path: root/net
2013-06-06net: Unbreak compat_sys_{send,recv}msgAndy Lutomirski
I broke them in this commit: commit 1be374a0518a288147c6a7398792583200a67261 Author: Andy Lutomirski <luto@amacapital.net> Date: Wed May 22 14:07:44 2013 -0700 net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg This patch adds __sys_sendmsg and __sys_sendmsg as common helpers that accept MSG_CMSG_COMPAT and blocks MSG_CMSG_COMPAT at the syscall entrypoints. It also reverts some unnecessary checks in sys_socketcall. Apparently I was suffering from underscore blindness the first time around. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Tested-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix timeouts with direct mode authentication in mac80211, from Stanislaw Gruszka. 2) Aggregation sessions can deadlock in ath9k, from Felix Fietkau. 3) Netfilter's xt_addrtype doesn't work with ipv6 due to route lookups creating undesirable cache entries, from Florian Westphal. 4) Fix netfilter's ipt_ULOG from generating non-NULL terminated strings. 5) Fix netdev transmit queue crashes in mac80211, from Johannes Berg. 6) Fix copy and paste error in 802.11 stack that broke reporting of 64-bit station tx statistics, from Felix Fietkau. 7) When qlge_probe fails, it leaks the netdev. Fix from Wei Yongjun. 8) SKB control block (where we store the IP options information, amongst other things) must be cleared properly otherwise ICMP sending can crash for IP tunnels. Fix from Eric Dumazet. 9) Verification of Energy Efficient Ether support was coded wrongly, the test was inversed. Fix from Giuseppe CAVALLARO. 10) TCP handles redirects improperly because the wrong flow key is used for the route lookup. From Michal Kubecek. 11) Don't interpret MSG_CMSG_COMPAT from userspace, fix from Andy Lutomirski. 12) The new AF_VSOCK was missing from the lockdep string table, fix from Federico Vaga. 13) be2net doesn't handle checksumming of IP fragments properly, from Somnath Kotur. 14) Fix several bugs in the device address list code that lead to crashes and other misbehaviors. From Jay Vosburgh. 15) Fix ipv6 segmentation handling of fragmented GRE tunnel traffic, from Pravin B Shalr. 16) Fix usage of stale policies in IPSEC layer, from Paul Moore. 17) Fix team driver dump of ports when there are a large number of them, from Jiri Pirko. 18) Fix softlockups in UDP ipv4 socket lookup causes by and error in the hlist_nulls_for_each_entry_rcu() macro. From Eric Dumazet. 19) Fix several regressions added by the high rate accuracy changes to the htb packet scheduler. From Eric Dumazet. 20) Fix DMA'ing onto the stack in esd_usb2 and peak_usb CAN drivers, from Olivier Sobrie and Marc Kleine-Budde. 21) Fix unremovable network devices due to missing route pointer installation in the per-device ipv6 address list entries. From Gao feng. 22) Apply the tg3 5719 DMA workaround on 5720 chips as well, otherwise we get stalls. From Nithin Sujir. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits) net_sched: htb: do not mix 1ns and 64ns time units net: fix sk_buff head without data area tg3: Add read dma workaround for 5720 net: ethernet: xilinx_emaclite: set protocol selector bits when writing ANAR bnx2x: Fix bridged GSO for 57710/57711 chips net: fec: add fallback to random MAC address bnx2x: fix TCP offload for tunneling ipv4 over ipv6 ipv6: assign rt6_info to inet6_ifaddr in init_loopback net/mlx4_core: Keep VF assigned MAC in the PF admin table net/mlx4_en: Handle unassigned VF MAC address correctly net/mlx4_core: Return -EPROBE_DEFER when a VF is probed before PF is sufficiently initialized net/mlx4_en: Fix adaptive moderation cq update net: can: peak_usb: Do not do dma on the stack net: can: esd_usb2: Do not do dma on the stack net: can: kvaser_usb: fix reception on "USBcan Pro" and "USBcan R" type hardware. net_sched: restore "overhead xxx" handling net: force a reload of first item in hlist_nulls_for_each_entry_rcu hyperv: Fix vlan_proto setting in netvsc_recv_callback() team: fix port list dump for big number of ports list: introduce list_first_entry_or_null ...
