[ Upstream commit d3217b15a19a4779c39b212358a5c71d725822ee ]
Consider the scenario:
For a TCP-style socket, while processing the COOKIE_ECHO chunk in
sctp_sf_do_5_1D_ce(), after it has passed a series of sanity check,
a new association would be created in sctp_unpack_cookie(), but afterwards,
some processing maybe failed, and sctp_association_free() will be called to
free the previously allocated association, in sctp_association_free(),
sk_ack_backlog value is decremented for this socket, since the initial
value for sk_ack_backlog is 0, after the decrement, it will be 65535,
a wrap-around problem happens, and if we want to establish new associations
afterward in the same socket, ABORT would be triggered since sctp deem the
accept queue as full.
Fix this issue by only decrementing sk_ack_backlog for associations in
the endpoint's list.
Fix-suggested-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 39c36094d78c39e038c1e499b2364e13bce36f54 ]
I noticed we were sending wrong IPv4 ID in TCP flows when MTU discovery
is disabled.
Note how GSO/TSO packets do not have monotonically incrementing ID.
06:37:41.575531 IP (id 14227, proto: TCP (6), length: 4396)
06:37:41.575534 IP (id 14272, proto: TCP (6), length: 65212)
06:37:41.575544 IP (id 14312, proto: TCP (6), length: 57972)
06:37:41.575678 IP (id 14317, proto: TCP (6), length: 7292)
06:37:41.575683 IP (id 14361, proto: TCP (6), length: 63764)
It appears I introduced this bug in linux-3.1.
inet_getid() must return the old value of peer->ip_id_count,
not the new one.
Lets revert this part, and remove the prevention of
a null identification field in IPv6 Fragment Extension Header,
which is dubious and not even done properly.
Fixes: 87c48fa3b463 ("ipv6: make fragment identifications less predictable")
[ Upstream commit f98f89a0104454f35a62d681683c844f6dbf4043 ]
Enable the module alias hookup to allow tunnel modules to be autoloaded on demand.
This is in line with how most other netdev kinds work, and will allow userspace
to create tunnels without having CAP_SYS_MODULE.
Signed-off-by: Tom Gundersen <teg@jklm.no>
commit 895162b1101b3ea5db08ca6822ae9672717efec0 upstream.
else we may fail to forward skb even if original fragments do fit
outgoing link mtu:
1. remote sends 2k packets in two 1000 byte frags, DF set
2. we want to forward but only see '2k > mtu and DF set'
3. we then send icmp error saying that outgoing link is 1500
But original sender never sent a packet that would not fit
the outgoing link.
Setting local_df makes outgoing path test size vs.
IPCB(skb)->frag_max_size, so we will still send the correct
error in case the largest original size did not fit
outgoing link mtu.
Reported-by: Maxime Bizon <mbizon@freebox.fr>
Suggested-by: Maxime Bizon <mbizon@freebox.fr>
Fixes: 5f2d04f1f9 (ipv4: fix path MTU discovery with connection tracking)
Cc: Jiri Slaby <jslaby@suse.cz>
commit 3064639423c48d6e0eb9ecc27c512a58e38c6c57 upstream.
There could be a case, when NFSd file system is mounted in network, different
to socket's one, like below:
"ip netns exec" creates new network and mount namespace, which duplicates NFSd
mount point, created in init_net context. And thus NFS server stop in nested
network context leads to RPCBIND client destruction in init_net.
Then, on NFSd start in nested network context, rpc.nfsd process creates socket
in nested net and passes it into "write_ports", which leads to RPCBIND sockets
creation in init_net context because of the same reason (NFSd monut point was
created in init_net context). An attempt to register passed socket in nested
net leads to panic, because no RPCBIND client present in nexted network
namespace.
This patch add check that passed socket's net matches NFSd superblock's one.
And returns -EINVAL error to user psace otherwise.
v2: Put socket on exit.
Reported-by: Weng Meiling <wengmeiling.weng@huawei.com>
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: stable@vger.kernel.org
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[wengmeiling: backport to 3.4: adjust context]
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
commit 30d395b124c51db66d9f3ba0611cd62021afc392 upstream.
commit b9cdc88df8e63e81c723b82c286fc97f5d0dc325 upstream.
When using a virtio transport, the 9p net device may pass the physical
address of a kernel buffer to userspace via a scatterlist inside a
virtqueue. If the kernel buffer is mapped outside of the linear mapping
(e.g. highmem), then virt_to_page will return a bogus value and we will
populate the scatterlist with junk.
This patch uses kmap_to_page when populating the page array for a kernel
buffer.
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Yijing Wang <wangyijing@huawei.com>
commit 3f6fa3d489e127ca5a5b298eabac3ff5dbe0e112 upstream.
The length check is invalid since the length varies with type of
info response.
This was introduced by the commit cb3b3152b2f5939d67005cff841a1ca748b19888
Because of this, l2cap info rsp is not handled and command reject is sent.
> ACL data: handle 11 flags 0x02 dlen 16
L2CAP(s): Info rsp: type 2 result 0
Extended feature mask 0x00b8
Enhanced Retransmission mode
Streaming mode
FCS Option
Fixed Channels
< ACL data: handle 11 flags 0x00 dlen 10
L2CAP(s): Command rej: reason 0
Command not understood
Signed-off-by: Jaganath Kanakkassery <jaganath.k@samsung.com>
Signed-off-by: Chan-Yeol Park <chanyeol.park@samsung.com>
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Cc: Jianguo Wu <wujianguo@huawei.com>
commit cb3b3152b2f5939d67005cff841a1ca748b19888 upstream.
There has been code in place to check that the L2CAP length header
matches the amount of data received, but many PDU handlers have not been
checking that the data received actually matches that expected by the
specific PDU. This patch adds passing the length header to the specific
handler functions and ensures that those functions fail cleanly in the
case of an incorrect amount of data.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
[bwh: Backported to 3.2:
- Adjust context
- Move uses of *req below the new check in l2cap_connect_req]
[wujg: Backported to 3.4:
- Adjust context
- Adjust l2cap_create_channel_rsp()'s parameters]
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
commit 6329b8d917adc077caa60c2447385554130853a3 upstream.
