Export the symbols to fix the below errors when built as modules:
ERROR: "tso_build_data" [drivers/net/ethernet/marvell/mvneta.ko] undefined!
ERROR: "tso_build_hdr" [drivers/net/ethernet/marvell/mvneta.ko] undefined!
ERROR: "tso_start" [drivers/net/ethernet/marvell/mvneta.ko] undefined!
ERROR: "tso_count_descs" [drivers/net/ethernet/marvell/mvneta.ko] undefined!
ERROR: "tso_build_data" [drivers/net/ethernet/marvell/mv643xx_eth.ko] undefined!
ERROR: "tso_build_hdr" [drivers/net/ethernet/marvell/mv643xx_eth.ko] undefined!
ERROR: "tso_start" [drivers/net/ethernet/marvell/mv643xx_eth.ko] undefined!
ERROR: "tso_count_descs" [drivers/net/ethernet/marvell/mv643xx_eth.ko] undefined!
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
This patch adds new ethtool cmd, ETHTOOL_GTUNABLE & ETHTOOL_STUNABLE for getting
tunable values from driver.
Add get_tunable and set_tunable to ethtool_ops. Driver implements these
functions for getting/setting tunable value.
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
We usually allocate special values of u32 fields starting from the top
down, so also change the value to 0xffffffff. As these operations
haven't been included in a stable release yet, it's not too late to
change.
This ethtool patch primarily copies the ioctl command data structures
from/to the User space and invokes the driver hook.
Signed-off-by: Venkat Duvvuru <VenkatKumar.Duvvuru@Emulex.com>
Although the implementation probably needs a lot of work, this initial API
allows to implement software TSO in mvneta and mv643xx_eth drivers in a not
so intrusive way.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
commit 4fabb59449aa44a585b3603ffdadd4c5f4d0c033 upstream.
Fixes: 3e0249f9c05c ("RDS/IB: add refcount tracking to struct rds_ib_device")
There lacks a dropping on rds_ib_device.refcount in case rds_ib_alloc_fmr
failed(mr pool running out). this lead to the refcount overflow.
A complain in line 117(see following) is seen. From vmcore:
s_ib_rdma_mr_pool_depleted is 2147485544 and rds_ibdev->refcount is -2147475448.
That is the evidence the mr pool is used up. so rds_ib_alloc_fmr is very likely
to return ERR_PTR(-EAGAIN).
115 void rds_ib_dev_put(struct rds_ib_device *rds_ibdev)
116 {
117 BUG_ON(atomic_read(&rds_ibdev->refcount) <= 0);
118 if (atomic_dec_and_test(&rds_ibdev->refcount))
119 queue_work(rds_wq, &rds_ibdev->free_work);
120 }
fix is to drop refcount when rds_ib_alloc_fmr failed.
Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com>
Reviewed-by: Haggai Eran <haggaie@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 4479004e6409087d1b4986881dc98c6c15dffb28 upstream.
If we don't do this, and we then fail to recreate the debugfs
directory during a mode change, then we will fail later trying
to add stations to this now bogus directory:
BUG: unable to handle kernel NULL pointer dereference at 0000006c
IP: [<c0a92202>] mutex_lock+0x12/0x30
Call Trace:
[<c0678ab4>] start_creating+0x44/0xc0
[<c0679203>] debugfs_create_dir+0x13/0xf0
[<f8a938ae>] ieee80211_sta_debugfs_add+0x6e/0x490 [mac80211]
Signed-off-by: Tom Hughes <tom@compton.nu>
commit a84b69cb6e0a41e86bc593904faa6def3b957343 upstream.
If we'd already sent a request and decide to abort it, we *must*
issue TFLUSH properly and not just blindly reuse the tag, or
we'll get seriously screwed when response eventually arrives
and we confuse it for response to later request that had reused
the same tag.
commit 88de6af24f2b48b06c514d3c3d0a8f22fafe30bd upstream.
req->rq_private_buf isn't initialised when xprt_setup_backchannel calls
xprt_free_allocation.
Fixes: fb7a0b9addbdb ("nfs41: New backchannel helper routines")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit ab499db80fcf07c18e4053f91a619500f663e90e upstream.
There was a possible race between
ieee80211_reconfig() and
ieee80211_delayed_tailroom_dec(). This could
result in inability to transmit data if driver
crashed during roaming or rekeying and subsequent
skbs with insufficient tailroom appeared.
This race was probably never seen in the wild
because a device driver would have to crash AND
recover within 0.5s which is very unlikely.
I was able to prove this race exists after
changing the delay to 10s locally and crashing
ath10k via debugfs immediately after GTK
rekeying. In case of ath10k the counter went below
0. This was harmless but other drivers which
actually require tailroom (e.g. for WEP ICV or
MMIC) could end up with the counter at 0 instead
of >0 and introduce insufficient skb tailroom
failures because mac80211 would not resize skbs
appropriately anymore.
Fixes: 8d1f7ecd2af5 ("mac80211: defer tailroom counter manipulation when roaming")
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
commit 82cd003a77173c91b9acad8033fb7931dac8d751 upstream.
struct crush_bucket_tree::num_nodes is u8, so ceph_decode_8_safe()
should be used. -Wconversion catches this, but I guess it went
unnoticed in all the noise it spews. The actual problem (at least for
common crushmaps) isn't the u32 -> u8 truncation though - it's the
advancement by 4 bytes instead of 1 in the crushmap buffer.
Fixes: http://tracker.ceph.com/issues/2759
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Josh Durgin <jdurgin@redhat.com>
[ Upstream commit 29c4afc4e98f4dc0ea9df22c631841f9c220b944 ]
There is NULL pointer dereference possible during statistics update if the route
used for OOTB responce is removed at unfortunate time. If the route exists when
we receive OOTB packet and we finally jump into sctp_packet_transmit() to send
ABORT, but in the meantime route is removed under our feet, we take "no_route"
path and try to update stats with IP_INC_STATS(sock_net(asoc->base.sk), ...).
But sctp_ootb_pkt_new() used to prepare responce packet doesn't call
sctp_transport_set_owner() and therefore there is no asoc associated with this
packet. Probably temporary asoc just for OOTB responces is overkill, so just
introduce a check like in all other places in sctp_packet_transmit(), where
"asoc" is dereferenced.