2013-06-04net_sched: htb: do not mix 1ns and 64ns time unitsEric Dumazet
commit 56b765b79 ("htb: improved accuracy at high rates") added another regression for low rates, because it mixes 1ns and 64ns time units. So the maximum delay (mbuffer) was not 60 second, but 937 ms. Lets convert all time fields to 1ns as 64bit arches are becoming the norm. Reported-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04net: fix sk_buff head without data areaPablo Neira
Eric Dumazet spotted that we have to check skb->head instead of skb->data as skb->head points to the beginning of the data area of the skbuff. Similarly, we have to initialize the skb->head pointer, not skb->data in __alloc_skb_head. After this fix, netlink crashes in the release path of the sk_buff, so let's fix that as well. This bug was introduced in (0ebd0ac net: add function to allocate sk_buff head without data area). Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04ipv6: assign rt6_info to inet6_ifaddr in init_loopbackGao feng
Commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f "net IPv6 : Fix broken IPv6 routing table after loopback down-up" forgot to assign rt6_info to the inet6_ifaddr. When disable the net device, the rt6_info which allocated in init_loopback will not be destroied in __ipv6_ifa_notify. This will trigger the waring message below [23527.916091] unregister_netdevice: waiting for tap0 to become free. Usage count = 1 Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com> Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-02net_sched: restore "overhead xxx" handlingEric Dumazet
commit 56b765b79 ("htb: improved accuracy at high rates") broke the "overhead xxx" handling, as well as the "linklayer atm" attribute. tc class add ... htb rate X ceil Y linklayer atm overhead 10 This patch restores the "overhead xxx" handling, for htb, tbf and act_police The "linklayer atm" thing needs a separate fix. Reported-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Vimalkumar <j.vimal@gmail.com> Cc: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31xfrm: force a garbage collection after deleting a policyPaul Moore
In some cases after deleting a policy from the SPD the policy would remain in the dst/flow/route cache for an extended period of time which caused problems for SELinux as its dynamic network access controls key off of the number of XFRM policy and state entries. This patch corrects this problem by forcing a XFRM garbage collection whenever a policy is sucessfully removed. Reported-by: Ondrej Moris <omoris@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31udp6: Fix udp fragmentation for tunnel traffic.Pravin B Shelar
udp6 over GRE tunnel does not work after to GRE tso changes. GRE tso handler passes inner packet but keeps track of outer header start in SKB_GSO_CB(skb)->mac_offset. udp6 fragment need to take care of outer header, which start at the mac_offset, while adding fragment header. This bug is introduced by commit 68c3316311 (GRE: Add TCP segmentation offload for GRE). Reported-by: Dmitry Kravkov <dkravkov@gmail.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Tested-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31net/core: dev_mc_sync_multiple calls wrong helperJay Vosburgh
The dev_mc_sync_multiple function is currently calling __hw_addr_sync, and not __hw_addr_sync_multiple. This will result in addresses only being synced to the first device from the set. Corrected by calling the _multiple variant. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Reviewed-by: Vlad Yasevich <vyasevic@redhat.com> Tested-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31net/core: __hw_addr_sync_one / _multiple brokenJay Vosburgh
Currently, __hw_addr_sync_one is called in a loop by __hw_addr_sync_multiple to sync each of a "from" device's hw addresses to a "to" device. __hw_addr_sync_one calls __hw_addr_add_ex to attempt to add each address. __hw_addr_add_ex is called with global=false, and sync=true. __hw_addr_add_ex checks to see if the new address matches an address already on the list. If so, it tests global and sync. In this case, sync=true, and it then checks if the address is already synced, and if so, returns 0. This 0 return causes __hw_addr_sync_one to increment the sync_cnt and refcount for the "from" list's address entry, even though the address is already synced and has a reference and sync_cnt. This will cause the sync_cnt and refcount to increment without bound every time an addresses is added to the "from" device and synced to the "to" device. The fix here has two parts: First, when __hw_addr_add_ex finds the address already exists and is synced, return -EEXIST instead of 0. Second, __hw_addr_sync_one checks the error return for -EEXIST, and if so, it (a) does not add a refcount/sync_cnt, and (b) returns 0 itself so that __hw_addr_sync_multiple will not return an error. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Reviewed-by: Vlad Yasevich <vyasevic@redhat.com> Tested-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31net/core: __hw_addr_unsync_one "from" address not marked syncedJay Vosburgh
