path: root/net
2013-10-13net: Update the sysctl permissions handler to test effective uid/gidEric W. Biederman
commit 2433c8f094a008895e66f25bd1773cdb01c91d01 upstream. Modify the code to use current_euid(), and in_egroup_p, as in done in fs/proc/proc_sysctl.c:test_perm() Reviewed-by: Eric Sandeen <sandeen@redhat.com> Reported-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13Bluetooth: Fix rfkill functionality during the HCI setup stageJohan Hedberg
commit bf5430360ebe4b2d0c51d91f782e649107b502eb upstream. We need to let the setup stage complete cleanly even when the HCI device is rfkilled. Otherwise the HCI device will stay in an undefined state and never get notified to user space through mgmt (even when it gets unblocked through rfkill). This patch makes sure that hci_dev_open() can be called in the HCI_SETUP stage, that blocking the device doesn't abort the setup stage, and that the device gets proper powered down as soon as the setup stage completes in case it was blocked meanwhile. The bug that this patch fixed can be very easily reproduced using e.g. the rfkill command line too. By running "rfkill block all" before inserting a Bluetooth dongle the resulting HCI device goes into a state where it is never announced over mgmt, not even when "rfkill unblock all" is run. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13Bluetooth: Introduce a new HCI_RFKILLED flagJohan Hedberg
commit 5e130367d43ff22836bbae380d197d600fe8ddbb upstream. This makes it more convenient to check for rfkill (no need to check for dev->rfkill before calling rfkill_blocked()) and also avoids potential races if the RFKILL state needs to be checked from within the rfkill callback. Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13Bluetooth: Fix encryption key size for peripheral roleAndre Guedes
commit 89cbb4da0abee2f39d75f67f9fd57f7410c8b65c upstream. This patch fixes the connection encryption key size information when the host is playing the peripheral role. We should set conn->enc_key_ size in hci_le_ltk_request_evt, otherwise it is left uninitialized. Signed-off-by: Andre Guedes <andre.guedes@openbossa.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13Bluetooth: Fix security level for peripheral roleAndre Guedes
commit f8776218e8546397be64ad2bc0ebf4748522d6e3 upstream. While playing the peripheral role, the host gets a LE Long Term Key Request Event from the controller when a connection is established with a bonded device. The host then informs the LTK which should be used for the connection. Once the link is encrypted, the host gets an Encryption Change Event. Therefore we should set conn->pending_sec_level instead of conn-> sec_level in hci_le_ltk_request_evt. This way, conn->sec_level is properly updated in hci_encrypt_change_evt. Moreover, since we have a LTK associated to the device, we have at least BT_SECURITY_MEDIUM security level. Signed-off-by: Andre Guedes <andre.guedes@openbossa.org> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ip6tnl: allow to use rtnl ops on fb tunnelNicolas Dichtel
[ Upstream commit bb8140947a247b9aa15652cc24dc555ebb0b64b0 ] rtnl ops where introduced by c075b13098b3 ("ip6tnl: advertise tunnel param via rtnl"), but I forget to assign rtnl ops to fb tunnels. Now that it is done, we must remove the explicit call to unregister_netdevice_queue(), because the fallback tunnel is added to the queue in ip6_tnl_destroy_tunnels() when checking rtnl_link_ops of all netdevices (this is valid since commit 0bd8762824e7 ("ip6tnl: add x-netns support")). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sit: allow to use rtnl ops on fb tunnelNicolas Dichtel
[ Upstream commit 205983c43700ac3a81e7625273a3fa83cd2759b5 ] rtnl ops where introduced by ba3e3f50a0e5 ("sit: advertise tunnel param via rtnl"), but I forget to assign rtnl ops to fb tunnels. Now that it is done, we must remove the explicit call to unregister_netdevice_queue(), because the fallback tunnel is added to the queue in sit_destroy_tunnels() when checking rtnl_link_ops of all netdevices (this is valid since commit 5e6700b3bf98 ("sit: add support of x-netns")). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ip_tunnel: Fix a memory corruption in ip_tunnel_xmitSteffen Klassert
[ Upstream commit 3e08f4a72f689c6296d336c2aab4bddd60c93ae2 ] We might extend the used aera of a skb beyond the total headroom when we install the ipip header. Fix this by calling skb_cow_head() unconditionally. Bug was introduced with commit c544193214 ("GRE: Refactor GRE tunneling code.") Cc: Pravin Shelar <pshelar@nicira.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ipv6 mcast: use in6_dev_put in timer handlers instead of __in6_dev_putSalam Noureddine