To reproduce this, one needs to
0. ensure that sctp module is loaded (otherwise ABORT is not generated)
1. remove default route on the machine
2. while true; do
ip route del [interface-specific route]
ip route add [interface-specific route]
done
3. send enough OOTB packets (i.e. HB REQs) from another host to trigger ABORT
responce
On x86_64 the crash looks like this:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa05ec9ac>] sctp_packet_transmit+0x63c/0x730 [sctp]
PGD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: ...
CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 4.0.5-1-ARCH #1
Hardware name: ...
task: ffffffff818124c0 ti: ffffffff81800000 task.ti: ffffffff81800000
RIP: 0010:[<ffffffffa05ec9ac>] [<ffffffffa05ec9ac>] sctp_packet_transmit+0x63c/0x730 [sctp]
RSP: 0018:ffff880127c037b8 EFLAGS: 00010296
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000015ff66b480
RDX: 00000015ff66b400 RSI: ffff880127c17200 RDI: ffff880123403700
RBP: ffff880127c03888 R08: 0000000000017200 R09: ffffffff814625af
R10: ffffea00047e4680 R11: 00000000ffffff80 R12: ffff8800b0d38a28
R13: ffff8800b0d38a28 R14: ffff8800b3e88000 R15: ffffffffa05f24e0
FS: 0000000000000000(0000) GS:ffff880127c00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 00000000c855b000 CR4: 00000000000007f0
Stack:
ffff880127c03910 ffff8800b0d38a28 ffffffff8189d240 ffff88011f91b400
ffff880127c03828 ffffffffa05c94c5 0000000000000000 ffff8800baa1c520
0000000000000000 0000000000000001 0000000000000000 0000000000000000
Call Trace:
<IRQ>
[<ffffffffa05c94c5>] ? sctp_sf_tabort_8_4_8.isra.20+0x85/0x140 [sctp]
[<ffffffffa05d6b42>] ? sctp_transport_put+0x52/0x80 [sctp]
[<ffffffffa05d0bfc>] sctp_do_sm+0xb8c/0x19a0 [sctp]
[<ffffffff810b0e00>] ? trigger_load_balance+0x90/0x210
[<ffffffff810e0329>] ? update_process_times+0x59/0x60
[<ffffffff812c7a40>] ? timerqueue_add+0x60/0xb0
[<ffffffff810e0549>] ? enqueue_hrtimer+0x29/0xa0
[<ffffffff8101f599>] ? read_tsc+0x9/0x10
[<ffffffff8116d4b5>] ? put_page+0x55/0x60
[<ffffffff810ee1ad>] ? clockevents_program_event+0x6d/0x100
[<ffffffff81462b68>] ? skb_free_head+0x58/0x80
[<ffffffffa029a10b>] ? chksum_update+0x1b/0x27 [crc32c_generic]
[<ffffffff81283f3e>] ? crypto_shash_update+0xce/0xf0
[<ffffffffa05d3993>] sctp_endpoint_bh_rcv+0x113/0x280 [sctp]
[<ffffffffa05dd4e6>] sctp_inq_push+0x46/0x60 [sctp]
[<ffffffffa05ed7a0>] sctp_rcv+0x880/0x910 [sctp]
[<ffffffffa05ecb50>] ? sctp_packet_transmit_chunk+0xb0/0xb0 [sctp]
[<ffffffffa05ecb70>] ? sctp_csum_update+0x20/0x20 [sctp]
[<ffffffff814b05a5>] ? ip_route_input_noref+0x235/0xd30
[<ffffffff81051d6b>] ? ack_ioapic_level+0x7b/0x150
[<ffffffff814b27be>] ip_local_deliver_finish+0xae/0x210
[<ffffffff814b2e15>] ip_local_deliver+0x35/0x90
[<ffffffff814b2a15>] ip_rcv_finish+0xf5/0x370
[<ffffffff814b3128>] ip_rcv+0x2b8/0x3a0
[<ffffffff81474193>] __netif_receive_skb_core+0x763/0xa50
[<ffffffff81476c28>] __netif_receive_skb+0x18/0x60
[<ffffffff81476cb0>] netif_receive_skb_internal+0x40/0xd0
[<ffffffff814776c8>] napi_gro_receive+0xe8/0x120
[<ffffffffa03946aa>] rtl8169_poll+0x2da/0x660 [r8169]
[<ffffffff8147896a>] net_rx_action+0x21a/0x360
[<ffffffff81078dc1>] __do_softirq+0xe1/0x2d0
[<ffffffff8107912d>] irq_exit+0xad/0xb0
[<ffffffff8157d158>] do_IRQ+0x58/0xf0
[<ffffffff8157b06d>] common_interrupt+0x6d/0x6d
<EOI>
[<ffffffff810e1218>] ? hrtimer_start+0x18/0x20
[<ffffffffa05d65f9>] ? sctp_transport_destroy_rcu+0x29/0x30 [sctp]
[<ffffffff81020c50>] ? mwait_idle+0x60/0xa0
[<ffffffff810216ef>] arch_cpu_idle+0xf/0x20
[<ffffffff810b731c>] cpu_startup_entry+0x3ec/0x480
[<ffffffff8156b365>] rest_init+0x85/0x90
[<ffffffff818eb035>] start_kernel+0x48b/0x4ac
[<ffffffff818ea120>] ? early_idt_handlers+0x120/0x120
[<ffffffff818ea339>] x86_64_start_reservations+0x2a/0x2c
[<ffffffff818ea49c>] x86_64_start_kernel+0x161/0x184
Code: 90 48 8b 80 b8 00 00 00 48 89 85 70 ff ff ff 48 83 bd 70 ff ff ff 00 0f 85 cd fa ff ff 48 89 df 31 db e8 18 63 e7 e0 48 8b 45 80 <48> 8b 40 20 48 8b 40 30 48 8b 80 68 01 00 00 65 48 ff 40 78 e9
RIP [<ffffffffa05ec9ac>] sctp_packet_transmit+0x63c/0x730 [sctp]
RSP <ffff880127c037b8>
---[ end trace 5aec7fd2dc983574 ]---
Kernel panic - not syncing: Fatal exception in interrupt
Kernel Offset: 0x0 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffff9fffffff)
drm_kms_helper: panic occurred, switching back to text console
---[ end Kernel panic - not syncing: Fatal exception in interrupt
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit dfea2aa654243f70dc53b8648d0bbdeec55a7df1 ]
tcp_fastopen_reset_cipher really cannot be called from interrupt
context. It allocates the tcp_fastopen_context with GFP_KERNEL and
calls crypto_alloc_cipher, which allocates all kind of stuff with
GFP_KERNEL.
