path: root/net/xfrm/xfrm_user.c
2008-05-21xfrm_user: Remove zero length key checks.David S. Miller
The crypto layer will determine whether that is valid or not. Suggested by Herbert Xu, based upon a report and patch by Martin Willi. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-28Audit: collect sessionid in netlink messagesEric Paris
Previously I added sessionid output to all audit messages where it was available but we still didn't know the sessionid of the sender of netlink messages. This patch adds that information to netlink messages so we can audit who sent netlink messages. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-22[IPSEC]: Fix catch-22 with algorithm IDs above 31Herbert Xu
As it stands it's impossible to use any authentication algorithms with an ID above 31 portably. It just happens to work on x86 but fails miserably on ppc64. The reason is that we're using a bit mask to check the algorithm ID but the mask is only 32 bits wide. After looking at how this is used in the field, I have concluded that in the long term we should phase out state matching by IDs because this is made superfluous by the reqid feature. For current applications, the best solution IMHO is to allow all algorithms when the bit masks are all ~0. The following patch does exactly that. This bug was identified by IBM when testing on the ppc64 platform using the NULL authentication algorithm which has an ID of 251. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[XFRM]: Compilation warnings in xfrm_user.c.Denis V. Lunev
When CONFIG_SECURITY_NETWORK_XFRM is undefined the following warnings appears: net/xfrm/xfrm_user.c: In function 'xfrm_add_pol_expire': net/xfrm/xfrm_user.c:1576: warning: 'ctx' may be used uninitialized in this function net/xfrm/xfrm_user.c: In function 'xfrm_get_policy': net/xfrm/xfrm_user.c:1340: warning: 'ctx' may be used uninitialized in this function (security_xfrm_policy_alloc is noop for the case). It seems that they are result of the commit 03e1ad7b5d871d4189b1da3125c2f12d1b5f7d0b ("LSM: Make the Labeled IPsec hooks more stack friendly") Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-12LSM: Make the Labeled IPsec hooks more stack friendlyPaul Moore
The xfrm_get_policy() and xfrm_add_pol_expire() put some rather large structs on the stack to work around the LSM API. This patch attempts to fix that problem by changing the LSM API to require only the relevant "security" pointers instead of the entire SPD entry; we do this for all of the security_xfrm_policy*() functions to keep things consistent. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-09[XFRM]: xfrm_user: fix selector family initializationPatrick McHardy
Commit df9dcb45 ([IPSEC]: Fix inter address family IPsec tunnel handling) broke openswan by removing the selector initialization for tunnel mode in case it is uninitialized. This patch restores the initialization, fixing openswan, but probably breaking inter-family tunnels again (unknown since the patch author disappeared). The correct thing for inter-family tunnels is probably to simply initialize the selector family explicitly. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[XFRM]: Speed up xfrm_policy and xfrm_state walkingTimo Teras
Change xfrm_policy and xfrm_state walking algorithm from O(n^2) to O(n). This is achieved adding the entries to one more list which is used solely for walking the entries. This also fixes some races where the dump can have duplicate or missing entries when the SPD/SADB is modified during an ongoing dump. Dumping SADB with 20000 entries using "time ip xfrm state" the sys time dropped from 1.012s to 0.080s. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14[XFRM]: Avoid bogus BUG() when throwing new policy away.YOSHIFUJI Hideaki
From: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> When we destory a new policy entry, we need to tell xfrm_policy_destroy() explicitly that the entry is not alive yet. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPSEC]: Add support for combined mode algorithmsHerbert Xu
This patch adds support for combined mode algorithms with GCM being the first algorithm supported. Combined mode algorithms can be added through the xfrm_user interface using the new algorithm payload type XFRMA_ALG_AEAD. Each algorithms is identified by its name and the ICV length. For the purposes of matching algorithms in xfrm_tmpl structures, combined mode algorithms occupy the same name space as encryption algorithms. This is in line with how they are negotiated using IKE. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Consolidate kernel netlink socket destruction.Denis V. Lunev
Create a specific helper for netlink kernel socket disposal. This just let the code look better and provides a ground for proper disposal inside a namespace. Signed-off-by: Denis V. Lunev <den@openvz.org> Tested-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM] xfrm_policy_destroy: Rename and relative fixes.WANG Cong
Since __xfrm_policy_destroy is used to destory the resources allocated by xfrm_policy_alloc. So using the name __xfrm_policy_destroy is not correspond with xfrm_policy_alloc. Rename it to xfrm_policy_destroy. And along with some instances that call xfrm_policy_alloc but not using xfrm_policy_destroy to destroy the resource, fix them. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Make x->lastused an unsigned longHerbert Xu
Currently x->lastused is u64 which means that it cannot be read/written atomically on all architectures. David Miller observed that the value stored in it is only an unsigned long which is always atomic. So based on his suggestion this patch changes the internal representation from u64 to unsigned long while the user-interface still refers to it as u64. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[XFRM]: xfrm_algo_clone() allocates too much memoryEric Dumazet
alg_key_len is the length in bits of the key, not in bytes. Best way to fix this is to move alg_len() function from net/xfrm/xfrm_user.c to include/net/xfrm.h, and to use it in xfrm_algo_clone() alg_len() is renamed to xfrm_alg_len() because of its global exposition. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-26[IPSEC]: Temporarily remove locks around copying of non-atomic fieldsHerbert Xu