If an Ad-Hoc node receives packets with the Cell ID or its own MAC
address as source address, it hits a WARN_ON in sta_info_insert_check()
With many packets, this can massively spam the logs. One way that this
can easily happen is through having Cisco APs in the area with rouge AP
detection and countermeasures enabled.
Such Cisco APs will regularly send fake beacons, disassoc and deauth
packets that trigger these warnings.
To fix this issue, drop such spoofed packets early in the rx path.
Reported-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
[bwh: Backported to 3.2: use compare_ether_addr() instead of ether_addr_equal()]
Cc: Qiang Huang <h.huangqiang@huawei.com>
commit c815797663b72e3ac1736f1886538152bc48e4af upstream.
If a P2P-Device is present and another virtual interface triggers
the connection work, the system crash because it tries to check
if the P2P-Device's netdev (which doesn't exist) is up. Skip any
wdevs that have no netdev to fix this.
Reported-by: YanBo <dreamfly281@gmail.com>
[bwh: Backported to 3.2: adjust context]
commit 5b632fe85ec82e5c43740b52e74c66df50a37db3 upstream.
Commit f0425beda4d404a6e751439b562100b902ba9c98 "mac80211: retry sending
failed BAR frames later instead of tearing down aggr" caused regression
on rt2x00 hardware (connection hangs). This regression was fixed by
commit be03d4a45c09ee5100d3aaaedd087f19bc20d01 "rt2x00: Don't let
mac80211 send a BAR when an AMPDU subframe fails". But the latter
commit caused yet another problem reported in
https://bugzilla.kernel.org/show_bug.cgi?id=42828#c22
After long discussion in this thread:
http://mid.gmane.org/20121018075615.GA18212@redhat.com
and testing various alternative solutions, which failed on one or other
setup, we have no other good fix for the issues like just revert both
mentioned earlier commits.
To do not affect other hardware which benefit from commit
f0425beda4d404a6e751439b562100b902ba9c98, instead of reverting it,
introduce flag that when used will restore mac80211 behaviour before
the commit.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
[replaced link with mid.gmane.org that has message-id]
[hq: Backported to 3.4: adjust context]
Signed-off-by: Qiang Huang <h.huangqiang@huawei.com>
[ Upstream commit e33d0ba8047b049c9262fdb1fcafb93cb52ceceb ]
Recycling skb always had been very tough...
This time it appears GRO layer can accumulate skb->truesize
adjustments made by drivers when they attach a fragment to skb.
skb_gro_receive() can only subtract from skb->truesize the used part
of a fragment.
I spotted this problem seeing TcpExtPruneCalled and
TcpExtTCPRcvCollapsed that were unexpected with a recent kernel, where
TCP receive window should be sized properly to accept traffic coming
from a driver not overshooting skb->truesize.
[ Upstream commit ec47ea82477404631d49b8e568c71826c9b663ac ]
With the recent changes for how we compute the skb truesize it occurs to me
we are probably going to have a lot of calls to skb_end_pointer -
skb->head. Instead of running all over the place doing that it would make
more sense to just make it a separate inline skb_end_offset(skb) that way
we can return the correct value without having gcc having to do all the
optimization to cancel out skb->head - skb->head.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit fbdc0ad095c0a299e9abf5d8ac8f58374951149a ]
the value of itag is a random value from stack, and may not be initiated by
fib_validate_source, which called fib_combine_itag if CONFIG_IP_ROUTE_CLASSID
is not set
This will make the cached dst uncertainty
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
[ Upstream commit 16c0b164bd24d44db137693a36b428ba28970c62 ]
We drop packet unconditionally when we fail to mirror it. This is not intended
in some cases. Consdier for kvm guest, we may mirror the traffic of the bridge
to a tap device used by a VM. When kernel fails to mirror the packet in
conditions such as when qemu crashes or stop polling the tap, it's hard for the
management software to detect such condition and clean the the mirroring
before. This would lead all packets to the bridge to be dropped and break the
netowrk of other virtual machines.
To solve the issue, the patch does not drop packets when kernel fails to mirror
it, and only drop the redirected packets.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit aeefa1ecfc799b0ea2c4979617f14cecd5cccbfd ]
Increment fib_info_cnt in fib_create_info() right after successfuly
alllocating fib_info structure, overwise fib_metrics allocation failure
leads to fib_info_cnt incorrectly decremented in free_fib_info(), called
on error path from fib_create_info().
Signed-off-by: Sergey Popovich <popovich_sergei@mail.ru>
[ Upstream commit ca6c5d4ad216d5942ae544bbf02503041bd802aa ]
local_df means 'ignore DF bit if set', so if its set we're
allowed to perform ip fragmentation.
This wasn't noticed earlier because the output path also drops such skbs
(and emits needed icmp error) and because netfilter ip defrag did not
set local_df until couple of days ago.
Only difference is that DF-packets-larger-than MTU now discarded
earlier (f.e. we avoid pointless netfilter postrouting trip).
While at it, drop the repeated test ip_exceeds_mtu, checking it once
is enough...
Fixes: fe6cc55f3a9 ("net: ip, ipv6: handle gso skbs in forwarding path")
[ Upstream commit 0cda345d1b2201dd15591b163e3c92bad5191745 ]
commit b9f47a3aaeab (tcp_cubic: limit delayed_ack ratio to prevent
divide error) try to prevent divide error, but there is still a little
chance that delayed_ack can reach zero. In case the param cnt get
negative value, then ratio+cnt would overflow and may happen to be zero.
As a result, min(ratio, ACK_RATIO_LIMIT) will calculate to be zero.