[ Upstream commit 9260d3e1013701aa814d10c8fc6a9f92bd17d643 ] It is possible for the timer handlers to run after the call to ipv6_mc_down so use in6_dev_put instead of __in6_dev_put in the handler function in order to do proper cleanup when the refcnt reaches 0. Otherwise, the refcnt can reach zero without the inet6_dev being destroyed and we end up leaking a reference to the net_device and see messages like the following, unregister_netdevice: waiting for eth0 to become free. Usage count = 1 Tested on linux-3.4.43. Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ipv4 igmp: use in_dev_put in timer handlers instead of __in_dev_putSalam Noureddine
[ Upstream commit e2401654dd0f5f3fb7a8d80dad9554d73d7ca394 ] It is possible for the timer handlers to run after the call to ip_mc_down so use in_dev_put instead of __in_dev_put in the handler function in order to do proper cleanup when the refcnt reaches 0. Otherwise, the refcnt can reach zero without the in_device being destroyed and we end up leaking a reference to the net_device and see messages like the following, unregister_netdevice: waiting for eth0 to become free. Usage count = 1 Tested on linux-3.4.43. Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ipv6: gre: correct calculation of max_headroomHannes Frederic Sowa
[ Upstream commit 3da812d860755925da890e8c713f2d2e2d7b1bae ] gre_hlen already accounts for sizeof(struct ipv6_hdr) + gre header, so initialize max_headroom to zero. Otherwise the if (encap_limit >= 0) { max_headroom += 8; mtu -= 8; } increments an uninitialized variable before max_headroom was reset. Found with coverity: 728539 Cc: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: net_secret should not depend on TCPEric Dumazet
[ Upstream commit 9a3bab6b05383f1e4c3716b3615500c51285959e ] A host might need net_secret[] and never open a single socket. Problem added in commit aebda156a570782 ("net: defer net_secret[] initialization") Based on prior patch from Hannes Frederic Sowa. Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Hannes Frederic Sowa <hannes@strressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13IPv6 NAT: Do not drop DNATed 6to4/6rd packetsCatalin(ux) M. BOIE
[ Upstream commit 7df37ff33dc122f7bd0614d707939fe84322d264 ] When a router is doing DNAT for 6to4/6rd packets the latest anti-spoofing commit 218774dc ("ipv6: add anti-spoofing checks for 6to4 and 6rd") will drop them because the IPv6 address embedded does not match the IPv4 destination. This patch will allow them to pass by testing if we have an address that matches on 6to4/6rd interface. I have been hit by this problem using Fedora and IPV6TO4_IPV4ADDR. Also, log the dropped packets (with rate limit). Signed-off-by: Catalin(ux) M. BOIE <catab@embedromix.ro> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ipv6: udp packets following an UFO enqueued packet need also be handled by UFOHannes Frederic Sowa
[ Upstream commit 2811ebac2521ceac84f2bdae402455baa6a7fb47 ] In the following scenario the socket is corked: If the first UDP packet is larger then the mtu we try to append it to the write queue via ip6_ufo_append_data. A following packet, which is smaller than the mtu would be appended to the already queued up gso-skb via plain ip6_append_data. This causes random memory corruptions. In ip6_ufo_append_data we also have to be careful to not queue up the same skb multiple times. So setup the gso frame only when no first skb is available. This also fixes a shortcoming where we add the current packet's length to cork->length but return early because of a packet > mtu with dontfrag set (instead of sutracting it again). Found with trinity. Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ip: generate unique IP identificator if local fragmentation is allowedAnsis Atteka
[ Upstream commit 703133de331a7a7df47f31fb9de51dc6f68a9de8 ] If local fragmentation is allowed, then ip_select_ident() and ip_select_ident_more() need to generate unique IDs to ensure correct defragmentation on the peer. For example, if IPsec (tunnel mode) has to encrypt large skbs that have local_df bit set, then all IP fragments that belonged to different ESP datagrams would have used the same identificator. If one of these IP fragments would get lost or reordered, then peer could possibly stitch together wrong IP fragments that did not belong to the same datagram. This would lead to a packet loss or data corruption. Signed-off-by: Ansis Atteka <aatteka@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ip: use ip_hdr() in __ip_make_skb() to retrieve IP headerAnsis Atteka
