[ Upstream commit 97a804102021431fa6fa33c21c85df762b0f5cb9 ]
As rt_iif represents input device even for packets
coming from loopback with output route, it is not an unique
key specific to input routes. Now rt_route_iif has such role,
it was fl.iif in 2.6.38, so better to change the checks at
some places to save CPU cycles and to restore 2.6.38 semantics.
compare_keys:
- input routes: only rt_route_iif matters, rt_iif is same
- output routes: only rt_oif matters, rt_iif is not
used for matching in __ip_route_output_key
- now we are back to 2.6.38 state
ip_route_input_common:
- matching rt_route_iif implies input route
- compared to 2.6.38 we eliminated one rth->fl.oif check
because it was not needed even for 2.6.38
compare_hash_inputs:
Only the change here is not an optimization, it has
effect only for output routes. I assume I'm restoring
the original intention to ignore oif, it was using fl.iif
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit 561dac2d410ffac0b57a23b85ae0a623c1a076ca ]
add new fib rule can cause BUG_ON happen
the reproduce shell is
ip rule add pref 38
ip rule add pref 38
ip rule add to 192.168.3.0/24 goto 38
ip rule del pref 38
ip rule add pref 38
then the BUG_ON will happen
del BUG_ON and use (ctarget == NULL) identify whether this rule is unresolved
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit 11f3a6bdc2528d1ce2af50202dbf7138fdee1b34 ]
Jan Beulich reported a possible net_device leak in bridge code after
commit bb900b27a2f4 (bridge: allow creating bridge devices with netlink)
Reported-by: Jan Beulich <JBeulich@novell.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
[ Upstream commit 20e6074eb8e096b3a595c093d1cb222f378cd671 ]
Dave Jones reported a lockdep splat triggered by an arp_process() call
from parp_redo().
Commit faa9dcf793be (arp: RCU changes) is the origin of the bug, since
it assumed arp_process() was called under rcu_read_lock(), which is not
true in this particular path.
Instead of adding rcu_read_lock() in parp_redo(), I chose to add it in
neigh_proxy_process() to take care of IPv6 side too.
[ INFO: suspicious rcu_dereference_check() usage. ]
include/linux/inetdevice.h:209 invoked rcu_dereference_check() without
protection!
rcu_scheduler_active = 1, debug_locks = 0
4 locks held by setfiles/2123:
#0: (&sb->s_type->i_mutex_key#13){+.+.+.}, at: [<ffffffff8114cbc4>]
walk_component+0x1ef/0x3e8
#1: (&isec->lock){+.+.+.}, at: [<ffffffff81204bca>]
inode_doinit_with_dentry+0x3f/0x41f
#2: (&tbl->proxy_timer){+.-...}, at: [<ffffffff8106a803>]
run_timer_softirq+0x157/0x372
#3: (class){+.-...}, at: [<ffffffff8141f256>] neigh_proxy_process
+0x36/0x103
stack backtrace:
Pid: 2123, comm: setfiles Tainted: G W
3.1.0-0.rc2.git7.2.fc16.x86_64 #1
Call Trace:
<IRQ> [<ffffffff8108ca23>] lockdep_rcu_dereference+0xa7/0xaf
[<ffffffff8146a0b7>] __in_dev_get_rcu+0x55/0x5d
[<ffffffff8146a751>] arp_process+0x25/0x4d7
[<ffffffff8146ac11>] parp_redo+0xe/0x10
[<ffffffff8141f2ba>] neigh_proxy_process+0x9a/0x103
[<ffffffff8106a8c4>] run_timer_softirq+0x218/0x372
[<ffffffff8106a803>] ? run_timer_softirq+0x157/0x372
[<ffffffff8141f220>] ? neigh_stat_seq_open+0x41/0x41
[<ffffffff8108f2f0>] ? mark_held_locks+0x6d/0x95
