path: root/net/xfrm
2010-07-14xfrm: do not assume that template resolving always returns xfrmsTimo Teräs
xfrm_resolve_and_create_bundle() assumed that, if policies indicated presence of xfrms, bundle template resolution would always return some xfrms. This is not true for 'use' level policies which can result in no xfrm's being applied if there is no suitable xfrm states. This fixes a crash by this incorrect assumption. Reported-by: George Spelvin <linux@horizon.com> Bisected-by: George Spelvin <linux@horizon.com> Tested-by: George Spelvin <linux@horizon.com> Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24xfrm: check bundle policy existance before dereferencing itTimo Teräs
Fix the bundle validation code to not assume having a valid policy. When we have multiple transformations for a xfrm policy, the bundle instance will be a chain of bundles with only the first one having the policy reference. When policy_genid is bumped it will expire the first bundle in the chain which is equivalent of expiring the whole chain. Reported-bisected-and-tested-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04net: check for refcount if pop a stacked dst_entrySteffen Klassert
xfrm triggers a warning if dst_pop() drops a refcount on a noref dst. This patch changes dst_pop() to skb_dst_pop(). skb_dst_pop() drops the refcnt only on a refcounted dst. Also we don't clone the child dst_entry, so it is not refcounted and we can use skb_dst_set_noref() in xfrm_output_one(). Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02xfrm: force a dst reference in __xfrm_route_forward()Eric Dumazet
Packets going through __xfrm_route_forward() have a not refcounted dst entry, since we enabled a noref forwarding path. xfrm_lookup() might incorrectly release this dst entry. It's a bit late to make invasive changes in xfrm_lookup(), so lets force a refcount in this path. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17xfrm: add severity to printkstephen hemminger
Serious oh sh*t messages converted to WARN(). Add KERN_NOTICE severity to the unknown policy type messages. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary semicolons after switch statementsJoe Perches
Also added an explicit break; to avoid a fallthrough in net/ipv4/tcp_input.c Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15xfrm: fix policy unreferencing on larval dropTimo Teras
I mistakenly had the error path to use num_pols to decide how many policies we need to drop (cruft from earlier patch set version which did not handle socket policies right). This is wrong since normally we do not keep explicit references (instead we hold reference to the cache entry which holds references to policies). drop_pols is set to num_pols if we are holding the references, so use that. Otherwise we eventually BUG_ON inside xfrm_policy_destroy due to premature policy deletion. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30xfrm: potential uninitialized variable num_xfrmsChangli Gao
potential uninitialized variable num_xfrms fix compiler warning: 'num_xfrms' may be used uninitialized in this function. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/xfrm/xfrm_policy.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: Fix various endianness glitchesEric Dumazet
Sparse can help us find endianness bugs, but we need to make some cleanups to be able to more easily spot real bugs. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-07xfrm: remove policy garbage collectionTimo Teräs
Policies are now properly reference counted and destroyed from all code paths. The delayed gc is just an overhead now and can be removed. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07xfrm: cache bundles instead of policies for outgoing flowsTimo Teräs
__xfrm_lookup() is called for each packet transmitted out of system. The xfrm_find_bundle() does a linear search which can kill system performance depending on how many bundles are required per policy. This modifies __xfrm_lookup() to store bundles directly in the flow cache. If we did not get a hit, we just create a new bundle instead of doing slow search. This means that we can now get multiple xfrm_dst's for same flow (on per-cpu basis). Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07flow: virtualize flow cache entry methodsTimo Teräs
This allows to validate the cached object before returning it. It also allows to destruct object properly, if the last reference was held in flow cache. This is also a prepartion for caching bundles in the flow cache. In return for virtualizing the methods, we save on: - not having to regenerate the whole flow cache on policy removal: each flow matching a killed policy gets refreshed as the getter function notices it smartly. - we do not have to call flow_cache_flush from policy gc, since the flow cache now properly deletes the object if it had any references Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01xfrm: remove policy lock when accessing policy->walk.deadTimo Teräs