[ Upstream commit 749154aa56b57652a282cbde57a57abc278d1205 ] skb->data already points to IP header, but for the sake of consistency we can also use ip_hdr() to retrieve it. Signed-off-by: Ansis Atteka <aatteka@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net:dccp: do not report ICMP redirects to user spaceDuan Jiong
[ Upstream commit bd784a140712fd06674f2240eecfc4ccae421129 ] DCCP shouldn't be setting sk_err on redirects as it isn't an error condition. it should be doing exactly what tcp is doing and leaving the error handler without touching the socket. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: sctp: rfc4443: do not report ICMP redirects to user spaceDaniel Borkmann
[ Upstream commit 3f96a532113131d5a65ac9e00fc83cfa31b0295f ] Adapt the same behaviour for SCTP as present in TCP for ICMP redirect messages. For IPv6, RFC4443, section 2.4. says: ... (e) An ICMPv6 error message MUST NOT be originated as a result of receiving the following: ... (e.2) An ICMPv6 redirect message [IPv6-DISC]. ... Therefore, do not report an error to user space, just invoke dst's redirect callback and leave, same for IPv4 as done in TCP as well. The implication w/o having this patch could be that the reception of such packets would generate a poll notification and in worst case it could even tear down the whole connection. Therefore, stop updating sk_err on redirects. Reported-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Suggested-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ip6_tunnels: raddr and laddr are inverted in nl msgDing Zhi
[ Upstream commit 0d2ede929f61783aebfb9228e4d32a0546ee4d23 ] IFLA_IPTUN_LOCAL and IFLA_IPTUN_REMOTE were inverted. Introduced by c075b13098b3 (ip6tnl: advertise tunnel param via rtnl). Signed-off-by: Ding Zhi <zhi.ding@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13bridge: fix NULL pointer deref of br_port_get_rcuHong Zhiguo
[ Upstream commit 716ec052d2280d511e10e90ad54a86f5b5d4dcc2 ] The NULL deref happens when br_handle_frame is called between these 2 lines of del_nbp: dev->priv_flags &= ~IFF_BRIDGE_PORT; /* --> br_handle_frame is called at this time */ netdev_rx_handler_unregister(dev); In br_handle_frame the return of br_port_get_rcu(dev) is dereferenced without check but br_port_get_rcu(dev) returns NULL if: !(dev->priv_flags & IFF_BRIDGE_PORT) Eric Dumazet pointed out the testing of IFF_BRIDGE_PORT is not necessary here since we're in rcu_read_lock and we have synchronize_net() in netdev_rx_handler_unregister. So remove the testing of IFF_BRIDGE_PORT and by the previous patch, make sure br_port_get_rcu is called in bridging code. Signed-off-by: Hong Zhiguo <zhiguohong@tencent.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13bridge: use br_port_get_rtnl within rtnl lockHong Zhiguo
[ Upstream commit 1fb1754a8c70d69ab480763c423e0a74369c4a67 ] current br_port_get_rcu is problematic in bridging path (NULL deref). Change these calls in netlink path first. Signed-off-by: Hong Zhiguo <zhiguohong@tencent.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13bridge: Clamp forward_delay when enabling STPHerbert Xu
[ Upstream commit be4f154d5ef0ca147ab6bcd38857a774133f5450 ] At some point limits were added to forward_delay. However, the limits are only enforced when STP is enabled. This created a scenario where you could have a value outside the allowed range while STP is disabled, which then stuck around even after STP is enabled. This patch fixes this by clamping the value when we enable STP. I had to move the locking around a bit to ensure that there is no window where someone could insert a value outside the range while we're in the middle of enabling STP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13resubmit bridge: fix message_age_timer calculationChris Healy
[ Upstream commit 9a0620133ccce9dd35c00a96405c8d80938c2cc0 ] This changes the message_age_timer calculation to use the BPDU's max age as opposed to the local bridge's max age. This is in accordance with section 8.6.2.3.2 Step 2 of the 802.1D-1998 sprecification. With the current implementation, when running with very large bridge diameters, convergance will not always occur even if a root bridge is configured to have a longer max age. Tested successfully on bridge diameters of ~200. Signed-off-by: Chris Healy <cphealy@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: sctp: fix ipv6 ipsec encryption bug in sctp_v6_xmitDaniel Borkmann