In some old kernels, such as 2.6.32, there is a bug that would
pass negative param, which then ultimately leads to this divide error.
commit 5b35e1e6e9c (tcp: fix tcp_trim_head() to adjust segment count
with skb MSS) fixed the negative param issue. However,
it's safe that we fix the range of delayed_ack as well,
to make sure we do not hit a divide by zero.
CC: Stephen Hemminger <shemminger@vyatta.com>
Signed-off-by: Liu Yu <allanyuliu@tencent.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit c53864fd60227de025cb79e05493b13f69843971 ]
Since 115c9b81928360d769a76c632bae62d15206a94a (rtnetlink: Fix problem with
buffer allocation), RTM_NEWLINK messages only contain the IFLA_VFINFO_LIST
attribute if they were solicited by a GETLINK message containing an
IFLA_EXT_MASK attribute with the RTEXT_FILTER_VF flag.
That was done because some user programs broke when they received more data
than expected - because IFLA_VFINFO_LIST contains information for each VF
it can become large if there are many VFs.
However, the IFLA_VF_PORTS attribute, supplied for devices which implement
ndo_get_vf_port (currently the 'enic' driver only), has the same problem.
It supplies per-VF information and can therefore become large, but it is
not currently conditional on the IFLA_EXT_MASK value.
Worse, it interacts badly with the existing EXT_MASK handling. When
IFLA_EXT_MASK is not supplied, the buffer for netlink replies is fixed at
NLMSG_GOODSIZE. If the information for IFLA_VF_PORTS exceeds this, then
rtnl_fill_ifinfo() returns -EMSGSIZE on the first message in a packet.
netlink_dump() will misinterpret this as having finished the listing and
omit data for this interface and all subsequent ones. That can cause
getifaddrs(3) to enter an infinite loop.
This patch addresses the problem by only supplying IFLA_VF_PORTS when
IFLA_EXT_MASK is supplied with the RTEXT_FILTER_VF flag set.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 973462bbde79bb827824c73b59027a0aed5c9ca6 ]
Without IFLA_EXT_MASK specified, the information reported for a single
interface in response to RTM_GETLINK is expected to fit within a netlink
packet of NLMSG_GOODSIZE.
If it doesn't, however, things will go badly wrong, When listing all
interfaces, netlink_dump() will incorrectly treat -EMSGSIZE on the first
message in a packet as the end of the listing and omit information for
that interface and all subsequent ones. This can cause getifaddrs(3) to
This patch won't fix the problem, but it will WARN_ON() making it easier to
track down what's going wrong.
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
[ Upstream commit 05ab8f2647e4221cbdb3856dd7d32bd5407316b3 ]
The BPF_S_ANC_NLATTR and BPF_S_ANC_NLATTR_NEST extensions fail to check
for a minimal message length before testing the supplied offset to be
within the bounds of the message. This allows the subtraction of the nla
header to underflow and therefore -- as the data type is unsigned --
allowing far to big offset and length values for the search of the
netlink attribute.
The remainder calculation for the BPF_S_ANC_NLATTR_NEST extension is
also wrong. It has the minuend and subtrahend mixed up, therefore
calculates a huge length value, allowing to overrun the end of the
message while looking for the netlink attribute.
The following three BPF snippets will trigger the bugs when attached to
a UNIX datagram socket and parsing a message with length 1, 2 or 3.
,-[ PoC for missing size check in BPF_S_ANC_NLATTR ]--
| ld #0x87654321
| ldx #42
| ld #nla
| ret a
,-[ PoC for the same bug in BPF_S_ANC_NLATTR_NEST ]--
| ld #0x87654321
| ldx #42
| ld #nlan
| ret a
,-[ PoC for wrong remainder calculation in BPF_S_ANC_NLATTR_NEST ]--
| ; (needs a fake netlink header at offset 0)
| ld #0
| ldx #42
| ld #nlan
| ret a
Fix the first issue by ensuring the message length fulfills the minimal
size constrains of a nla header. Fix the second bug by getting the math
for the remainder calculation right.
Fixes: 4738c1db15 ("[SKFILTER]: Add SKF_ADF_NLATTR instruction")
Fixes: d214c7537b ("filter: add SKF_AD_NLATTR_NEST to look for nested..")
Cc: Patrick McHardy <kaber@trash.net>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[ Upstream commit b04c46190219a4f845e46a459e3102137b7f6cac ]
Plug a group_info refcount leak in ping_init.
group_info is only needed during initialization and
the code failed to release the reference on exit.
While here move grabbing the reference to a place
where it is actually needed.
Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com>
Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com>
Signed-off-by: xiaoming wang <xiaoming.wang@intel.com>
[ Upstream commit 30f78d8ebf7f514801e71b88a10c948275168518 ]
Francois reported that setting big mtu on loopback device could prevent
tcp sessions making progress.
We do not support (yet ?) IPv6 Jumbograms and cook corrupted packets.
We must limit the IPv6 MTU to (65535 + 40) bytes in theory.
Tested:
ifconfig lo mtu 70000
netperf -H ::1
Before patch : Throughput : 0.05 Mbits
After patch : Throughput : 35484 Mbits
Reported-by: Francois WELLENREITER <f.wellenreiter@gmail.com>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 6d39d589bb76ee8a1c6cde6822006ae0053decff ]
In case of tcp, gso_size contains the tcpmss.
For UFO (udp fragmentation offloading) skbs, gso_size is the fragment
payload size, i.e. we must not account for udp header size.
Otherwise, when using virtio drivers, a to-be-forwarded UFO GSO packet
will be needlessly fragmented in the forward path, because we think its
individual segments are too large for the outgoing link.
Fixes: fe6cc55f3a9a053 ("net: ip, ipv6: handle gso skbs in forwarding path")
Reported-by: Tobias Brunner <tobias@strongswan.org>
[ Upstream commit f34c4a35d87949fbb0e0f31eba3c054e9f8199ba ]
When l2tp driver tries to get PMTU for the tunnel destination, it uses
the pointer to struct sock that represents PPPoX socket, while it
should use the pointer that represents UDP socket of the tunnel.