When an address is added to a subordinate interface (the "to" list), the address entry in the "from" list is not marked "synced" as the entry added to the "to" list is. When performing the unsync operation (e.g., dev_mc_unsync), __hw_addr_unsync_one calls __hw_addr_del_entry with the "synced" parameter set to true for the case when the address reference is being released from the "from" list. This causes a test inside to fail, with the result being that the reference count on the "from" address is not properly decremeted and the address on the "from" list will never be freed. Correct this by having __hw_addr_unsync_one call the __hw_addr_del_entry function with the "sync" flag set to false for the "remove from the from list" case. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Reviewed-by: Vlad Yasevich <vyasevic@redhat.com> Tested-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31net/core: __hw_addr_create_ex does not initialize sync_cntJay Vosburgh
The sync_cnt field is not being initialized, which can result in arbitrary values in the field. Fixed by initializing it to zero. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Reviewed-by: Vlad Yasevich <vyasevic@redhat.com> Tested-by: Shawn Bohrer <sbohrer@rgmadvisors.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31snmp6: remove IPSTATS_MIB_CSUMERRORSNicolas Dichtel
This stat is not relevant in IPv6, there is no checksum in IPv6 header. Just leave a comment to explain the hole. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== Please pull this batch of fixes intended for the 3.10 stream... Regarding the NFC bits, Samuel says: "This is the first batch of NFC fixes for 3.10, and it contains: - 3 fixes for the NFC MEI support: * We now depend on the correct Kconfig symbol. * We register an MEI event callback whenever we enable an NFC device, otherwise we fail to read anything after an enable/disable cycle. * We only disable an MEI device from its disable mey_phy_ops, preventing useless consecutive disable calls. - An NFC Makefile cleanup, as I forgot to remove a commented out line when moving the LLCP code to the NFC top level directory." As for the mac80211 bits, Johannes says: "This time I have a fix from Stanislaw for a stupid mistake I made in the auth/assoc timeout changes, a fix from Felix for 64-bit traffic counters and one from Helmut for address mask handling in mac80211. I also have a few fixes myself for four different crashes reported by a few people." And Johannes says this about the iwlwifi bit: "This fixes a brown paper-bag bug that we really should've caught in review. More details in the changelog for the fix." On top of that... Arend van Spriel and Hante Meuleman cooperate to send a series of AP and P2P mode fixes for brcmfmac. Gabor Juhos corrects a register offset for AR9550, avoiding a bus error. Dan Carpenter provides a fixup to some dmesg output in the atmel driver. And, finally... Felix Fietkau not only gives us a trio of small AR934x fixes, but also refactors the ath9k aggregation session start/stop handling (using the generic mac80211 support) in order to avoid a deadlock. Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-31Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fixes from Bruce Fields: "A couple minor fixes for the (new to 3.10) gss-proxy code. And one regression from user-namespace changes. (XBMC clients were doing something admittedly weird--sending -1 gid's--but something that we used to allow.)" * 'for-3.10' of git://linux-nfs.org/~bfields/linux: svcrpc: fix failures to handle -1 uid's and gid's svcrpc: implement O_NONBLOCK behavior for use-gss-proxy svcauth_gss: fix error code in use_gss_proxy()