The change 050f009e16f908932070313c1745d09dc69fd62b [IPSEC]: Lock state when copying non-atomic fields to user-space caused a regression. Ingo Molnar reports that it causes a potential dead-lock found by the lock validator as it tries to take x->lock within xfrm_state_lock while numerous other sites take the locks in opposite order. For 2.6.24, the best fix is to simply remove the added locks as that puts us back in the same state as we've been in for years. For later kernels a proper fix would be to reverse the locking order for every xfrm state user such that if x->lock is taken together with xfrm_state_lock then it is to be taken within it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[NET]: make netlink user -> kernel interface synchroniousDenis V. Lunev
This patch make processing netlink user -> kernel messages synchronious. This change was inspired by the talk with Alexey Kuznetsov about current netlink messages processing. He says that he was badly wrong when introduced asynchronious user -> kernel communication. The call netlink_unicast is the only path to send message to the kernel netlink socket. But, unfortunately, it is also used to send data to the user. Before this change the user message has been attached to the socket queue and sk->sk_data_ready was called. The process has been blocked until all pending messages were processed. The bad thing is that this processing may occur in the arbitrary process context. This patch changes nlk->data_ready callback to get 1 skb and force packet processing right in the netlink_unicast. Kernel -> user path in netlink_unicast remains untouched. EINTR processing for in netlink_run_queue was changed. It forces rtnl_lock drop, but the process remains in the cycle until the message will be fully processed. So, there is no need to use this kludges now. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Lock state when copying non-atomic fields to user-spaceHerbert Xu
This patch adds locking so that when we're copying non-atomic fields such as life-time or coaddr to user-space we don't get a partial result. For af_key I've changed every instance of pfkey_xfrm_state2msg apart from expiration notification to include the keys and life-times. This is in-line with XFRM behaviour. The actual cases affected are: * pfkey_getspi: No change as we don't have any keys to copy. * key_notify_sa: + ADD/UPD: This wouldn't work otherwise. + DEL: It can't hurt. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] user: Move attribute copying code into copy_to_user_state_extraHerbert Xu
Here's a good example of code duplication leading to code rot. The notification patch did its own netlink message creation for xfrm states. It duplicated code that was already in dump_one_state. Guess what, the next time (and the time after) when someone updated dump_one_state the notification path got zilch. This patch moves that code from dump_one_state to copy_to_user_state_extra and uses it in xfrm_notify_sa too. Unfortunately whoever updates this still needs to update xfrm_sa_len since the notification path wants to know the exact size for allocation. At least I've added a comment saying so and if someone still forgest, we'll have a WARN_ON telling us so. I also changed the security size calculation to use xfrm_user_sec_ctx since that's what we actually put into the skb. However it makes no practical difference since it has the same size as xfrm_sec_ctx. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common code into xfrm_alloc_spiHerbert Xu
This patch moves some common code that conceptually belongs to the xfrm core from af_key/xfrm_user into xfrm_alloc_spi. In particular, the spin lock on the state is now taken inside xfrm_alloc_spi. Previously it also protected the construction of the response PF_KEY/XFRM messages to user-space. This is inconsistent as other identical constructions are not protected by the state lock. This is bad because they in fact should be protected but only in certain spots (so as not to hold the lock for too long which may cause packet drops). The SPI byte order conversion has also been moved. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETLINK]: Avoid pointer in netlink_run_queueHerbert Xu
I was looking at Patrick's fix to inet_diag and it occured to me that we're using a pointer argument to return values unnecessarily in netlink_run_queue. Changing it to return the value will allow the compiler to generate better code since the value won't have to be memory-backed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Support multiple network namespaces with netlinkEric W. Biederman
Each netlink socket will live in exactly one network namespace, this includes the controlling kernel sockets. This patch updates all of the existing netlink protocols to only support the initial network namespace. Request by clients in other namespaces will get -ECONREFUSED. As they would if the kernel did not have the support for that netlink protocol compiled in. As each netlink protocol is updated to be multiple network namespace safe it can register multiple kernel sockets to acquire a presence in the rest of the network namespaces. The implementation in af_netlink is a simple filter implementation at hash table insertion and hash table look up time. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM]: xfrm audit callsJoy Latten
This patch modifies the current ipsec audit layer by breaking it up into purpose driven audit calls. So far, the only audit calls made are when add/delete an SA/policy. It had been discussed to give each key manager it's own calls to do this, but I found there to be much redundnacy since they did the exact same things, except for how they got auid and sid, so I combined them. The below audit calls can be made by any key manager. Hopefully, this is ok. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Inline attach_encap_tmpl(), attach_sec_ctx(), and ↵Thomas Graf
attach_one_addr() These functions are only used once and are a lot easier to understand if inlined directly into the function. Fixes by Masahide NAKAMURA. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Remove dependency on rtnetlinkThomas Graf
2007-10-10[XFRM] netlink: Use nlattr instead of rtattrThomas Graf
2007-10-10[XFRM] netlink: Rename attribute array from xfrma[] to attrs[]Thomas Graf