[<ffffffff81062bb6>] __do_softirq+0x112/0x25a
[<ffffffff8150d27c>] call_softirq+0x1c/0x30
[<ffffffff81010bf5>] do_softirq+0x4b/0xa2
[<ffffffff81062f65>] irq_exit+0x5d/0xcf
[<ffffffff8150dc11>] smp_apic_timer_interrupt+0x7c/0x8a
[<ffffffff8150baf3>] apic_timer_interrupt+0x73/0x80
<EOI> [<ffffffff8108f439>] ? trace_hardirqs_on_caller+0x121/0x158
[<ffffffff814fc285>] ? __slab_free+0x30/0x24c
[<ffffffff814fc283>] ? __slab_free+0x2e/0x24c
[<ffffffff81204e74>] ? inode_doinit_with_dentry+0x2e9/0x41f
[<ffffffff81130cb0>] kfree+0x108/0x131
[<ffffffff81204e74>] inode_doinit_with_dentry+0x2e9/0x41f
[<ffffffff81204fc6>] selinux_d_instantiate+0x1c/0x1e
[<ffffffff81200f4f>] security_d_instantiate+0x21/0x23
[<ffffffff81154625>] d_instantiate+0x5c/0x61
[<ffffffff811563ca>] d_splice_alias+0xbc/0xd2
[<ffffffff811b17ff>] ext4_lookup+0xba/0xeb
[<ffffffff8114bf1e>] d_alloc_and_lookup+0x45/0x6b
[<ffffffff8114cbea>] walk_component+0x215/0x3e8
[<ffffffff8114cdf8>] lookup_last+0x3b/0x3d
[<ffffffff8114daf3>] path_lookupat+0x82/0x2af
[<ffffffff8110fc53>] ? might_fault+0xa5/0xac
[<ffffffff8110fc0a>] ? might_fault+0x5c/0xac
[<ffffffff8114c564>] ? getname_flags+0x31/0x1ca
[<ffffffff8114dd48>] do_path_lookup+0x28/0x97
[<ffffffff8114df2c>] user_path_at+0x59/0x96
[<ffffffff811467ad>] ? cp_new_stat+0xf7/0x10d
[<ffffffff811469a6>] vfs_fstatat+0x44/0x6e
[<ffffffff811469ee>] vfs_lstat+0x1e/0x20
[<ffffffff81146b3d>] sys_newlstat+0x1a/0x33
[<ffffffff812535fe>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8150af82>] system_call_fastpath+0x16/0x1b
Reported-by: Dave Jones <davej@redhat.com>
commit aa3d7eef398dd4f29045e9889b817d5161afe03e upstream.
During the association, the regulatory is updated by country IE
that reaps the previously found beacons. The impact is that
after a STA disconnects *or* when for any reason a regulatory
domain change happens the beacon hint flag is not cleared
therefore preventing future beacon hints to be learned.
This is important as a regulatory domain change or a restore
of regulatory settings would set back the passive scan and no-ibss
flags on the channel. This is the right place to do this given that
it covers any regulatory domain change.
Reviewed-by: Luis R. Rodriguez <mcgrof@gmail.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
commit 4bae7d976976fa52d345805ba686934cd548343e upstream.
Since my commit 34e895075e21be3e21e71d6317440d1ee7969ad0
("mac80211: allow station add/remove to sleep") there is
a race in mac80211 when it clears the TIM bit because a
sleeping station disconnected, the spinlock isn't held
around the relevant code any more. Use the right API to
acquire the spinlock correctly.
commit b49d8b5d7007a673796f3f99688b46931293873e upstream.
With msize equal to 512K (PAGE_SIZE * VIRTQUEUE_NUM), we hit multiple
crashes. This patch fix those.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
commit c9ffb05ca5b5098d6ea468c909dd384d90da7d54 upstream.
msize represents the maximum PDU size that includes P9_IOHDRSZ.
Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com>
commit 5034990e28efb2d232ee82443a9edd62defd17ba upstream.
free the fid even in case of failed clunk.
commit 7f781679dd596c8abde8336b4d0d166d6a4aad04 upstream.