[ Upstream commit 95ee62083cb6453e056562d91f597552021e6ae7 ] Alan Chester reported an issue with IPv6 on SCTP that IPsec traffic is not being encrypted, whereas on IPv4 it is. Setting up an AH + ESP transport does not seem to have the desired effect: SCTP + IPv4: 22:14:20.809645 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 116) 192.168.0.2 > 192.168.0.5: AH(spi=0x00000042,sumlen=16,seq=0x1): ESP(spi=0x00000044,seq=0x1), length 72 22:14:20.813270 IP (tos 0x2,ECT(0), ttl 64, id 0, offset 0, flags [DF], proto AH (51), length 340) 192.168.0.5 > 192.168.0.2: AH(spi=0x00000043,sumlen=16,seq=0x1): SCTP + IPv6: 22:31:19.215029 IP6 (class 0x02, hlim 64, next-header SCTP (132) payload length: 364) fe80::222:15ff:fe87:7fc.3333 > fe80::92e6:baff:fe0d:5a54.36767: sctp 1) [INIT ACK] [init tag: 747759530] [rwnd: 62464] [OS: 10] [MIS: 10] Moreover, Alan says: This problem was seen with both Racoon and Racoon2. Other people have seen this with OpenSwan. When IPsec is configured to encrypt all upper layer protocols the SCTP connection does not initialize. After using Wireshark to follow packets, this is because the SCTP packet leaves Box A unencrypted and Box B believes all upper layer protocols are to be encrypted so it drops this packet, causing the SCTP connection to fail to initialize. When IPsec is configured to encrypt just SCTP, the SCTP packets are observed unencrypted. In fact, using `socat sctp6-listen:3333 -` on one end and transferring "plaintext" string on the other end, results in cleartext on the wire where SCTP eventually does not report any errors, thus in the latter case that Alan reports, the non-paranoid user might think he's communicating over an encrypted transport on SCTP although he's not (tcpdump ... -X): ... 0x0030: 5d70 8e1a 0003 001a 177d eb6c 0000 0000 ]p.......}.l.... 0x0040: 0000 0000 706c 6169 6e74 6578 740a 0000 ....plaintext... Only in /proc/net/xfrm_stat we can see XfrmInTmplMismatch increasing on the receiver side. Initial follow-up analysis from Alan's bug report was done by Alexey Dobriyan. Also thanks to Vlad Yasevich for feedback on this. SCTP has its own implementation of sctp_v6_xmit() not calling inet6_csk_xmit(). This has the implication that it probably never really got updated along with changes in inet6_csk_xmit() and therefore does not seem to invoke xfrm handlers. SCTP's IPv4 xmit however, properly calls ip_queue_xmit() to do the work. Since a call to inet6_csk_xmit() would solve this problem, but result in unecessary route lookups, let us just use the cached flowi6 instead that we got through sctp_v6_get_dst(). Since all SCTP packets are being sent through sctp_packet_transmit(), we do the route lookup / flow caching in sctp_transport_route(), hold it in tp->dst and skb_dst_set() right after that. If we would alter fl6->daddr in sctp_v6_xmit() to np->opt->srcrt, we possibly could run into the same effect of not having xfrm layer pick it up, hence, use fl6_update_dst() in sctp_v6_get_dst() instead to get the correct source routed dst entry, which we assign to the skb. Also source address routing example from 625034113 ("sctp: fix sctp to work with ipv6 source address routing") still works with this patch! Nevertheless, in RFC5095 it is actually 'recommended' to not use that anyway due to traffic amplification [1]. So it seems we're not supposed to do that anyway in sctp_v6_xmit(). Moreover, if we overwrite the flow destination here, the lower IPv6 layer will be unable to put the correct destination address into IP header, as routing header is added in ipv6_push_nfrag_opts() but then probably with wrong final destination. Things aside, result of this patch is that we do not have any XfrmInTmplMismatch increase plus on the wire with this patch it now looks like: SCTP + IPv6: 08:17:47.074080 IP6 2620:52:0:102f:7a2b:cbff:fe27:1b0a > 2620:52:0:102f:213:72ff:fe32:7eba: AH(spi=0x00005fb4,seq=0x1): ESP(spi=0x00005fb5,seq=0x1), length 72 08:17:47.074264 IP6 2620:52:0:102f:213:72ff:fe32:7eba > 2620:52:0:102f:7a2b:cbff:fe27:1b0a: AH(spi=0x00003d54,seq=0x1): ESP(spi=0x00003d55,seq=0x1), length 296 This fixes Kernel Bugzilla 24412. This security issue seems to be present since 2.6.18 kernels. Lets just hope some big passive adversary in the wild didn't have its fun with that. lksctp-tools IPv6 regression test suite passes as well with this patch. [1] http://www.secdev.org/conf/IPv6_RH_security-csw07.pdf Reported-by: Alan Chester <alan.chester@tekelec.com> Reported-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13netpoll: fix NULL pointer dereference in netpoll_cleanupNikolay Aleksandrov