Increases readability a lot. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Enhance indexing of the attribute arrayThomas Graf
nlmsg_parse() puts attributes at array[type] so the indexing method can be simpilfied by removing the obscuring "- 1". Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Establish an attribute policyThomas Graf
Adds a policy defining the minimal payload lengths for all the attributes allowing for most attribute validation checks to be removed from in the middle of the code path. Makes updates more consistent as many format errors are recognised earlier, before any changes have been attempted. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_parse() to parse attributesThomas Graf
Uses nlmsg_parse() to parse the attributes. This actually changes behaviour as unknown attributes (type > MAXTYPE) no longer cause an error. Instead unknown attributes will be ignored henceforth to keep older kernels compatible with more recent userspace tools. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_new() and type-safe size calculation helpersThomas Graf
Moves all complex message size calculation into own inlined helper functions and makes use of the type-safe netlink interface. Using nlmsg_new() simplifies the calculation itself as it takes care of the netlink header length by itself. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Clear up some of the CONFIG_XFRM_SUB_POLICY ifdef messThomas Graf
Moves all of the SUB_POLICY ifdefs related to the attribute size calculation into a function. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Move algorithm length calculation to its own functionThomas Graf
Adds alg_len() to calculate the properly padded length of an algorithm attribute to simplify the code. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nla_put()/NLA_PUT() variantesThomas Graf
Also makes use of copy_sec_ctx() in another place and removes duplicated code. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_broadcast() and nlmsg_unicast()Thomas Graf
This simplifies successful return codes from >0 to 0. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_data() instead of NLMSG_DATA()Thomas Graf
2007-10-10[XFRM] netlink: Use nlmsg_end() and nlmsg_cancel()Thomas Graf
2007-10-10[XFRM] netlink: Use nlmsg_put() instead of NLMSG_PUT()Thomas Graf
2007-07-31[IPSEC]: Ensure that state inner family is setHerbert Xu
Similar to the issue we had with template families which specified the inner families of policies, we need to set the inner families of states as the main xfrm user Openswan leaves it as zero. af_key is unaffected because the inner family is set by it and not the KM. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07xfrm: Add security check before flushing SAD/SPDJoy Latten
Currently we check for permission before deleting entries from SAD and SPD, (see security_xfrm_policy_delete() security_xfrm_state_delete()) However we are not checking for authorization when flushing the SPD and the SAD completely. It was perhaps missed in the original security hooks patch. This patch adds a security check when flushing entries from the SAD and SPD. It runs the entire database and checks each entry for a denial. If the process attempting the flush is unable to remove all of the entries a denial is logged the the flush function returns an error without removing anything. This is particularly useful when a process may need to create or delete its own xfrm entries used for things like labeled networking but that same process should not be able to delete other entries or flush the entire database. Signed-off-by: Joy Latten<latten@austin.ibm.com> Signed-off-by: Eric Paris <eparis@parisplace.org> Signed-off-by: James Morris <jmorris@namei.org>
2007-05-04[XFRM] SPD info TLV aggregationJamal Hadi Salim
Aggregate the SPD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[XFRM] SAD info TLV aggregationxJamal Hadi Salim
Aggregate the SAD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[XFRM]: Export SPD infoJamal Hadi Salim
With this patch you can use iproute2 in user space to efficiently see how many policies exist in different directions. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[XFRM]: Missing bits to SAD info.Jamal Hadi Salim
This brings the SAD info in sync with net-2.6.22/net-2.6 Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[XFRM]: Export SAD info.Jamal Hadi Salim
On a system with a lot of SAs, counting SAD entries chews useful CPU time since you need to dump the whole SAD to user space; i.e something like ip xfrm state ls | grep -i src | wc -l I have seen taking literally minutes on a 40K SAs when the system is swapping. With this patch, some of the SAD info (that was already being tracked) is exposed to user space. i.e you do: ip xfrm state count And you get the count; you can also pass -s to the command line and get the hash info. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Switch cb_lock spinlock to mutex and allow to override itPatrick McHardy
Switch cb_lock to mutex and allow netlink kernel users to override it with a subsystem specific mutex for consistent locking in dump callbacks. All netlink_dump_start users have been audited not to rely on any side-effects of the previously used spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Directly return -EINTR from netlink_dump_start()Thomas Graf
Now that all users of netlink_dump_start() use netlink_run_queue() to process the receive queue, it is possible to return -EINTR from netlink_dump_start() directly, therefore simplying the callers. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Remove error pointer from netlink message handlerThomas Graf
The error pointer argument in netlink message handlers is used to signal the special case where processing has to be interrupted because a dump was started but no error happened. Instead it is simpler and more clear to return -EINTR and have netlink_run_queue() deal with getting the queue right. nfnetlink passed on this error pointer to its subsystem handlers but only uses it to signal the start of a netlink dump. Therefore it can be removed there as well. This patch also cleans up the error handling in the affected message handlers to be consistent since it had to be touched anyway. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
