commit df6d02300f7c2fbd0fbe626d819c8e5237d72c62 upstream.
When a driver doesn't fill the entire buffer, old
heap contents may remain, and if it also doesn't
update the length properly, this old heap content
will be copied back to userspace.
It is very unlikely that this happens in any of
the drivers using private ioctls since it would
show up as junk being reported by iwpriv, but it
seems better to be safe here, so use kzalloc.
Reported-by: Jeff Mahoney <jeffm@suse.com>
commit cf9b94f88bdbe8a02015fc30d7c232b2d262d4ad upstream.
This is an off by one. We would go past the end when we NUL terminate
the "value" string at end of the function. The "value" buffer is
allocated in irlan_client_parse_response() or
irlan_provider_parse_command().
CC: stable@kernel.org
commit 5b75c4973ce779520b9d1e392483207d6f842cde upstream.
This patch adds a limit for nframes as the number of frames in TX_SETUP and
RX_SETUP are derived from a single byte multiplex value by default.
Use-cases that would require to send/filter more than 256 CAN frames should
be implemented in userspace for complexity reasons anyway.
Additionally the assignments of unsigned values from userspace to signed
values in kernelspace and vice versa are fixed by using unsigned values in
kernelspace consistently.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Reported-by: Ben Hawkes <hawkes@google.com>
Acked-by: Urs Thuermann <urs.thuermann@volkswagen.de>
commit 499031ac8a3df6738f6186ded9da853e8ea18253 upstream.
We should release dst if dst->error is set.
Bug introduced in 2.6.14 by commit e104411b82f5c
([XFRM]: Always release dst_entry on error in xfrm_lookup)
commit 2e3219b5c8a2e44e0b83ae6e04f52f20a82ac0f2 upstream.
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809
sctp: Fix skb_over_panic resulting from multiple invalid \
parameter errors (CVE-2010-1173) (v4)
cause 'error cause' never be add the the ERROR chunk due to
some typo when check valid length in sctp_init_cause_fixed().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
commit d0021b252eaf65ca07ed14f0d66425dd9ccab9a6 upstream.
Fix TIPC to disallow sending to remote addresses prior to entering NET_MODE
user programs can oops the kernel by sending datagrams via AF_TIPC prior to
entering networked mode. The following backtrace has been observed:
ID: 13459 TASK: ffff810014640040 CPU: 0 COMMAND: "tipc-client"
[exception RIP: tipc_node_select_next_hop+90]
RIP: ffffffff8869d3c3 RSP: ffff81002d9a5ab8 RFLAGS: 00010202
RAX: 0000000000000001 RBX: 0000000000000001 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000001001001
RBP: 0000000001001001 R8: 0074736575716552 R9: 0000000000000000
R10: ffff81003fbd0680 R11: 00000000000000c8 R12: 0000000000000008
R13: 0000000000000001 R14: 0000000000000001 R15: ffff810015c6ca00
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
RIP: 0000003cbd8d49a3 RSP: 00007fffc84e0be8 RFLAGS: 00010206
RAX: 000000000000002c RBX: ffffffff8005d116 RCX: 0000000000000000
RDX: 0000000000000008 RSI: 00007fffc84e0c00 RDI: 0000000000000003
RBP: 0000000000000000 R8: 00007fffc84e0c10 R9: 0000000000000010
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 00007fffc84e0d10 R14: 0000000000000000 R15: 00007fffc84e0c30
ORIG_RAX: 000000000000002c CS: 0033 SS: 002b
What happens is that, when the tipc module in inserted it enters a standalone
node mode in which communication to its own address is allowed <0.0.0> but not
to other addresses, since the appropriate data structures have not been
allocated yet (specifically the tipc_net pointer). There is nothing stopping a
client from trying to send such a message however, and if that happens, we
attempt to dereference tipc_net.zones while the pointer is still NULL, and
explode. The fix is pretty straightforward. Since these oopses all arise from
the dereference of global pointers prior to their assignment to allocated
values, and since these allocations are small (about 2k total), lets convert
these pointers to static arrays of the appropriate size. All the accesses to
these bits consider 0/NULL to be a non match when searching, so all the lookups
still work properly, and there is no longer a chance of a bad dererence
anywhere. As a bonus, this lets us eliminate the setup/teardown routines for
those pointers, and elimnates the need to preform any locking around them to
prevent access while their being allocated/freed.