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 114e6f3a5ede73d5b56e145f04680c61c3dd67c4 upstream.
commit b85f7d92d7bd7e3298159e8b1eed8cb8cbbb0348 upstream.
There was a BUG_ON to protect against a bad id which could be dealt with
more gracefully.
Reported-by: Natalie Orlin <norlin@us.ibm.com>
commit fbe5e29ec1886967255e76946aaf537b8cc9b81e upstream.
This oops have been already fixed with commit
27141666b69f535a4d63d7bc6d9e84ee5032f82a
atm: [br2684] Fix oops due to skb->dev being NULL
It happens that if a packet arrives in a VC between the call to open it on
the hardware and the call to change the backend to br2684, br2684_regvcc
processes the packet and oopses dereferencing skb->dev because it is
NULL before the call to br2684_push().
but have been introduced again with commit
b6211ae7f2e56837c6a4849316396d1535606e90
atm: Use SKB queue and list helpers instead of doing it by-hand.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
commit bc909d9ddbf7778371e36a651d6e4194b1cc7d4c upstream.
Dereferencing a user pointer directly from kernel-space without going
through the copy_from_user family of functions is a bad idea. Two of
such usages can be found in the sendmsg code path called from sendmmsg,
added by
commit c71d8ebe7a4496fb7231151cb70a6baa0cb56f9a upstream.
commit 5b47b8038f183b44d2d8ff1c7d11a5c1be706b34 in the 3.0-stable tree.
Usages are performed through memcmp() and memcpy() directly. Fix those
by using the already copied msg_sys structure instead of the __user *msg
structure. Note that msg_sys can be set to NULL by verify_compat_iovec()
or verify_iovec(), which requires additional NULL pointer checks.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: David Goulet <dgoulet@ev0ke.net>
CC: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
CC: Anton Blanchard <anton@samba.org>
CC: David S. Miller <davem@davemloft.net>
commit a08af810cdc29d2ca930e8a869d3d01744c392d8 upstream.
Reported-by: Pascal Hambourg <pascal@plouf.fr.eu.org>
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
[ Upstream commit 559fafb94ad9e4cd8774f39241917c57396f9fc5 ]
Fix improper protocol err_handler, current implementation is fully
unapplicable and may cause kernel crash due to double kfree_skb.
Signed-off-by: Dmitry Kozlov <xeb@mail.ru>
[ Upstream commit b0fe4a31849063fcac0bdc93716ca92615e93f57 ]
rt_tos was changed to iph->tos but it must be filtered by RT_TOS
[ Upstream commit 1821f7cd65ad9ea56580b830ac79bf4c4fef59cb ]
As reported by Ben Greer and Froncois Romieu. The code path in
the netif_carrier code leads it to try and disable
a late workqueue to reenable it immediately
netif_carrier_on
-> linkwatch_fire_event
-> linkwatch_schedule_work
-> cancel_delayed_work
-> del_timer_sync
If __cancel_delayed_work is used instead then there is no
problem of waiting for running linkwatch_event.
There is a race between linkwatch_event running re-scheduling
but it is harmless to schedule an extra scan of the linkwatch queue.
[ Upstream commit 4203223a1aed862b4445fdcd260d6139603a51d9 ]
Fix the min and max bit lengths for AES-CTR (RFC3686) keys.
The number of bits in key spec is the key length (128/256)
plus 32 bits of nonce.
This change takes care of the "Invalid key length" errors
reported by setkey when specifying 288 bit keys for aes-ctr.