All of the code considers ->dead as a hint that the cached policy needs to get refreshed. The read side can just drop the read lock without any side effects. The write side needs to make sure that it's written only exactly once. Only possible race is at xfrm_policy_kill(). This is fixed by checking result of __xfrm_policy_unlink() when needed. It will always succeed if the policy object is looked up from the hash list (so some checks are removed), but it needs to be checked if we are trying to unlink policy via a reference (appropriate checks added). Since policy->walk.dead is written exactly once, it no longer needs to be protected with a write lock. Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01xfrm_user: verify policy direction at XFRM_MSG_POLEXPIRE handlerTimo Teräs
Add missing check for policy direction verification. This is especially important since without this xfrm_user may end up deleting per-socket policy which is not allowed. Signed-off-by: Timo Teras <timo.teras@iki.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01xfrm: Remove xfrm_state_genidHerbert Xu
The xfrm state genid only needs to be matched against the copy saved in xfrm_dst. So we don't need a global genid at all. In fact, we don't even need to initialise it. Based on observation by Timo Teräs. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03ipsec: Fix bogus bundle flowiHerbert Xu
When I merged the bundle creation code, I introduced a bogus flowi value in the bundle. Instead of getting from the caller, it was instead set to the flow in the route object, which is totally different. The end result is that the bundles we created never match, and we instead end up with an ever growing bundle list. Thanks to Jamal for find this problem. Reported-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/firmware/iscsi_ibft.c
2010-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits) crypto: aes_generic - Fix checkpatch errors crypto: fcrypt - Fix checkpatch errors crypto: ecb - Fix checkpatch errors crypto: des_generic - Fix checkpatch errors crypto: deflate - Fix checkpatch errors crypto: crypto_null - Fix checkpatch errors crypto: cipher - Fix checkpatch errors crypto: crc32 - Fix checkpatch errors crypto: compress - Fix checkpatch errors crypto: cast6 - Fix checkpatch errors crypto: cast5 - Fix checkpatch errors crypto: camellia - Fix checkpatch errors crypto: authenc - Fix checkpatch errors crypto: api - Fix checkpatch errors crypto: anubis - Fix checkpatch errors crypto: algapi - Fix checkpatch errors crypto: blowfish - Fix checkpatch errors crypto: aead - Fix checkpatch errors crypto: ablkcipher - Fix checkpatch errors crypto: pcrypt - call the complete function on error ...
2010-02-23xfrm: clone mark when cloning policyJamal Hadi Salim
When we clone the SP, we should also clone the mark. Useful for socket based SPs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: Allow user space manipulation of SPD markJamal Hadi Salim
Add ability for netlink userspace to manipulate the SPD and manipulate the mark, retrieve it and get events with a defined mark, etc. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: Allow user space config of SAD markJamal Hadi Salim
Add ability for netlink userspace to manipulate the SAD and manipulate the mark, retrieve it and get events with a defined mark. MIGRATE may be added later. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SP lookups with markJamal Hadi Salim
Allow mark to be used when doing SP lookup Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SP lookups signature with markJamal Hadi Salim
pass mark to all SP lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SA lookups with markJamal Hadi Salim
Allow mark to be added to the SA lookup Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SA lookups signature with markJamal Hadi Salim
pass mark to all SA lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19xfrm: Flushing empty SPD generates false eventsJamal Hadi Salim
To see the effect make sure you have an empty SPD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm policy flush" You get prompt back in window2 and you see the flush event on window1. With this fix, you still get prompt on window1 but no event on window2. Thanks to Alexey Dobriyan for finding a bug in earlier version when using pfkey to do the flushing. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-19xfrm: Flushing empty SAD generates false eventsJamal Hadi Salim
To see the effect make sure you have an empty SAD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm state flush" You get prompt back in window2 and you see the flush event on window1. With this fix, you still get prompt on window1 but no event on window2. Thanks to Alexey Dobriyan for finding a bug in earlier version when using pfkey to do the flushing. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18xfrm: Introduce LINUX_MIB_XFRMFWDHDRERRORjamal
XFRMINHDRERROR counter is ambigous when validating forwarding path. It makes it tricky to debug when you have both in and fwd validation. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17xfrm: Revert false event eliding commits.David S. Miller
