path: root/net
2009-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: bnx2: Fix the behavior of ethtool when ONBOOT=no qla3xxx: Don't sleep while holding lock. qla3xxx: Give the PHY time to come out of reset. ipv4 routing: Ensure that route cache entries are usable and reclaimable with caching is off net: Move rx skb_orphan call to where needed ipv6: Use correct data types for ICMPv6 type and code net: let KS8842 driver depend on HAS_IOMEM can: let SJA1000 driver depend on HAS_IOMEM netxen: fix firmware init handshake netxen: fix build with without CONFIG_PM netfilter: xt_rateest: fix comparison with self netfilter: xt_quota: fix incomplete initialization netfilter: nf_log: fix direct userspace memory access in proc handler netfilter: fix some sparse endianess warnings netfilter: nf_conntrack: fix conntrack lookup race netfilter: nf_conntrack: fix confirmation race condition netfilter: nf_conntrack: death_by_timeout() fix
2009-06-23ipv4 routing: Ensure that route cache entries are usable and reclaimable ↵Neil Horman
with caching is off When route caching is disabled (rt_caching returns false), We still use route cache entries that are created and passed into rt_intern_hash once. These routes need to be made usable for the one call path that holds a reference to them, and they need to be reclaimed when they're finished with their use. To be made usable, they need to be associated with a neighbor table entry (which they currently are not), otherwise iproute_finish2 just discards the packet, since we don't know which L2 peer to send the packet to. To do this binding, we need to follow the path a bit higher up in rt_intern_hash, which calls arp_bind_neighbour, but not assign the route entry to the hash table. Currently, if caching is off, we simply assign the route to the rp pointer and are reutrn success. This patch associates us with a neighbor entry first. Secondly, we need to make sure that any single use routes like this are known to the garbage collector when caching is off. If caching is off, and we try to hash in a route, it will leak when its refcount reaches zero. To avoid this, this patch calls rt_free on the route cache entry passed into rt_intern_hash. This places us on the gc list for the route cache garbage collector, so that when its refcount reaches zero, it will be reclaimed (Thanks to Alexey for this suggestion). I've tested this on a local system here, and with these patches in place, I'm able to maintain routed connectivity to remote systems, even if I set /proc/sys/net/ipv4/rt_cache_rebuild_count to -1, which forces rt_caching to return false. Signed-off-by: Neil Horman <nhorman@redhat.com> Reported-by: Jarek Poplawski <jarkao2@gmail.com> Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-22Merge branch 'for-2.6.31' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'for-2.6.31' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (128 commits) nfs41: sunrpc: xprt_alloc_bc_request() should not use spin_lock_bh() nfs41: Move initialization of nfs4_opendata seq_res to nfs4_init_opendata_res nfs: remove unnecessary NFS_INO_INVALID_ACL checks NFS: More "sloppy" parsing problems NFS: Invalid mount option values should always fail, even with "sloppy" NFS: Remove unused XDR decoder functions NFS: Update MNT and MNT3 reply decoding functions NFS: add XDR decoder for mountd version 3 auth-flavor lists NFS: add new file handle decoders to in-kernel mountd client NFS: Add separate mountd status code decoders for each mountd version NFS: remove unused function in fs/nfs/mount_clnt.c NFS: Use xdr_stream-based XDR encoder for MNT's dirpath argument NFS: Clean up MNT program definitions lockd: Don't bother with RPC ping for NSM upcalls lockd: Update NSM state from SM_MON replies NFS: Fix false error return from nfs_callback_up() if ipv6.ko is not available NFS: Return error code from nfs_callback_up() to user space NFS: Do not display the setting of the "intr" mount option NFS: add support for splice writes nfs41: Backchannel: CB_SEQUENCE validation ...