2013-05-30Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains Netfilter/IPVS fixes for 3.10-rc3, they are: * fix xt_addrtype with IPv6, from Florian Westphal. This required a new hook for IPv6 functions in the netfilter core to avoid hard dependencies with the ipv6 subsystem when this match is only used for IPv4. * fix connection reuse case in IPVS. Currently, if an reused connection are directed to the same server. If that server is down, those connection would fail. Therefore, clear the connection and choose a new server among the available ones. * fix possible non-nul terminated string sent to user-space if ipt_ULOG is used as the default netfilter logging stub, from Chen Gang. * fix mark logging of IPv6 packets in xt_LOG, from Michal Kubecek. This bug has been there since 2.6.26. * Fix breakage ip_vs_sh due to incorrect structure layout for RCU, from Jan Beulich. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-29ipvs: ip_vs_sh: fix buildJan Beulich
kfree_rcu() requires offsetof(..., rcu_head) < 4096, which can get violated with a sufficiently high CONFIG_IP_VS_SH_TAB_BITS. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2013-05-29svcrpc: fix failures to handle -1 uid's and gid'sJ. Bruce Fields
As of f025adf191924e3a75ce80e130afcd2485b53bb8 "sunrpc: Properly decode kuids and kgids in RPC_AUTH_UNIX credentials" any rpc containing a -1 (0xffff) uid or gid would fail with a badcred error. Reported symptoms were xmbc clients failing on upgrade of the NFS server; examination of the network trace showed them sending -1 as the gid. Reported-by: Julian Sikorski <belegdol@gmail.com> Tested-by: Julian Sikorski <belegdol@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-29netfilter: xt_LOG: fix mark logging for IPv6 packetsMichal Kubeček
In dump_ipv6_packet(), the "recurse" parameter is zero only if dumping contents of a packet embedded into an ICMPv6 error message. Therefore we want to log packet mark if recurse is non-zero, not when it is zero. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-28net/core/sock.c: add missing VSOCK string in af_family_*_key_stringsFederico Vaga
The three arrays of strings: af_family_key_strings, af_family_slock_key_strings and af_family_clock_key_strings have not VSOCK's string Signed-off-by: Federico Vaga <federico.vaga@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msgAndy Lutomirski
To: linux-kernel@vger.kernel.org Cc: x86@kernel.org, trinity@vger.kernel.org, Andy Lutomirski <luto@amacapital.net>, netdev@vger.kernel.org, "David S. Miller" <davem@davemloft.net> Subject: [PATCH 5/5] net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API -- it's a hack that steals a bit to indicate to other networking code that a compat entry was used. So don't allow it from a non-compat syscall. This prevents an oops when running this code: int main() { int s; struct sockaddr_in addr; struct msghdr *hdr; char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0); if (highpage == MAP_FAILED) err(1, "mmap"); s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP); if (s == -1) err(1, "socket"); addr.sin_family = AF_INET; addr.sin_port = htons(1); addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0) err(1, "connect"); void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE; printf("Evil address is %p\n", evil); if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0) err(1, "sendmmsg"); return 0; } Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28svcrpc: implement O_NONBLOCK behavior for use-gss-proxyJ. Bruce Fields
Somebody noticed LTP was complaining about O_NONBLOCK opens of /proc/net/rpc/use-gss-proxy succeeding and then a following read hanging. I'm not convinced LTP really has any business opening random proc files and expecting them to behave a certain way. Maybe this isn't really a bug. But in any case the O_NONBLOCK behavior could be useful for someone that wants to test whether gss-proxy is up without waiting. Reported-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-28Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211
2013-05-27ipv4: fix redirect handling for TCP packetsMichal Kubecek
Unlike ipv4_redirect() and ipv4_sk_redirect(), ip_do_redirect() doesn't call __build_flow_key() directly but via ip_rt_build_flow_key() wrapper. This leads to __build_flow_key() getting pointer to IPv4 header of the ICMP redirect packet rather than pointer to the embedded IPv4 header of the packet initiating the redirect. As a result, handling of ICMP redirects initiated by TCP packets is broken. Issue was introduced by 4895c771c ("ipv4: Add FIB nexthop exceptions.") Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27ipvs: Fix reuse connection if real server is deadGrzegorz Lyczba