[ Upstream commit d0fe8c888b1fd1a2f84b9962cabcb98a70988aec ] I've been hitting a NULL ptr deref while using netconsole because the np->dev check and the pointer manipulation in netpoll_cleanup are done without rtnl and the following sequence happens when having a netconsole over a vlan and we remove the vlan while disabling the netconsole: CPU 1 CPU2 removes vlan and calls the notifier enters store_enabled(), calls netdev_cleanup which checks np->dev and then waits for rtnl executes the netconsole netdev release notifier making np->dev == NULL and releases rtnl continues to dereference a member of np->dev which at this point is == NULL Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13netpoll: Should handle ETH_P_ARP other than ETH_P_IP in netpoll_neigh_replySonic Zhang
[ Upstream commit b0dd663b60944a3ce86430fa35549fb37968bda0 ] The received ARP request type in the Ethernet packet head is ETH_P_ARP other than ETH_P_IP. [ Bug introduced by commit b7394d2429c198b1da3d46ac39192e891029ec0f ("netpoll: prepare for ipv6") ] Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net_sched: htb: fix a typo in htb_change_class()Vimalkumar
[ Upstream commit f3ad857e3da1abaea780dc892b592cd86c541c52 ] Fix a typo added in commit 56b765b79 ("htb: improved accuracy at high rates") cbuffer should not be a copy of buffer. Signed-off-by: Vimalkumar <j.vimal@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: flow_dissector: fix thoff for IPPROTO_AHEric Dumazet
[ Upstream commit b86783587b3d1d552326d955acee37eac48800f1 ] In commit 8ed781668dd49 ("flow_keys: include thoff into flow_keys for later usage"), we missed that existing code was using nhoff as a temporary variable that could not always contain transport header offset. This is not a problem for TCP/UDP because port offset (@poff) is 0 for these protocols. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: fix multiqueue selectionEric Dumazet
[ Upstream commit 50d1784ee4683f073c0362ee360bfae7a3333d6c ] commit 416186fbf8c5b4e4465 ("net: Split core bits of netdev_pick_tx into __netdev_pick_tx") added a bug that disables caching of queue index in the socket. This is the source of packet reorders for TCP flows, and again this is happening more often when using FQ pacing. Old code was doing if (queue_index != old_index) sk_tx_queue_set(sk, queue_index); Alexander renamed the variables but forgot to change sk_tx_queue_set() 2nd parameter. if (queue_index != new_index) sk_tx_queue_set(sk, queue_index); This means we store -1 over and over in sk->sk_tx_queue_mapping Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: sctp: fix smatch warning in sctp_send_asconf_del_ipDaniel Borkmann
[ Upstream commit 88362ad8f9a6cea787420b57cc27ccacef000dbe ] This was originally reported in [1] and posted by Neil Horman [2], he said: Fix up a missed null pointer check in the asconf code. If we don't find a local address, but we pass in an address length of more than 1, we may dereference a NULL laddr pointer. Currently this can't happen, as the only users of the function pass in the value 1 as the addrcnt parameter, but its not hot path, and it doesn't hurt to check for NULL should that ever be the case. The callpath from sctp_asconf_mgmt() looks okay. But this could be triggered from sctp_setsockopt_bindx() call with SCTP_BINDX_REM_ADDR and addrcnt > 1 while passing all possible addresses from the bind list to SCTP_BINDX_REM_ADDR so that we do *not* find a single address in the association's bind address list that is not in the packed array of addresses. If this happens when we have an established association with ASCONF-capable peers, then we could get a NULL pointer dereference as we only check for laddr == NULL && addrcnt == 1 and call later sctp_make_asconf_update_ip() with NULL laddr. BUT: this actually won't happen as sctp_bindx_rem() will catch such a case and return with an error earlier. As this is incredably unintuitive and error prone, add a check to catch at least future bugs here. As Neil says, its not hot path. Introduced by 8a07eb0a5 ("sctp: Add ASCONF operation on the single-homed host"). [1] http://www.spinics.net/lists/linux-sctp/msg02132.html [2] http://www.spinics.net/lists/linux-sctp/msg02133.html Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Michio Honda <micchie@sfc.wide.ad.jp> Acked-By: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: sctp: fix bug in sctp_poll for SOCK_SELECT_ERR_QUEUEDaniel Borkmann
