[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit 4ccb93ce7439b63c31bc7597bfffd13567fa483d ]
Two of the x25 ioctl cases have error paths that break out of the function without
unlocking the socket, leading to this warning:
[ BUG: lock held when returning to user space! ]
3.10.0-rc7+ #36 Not tainted
trinity-child2/31407 is leaving the kernel with locks still held!
1 lock held by trinity-child2/31407:
#0: (sk_lock-AF_X25){+.+.+.}, at: [<ffffffffa024b6da>] x25_ioctl+0x8a/0x740 [x25]
Signed-off-by: Dave Jones <davej@redhat.com>
Use IS_ENABLED(CONFIG_FOO)
instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE)
Signed-off-by: Igor Maravić <igorm@etf.rs>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
commit cb101ed2 in 3.0 introduced a bug in x25_recvmsg()
When passed bogus junk from userspace, x25->neighbour can be NULL,
as shown in this oops..
BUG: unable to handle kernel NULL pointer dereference at 000000000000001c
IP: [<ffffffffa05482bd>] x25_recvmsg+0x4d/0x280 [x25]
PGD 1015f3067 PUD 105072067 PMD 0
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Pid: 27928, comm: iknowthis Not tainted 3.1.0+ #2 Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H
RIP: 0010:[<ffffffffa05482bd>] [<ffffffffa05482bd>] x25_recvmsg+0x4d/0x280 [x25]
RSP: 0018:ffff88010c0b7cc8 EFLAGS: 00010282
RAX: 0000000000000000 RBX: ffff88010c0b7d78 RCX: 0000000000000c02
RDX: ffff88010c0b7d78 RSI: ffff88011c93dc00 RDI: ffff880103f667b0
RBP: ffff88010c0b7d18 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880103f667b0
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f479ce7f700(0000) GS:ffff88012a600000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000000001c CR3: 000000010529e000 CR4: 00000000000006f0
Process iknowthis (pid: 27928, threadinfo ffff88010c0b6000, task ffff880103faa4f0)
Stack:
0000000000000c02 0000000000000c02 ffff88010c0b7d18 ffffff958153cb37
ffffffff8153cb60 0000000000000c02 ffff88011c93dc00 0000000000000000
0000000000000c02 ffff88010c0b7e10 ffff88010c0b7de8 ffffffff815372c2
Call Trace:
[<ffffffff8153cb60>] ? sock_update_classid+0xb0/0x180
[<ffffffff815372c2>] sock_aio_read.part.10+0x142/0x150
[<ffffffff812d6752>] ? inode_has_perm+0x62/0xa0
[<ffffffff815372fd>] sock_aio_read+0x2d/0x40
[<ffffffff811b05e2>] do_sync_read+0xd2/0x110
[<ffffffff812d3796>] ? security_file_permission+0x96/0xb0
[<ffffffff811b0a91>] ? rw_verify_area+0x61/0x100
[<ffffffff811b103d>] vfs_read+0x16d/0x180
[<ffffffff811b109d>] sys_read+0x4d/0x90
[<ffffffff81657282>] system_call_fastpath+0x16/0x1b
Code: 8b 66 20 4c 8b 32 48 89 d3 48 89 4d b8 45 89 c7 c7 45 cc 95 ff ff ff 4d 85 e4 0f 84 ed 01 00 00 49 8b 84 24 18 05 00 00 4c 89 e7
78 1c 01 45 19 ed 31 f6 e8 d5 37 ff e0 41 0f b6 44 24 0e 41
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
x25_find_listener does not check that the amount of call user data given
in the skb is big enough in per-socket comparisons, hence buffer
overreads may occur. Fix this by adding a check.
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Cc: stable <stable@kernel.org>
Acked-by: Andrew Hendry <andrew.hendry@gmail.com>
There are multiple locations in the X.25 packet layer where a skb is
assumed to be of at least a certain size and that all its data is
currently available at skb->data. These assumptions are not checked,
hence buffer overreads may occur. Use pskb_may_pull to check these
minimal size assumptions and ensure that data is available at skb->data
when necessary, as well as use skb_copy_bits where needed.
X.25 call user data is being copied in its entirety from incoming messages
without consideration to the size of the destination buffers, leading to
possible buffer overflows. Validate incoming call user data lengths before
these copies are performed.
It appears this issue was noticed some time ago, however nothing seemed to
come of it: see http://www.spinics.net/lists/linux-x25/msg00043.html and
commit 8db09f26f912f7c90c764806e804b558da520d4f.
Tested-by: Andrew Hendry <andrew.hendry@gmail.com>
Make the case labels the same indent as the switch.
git diff -w shows 80 column line reflowing.
This replaces all instances of lock_kernel in x25
with lock_sock, taking care to release the socket
lock around sleeping functions (sock_alloc_send_skb
and skb_recv_datagram). It is not clear whether
this is a correct solution, but it seem to be what
other protocols do in the same situation.
Includes a fix suggested by Eric Dumazet.
Cc: linux-x25@vger.kernel.org
Cc: netdev@vger.kernel.org
In x25_link_free(), we destroy 'nb' before dereferencing
'nb->dev'. Don't do this, because 'nb' might be freed
by then.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Originally x25_parse_facilities returned
-1 for an error
0 meaning 0 length facilities
>0 the length of the facilities parsed.