I've updated the tipc_net structure to behave this way to fix the exact reported
problem, and also fixed up the tipc_bearers and media_list arrays to fix an
obvious simmilar problem that arises from issuing tipc-config commands to
manipulate bearers/links prior to entering networked mode
I've tested this for a few hours by running the sanity tests and stress test
with the tipcutils suite, and nothing has fallen over. There have been a few
lockdep warnings, but those were there before, and can be addressed later, as
they didn't actually result in any deadlock.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Allan Stephens <allan.stephens@windriver.com>
CC: David S. Miller <davem@davemloft.net>
CC: tipc-discussion@lists.sourceforge.net
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809 upstream.
Ok, version 4
Change Notes:
1) Minor cleanups, from Vlads notes
Summary:
Hey-
Recently, it was reported to me that the kernel could oops in the
following way:
<5> kernel BUG at net/core/skbuff.c:91!
<5> invalid operand: 0000 [#1]
<5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter
ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U)
vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5
ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss
snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore
pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi
mptbase sd_mod scsi_mod
<5> CPU: 0
<5> EIP: 0060:[<c02bff27>] Not tainted VLI
<5> EFLAGS: 00010216 (2.6.9-89.0.25.EL)
<5> EIP is at skb_over_panic+0x1f/0x2d
<5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44
<5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40
<5> ds: 007b es: 007b ss: 0068
<5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0)
<5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180
e0c2947d
<5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004
df653490
<5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e
00000004
<5> Call Trace:
<5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp]
<5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp]
<5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp]
<5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp]
<5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp]
<5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp]
<5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp]
<5> [<c01555a4>] cache_grow+0x140/0x233
<5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp]
<5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp]
<5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp]
<5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter]
<5> [<c02d005e>] nf_iterate+0x40/0x81
<5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151
<5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151
<5> [<c02d0362>] nf_hook_slow+0x83/0xb5
<5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9
<5> [<c02e103e>] ip_rcv+0x334/0x3b4
<5> [<c02c66fd>] netif_receive_skb+0x320/0x35b
<5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd]
<5> [<c02c67a4>] process_backlog+0x6c/0xd9
<5> [<c02c690f>] net_rx_action+0xfe/0x1f8
<5> [<c012a7b1>] __do_softirq+0x35/0x79
<5> [<c0107efb>] handle_IRQ_event+0x0/0x4f
<5> [<c01094de>] do_softirq+0x46/0x4d
Its an skb_over_panic BUG halt that results from processing an init chunk in
which too many of its variable length parameters are in some way malformed.
The problem is in sctp_process_unk_param:
if (NULL == *errp)
*errp = sctp_make_op_error_space(asoc, chunk,
ntohs(chunk->chunk_hdr->length));
if (*errp) {
sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM,
WORD_ROUND(ntohs(param.p->length)));
sctp_addto_chunk(*errp,
WORD_ROUND(ntohs(param.p->length)),
param.v);
When we allocate an error chunk, we assume that the worst case scenario requires
that we have chunk_hdr->length data allocated, which would be correct nominally,
given that we call sctp_addto_chunk for the violating parameter. Unfortunately,
we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error
chunk, so the worst case situation in which all parameters are in violation
requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data.
The result of this error is that a deliberately malformed packet sent to a
listening host can cause a remote DOS, described in CVE-2010-1173:
http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173
I've tested the below fix and confirmed that it fixes the issue. We move to a
strategy whereby we allocate a fixed size error chunk and ignore errors we don't
have space to report. Tested by me successfully
commit 22945e4a1c7454c97f5d8aee1ef526c83fef3223 upstream.
A race between svc_revisit and svc_delete_xprt can result in
deferred requests holding references on a transport that can never be
recovered because dead transports are not enqueued for subsequent
processing.
Check for XPT_DEAD in revisit to clean up completing deferrals on a dead
transport and sweep a transport's deferred queue to do the same for queued
but unprocessed deferrals.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Cc: roma1390 <roma1390@gmail.com>
commit 16ebb5e0b36ceadc8186f71d68b0c4fa4b6e781b upstream.
Three bytes of uninitialized kernel memory are currently leaked to user
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
commit 657e9649e745b06675aa5063c84430986cdc3afa upstream.
I have recently came across a preemption imbalance detected by:
<4>huh, entered ffffffff80644630 with preempt_count 00000102, exited with 00000101?
