[ Upstream commit: f398035f2dec0a6150833b0bc105057953594edb ]
The aalgos/ealgos fields are only 32 bits wide. However, af_key tries
to test them with the expression 1 << id where id can be as large as
253. This produces different behaviour on different architectures.
The following patch explicitly checks whether ID is greater than 31
and fails the check if that's the case.
We cannot easily extend the mask to be longer than 32 bits due to
exposure to user-space. Besides, this whole interface is obsolete
anyway in favour of the xfrm_user interface which doesn't use this
bit mask in templates (well not within the kernel anyway).
Signed-off-by: Adrian Bunk <bunk@kernel.org>
[ Upstream commit: 9e8d6f8959c356d8294d45f11231331c3e1bcae6 ]
easy to trigger as user with sfuzz.
irda_create() is quiet on unknown sock->type,
match this behaviour for SOCK_DGRAM unknown protocol
Signed-off-by: Maximilian Attems <max@stro.at>
[ Upstream commit: 44344b2a85f03326c7047a8c861b0c625c674839 ]
When re-naming an interface, the previous secondary address
labels get lost e.g.
$> brctl addbr foo
$> ip addr add 192.168.0.1 dev foo
$> ip addr add 192.168.0.2 dev foo label foo:00
$> ip addr show dev foo | grep inet
inet 192.168.0.1/32 scope global foo
inet 192.168.0.2/32 scope global foo:00
$> ip link set foo name bar
$> ip addr show dev bar | grep inet
inet 192.168.0.1/32 scope global bar
inet 192.168.0.2/32 scope global bar:2
Turns out to be a simple thinko in inetdev_changename() - clearly we
want to look at the address label, rather than the device name, for
a suffix to retain.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
[ Upstream commit: f844c74fe07321953e2dd227fe35280075f18f60 ]
We currently check that iph->ihl is bounded by the real length and that
the real length is greater than the minimum IP header length. However,
we did not check the caes where iph->ihl is less than the minimum IP
header length.
This breaks because some ip_fast_csum implementations assume that which
is quite reasonable.
[ Upstream commit: d31c7b8fa303eb81311f27b80595b8d2cbeef950 ]
Avaid provided test application, so bug got fixed.
IPv6 addrconf removes ipv6 inner device from netdev each time cmu
changes and new value is less than IPV6_MIN_MTU (1280 bytes).
When mtu is changed and new value is greater than IPV6_MIN_MTU,
it does not add ipv6 addresses and inner device bac.
This patch fixes that.
Tested with Avaid's application, which works ok now.
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
[ Upstream commit: 435000bebd94aae3a7a50078d142d11683d3b193 ]
Kernel needs to respond to an SADB_GET with the same message type to
conform to the RFC 2367 Section 3.1.5
The #ifdef's in arp_process() were not only a mess, they were also wrong
in the CONFIG_NET_ETHERNET=n and (CONFIG_NETDEV_1000=y or
CONFIG_NETDEV_10000=y) cases.
Since they are not required this patch removes them.
Also removed are some #ifdef's around #include's that caused compile
errors after this change.
[ Upstream commit: c3d8d1e30cace31fed6186a4b8c6b1401836d89c ]
Commit ed6dcf4a in the history.git tree broke netlink_unicast timeouts
by moving the schedule_timeout() call to a new function that doesn't
propagate the remaining timeout back to the caller. This means on each
retry we start with the full timeout again.
ipc/mqueue.c seems to actually want to wait indefinitely so this
behaviour is retained.
While trying to implement u32 hashes in my shaping machine I ran into
a possible bug in the u32 hash/bucket computing algorithm
(net/sched/cls_u32.c).
The problem occurs only with hash masks that extend over the octet
boundary, on little endian machines (where htonl() actually does
something).
Let's say that I would like to use 0x3fc0 as the hash mask. This means
8 contiguous "1" bits starting at b6. With such a mask, the expected
(and logical) behavior is to hash any address in, for instance,
192.168.0.0/26 in bucket 0, then any address in 192.168.0.64/26 in
bucket 1, then 192.168.0.128/26 in bucket 2 and so on.
