path: root/net
2015-03-12sunrpc: fix braino in ->poll()Al Viro
commit 1711fd9addf214823b993468567cab1f8254fc51 upstream. POLL_OUT isn't what callers of ->poll() are expecting to see; it's actually __SI_POLL | 2 and it's a siginfo code, not a poll bitmap bit... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Bruce Fields <bfields@fieldses.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12net: irda: fix wait_until_sent poll timeoutJohan Hovold
commit 2c3fbe3cf28fbd7001545a92a83b4f8acfd9fa36 upstream. In case an infinite timeout (0) is requested, the irda wait_until_sent implementation would use a zero poll timeout rather than the default 200ms. Note that wait_until_sent is currently never called with a 0-timeout argument due to a bug in tty_wait_until_sent. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12mac80211: Send EAPOL frames at lowest rateJouni Malinen
commit 9c1c98a3bb7b7593b60264b9a07e001e68b46697 upstream. The current minstrel_ht rate control behavior is somewhat optimistic in trying to find optimum TX rate. While this is usually fine for normal Data frames, there are cases where a more conservative set of retry parameters would be beneficial to make the connection more robust. EAPOL frames are critical to the authentication and especially the EAPOL-Key message 4/4 (the last message in the 4-way handshake) is important to get through to the AP. If that message is lost, the only recovery mechanism in many cases is to reassociate with the AP and start from scratch. This can often be avoided by trying to send the frame with more conservative rate and/or with more link layer retries. In most cases, minstrel_ht is currently using the initial EAPOL-Key frames for probing higher rates and this results in only five link layer transmission attempts (one at high(ish) MCS and four at MCS0). While this works with most APs, it looks like there are some deployed APs that may have issues with the EAPOL frames using HT MCS immediately after association. Similarly, there may be issues in cases where the signal strength or radio environment is not good enough to be able to get frames through even at couple of MCS 0 tries. The best approach for this would likely to be to reduce the TX rate for the last rate (3rd rate parameter in the set) to a low basic rate (say, 6 Mbps on 5 GHz and 2 or 5.5 Mbps on 2.4 GHz), but doing that cleanly requires some more effort. For now, we can start with a simple one-liner that forces the minimum rate to be used for EAPOL frames similarly how the TX rate is selected for the IEEE 802.11 Management frames. This does result in a small extra latency added to the cases where the AP would be able to receive the higher rate, but taken into account how small number of EAPOL frames are used, this is likely to be insignificant. A future optimization in the minstrel_ht design can also allow this patch to be reverted to get back to the more optimized initial TX rate. It should also be noted that many drivers that do not use minstrel as the rate control algorithm are already doing similar workarounds by forcing the lowest TX rate to be used for EAPOL frames. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12net: ping: Return EAFNOSUPPORT when appropriate.Lorenzo Colitti
[ Upstream commit 9145736d4862145684009d6a72a6e61324a9439e ] 1. For an IPv4 ping socket, ping_check_bind_addr does not check the family of the socket address that's passed in. Instead, make it behave like inet_bind, which enforces either that the address family is AF_INET, or that the family is AF_UNSPEC and the address is 0.0.0.0. 2. For an IPv6 ping socket, ping_check_bind_addr returns EINVAL if the socket family is not AF_INET6. Return EAFNOSUPPORT instead, for consistency with inet6_bind. 3. Make ping_v4_sendmsg and ping_v6_sendmsg return EAFNOSUPPORT instead of EINVAL if an incorrect socket address structure is passed in. 4. Make IPv6 ping sockets be IPv6-only. The code does not support IPv4, and it cannot easily be made to support IPv4 because the protocol numbers for ICMP and ICMPv6 are different. This makes connect(::ffff:192.0.2.1) fail with EAFNOSUPPORT instead of making the socket unusable. Among other things, this fixes an oops that can be triggered by: int s = socket(AF_INET, SOCK_DGRAM, IPPROTO_ICMP); struct sockaddr_in6 sin6 = { .sin6_family = AF_INET6, .sin6_addr = in6addr_any, }; bind(s, (struct sockaddr *) &sin6, sizeof(sin6)); Change-Id: If06ca86d9f1e4593c0d6df174caca3487c57a241 Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12udp: only allow UFO for packets from SOCK_DGRAM socketsMichal Kubeček
[ Upstream commit acf8dd0a9d0b9e4cdb597c2f74802f79c699e802 ] If an over-MTU UDP datagram is sent through a SOCK_RAW socket to a UFO-capable device, ip_ufo_append_data() sets skb->ip_summed to CHECKSUM_PARTIAL unconditionally as all GSO code assumes transport layer checksum is to be computed on segmentation. However, in this case, skb->csum_start and skb->csum_offset are never set as raw socket transmit path bypasses udp_send_skb() where they are usually set. As a result, driver may access invalid memory when trying to calculate the checksum and store the result (as observed in virtio_net driver). Moreover, the very idea of modifying the userspace provided UDP header is IMHO against raw socket semantics (I wasn't able to find a document clearly stating this or the opposite, though). And while allowing CHECKSUM_NONE in the UFO case would be more efficient, it would be a bit too intrusive change just to handle a corner case like this. Therefore disallowing UFO for packets from SOCK_DGRAM seems to be the best option. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12net: compat: Ignore MSG_CMSG_COMPAT in compat_sys_{send, recv}msgCatalin Marinas