Signed-off-by: Tushar Gohad <tgohad@mvista.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit 550fd08c2cebad61c548def135f67aba284c6162 ]
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
[ Upstream commit d8873315065f1f527c7c380402cf59b1e1d0ae36 ]
Pktgen attempts to transmit shared skbs to net devices, which can't be used by
some drivers as they keep state information in skbs. This patch adds a flag
marking drivers as being able to handle shared skbs in their tx path. Drivers
are defaulted to being unable to do so, but calling ether_setup enables this
flag, as 90% of the drivers calling ether_setup touch real hardware and can
handle shared skbs. A subsequent patch will audit drivers to ensure that the
flag is set properly
Reported-by: Jiri Pirko <jpirko@redhat.com>
CC: Robert Olsson <robert.olsson@its.uu.se>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Alexey Dobriyan <adobriyan@gmail.com>
[ Upstream commit b76d0789c92a816a5539dc14232a700b8d62a53a ]
If a device event generates gratuitous ARP messages, only primary
address is used for sending. This patch iterates through the whole
list. Tested with 2 IP addresses configuration on bonding interface.
Signed-off-by: Zoltan Kiss <schaman@sch.bme.hu>
[ Upstream commit e1738bd9cecc5c867b0e2996470c1ff20f66ba79 ]
commit 8efa88540635 (sch_sfq: avoid giving spurious NET_XMIT_CN signals)
forgot to call qdisc_tree_decrease_qlen() to signal upper levels that a
packet (from another flow) was dropped, leading to various problems.
With help from Michal Soltys and Michal Pokrywka, who did a bisection.
Bugzilla ref: https://bugzilla.kernel.org/show_bug.cgi?id=39372
Debian ref: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=631945
Reported-by: Lucas Bocchi <lucas.bocchi@gmail.com>
Reported-and-bisected-by: Michal Pokrywka <wolfmoon@o2.pl>
CC: Michal Soltys <soltys@ziu.info>
Acked-by: Patrick McHardy <kaber@trash.net>
[ Upstream commit a1889c0d2039a53ae04abb9f20c62500bd312bf3 ]
Convert array index from the loop bound to the loop index.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression e1,e2,ar;
for(e1 = 0; e1 < e2; e1++) { <...
ar[
- e2
+ e1
// </smpl>
[ Upstream commit 7676e345824f162191b1fe2058ad948a6cf91c20 ]
This resolves a panic on module removal.
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit d547f727df86059104af2234804fdd538e112015 ]
compare_keys and ip_route_input_common rely on
rt_oif for distinguishing of input and output routes
with same keys values. But sometimes the input route has
also same hash chain (keyed by iif != 0) with the output
routes (keyed by orig_oif=0). Problem visible if running
with small number of rhash_entries.
Fix them to use rt_route_iif instead. By this way
input route can not be returned to users that request
output route.
The patch fixes the ip_rt_bug errors that were
reported in ip_local_out context, mostly for 255.255.255.255
destinations.
[ Upstream commit d9be4f7a6f5a8da3133b832eca41c3591420b1ca ]
Because the ip fragment offset field counts 8-byte chunks, ip
fragments other than the last must contain a multiple of 8 bytes of
payload. ip_ufo_append_data wasn't respecting this constraint and,
depending on the MTU and ip option sizes, could create malformed
non-final fragments.
Google-Bug-Id: 5009328
Signed-off-by: Bill Sommerfeld <wsommerfeld@google.com>
[ Upstream commit 415b3334a21aa67806c52d1acf4e72e14f7f402f ]
icmp_route_lookup() uses the wrong flow parameters if the reverse
session route lookup isn't used.
So do not commit to the re-decoded flow until we actually make a
final decision to use a real route saved in 'rt2'.
Reported-by: Florian Westphal <fw@strlen.de>
[ Backport of upstream commit 87c48fa3b4630905f98268dde838ee43626a060c ]
Fernando Gont reported current IPv6 fragment identification generation
was not secure, because using a very predictable system-wide generator,
allowing various attacks.
IPv4 uses inetpeer cache to address this problem and to get good
performance. We'll use this mechanism when IPv6 inetpeer is stable
enough in linux-3.1
For the time being, we use jhash on destination address to provide less
predictable identifications. Also remove a spinlock and use cmpxchg() to
get better SMP performance.