Signed-off-by: Dmitry Petukhov <dmgenp@gmail.com>
[ Upstream commit 1e1cdf8ac78793e0875465e98a648df64694a8d0 ]
In function sctp_wake_up_waiters(), we need to involve a test
if the association is declared dead. If so, we don't have any
reference to a possible sibling association anymore and need
to invoke sctp_write_space() instead, and normally walk the
socket's associations and notify them of new wmem space. The
reason for special casing is that otherwise, we could run
into the following issue when a sctp_primitive_SEND() call
from sctp_sendmsg() fails, and tries to flush an association's
outq, i.e. in the following way:
`-> list_del(&asoc->asocs) <-- poisons list pointer
asoc->base.dead = true
sctp_outq_free(&asoc->outqueue)
`-> __sctp_outq_teardown()
`-> sctp_chunk_free()
`-> consume_skb()
`-> sctp_wfree()
`-> sctp_wake_up_waiters() <-- dereferences poisoned pointers
if asoc->ep->sndbuf_policy=0
Therefore, only walk the list in an 'optimized' way if we find
that the current association is still active. We could also use
list_del_init() in addition when we call sctp_association_free(),
but as Vlad suggests, we want to trap such bugs and thus leave
it poisoned as is.
Why is it safe to resolve the issue by testing for asoc->base.dead?
Parallel calls to sctp_sendmsg() are protected under socket lock,
that is lock_sock()/release_sock(). Only within that path under
lock held, we're setting skb/chunk owner via sctp_set_owner_w().
Eventually, chunks are freed directly by an association still
under that lock. So when traversing association list on destruction
time from sctp_wake_up_waiters() via sctp_wfree(), a different
CPU can't be running sctp_wfree() while another one calls
sctp_association_free() as both happens under the same lock.
Therefore, this can also not race with setting/testing against
asoc->base.dead as we are guaranteed for this to happen in order,
under lock. Further, Vlad says: the times we check asoc->base.dead
is when we've cached an association pointer for later processing.
In between cache and processing, the association may have been
freed and is simply still around due to reference counts. We check
asoc->base.dead under a lock, so it should always be safe to check
and not race against sctp_association_free(). Stress-testing seems
fine now, too.
Fixes: cd253f9f357d ("net: sctp: wake up all assocs if sndbuf policy is per socket")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Vlad Yasevich <vyasevic@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 52c35befb69b005c3fc5afdaae3a5717ad013411 ]
SCTP charges chunks for wmem accounting via skb->truesize in
sctp_set_owner_w(), and sctp_wfree() respectively as the
reverse operation. If a sender runs out of wmem, it needs to
wait via sctp_wait_for_sndbuf(), and gets woken up by a call
to __sctp_write_space() mostly via sctp_wfree().
__sctp_write_space() is being called per association. Although
we assign sk->sk_write_space() to sctp_write_space(), which
is then being done per socket, it is only used if send space
is increased per socket option (SO_SNDBUF), as SOCK_USE_WRITE_QUEUE
is set and therefore not invoked in sock_wfree().
Commit 4c3a5bdae293 ("sctp: Don't charge for data in sndbuf
again when transmitting packet") fixed an issue where in case
sctp_packet_transmit() manages to queue up more than sndbuf
bytes, sctp_wait_for_sndbuf() will never be woken up again
unless it is interrupted by a signal. However, a still
remaining issue is that if net.sctp.sndbuf_policy=0, that is
accounting per socket, and one-to-many sockets are in use,
the reclaimed write space from sctp_wfree() is 'unfairly'
handed back on the server to the association that is the lucky
one to be woken up again via __sctp_write_space(), while
the remaining associations are never be woken up again
(unless by a signal).
The effect disappears with net.sctp.sndbuf_policy=1, that
is wmem accounting per association, as it guarantees a fair
share of wmem among associations.
Therefore, if we have reclaimed memory in case of per socket
accounting, wake all related associations to a socket in a
fair manner, that is, traverse the socket association list
starting from the current neighbour of the association and
issue a __sctp_write_space() to everyone until we end up
waking ourselves. This guarantees that no association is
preferred over another and even if more associations are
taken into the one-to-many session, all receivers will get
messages from the server and are not stalled forever on
high load. This setting still leaves the advantage of per
socket accounting in touch as an association can still use
up global limits if unused by others.
Fixes: 4eb701dfc618 ("[SCTP] Fix SCTP sendbuffer accouting.")
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Neil Horman <nhorman@tuxdriver.com>
commit c58dd2dd443c26d856a168db108a0cd11c285bf3 upstream.
All xtables variants suffer from the defect that the copy_to_user()
to copy the counters to user memory may fail after the table has
already been exchanged and thus exposed. Return an error at this
point will result in freeing the already exposed table. Any
subsequent packet processing will result in a kernel panic.
We can't copy the counters before exposing the new tables as we
want provide the counter state after the old table has been
unhooked. Therefore convert this into a silent error.
Cc: Florian Westphal <fw@strlen.de>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
commit 5981a8821b774ada0be512fd9bad7c241e17657e upstream.
This patch fixes authentication failure on LE link re-connection when
BlueZ acts as slave (peripheral). LTK is removed from the internal list
after its first use causing PIN or Key missing reply when re-connecting
the link. The LE Long Term Key Request event indicates that the master
is attempting to encrypt or re-encrypt the link.
Pre-condition: BlueZ host paired and running as slave.