This is exactly what would happen on a big endian machine, but on
little endian machines, what would actually happen with current
implementation is 0x3fc0 being reversed (into 0xc03f0000) by htonl()
in the userspace tool and then applied to 192.168.x.x in the u32
classifier. When shifting right by 16 bits (rank of first "1" bit in
the reversed mask) and applying the divisor mask (0xff for divisor
256), what would actually remain is 0x3f applied on the "168" octet of
the address.
One could say is this can be easily worked around by taking endianness
into account in userspace and supplying an appropriate mask (0xfc03)
that would be turned into contiguous "1" bits when reversed
(0x03fc0000). But the actual problem is the network address (inside
the packet) not being converted to host order, but used as a
host-order value when computing the bucket.
Let's say the network address is written as n31 n30 ... n0, with n0
being the least significant bit. When used directly (without any
conversion) on a little endian machine, it becomes n7 ... n0 n8 ..n15
etc in the machine's registers. Thus bits n7 and n8 would no longer be
adjacent and 192.168.64.0/26 and 192.168.128.0/26 would no longer be
consecutive.
The fix is to apply ntohl() on the hmask before computing fshift,
and in u32_hash_fold() convert the packet data to host order before
shifting down by fshift.
With helpful feedback from Jamal Hadi Salim and Jarek Poplawski.
[ Upstream commit: 4f9f8311a08c0d95c70261264a2b47f2ae99683a ]
tecl_reset() is called from deactivate and qdisc is set to noop already,
but subsequent teql_xmit does not know about it and dereference private
data as teql qdisc and thus oopses.
not catch it first :)
netlink_run_queue() doesn't handle multiple processes processing the
queue concurrently. Serialize queue processing in inet_diag to fix
a oops in netlink_rcv_skb caused by netlink_run_queue passing a
NULL for the skb.
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000054
[349587.500454] printing eip:
[349587.500457] c03318ae
[349587.500459] *pde = 00000000
[349587.500464] Oops: 0000 [#1]
[349587.500466] PREEMPT SMP
[349587.500474] Modules linked in: w83627hf hwmon_vid i2c_isa
[349587.500483] CPU: 0
[349587.500485] EIP: 0060:[<c03318ae>] Not tainted VLI
[349587.500487] EFLAGS: 00010246 (2.6.22.3 #1)
[349587.500499] EIP is at netlink_rcv_skb+0xa/0x7e
[349587.500506] eax: 00000000 ebx: 00000000 ecx: c148d2a0 edx: c0398819
[349587.500510] esi: 00000000 edi: c0398819 ebp: c7a21c8c esp: c7a21c80
[349587.500517] ds: 007b es: 007b fs: 00d8 gs: 0033 ss: 0068
[349587.500521] Process oidentd (pid: 17943, ti=c7a20000 task=cee231c0 task.ti=c7a20000)
[349587.500527] Stack: 00000000 c7a21cac f7c8ba78 c7a21ca4 c0331962 c0398819 f7c8ba00 0000004c
[349587.500542] f736f000 c7a21cb4 c03988e3 00000001 f7c8ba00 c7a21cc4 c03312a5 0000004c
[349587.500558] f7c8ba00 c7a21cd4 c0330681 f7c8ba00 e4695280 c7a21d00 c03307c6 7fffffff
[349587.500578] Call Trace:
[349587.500581] [<c010361a>] show_trace_log_lvl+0x1c/0x33
[349587.500591] [<c01036d4>] show_stack_log_lvl+0x8d/0xaa
[349587.500595] [<c010390e>] show_registers+0x1cb/0x321
[349587.500604] [<c0103bff>] die+0x112/0x1e1
[349587.500607] [<c01132d2>] do_page_fault+0x229/0x565
[349587.500618] [<c03c8d3a>] error_code+0x72/0x78
[349587.500625] [<c0331962>] netlink_run_queue+0x40/0x76
[349587.500632] [<c03988e3>] inet_diag_rcv+0x1f/0x2c