2009-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (43 commits) via-velocity: Fix velocity driver unmapping incorrect size. mlx4_en: Remove redundant refill code on RX mlx4_en: Removed redundant check on lso header size mlx4_en: Cancel port_up check in transmit function mlx4_en: using stop/start_all_queues mlx4_en: Removed redundant skb->len check mlx4_en: Counting all the dropped packets on the TX side usbnet cdc_subset: fix issues talking to PXA gadgets Net: qla3xxx, remove sleeping in atomic ipv4: fix NULL pointer + success return in route lookup path isdn: clean up documentation index cfg80211: validate station settings cfg80211: allow setting station parameters in mesh cfg80211: allow adding/deleting stations on mesh ath5k: fix beacon_int handling MAINTAINERS: Fix Atheros pattern paths ath9k: restore PS mode, before we put the chip into FULL SLEEP state. ath9k: wait for beacon frame along with CAB acer-wmi: fix rfkill conversion ath5k: avoid PCI FATAL interrupts by restoring RETRY_TIMEOUT disabling ...
2009-06-22netfilter: xt_rateest: fix comparison with selfPatrick McHardy
As noticed by Török Edwin <edwintorok@gmail.com>: Compiling the kernel with clang has shown this warning: net/netfilter/xt_rateest.c:69:16: warning: self-comparison always results in a constant value ret &= pps2 == pps2; ^ Looking at the code: if (info->flags & XT_RATEEST_MATCH_BPS) ret &= bps1 == bps2; if (info->flags & XT_RATEEST_MATCH_PPS) ret &= pps2 == pps2; Judging from the MATCH_BPS case it seems to be a typo, with the intention of comparing pps1 with pps2. http://bugzilla.kernel.org/show_bug.cgi?id=13535 Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: xt_quota: fix incomplete initializationJan Engelhardt
Commit v2.6.29-rc5-872-gacc738f ("xtables: avoid pointer to self") forgot to copy the initial quota value supplied by iptables into the private structure, thus counting from whatever was in the memory kmalloc returned. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: nf_log: fix direct userspace memory access in proc handlerPatrick McHardy
2009-06-22netfilter: fix some sparse endianess warningsPatrick McHardy
net/netfilter/xt_NFQUEUE.c:46:9: warning: incorrect type in assignment (different base types) net/netfilter/xt_NFQUEUE.c:46:9: expected unsigned int [unsigned] [usertype] ipaddr net/netfilter/xt_NFQUEUE.c:46:9: got restricted unsigned int net/netfilter/xt_NFQUEUE.c:68:10: warning: incorrect type in assignment (different base types) net/netfilter/xt_NFQUEUE.c:68:10: expected unsigned int [unsigned] <noident> net/netfilter/xt_NFQUEUE.c:68:10: got restricted unsigned int net/netfilter/xt_NFQUEUE.c:69:10: warning: incorrect type in assignment (different base types) net/netfilter/xt_NFQUEUE.c:69:10: expected unsigned int [unsigned] <noident> net/netfilter/xt_NFQUEUE.c:69:10: got restricted unsigned int net/netfilter/xt_NFQUEUE.c:70:10: warning: incorrect type in assignment (different base types) net/netfilter/xt_NFQUEUE.c:70:10: expected unsigned int [unsigned] <noident> net/netfilter/xt_NFQUEUE.c:70:10: got restricted unsigned int net/netfilter/xt_NFQUEUE.c:71:10: warning: incorrect type in assignment (different base types) net/netfilter/xt_NFQUEUE.c:71:10: expected unsigned int [unsigned] <noident> net/netfilter/xt_NFQUEUE.c:71:10: got restricted unsigned int net/netfilter/xt_cluster.c:20:55: warning: incorrect type in return expression (different base types) net/netfilter/xt_cluster.c:20:55: expected unsigned int net/netfilter/xt_cluster.c:20:55: got restricted unsigned int const [usertype] ip net/netfilter/xt_cluster.c:20:55: warning: incorrect type in return expression (different base types) net/netfilter/xt_cluster.c:20:55: expected unsigned int net/netfilter/xt_cluster.c:20:55: got restricted unsigned int const [usertype] ip Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: nf_conntrack: fix conntrack lookup racePatrick McHardy
The RCU protected conntrack hash lookup only checks whether the entry has a refcount of zero to decide whether it is stale. This is not sufficient, entries are explicitly removed while there is at least one reference left, possibly more. Explicitly check whether the entry has been marked as dying to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: nf_conntrack: fix confirmation race conditionPatrick McHardy
New connection tracking entries are inserted into the hash before they are fully set up, namely the CONFIRMED bit is not set and the timer not started yet. This can theoretically lead to a race with timer, which would set the timeout value to a relative value, most likely already in the past. Perform hash insertion as the final step to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-22netfilter: nf_conntrack: death_by_timeout() fixEric Dumazet