How to reproduce(master):
1) Establish an ACL LE encrypted link
2) Disconnect the link
3) Try to re-establish the ACL LE encrypted link (fails)
> HCI Event: LE Meta Event (0x3e) plen 19
LE Connection Complete (0x01)
Status: Success (0x00)
Handle: 64
Role: Slave (0x01)
@ Device Connected: 00:02:72:DC:29:C9 (1) flags 0x0000
> HCI Event: LE Meta Event (0x3e) plen 13
LE Long Term Key Request (0x05)
Handle: 64
Random number: 875be18439d9aa37
Encryption diversifier: 0x76ed
< HCI Command: LE Long Term Key Request Reply (0x08|0x001a) plen 18
Handle: 64
Long term key: 2aa531db2fce9f00a0569c7d23d17409
> HCI Event: Command Complete (0x0e) plen 6
LE Long Term Key Request Reply (0x08|0x001a) ncmd 1
Handle: 64
> HCI Event: Encryption Change (0x08) plen 4
Handle: 64
Encryption: Enabled with AES-CCM (0x01)
@ Device Disconnected: 00:02:72:DC:29:C9 (1) reason 3
< HCI Command: LE Set Advertise Enable (0x08|0x000a) plen 1
Advertising: Enabled (0x01)
> HCI Event: Command Complete (0x0e) plen 4
LE Set Advertise Enable (0x08|0x000a) ncmd 1
Handle: 64
Role: Slave (0x01)
Handle: 64
< HCI Command: LE Long Term Key Request Neg Reply (0x08|0x001b) plen 2
Handle: 64
LE Long Term Key Request Neg Reply (0x08|0x001b) ncmd 1
Handle: 64
> HCI Event: Disconnect Complete (0x05) plen 4
Handle: 64
Reason: Authentication Failure (0x05)
@ Device Disconnected: 00:02:72:DC:29:C9 (1) reason 0
Signed-off-by: Claudio Takahasi <claudio.takahasi@openbossa.org>
[ Upstream commit bf39b4247b8799935ea91d90db250ab608a58e50 ]
Binding might result in a NULL device which is later dereferenced
without checking.
[ Upstream commit 43a43b6040165f7b40b5b489fe61a4cb7f8c4980 ]
After commit c15b1ccadb323ea ("ipv6: move DAD and addrconf_verify
processing to workqueue") some counters are now updated in process context
and thus need to disable bh before doing so, otherwise deadlocks can
happen on 32-bit archs. Fabio Estevam noticed this while while mounting
a NFS volume on an ARM board.
As a compensation for missing this I looked after the other *_STATS_BH
and found three other calls which need updating:
1) icmp6_send: ip6_fragment -> icmpv6_send -> icmp6_send (error handling)
2) ip6_push_pending_frames: rawv6_sendmsg -> rawv6_push_pending_frames -> ...
(only in case of icmp protocol with raw sockets in error handling)
3) ping6_v6_sendmsg (error handling)
Fixes: c15b1ccadb323ea ("ipv6: move DAD and addrconf_verify processing to workqueue")
Reported-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
[ Upstream commit e367c2d03dba4c9bcafad24688fadb79dd95b218 ]
In ip6_append_data_mtu(), when the xfrm mode is not tunnel(such as
transport),the ipsec header need to be added in the first fragment, so the mtu
will decrease to reserve space for it, then the second fragment come, the mtu
should be turn back, as the commit 0c1833797a5a6ec23ea9261d979aa18078720b74
said. however, in the commit a493e60ac4bbe2e977e7129d6d8cbb0dd236be, it use
*mtu = min(*mtu, ...) to change the mtu, which lead to the new mtu is alway
equal with the first fragment's. and cannot turn back.
when I test through ping6 -c1 -s5000 $ip (mtu=1280):
...frag (0|1232) ESP(spi=0x00002000,seq=0xb), length 1232
...frag (1232|1216)
...frag (2448|1216)
...frag (3664|1216)
...frag (4880|164)
which should be:
...frag (0|1232) ESP(spi=0x00001000,seq=0x1), length 1232
...frag (1232|1232)
...frag (2464|1232)
...frag (3696|1232)
...frag (4928|116)
so delete the min() when change back the mtu.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Fixes: 75a493e60ac4bb ("ipv6: ip6_append_data_mtu did not care about pmtudisc and frag_size")
[ Upstream commit ecab67015ef6e3f3635551dcc9971cf363cc1cd5 ]
tmp_prefered_lft is an offset to ifp->tstamp, not now. Therefore
age needs to be added to the condition.
Age calculation in ipv6_create_tempaddr is different from the one
in addrconf_verify and doesn't consider ADDRCONF_TIMER_FUZZ_MINUS.
This can cause age in ipv6_create_tempaddr to be less than the one
in addrconf_verify and therefore unnecessary temporary address to
be generated.
Use age calculation as in addrconf_modify to avoid this.
Signed-off-by: Heiner Kallweit <heiner.kallweit@web.de>
[ Upstream commit dbb490b96584d4e958533fb637f08b557f505657 ]
When copying in a struct msghdr from the user, if the user has set the
msg_namelen parameter to a negative value it gets clamped to a valid
size due to a comparison between signed and unsigned values.
Ensure the syscall errors when the user passes in a negative value.
Signed-off-by: Matthew Leach <matthew.leach@arm.com>
[ Upstream commit dd38743b4cc2f86be250eaf156cf113ba3dd531a ]
With TX VLAN offload enabled the source MAC address for frames sent using the
VLAN interface is currently set to the address of the real interface. This is
wrong since the VLAN interface may be configured with a different address.
The bug was introduced in commit 2205369a314e12fcec4781cc73ac9c08fc2b47de
("vlan: Fix header ops passthru when doing TX VLAN offload.").
This patch sets the source address before calling the create function of the
real interface.
Signed-off-by: Peter Boström <peter.bostrom@netrounds.com>
[ Upstream commit c88507fbad8055297c1d1e21e599f46960cbee39 ]
DST_NOCOUNT should only be used if an authorized user adds routes
locally. In case of routes which are added on behalf of router
advertisments this flag must not get used as it allows an unlimited
number of routes getting added remotely.