[ Upstream commit d720d8cec563ce4e4fa44a613d4f2dcb1caf2998 ] With commit a7526eb5d06b (net: Unbreak compat_sys_{send,recv}msg), the MSG_CMSG_COMPAT flag is blocked at the compat syscall entry points, changing the kernel compat behaviour from the one before the commit it was trying to fix (1be374a0518a, net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msg). On 32-bit kernels (!CONFIG_COMPAT), MSG_CMSG_COMPAT is 0 and the native 32-bit sys_sendmsg() allows flag 0x80000000 to be set (it is ignored by the kernel). However, on a 64-bit kernel, the compat ABI is different with commit a7526eb5d06b. This patch changes the compat_sys_{send,recv}msg behaviour to the one prior to commit 1be374a0518a. The problem was found running 32-bit LTP (sendmsg01) binary on an arm64 kernel. Arguably, LTP should not pass 0xffffffff as flags to sendmsg() but the general rule is not to break user ABI (even when the user behaviour is not entirely sane). Fixes: a7526eb5d06b (net: Unbreak compat_sys_{send,recv}msg) Cc: Andy Lutomirski <luto@amacapital.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12net: reject creation of netdev names with colonsMatthew Thode
[ Upstream commit a4176a9391868bfa87705bcd2e3b49e9b9dd2996 ] colons are used as a separator in netdev device lookup in dev_ioctl.c Specific functions are SIOCGIFTXQLEN SIOCETHTOOL SIOCSIFNAME Signed-off-by: Matthew Thode <mthode@mthode.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12ematch: Fix auto-loading of ematch modules.Ignacy Gawędzki
[ Upstream commit 34eea79e2664b314cab6a30fc582fdfa7a1bb1df ] In tcf_em_validate(), after calling request_module() to load the kind-specific module, set em->ops to NULL before returning -EAGAIN, so that module_put() is not called again by tcf_em_tree_destroy(). Signed-off-by: Ignacy Gawędzki <ignacy.gawedzki@green-communications.fr> Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12ipv4: ip_check_defrag should not assume that skb_network_offset is zeroAlexander Drozdov
[ Upstream commit 3e32e733d1bbb3f227259dc782ef01d5706bdae0 ] ip_check_defrag() may be used by af_packet to defragment outgoing packets. skb_network_offset() of af_packet's outgoing packets is not zero. Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12ipv4: ip_check_defrag should correctly check return value of skb_copy_bitsAlexander Drozdov
[ Upstream commit fba04a9e0c869498889b6445fd06cbe7da9bb834 ] skb_copy_bits() returns zero on success and negative value on error, so it is needed to invert the condition in ip_check_defrag(). Fixes: 1bf3751ec90c ("ipv4: ip_check_defrag must not modify skb before unsharing") Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12gen_stats.c: Duplicate xstats buffer for later useIgnacy Gawędzki
[ Upstream commit 1c4cff0cf55011792125b6041bc4e9713e46240f ] The gnet_stats_copy_app() function gets called, more often than not, with its second argument a pointer to an automatic variable in the caller's stack. Therefore, to avoid copying garbage afterwards when calling gnet_stats_finish_copy(), this data is better copied to a dynamically allocated memory that gets freed after use. [xiyou.wangcong@gmail.com: remove a useless kfree()] Signed-off-by: Ignacy Gawędzki <ignacy.gawedzki@green-communications.fr> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12rtnetlink: call ->dellink on failure when ->newlink existsWANG Cong
[ Upstream commit 7afb8886a05be68e376655539a064ec672de8a8e ] Ignacy reported that when eth0 is down and add a vlan device on top of it like: ip link add link eth0 name eth0.1 up type vlan id 1 We will get a refcount leak: unregister_netdevice: waiting for eth0.1 to become free. Usage count = 2 The problem is when rtnl_configure_link() fails in rtnl_newlink(), we simply call unregister_device(), but for stacked device like vlan, we almost do nothing when we unregister the upper device, more work is done when we unregister the lower device, so call its ->dellink(). Reported-by: Ignacy Gawedzki <ignacy.gawedzki@green-communications.fr> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12ipv6: fix ipv6_cow_metrics for non DST_HOST caseMartin KaFai Lau
[ Upstream commit 3b4711757d7903ab6fa88a9e7ab8901b8227da60 ] ipv6_cow_metrics() currently assumes only DST_HOST routes require dynamic metrics allocation from inetpeer. The assumption breaks when ndisc discovered router with RTAX_MTU and RTAX_HOPLIMIT metric. Refer to ndisc_router_discovery() in ndisc.c and note that dst_metric_set() is called after the route is created. This patch creates the metrics array (by calling dst_cow_metrics_generic) in ipv6_cow_metrics(). Test: radvd.conf: interface qemubr0 { AdvLinkMTU 1300; AdvCurHopLimit 30; prefix fd00:face:face:face::/64 { AdvOnLink on; AdvAutonomous on; AdvRouterAddr off; }; }; Before: [root@qemu1 ~]# ip -6 r show | egrep -v unreachable fd00:face:face:face::/64 dev eth0 proto kernel metric 256 expires 27sec fe80::/64 dev eth0 proto kernel metric 256 default via fe80::74df:d0ff:fe23:8ef2 dev eth0 proto ra metric 1024 expires 27sec After: [root@qemu1 ~]# ip -6 r show | egrep -v unreachable fd00:face:face:face::/64 dev eth0 proto kernel metric 256 expires 27sec mtu 1300 fe80::/64 dev eth0 proto kernel metric 256 mtu 1300 default via fe80::74df:d0ff:fe23:8ef2 dev eth0 proto ra metric 1024 expires 27sec mtu 1300 hoplimit 30 Fixes: 8e2ec639173f325 (ipv6: don't use inetpeer to store metrics for routes.) Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12rtnetlink: ifla_vf_policy: fix misuses of NLA_BINARYDaniel Borkmann