Thus, we might sleep when the key-generation is triggered by an
incoming TFO cookie-request which would then happen in interrupt-
context, as shown by enabling CONFIG_DEBUG_ATOMIC_SLEEP:
[ 36.001813] BUG: sleeping function called from invalid context at mm/slub.c:1266
[ 36.003624] in_atomic(): 1, irqs_disabled(): 0, pid: 1016, name: packetdrill
[ 36.004859] CPU: 1 PID: 1016 Comm: packetdrill Not tainted 4.1.0-rc7 #14
[ 36.006085] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org 04/01/2014
[ 36.008250] 00000000000004f2 ffff88007f8838a8 ffffffff8171d53a ffff880075a084a8
[ 36.009630] ffff880075a08000 ffff88007f8838c8 ffffffff810967d3 ffff88007f883928
[ 36.011076] 0000000000000000 ffff88007f8838f8 ffffffff81096892 ffff88007f89be00
[ 36.012494] Call Trace:
[ 36.012953] <IRQ> [<ffffffff8171d53a>] dump_stack+0x4f/0x6d
[ 36.014085] [<ffffffff810967d3>] ___might_sleep+0x103/0x170
[ 36.015117] [<ffffffff81096892>] __might_sleep+0x52/0x90
[ 36.016117] [<ffffffff8118e887>] kmem_cache_alloc_trace+0x47/0x190
[ 36.017266] [<ffffffff81680d82>] ? tcp_fastopen_reset_cipher+0x42/0x130
[ 36.018485] [<ffffffff81680d82>] tcp_fastopen_reset_cipher+0x42/0x130
[ 36.019679] [<ffffffff81680f01>] tcp_fastopen_init_key_once+0x61/0x70
[ 36.020884] [<ffffffff81680f2c>] __tcp_fastopen_cookie_gen+0x1c/0x60
[ 36.022058] [<ffffffff816814ff>] tcp_try_fastopen+0x58f/0x730
[ 36.023118] [<ffffffff81671788>] tcp_conn_request+0x3e8/0x7b0
[ 36.024185] [<ffffffff810e3872>] ? __module_text_address+0x12/0x60
[ 36.025327] [<ffffffff8167b2e1>] tcp_v4_conn_request+0x51/0x60
[ 36.026410] [<ffffffff816727e0>] tcp_rcv_state_process+0x190/0xda0
[ 36.027556] [<ffffffff81661f97>] ? __inet_lookup_established+0x47/0x170
[ 36.028784] [<ffffffff8167c2ad>] tcp_v4_do_rcv+0x16d/0x3d0
[ 36.029832] [<ffffffff812e6806>] ? security_sock_rcv_skb+0x16/0x20
[ 36.030936] [<ffffffff8167cc8a>] tcp_v4_rcv+0x77a/0x7b0
[ 36.031875] [<ffffffff816af8c3>] ? iptable_filter_hook+0x33/0x70
[ 36.032953] [<ffffffff81657d22>] ip_local_deliver_finish+0x92/0x1f0
[ 36.034065] [<ffffffff81657f1a>] ip_local_deliver+0x9a/0xb0
[ 36.035069] [<ffffffff81657c90>] ? ip_rcv+0x3d0/0x3d0
[ 36.035963] [<ffffffff81657569>] ip_rcv_finish+0x119/0x330
[ 36.036950] [<ffffffff81657ba7>] ip_rcv+0x2e7/0x3d0
[ 36.037847] [<ffffffff81610652>] __netif_receive_skb_core+0x552/0x930
[ 36.038994] [<ffffffff81610a57>] __netif_receive_skb+0x27/0x70
[ 36.040033] [<ffffffff81610b72>] process_backlog+0xd2/0x1f0
[ 36.041025] [<ffffffff81611482>] net_rx_action+0x122/0x310
[ 36.042007] [<ffffffff81076743>] __do_softirq+0x103/0x2f0
[ 36.042978] [<ffffffff81723e3c>] do_softirq_own_stack+0x1c/0x30
This patch moves the call to tcp_fastopen_init_key_once to the places
where a listener socket creates its TFO-state, which always happens in
user-context (either from the setsockopt, or implicitly during the
listen()-call)
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Fixes: 222e83d2e0ae ("tcp: switch tcp_fastopen key generation to net_get_random_once")
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
[ Upstream commit 2c51a97f76d20ebf1f50fef908b986cb051fdff9 ]
The lockless lookups can return entry that is unlinked.
Sometimes they get reference before last neigh_cleanup_and_release,
sometimes they do not need reference. Later, any
modification attempts may result in the following problems:
1. entry is not destroyed immediately because neigh_update
can start the timer for dead entry, eg. on change to NUD_REACHABLE
state. As result, entry lives for some time but is invisible
and out of control.
2. __neigh_event_send can run in parallel with neigh_destroy
while refcnt=0 but if timer is started and expired refcnt can
reach 0 for second time leading to second neigh_destroy and
possible crash.
Thanks to Eric Dumazet and Ying Xue for their work and analyze
on the __neigh_event_send change.
Fixes: 767e97e1e0db ("neigh: RCU conversion of struct neighbour")
Fixes: a263b3093641 ("ipv4: Make neigh lookups directly in output packet path.")
Fixes: 6fd6ce2056de ("ipv6: Do not depend on rt->n in ip6_finish_output2().")
Cc: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit 468479e6043c84f5a65299cc07cb08a22a28c2b1 ]
PACKET_FANOUT_LB computes f->rr_cur such that it is modulo
f->num_members. It returns the old value unconditionally, but
f->num_members may have changed since the last store. Ensure
that the return value is always < num.
When modifying the logic, simplify it further by replacing the loop
with an unconditional atomic increment.