death_by_timeout() might delete a conntrack from hash list and insert it in dying list. nf_ct_delete_from_lists(ct); nf_ct_insert_dying_list(ct); I believe a (lockless) reader could *catch* ct while doing a lookup and miss the end of its chain. (nulls lookup algo must check the null value at the end of lookup and should restart if the null value is not the expected one. cf Documentation/RCU/rculist_nulls.txt for details) We need to change nf_conntrack_init_net() and use a different "null" value, guaranteed not being used in regular lists. Choose very large values, since hash table uses [0..size-1] null values. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-20nfs41: sunrpc: xprt_alloc_bc_request() should not use spin_lock_bh()Ricardo Labiaga
xprt_alloc_bc_request() is always called in soft interrupt context. Grab the spin_lock instead of the bottom half spin_lock. Softirqs do not preempt other softirqs running on the same processor, so there is no need to disable bottom halves. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-20Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-06-20ipv4: fix NULL pointer + success return in route lookup pathNeil Horman
Don't drop route if we're not caching I recently got a report of an oops on a route lookup. Maxime was testing what would happen if route caching was turned off (doing so by setting making rt_caching always return 0), and found that it triggered an oops. I looked at it and found that the problem stemmed from the fact that the route lookup routines were returning success from their lookup paths (which is good), but never set the **rp pointer to anything (which is bad). This happens because in rt_intern_hash, if rt_caching returns false, we call rt_drop and return 0. This almost emulates slient success. What we should be doing is assigning *rp = rt and _not_ dropping the route. This way, during slow path lookups, when we create a new route cache entry, we don't immediately discard it, rather we just don't add it into the cache hash table, but we let this one lookup use it for the purpose of this route request. Maxime has tested and reports it prevents the oops. There is still a subsequent routing issue that I'm looking into further, but I'm confident that, even if its related to this same path, this patch makes sense to take. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-19cfg80211: validate station settingsJohannes Berg
When I disallowed interfering with stations on non-AP interfaces, I not only forget mesh but also managed interfaces which need this for the authorized flag. Let's actually validate everything properly. This fixes an nl80211 regression introduced by the interfering, under which wpa_supplicant -Dnl80211 could not properly connect. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19cfg80211: allow setting station parameters in meshAndrey Yurovsky
Mesh Point interfaces can also set parameters, for example plink_open is used to manually establish peer links from user-space (currently via iw). Add Mesh Point to the check in nl80211_set_station. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19cfg80211: allow adding/deleting stations on meshAndrey Yurovsky
Commit b2a151a288 added a check that prevents adding or deleting stations on non-AP interfaces. Adding and deleting stations is supported for Mesh Point interfaces, so add Mesh Point to that check as well. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: export persistent attribute in sysfsAlan Jenkins
This information allows userspace to implement a hybrid policy where it can store the rfkill soft-blocked state in platform non-volatile storage if available, and if not then file-based storage can be used. Some users prefer platform non-volatile storage because of the behaviour when dual-booting multiple versions of Linux, or if the rfkill setting is changed in the BIOS setting screens, or if the BIOS responds to wireless-toggle hotkeys itself before the relevant platform driver has been loaded. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: don't restore software blocked state on persistent devicesAlan Jenkins
The setting of the "persistent" flag is also made more explicit using a new rfkill_init_sw_state() function, instead of special-casing rfkill_set_sw_state() when it is called before registration. Suspend is a bit of a corner case so we try to get away without adding another hack to rfkill-input - it's going to be removed soon. If the state does change over suspend, users will simply have to prod rfkill-input twice in order to toggle the state. Userspace policy agents will be able to implement a more consistent user experience. For example, they can avoid the above problem if they toggle devices individually. Then there would be no "global state" to get out of sync. Currently there are only two rfkill drivers with persistent soft-blocked state. thinkpad-acpi already checks the software state on resume. eeepc-laptop will require modification. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> CC: Marcel Holtmann <marcel@holtmann.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: rfkill_set_block() when suspended nitpickAlan Jenkins
