path: root/net/xfrm/xfrm_user.c
2011-06-09rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-26xfrm: Check for the new replay implementation if an esn state is insertedSteffen Klassert
IPsec extended sequence numbers can be used only with the new anti-replay window implementation. So check if the new implementation is used if an esn state is inserted and return an error if it is not. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-28xfrm: Restrict extended sequence numbers to espSteffen Klassert
The IPsec extended sequence numbers are fully implemented just for esp. So restrict the usage to esp until other protocols have support too. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-28xfrm: Check for esn buffer len in xfrm_new_aeSteffen Klassert
In xfrm_new_ae() we may overwrite the allocated esn replay state buffer with a wrong size. So check that the new size matches the original allocated size and return an error if this is not the case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21xfrm: Fix initialize repl field of struct xfrm_stateWei Yongjun
Commit 'xfrm: Move IPsec replay detection functions to a separate file' (9fdc4883d92d20842c5acea77a4a21bb1574b495) introduce repl field to struct xfrm_state, and only initialize it under SA's netlink create path, the other path, such as pf_key, ipcomp/ipcomp6 etc, the repl field remaining uninitialize. So if the SA is created by pf_key, any input packet with SA's encryption algorithm will cause panic. int xfrm_input() { ... x->repl->advance(x, seq); ... } This patch fixed it by introduce new function __xfrm_init_state(). Pid: 0, comm: swapper Not tainted 2.6.38-next+ #14 Bochs Bochs EIP: 0060:[<c078e5d5>] EFLAGS: 00010206 CPU: 0 EIP is at xfrm_input+0x31c/0x4cc EAX: dd839c00 EBX: 00000084 ECX: 00000000 EDX: 01000000 ESI: dd839c00 EDI: de3a0780 EBP: dec1de88 ESP: dec1de64 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process swapper (pid: 0, ti=dec1c000 task=c09c0f20 task.ti=c0992000) Stack: 00000000 00000000 00000002 c0ba27c0 00100000 01000000 de3a0798 c0ba27c0 00000033 dec1de98 c0786848 00000000 de3a0780 dec1dea4 c0786868 00000000 dec1debc c074ee56 e1da6b8c de3a0780 c074ed44 de3a07a8 dec1decc c074ef32 Call Trace: [<c0786848>] xfrm4_rcv_encap+0x22/0x27 [<c0786868>] xfrm4_rcv+0x1b/0x1d [<c074ee56>] ip_local_deliver_finish+0x112/0x1b1 [<c074ed44>] ? ip_local_deliver_finish+0x0/0x1b1 [<c074ef32>] NF_HOOK.clone.1+0x3d/0x44 [<c074ef77>] ip_local_deliver+0x3e/0x44 [<c074ed44>] ? ip_local_deliver_finish+0x0/0x1b1 [<c074ec03>] ip_rcv_finish+0x30a/0x332 [<c074e8f9>] ? ip_rcv_finish+0x0/0x332 [<c074ef32>] NF_HOOK.clone.1+0x3d/0x44 [<c074f188>] ip_rcv+0x20b/0x247 [<c074e8f9>] ? ip_rcv_finish+0x0/0x332 [<c072797d>] __netif_receive_skb+0x373/0x399 [<c0727bc1>] netif_receive_skb+0x4b/0x51 [<e0817e2a>] cp_rx_poll+0x210/0x2c4 [8139cp] [<c072818f>] net_rx_action+0x9a/0x17d [<c0445b5c>] __do_softirq+0xa1/0x149 [<c0445abb>] ? __do_softirq+0x0/0x149 Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-13xfrm: Add user interface for esn and big anti-replay windowsSteffen Klassert
This patch adds a netlink based user interface to configure esn and big anti-replay windows. The new netlink attribute XFRMA_REPLAY_ESN_VAL is used to configure the new implementation. If the XFRM_STATE_ESN flag is set, we use esn and support for big anti-replay windows for the configured state. If this flag is not set we use the new implementation with 32 bit sequence numbers. A big anti-replay window can be configured in this case anyway. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-13xfrm: Move IPsec replay detection functions to a separate fileSteffen Klassert
To support multiple versions of replay detection, we move the replay detection functions to a separate file and make them accessible via function pointers contained in the struct xfrm_replay. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03netlink: kill loginuid/sessionid/sid members from struct netlink_skb_parmsPatrick McHardy
Netlink message processing in the kernel is synchronous these days, the session information can be collected when needed. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-27xfrm: Pass name as const to xfrm_*_get_byname().David S. Miller
2011-02-23xfrm: Const'ify pointer args to km_migrate() and implementations.David S. Miller
2011-02-23xfrm: Pass km_event pointers around as const when possible.David S. Miller
2011-01-19Revert "netlink: test for all flags of the NLM_F_DUMP composite"David S. Miller
This reverts commit 0ab03c2b1478f2438d2c80204f7fef65b1bca9cf. It breaks several things including the avahi daemon. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11xfrm: check trunc_len in XFRMA_ALG_AUTH_TRUNCNicolas Dichtel
Maximum trunc length is defined by MAX_AH_AUTH_LEN (in bytes) and need to be checked when this value is set (in bits) by the user. In ah4.c and ah6.c a BUG_ON() checks this condiftion. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09netlink: test for all flags of the NLM_F_DUMP compositeJan Engelhardt