Fixes: dc99f600698d ("packet: Add fanout support.")
Suggested-by: Eric Dumazet <edumazet@google.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit f98f4514d07871da7a113dd9e3e330743fd70ae4 ]
We need to tell compiler it must not read f->num_members multiple
times. Otherwise testing if num is not zero is flaky, and we could
attempt an invalid divide by 0 in fanout_demux_cpu()
Note bug was present in packet_rcv_fanout_hash() and
packet_rcv_fanout_lb() but final 3.1 had a simple location
after commit 95ec3eb417115fb ("packet: Add 'cpu' fanout policy.")
Fixes: dc99f600698dc ("packet: Add fanout support.")
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit 2dab80a8b486f02222a69daca6859519e05781d9 ]
After the ->set() spinlocks were removed br_stp_set_bridge_priority
was left running without any protection when used via sysfs. It can
race with port add/del and could result in use-after-free cases and
corrupted lists. Tested by running port add/del in a loop with stp
enabled while setting priority in a loop, crashes are easily
reproducible.
The spinlocks around sysfs ->set() were removed in commit:
14f98f258f19 ("bridge: range check STP parameters")
There's also a race condition in the netlink priority support that is
fixed by this change, but it was introduced recently and the fixes tag
covers it, just in case it's needed the commit is:
af615762e972 ("bridge: add ageing_time, stp_state, priority over netlink")
Signed-off-by: Nikolay Aleksandrov <razor@blackwall.org>
Fixes: 14f98f258f19 ("bridge: range check STP parameters")
[ Upstream commit 2d45a02d0166caf2627fe91897c6ffc3b19514c4 ]
->auto_asconf_splist is per namespace and mangled by functions like
sctp_setsockopt_auto_asconf() which doesn't guarantee any serialization.
Also, the call to inet_sk_copy_descendant() was backuping
->auto_asconf_list through the copy but was not honoring
->do_auto_asconf, which could lead to list corruption if it was
different between both sockets.
This commit thus fixes the list handling by using ->addr_wq_lock
spinlock to protect the list. A special handling is done upon socket
creation and destruction for that. Error handlig on sctp_init_sock()
will never return an error after having initialized asconf, so
sctp_destroy_sock() can be called without addrq_wq_lock. The lock now
will be take on sctp_close_sock(), before locking the socket, so we
don't do it in inverse order compared to sctp_addr_wq_timeout_handler().
Instead of taking the lock on sctp_sock_migrate() for copying and
restoring the list values, it's preferred to avoid rewritting it by
implementing sctp_copy_descendant().
Issue was found with a test application that kept flipping sysctl
default_auto_asconf on and off, but one could trigger it by issuing
simultaneous setsockopt() calls on multiple sockets or by
creating/destroying sockets fast enough. This is only triggerable
locally.
Fixes: 9f7d653b67ae ("sctp: Add Auto-ASCONF support (core).")
Reported-by: Ji Jianwen <jiji@redhat.com>
Suggested-by: Neil Horman <nhorman@tuxdriver.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit fb05e7a89f500cfc06ae277bdc911b281928995d ]
We saw excessive direct memory compaction triggered by skb_page_frag_refill.
This causes performance issues and add latency. Commit 5640f7685831e0
introduces the order-3 allocation. According to the changelog, the order-3
allocation isn't a must-have but to improve performance. But direct memory
compaction has high overhead. The benefit of order-3 allocation can't
compensate the overhead of direct memory compaction.
This patch makes the order-3 page allocation atomic. If there is no memory
pressure and memory isn't fragmented, the alloction will still success, so we
don't sacrifice the order-3 benefit here. If the atomic allocation fails,
direct memory compaction will not be triggered, skb_page_frag_refill will
fallback to order-0 immediately, hence the direct memory compaction overhead is
avoided. In the allocation failure case, kswapd is waken up and doing
compaction, so chances are allocation could success next time.
alloc_skb_with_frags is the same.
The mellanox driver does similar thing, if this is accepted, we must fix
the driver too.
V3: fix the same issue in alloc_skb_with_frags as pointed out by Eric
V2: make the changelog clearer
Cc: Eric Dumazet <edumazet@google.com>
Cc: Chris Mason <clm@fb.com>
Cc: Debabrata Banerjee <dbavatar@gmail.com>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit 1a040eaca1a22f8da8285ceda6b5e4a2cb704867 ]
Since the addition of sysfs multicast router support if one set
multicast_router to "2" more than once, then the port would be added to
the hlist every time and could end up linking to itself and thus causing an
endless loop for rlist walkers.
So to reproduce just do:
echo 2 > multicast_router; echo 2 > multicast_router;
in a bridge port and let some igmp traffic flow, for me it hangs up
in br_multicast_flood().
Fix this by adding a check in br_multicast_add_router() if the port is
already linked.
The reason this didn't happen before the addition of multicast_router
sysfs entries is because there's a !hlist_unhashed check that prevents
it.
Fixes: 0909e11758bd ("bridge: Add multicast_router sysfs entries")
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit d6b6cb1d3e6f78d55c2d4043d77d0d8def3f3b99 upstream.
If there's an existing base chain, we have to allow to change the
default policy without indicating the hook information.
However, if the chain doesn't exists, we have to enforce the presence of
the hook attribute.
commit 749177ccc74f9c6d0f51bd78a15c652a2134aa11 upstream.
ip6tables extensions check for this flag to restrict match/target to a
given protocol. Without this flag set, SYNPROXY6 returns an error.
Acked-by: Patrick McHardy <kaber@trash.net>
commit 78146572b9cd20452da47951812f35b1ad4906be upstream.
nfnl_cthelper_parse_tuple() is called from nfnl_cthelper_new(),
nfnl_cthelper_get() and nfnl_cthelper_del(). In each case they pass
a pointer to an nf_conntrack_tuple data structure local variable:
struct nf_conntrack_tuple tuple;
ret = nfnl_cthelper_parse_tuple(&tuple, tb[NFCTH_TUPLE]);
The problem is that this local variable is not initialized, and
nfnl_cthelper_parse_tuple() only initializes two fields: src.l3num and
dst.protonum. This leaves all other fields with undefined values
based on whatever is on the stack:
tuple->src.l3num = ntohs(nla_get_be16(tb[NFCTH_TUPLE_L3PROTONUM]));
tuple->dst.protonum = nla_get_u8(tb[NFCTH_TUPLE_L4PROTONUM]);
The symptom observed was that when the rpc and tns helpers were added
then traffic to port 1536 was being sent to user-space.