[ Upstream commit 364d5716a7adb91b731a35765d369602d68d2881 ] ifla_vf_policy[] is wrong in advertising its individual member types as NLA_BINARY since .type = NLA_BINARY in combination with .len declares the len member as *max* attribute length [0, len]. The issue is that when do_setvfinfo() is being called to set up a VF through ndo handler, we could set corrupted data if the attribute length is less than the size of the related structure itself. The intent is exactly the opposite, namely to make sure to pass at least data of minimum size of len. Fixes: ebc08a6f47ee ("rtnetlink: Add VF config code to rtnetlink") Cc: Mitch Williams <mitch.a.williams@intel.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-12pktgen: fix UDP checksum computationSabrina Dubroca
[ Upstream commit 7744b5f3693cc06695cb9d6667671c790282730f ] This patch fixes two issues in UDP checksum computation in pktgen. First, the pseudo-header uses the source and destination IP addresses. Currently, the ports are used for IPv4. Second, the UDP checksum covers both header and data. So we need to generate the data earlier (move pktgen_finalize_skb up), and compute the checksum for UDP header + data. Fixes: c26bf4a51308c ("pktgen: Add UDPCSUM flag to support UDP checksums") Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-10netfilter: xt_socket: fix a stack corruption bugEric Dumazet
[ upstream commit 78296c97ca1fd3b104f12e1f1fbc06c46635990b ] As soon as extract_icmp6_fields() returns, its local storage (automatic variables) is deallocated and can be overwritten. Lets add an additional parameter to make sure storage is valid long enough. While we are at it, adds some const qualifiers. Cc: <stable@vger.kernel.org> # 3.12.x Cc: <stable@vger.kernel.org> # 3.14.x Cc: <stable@vger.kernel.org> # 3.18.x Cc: <stable@vger.kernel.org> # 3.19.x Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: b64c9256a9b76 ("tproxy: added IPv6 support to the socket match") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-10ipvs: rerouting to local clients is not needed anymoreJulian Anastasov
[ upstream commit 579eb62ac35845686a7c4286c0a820b4eb1f96aa ] commit f5a41847acc5 ("ipvs: move ip_route_me_harder for ICMP") from 2.6.37 introduced ip_route_me_harder() call for responses to local clients, so that we can provide valid rt_src after SNAT. It was used by TCP to provide valid daddr for ip_send_reply(). After commit 0a5ebb8000c5 ("ipv4: Pass explicit daddr arg to ip_send_reply()." from 3.0 this rerouting is not needed anymore and should be avoided, especially in LOCAL_IN. Fixes 3.12.33 crash in xfrm reported by Florian Wiessner: "3.12.33 - BUG xfrm_selector_match+0x25/0x2f6" Cc: <stable@vger.kernel.org> # 3.10.x Cc: <stable@vger.kernel.org> # 3.12.x Cc: <stable@vger.kernel.org> # 3.14.x Cc: <stable@vger.kernel.org> # 3.18.x Reported-by: Smart Weblications GmbH - Florian Wiessner <f.wiessner@smart-weblications.de> Tested-by: Smart Weblications GmbH - Florian Wiessner <f.wiessner@smart-weblications.de> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-10ipvs: add missing ip_vs_pe_put in sync codeJulian Anastasov
[ upstream commit 528c943f3bb919aef75ab2fff4f00176f09a4019 ] ip_vs_conn_fill_param_sync() gets in param.pe a module reference for persistence engine from __ip_vs_pe_getbyname() but forgets to put it. Problem occurs in backup for sync protocol v1 (2.6.39). Also, pe_data usually comes in sync messages for connection templates and ip_vs_conn_new() copies the pointer only in this case. Make sure pe_data is not leaked if it comes unexpectedly for normal connections. Leak can happen only if bogus messages are sent to backup server. Fixes: fe5e7a1efb66 ("IPVS: Backup, Adding Version 1 receive capability") Cc: <stable@vger.kernel.org> # 3.10.x Cc: <stable@vger.kernel.org> # 3.12.x Cc: <stable@vger.kernel.org> # 3.14.x Cc: <stable@vger.kernel.org> # 3.18.x Cc: <stable@vger.kernel.org> # 3.19.x Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-05libceph: fix double __remove_osd() problemIlya Dryomov
commit 7eb71e0351fbb1b242ae70abb7bb17107fe2f792 upstream. It turns out it's possible to get __remove_osd() called twice on the same OSD. That doesn't sit well with rb_erase() - depending on the shape of the tree we can get a NULL dereference, a soft lockup or a random crash at some point in the future as we end up touching freed memory. One scenario that I was able to reproduce is as follows: <osd3 is idle, on the osd lru list> <con reset - osd3> con_fault_finish() osd_reset() <osdmap - osd3 down> ceph_osdc_handle_map() <takes map_sem> kick_requests() <takes request_mutex> reset_changed_osds() __reset_osd() __remove_osd() <releases request_mutex> <releases map_sem> <takes map_sem> <takes request_mutex> __kick_osd_requests() __reset_osd() __remove_osd() <-- !!! A case can be made that osd refcounting is imperfect and reworking it would be a proper resolution, but for now Sage and I decided to fix this by adding a safe guard around __remove_osd(). Fixes: http://tracker.ceph.com/issues/8087 Cc: Sage Weil <sage@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-05libceph: change from BUG to WARN for __remove_osd() assertsIlya Dryomov