Due to NLM_F_DUMP is composed of two bits, NLM_F_ROOT | NLM_F_MATCH, when doing "if (x & NLM_F_DUMP)", it tests for _either_ of the bits being set. Because NLM_F_MATCH's value overlaps with NLM_F_EXCL, non-dump requests with NLM_F_EXCL set are mistaken as dump requests. Substitute the condition to test for _all_ bits being set. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Acked-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10xfrm: Add Traffic Flow Confidentiality padding XFRM attributeMartin Willi
The XFRMA_TFCPAD attribute for XFRM state installation configures Traffic Flow Confidentiality by padding ESP packets to a specified length. Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-01xfrm_user: avoid a warning with some compilerNicolas Dichtel
Attached is a small patch to remove a warning ("warning: ISO C90 forbids mixed declarations and code" with gcc 4.3.2). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-14xfrm: Use GFP_ATOMIC in xfrm_compile_policyHerbert Xu
As xfrm_compile_policy runs within a read_lock, we cannot use GFP_KERNEL for memory allocations. Reported-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17xfrm: add severity to printkstephen hemminger
Serious oh sh*t messages converted to WARN(). Add KERN_NOTICE severity to the unknown policy type messages. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01xfrm: remove policy lock when accessing policy->walk.deadTimo Teräs
All of the code considers ->dead as a hint that the cached policy needs to get refreshed. The read side can just drop the read lock without any side effects. The write side needs to make sure that it's written only exactly once. Only possible race is at xfrm_policy_kill(). This is fixed by checking result of __xfrm_policy_unlink() when needed. It will always succeed if the policy object is looked up from the hash list (so some checks are removed), but it needs to be checked if we are trying to unlink policy via a reference (appropriate checks added). Since policy->walk.dead is written exactly once, it no longer needs to be protected with a write lock. Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01xfrm_user: verify policy direction at XFRM_MSG_POLEXPIRE handlerTimo Teräs
Add missing check for policy direction verification. This is especially important since without this xfrm_user may end up deleting per-socket policy which is not allowed. Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: Allow user space manipulation of SPD markJamal Hadi Salim
Add ability for netlink userspace to manipulate the SPD and manipulate the mark, retrieve it and get events with a defined mark, etc. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: Allow user space config of SAD markJamal Hadi Salim
Add ability for netlink userspace to manipulate the SAD and manipulate the mark, retrieve it and get events with a defined mark. MIGRATE may be added later. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SP lookups signature with markJamal Hadi Salim
pass mark to all SP lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SA lookups signature with markJamal Hadi Salim
pass mark to all SA lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19xfrm: Flushing empty SPD generates false eventsJamal Hadi Salim
To see the effect make sure you have an empty SPD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm policy flush" You get prompt back in window2 and you see the flush event on window1. With this fix, you still get prompt on window1 but no event on window2. Thanks to Alexey Dobriyan for finding a bug in earlier version when using pfkey to do the flushing. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19xfrm: Flushing empty SAD generates false eventsJamal Hadi Salim
To see the effect make sure you have an empty SAD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm state flush" You get prompt back in window2 and you see the flush event on window1. With this fix, you still get prompt on window1 but no event on window2. Thanks to Alexey Dobriyan for finding a bug in earlier version when using pfkey to do the flushing. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17xfrm: Revert false event eliding commits.David S. Miller
As reported by Alexey Dobriyan: -------------------- setkey now takes several seconds to run this simple script and it spits "recv: Resource temporarily unavailable" messages. #!/usr/sbin/setkey -f flush; spdflush; add A B ipcomp 44 -m tunnel -C deflate; add B A ipcomp 45 -m tunnel -C deflate; spdadd A B any -P in ipsec ipcomp/tunnel/192.168.1.2-192.168.1.3/use; spdadd B A any -P out ipsec ipcomp/tunnel/192.168.1.3-192.168.1.2/use; -------------------- Obviously applications want the events even when the table is empty. So we cannot make this behavioral change. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15xfrm: Flushing empty SPD generates false eventsjamal