<0>------------[ cut here ]------------
<2>kernel BUG at /usr/src/linux/kernel/timer.c:664!
<0>invalid opcode: 0000 [1] PREEMPT SMP
with ffffffff80644630 being inet_twdr_hangman().
This appeared after I enabled CONFIG_TCP_MD5SIG and played with it a
bit, so I looked at what might have caused it.
One thing that struck me as strange is tcp_twsk_destructor(), as it
calls tcp_put_md5sig_pool() -- which entails a put_cpu(), causing the
detected imbalance. Found on 2.6.23.9, but 2.6.31 is affected as well,
as far as I can tell.
Signed-off-by: Robert Varga <nite@hq.alert.sk>
commit 298bf12ddb25841804f26234a43b89da1b1c0e21 upstream.
When requesting all prl entries (kprl.addr == INADDR_ANY) and there are
more prl entries than there is space passed from userspace, the existing
code would always copy cmax+1 entries, which is more than can be handled.
This patch makes the kernel copy only exactly cmax entries.
Signed-off-by: Sascha Hlusiak <contact@saschahlusiak.de>
Acked-By: Fred L. Templin <Fred.L.Templin@boeing.com>
commit 8ba69ba6a324b13e1190fc31e41954d190fd4f1d upstream.
Kalle Olavi Niemitalo reported that:
"..., when one process calls sendmsg once to send 43804 bytes of
data and one file descriptor, and another process then calls recvmsg
three times to receive the 16032+16032+11740 bytes, each of those
recvmsg calls returns the file descriptor in the ancillary data. I
confirmed this with strace. The behaviour differs from Linux
2.6.26, where reportedly only one of those recvmsg calls (I think
the first one) returned the file descriptor."
This bug was introduced by a patch from me titled "net: unix: fix inflight
counting bug in garbage collector", commit 6209344f5.
And the reason is, quoting Kalle:
"Before your patch, unix_attach_fds() would set scm->fp = NULL, so
that if the loop in unix_stream_sendmsg() ran multiple iterations,
it could not call unix_attach_fds() again. But now,
unix_attach_fds() leaves scm->fp unchanged, and I think this causes
it to be called multiple times and duplicate the same file
descriptors to each struct sk_buff."
Fix this by introducing a flag that is cleared at the start and set
when the fds attached to the first buffer. The resulting code should
work equivalently to the one on 2.6.26.
Reported-by: Kalle Olavi Niemitalo <kon@iki.fi>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 8c185ab6185bf5e67766edb000ce428269364c86 upstream.
In ax25_make_new, if kmemdup of digipeat returns an error, there would
be an oops in sk_free while calling sk_destruct, because sk_protinfo
is NULL at the moment; move sk->sk_destruct initialization after this.
BTW of reported-by: Bernard Pidoux F6BVP <f6bvp@free.fr>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
commit dce766af541f6605fa9889892c0280bab31c66ab upstream.
normal users are currently allowed to set/modify ebtables rules.
Restrict it to processes with CAP_NET_ADMIN.
Note that this cannot be reproduced with unmodified ebtables binary
because it uses SOCK_RAW.
Signed-off-by: Florian Westphal <fwestphal@astaro.com>
delivery
commit 0b5ccb2ee250136dd7385b1c7da28417d0d4d32d upstream.
Currently the same reassembly queue might be used for packets reassembled
by conntrack in different positions in the stack (PREROUTING/LOCAL_OUT),
as well as local delivery. This can cause "packet jumps" when the fragment
completing a reassembled packet is queued from a different position in the
stack than the previous ones.
Add a "user" identifier to the reassembly queue key to seperate the queues
of each caller, similar to what we do for IPv4.
commit ad61df918c44316940404891d5082c63e79c256a upstream.
Commit 9ef1d4c7c7aca1cd436612b6ca785b726ffb8ed8 ("[NETLINK]: Missing
initializations in dumped data") introduced a typo in
initialization. This patch fixes this.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit ffcfb8db540ff879c2a85bf7e404954281443414 upstream
appletalk: Fix skb leak when ipddp interface is not loaded
[ backport to 2.6.27 : Chuck Ebbert <cebbert@redhat.com ]
And also do a better job of returning proper NET_{RX,XMIT}_ values.
Based on a patch and suggestions by Mark Smith.
This fixes CVE-2009-2903
Reported-by: Mark Smith <lk-netdev@lk-netdev.nosense.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 77238f2b942b38ab4e7f3aced44084493e4a8675 upstream.