commit cc9f1f518cec079289d11d732efa490306b1ddad upstream. No reason to use BUG_ON for osd request list assertions. Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-03-05libceph: assert both regular and lingering lists in __remove_osd()Ilya Dryomov
commit 7c6e6fc53e7335570ed82f77656cedce1502744e upstream. It is important that both regular and lingering requests lists are empty when the OSD is removed. Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Handle EPIPE in xprt_connect_statusTrond Myklebust
commit 2fc193cf924ea6eb74f6a0cf73b94b2e62938ae5 upstream. The callback handler xs_error_report() can end up propagating an EPIPE error by means of the call to xprt_wake_pending_tasks(). Ensure that xprt_connect_status() does not automatically convert this into an EIO error. Reported-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure that we handle ENOBUFS errors correctly.Trond Myklebust
commit 3601c4a91ebbbf1cf69f66a2abeffc6c64a4fe64 upstream. Currently, an ENOBUFS error will result in a fatal error for the RPC call. Normally, we will just want to wait and then retry. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure call_connect_status() deals correctly with SOFTCONN tasksSteve Dickson
commit 1fa3e2eb9db07f30a605c66d1a2fdde4b24e74d5 upstream. Don't schedule an rpc_delay before checking to see if the task is a SOFTCONN because the tk_callback from the delay (__rpc_atrun) clears the task status before the rpc_exit_task can be run. Signed-off-by: Steve Dickson <steved@redhat.com> Fixes: 561ec1603171c (SUNRPC: call_connect_status should recheck...) Link: http://lkml.kernel.org/r/5329CF7C.7090308@RedHat.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure that call_connect times out correctlyTrond Myklebust
commit 485f2251782f7c44299c491d4676a8a01428d191 upstream. When the server is unavailable due to a networking error, etc, we want the RPC client to respect the timeout delays when attempting to reconnect. Reported-by: Neil Brown <neilb@suse.de> Fixes: 561ec1603171 (SUNRPC: call_connect_status should recheck bind..) Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Handle connect errors ECONNABORTED and EHOSTUNREACHTrond Myklebust
commit df2772700c6ee706be7b2fd16c6bf2c1bf63cda0 upstream. Ensure that call_bind_status, call_connect_status, call_transmit_status and call_status all are capable of handling ECONNABORTED and EHOSTUNREACH. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure xprt_connect_status handles all potential connection errorsTrond Myklebust
commit 0fe8d04e8c3a1eb49089793e38b60a17cee564e3 upstream. Currently, xprt_connect_status will convert connection error values such as ECONNREFUSED, ECONNRESET, ... into EIO, which means that they never get handled. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: call_connect_status should recheck bind and connect status on errorTrond Myklebust
commit 561ec1603171cd9b38dcf6cac53e8710f437a48d upstream. Currently, we go directly to call_transmit which sends us to call_status on error. If we know that the connect attempt failed, we should rather just jump straight back to call_bind and call_connect. Ditto for EAGAIN, except do not delay. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16net, sunrpc: suppress allocation warning in rpc_malloc()David Rientjes
commit c6c8fe79a83e1a03e5dd83d0bac178d6ba5ef30a upstream. rpc_malloc() allocates with GFP_NOWAIT without making any attempt at reclaim so it easily fails when low on memory. This ends up spamming the kernel log: SLAB: Unable to allocate memory on node 0 (gfp=0x4000) cache: kmalloc-8192, object size: 8192, order: 1 node 0: slabs: 207/207, objs: 207/207, free: 0 rekonq: page allocation failure: order:1, mode:0x204000 CPU: 2 PID: 14321 Comm: rekonq Tainted: G O 3.15.0-rc3-12.gfc9498b-desktop+ #6 Hardware name: System manufacturer System Product Name/M4A785TD-V EVO, BIOS 2105 07/23/2010 0000000000000000 ffff880010ff17d0 ffffffff815e693c 0000000000204000 ffff880010ff1858 ffffffff81137bd2 0000000000000000 0000001000000000 ffff88011ffebc38 0000000000000001 0000000000204000 ffff88011ffea000 Call Trace: [<ffffffff815e693c>] dump_stack+0x4d/0x6f [<ffffffff81137bd2>] warn_alloc_failed+0xd2/0x140 [<ffffffff8113be19>] __alloc_pages_nodemask+0x7e9/0xa30 [<ffffffff811824a8>] kmem_getpages+0x58/0x140 [<ffffffff81183de6>] fallback_alloc+0x1d6/0x210 [<ffffffff81183be3>] ____cache_alloc_node+0x123/0x150 [<ffffffff81185953>] __kmalloc+0x203/0x490 [<ffffffffa06b0ee2>] rpc_malloc+0x32/0xa0 [sunrpc] [<ffffffffa06a6999>] call_allocate+0xb9/0x170 [sunrpc] [<ffffffffa06b19d8>] __rpc_execute+0x88/0x460 [sunrpc] [<ffffffffa06b2da9>] rpc_execute+0x59/0xc0 [sunrpc] [<ffffffffa06a932b>] rpc_run_task+0x6b/0x90 [sunrpc] [<ffffffffa077b5c1>] nfs4_call_sync_sequence+0x51/0x80 [nfsv4] [<ffffffffa077d45d>] _nfs4_do_setattr+0x1ed/0x280 [nfsv4] [<ffffffffa0782a72>] nfs4_do_setattr+0x72/0x180 [nfsv4] [<ffffffffa078334c>] nfs4_proc_setattr+0xbc/0x140 [nfsv4] [<ffffffffa074a7e8>] nfs_setattr+0xd8/0x240 [nfs] [<ffffffff811baa71>] notify_change+0x231/0x380 [<ffffffff8119cf5c>] chmod_common+0xfc/0x120 [<ffffffff8119df80>] SyS_chmod+0x40/0x90 [<ffffffff815f4cfd>] system_call_fastpath+0x1a/0x1f ... If the allocation fails, simply return NULL and avoid spamming the kernel log. Reported-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: sctp: fix passing wrong parameter header to param_type2af in ↵Saran Maruti Ramanara