Signed-off-by: Ian Wilson <iwilson@brocade.com>
commit b18c5d15e8714336365d9d51782d5b53afa0443c upstream.
The related code can be simplified, and also can avoid related warnings
(with allmodconfig under parisc):
CC [M] net/netfilter/nfnetlink_cthelper.o
net/netfilter/nfnetlink_cthelper.c: In function ‘nfnl_cthelper_from_nlattr’:
net/netfilter/nfnetlink_cthelper.c:97:9: warning: passing argument 1 o ‘memcpy’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-array-qualifiers]
memcpy(&help->data, nla_data(attr), help->helper->data_len);
In file included from include/linux/string.h:17:0,
from include/uapi/linux/uuid.h:25,
from include/linux/uuid.h:23,
from include/linux/mod_devicetable.h:12,
from ./arch/parisc/include/asm/hardware.h:4,
from ./arch/parisc/include/asm/processor.h:15,
from ./arch/parisc/include/asm/spinlock.h:6,
from ./arch/parisc/include/asm/atomic.h:21,
from include/linux/atomic.h:4,
from ./arch/parisc/include/asm/bitops.h:12,
from include/linux/bitops.h:36,
from include/linux/kernel.h:10,
from include/linux/list.h:8,
from include/linux/module.h:9,
from net/netfilter/nfnetlink_cthelper.c:11:
./arch/parisc/include/asm/string.h:8:8: note: expected ‘void *’ but argument is of type ‘const char (*)[]’
void * memcpy(void * dest,const void *src,size_t count);
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Signed-off-by: Pablo Neira Ayuso <pablo@soleta.eu>
commit 9c5a18a31b321f120efda412281bb9f610f84aa0 upstream.
Until recently, mac80211 overwrote all the statistics it could
provide when getting called, but it now relies on the struct
having been zeroed by the caller. This was always the case in
nl80211, but wext used a static struct which could even cause
values from one device leak to another.
Using a static struct is OK (as even documented in a comment)
since the whole usage of this function and its return value is
always locked under RTNL. Not clearing the struct for calling
the driver has always been wrong though, since drivers were
free to only fill values they could report, so calling this
for one device and then for another would always have leaked
values from one to the other.
Fix this by initializing the structure in question before the
driver method call.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=99691
Reported-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Reported-by: Alexander Kaltsas <alexkaltsas@gmail.com>
[ Upstream commit c4c832f89dc468cf11dc0dd17206bace44526651 ]
br_fdb_update() can be called in process context in the following way:
br_fdb_add() -> __br_fdb_add() -> br_fdb_update() (if NTF_USE flag is set)
so we need to disable softirqs because there are softirq users of the
hash_lock. One easy way to reproduce this is to modify the bridge utility
to set NTF_USE, enable stp and then set maxageing to a low value so
br_fdb_cleanup() is called frequently and then just add new entries in
a loop. This happens because br_fdb_cleanup() is called from timer/softirq
context. The spin locks in br_fdb_update were _bh before commit f8ae737deea1
("[BRIDGE]: forwarding remove unneeded preempt and bh diasables")
and at the time that commit was correct because br_fdb_update() couldn't be
called from process context, but that changed after commit:
292d1398983f ("bridge: add NTF_USE support")
Using local_bh_disable/enable around br_fdb_update() allows us to keep
using the spin_lock/unlock in br_fdb_update for the fast-path.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Fixes: 292d1398983f ("bridge: add NTF_USE support")
[ Upstream commit 6e540309326188f769e03bb4c6dd8ff6752930c2 ]
421b3885bf6d56391297844f43fb7154a6396e12 "udp: ipv4: Add udp early
demux" introduced a regression that allowed sockets bound to INADDR_ANY
to receive packets from multicast groups that the socket had not joined.
For example a socket that had joined 224.168.2.9 could also receive
packets from 225.168.2.9 despite not having joined that group if
ip_early_demux is enabled.
Fix this by calling ip_check_mc_rcu() in udp_v4_early_demux() to verify
that the multicast packet is indeed ours.
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru>
[ Upstream commit beb39db59d14990e401e235faf66a6b9b31240b0 ]
We have two problems in UDP stack related to bogus checksums :
1) We return -EAGAIN to application even if receive queue is not empty.
This breaks applications using edge trigger epoll()
2) Under UDP flood, we can loop forever without yielding to other
processes, potentially hanging the host, especially on non SMP.
This patch is an attempt to make things better.
We might in the future add extra support for rt applications
wanting to better control time spent doing a recv() in a hostile
environment. For example we could validate checksums before queuing
packets in socket receive queue.
[ Upstream commit 86e363dc3b50bfd50a1f315934583fbda673ab8d ]
For mq qdisc, we add per tx queue qdisc to root qdisc
for display purpose, however, that happens too early,
before the new dev->qdisc is finally set, this causes
q->list points to an old root qdisc which is going to be
freed right before assigning with a new one.
Fix this by moving ->attach() after setting dev->qdisc.