Expire cached connection for new TCP/SCTP connection if real server is down. Otherwise, IPVS uses the dead server for the reused connection, instead of a new working one. Signed-off-by: Grzegorz Lyczba <grzegorz.lyczba@gmail.com> Acked-by: Hans Schillstrom <hans@schillstrom.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-27mac80211: Allow single vif mac address change with addr_maskHelmut Schaa
When changing the MAC address of a single vif mac80211 will check if the new address fits into the address mask specified by the driver. This only needs to be done when using multiple BSSIDs. Hence, check the new address only against all other vifs. Also fix the MAC address assignment on new interfaces if the user changed the address of a vif such that perm_addr is not covered by addr_mask anymore. Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=57371 Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Jakub Kicinski <kubakici@wp.pl> Reported-by: Alessandro Lannocca <alessandro.lannocca@gmail.com> Cc: Alessandro Lannocca <alessandro.lannocca@gmail.com> Cc: Bruno Randolf <br1@thinktube.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-27mac80211: close AP_VLAN interfaces before unregistering allJohannes Berg
Since Eric's commit efe117ab8 ("Speedup ieee80211_remove_interfaces") there's a bug in mac80211 when it unregisters with AP_VLAN interfaces up. If the AP_VLAN interface was registered after the AP it belongs to (which is the typical case) and then we get into this code path, unregister_netdevice_many() will crash because it isn't prepared to deal with interfaces being closed in the middle of it. Exactly this happens though, because we iterate the list, find the AP master this AP_VLAN belongs to and dev_close() the dependent VLANs. After this, unregister_netdevice_many() won't pick up the fact that the AP_VLAN is already down and will do it again, causing a crash. Cc: stable@vger.kernel.org [2.6.33+] Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-27mac80211: assign AP_VLAN hw queues correctlyJohannes Berg
A lot of code in mac80211 assumes that the hw queues are set up correctly for all interfaces (except for monitor) but this isn't true for AP_VLAN interfaces. Fix this by copying the AP master configuration when an AP VLAN is brought up, after this the AP interface can't change its configuration any more and needs to be brought down to change it, which also forces AP_VLAN interfaces down, so just copying in open() is sufficient. Reported-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-26Merge tag 'nfs-for-3.10-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Stable fix to prevent an rpc_task wakeup race - Fix a NFSv4.1 session drain deadlock - Fix a NFSv4/v4.1 mount regression when not running rpc.gssd - Ensure auth_gss pipe detection works in namespaces - Fix SETCLIENTID fallback if rpcsec_gss is not available * tag 'nfs-for-3.10-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: Fix SETCLIENTID fallback if GSS is not available SUNRPC: Prevent an rpc_task wakeup race NFSv4.1 Fix a pNFS session draining deadlock SUNRPC: Convert auth_gss pipe detection to work in namespaces SUNRPC: Faster detection if gssd is actually running SUNRPC: Fix a bug in gss_create_upcall
2013-05-25ip_tunnel: fix kernel panic with icmp_dest_unreachEric Dumazet
Daniel Petre reported crashes in icmp_dst_unreach() with following call graph: #3 [ffff88003fc03938] __stack_chk_fail at ffffffff81037f77 #4 [ffff88003fc03948] icmp_send at ffffffff814d5fec #5 [ffff88003fc03ae8] ipv4_link_failure at ffffffff814a1795 #6 [ffff88003fc03af8] ipgre_tunnel_xmit at ffffffff814e7965 #7 [ffff88003fc03b78] dev_hard_start_xmit at ffffffff8146e032 #8 [ffff88003fc03bc8] sch_direct_xmit at ffffffff81487d66 #9 [ffff88003fc03c08] __qdisc_run at ffffffff81487efd #10 [ffff88003fc03c48] dev_queue_xmit at ffffffff8146e5a7 #11 [ffff88003fc03c88] ip_finish_output at ffffffff814ab596 Daniel found a similar problem mentioned in http://lkml.indiana.edu/hypermail/linux/kernel/1007.0/00961.html And indeed this is the root cause : skb->cb[] contains data fooling IP stack. We must clear IPCB in ip_tunnel_xmit() sooner in case dst_link_failure() is called. Or else skb->cb[] might contain garbage from GSO segmentation layer. A similar fix was tested on linux-3.9, but gre code was refactored in linux-3.10. I'll send patches for stable kernels as well. Many thanks to Daniel for providing reports, patches and testing ! Reported-by: Daniel Petre <daniel.petre@rcs-rds.ro> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "It's been a while since my last pull request so quite a few fixes have piled up." Indeed. 