I found a deadlock bug in UNIX domain socket, which makes able to DoS
attack against the local machine by non-root users.
How to reproduce:
1. Make a listening AF_UNIX/SOCK_STREAM socket with an abstruct
namespace(*), and shutdown(2) it.
2. Repeat connect(2)ing to the listening socket from the other sockets
until the connection backlog is full-filled.
3. connect(2) takes the CPU forever. If every core is taken, the
system hangs.
PoC code: (Run as many times as cores on SMP machines.)
int main(void)
int ret;
int csd;
int lsd;
struct sockaddr_un sun;
/* make an abstruct name address (*) */
memset(&sun, 0, sizeof(sun));
sun.sun_family = PF_UNIX;
sprintf(&sun.sun_path[1], "%d", getpid());
/* create the listening socket and shutdown */
lsd = socket(AF_UNIX, SOCK_STREAM, 0);
bind(lsd, (struct sockaddr *)&sun, sizeof(sun));
listen(lsd, 1);
shutdown(lsd, SHUT_RDWR);
/* connect loop */
alarm(15); /* forcely exit the loop after 15 sec */
for (;;) {
csd = socket(AF_UNIX, SOCK_STREAM, 0);
ret = connect(csd, (struct sockaddr *)&sun, sizeof(sun));
if (-1 == ret) {
perror("connect()");
break;
puts("Connection OK");
return 0;
(*) Make sun_path[0] = 0 to use the abstruct namespace.
If a file-based socket is used, the system doesn't deadlock because
of context switches in the file system layer.
Why this happens:
Error checks between unix_socket_connect() and unix_wait_for_peer() are
inconsistent. The former calls the latter to wait until the backlog is
processed. Despite the latter returns without doing anything when the
socket is shutdown, the former doesn't check the shutdown state and
just retries calling the latter forever.
Patch:
The patch below adds shutdown check into unix_socket_connect(), so
connect(2) to the shutdown socket will return -ECONREFUSED.
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama.qu@hitachi.com>
Signed-off-by: Masanori Yoshida <masanori.yoshida.tv@hitachi.com>
netfilter: bridge: refcount fix
Upstream commit f3abc9b9:
commit f216f082b2b37c4943f1e7c393e2786648d48f6f
([NETFILTER]: bridge netfilter: deal with martians correctly)
added a refcount leak on in_dev.
Instead of using in_dev_get(), we can use __in_dev_get_rcu(),
as netfilter hooks are running under rcu_read_lock(), as pointed
by Patrick.
fixed upstream in commit b7058842c940ad2c08dd829b21e5c92ebe3b8758 in a different way
The length of the to-copy data structure is currently stored in
a signed integer. However many comparisons are done with sizeof(..)
which is unsigned. It's more suitable for this variable to be unsigned
to make these comparisons more naturally right.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The ax25 code tried to use
if (optlen < sizeof(int))
return -EINVAL;
as a security check against optlen being negative (or zero) in the
set socket option.
Unfortunately, "sizeof(int)" is an unsigned property, with the
result that the whole comparison is done in unsigned, letting
negative values slip through.
This patch changes this to
if (optlen < (int)sizeof(int))
return -EINVAL;
so that the comparison is done as signed, and negative values
get properly caught.
[ Upstream commit 144586301f6af5ae5943a002f030d8c626fa4fdd ]
memcpy() should take into account size of pointers,
not only number of pointers to copy.
Acked-by: Pavel Emelyanov <xemul@openvz.org>
This fixes a problem that was reported as Red Hat Bugzilla entry number
485339, in which rpciod starts looping on the TCP connection code,
rendering the NFS client unusable for 1/2 minute or so.
It is basically a backport of commit
f75e6745aa3084124ae1434fd7629853bdaf6798 (SUNRPC: Fix the problem of
EADDRNOTAVAIL syslog floods on reconnect)
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 17ac2e9c58b69a1e25460a568eae1b0dc0188c25 upstream.
rose_getname() can leak kernel memory to user.
commit f6b97b29513950bfbf621a83d85b6f86b39ec8db upstream.
nr_getname() can leak kernel memory to user.
commit 28e9fc592cb8c7a43e4d3147b38be6032a0e81bc upstream.
sllc_arphrd member of sockaddr_llc might not be changed. Zero sllc
before copying to the above layer's structure.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
commit 09384dfc76e526c3993c09c42e016372dc9dd22c upstream.