sctp_process_param [ Upstream commit cfbf654efc6d78dc9812e030673b86f235bf677d ] When making use of RFC5061, section 4.2.4. for setting the primary IP address, we're passing a wrong parameter header to param_type2af(), resulting always in NULL being returned. At this point, param.p points to a sctp_addip_param struct, containing a sctp_paramhdr (type = 0xc004, length = var), and crr_id as a correlation id. Followed by that, as also presented in RFC5061 section 4.2.4., comes the actual sctp_addr_param, which also contains a sctp_paramhdr, but this time with the correct type SCTP_PARAM_IPV{4,6}_ADDRESS that param_type2af() can make use of. Since we already hold a pointer to addr_param from previous line, just reuse it for param_type2af(). Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT") Signed-off-by: Saran Maruti Ramanara <saran.neti@telus.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv4: tcp: get rid of ugly unicast_sockEric Dumazet
[ Upstream commit bdbbb8527b6f6a358dbcb70dac247034d665b8e4 ] In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock") I tried to address contention on a socket lock, but the solution I chose was horrible : commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside of TCP stack") addressed a selinux regression. commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1") took care of another regression. commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression. commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate") was another shot in the dark. Really, just use a proper socket per cpu, and remove the skb_orphan() call, to re-enable flow control. This solves a serious problem with FQ packet scheduler when used in hostile environments, as we do not want to allocate a flow structure for every RST packet sent in response to a spoofed packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10tcp: ipv4: initialize unicast_sock sk_pacing_rateEric Dumazet
[ Upstream commit 811230cd853d62f09ed0addd0ce9a1b9b0e13fb5 ] When I added sk_pacing_rate field, I forgot to initialize its value in the per cpu unicast_sock used in ip_send_unicast_reply() This means that for sch_fq users, RST packets, or ACK packets sent on behalf of TIME_WAIT sockets might be sent to slowly or even dropped once we reach the per flow limit. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 95bd09eb2750 ("tcp: TSO packets automatic sizing") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10bridge: dont send notification when skb->len == 0 in rtnl_bridge_notifyRoopa Prabhu
[ Upstream commit 59ccaaaa49b5b096cdc1f16706a9f931416b2332 ] Reported in: https://bugzilla.kernel.org/show_bug.cgi?id=92081 This patch avoids calling rtnl_notify if the device ndo_bridge_getlink handler does not return any bytes in the skb. Alternately, the skb->len check can be moved inside rtnl_notify. For the bridge vlan case described in 92081, there is also a fix needed in bridge driver to generate a proper notification. Will fix that in subsequent patch. v2: rebase patch on net tree Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: don't OOPS on socket aioChristoph Hellwig
[ Upstream commit 06539d3071067ff146a9bffd1c801fa56d290909 ] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv6: replacing a rt6_info needs to purge possible propagated rt6_infos tooHannes Frederic Sowa
[ Upstream commit 6e9e16e6143b725662e47026a1d0f270721cdd24 ] Lubomir Rintel reported that during replacing a route the interface reference counter isn't correctly decremented. To quote bug <https://bugzilla.kernel.org/show_bug.cgi?id=91941>: | [root@rhel7-5 lkundrak]# sh -x lal | + ip link add dev0 type dummy | + ip link set dev0 up | + ip link add dev1 type dummy | + ip link set dev1 up | + ip addr add 2001:db8:8086::2/64 dev dev0 | + ip route add 2001:db8:8086::/48 dev dev0 proto static metric 20 | + ip route add 2001:db8:8088::/48 dev dev1 proto static metric 10 | + ip route replace 2001:db8:8086::/48 dev dev1 proto static metric 20 | + ip link del dev0 type dummy | Message from syslogd@rhel7-5 at Jan 23 10:54:41 ... | kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2 | | Message from syslogd@rhel7-5 at Jan 23 10:54:51 ... | kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2 During replacement of a rt6_info we must walk all parent nodes and check if the to be replaced rt6_info got propagated. If so, replace it with an alive one. Fixes: 4a287eba2de3957 ("IPv6 routing, NLM_F_* flag support: REPLACE and EXCL flags support, warn about missing CREATE flag") Reported-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Tested-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ping: Fix race in free in receive pathsubashab@codeaurora.org