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit de1443916791d75fdd26becb116898277bb0273f ]
Some applications didn't expect recvmsg() on a non blocking socket
could return -EINTR. This possibility was added as a side effect
of commit b3ca9b02b00704 ("net: fix multithreaded signal handling in
unix recv routines").
To hit this bug, you need to be a bit unlucky, as the u->readlock
mutex is usually held for very small periods.
Fixes: b3ca9b02b00704 ("net: fix multithreaded signal handling in unix recv routines")
Cc: Rainer Weikusat <rweikusat@mobileactivedefense.com>
[ Upstream commit 6565b9eeef194afbb3beec80d6dd2447f4091f8c ]
MLD queries are supposed to have an IPv6 link-local source address
according to RFC2710, section 4 and RFC3810, section 5.1.14. This patch
adds a sanity check to ignore such broken MLD queries.
Without this check, such malformed MLD queries can result in a
denial of service: The queries are ignored by any MLD listener
therefore they will not respond with an MLD report. However,
without this patch these malformed MLD queries would enable the
snooping part in the bridge code, potentially shutting down the
according ports towards these hosts for multicast traffic as the
bridge did not learn about these listeners.
Reported-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: Linus Lüssing <linus.luessing@web.de>
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit c485658bae87faccd7aed540fd2ca3ab37992310 ]
While working on ec0223ec48a9 ("net: sctp: fix sctp_sf_do_5_1D_ce to
verify if we/peer is AUTH capable"), we noticed that there's a skb
memory leakage in the error path.
Running the same reproducer as in ec0223ec48a9 and by unconditionally
jumping to the error label (to simulate an error condition) in
sctp_sf_do_5_1D_ce() receive path lets kmemleak detector bark about
the unfreed chunk->auth_chunk skb clone:
Unreferenced object 0xffff8800b8f3a000 (size 256):
comm "softirq", pid 0, jiffies 4294769856 (age 110.757s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
89 ab 75 5e d4 01 58 13 00 00 00 00 00 00 00 00 ..u^..X.........
backtrace:
[<ffffffff816660be>] kmemleak_alloc+0x4e/0xb0
[<ffffffff8119f328>] kmem_cache_alloc+0xc8/0x210
[<ffffffff81566929>] skb_clone+0x49/0xb0
[<ffffffffa0467459>] sctp_endpoint_bh_rcv+0x1d9/0x230 [sctp]
[<ffffffffa046fdbc>] sctp_inq_push+0x4c/0x70 [sctp]
[<ffffffffa047e8de>] sctp_rcv+0x82e/0x9a0 [sctp]
[<ffffffff815abd38>] ip_local_deliver_finish+0xa8/0x210
[<ffffffff815a64af>] nf_reinject+0xbf/0x180
[<ffffffffa04b4762>] nfqnl_recv_verdict+0x1d2/0x2b0 [nfnetlink_queue]
[<ffffffffa04aa40b>] nfnetlink_rcv_msg+0x14b/0x250 [nfnetlink]
[<ffffffff815a3269>] netlink_rcv_skb+0xa9/0xc0
[<ffffffffa04aa7cf>] nfnetlink_rcv+0x23f/0x408 [nfnetlink]
[<ffffffff815a2bd8>] netlink_unicast+0x168/0x250
[<ffffffff815a2fa1>] netlink_sendmsg+0x2e1/0x3f0
[<ffffffff8155cc6b>] sock_sendmsg+0x8b/0xc0
[<ffffffff8155d449>] ___sys_sendmsg+0x369/0x380
What happens is that commit bbd0d59809f9 clones the skb containing
the AUTH chunk in sctp_endpoint_bh_rcv() when having the edge case
that an endpoint requires COOKIE-ECHO chunks to be authenticated:
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
------------------ AUTH; COOKIE-ECHO ---------------->
<-------------------- COOKIE-ACK ---------------------
When we enter sctp_sf_do_5_1D_ce() and before we actually get to
the point where we process (and subsequently free) a non-NULL
chunk->auth_chunk, we could hit the "goto nomem_init" path from
an error condition and thus leave the cloned skb around w/o
freeing it.
The fix is to centrally free such clones in sctp_chunk_destroy()
handler that is invoked from sctp_chunk_free() after all refs have
dropped; and also move both kfree_skb(chunk->auth_chunk) there,
so that chunk->auth_chunk is either NULL (since sctp_chunkify()
allocs new chunks through kmem_cache_zalloc()) or non-NULL with
a valid skb pointer. chunk->skb and chunk->auth_chunk are the
only skbs in the sctp_chunk structure that need to be handeled.
While at it, we should use consume_skb() for both. It is the same
as dev_kfree_skb() but more appropriately named as we are not
a device but a protocol. Also, this effectively replaces the
kfree_skb() from both invocations into consume_skb(). Functions
are the same only that kfree_skb() assumes that the frame was
being dropped after a failure (e.g. for tools like drop monitor),
usage of consume_skb() seems more appropriate in function
sctp_chunk_destroy() though.
Fixes: bbd0d59809f9 ("[SCTP]: Implement the receive and verification of AUTH chunk")
Cc: Vlad Yasevich <yasevich@gmail.com>
commit b22f5126a24b3b2f15448c3f2a254fc10cbc2b92 upstream.
Some occurences in the netfilter tree use skb_header_pointer() in
the following way ...
struct dccp_hdr _dh, *dh;
skb_header_pointer(skb, dataoff, sizeof(_dh), &dh);
... where dh itself is a pointer that is being passed as the copy
buffer. Instead, we need to use &_dh as the forth argument so that
we're copying the data into an actual buffer that sits on the stack.
Currently, we probably could overwrite memory on the stack (e.g.
with a possibly mal-formed DCCP packet), but unintentionally, as
we only want the buffer to be placed into _dh variable.