For the record, this fixes the following crash:
WARNING: CPU: 1 PID: 975 at lib/list_debug.c:59 __list_del_entry+0x5a/0x98()
list_del corruption. prev->next should be ffff8800d1998ae8, but was 6b6b6b6b6b6b6b6b
CPU: 1 PID: 975 Comm: tc Not tainted 4.1.0-rc4+ #1019
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
0000000000000009 ffff8800d73fb928 ffffffff81a44e7f 0000000047574756
ffff8800d73fb978 ffff8800d73fb968 ffffffff810790da ffff8800cfc4cd20
ffffffff814e725b ffff8800d1998ae8 ffffffff82381250 0000000000000000
Call Trace:
[<ffffffff81a44e7f>] dump_stack+0x4c/0x65
[<ffffffff810790da>] warn_slowpath_common+0x9c/0xb6
[<ffffffff814e725b>] ? __list_del_entry+0x5a/0x98
[<ffffffff81079162>] warn_slowpath_fmt+0x46/0x48
[<ffffffff81820eb0>] ? dev_graft_qdisc+0x5e/0x6a
[<ffffffff814e725b>] __list_del_entry+0x5a/0x98
[<ffffffff814e72a7>] list_del+0xe/0x2d
[<ffffffff81822f05>] qdisc_list_del+0x1e/0x20
[<ffffffff81820cd1>] qdisc_destroy+0x30/0xd6
[<ffffffff81822676>] qdisc_graft+0x11d/0x243
[<ffffffff818233c1>] tc_get_qdisc+0x1a6/0x1d4
[<ffffffff810b5eaf>] ? mark_lock+0x2e/0x226
[<ffffffff817ff8f5>] rtnetlink_rcv_msg+0x181/0x194
[<ffffffff817ff72e>] ? rtnl_lock+0x17/0x19
[<ffffffff817ff774>] ? __rtnl_unlock+0x17/0x17
[<ffffffff81855dc6>] netlink_rcv_skb+0x4d/0x93
[<ffffffff817ff756>] rtnetlink_rcv+0x26/0x2d
[<ffffffff818544b2>] netlink_unicast+0xcb/0x150
[<ffffffff81161db9>] ? might_fault+0x59/0xa9
[<ffffffff81854f78>] netlink_sendmsg+0x4fa/0x51c
[<ffffffff817d6e09>] sock_sendmsg_nosec+0x12/0x1d
[<ffffffff817d8967>] sock_sendmsg+0x29/0x2e
[<ffffffff817d8cf3>] ___sys_sendmsg+0x1b4/0x23a
[<ffffffff8100a1b8>] ? native_sched_clock+0x35/0x37
[<ffffffff810a1d83>] ? sched_clock_local+0x12/0x72
[<ffffffff810a1fd4>] ? sched_clock_cpu+0x9e/0xb7
[<ffffffff810def2a>] ? current_kernel_time+0xe/0x32
[<ffffffff810b4bc5>] ? lock_release_holdtime.part.29+0x71/0x7f
[<ffffffff810ddebf>] ? read_seqcount_begin.constprop.27+0x5f/0x76
[<ffffffff810b6292>] ? trace_hardirqs_on_caller+0x17d/0x199
[<ffffffff811b14d5>] ? __fget_light+0x50/0x78
[<ffffffff817d9808>] __sys_sendmsg+0x42/0x60
[<ffffffff817d9838>] SyS_sendmsg+0x12/0x1c
[<ffffffff81a50e97>] system_call_fastpath+0x12/0x6f
---[ end trace ef29d3fb28e97ae7 ]---
For long term, we probably need to clean up the qdisc_graft() code
in case it hides other bugs like this.
Fixes: 95dc19299f74 ("pkt_sched: give visibility to mq slave qdiscs")
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit b48732e4a48d80ed4a14812f0bab09560846514e ]
got a rare NULL pointer dereference in clear_bit
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
v2: switch to sock_flag(sk, SOCK_DEAD) and added net/caif/caif_socket.c
v3: return -ECONNRESET in upstream caller of wait function for SOCK_DEAD
[ Upstream commit 47cc84ce0c2fe75c99ea5963c4b5704dd78ead54 ]
When more than a multicast address is present in a MLDv2 report, all but
the first address is ignored, because the code breaks out of the loop if
there has not been an error adding that address.
This has caused failures when two guests connected through the bridge
tried to communicate using IPv6. Neighbor discoveries would not be
transmitted to the other guest when both used a link-local address and a
static address.
This only happens when there is a MLDv2 querier in the network.
The fix will only break out of the loop when there is a failure adding a
multicast address.
The mdb before the patch:
dev ovirtmgmt port vnet0 grp ff02::1:ff7d:6603 temp
dev ovirtmgmt port vnet1 grp ff02::1:ff7d:6604 temp
dev ovirtmgmt port bond0.86 grp ff02::2 temp
After the patch:
dev ovirtmgmt port bond0.86 grp ff02::fb temp
dev ovirtmgmt port bond0.86 grp ff02::d temp
dev ovirtmgmt port vnet0 grp ff02::1:ff00:76 temp
dev ovirtmgmt port bond0.86 grp ff02::16 temp
dev ovirtmgmt port vnet1 grp ff02::1:ff00:77 temp
dev ovirtmgmt port bond0.86 grp ff02::1:ff00:def temp
dev ovirtmgmt port bond0.86 grp ff02::1:ffa1:40bf temp
Fixes: 08b202b67264 ("bridge br_multicast: IPv6 MLD support.")
Reported-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@redhat.com>
Tested-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
[ Upstream commit 381c759d9916c42959515ad34a6d467e24a88e93 ]
ip_error does not check if in_dev is NULL before dereferencing it.
IThe following sequence of calls is possible:
CPU A CPU B
ip_rcv_finish
ip_route_input_noref()
ip_route_input_slow()
inetdev_destroy()
dst_input()
With the result that a network device can be destroyed while processing
an input packet.
A crash was triggered with only unicast packets in flight, and
forwarding enabled on the only network device. The error condition
was created by the removal of the network device.
As such it is likely the that error code was -EHOSTUNREACH, and the
action taken by ip_error (if in_dev had been accessible) would have
been to not increment any counters and to have tried and likely failed
to send an icmp error as the network device is going away.
Therefore handle this weird case by just dropping the packet if
!in_dev. It will result in dropping the packet sooner, and will not
result in an actual change of behavior.
Fixes: 251da4130115b ("ipv4: Cache ip_error() routes even when not forwarding.")
Reported-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Tested-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
[ Upstream commit 21858cd02dabcf290564cbf4769b101eba54d7bb ]
commit 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages
send from TIME_WAIT") added the flow label in the last TCP packets.
Unfortunately, it was not casted properly.
This patch replace the buggy shift with be32_to_cpu/cpu_to_be32.
Fixes: 1d13a96c74fc ("ipv6: tcp: fix flowlabel value in ACK messages")
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
[ Upstream commit d66bf7dd27573ee5ea90484899ee952c19ccb194 ]
The code in __netdev_upper_dev_link() has an over-stringent
loop detection logic that actually prevents valid configurations
from working correctly.