[ Upstream commit fc752f1f43c1c038a2c6ae58cc739ebb5953ccb0 ] An exception is seen in ICMP ping receive path where the skb destructor sock_rfree() tries to access a freed socket. This happens because ping_rcv() releases socket reference with sock_put() and this internally frees up the socket. Later icmp_rcv() will try to free the skb and as part of this, skb destructor is called and which leads to a kernel panic as the socket is freed already in ping_rcv(). -->|exception -007|sk_mem_uncharge -007|sock_rfree -008|skb_release_head_state -009|skb_release_all -009|__kfree_skb -010|kfree_skb -011|icmp_rcv -012|ip_local_deliver_finish Fix this incorrect free by cloning this skb and processing this cloned skb instead. This patch was suggested by Eric Dumazet Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10udp_diag: Fix socket skipping within chainHerbert Xu
[ Upstream commit 86f3cddbc3037882414c7308973530167906b7e9 ] While working on rhashtable walking I noticed that the UDP diag dumping code is buggy. In particular, the socket skipping within a chain never happens, even though we record the number of sockets that should be skipped. As this code was supposedly copied from TCP, this patch does what TCP does and resets num before we walk a chain. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv4: try to cache dst_entries which would cause a redirectHannes Frederic Sowa
[ Upstream commit df4d92549f23e1c037e83323aff58a21b3de7fe0 ] Not caching dst_entries which cause redirects could be exploited by hosts on the same subnet, causing a severe DoS attack. This effect aggravated since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()"). Lookups causing redirects will be allocated with DST_NOCACHE set which will force dst_release to free them via RCU. Unfortunately waiting for RCU grace period just takes too long, we can end up with >1M dst_entries waiting to be released and the system will run OOM. rcuos threads cannot catch up under high softirq load. Attaching the flag to emit a redirect later on to the specific skb allows us to cache those dst_entries thus reducing the pressure on allocation and deallocation. This issue was discovered by Marcelo Leitner. Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Leitner <mleitner@redhat.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: sctp: fix slab corruption from use after free on INIT collisionsDaniel Borkmann
[ Upstream commit 600ddd6825543962fb807884169e57b580dba208 ] When hitting an INIT collision case during the 4WHS with AUTH enabled, as already described in detail in commit 1be9a950c646 ("net: sctp: inherit auth_capable on INIT collisions"), it can happen that we occasionally still remotely trigger the following panic on server side which seems to have been uncovered after the fix from commit 1be9a950c646 ... [ 533.876389] BUG: unable to handle kernel paging request at 00000000ffffffff [ 533.913657] IP: [<ffffffff811ac385>] __kmalloc+0x95/0x230 [ 533.940559] PGD 5030f2067 PUD 0 [ 533.957104] Oops: 0000 [#1] SMP [ 533.974283] Modules linked in: sctp mlx4_en [...] [ 534.939704] Call Trace: [ 534.951833] [<ffffffff81294e30>] ? crypto_init_shash_ops+0x60/0xf0 [ 534.984213] [<ffffffff81294e30>] crypto_init_shash_ops+0x60/0xf0 [ 535.015025] [<ffffffff8128c8ed>] __crypto_alloc_tfm+0x6d/0x170 [ 535.045661] [<ffffffff8128d12c>] crypto_alloc_base+0x4c/0xb0 [ 535.074593] [<ffffffff8160bd42>] ? _raw_spin_lock_bh+0x12/0x50 [ 535.105239] [<ffffffffa0418c11>] sctp_inet_listen+0x161/0x1e0 [sctp] [ 535.138606] [<ffffffff814e43bd>] SyS_listen+0x9d/0xb0 [ 535.166848] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b ... or depending on the the application, for example this one: [ 1370.026490] BUG: unable to handle kernel paging request at 00000000ffffffff [ 1370.026506] IP: [<ffffffff811ab455>] kmem_cache_alloc+0x75/0x1d0 [ 1370.054568] PGD 633c94067 PUD 0 [ 1370.070446] Oops: 0000 [#1] SMP [ 1370.085010] Modules linked in: sctp kvm_amd kvm [...] [ 1370.963431] Call Trace: [ 1370.974632] [<ffffffff8120f7cf>] ? SyS_epoll_ctl+0x53f/0x960 [ 1371.000863] [<ffffffff8120f7cf>] SyS_epoll_ctl+0x53f/0x960 [ 1371.027154] [<ffffffff812100d3>] ? anon_inode_getfile+0xd3/0x170 [ 1371.054679] [<ffffffff811e3d67>] ? __alloc_fd+0xa7/0x130 [ 1371.080183] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b With slab debugging enabled, we can see that the poison has been overwritten: [ 669.826368] BUG kmalloc-128 (Tainted: G W ): Poison overwritten [ 669.826385] INFO: 0xffff880228b32e50-0xffff880228b32e50. First byte 0x6a instead of 0x6b [ 669.826414] INFO: Allocated in sctp_auth_create_key+0x23/0x50 [sctp] age=3 cpu=0 pid=18494 [ 669.826424] __slab_alloc+0x4bf/0x566 [ 669.826433] __kmalloc+0x280/0x310 [ 669.826453] sctp_auth_create_key+0x23/0x50 [sctp] [ 669.826471] sctp_auth_asoc_create_secret+0xcb/0x1e0 [sctp] [ 669.826488] sctp_auth_asoc_init_active_key+0x68/0xa0 [sctp] [ 669.826505] sctp_do_sm+0x29d/0x17c0 [sctp] [...] [ 669.826629] INFO: Freed in kzfree+0x31/0x40 age=1 cpu=0 pid=18494 [ 669.826635] __slab_free+0x39/0x2a8 [ 669.826643] kfree+0x1d6/0x230 [ 669.826650] kzfree+0x31/0x40 [ 669.826666] sctp_auth_key_put+0x19/0x20 [sctp] [ 669.826681] sctp_assoc_update+0x1ee/0x2d0 [sctp] [ 669.826695] sctp_do_sm+0x674/0x17c0 [sctp] Since this only triggers in some collision-cases with AUTH, the problem at heart is that sctp_auth_key_put() on asoc->asoc_shared_key is called twice when having refcnt 1, once directly in sctp_assoc_update() and yet again from within sctp_auth_asoc_init_active_key() via