Reported-by: Fernando Gont <fernando@gont.com.ar>
Computers have become a lot faster since we compromised on the
partial MD4 hash which we use currently for performance reasons.
MD5 is a much safer choice, and is inline with both RFC1948 and
other ISS generators (OpenBSD, Solaris, etc.)
Furthermore, only having 24-bits of the sequence number be truly
unpredictable is a very serious limitation. So the periodic
regeneration and 8-bit counter have been removed. We compute and
use a full 32-bit sequence number.
For ipv6, DCCP was found to use a 32-bit truncated initial sequence
number (it needs 43-bits) and that is fixed here as well.
Reported-by: Dan Kaminsky <dan@doxpara.com>
Tested-by: Willy Tarreau <w@1wt.eu>
The sendmmsg() introduced by commit 228e548e "net: Add sendmmsg socket system
call" is capable of sending to multiple different destination addresses.
SMACK is using destination's address for checking sendmsg() permission.
However, security_socket_sendmsg() is called for only once even if multiple
different destination addresses are passed to sendmmsg().
Therefore, we need to call security_socket_sendmsg() for each destination
address rather than only the first destination address.
Since calling security_socket_sendmsg() every time when only single destination
address was passed to sendmmsg() is a waste of time, omit calling
security_socket_sendmsg() unless destination address of previous datagram and
that of current datagram differs.
Acked-by: Anton Blanchard <anton@samba.org>
commit 98382f419f32d2c12d021943b87dea555677144b upstream.
To limit the amount of time we can spend in sendmmsg, cap the
number of elements to UIO_MAXIOV (currently 1024).
For error handling an application using sendmmsg needs to retry at
the first unsent message, so capping is simpler and requires less
application logic than returning EINVAL.
commit 728ffb86f10873aaf4abd26dde691ee40ae731fe upstream.
sendmmsg uses a similar error return strategy as recvmmsg but it
turns out to be a confusing way to communicate errors.
The current code stores the error code away and returns it on the next
sendmmsg call. This means a call with completely valid arguments could
get an error from a previous call.
Change things so we only return an error if no datagrams could be sent.
If less than the requested number of messages were sent, the application
must retry starting at the first failed one and if the problem is
persistent the error will be returned.
This matches the behaviour of other syscalls like read/write - it
is not an error if less than the requested number of elements are sent.
commit a203c2aa4cefccb879c879b8e1cad1a09a679e55 upstream.
At the beginning of wiphy_update_regulatory() a check is performed
whether the request is to be ignored. Then the request is sent to
the driver nevertheless. This happens even if last_request points
to NULL, leading to a crash in the driver:
[<bf01d864>] (lbs_set_11d_domain_info+0x28/0x1e4 [libertas]) from [<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4)
[<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4) from [<c03b4008>] (wiphy_register+0x354/0x420)
[<c03b4008>] (wiphy_register+0x354/0x420) from [<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas])
[<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas]) from [<bf020e64>] (lbs_start_card+0x20/0x88 [libertas])
[<bf020e64>] (lbs_start_card+0x20/0x88 [libertas]) from [<bf02cbd8>] (if_sdio_probe+0x898/0x9c0 [libertas_sdio])
Fix this by returning early. Also remove the out: label as it is
not any longer needed.
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com>
Cc: linux-wireless@vger.kernel.org
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Daniel Mack <daniel@zonque.org>
commit ebc63e531cc6a457595dd110b07ac530eae788c3 upstream.
After commit 3262c816a3d7fb1eaabce633caa317887ed549ae "[PATCH] knfsd:
split svc_serv into pools", svc_delete_xprt (then svc_delete_socket) no
longer removed its xpt_ready (then sk_ready) field from whatever list it
was on, noting that there was no point since the whole list was about to
be destroyed anyway.