1) Fix nf_{log,queue} compilation with PROC_FS disabled, from Pablo Neira Ayuso. 2) Fix data corruption on some tg3 chips with TSO enabled, from Michael Chan. 3) Fix double insertion of VLAN tags in be2net driver, from Sarveshwar Bandi. 4) Don't have TCP's MD5 support pass > PAGE_SIZE page offsets in scatter-gather entries into the crypto layer, the crypto layer can't handle that. From Eric Dumazet. 5) Fix lockdep splat in 802.1Q MRP code, also from Eric Dumazet. 6) Fix OOPS in netfilter log module when called from conntrack, from Hans Schillstrom. 7) FEC driver needs to use netif_tx_{lock,unlock}_bh() rather than the non-BH disabling variants. From Fabio Estevam. 8) TCP GSO can generate out-of-order packets, fix from Eric Dumazet. 9) vxlan driver doesn't update 'used' field of fdb entries when it should, from Sridhar Samudrala. 10) ipv6 should use kzalloc() to allocate inet6 socket cork options, otherwise we can OOPS in ip6_cork_release(). From Eric Dumazet. 11) Fix races in bonding set mode, from Nikolay Aleksandrov. 12) Fix checksum generation regression added by "r8169: fix 8168evl frame padding.", from Francois Romieu. 13) ip_gre can look at stale SKB data pointer, fix from Eric Dumazet. 14) Fix checksum handling when GSO is enabled in bnx2x driver with certain chips, from Yuval Mintz. 15) Fix double free in batman-adv, from Martin Hundebøll. 16) Fix device startup synchronization with firmware in tg3 driver, from Nithin Sujit. 17) perf networking dropmonitor doesn't work at all due to mixed up trace parameter ordering, from Ben Hutchings. 18) Fix proportional rate reduction handling in tcp_ack(), from Nandita Dukkipati. 19) IPSEC layer doesn't return an error when a valid state is detected, causing an OOPS. Fix from Timo Teräs. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits) be2net: bug fix on returning an invalid nic descriptor tcp: xps: fix reordering issues net: Revert unused variable changes. xfrm: properly handle invalid states as an error virtio_net: enable napi for all possible queues during open tcp: bug fix in proportional rate reduction. net: ethernet: sun: drop unused variable net: ethernet: korina: drop unused variable net: ethernet: apple: drop unused variable qmi_wwan: Added support for Cinterion's PLxx WWAN Interface perf: net_dropmonitor: Remove progress indicator perf: net_dropmonitor: Use bisection in symbol lookup perf: net_dropmonitor: Do not assume ordering of dictionaries perf: net_dropmonitor: Fix symbol-relative addresses perf: net_dropmonitor: Fix trace parameter order net: fec: use a more proper compatible string for MVF type device qlcnic: Fix updating netdev->features qlcnic: remove netdev->trans_start updates within the driver qlcnic: Return proper error codes from probe failure paths tg3: Update version to 3.132 ...
2013-05-23tcp: xps: fix reordering issuesEric Dumazet
commit 3853b5841c01a ("xps: Improvements in TX queue selection") introduced ooo_okay flag, but the condition to set it is slightly wrong. In our traces, we have seen ACK packets being received out of order, and RST packets sent in response. We should test if we have any packets still in host queue. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-23cfg80211: fix reporting 64-bit station info tx bytesFelix Fietkau
Copy & paste mistake - STATION_INFO_TX_BYTES64 is the name of the flag, not NL80211_STA_INFO_TX_BYTES64. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-23mac80211: fix queue handling crashJohannes Berg
The code I added in "mac80211: don't start new netdev queues if driver stopped" crashes for monitor and AP VLAN interfaces because while they have a netdev, they don't have queues set up by the driver. To fix the crash, exclude these from queue accounting here and just start their netdev queues unconditionally. For monitor, this is the best we can do, as we can redirect frames there to any other interface and don't know which one that will since it can be different for each frame. For AP VLAN interfaces, we can do better later and actually properly track the queue status. Not doing this is really a separate bug though. Reported-by: Ilan Peer <ilan.peer@intel.com> Reported-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-23cfg80211: check wdev->netdev in connection workJohannes Berg
If a P2P-Device is present and another virtual interface triggers the connection work, the system crash because it tries to check if the P2P-Device's netdev (which doesn't exist) is up. Skip any wdevs that have no netdev to fix this. Cc: stable@vger.kernel.org Reported-by: YanBo <dreamfly281@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-23netfilter: ipt_ULOG: fix non-null terminated string in the nf_log pathChen Gang