[ Upstream commit a0fb05d1aef0f5df936f80b726d1b3bfd4275f95 ] If we do not add braces around ... mask |= POLLERR | sock_flag(sk, SOCK_SELECT_ERR_QUEUE) ? POLLPRI : 0; ... then this condition always evaluates to true as POLLERR is defined as 8 and binary or'd with whatever result comes out of sock_flag(). Hence instead of (X | Y) ? A : B, transform it into X | (Y ? A : B). Unfortunatelty, commit 8facd5fb73 ("net: fix smatch warnings inside datagram_poll") forgot about SCTP. :-( Introduced by 7d4c04fc170 ("net: add option to enable error queue packets waking select"). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Jacob Keller <jacob.e.keller@intel.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Jacob Keller <jacob.e.keller@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13net: fib: fib6_add: fix potential NULL pointer dereferenceDaniel Borkmann
[ Upstream commit ae7b4e1f213aa659aedf9c6ecad0bf5f0476e1e2 ] When the kernel is compiled with CONFIG_IPV6_SUBTREES, and we return with an error in fn = fib6_add_1(), then error codes are encoded into the return pointer e.g. ERR_PTR(-ENOENT). In such an error case, we write the error code into err and jump to out, hence enter the if(err) condition. Now, if CONFIG_IPV6_SUBTREES is enabled, we check for: if (pn != fn && pn->leaf == rt) ... if (pn != fn && !pn->leaf && !(pn->fn_flags & RTN_RTINFO)) ... Since pn is NULL and fn is f.e. ERR_PTR(-ENOENT), then pn != fn evaluates to true and causes a NULL-pointer dereference on further checks on pn. Fix it, by setting both NULL in error case, so that pn != fn already evaluates to false and no further dereference takes place. This was first correctly implemented in 4a287eba2 ("IPv6 routing, NLM_F_* flag support: REPLACE and EXCL flags support, warn about missing CREATE flag"), but the bug got later on introduced by 188c517a0 ("ipv6: return errno pointers consistently for fib6_add_1()"). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Lin Ming <mlin@ss.pku.edu.cn> Cc: Matti Vaittinen <matti.vaittinen@nsn.com> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Matti Vaittinen <matti.vaittinen@nsn.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13ipv6/exthdrs: accept tlv which includes only paddingJiri Pirko
[ Upstream commit 8112b1fe071be01a28a774ed55909e6f4b29712d ] In rfc4942 and rfc2460 I cannot find anything which would implicate to drop packets which have only padding in tlv. Current behaviour breaks TAHI Test v6LC.1.2.6. Problem was intruduced in: 9b905fe6843 "ipv6/exthdrs: strict Pad1 and PadN check" Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13tcp: Add missing braces to do_tcp_setsockoptDave Jones
[ Upstream commit e2e5c4c07caf810d7849658dca42f598b3938e21 ] Signed-off-by: Dave Jones <davej@fedoraproject.org> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13caif: Add missing braces to multiline if in cfctrl_linkup_requestDave Jones
[ Upstream commit 0c1db731bfcf3a9fd6c58132134f8b0f423552f0 ] The indentation here implies this was meant to be a multi-line if. Introduced several years back in commit c85c2951d4da1236e32f1858db418221e624aba5 ("caif: Handle dev_queue_xmit errors.") Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13HID: fix unused rsize usageJiri Kosina
commit bc197eedef1ae082ec662c64c3f4aa302821fb7a upstream. 27ce4050 ("HID: fix data access in implement()") by mistake removed a setting of buffer size in hidp. Fix that by putting it back. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13HID: fix data access in implement()Jiri Kosina
commit 27ce405039bfe6d3f4143415c638f56a3df77dca upstream. implement() is setting bytes in LE data stream. In case the data is not aligned to 64bits, it reads past the allocated buffer. It doesn't really change any value there (it's properly bitmasked), but in case that this read past the boundary hits a page boundary, pagefault happens when accessing 64bits of 'x' in implement(), and kernel oopses. This happens much more often when numbered reports are in use, as the initial 8bit skip in the buffer makes the whole process work on values which are not aligned to 64bits. This problem dates back to attempts in 2005 and 2006 to make implement() and extract() as generic as possible, and even back then the problem was realized by Adam Kroperlin, but falsely assumed to be impossible to cause any