path: root/net/xfrm/Makefile
2012-05-15xfrm: make xfrm_algo.c a moduleJan Beulich
By making this a standalone config option (auto-selected as needed), selecting CRYPTO from here rather than from XFRM (which is boolean) allows the core crypto code to become a module again even when XFRM=y. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-13xfrm: Move IPsec replay detection functions to a separate fileSteffen Klassert
To support multiple versions of replay detection, we move the replay detection functions to a separate file and make them accessible via function pointers contained in the struct xfrm_replay. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns sysctlsAlexey Dobriyan
Make net.core.xfrm_aevent_etime net.core.xfrm_acq_expires net.core.xfrm_aevent_rseqth net.core.xfrm_larval_drop sysctls per-netns. For that make net_core_path[] global, register it to prevent two /proc/net/core antries and change initcall position -- xfrm_init() is called from fs_initcall, so this one should be fs_initcall at least. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25ipsec: ipcomp - Merge IPComp implementationsHerbert Xu
This patch merges the IPv4/IPv6 IPComp implementations since most of the code is identical. As a result future enhancements will no longer need to be duplicated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: Define packet dropping statistics.Masahide NAKAMURA
This statistics is shown factor dropped by transformation at /proc/net/xfrm_stat for developer. It is a counter designed from current transformation source code and defined as linux private MIB. See Documentation/networking/xfrm_proc.txt for the detail. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common output code to xfrm_outputHerbert Xu
Most of the code in xfrm4_output_one and xfrm6_output_one are identical so this patch moves them into a common xfrm_output function which will live in net/xfrm. In fact this would seem to fix a bug as on IPv4 we never reset the network header after a transform which may upset netfilter later on. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Extract common hashing code into xfrm_hash.[ch]David S. Miller