If we return after fiddling with the state, userspace will see the wrong state and rfkill_set_sw_state() won't work until the next call to rfkill_set_block(). At the moment rfkill_set_block() will always be called from rfkill_resume(), but this will change in future. Also, presumably the point of this test is to avoid bothering devices which may be suspended. If we don't want to call set_block(), we probably don't want to call query() either :-). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19ieee802154: use standard routine for printing dumpsDmitry Baryshkov
Use print_hex_dump_bytes instead of self-written dumping function for outputting packet dumps. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-19af_iucv: Return -EAGAIN if iucv msg limit is exceededHendrik Brueckner
If the iucv message limit for a communication path is exceeded, sendmsg() returns -EAGAIN instead of -EPIPE. The calling application can then handle this error situtation, e.g. to try again after waiting some time. For blocking sockets, sendmsg() waits up to the socket timeout before returning -EAGAIN. For the new wait condition, a macro has been introduced and the iucv_sock_wait_state() has been refactored to this macro. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-19af_iucv: Change if condition in sendmsg() for more readabilityHendrik Brueckner
Change the if condition to exit sendmsg() if the socket in not connected. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18SUNRPC: Fix the TCP server's send buffer accountingTrond Myklebust
Currently, the sunrpc server is refusing to allow us to process new RPC calls if the TCP send buffer is 2/3 full, even if we do actually have enough free space to guarantee that we can send another request. The following patch fixes svc_tcp_has_wspace() so that we only stop processing requests if we know that the socket buffer cannot possibly fit another reply. It also fixes the tcp write_space() callback so that we only clear the SOCK_NOSPACE flag when the TCP send buffer is less than 2/3 full. This should ensure that the send window will grow as per the standard TCP socket code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-06-18Merge branch 'devel-for-2.6.31' into for-2.6.31Trond Myklebust
Conflicts: fs/nfs/client.c fs/nfs/super.c
2009-06-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (55 commits) netxen: fix tx ring accounting netxen: fix detection of cut-thru firmware mode forcedeth: fix dma api mismatches atm: sk_wmem_alloc initial value is one net: correct off-by-one write allocations reports via-velocity : fix no link detection on boot Net / e100: Fix suspend of devices that cannot be power managed TI DaVinci EMAC : Fix rmmod error net: group address list and its count ipv4: Fix fib_trie rebalancing, part 2 pkt_sched: Update drops stats in act_police sky2: version 1.23 sky2: add GRO support sky2: skb recycling sky2: reduce default transmit ring sky2: receive counter update sky2: fix shutdown synchronization sky2: PCI irq issues sky2: more receive shutdown sky2: turn off pause during shutdown ... Manually fix trivial conflict in net/core/skbuff.c due to kmemcheck
2009-06-18atm: sk_wmem_alloc initial value is oneEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. This broke net/atm since this protocol assumed a null initial value. This patch makes necessary changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: group address list and its countJiri Pirko
This patch is inspired by patch recently posted by Johannes Berg. Basically what my patch does is to group list and a count of addresses into newly introduced structure netdev_hw_addr_list. This brings us two benefits: 1) struct net_device becames a bit nicer. 2) in the future there will be a possibility to operate with lists independently on netdevices (with exporting right functions). I wanted to introduce this patch before I'll post a multicast lists conversion. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 4 +- drivers/net/e1000/e1000_main.c | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/mv643xx_eth.c | 2 +- drivers/net/niu.c | 4 +- drivers/net/virtio_net.c | 10 ++-- drivers/s390/net/qeth_l2_main.c | 2 +- include/linux/netdevice.h | 17 +++-- net/core/dev.c | 130 ++++++++++++++++++-------------------- 9 files changed, 89 insertions(+), 90 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18ipv4: Fix fib_trie rebalancing, part 2Jarek Poplawski
My previous patch, which explicitly delays freeing of tnodes by adding them to the list to flush them after the update is finished, isn't strict enough. It treats exceptionally tnodes without parent, assuming they are newly created, so "invisible" for the read side yet. But the top tnode doesn't have parent as well, so we have to exclude all exceptions (at least until a better way is found). Additionally we need to move rcu assignment of this node before flushing, so the return type of the trie_rebalance() function is changed. Reported-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17pkt_sched: Update drops stats in act_policeJarek Poplawski