harm: http://www.mail-archive.com/linux-usb-devel@lists.sourceforge.net/msg47690.html I have made several attempts at fixing it "on the spot" directly in implement(), but the results were horrible; the special casing for processing last 64bit chunk and switching to different math makes it unreadable mess. I therefore took a path to allocate a few bytes more which will never make it into final report, but are there as a cushion for all the 64bit math operations happening in implement() and extract(). All callers of hid_output_report() are converted at the same time to allocate the buffer by newly introduced hid_alloc_report_buf() helper. Bruno noticed that the whole raw_size test can be dropped as well, as hid_alloc_report_buf() makes sure that the buffer is always of a proper size. Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Acked-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01netfilter: ipset: Fix serious failure in CIDR trackingOliver Smith
commit 2cf55125c64d64cc106e204d53b107094762dfdf upstream. This fixes a serious bug affecting all hash types with a net element - specifically, if a CIDR value is deleted such that none of the same size exist any more, all larger (less-specific) values will then fail to match. Adding back any prefix with a CIDR equal to or more specific than the one deleted will fix it. Steps to reproduce: ipset -N test hash:net ipset -A test 1.1.0.0/16 ipset -A test 2.2.2.0/24 ipset -T test 1.1.1.1 #1.1.1.1 IS in set ipset -D test 2.2.2.0/24 ipset -T test 1.1.1.1 #1.1.1.1 IS NOT in set This is due to the fact that the nets counter was unconditionally decremented prior to the iteration that shifts up the entries. Now, we first check if there is a proceeding entry and if not, decrement it and return. Otherwise, we proceed to iterate and then zero the last element, which, in most cases, will already be zero. Signed-off-by: Oliver Smith <oliver@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa> Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01rpc: let xdr layer allocate gssproxy receieve pagesJ. Bruce Fields
commit d4a516560fc96a9d486a9939bcb567e3fdce8f49 upstream. In theory the linux cred in a gssproxy reply can include up to NGROUPS_MAX data, 256K of data. In the common case we expect it to be shorter. So do as the nfsv3 ACL code does and let the xdr code allocate the pages as they come in, instead of allocating a lot of pages that won't typically be used. Tested-by: Simo Sorce <simo@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01rpc: fix huge kmalloc's in gss-proxyJ. Bruce Fields
commit 9dfd87da1aeb0fd364167ad199f40fe96a6a87be upstream. The reply to a gssproxy can include up to NGROUPS_MAX gid's, which will take up more than a page. We therefore need to allocate an array of pages to hold the reply instead of trying to allocate a single huge buffer. Tested-by: Simo Sorce <simo@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01rpc: comment on linux_cred encoding, treat all as unsignedJ. Bruce Fields
commit 6a36978e6931e6601be586eb313375335f2cfaa3 upstream. The encoding of linux creds is a bit confusing. Also: I think in practice it doesn't really matter whether we treat any of these things as signed or unsigned, but unsigned seems more straightforward: uid_t/gid_t are unsigned and it simplifies the ngroups overflow check. Tested-by: Simo Sorce <simo@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01rpc: clean up decoding of gssproxy linux credsJ. Bruce Fields
commit 778e512bb1d3315c6b55832248cd30c566c081d7 upstream. We can use the normal coding infrastructure here. Two minor behavior changes: - we're assuming no wasted space at the end of the linux cred. That seems to match gss-proxy's behavior, and I can't see why it would need to do differently in the future. - NGROUPS_MAX check added: note groups_alloc doesn't do this, this is the caller's responsibility. Tested-by: Simo Sorce <simo@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26libceph: use pg_num_mask instead of pgp_num_mask for pg.seed calcSage Weil
commit 9542cf0bf9b1a3adcc2ef271edbcbdba03abf345 upstream. Fix a typo that used the wrong bitmask for the pg.seed calculation. This is normally unnoticed because in most cases pg_num == pgp_num. It is, however, a bug that is easily corrected. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <alex.elder@linary.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26libceph: unregister request in __map_request failed and nofail == falsemajianpeng