irda_getname() can leak kernel memory to user.
commit 80922bbb12a105f858a8f0abb879cb4302d0ecaa upstream.
econet_getname() can leak kernel memory to user.
commit e84b90ae5eb3c112d1f208964df1d8156a538289 upstream.
raw_getname() can leak 10 bytes of kernel memory to user
(two bytes hole between can_family and can_ifindex,
8 bytes at the end of sockaddr_can structure)
Acked-by: Oliver Hartkopp <oliver@hartkopp.net>
commit 3d392475c873c10c10d6d96b94d092a34ebd4791 upstream.
atalk_getname() can leak 8 bytes of kernel memory to user
commit 2574cc9f4ffc6c681c9177111357efe5b76f0e36 upstream.
This patch fixes the bug that was reported in
http://bugzilla.kernel.org/show_bug.cgi?id=14053
If we're in the case where we need to force a reencode and then resend of
the RPC request, due to xprt_transmit failing with a networking error, then
we _must_ retransmit the entire request.
commit e694958388c50148389b0e9b9e9e8945cf0f1b98 upstream.
kernel_sendpage() does the proper default case handling for when the
socket doesn't have a native sendpage implementation.
Now, arguably this might be something that we could instead solve by
just specifying that all protocols should do it themselves at the
protocol level, but we really only care about the common protocols.
Does anybody really care about sendpage on something like Appletalk? Not
likely.
Acked-by: Julien TINNES <julien@cr0.org>
Acked-by: Tavis Ormandy <taviso@sdf.lonestar.org>
[ Upstream commit 14ebaf81e13ce66bff275380b246796fd16cbfa1 ]
If socket destuction gets delayed to a timer, we try to
lock_sock() from that timer which won't work.
Use bh_lock_sock() in that case.
Tested-by: Ingo Molnar <mingo@elte.hu>
[ Upstream commit 245acb87729bc76ba65c7476665c01837e0cdccb ]
Our CAST algorithm is called cast5, not cast128. Clearly nobody
has ever used it :)
commit 40d2549db5f515e415894def98b49db7d4c56714 upstream.
commit 670f94573104b4a25525d3fcdcd6496c678df172 upstream.
...so that we can distinguish between when we need to shutdown and when we
don't. Also remove the call to xs_tcp_shutdown() from xs_tcp_connect(),
since xprt_connect() makes the same test.
commit 15f081ca8ddfe150fb639c591b18944a539da0fc upstream.
If the socket is unconnected, and xprt_transmit() returns ENOTCONN, we
currently give up the lock on the transport channel. Doing so means that
the lock automatically gets assigned to the next task in the xprt->sending
queue, and so that task needs to be woken up to do the actual connect.
The following patch aims to avoid that unnecessary task switch.
commit f5fff5dc8a7a3f395b0525c02ba92c95d42b7390 upstream.
I'm trying to use the TCP_MAXSEG option to setsockopt() to set the MSS
for both sides of a bidirectional connection.
man tcp says: "If this option is set before connection establishment, it
also changes the MSS value announced to the other end in the initial
packet."
However, the kernel only uses the MTU/route cache to set the advertised
MSS. That means if I set the MSS to, say, 500 before calling connect(),
I will send at most 500-byte packets, but I will still receive 1500-byte
packets in reply.
This is a bug, either in the kernel or the documentation.
This patch (applies to latest net-2.6) reduces the advertised value to
that requested by the user as long as setsockopt() is called before
connect() or accept(). This seems like the behavior that one would
expect as well as that which is documented.
I've tried to make sure that things that depend on the advertised MSS
are set correctly.
Signed-off-by: Tom Quetchenbach <virtualphtn@gmail.com>
Cc: Willy Tarreau <w@1wt.eu>
commit a8659597bf744b0f8d2560e2a734b5c941569e0e upstream
pid doesn't count with some band having more bitrates than the one
associated the first time.
Fix that by counting the maximal available bitrate count and allocate
big enough space.
Secondly, fix touching uninitialized memory which causes panics.
Index sucked from this random memory points to the hell.
The fix is to sort the rates on each band change.
Also remove a comment which is wrong now.
This version also contains half of
mac80211: avoid NULL ptr deref when finding max_rates in PID and minstrel
patch by John W. Linville, which is namely:
- if (sband->n_bitrates > max_rates)
+ if (sband && sband->n_bitrates > max_rates)
to fix oopses on one band devices.