Action police statistics could be misleading because drops are not shown when expected. With feedback from: Jamal Hadi Salim <hadi@cyberus.ca> Reported-by: Pawel Staszewski <pstaszewski@itcare.pl> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17skbuff: don't corrupt mac_header on skb expansionStephen Hemminger
The skb mac_header field is sometimes NULL (or ~0u) as a sentinel value. The places where skb is expanded add an offset which would change this flag into an invalid pointer (or offset). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17skbuff: skb_mac_header_was_set is always true on >32 bitStephen Hemminger
Looking at the crash in log_martians(), one suspect is that the check for mac header being set is not correct. The value of mac_header defaults to 0 on allocation, therefore skb_mac_header_was_set will always be true on platforms using NET_SKBUFF_USES_OFFSET. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17Merge commit 'linux-pnfs/nfs41-for-2.6.31' into nfsv41-for-2.6.31Trond Myklebust
2009-06-17nfs41: Rename rq_received to rq_reply_bytes_recvdRicardo Labiaga
The 'rq_received' member of 'struct rpc_rqst' is used to track when we have received a reply to our request. With v4.1, the backchannel can now accept callback requests over the existing connection. Rename this field to make it clear that it is only used for tracking reply bytes and not all bytes received on the connection. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Get the rpc_xprt * from the rpc_rqst instead of the rpc_clnt.Rahul Iyer
Obtain the rpc_xprt from the rpc_rqst so that calls and callback replies can both use the same code path. A client needs the rpc_xprt in order to reply to a callback. Signed-off-by: Rahul Iyer <iyer@netapp.com> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: create a svc_xprt for nfs41 callback thread and use for incoming ↵Benny Halevy
callbacks Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: sunrpc: add a struct svc_xprt pointer to struct svc_serv for ↵Andy Adamson
backchannel use This svc_xprt is passed on to the callback service thread to be later used to processes incoming svc_rqst's Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: sunrpc: provide functions to create and destroy a svc_xprt for ↵Benny Halevy
backchannel use For nfs41 callbacks we need an svc_xprt to process requests coming up the backchannel socket as rpc_rqst's that are transformed into svc_rqst's that need a rq_xprt to be processed. The svc_{udp,tcp}_create methods are too heavy for this job as svc_create_socket creates an actual socket to listen on while for nfs41 we're "reusing" the fore channel's socket. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Backchannel bc_svc_process()Ricardo Labiaga
Implement the NFSv4.1 backchannel service. Invokes the common callback processing logic svc_process_common() to authenticate the call and dispatch the appropriate NFSv4.1 XDR decoder and operation procedure. It then invokes bc_send() to send the reply over the same connection. bc_send() is implemented in a separate patch. At this time there is no slot validation or reply cache handling. [nfs41: Preallocate rpc_rqst receive buffer for handling callbacks] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Move bc_svc_process() declaration to correct patch] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Refactor svc_process()Ricardo Labiaga
net/sunrpc/svc.c:svc_process() is used by the NFSv4 callback service to process RPC requests arriving over connections initiated by the server. NFSv4.1 supports callbacks over the backchannel on connections initiated by the client. This patch refactors svc_process() so that common code can also be used by the backchannel. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Backchannel callback service helper routinesRicardo Labiaga
Executes the backchannel task on the RPC state machine using the existing open connection previously established by the client. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> nfs41: Add bc_svc.o to sunrpc Makefile. [nfs41: bc_send() does not need to be exported outside RPC module] [nfs41: xprt_free_bc_request() need not be exported outside RPC module] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Update copyright] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Add backchannel processing support to RPC state machineRicardo Labiaga