[349587.500639] [<c03312a5>] netlink_data_ready+0x57/0x59
[349587.500643] [<c0330681>] netlink_sendskb+0x24/0x45
[349587.500651] [<c03307c6>] netlink_unicast+0x100/0x116
[349587.500656] [<c0330f83>] netlink_sendmsg+0x1c2/0x280
[349587.500664] [<c02fcce9>] sock_sendmsg+0xba/0xd5
[349587.500671] [<c02fe4d1>] sys_sendmsg+0x17b/0x1e8
[349587.500676] [<c02fe92d>] sys_socketcall+0x230/0x24d
[349587.500684] [<c01028d2>] syscall_call+0x7/0xb
[349587.500691] =======================
[349587.500693] Code: f0 ff 4e 18 0f 94 c0 84 c0 0f 84 66 ff ff ff 89 f0 e8 86 e2 fc ff e9 5a ff ff ff f0 ff 40 10 eb be 55 89 e5 57 89 d7 56 89 c6 53 <8b> 50 54 83 fa 10 72 55 8b 9e 9c 00 00 00 31 c9 8b 03 83 f8 0f
Reported by Athanasius <link@miggy.org>
Adrian Bunk:
Backported to 2.6.16 based on a suggestion by David S. Miller.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
The snap_rcv code reads 5 bytes so we should make sure that
we have 5 bytes in the head before proceeding.
Based on diagnosis and fix by Evgeniy Polyakov, reported by
Alan J. Wylie.
Patch also kills the skb->sk assignment before kfree_skb
since it's redundant.
-Fixes ABBA deadlock noted by Patrick McHardy <kaber@trash.net>:
> There is at least one ABBA deadlock, est_timer() does:
> read_lock(&est_lock)
> spin_lock(e->stats_lock) (which is dev->queue_lock)
> and qdisc_destroy calls htb_destroy under dev->queue_lock, which
> calls htb_destroy_class, then gen_kill_estimator and this
> write_locks est_lock.
To fix the ABBA deadlock the rate estimators are now kept on an rcu list.
-The est_lock changes the use from protecting the list to protecting
the update to the 'bstat' pointer in order to avoid NULL dereferencing.
-The 'interval' member of the gen_estimator structure removed as it is
not needed.
Signed-off-by: Ranko Zivojnovic <ranko@spidernet.net>
Currently when icmp_errors_use_inbound_ifaddr is set and an ICMP error is
sent after the packet passed through ip_output(), an address from the
outgoing interface is chosen as ICMP source address since skb->dev doesn't
point to the incoming interface anymore.
Fix this by doing an interface lookup on rt->dst.iif and using that device.
Reported by Chris Evans <scarybeasts@gmail.com>:
> The summary is that an evil 80211 frame can crash out a victim's
> machine. It only applies to drivers using the 80211 wireless code, and
> only then to certain drivers (and even then depends on a card's
> firmware not dropping a dubious packet). I must confess I'm not
> keeping track of Linux wireless support, and the different protocol
> stacks etc.
> Details are as follows:
> ieee80211_rx() does not explicitly check that "skb->len >= hdrlen".
> There are other skb->len checks, but not enough to prevent a subtle
> off-by-two error if the frame has the IEEE80211_STYPE_QOS_DATA flag
> set.
> This leads to integer underflow and crash here:
> if (frag != 0)
> flen -= hdrlen;
> (flen is subsequently used as a memcpy length parameter).
How about this?
When only GSO skb was partially ACKed, no hints are reset,
therefore fastpath_cnt_hint must be tweaked too or else it can
corrupt fackets_out. The corruption to occur, one must have
non-trivial ACK/SACK sequence, so this bug is not very often
that harmful. There's a fackets_out state reset in TCP because
fackets_out is known to be inaccurate and that fixes the issue
eventually anyway.