That was mostly true, but forgot that a few svc_xprt_enqueue()'s might
still be hanging around playing with the about-to-be-destroyed list, and
could get themselves into trouble writing to freed memory if we left
this xprt on the list after freeing it.
(This is actually functionally identical to a patch made first by Ben
Greear, but with more comments.)
Cc: gnb@fmeh.org
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Ben Greear <greearb@candelatech.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 676b58c27475a9defccc025fea1cbd2b141ee539 upstream.
A panic was observed when the device is failed to resume properly,
and there are no running interfaces. ieee80211_reconfig tries
to restart STA timers on unassociated state.
commit 67ae7cf1eeda777f79259c4c6cb17a0bd28dee71 upstream.
Some drivers (ab)use the ethtool_ops::get_regs operation to expose
only a hardware revision ID. Commit
a77f5db361ed9953b5b749353ea2c7fed2bf8d93 ('ethtool: Allocate register
dump buffer with vmalloc()') had the side-effect of breaking these, as
vmalloc() returns a null pointer for size=0 whereas kmalloc() did not.
For backward-compatibility, allow zero-length dumps again.
Reported-by: Kalle Valo <kvalo@qca.qualcomm.com>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit 0c03150e7ea8f7fcd03cfef29385e0010b22ee92 upstream.
A bridge topology with three systems:
| A(2) |--| B(1) |
| C(3) |
What is supposed to happen:
* bridge with the lowest ID is elected root (for example: B)
* C detects that A->C is higher cost path and puts in blocking state
What happens. Bridge with lowest id (B) is elected correctly as
root and things start out fine initially. But then config BPDU
doesn't get transmitted from A -> C. Because of that
the link from A-C is transistioned to the forwarding state.
The root cause of this is that the configuration messages
is generated with bogus message age, and dropped before
sending.
In the standardmessage_age is supposed to be:
the time since the generation of the Configuration BPDU by
the Root that instigated the generation of this Configuration BPDU.
Reimplement this by recording the timestamp (age + jiffies) when
recording config information. The old code incorrectly used the time
elapsed on the ageing timer which was incorrect.
See also:
https://bugzilla.vyatta.com/show_bug.cgi?id=7164
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: fix file mode calculation
open(2) must always include one of O_RDONLY, O_WRONLY, or O_RDWR. No need
for any O_APPEND special case.
Passing O_WRONLY|O_RDWR is undefined according to the man page, but the
Linux VFS interprets this as O_RDWR, so we'll do the same.
This fixes open(2) with flags O_RDWR|O_APPEND, which was incorrectly being
translated to readonly.
Reported-by: Fyodor Ustinov <ufm@ufm.su>
Signed-off-by: Sage Weil <sage@newdream.net>
Another regression fix considering incomming l2cap connections with
defer_setup enabled. In situations when incomming connection is
extracted with l2cap_sock_accept, it's bt_sock info will have
'parent' member zerroed, but 'parent' may be used unconditionally
in l2cap_conn_start() and l2cap_security_cfm() when defer_setup
is enabled.
Backtrace:
[<bf02d5ac>] (l2cap_security_cfm+0x0/0x2ac [bluetooth]) from [<bf01f01c>] (hci_event_pac
ket+0xc2c/0x4aa4 [bluetooth])
[<bf01e3f0>] (hci_event_packet+0x0/0x4aa4 [bluetooth]) from [<bf01a844>] (hci_rx_task+0x
cc/0x27c [bluetooth])
[<bf01a778>] (hci_rx_task+0x0/0x27c [bluetooth]) from [<c008eee4>] (tasklet_action+0xa0/
0x15c)
[<c008ee44>] (tasklet_action+0x0/0x15c) from [<c008f38c>] (__do_softirq+0x98/0x130)
r7:00000101 r6:00000018 r5:00000001 r4:efc46000
[<c008f2f4>] (__do_softirq+0x0/0x130) from [<c008f524>] (do_softirq+0x4c/0x58)
[<c008f4d8>] (do_softirq+0x0/0x58) from [<c008f5e0>] (run_ksoftirqd+0xb0/0x1b4)
r4:efc46000 r3:00000001
[<c008f530>] (run_ksoftirqd+0x0/0x1b4) from [<c009f2a8>] (kthread+0x84/0x8c)
r7:00000000 r6:c008f530 r5:efc47fc4 r4:efc41f08
[<c009f224>] (kthread+0x0/0x8c) from [<c008cc84>] (do_exit+0x0/0x5f0)
Signed-off-by: Ilia Kolomisnky <iliak@ti.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Caused by the following commit, partially revert it.