Observed similar behavior on SPD as previouly seen on SAD flushing.. This fixes it. cheers, jamal commit 428b20432dc31bc2e01a94cd451cf5a2c00d2bf4 Author: Jamal Hadi Salim <hadi@cyberus.ca> Date: Thu Feb 11 05:49:38 2010 -0500 xfrm: Flushing empty SPD generates false events To see the effect make sure you have an empty SPD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm policy flush" You get prompt back in window1 and you see the flush event on window2. With this fix, you still get prompt on window1 but no event on window2. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15xfrm: Flushing empty SAD generates false eventsjamal
To see the effect make sure you have an empty SAD. -On window1 "ip xfrm mon" -on window2 issue "ip xfrm state flush" You get prompt back in window1 and you see the flush event on window2. With this fix, you still get prompt on window1 but no event on window2. I was tempted to return -ESRCH on window1 (which would show "RTNETLINK answers: No such process") but didnt want to change current behavior. cheers, jamal commit 5f3dd4a772326166e1bcf54acc2391df00dc7ab5 Author: Jamal Hadi Salim <hadi@cyberus.ca> Date: Thu Feb 11 04:41:36 2010 -0500 xfrm: Flushing empty SAD generates false events To see the effect make sure you have an empty SAD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm state flush" You get prompt back in window1 and you see the flush event on window2. With this fix, you still get prompt on window1 but no event on window2. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12xfrm: validate attributesjamal
Some XFRM attributes were not going through basic validation. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23netns xfrm: fix "ip xfrm state|policy count" misreportAlexey Dobriyan
"ip xfrm state|policy count" report SA/SP count from init_net, not from netns of caller process. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Allow xfrm_user_net_exit to batch efficiently.Eric W. Biederman
xfrm.nlsk is provided by the xfrm_user module and is access via rcu from other parts of the xfrm code. Add xfrm.nlsk_stash a copy of xfrm.nlsk that will never be set to NULL. This allows the synchronize_net and netlink_kernel_release to be deferred until a whole batch of xfrm.nlsk sockets have been set to NULL. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25xfrm: Store aalg in xfrm_state with a user specified truncation lengthMartin Willi
Adding a xfrm_state requires an authentication algorithm specified either as xfrm_algo or as xfrm_algo_auth with a specific truncation length. For compatibility, both attributes are dumped to userspace, and we also accept both attributes, but prefer the new syntax. If no truncation length is specified, or the authentication algorithm is specified using xfrm_algo, the truncation length from the algorithm description in the kernel is used. Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-20Revert "xfrm: For 32/64 compatability wrt. xfrm_usersa_info"David S. Miller
This reverts commit fc8c7dc1b29560c016a67a34ccff32a712b5aa86. As indicated by Jiri Klimes, this won't work. These numbers are not only used the size validation, they are also used to locate attributes sitting after the message. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14xfrm: For 32/64 compatability wrt. xfrm_usersa_infoDavid S. Miller
Reported by Jiri Klimes. Fix suggested by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-14xfrm: join error pathsIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns sysctlsAlexey Dobriyan
Make net.core.xfrm_aevent_etime net.core.xfrm_acq_expires net.core.xfrm_aevent_rseqth net.core.xfrm_larval_drop sysctls per-netns. For that make net_core_path[] global, register it to prevent two /proc/net/core antries and change initcall position -- xfrm_init() is called from fs_initcall, so this one should be fs_initcall at least. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: KM reporting in netnsAlexey Dobriyan
2008-11-25netns xfrm: pass netns with KM notificationsAlexey Dobriyan
SA and SPD flush are executed with NULL SA and SPD respectively, for these cases pass netns explicitly from userspace socket. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: xfrm_user module in netnsAlexey Dobriyan
Grab netns either from netlink socket, state or policy. SA and SPD flush are in init_net for now, this requires little attention, see below. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: per-netns NETLINK_XFRM socketAlexey Dobriyan
Stub senders to init_net's one temporarily. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: policy walking in netnsAlexey Dobriyan
2008-11-25netns xfrm: finding policy in netnsAlexey Dobriyan
Add netns parameter to xfrm_policy_bysel_ctx(), xfrm_policy_byidx(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: policy flushing in netnsAlexey Dobriyan
2008-11-25netns xfrm: state walking in netnsAlexey Dobriyan
2008-11-25netns xfrm: finding states in netnsAlexey Dobriyan
2008-11-25netns xfrm: state lookup in netnsAlexey Dobriyan
2008-11-25netns xfrm: state flush in netnsAlexey Dobriyan
2008-11-25netns xfrm: add struct xfrm_policy::xp_netAlexey Dobriyan
Again, to avoid complications with passing netns when not necessary. Again, ->xp_net is set-once field, once set it never changes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