Fixes: 2bc780499aa3 ("[NETFILTER]: nf_conntrack: add DCCP protocol support")
commit 9a1ea2dbff11547a8e664f143c1ffefc586a577a upstream.
With the current full handling, there is a race between osds and
clients getting the first map marked full. If the osd wins, it will
return -ENOSPC to any writes, but the client may already have writes
in flight. This results in the client getting the error and
propagating it up the stack. For rbd, the block layer turns this into
EIO, which can cause corruption in filesystems above it.
To avoid this race, osds are being changed to drop writes that came
from clients with an osdmap older than the last osdmap marked full.
In order for this to work, clients must resend all writes after they
encounter a full -> not full transition in the osdmap. osds will wait
for an updated map instead of processing a request from a client with
a newer map, so resent writes will not be dropped by the osd unless
there is another not full -> full transition.
This approach requires both osds and clients to be fixed to avoid the
race. Old clients talking to osds with this fix may hang instead of
returning EIO and potentially corrupting an fs. New clients talking to
old osds have the same behavior as before if they encounter this race.
Fixes: http://tracker.ceph.com/issues/6938
Reviewed-by: Sage Weil <sage@inktank.com>
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
commit 1d147bfa64293b2723c4fec50922168658e613ba upstream.
There is a race between the TX path and the STA wakeup: while
a station is sleeping, mac80211 buffers frames until it wakes
up, then the frames are transmitted. However, the RX and TX
path are concurrent, so the packet indicating wakeup can be
processed while a packet is being transmitted.
This can lead to a situation where the buffered frames list
is emptied on the one side, while a frame is being added on
the other side, as the station is still seen as sleeping in
the TX path.
As a result, the newly added frame will not be send anytime
soon. It might be sent much later (and out of order) when the
station goes to sleep and wakes up the next time.
Additionally, it can lead to the crash below.
Fix all this by synchronising both paths with a new lock.
Both path are not fastpath since they handle PS situations.
In a later patch we'll remove the extra skb queue locks to
reduce locking overhead.
BUG: unable to handle kernel
NULL pointer dereference at 000000b0
IP: [<ff6f1791>] ieee80211_report_used_skb+0x11/0x3e0 [mac80211]
*pde = 00000000
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
EIP: 0060:[<ff6f1791>] EFLAGS: 00210282 CPU: 1
EIP is at ieee80211_report_used_skb+0x11/0x3e0 [mac80211]
EAX: e5900da0 EBX: 00000000 ECX: 00000001 EDX: 00000000
ESI: e41d00c0 EDI: e5900da0 EBP: ebe458e4 ESP: ebe458b0
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR0: 8005003b CR2: 000000b0 CR3: 25a78000 CR4: 000407d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
Process iperf (pid: 3934, ti=ebe44000 task=e757c0b0 task.ti=ebe44000)
iwlwifi 0000:02:00.0: I iwl_pcie_enqueue_hcmd Sending command LQ_CMD (#4e), seq: 0x0903, 92 bytes at 3[3]:9
Stack:
e403b32c ebe458c4 00200002 00200286 e403b338 ebe458cc c10960bb e5900da0
ff76a6ec ebe458d8 00000000 e41d00c0 e5900da0 ebe458f0 ff6f1b75 e403b210
ebe4598c ff723dc1 00000000 ff76a6ec e597c978 e403b758 00000002 00000002
Call Trace:
[<ff6f1b75>] ieee80211_free_txskb+0x15/0x20 [mac80211]
[<ff723dc1>] invoke_tx_handlers+0x1661/0x1780 [mac80211]
[<ff7248a5>] ieee80211_tx+0x75/0x100 [mac80211]
[<ff7249bf>] ieee80211_xmit+0x8f/0xc0 [mac80211]
[<ff72550e>] ieee80211_subif_start_xmit+0x4fe/0xe20 [mac80211]
[<c149ef70>] dev_hard_start_xmit+0x450/0x950
[<c14b9aa9>] sch_direct_xmit+0xa9/0x250
[<c14b9c9b>] __qdisc_run+0x4b/0x150
[<c149f732>] dev_queue_xmit+0x2c2/0xca0
Reported-by: Yaara Rozenblum <yaara.rozenblum@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
[reword commit log, use a separate lock]
[ Upstream commit ec0223ec48a90cb605244b45f7c62de856403729 ]
RFC4895 introduced AUTH chunks for SCTP; during the SCTP
handshake RANDOM; CHUNKS; HMAC-ALGO are negotiated (CHUNKS
being optional though):
-------------------- COOKIE-ECHO -------------------->
A special case is when an endpoint requires COOKIE-ECHO
RFC4895, section 6.3. Receiving Authenticated Chunks says:
The receiver MUST use the HMAC algorithm indicated in
the HMAC Identifier field. If this algorithm was not
specified by the receiver in the HMAC-ALGO parameter in
the INIT or INIT-ACK chunk during association setup, the
AUTH chunk and all the chunks after it MUST be discarded
and an ERROR chunk SHOULD be sent with the error cause
defined in Section 4.1. [...] If no endpoint pair shared
key has been configured for that Shared Key Identifier,
all authenticated chunks MUST be silently discarded. [...]
When an endpoint requires COOKIE-ECHO chunks to be
authenticated, some special procedures have to be followed
because the reception of a COOKIE-ECHO chunk might result
in the creation of an SCTP association. If a packet arrives
containing an AUTH chunk as a first chunk, a COOKIE-ECHO
chunk as the second chunk, and possibly more chunks after
them, and the receiver does not have an STCB for that
packet, then authentication is based on the contents of
the COOKIE-ECHO chunk. In this situation, the receiver MUST
authenticate the chunks in the packet by using the RANDOM
parameters, CHUNKS parameters and HMAC_ALGO parameters
obtained from the COOKIE-ECHO chunk, and possibly a local
shared secret as inputs to the authentication procedure
specified in Section 6.3. If authentication fails, then
the packet is discarded. If the authentication is successful,
the COOKIE-ECHO and all the chunks after the COOKIE-ECHO
MUST be processed. If the receiver has an STCB, it MUST
process the AUTH chunk as described above using the STCB
from the existing association to authenticate the
COOKIE-ECHO chunk and all the chunks after it. [...]