commit 9fa7e4f76f3658ba1f44fbdb95c77e7df3f53f95
Author: Gustavo F. Padovan <padovan@profusion.mobi>
Date: Thu Jun 30 16:11:30 2011 -0300
Bluetooth: Fix regression with incoming L2CAP connections
PTS test A2DP/SRC/SRC_SET/TC_SRC_SET_BV_02_I revealed that
( probably after the df3c3931e commit ) the l2cap connection
could not be established in case when the "Auth Complete" HCI
event does not arive before the initiator send "Configuration
request", in which case l2cap replies with "Command rejected"
since the channel is still in BT_CONNECT2 state.
Signed-off-by: Luiz Augusto von Dentz <luiz.von.dentz@intel.com>
There is no software fallback implemented for SCTP or FCoE checksumming,
and so it should not be passed on by software devices like bridge or bonding.
For VLAN devices, this is different. First, the driver for underlying device
should be prepared to get offloaded packets even when the feature is disabled
(especially if it advertises it in vlan_features). Second, devices under
VLANs do not get replaced without tearing down the VLAN first.
This fixes a mess I accidentally introduced while converting bonding to
ndo_fix_features.
NETIF_F_SOFT_FEATURES are removed from BOND_VLAN_FEATURES because they
are unused as of commit 712ae51afd.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Packets to devices without NETIF_F_SCTP_CSUM (including NETIF_F_NO_CSUM)
should be properly checksummed because the packets can be diverted or
rerouted after construction. This still leaves packets diverted from
NETIF_F_SCTP_CSUM-enabled devices with broken checksums. Fixing this
needs implementing software offload fallback in networking core.
For users of sctp_checksum_disable, skb->ip_summed should be left as
CHECKSUM_NONE and not CHECKSUM_UNNECESSARY as per include/linux/skbuff.h.
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
SUNRPC: Fix use of static variable in rpcb_getport_async
NFSv4.1: update nfs4_fattr_bitmap_maxsz
SUNRPC: Fix a race between work-queue and rpc_killall_tasks
pnfs: write: Set mds_offset in the generic layer - it is needed by all LDs
Because struct rpcbind_args *map was declared static, if two
threads entered this method at the same time, the values
assigned to map could be sent two two differen tasks.
This could cause all sorts of problems, include use-after-free
and double-free of memory.
Fix this by removing the static declaration so that the map
pointer is on the stack.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Cc: stable@kernel.org
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
closing socket
Trigger user ABORT if application closes a socket which has data
queued on the socket receive queue or chunks waiting on the
reassembly or ordering queue as this would imply data being lost
which defeats the point of a graceful shutdown.
This behavior is already practiced in TCP.
We do not check the input queue because that would mean to parse
all chunks on it to look for unacknowledged data which seems too
much of an effort. Control chunks or duplicated chunks may also
be in the input queue and should not be stopping a graceful
shutdown.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Upon "ip xfrm state update ..", xfrm_add_sa() takes an extra reference on
the user-supplied SA and forgets to drop the reference when
xfrm_state_update() returns 0. This leads to a memory leak as the
parameter SA is never freed. This change attempts to fix the leak by
calling __xfrm_state_put() when xfrm_state_update() updates a valid SA
(err = 0). The parameter SA is added to the gc list when the final
reference is dropped by xfrm_add_sa() upon completion.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