In case there was also at least one skb that got fully ACKed,
the fastpath_skb_hint is set to NULL which causes a recount for
fastpath_cnt_hint (the old value won't be accessed anymore),
thus it can safely be decremented without additional checking.
Reported by Cedric Le Goater <clg@fr.ibm.com>
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
This fixes kernel bugzilla #5731
It should generate an empty packet for datagram protocols when the
socket is connected, for one.
The check is doubly-wrong because all that a write() can be is a
sendmsg() call with a NULL msg_control and a single entry iovec. No
special semantics should be assigned to it, therefore the zero length
check should be removed entirely.
This matches the behavior of BSD and several other systems.
Alan Cox notes that SuSv3 says the behavior of a zero length write on
non-files is "unspecified", but that's kind of useless since BSD has
defined this behavior for a quarter century and BSD is essentially
what application folks code to.
Based upon a patch from Stephen Hemminger.
Adrian Bunk:
Backported to 2.6.16.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This reverts commit 3198d0f16dec0c87071cf26f3f11af9c8f0a009b.
Static functions mustn't be exported.
A static function mustn't be exported.
In testing our ESP/AH offload hardware, I discovered an issue with how
AH handles mutable fields in IPv4. RFC 4302 (AH) states the following
on the subject:
For IPv4, the entire option is viewed as a unit; so even
though the type and length fields within most options are immutable
in transit, if an option is classified as mutable, the entire option
is zeroed for ICV computation purposes.
The current implementation does not zero the type and length fields,
resulting in authentication failures when communicating with hosts
that do (i.e. FreeBSD).
I have tested record route and timestamp options (ping -R and ping -T)
on a small network involving Windows XP, FreeBSD 6.2, and Linux hosts,
with one router. In the presence of these options, the FreeBSD and
Linux hosts (with the patch or with the hardware) can communicate.
The Windows XP host simply fails to accept these packets with or
without the patch.
I have also been trying to test source routing options (using
traceroute -g), but haven't had much luck getting this option to work
*without* AH, let alone with.
Signed-off-by: Nick Bowler <nbowler@ellipticsemi.com>
It's possible that new SACK blocks that should trigger new LOST
markings arrive with new data (which previously made is_dupack
false). In addition, I think this fixes a case where we get
a cumulative ACK with enough SACK blocks to trigger the fast
recovery (is_dupack would be false there too).
I'm not completely pleased with this solution because readability
of the code is somewhat questionable as 'is_dupack' in SACK case
is no longer about dupacks only but would mean something like
'lost_marker_work_todo' too... But because of Eifel stuff done
in CA_Recovery, the FLAG_DATA_SACKED check cannot be placed to
the if statement which seems attractive solution. Nevertheless,
I didn't like adding another variable just for that either... :-)
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=8747
Problem Description:
It is related to the possibility to obtain MSG_ERRQUEUE messages from the udp
and raw sockets, both connected and unconnected.
There is a little typo in net/ipv6/icmp.c code, which prevents such messages
to be delivered to the errqueue of the correspond raw socket, when the socket
is CONNECTED. The typo is due to swap of local/remote addresses.
Consider __raw_v6_lookup() function from net/ipv6/raw.c. When a raw socket is
looked up usual way, it is something like:
sk = __raw_v6_lookup(sk, nexthdr, daddr, saddr, IP6CB(skb)->iif);
where "daddr" is a destination address of the incoming packet (IOW our local
address), "saddr" is a source address of the incoming packet (the remote end).
But when the raw socket is looked up for some icmp error report, in
net/ipv6/icmp.c:icmpv6_notify() , daddr/saddr are obtained from the echoed
fragment of the "bad" packet, i.e. "daddr" is the original destination
address of that packet, "saddr" is our local address. Hence, for
icmpv6_notify() must use "saddr, daddr" in its arguments, not "daddr, saddr"
Steps to reproduce:
Create some raw socket, connect it to an address, and cause some error
situation: f.e. set ttl=1 where the remote address is more than 1 hop to reach.
Set IPV6_RECVERR .