commit 73d9f7eef3d98c3920e144797cc1894c6b005a1e upstream. For nofail == false request, if __map_request failed, the caller does cleanup work, like releasing the relative pages. It doesn't make any sense to retry this request. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26net: Check the correct namespace when spoofing pid over SCM_RIGHTSAndy Lutomirski
commit d661684cf6820331feae71146c35da83d794467e upstream. This is a security bug. The follow-up will fix nsproxy to discourage this type of issue from happening again. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14net: ipv6: tcp: fix potential use after free in tcp_v6_do_rcvDaniel Borkmann
[ Upstream commit 3a1c756590633c0e86df606e5c618c190926a0df ] In tcp_v6_do_rcv() code, when processing pkt options, we soley work on our skb clone opt_skb that we've created earlier before entering tcp_rcv_established() on our way. However, only in condition ... if (np->rxopt.bits.rxtclass) np->rcv_tclass = ipv6_get_dsfield(ipv6_hdr(skb)); ... we work on skb itself. As we extract every other information out of opt_skb in ipv6_pktoptions path, this seems wrong, since skb can already be released by tcp_rcv_established() earlier on. When we try to access it in ipv6_hdr(), we will dereference freed skb. [ Bug added by commit 4c507d2897bd9b ("net: implement IP_RECVTOS for IP_PKTOPTIONS") ] Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14ipv6: fix null pointer dereference in __ip6addrlbl_addHannes Frederic Sowa
[ Upstream commit 639739b5e609a5074839bb22fc061b37baa06269 ] Commit b67bfe0d42cac56c512dd5da4b1b347a23f4b70a ("hlist: drop the node parameter from iterators") changed the behavior of hlist_for_each_entry_safe to leave the p argument NULL. Fix this up by tracking the last argument. Reported-by: Michele Baldessari <michele@acksyn.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Tested-by: Michele Baldessari <michele@acksyn.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14ICMPv6: treat dest unreachable codes 5 and 6 as EACCES, not EPROTOJiri Bohac
[ Upstream commit 61e76b178dbe7145e8d6afa84bb4ccea71918994 ] RFC 4443 has defined two additional codes for ICMPv6 type 1 (destination unreachable) messages: 5 - Source address failed ingress/egress policy 6 - Reject route to destination Now they are treated as protocol error and icmpv6_err_convert() converts them to EPROTO. RFC 4443 says: "Codes 5 and 6 are more informative subsets of code 1." Treat codes 5 and 6 as code 1 (EACCES) Btw, connect() returning -EPROTO confuses firefox, so that fallback to other/IPv4 addresses does not work: https://bugzilla.mozilla.org/show_bug.cgi?id=910773 Signed-off-by: Jiri Bohac <jbohac@suse.cz> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14net: bridge: convert MLDv2 Query MRC into msecs_to_jiffies for max_delayDaniel Borkmann
[ Upstream commit 2d98c29b6fb3de44d9eaa73c09f9cf7209346383 ] While looking into MLDv1/v2 code, I noticed that bridging code does not convert it's max delay into jiffies for MLDv2 messages as we do in core IPv6' multicast code. RFC3810, 5.1.3. Maximum Response Code says: The Maximum Response Code field specifies the maximum time allowed before sending a responding Report. The actual time allowed, called the Maximum Response Delay, is represented in units of milliseconds, and is derived from the Maximum Response Code as follows: [...] As we update timers that work with jiffies, we need to convert it. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Linus Lüssing <linus.luessing@web.de> Cc: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14net: revert 8728c544a9c ("net: dev_pick_tx() fix")Eric Dumazet
[ Upstream commit 702821f4ea6f68db18aa1de7d8ed62c6ba586a64 ] commit 8728c544a9cbdc ("net: dev_pick_tx() fix") and commit b6fe83e9525a ("bonding: refine IFF_XMIT_DST_RELEASE capability") are quite incompatible : Queue selection is disabled because skb dst was dropped before entering bonding device. This causes major performance regression, mainly because TCP packets for a given flow can be sent to multiple queues. This is particularly visible when using the new FQ packet scheduler with MQ + FQ setup on the slaves. We can safely revert the first commit now that 416186fbf8c5b ("net: Split core bits of netdev_pick_tx into __netdev_pick_tx") properly caps the queue_index. Reported-by: Xi Wang <xii@google.com> Diagnosed-by: Xi Wang <xii@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: Denys Fedorysychenko <nuclearcat@nuclearcat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