If nf_log uses ipt_ULOG as logging output, we can deliver non-null terminated strings to user-space since the maximum length of the prefix that is passed by nf_log is NF_LOG_PREFIXLEN but pm->prefix is 32 bytes long (ULOG_PREFIX_LEN). This is actually happening already from nf_conntrack_tcp if ipt_ULOG is used, since it is passing strings longer than 32 bytes. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-23netfilter: add nf_ipv6_ops hook to fix xt_addrtype with IPv6Florian Westphal
Quoting https://bugzilla.netfilter.org/show_bug.cgi?id=812: [ ip6tables -m addrtype ] When I tried to use in the nat/PREROUTING it messes up the routing cache even if the rule didn't matched at all. [..] If I remove the --limit-iface-in from the non-working scenario, so just use the -m addrtype --dst-type LOCAL it works! This happens when LOCAL type matching is requested with --limit-iface-in, and the default ipv6 route is via the interface the packet we test arrived on. Because xt_addrtype uses ip6_route_output, the ipv6 routing implementation creates an unwanted cached entry, and the packet won't make it to the real/expected destination. Silently ignoring --limit-iface-in makes the routing work but it breaks rule matching (--dst-type LOCAL with limit-iface-in is supposed to only match if the dst address is configured on the incoming interface; without --limit-iface-in it will match if the address is reachable via lo). The test should call ipv6_chk_addr() instead. However, this would add a link-time dependency on ipv6. There are two possible solutions: 1) Revert the commit that moved ipt_addrtype to xt_addrtype, and put ipv6 specific code into ip6t_addrtype. 2) add new "nf_ipv6_ops" struct to register pointers to ipv6 functions. While the former might seem preferable, Pablo pointed out that there are more xt modules with link-time dependeny issues regarding ipv6, so lets go for 2). Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-05-23xfrm: properly handle invalid states as an errorTimo Teräs
The error exit path needs err explicitly set. Otherwise it returns success and the only caller, xfrm_output_resume(), would oops in skb_dst(skb)->ops derefence as skb_dst(skb) is NULL. Bug introduced in commit bb65a9cb (xfrm: removes a superfluous check and add a statistic). Signed-off-by: Timo Teräs <timo.teras@iki.fi> Cc: Li RongQing <roy.qing.li@gmail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-23tcp: bug fix in proportional rate reduction.Nandita Dukkipati
This patch is a fix for a bug triggering newly_acked_sacked < 0 in tcp_ack(.). The bug is triggered by sacked_out decreasing relative to prior_sacked, but packets_out remaining the same as pior_packets. This is because the snapshot of prior_packets is taken after tcp_sacktag_write_queue() while prior_sacked is captured before tcp_sacktag_write_queue(). The problem is: tcp_sacktag_write_queue (tcp_match_skb_to_sack() -> tcp_fragment) adjusts the pcount for packets_out and sacked_out (MSS change or other reason). As a result, this delta in pcount is reflected in (prior_sacked - sacked_out) but not in (prior_packets - packets_out). This patch does the following: 1) initializes prior_packets at the start of tcp_ack() so as to capture the delta in packets_out created by tcp_fragment. 2) introduces a new "previous_packets_out" variable that snapshots packets_out right before tcp_clean_rtx_queue, so pkts_acked can be correctly computed as before. 3) Computes pkts_acked using previous_packets_out, and computes newly_acked_sacked using prior_packets. Signed-off-by: Nandita Dukkipati <nanditad@google.com> Acked-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-22SUNRPC: Prevent an rpc_task wakeup raceTrond Myklebust
The lockless RPC_IS_QUEUED() test in __rpc_execute means that we need to be careful about ordering the calls to rpc_test_and_set_running(task) and rpc_clear_queued(task). If we get the order wrong, then we may end up testing the RPC_TASK_RUNNING flag after __rpc_execute() has looped and changed the state of the rpc_task. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org
2013-05-21batman-adv: Avoid double freeing of bat_countersMartin Hundebøll