Adds rpc_run_bc_task() which is called by the NFS callback service to process backchannel requests. It performs similar work to rpc_run_task() though "schedules" the backchannel task to be executed starting at the call_trasmit state in the RPC state machine. It also introduces some miscellaneous updates to the argument validation, call_transmit, and transport cleanup functions to take into account that there are now forechannel and backchannel tasks. Backchannel requests do not carry an RPC message structure, since the payload has already been XDR encoded using the existing NFSv4 callback mechanism. Introduce a new transmit state for the client to reply on to backchannel requests. This new state simply reserves the transport and issues the reply. In case of a connection related error, disconnects the transport and drops the reply. It requires the forechannel to re-establish the connection and the server to retransmit the request, as stated in NFSv4.1 section 2.9.2 "Client and Server Transport Behavior". Note: There is no need to loop attempting to reserve the transport. If EAGAIN is returned by xprt_prepare_transmit(), return with tk_status == 0, setting tk_action to call_bc_transmit. rpc_execute() will invoke it again after the task is taken off the sleep queue. [nfs41: rpc_run_bc_task() need not be exported outside RPC module] [nfs41: New call_bc_transmit RPC state] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Backchannel: No need to loop in call_bc_transmit()] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [rpc_count_iostats incorrectly exits early] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Convert rpc_reply_expected() to inline function] [Remove unnecessary BUG_ON()] [Rename variable] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17SUNRPC: Fix a missing "break" option in xs_tcp_setup_socket()Trond Myklebust
In the case of -EADDRNOTAVAIL and/or unhandled connection errors, we want to get rid of the existing socket and retry immediately, just as the comment says. Currently we end up sleeping for a minute, due to the missing "break" statement. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: New xs_tcp_read_data()Ricardo Labiaga
Handles RPC replies and backchannel callbacks. Traditionally the NFS client has expected only RPC replies on its open connections. With NFSv4.1, callbacks can arrive over an existing open connection. This patch refactors the old xs_tcp_read_request() into an RPC reply handler: xs_tcp_read_reply(), a new backchannel callback handler: xs_tcp_read_callback(), and a common routine to read the data off the transport: xs_tcp_read_common(). The new xs_tcp_read_callback() queues callback requests onto a queue where the callback service (a separate thread) is listening for the processing. This patch incorporates work and suggestions from Rahul Iyer (iyer@netapp.com) and Benny Halevy (bhalevy@panasas.com). xs_tcp_read_callback() drops the connection when the number of expected callbacks is exceeded. Use xprt_force_disconnect(), ensuring tasks on the pending queue are awaken on disconnect. [nfs41: Keep track of RPC call/reply direction with a flag] [nfs41: Preallocate rpc_rqst receive buffer for handling callbacks] Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: sunrpc: xs_tcp_read_callback() should use xprt_force_disconnect()] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Moves embedded #ifdefs into #ifdef function blocks] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: New backchannel helper routinesRicardo Labiaga
This patch introduces support to setup the callback xprt on the client side. It allocates/ destroys the preallocated memory structures used to process backchannel requests. At setup time, xprt_setup_backchannel() is invoked to allocate one or more rpc_rqst structures and substructures. This ensures that they are available when an RPC callback arrives. The rpc_rqst structures are maintained in a linked list attached to the rpc_xprt structure. We keep track of the number of allocations so that they can be correctly removed when the channel is destroyed. When an RPC callback arrives, xprt_alloc_bc_request() is invoked to obtain a preallocated rpc_rqst structure. An rpc_xprt structure is returned, and its RPC_BC_PREALLOC_IN_USE bit is set in rpc_xprt->bc_flags. The structure is removed from the the list since it is now in use, and it will be later added back when its user is done with it. After the RPC callback replies, the rpc_rqst structure is returned by invoking xprt_free_bc_request(). This clears the RPC_BC_PREALLOC_IN_USE bit and adds it back to the list, allowing it to be reused by a subsequent RPC callback request. To be consistent with the reception of RPC messages, the backchannel requests should be placed into the 'struct rpc_rqst' rq_rcv_buf, which is then in turn copied to the 'struct rpc_rqst' rq_private_buf. [nfs41: Preallocate rpc_rqst receive buffer for handling callbacks] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Update copyright notice and explain page allocation] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Initialize new rpc_xprt callback related fieldsRicardo Labiaga
