25_bind()/af_x25.c). Now when a user-space client application attempts to connect to the server on the listening socket, if the kernel accepts this in-coming call, then it returns a new socket to userland and attempts to reply to the caller. The reply/x25_sendmsg() will fail, because the new socket created on call-accept has its SOCK_ZAPPED flag set by x25_make_new(). (sock_init_data() called by x25_alloc_socket() called by x25_make_new() sets the flag to SOCK_ZAPPED)). Fix: Using the sock_copy_flag() routine available in sock.h fixes this. Tested on 32 and 64 bit kernels with x25 over tcp. Signed-off-by: Shaun Pereira <pereira.shaun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2005-07-11[NET]: move config options out to individual protocolsSam Ravnborg
Move the protocol specific config options out to the specific protocols. With this change net/Kconfig now starts to become readable and serve as a good basis for further re-structuring. The menu structure is left almost intact, except that indention is fixed in most cases. Most visible are the INET changes where several "depends on INET" are replaced with a single ifdef INET / endif pair. Several new files were created to accomplish this change - they are small but serve the purpose that config options are now distributed out where they belongs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[X25]: Fast select with no restriction on responseShaun Pereira
This patch is a follow up to patch 1 regarding "Selective Sub Address matching with call user data". It allows use of the Fast-Select-Acceptance optional user facility for X.25. This patch just implements fast select with no restriction on response (NRR). What this means (according to ITU-T Recomendation 10/96 section 6.16) is that if in an incoming call packet, the relevant facility bits are set for fast-select-NRR, then the called DTE can issue a direct response to the incoming packet using a call-accepted packet that contains call-user-data. This patch allows such a response. The called DTE can also respond with a clear-request packet that contains call-user-data. However, this feature is currently not implemented by the patch. How is Fast Select Acceptance used? By default, the system does not allow fast select acceptance (as before). To enable a response to fast select acceptance, After a listen socket in created and bound as follows socket(AF_X25, SOCK_SEQPACKET, 0); bind(call_soc, (struct sockaddr *)&locl_addr, sizeof(locl_addr)); but before a listen system call is made, the following ioctl should be used. ioctl(call_soc,SIOCX25CALLACCPTAPPRV); Now the listen system call can be made listen(call_soc, 4); After this, an incoming-call packet will be accepted, but no call-accepted packet will be sent back until the following system call is made on the socket that accepts the call ioctl(vc_soc,SIOCX25SENDCALLACCPT); The network (or cisco xot router used for testing here) will allow the application server's call-user-data in the call-accepted packet, provided the call-request was made with Fast-select NRR. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[X25]: Selective sub-address matching with call user data.Shaun Pereira
From: Shaun Pereira <spereira@tusc.com.au> This is the first (independent of the second) patch of two that I am working on with x25 on linux (tested with xot on a cisco router). Details are as follows. Current state of module: A server using the current implementation (2.6.11.7) of the x25 module will accept a call request/ incoming call packet at the listening x.25 address, from all callers to that address, as long as NO call user data is present in the packet header. If the server needs to choose to accept a particular call request/ incoming call packet arriving at its listening x25 address, then the kernel has to allow a match of call user data present in the call request packet with its own. This is required when multiple servers listen at the same x25 address and device interface. The kernel currently matches ALL call user data, if present. Current Changes: This patch is a follow up to the patch submitted previously by Andrew Hendry, and allows the user to selectively control the number of octets of call user data in the call request packet, that the kernel will match. By default no call user data is matched, even if call user data is present. To allow call user data matching, a cudmatchlength > 0 has to be passed into the kernel after which the passed number of octets will be matched. Otherwise the kernel behavior is exactly as the original implementation. This patch also ensures that as is normally the case, no call user data will be present in the Call accepted / call connected packet sent back to the caller Future Changes on next patch: There are cases however when call user data may be present in the call accepted packet. According to the X.25 recommendation (ITU-T 10/96) section 5.2.3.2 call user data may be present in the call accepted packet provided the fast select facility is used. My next patch will include this fast select utility and the ability to send up to 128 octets call user data in the call accepted packet provided the fast select facility is used. I am currently testing this, again with xot on linux and cisco. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> (With a fix from Alexey Dobriyan <adobriyan@gmail.com>) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