sctp_assoc_update() on the already kzfree'd memory, which is also consistent with the observation of the poison decrease from 0x6b to 0x6a (note: the overwrite is detected at a later point in time when poison is checked on new allocation). Reference counting of auth keys revisited: Shared keys for AUTH chunks are being stored in endpoints and associations in endpoint_shared_keys list. On endpoint creation, a null key is being added; on association creation, all endpoint shared keys are being cached and thus cloned over to the association. struct sctp_shared_key only holds a pointer to the actual key bytes, that is, struct sctp_auth_bytes which keeps track of users internally through refcounting. Naturally, on assoc or enpoint destruction, sctp_shared_key are being destroyed directly and the reference on sctp_auth_bytes dropped. User space can add keys to either list via setsockopt(2) through struct sctp_authkey and by passing that to sctp_auth_set_key() which replaces or adds a new auth key. There, sctp_auth_create_key() creates a new sctp_auth_bytes with refcount 1 and in case of replacement drops the reference on the old sctp_auth_bytes. A key can be set active from user space through setsockopt() on the id via sctp_auth_set_active_key(), which iterates through either endpoint_shared_keys and in case of an assoc, invokes (one of various places) sctp_auth_asoc_init_active_key(). sctp_auth_asoc_init_active_key() computes the actual secret from local's and peer's random, hmac and shared key parameters and returns a new key directly as sctp_auth_bytes, that is asoc->asoc_shared_key, plus drops the reference if there was a previous one. The secret, which where we eventually double drop the ref comes from sctp_auth_asoc_set_secret() with intitial refcount of 1, which also stays unchanged eventually in sctp_assoc_update(). This key is later being used for crypto layer to set the key for the hash in crypto_hash_setkey() from sctp_auth_calculate_hmac(). To close the loop: asoc->asoc_shared_key is freshly allocated secret material and independant of the sctp_shared_key management keeping track of only shared keys in endpoints and assocs. Hence, also commit 4184b2a79a76 ("net: sctp: fix memory leak in auth key management") is independant of this bug here since it concerns a different layer (though same structures being used eventually). asoc->asoc_shared_key is reference dropped correctly on assoc destruction in sctp_association_free() and when active keys are being replaced in sctp_auth_asoc_init_active_key(), it always has a refcount of 1. Hence, it's freed prematurely in sctp_assoc_update(). Simple fix is to remove that sctp_auth_key_put() from there which fixes these panics. Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv6: stop sending PTB packets for MTU < 1280Hagen Paul Pfeifer
[ Upstream commit 9d289715eb5c252ae15bd547cb252ca547a3c4f2 ] Reduce the attack vector and stop generating IPv6 Fragment Header for paths with an MTU smaller than the minimum required IPv6 MTU size (1280 byte) - called atomic fragments. See IETF I-D "Deprecating the Generation of IPv6 Atomic Fragments" [1] for more information and how this "feature" can be misused. [1] https://tools.ietf.org/html/draft-ietf-6man-deprecate-atomfrag-generation-00 Signed-off-by: Fernando Gont <fgont@si6networks.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: rps: fix cpu unplugEric Dumazet
[ Upstream commit ac64da0b83d82abe62f78b3d0e21cca31aea24fa ] softnet_data.input_pkt_queue is protected by a spinlock that we must hold when transferring packets from victim queue to an active one. This is because other cpus could still be trying to enqueue packets into victim queue. A second problem is that when we transfert the NAPI poll_list from victim to current cpu, we absolutely need to special case the percpu backlog, because we do not want to add complex locking to protect process_queue : Only owner cpu is allowed to manipulate it, unless cpu is offline. Based on initial patch from Prasad Sodagudi & Subash Abhinov Kasiviswanathan. This version is better because we do not slow down packet processing, only make migration safer. Reported-by: Prasad Sodagudi <psodagud@codeaurora.org> Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ip: zero sockaddr returned on error queueWillem de Bruijn
[ Upstream commit f812116b174e59a350acc8e4856213a166a91222 ] The sockaddr is returned in IP(V6)_RECVERR as part of errhdr. That structure is defined and allocated on the stack as struct { struct sock_extended_err ee; struct sockaddr_in(6) offender; } errhdr; The second part is only initialized for certain SO_EE_ORIGIN values. Always initialize it completely. An MTU exceeded error on a SOCK_RAW/IPPROTO_RAW is one example that would return uninitialized bytes. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Also verified that there is no padding between errhdr.ee and errhdr.offender that could leak additional kernel data. Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-08nl80211: fix per-station group key get/del and memory leakJohannes Berg