In particular, the logic returns an error if an upper device
is already in the list of all upper devices for a given dev.
This particular check seems to be a overzealous as it disallows
perfectly valid configurations. For example:
# ip l a link eth0 name eth0.10 type vlan id 10
# ip l a dev br0 typ bridge
# ip l s eth0.10 master br0
# ip l s eth0 master br0 <--- Will fail
If you switch the last two commands (add eth0 first), then both
will succeed. If after that, you remove eth0 and try to re-add
it, it will fail!
It appears to be enough to simply check adj_list to keeps things
safe.
I've tried stacking multiple devices multiple times in all different
combinations, and either rx_handler registration prevented the stacking
of the device linking cought the error.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Veaceslav Falico <vfalico@gmail.com>
commit 45002267e8d2699bf9b022315bee3dd13b044843 upstream.
Crush temporary buffers are allocated as per replica size configured
by the user. When there are more final osds (to be selected as per
rule) than the replicas, buffer overlaps and it causes crash. Now, it
ensures that at most num-rep osds are selected even if more number of
osds are allowed by the rule.
Reflects ceph.git commits 6b4d1aa99718e3b367496326c1e64551330fabc0,
234b066ba04976783d15ff2abc3e81b6cc06fb10.
commit 9507271d960a1911a51683888837d75c171cd91f upstream.
In an environment where the KDC is running Active Directory, the
exported composite name field returned in the context could be large
enough to span a page boundary. Attaching a scratch buffer to the
decoding xdr_stream helps deal with those cases.
The case where we saw this was actually due to behavior that's been
fixed in newer gss-proxy versions, but we're fixing it here too.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
Reviewed-by: Simo Sorce <simo@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 47b4e1fc4972cc43a19121bc2608a60aef3bf216 upstream.
Remove checking tailroom when adding IV as it uses only
headroom, and move the check to the ICV generation that
actually needs the tailroom.
In other case I hit such warning and datapath don't work,
when testing:
- IBSS + WEP
- ath9k with hw crypt enabled
- IPv6 data (ping6)
WARNING: CPU: 3 PID: 13301 at net/mac80211/wep.c:102 ieee80211_wep_add_iv+0x129/0x190 [mac80211]()
Call Trace:
[<ffffffff817bf491>] dump_stack+0x45/0x57
[<ffffffff8107746a>] warn_slowpath_common+0x8a/0xc0
[<ffffffff8107755a>] warn_slowpath_null+0x1a/0x20
[<ffffffffc09ae109>] ieee80211_wep_add_iv+0x129/0x190 [mac80211]
[<ffffffffc09ae7ab>] ieee80211_crypto_wep_encrypt+0x6b/0xd0 [mac80211]
[<ffffffffc09d3fb1>] invoke_tx_handlers+0xc51/0xf30 [mac80211]
Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com>
commit b0494532214bdfbf241e94fabab5dd46f7b82631 upstream.
This commit does two things. First, if there are any homeless
lingering requests, we now request a new osdmap even if the osdmap that
is being processed brought no changes, i.e. if a given lingering
request turned homeless in one of the previous epochs and remained
homeless in the current epoch. Not doing so leaves us with a stale
osdmap and as a result we may miss our window for reestablishing the
watch and lose notifies.
MON=1 OSD=1:
# cat linger-needmap.sh
#!/bin/bash
rbd create --size 1 test
DEV=$(rbd map test)
ceph osd out 0
rbd map dne/dne # obtain a new osdmap as a side effect (!)
sleep 1
ceph osd in 0
rbd resize --size 2 test
# rbd info test | grep size -> 2M
# blockdev --getsize $DEV -> 1M
N.B.: Not obtaining a new osdmap in between "osd out" and "osd in"
above is enough to make it miss that resize notify, but that is a
bug^Wlimitation of ceph watch/notify v1.
Second, homeless lingering requests are now kicked just like those
lingering requests whose mapping has changed. This is mainly to
recognize that a homeless lingering request makes no sense and to
preserve the invariant that a registered lingering request is not
sitting on any of r_req_lru_item lists. This spares us a WARN_ON,
which commit ba9d114ec557 ("libceph: clear r_req_lru_item in
__unregister_linger_request()") tried to fix the _wrong_ way.
Reviewed-by: Sage Weil <sage@redhat.com>
Based on 08adb7dabd4874cc5666b4490653b26534702ce0 upstream.
We found that after v3.10.73, recvmsg might return -EFAULT while -EINVAL
was expected.
We tested it through the recvmsg01 testcase come from LTP testsuit. It set
msg->msg_namelen to -1 and the recvmsg syscall returned errno 14, which is
unexpected (errno 22 is expected):
recvmsg01 4 TFAIL : invalid socket length ; returned -1 (expected -1),
errno 14 (expected 22)
Linux mainline has no this bug for commit 08adb7dab fixes it accidentally.
However, it is too large and complex to be backported to LTS 3.10.
Commit 281c9c36 (net: compat: Update get_compat_msghdr() to match
copy_msghdr_from_user() behaviour) made get_compat_msghdr() return
error if msg_sys->msg_namelen was negative, which changed the behaviors
of recvmsg and sendmsg syscall in a lib32 system:
Before commit 281c9c36, get_compat_msghdr() wouldn't fail and it would
return -EINVAL in move_addr_to_user() or somewhere if msg_sys->msg_namelen
was invalid and then syscall returned -EINVAL, which is correct.
And now, when msg_sys->msg_namelen is negative, get_compat_msghdr() will
fail and wants to return -EINVAL, however, the outer syscall will return
-EFAULT directly, which is unexpected.
This patch gets the return value of get_compat_msghdr() as well as
copy_msghdr_from_user(), then returns this expected value if
get_compat_msghdr() fails.
Fixes: 281c9c36 (net: compat: Update get_compat_msghdr() to match copy_msghdr_from_user() behaviour)
Signed-off-by: Junling Zheng <zhengjunling@huawei.com>
Signed-off-by: Hanbing Xu <xuhanbing@huawei.com>
Cc: Li Zefan <lizefan@huawei.com>
[ Upstream commit a134f083e79fb4c3d0a925691e732c56911b4326 ]
If we don't do that, then the poison value is left in the ->pprev
backlink.