On errors in batadv_mesh_init(), bat_counters will be freed in both batadv_mesh_free() and batadv_softif_init_late(). This patch fixes this by returning earlier from batadv_softif_init_late() in case of errors in batadv_mesh_init() and by setting bat_counters to NULL after freeing. Signed-off-by: Martin Hundebøll <martin@hundeboll.net> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Antonio Quartulli <ordex@autistici.org>
2013-05-21NFC: Remove commented out LLCP related Makefile linePaul Bolle
The Kconfig symbol NFC_LLCP was removed in commit 30cc458765 ("NFC: Move LLCP code to the NFC top level diirectory"). But the reference to its macro in this Makefile was only commented out. Remove it now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-05-20Merge branch 'master' of ↵John W. Linville
2013-05-20ip_gre: fix a possible crash in ipgre_err()Eric Dumazet
Another fix needed in ipgre_err(), as parse_gre_header() might change skb->head. Bug added in commit c54419321455 (GRE: Refactor GRE tunneling code.) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-20Hoist memcpy_fromiovec/memcpy_toiovec into lib/Rusty Russell
ERROR: "memcpy_fromiovec" [drivers/vhost/vhost_scsi.ko] undefined! That function is only present with CONFIG_NET. Turns out that crypto/algif_skcipher.c also uses that outside net, but it actually needs sockets anyway. In addition, commit 6d4f0139d642c45411a47879325891ce2a7c164a added CONFIG_NET dependency to CONFIG_VMCI for memcpy_toiovec, so hoist that function and revert that commit too. socket.h already includes uio.h, so no callers need updating; trying only broke things fo x86_64 randconfig (thanks Fengguang!). Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-05-19net: irda: using kzalloc() instead of kmalloc() to avoid strncpy() issue.Chen Gang
'discovery->data.info' length is 22, NICKNAME_MAX_LEN is 21, so the strncpy() will always left the last byte of 'discovery->data.info' uninitialized. When 'text' length is longer than 21 (NICKNAME_MAX_LEN), if still left the last byte of 'discovery->data.info' uninitialized, the next strlen() will cause issue. Also 'discovery->data' is 'struct irda_device_info' which defined in "include/uapi/...", it may copy to user mode, so need whole initialized. All together, need use kzalloc() instead of kmalloc() to initialize all members firstly. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-19netlabel: improve domain mapping validationPaul Moore
The net/netlabel/netlabel_domainhash.c:netlbl_domhsh_add() function does not properly validate new domain hash entries resulting in potential problems when an administrator attempts to add an invalid entry. One such problem, as reported by Vlad Halilov, is a kernel BUG (found in netlabel_domainhash.c:netlbl_domhsh_audit_add()) when adding an IPv6 outbound mapping with a CIPSO configuration. This patch corrects this problem by adding the necessary validation code to netlbl_domhsh_add() via the newly created netlbl_domhsh_validate() function. Ideally this patch should also be pushed to the currently active -stable trees. Reported-by: Vlad Halilov <vlad.halilov@gmail.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-18ipv6: fix possible crashes in ip6_cork_release()Eric Dumazet
commit 0178b695fd6b4 ("ipv6: Copy cork options in ip6_append_data") added some code duplication and bad error recovery, leading to potential crash in ip6_cork_release() as kfree() could be called with garbage. use kzalloc() to make sure this wont happen. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Neal Cardwell <ncardwell@google.com>
2013-05-17mac80211: fix direct probe authStanislaw Gruszka
We send direct probe to broadcast address, as some APs do not respond to unicast PROBE frames when unassociated. Broadcast frames are not acked, so we can not use that for trigger MLME state machine, but we need to use old timeout mechanism. This fixes authentication timed out like below: [ 1024.671974] wlan6: authenticate with 54:e6:fc:98:63:fe [ 1024.694125] wlan6: direct probe to 54:e6:fc:98:63:fe (try 1/3) [ 1024.695450] wlan6: direct probe to 54:e6:fc:98:63:fe (try 2/3) [ 1024.700586] wlan6: send auth to 54:e6:fc:98:63:fe (try 3/3) [ 1024.701441] wlan6: authentication with 54:e6:fc:98:63:fe timed out With fix, we have: [ 4524.198978] wlan6: authenticate with 54:e6:fc:98:63:fe [ 4524.220692] wlan6: direct probe to 54:e6:fc:98:63:fe (try 1/3) [ 4524.421784] wlan6: send auth to 54:e6:fc:98:63:fe (try 2/3) [ 4524.423272] wlan6: authenticated [ 4524.423811] wlan6: associate with 54:e6:fc:98:63:fe (try 1/3) [ 4524.427492] wlan6: RX AssocResp from 54:e6:fc:98:63:fe (capab=0x431 status=0 aid=1) Cc: stable@vger.kernel.org # 3.9 Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