commit 0fa7b39131576dd1baa6ca17fca53c65d7f62249 upstream. In case userspace attempts to obtain key information for or delete a unicast key, this is currently erroneously rejected unless the driver sets the WIPHY_FLAG_IBSS_RSN flag. Apparently enough drivers do so it was never noticed. Fix that, and while at it fix a potential memory leak: the error path in the get_key() function was placed after allocating a message but didn't free it - move it to a better place. Luckily admin permissions are needed to call this operation. Fixes: e31b82136d1ad ("cfg80211/mac80211: allow per-station GTKs") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-08mac80211: properly set CCK flag in radiotapMathy Vanhoef
commit 3a5c5e81d8128a9e43abc52b75dd21d3da7a0cfc upstream. Fix a regression introduced by commit a5e70697d0c4 ("mac80211: add radiotap flag and handling for 5/10 MHz") where the IEEE80211_CHAN_CCK channel type flag was incorrectly replaced by the IEEE80211_CHAN_OFDM flag. This commit fixes that by using the CCK flag again. Fixes: a5e70697d0c4 ("mac80211: add radiotap flag and handling for 5/10 MHz") Signed-off-by: Mathy Vanhoef <vanhoefm@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-29ipvs: uninitialized data with IP_VS_IPV6Dan Carpenter
commit 3b05ac3824ed9648c0d9c02d51d9b54e4e7e874f upstream. The app_tcp_pkt_out() function expects "*diff" to be set and ends up using uninitialized data if CONFIG_IP_VS_IPV6 is turned on. The same issue is there in app_tcp_pkt_in(). Thanks to Julian Anastasov for noticing that. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26ipvs: correct usage/allocation of seqadj ext in ipvsJesper Dangaard Brouer
[ upstream commit b25adce1606427fd88da08f5203714cada7f6a98 ] The IPVS FTP helper ip_vs_ftp could trigger an OOPS in nf_ct_seqadj_set, after commit 41d73ec053d2 (netfilter: nf_conntrack: make sequence number adjustments usuable without NAT). This is because, the seqadj ext is now allocated dynamically, and the IPVS code didn't handle this situation. Fix this in the IPVS nfct code by invoking the alloc function nfct_seqadj_ext_add(). Cc: <stable@vger.kernel.org> # 3.12.x Fixes: 41d73ec053d2 (netfilter: nf_conntrack: make sequence number adjustments usuable without NAT) Suggested-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26cfg80211: avoid mem leak on driver hint setArik Nemtsov
commit 34f05f543f02350e920bddb7660ffdd4697aaf60 upstream. In the already-set and intersect case of a driver-hint, the previous wiphy regdomain was not freed before being reset with a copy of the cfg80211 regdomain. [js: backport to 3.12] Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Acked-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26netfilter: ipset: small potential read beyond the end of bufferDan Carpenter
commit 2196937e12b1b4ba139806d132647e1651d655df upstream. We could be reading 8 bytes into a 4 byte buffer here. It seems harmless but adding a check is the right thing to do and it silences a static checker warning. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26net/core: Handle csum for CHECKSUM_COMPLETE VXLAN forwardingJay Vosburgh
[ Upstream commit 2c26d34bbcc0b3f30385d5587aa232289e2eed8e ] When using VXLAN tunnels and a sky2 device, I have experienced checksum failures of the following type: [ 4297.761899] eth0: hw csum failure [...] [ 4297.765223] Call Trace: [ 4297.765224] <IRQ> [<ffffffff8172f026>] dump_stack+0x46/0x58 [ 4297.765235] [<ffffffff8162ba52>] netdev_rx_csum_fault+0x42/0x50 [ 4297.765238] [<ffffffff8161c1a0>] ? skb_push+0x40/0x40 [ 4297.765240] [<ffffffff8162325c>] __skb_checksum_complete+0xbc/0xd0 [ 4297.765243] [<ffffffff8168c602>] tcp_v4_rcv+0x2e2/0x950 [ 4297.765246] [<ffffffff81666ca0>] ? ip_rcv_finish+0x360/0x360 These are reliably reproduced in a network topology of: container:eth0 == host(OVS VXLAN on VLAN) == bond0 == eth0 (sky2) -> switch When VXLAN encapsulated traffic is received from a similarly configured peer, the above warning is generated in the receive processing of the encapsulated packet. Note that the warning is associated with the container eth0. The skbs from sky2 have ip_summed set to CHECKSUM_COMPLETE, and because the packet is an encapsulated Ethernet frame, the checksum generated by the hardware includes the inner protocol and Ethernet headers. The receive code is careful to update the skb->csum, except in __dev_forward_skb, as called by dev_forward_skb. __dev_forward_skb calls eth_type_trans, which in turn calls skb_pull_inline(skb, ETH_HLEN) to skip over the Ethernet header, but does not update skb->csum when doing so. This patch resolves the problem by adding a call to skb_postpull_rcsum to update the skb->csum after the call to eth_type_trans. Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26tcp: Do not apply TSO segment limit to non-TSO packetsHerbert Xu
[ Upstream commit 843925f33fcc293d80acf2c5c8a78adf3344d49b ] Thomas Jarosch reported IPsec TCP stalls when a PMTU event occurs. In fact the problem was completely unrelated to IPsec. The bug is also reproducible if you just disable TSO/GSO. The problem is that when the MSS goes down, existing queued packet on the TX queue that have not been transmitted yet all look like TSO packets and get treated as such. This then triggers a bug where tcp_mss_split_point tells us to generate a zero-sized packet on the TX queue. Once that happens we're screwed because the zero-sized packet can never be removed by ACKs. Fixes: 1485348d242 ("tcp: Apply device TSO segment limit earlier") Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cheers, Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