As reported by Alexey Dobriyan: -------------------- setkey now takes several seconds to run this simple script and it spits "recv: Resource temporarily unavailable" messages. #!/usr/sbin/setkey -f flush; spdflush; add A B ipcomp 44 -m tunnel -C deflate; add B A ipcomp 45 -m tunnel -C deflate; spdadd A B any -P in ipsec ipcomp/tunnel/192.168.1.2-192.168.1.3/use; spdadd B A any -P out ipsec ipcomp/tunnel/192.168.1.3-192.168.1.2/use; -------------------- Obviously applications want the events even when the table is empty. So we cannot make this behavioral change. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16Merge branch 'master' of ↵David S. Miller
2010-02-16xfrm: avoid spinlock in get_acqseq() used by xfrm userjamal
Eric's version fixed it for pfkey. This one is for xfrm user. I thought about amortizing those two get_acqseq()s but it seems reasonable to have two of these sequence spaces for the two different interfaces. cheers, jamal commit d5168d5addbc999c94aacda8f28a4a173756a72b Author: Jamal Hadi Salim <hadi@cyberus.ca> Date: Tue Feb 16 06:51:22 2010 -0500 xfrm: avoid spinlock in get_acqseq() used by xfrm user This is in the same spirit as commit 28aecb9d7728dc26bf03ce7925fe622023a83a2a by Eric Dumazet. Use atomic_inc_return() in get_acqseq() to avoid taking a spinlock Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16xfrm: Fix xfrm_state_clone leakHerbert Xu
xfrm_state_clone calls kfree instead of xfrm_state_put to free a failed state. Depending on the state of the failed state, it can cause leaks to things like module references. All states should be freed by xfrm_state_put past the point of xfrm_init_state. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15xfrm: Flushing empty SPD generates false eventsjamal
Observed similar behavior on SPD as previouly seen on SAD flushing.. This fixes it. cheers, jamal commit 428b20432dc31bc2e01a94cd451cf5a2c00d2bf4 Author: Jamal Hadi Salim <hadi@cyberus.ca> Date: Thu Feb 11 05:49:38 2010 -0500 xfrm: Flushing empty SPD generates false events To see the effect make sure you have an empty SPD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm policy flush" You get prompt back in window1 and you see the flush event on window2. With this fix, you still get prompt on window1 but no event on window2. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15xfrm: Flushing empty SAD generates false eventsjamal
To see the effect make sure you have an empty SAD. -On window1 "ip xfrm mon" -on window2 issue "ip xfrm state flush" You get prompt back in window1 and you see the flush event on window2. With this fix, you still get prompt on window1 but no event on window2. I was tempted to return -ESRCH on window1 (which would show "RTNETLINK answers: No such process") but didnt want to change current behavior. cheers, jamal commit 5f3dd4a772326166e1bcf54acc2391df00dc7ab5 Author: Jamal Hadi Salim <hadi@cyberus.ca> Date: Thu Feb 11 04:41:36 2010 -0500 xfrm: Flushing empty SAD generates false events To see the effect make sure you have an empty SAD. On window1 "ip xfrm mon" and on window2 issue "ip xfrm state flush" You get prompt back in window1 and you see the flush event on window2. With this fix, you still get prompt on window1 but no event on window2. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12xfrm: validate attributesjamal
Some XFRM attributes were not going through basic validation. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28Merge branch 'master' of ↵David S. Miller
2010-01-24netns xfrm: deal with dst entries in netnsAlexey Dobriyan
GC is non-existent in netns, so after you hit GC threshold, no new dst entries will be created until someone triggers cleanup in init_net. Make xfrm4_dst_ops and xfrm6_dst_ops per-netns. This is not done in a generic way, because it woule waste (AF_MAX - 2) * sizeof(struct dst_ops) bytes per-netns. Reorder GC threshold initialization so it'd be done before registering XFRM policies. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23netns xfrm: fix "ip xfrm state|policy count" misreportAlexey Dobriyan
"ip xfrm state|policy count" report SA/SP count from init_net, not from netns of caller process. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23net: constify MIB name tablesAlexey Dobriyan
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17crypto: gcm - Add RFC4543 wrapper for GCMTobias Brunner
This patch adds the RFC4543 (GMAC) wrapper for GCM similar to the existing RFC4106 wrapper. The main differences between GCM and GMAC are the contents of the AAD and that the plaintext is empty for the latter. Signed-off-by: Tobias Brunner <tobias@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-26NET: XFRM: Fix spelling of neighbour.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> net/xfrm/xfrm_policy.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-03net: Allow xfrm_user_net_exit to batch efficiently.Eric W. Biederman
xfrm.nlsk is provided by the xfrm_user module and is access via rcu from other parts of the xfrm code. Add xfrm.nlsk_stash a copy of xfrm.nlsk that will never be set to NULL. This allows the synchronize_net and netlink_kernel_release to be deferred until a whole batch of xfrm.nlsk sockets have been set to NULL. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/ht.c
2009-12-01ipsec: can not add camellia cipher algorithm when using "ip xfrm state" commandLi Yewang
can not add camellia cipher algorithm when using "ip xfrm state" command. Signed-off-by: Li Yewang <lyw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