Then send something and wait for the error (f.e. poll() with POLLERR|POLLIN).
You should receive "time exceeded" icmp message (because of "ttl=1"), but the
socket do not receive it.
If you do not connect your raw socket, you will receive MSG_ERRQUEUE
successfully. (The reason is that for unconnected socket there are no actual
checks for local/remote addresses).
As noticed by Jarek Poplawski <jarkao2@o2.pl>, the timer removal in
gen_kill_estimator races with the timer function rearming the timer.
Check whether the timer list is empty before rearming the timer
in the timer function to fix this.
Acked-by: Jarek Poplawski <jarkao2@o2.pl>
SCTP currently permits users to bind to link-local addresses,
but doesn't verify that the scope id specified at bind matches
the interface that the address is configured on. It was report
that this can hang a system.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
skb_clone_fraglist is static so it shouldn't be exported.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
The conntrack assigned to locally generated ICMP error is usually the one
assigned to the original packet which has caused the error. But if
the original packet is handled as invalid by nf_conntrack, no conntrack
is assigned to the original packet. Then nf_ct_attach() cannot assign
any conntrack to the ICMP error packet. In that case the current
nf_conntrack_icmp assigns appropriate conntrack to it. But the current
code mistakes the direction of the packet. As a result, NAT code mistakes
the address to be mangled.
To fix the bug, this changes nf_conntrack_icmp not to assign conntrack
to such ICMP error. Actually no address is necessary to be mangled
in this case.
Spotted by Jordan Russell.
Upstream commit ID: 130e7a83d7ec8c5c673225e0fa8ea37b1ed507a5
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
This diff changes the default port range used for outgoing connections,
from "use 32768-61000 in most cases, but use N-4999 on small boxes
(where N is a multiple of 1024, depending on just *how* small the box
is)" to just "use 32768-61000 in all cases".
I don't believe there are any drawbacks to this change, and it keeps
outgoing connection ports farther away from the mess of
IANA-registered ports.
Signed-off-by: Mark Glines <mark@glines.org>
sys_setsockopt() do not check properly timeout values for
SO_RCVTIMEO/SO_SNDTIMEO, for example it's possible to set negative timeout
values. POSIX do not defines behaviour for sys_setsockopt in case negative
timeouts, but requires that setsockopt() shall fail with -EDOM if the send and
receive timeout values are too big to fit into the timeout fields in the socket
structure.
In current implementation negative timeout can lead to error messages like
"schedule_timeout: wrong timeout value".
Proposed patch:
- checks tv_usec and returns -EDOM if it is wrong
- do not allows to set negative timeout values (sets 0 instead) and outputs
ratelimited information message about such attempts.
Signed-off-By: Vasily Averin <vvs@sw.ru>
As mentioned in http://bugzilla.kernel.org/show_bug.cgi?id=5015
The helptext implies that this is on by default.
This may be true on some distros (Fedora/RHEL have it enabled
in /etc/sysctl.conf), but the kernel defaults to it off.
Signed-off-by: Dave Jones <davej@redhat.com>
dereference (CVE-2007-2876)
When creating a new connection by sending an unknown chunk type, we don't
transition to a valid state, causing a NULL pointer dereference in
sctp_packet when accessing sctp_timeouts[SCTP_CONNTRACK_NONE].
Fix by don't creating new conntrack entry if initial state is invalid.
Noticed by Vilmos Nebehaj <vilmos.nebehaj@ramsys.hu>
This fixes an out-of-boundary condition when the classified
band equals q->bands. Caught by Alexey
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Reverse the sense of the promiscuous-mode tests in ip6_mc_input().
Signed-off-by: Corey Mutter <crm-netdev@mutternet.com>
Signed-off-by: David L Stevens <dlstevens@us.ibm.com>
When an IPv6 router is forwarding a packet with a link-local scope source
address off-link, RFC 4007 requires it to send an ICMPv6 destination
unreachable with code 2 ("not neighbor"), but Linux doesn't. Fix below.