5ef41308f94dc ("x25: Prevent crashing when parsing bad X.25 facilities") introduced more
error checking in x25_parse_facilities however used 0 to indicate bad parsing
a6331d6f9a429 ("memory corruption in X.25 facilities parsing") followed this further for
DTE facilities, again using 0 for bad parsing.
The meaning of 0 got confused in the callers.
If the facilities are messed up we can't determine where the data starts.
So patch makes all parsing errors return -1 and ensures callers close and don't use the skb further.
Reported-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com>
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
x25 does not decrement the network device reference counts on module unload.
Thus unregistering any pre-existing interface after unloading the x25 module
hangs and results in
unregister_netdevice: waiting for tap0 to become free. Usage count = 1
This patch decrements the reference counts of all interfaces in x25_link_free,
the way it is already done in x25_link_device_down for NETDEV_DOWN events.
Signed-off-by: Apollon Oikonomopoulos <apollon@noc.grnet.gr>
Routing doesn't use the socket data and is protected by x25_route_list_lock
Push down the bkl in the ioctls so they can be removed one at a time.
Now with improved comma support.
On parsing malformed X.25 facilities, decrementing the remaining length
may cause it to underflow. Since the length is an unsigned integer,
this will result in the loop continuing until the kernel crashes.
This patch adds checks to ensure decrementing the remaining length does
not cause it to wrap around.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-of-by: Andrew Hendry <andrew.hendry@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
With all the patches we have queued in the BKL removal tree, only a
few dozen modules are left that actually rely on the BKL, and even
there are lots of low-hanging fruit. We need to decide what to do
about them, this patch illustrates one of the options:
Every user of the BKL is marked as 'depends on BKL' in Kconfig,
and the CONFIG_BKL becomes a user-visible option. If it gets
disabled, no BKL using module can be built any more and the BKL
code itself is compiled out.
The one exception is file locking, which is practically always
enabled and does a 'select BKL' instead. This effectively forces
CONFIG_BKL to be enabled until we have solved the fs/lockd
mess and can apply the patch that removes the BKL from fs/locks.c.
The x25_datagram_poll didn't add anything, removed it.
Connect already has socket locking.
Accept already has socket locking.
[ Extend socket locking over TCP_LISTEN state test. -DaveM ]
Accept updates socket values in 3 lines so wrapped with lock_sock.
Listen updates socket values and needs lock_sock.
Removes the BKL in x25 setsock and getsockopts.
Moves the x25 accept approve flag from char into bitfield.
Moves the x25 interrupt flag from char into bitfield.
Moves the X25 q bit flag from char into a bitfield to allow BKL cleanup.
drivers/net/e100.c
drivers/net/e1000e/netdev.c
V2 Feedback from John Hughes.
- Add header for userspace implementations such as xot/xoe to use
- Use explicit values for interface stability
- No changes to driver patches
V1
- Use identifiers instead of magic numbers for X25 layer 3 to device interface.
- Also fixed checkpatch notes on updated code.
[ Add new user header to include/linux/Kbuild -DaveM ]
1, An X25 program binds and listens
2, calls arrive waiting to be accepted
3, Program exits without accepting
4, Sockets time out but don't get correctly cleaned up
5, cat /proc/net/x25/socket shows the dead sockets with bad inode fields.
This line borrowed from AX25 sets the dying socket so the timers clean up later.
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
The current X.25 code has some bugs in throughput negotiation:
1. It does negotiation in all cases, usually there is no need
2. It incorrectly attempts to negotiate the throughput class in one
direction only. There are separate throughput classes for input
and output and if either is negotiated both mist be negotiates.
This is bug https://bugzilla.kernel.org/show_bug.cgi?id=15681
This bug was first reported by Daniel Ferenci to the linux-x25 mailing
list on 6/8/2004, but is still present.
The current (2.6.34) x.25 code doesn't seem to know that the X.25
throughput facility includes two values, one for the required
throughput outbound, one for inbound.
This causes it to attempt to negotiate throughput 0x0A, which is
throughput 9600 inbound and the illegal value "0" for inbound
throughput.
Because of this some X.25 devices (e.g. Cisco 1600) refuse to connect
to Linux X.25.
The following patch fixes this behaviour. Unless the user specifies a
required throughput it does not attempt to negotiate. If the user
does not specify a throughput it accepts the suggestion of the remote
X.25 system. If the user requests a throughput then it validates both
the input and output throughputs and correctly negotiates them with
the remote end.
Signed-off-by: John Hughes <john@calva.com>
Here is a patch to stop X.25 examining fields beyond the end of the packet.
For example, when a simple CALL ACCEPTED was received:
10 10 0f
x25_parse_facilities was attempting to decode the FACILITIES field, but this
packet contains no facilities field.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
sk_add_backlog -> __sk_add_backlog
sk_add_backlog_limited -> sk_add_backlog
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Make x25 adapt to the limited socket backlog change.
Addresses should be all digits.
Stops x25_bind using addresses containing characters.