This can cause crashes if we do a disconnect, followed by a connect().
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Wen Xu <hotdog3645@gmail.com>
[ Upstream commit 2ea2f62c8bda242433809c7f4e9eae1c52c40bbe ]
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
[ Upstream commit 79930f5892e134c6da1254389577fffb8bd72c66 ]
build_skb() should look at the page pfmemalloc status.
If set, this means page allocator allocated this page in the
expectation it would help to free other pages. Networking
stack can do that only if skb->pfmemalloc is also set.
Also, we must refrain using high order pages from the pfmemalloc
reserve, so __page_frag_refill() must also use __GFP_NOMEMALLOC for
them. Under memory pressure, using order-0 pages is probably the best
strategy.
[ Upstream commit 845704a535e9b3c76448f52af1b70e4422ea03fd ]
Presence of an unbound loop in tcp_send_fin() had always been hard
to explain when analyzing crash dumps involving gigantic dying processes
with millions of sockets.
Lets try a different strategy :
In case of memory pressure, try to add the FIN flag to last packet
in write queue, even if packet was already sent. TCP stack will
be able to deliver this FIN after a timeout event. Note that this
FIN being delivered by a retransmit, it also carries a Push flag
given our current implementation.
By checking sk_under_memory_pressure(), we anticipate that cooking
many FIN packets might deplete tcp memory.
In the case we could not allocate a packet, even with __GFP_WAIT
allocation, then not sending a FIN seems quite reasonable if it allows
to get rid of this socket, free memory, and not block the process from
eventually doing other useful work.
[ Upstream commit d83769a580f1132ac26439f50068a29b02be535e ]
Using sk_stream_alloc_skb() in tcp_send_fin() is dangerous in
case a huge process is killed by OOM, and tcp_mem[2] is hit.
To be able to free memory we need to make progress, so this
patch allows FIN packets to not care about tcp_mem[2], if
skb allocation succeeded.
In a follow-up patch, we might abort tcp_send_fin() infinite loop
in case TIF_MEMDIE is set on this thread, as memory allocator
did its best getting extra memory already.
This patch reverts d22e15371811 ("tcp: fix tcp fin memory accounting")
Fixes: d22e15371811 ("tcp: fix tcp fin memory accounting")
[ Upstream commit 2ab957492d13bb819400ac29ae55911d50a82a13 ]
Initial discussion was:
[FYI] xfrm: Don't lookup sk_policy for timewait sockets
Forwarded frames should not have a socket attached. Especially
tw sockets will lead to panics later-on in the stack.
This was observed with TPROXY assigning a tw socket and broken
policy routing (misconfigured). As a result frame enters
forwarding path instead of input. We cannot solve this in
TPROXY as it cannot know that policy routing is broken.
v2:
Remove useless comment
Signed-off-by: Sebastian Poehn <sebastian.poehn@gmail.com>
commit db29a9508a9246e77087c5531e45b2c88ec6988b upstream.
Given following iptables ruleset:
-P FORWARD DROP
-A FORWARD -m sctp --dport 9 -j ACCEPT
-A FORWARD -p tcp --dport 80 -j ACCEPT
-A FORWARD -p tcp -m conntrack -m state ESTABLISHED,RELATED -j ACCEPT
One would assume that this allows SCTP on port 9 and TCP on port 80.
Unfortunately, if the SCTP conntrack module is not loaded, this allows
*all* SCTP communication, to pass though, i.e. -p sctp -j ACCEPT,
which we think is a security issue.
This is because on the first SCTP packet on port 9, we create a dummy
"generic l4" conntrack entry without any port information (since
conntrack doesn't know how to extract this information).
All subsequent packets that are unknown will then be in established
state since they will fallback to proto_generic and will match the
'generic' entry.
Our originally proposed version [1] completely disabled generic protocol
tracking, but Jozsef suggests to not track protocols for which a more
suitable helper is available, hence we now mitigate the issue for in
tree known ct protocol helpers only, so that at least NAT and direction
information will still be preserved for others.
[1] http://www.spinics.net/lists/netfilter-devel/msg33430.html
Joint work with Daniel Borkmann.
Fixes CVE-2014-8160.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
[ Upstream commit b50edd7812852d989f2ef09dcfc729690f54a42d ]
I noticed tcpdump was giving funky timestamps for locally
generated SYNACK messages on loopback interface.
11:42:46.938990 IP 127.0.0.1.48245 > 127.0.0.2.23850: S
945476042:945476042(0) win 43690 <mss 65495,nop,nop,sackOK,nop,wscale 7>
20:28:58.502209 IP 127.0.0.2.23850 > 127.0.0.1.48245: S
3160535375:3160535375(0) ack 945476043 win 43690 <mss
This is because we need to clear skb->tstamp before
entering lower stack, otherwise net_timestamp_check()
does not set skb->tstamp.
Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when")
[ Upstream commit f60e5990d9c1424af9dbca60a23ba2a1c7c1ce90 ]
We should not consult skb->sk for output decisions in xmit recursion
levels > 0 in the stack. Otherwise local socket settings could influence
the result of e.g. tunnel encapsulation process.
ipv6 does not conform with this in three places:
1) ip6_fragment: we do consult ipv6_npinfo for frag_size
2) sk_mc_loop in ipv6 uses skb->sk and checks if we should
loop the packet back to the local socket
3) ip6_skb_dst_mtu could query the settings from the user socket and
force a wrong MTU
Furthermore:
In sk_mc_loop we could potentially land in WARN_ON(1) if we use a
PF_PACKET socket ontop of an IPv6-backed vxlan device.
Reuse xmit_recursion as we are currently only interested in protecting
tunnel devices.
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 666b805150efd62f05810ff0db08f44a2370c937 ]
On processing cumulative ACKs, the FRTO code was not checking the
SACKed bit, meaning that there could be a spurious FRTO undo on a
cumulative ACK of a previously SACKed skb.
The FRTO code should only consider a cumulative ACK to indicate that
an original/unretransmitted skb is newly ACKed if the skb was not yet
SACKed.
The effect of the spurious FRTO undo would typically be to make the
connection think that all previously-sent packets were in flight when
they really weren't, leading to a stall and an RTO.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO")