Commit bbd0d59809f9 introduced the possibility to receive
and verification of AUTH chunk, including the edge case for
authenticated COOKIE-ECHO. On reception of COOKIE-ECHO,
the function sctp_sf_do_5_1D_ce() handles processing,
unpacks and creates a new association if it passed sanity
checks and also tests for authentication chunks being
present. After a new association has been processed, it
invokes sctp_process_init() on the new association and
walks through the parameter list it received from the INIT
chunk. It checks SCTP_PARAM_RANDOM, SCTP_PARAM_HMAC_ALGO
and SCTP_PARAM_CHUNKS, and copies them into asoc->peer
meta data (peer_random, peer_hmacs, peer_chunks) in case
sysctl -w net.sctp.auth_enable=1 is set. If in INIT's
SCTP_PARAM_SUPPORTED_EXT parameter SCTP_CID_AUTH is set,
peer_random != NULL and peer_hmacs != NULL the peer is to be
assumed asoc->peer.auth_capable=1, in any other case
asoc->peer.auth_capable=0.
Now, if in sctp_sf_do_5_1D_ce() chunk->auth_chunk is
available, we set up a fake auth chunk and pass that on to
sctp_sf_authenticate(), which at latest in
sctp_auth_calculate_hmac() reliably dereferences a NULL pointer
at position 0..0008 when setting up the crypto key in
crypto_hash_setkey() by using asoc->asoc_shared_key that is
NULL as condition key_id == asoc->active_key_id is true if
the AUTH chunk was injected correctly from remote. This
happens no matter what net.sctp.auth_enable sysctl says.
The fix is to check for net->sctp.auth_enable and for
asoc->peer.auth_capable before doing any operations like
sctp_sf_authenticate() as no key is activated in
sctp_auth_asoc_init_active_key() for each case.
Now as RFC4895 section 6.3 states that if the used HMAC-ALGO
passed from the INIT chunk was not used in the AUTH chunk, we
SHOULD send an error; however in this case it would be better
to just silently discard such a maliciously prepared handshake
as we didn't even receive a parameter at all. Also, as our
endpoint has no shared key configured, section 6.3 says that
MUST silently discard, which we are doing from now onwards.
Before calling sctp_sf_pdiscard(), we need not only to free
the association, but also the chunk->auth_chunk skb, as
commit bbd0d59809f9 created a skb clone in that case.
I have tested this locally by using netfilter's nfqueue and
re-injecting packets into the local stack after maliciously
modifying the INIT chunk (removing RANDOM; HMAC-ALGO param)
and the SCTP packet containing the COOKIE_ECHO (injecting
AUTH chunk before COOKIE_ECHO). Fixed with this patch applied.
commit a3c3cac5d31879cd9ae2de7874dc6544ca704aec upstream.
The lockless RPC_IS_QUEUED() test in __rpc_execute means that we need to
be careful about ordering the calls to rpc_test_and_set_running(task) and
rpc_clear_queued(task). If we get the order wrong, then we may end up
testing the RPC_TASK_RUNNING flag after __rpc_execute() has looped
and changed the state of the rpc_task.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Weng Meiling <wengmeiling.weng@huawei.com>
commit 506026c3ec270e18402f0c9d33fee37482c23861 upstream.
rpc_make_runnable is not generally called with the queue lock held, unless
it's waking up a task that has been sitting on a waitqueue. This is safe
when the task has not entered the FSM yet, but the comments don't really
spell this out.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 73d9f7eef3d98c3920e144797cc1894c6b005a1e upstream.
For nofail == false request, if __map_request failed, the caller does
cleanup work, like releasing the relative pages. It doesn't make any sense
to retry this request.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
[bwh: Backported to 3.2: adjust indentation]
Cc: Rui Xiang <rui.xiang@huawei.com>
commit 06ea0bfe6e6043cb56a78935a19f6f8ebc636226 upstream.
When a send failure occurs due to the socket being out of buffer space,
we call xs_nospace() in order to have the RPC task wait until the
socket has drained enough to make it worth while trying again.
The current patch fixes a race in which the socket is drained before
we get round to setting up the machinery in xs_nospace(), and which
is reported to cause hangs.
Link: http://lkml.kernel.org/r/20140210170315.33dfc621@notabene.brown
Fixes: a9a6b52ee1ba (SUNRPC: Don't start the retransmission timer...)
Reported-by: Neil Brown <neilb@suse.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
[ use zero netdev_feature mask to avoid backport of
netif_skb_dev_features function ]
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
[ no skb_gso_seglen helper in 3.4, leave tbf alone ]
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
[ Upstream commit ffd5939381c609056b33b7585fb05a77b4c695f3 ]
SCTP's sctp_connectx() abi breaks for 64bit kernels compiled with 32bit
emulation (e.g. ia32 emulation or x86_x32). Due to internal usage of
'struct sctp_getaddrs_old' which includes a struct sockaddr pointer,
sizeof(param) check will always fail in kernel as the structure in
64bit kernel space is 4bytes larger than for user binaries compiled
in 32bit mode. Thus, applications making use of sctp_connectx() won't
be able to run under such circumstances.
Introduce a compat interface in the kernel to deal with such
situations by using a 'struct compat_sctp_getaddrs_old' structure
where user data is copied into it, and then sucessively transformed
into a 'struct sctp_getaddrs_old' structure with the help of
compat_ptr(). That fixes sctp_connectx() abi without any changes
needed in user space, and lets the SCTP test suite pass when compiled
in 32bit and run on 64bit kernels.
Fixes: f9c67811ebc0 ("sctp: Fix regression introduced by new sctp_connectx api")