When the server drops its connection, NFS client reconnects using the
same socket after disconnecting. If the new connection's SYN,ACK
doesn't contain the TCP timestamp option and the old connection's did,
tp->tcp_header_len is recomputed assuming no timestamp header but
tp->rx_opt.tstamp_ok remains set. Then tcp_build_and_update_options()
adds in a timestamp option past the end of the allocated TCP header,
overwriting TCP data, or when the data is in skb_shinfo(skb)->frags[],
overwriting skb_shinfo(skb) causing a crash soon after. (The issue was
debugged from such a crash.)
Similarly, wscale_ok and sack_ok also get set based on the SYN,ACK
packet but not reset on disconnect, since they are zeroed out at
initialization. The patch zeroes out the entire tp->rx_opt struct in
tcp_disconnect() to avoid this sort of problem.
Signed-off-by: Srinivas Aji <Aji_Srinivas@emc.com>
When network device's are renamed, the IPV6 snmp6 code
gets confused. It doesn't track name changes so it will OOPS
when network device's are removed.
The fix is trivial, just unregister/re-register in notify handler.
__x25_find_socket does a sock_hold.
This adds a missing sock_put in x25_receive_data.
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com>
The clusterip_config_find_get() already increases entries reference
counter, so there is no reason to do it twice in checkentry() callback.
This causes the config to be freed before it is removed from the list,
resulting in a crash when adding the next rule.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
While porting some changes of the 2.6.21-rc7 pptp/proto_gre conntrack
and nat modules to a 2.4.32 kernel I noticed that the gre_key function
returns a wrong pointer to the GRE key of a version 0 packet thus
corrupting the packet payload.
The intended behaviour for GREv0 packets is to act like
ip_conntrack_proto_generic/ip_nat_proto_unknown so I have ripped the
offending functions (not used anymore) and modified the
ip_nat_proto_gre modules to not touch version 0 (non PPTP) packets.
Signed-off-by: Jorge Boncompte <jorge@dti2.net>
A security issue is emerging. Disallow Routing Header Type 0 by default
as we have been doing for IPv4.
This version already includes a fix for the original patch.
Reply to NETLINK_FIB_LOOKUP messages were misrouted back to kernel,
which resulted in infinite recursion and stack overflow.
The bug is present in all kernel versions since the feature appeared.
The patch also makes some minimal cleanup:
1. Return something consistent (-ENOENT) when fib table is missing
2. Do not crash when queue is empty (does not happen, but yet)
3. Put result of lookup
Sergey Vlasov:
Oops fix
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Without this initialization one gets
kernel BUG at kernel/rtmutex_common.h:80!
Signed-off-by: G. Liakhovetski <gl@dsa-ac.de>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
Acked-by: David Miller <davem@davemloft.net>
We must reserve SAR + MAX_HEADER bytes for IrLMP to fit in.
This fixes an oops reported (and fixed) by Jeet Chaudhuri, when max_sdu_size
is greater than 0.
This patch fixes an oops first reported in mid 2006 - see
http://lkml.org/lkml/2006/8/29/358 The cause of this bug report is that
when an error is signalled on the socket, irda_recvmsg_stream returns
without removing a local wait_queue variable from the socket's sk_sleep
queue. This causes havoc further down the road.
In response to this problem, a patch was made that invoked sock_orphan on
the socket when receiving a disconnect indication. This is not a good fix,
as this sets sk_sleep to NULL, causing applications sleeping in recvmsg
(and other places) to oops.
Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com>
In net poll mode, the current checksum function doesn't consider the
kind of packet which is padded to reach a specific minimum length. I
believe that's the problem causing my test case failed. The following
patch fixed this issue.
Signed-off-by: Aubrey Li <aubreylee@gmail.com>
Userspace uses an integer for TCA_TCINDEX_SHIFT, the kernel was changed
to expect and use a u16 value in 2.6.11, which broke compatibility on
big endian machines. Change back to use int.
Reported by Ole Reinartz <ole.reinartz@gmx.de>