Cc: John W. Linville <linville@tuxdriver.com>
[ Upstream commit 86bcebafc5e7f5163ccf828792fe694b112ed6fa ]
A long-standing feature in tcp_init_metrics() is such that
any of its goto reset prevents call to tcp_init_cwnd().
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
[ Upstream commit 995b337952cdf7e05d288eede580257b632a8343 ]
When called with a consumed value that is less than skb_headlen(skb)
bytes into a page frag, skb_seq_read() incorrectly returns an
offset/length relative to skb->data. Ensure that data which should come
from a page frag does.
Signed-off-by: Thomas Chenault <thomas_chenault@dell.com>
Tested-by: Shyam Iyer <shyam_iyer@dell.com>
[ Upstream commit 5b5f792a6a9a2f9ae812d151ed621f72e99b1725 ]
typo -- pkt_dev->nflows is for stats only, the number of concurrent
flows is stored in cflows.
Reported-By: Vladimir Ivashchenko <hazard@francoudi.com>
upstream commit: 1f9352ae2253a97b07b34dcf16ffa3b4ca12c558
Commit e1b4b9f ([NETFILTER]: {ip,ip6,arp}_tables: fix exponential worst-case
search for loops) introduced a regression in the loop detection algorithm,
causing sporadic incorrectly detected loops.
When a chain has already been visited during the check, it is treated as
having a standard target containing a RETURN verdict directly at the
beginning in order to not check it again. The real target of the first
rule is then incorrectly treated as STANDARD target and checked not to
contain invalid verdicts.
Fix by making sure the rule does actually contain a standard target.
Based on patch by Francis Dupont <Francis_Dupont@isc.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: cc29c70dd581f85ee7a3e7980fb031f90b90a2ab
Patch "af_rose/x25: Sanity check the maximum user frame size"
(commit 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9) from Alan Cox got
locking wrong. If we bail out due to user frame size being too large,
we must unlock the socket beforehand.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
upstream commit: 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9
CVE-2009-0795.
Otherwise we can wrap the sizes and end up sending garbage.
Closes #10423
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
[ Upstream commit cb0dc77de0d23615a845e45844a2e22fc224d7fe ]
broken by commit 5e739d1752aca4e8f3e794d431503bfca3162df4; AFAICS should
be -stable fodder as well...
Aced-by: Vlad Yasevich <vladislav.yasevich@hp.com>
[ Upstream commit 534f81a5068799799e264fd162e9488a129f98d4 ]
This patch fixes an unaligned memory access in tcp_sack while reading
sequence numbers from TCP selective acknowledgement options. Prior to
applying this patch, upstream linux-2.6.27.20 was occasionally
generating messages like this on my sparc64 system:
[54678.532071] Kernel unaligned access at TPC[6b17d4] tcp_packet+0xcd4/0xd00
[ Upstream commit 71f6f6dfdf7c7a67462386d9ea05c1095a89c555 ]
Commit 778d80be52699596bf70e0eb0761cf5e1e46088d
(ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface)
seems to have introduced a leak of sk_buff's for ipv6 traffic,
at least in some configurations where idev is NULL, or when ipv6
is disabled via sysctl.
The problem is that if the first condition of the if-statement
returns non-NULL, it returns an skb with only one reference,
and when the other conditions apply, execution jumps to the "out"
label, which does not call kfree_skb for it.
To plug this leak, change to use the "drop" label instead.
(this relies on it being ok to call kfree_skb on NULL)
This also allows us to avoid calling rcu_read_unlock here,
and removes the only user of the "out" label.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
[ Upstream commit 3f53a38131a4e7a053c0aa060aba0411242fb6b9 ]
We already have a valid net in that place, but this is not just a
cleanup - the tw pointer can be NULL there sometimes, thus causing
an oops in NET_NS=y case.
The same place in ipv4 code already works correctly using existing
net, rather than tw's one.
The bug exists since 2.6.27.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
[ Upstream commit cda6d377ec6b2ee2e58d563d0bd7eb313e0165df ]
This fixes an crash when empty bond device is added to a bridge.
If an interface with invalid ethernet address (all zero) is added
to a bridge, then bridge code detects it when setting up the forward
databas entry. But the error unwind is broken, the bridge port object
can get freed twice: once when ref count went to zeo, and once by kfree.
Since object is never really accessible, just free it.
