path: root/net
2008-12-18net: Fix module refcount leak in kernel_accept()Wei Yongjun
The kernel_accept() does not hold the module refcount of newsock->ops->owner, so we need __module_get(newsock->ops->owner) code after call kernel_accept() by hand. In sunrpc, the module refcount is missing to hold. So this cause kernel panic. Used following script to reproduct: while [ 1 ]; do mount -t nfs4 192.168.0.19:/ /mnt touch /mnt/file umount /mnt lsmod | grep ipv6 done This patch fixed the problem by add __module_get(newsock->ops->owner) to kernel_accept(). So we do not need to used __module_get(newsock->ops->owner) in every place when used kernel_accept(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: Phonet: keep TX queue disabled when the device is off SCHED: netem: Correct documentation comment in code. netfilter: update rwlock initialization for nat_table netlabel: Compiler warning and NULL pointer dereference fix e1000e: fix double release of mutex IA64: HP_SIMETH needs to depend upon NET netpoll: fix race on poll_list resulting in garbage entry ipv6: silence log messages for locally generated multicast sungem: improve ethtool output with internal pcs and serdes tcp: tcp_vegas cong avoid fix sungem: Make PCS PHY support partially work again.
2008-12-15Phonet: keep TX queue disabled when the device is offRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15SCHED: netem: Correct documentation comment in code.Jesper Dangaard Brouer
The netem simulator is no longer limited by Linux timer resolution HZ. Not since Patrick McHardy changed the QoS system to use hrtimer. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15netfilter: update rwlock initialization for nat_tableSteven Rostedt
The commit e099a173573ce1ba171092aee7bb3c72ea686e59 (netfilter: netns nat: per-netns NAT table) renamed the nat_table from __nat_table to nat_table without updating the __RW_LOCK_UNLOCKED(__nat_table.lock). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-11netlabel: Compiler warning and NULL pointer dereference fixPaul Moore
Fix the two compiler warnings show below. Thanks to Geert Uytterhoeven for finding and reporting the problem. net/netlabel/netlabel_unlabeled.c:567: warning: 'entry' may be used uninitialized in this function net/netlabel/netlabel_unlabeled.c:629: warning: 'entry' may be used uninitialized in this function Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09netpoll: fix race on poll_list resulting in garbage entryNeil Horman
A few months back a race was discused between the netpoll napi service path, and the fast path through net_rx_action: http://kerneltrap.org/mailarchive/linux-netdev/2007/10/16/345470 A patch was submitted for that bug, but I think we missed a case. Consider the following scenario: INITIAL STATE CPU0 has one napi_struct A on its poll_list CPU1 is calling netpoll_send_skb and needs to call poll_napi on the same napi_struct A that CPU0 has on its list CPU0 CPU1 net_rx_action poll_napi !list_empty (returns true) locks poll_lock for A poll_one_napi napi->poll netif_rx_complete __napi_complete (removes A from poll_list) list_entry(list->next) In the above scenario, net_rx_action assumes that the per-cpu poll_list is exclusive to that cpu. netpoll of course violates that, and because the netpoll path can dequeue from the poll list, its possible for CPU0 to detect a non-empty list at the top of the while loop in net_rx_action, but have it become empty by the time it calls list_entry. Since the poll_list isn't surrounded by any other structure, the returned data from that list_entry call in this situation is garbage, and any number of crashes can result based on what exactly that garbage is. Given that its not fasible for performance reasons to place exclusive locks arround each cpus poll list to provide that mutal exclusion, I think the best solution is modify the netpoll path in such a way that we continue to guarantee that the poll_list for a cpu is in fact exclusive to that cpu. To do this I've implemented the patch below. It adds an additional bit to the state field in the napi_struct. When executing napi->poll from the netpoll_path, this bit will be set. When a driver calls netif_rx_complete, if that bit is set, it will not remove the napi_struct from the poll_list. That work will be saved for the next iteration of net_rx_action. I've tested this and it seems to work well. About the biggest drawback I can see to it is the fact that it might result in an extra loop through net_rx_action in the event that the device is actually contended for (i.e. the netpoll path actually preforms all the needed work no the device, and the call to net_rx_action winds up doing nothing, except removing the napi_struct from the poll_list. However I think this is probably a small price to pay, given that the alternative is a crash. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09ipv6: silence log messages for locally generated multicastJan Sembera
This patch fixes minor annoyance during transmission of unsolicited neighbor advertisements from userspace to multicast addresses (as far as I can see in RFC, this is allowed and the similar functionality for IPv4 has been in arping for a long time). Outgoing multicast packets get reinserted into local processing as if they are received from the network. The machine thus sees its own NA and fills the logs with error messages. This patch removes the message if NA has been generated locally. Signed-off-by: Jan Sembera <jsembera@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09tcp: tcp_vegas cong avoid fix Doug Leith
This patch addresses a book-keeping issue in tcp_vegas.c. At present tcp_vegas does separate book-keeping of cwnd based on packet sequence numbers. A mismatch can develop between this book-keeping and tp->snd_cwnd due, for example, to delayed acks acking multiple packets. When vegas transitions to reno operation (e.g. following loss), then this mismatch leads to incorrect behaviour (akin to a cwnd backoff). This seems mostly to affect operation at low cwnds where delayed acking can lead to a significant fraction of cwnd being covered by a single ack, leading to the book-keeping mismatch. This patch modifies the congestion avoidance update to avoid the need for separate book-keeping while leaving vegas congestion avoidance functionally unchanged. A secondary advantage of this modification is that the use of fixed-point (via V_PARAM_SHIFT) and 64 bit arithmetic is no longer necessary, simplifying the code. Some example test measurements with the patched code (confirming no functional change in the congestion avoidance algorithm) can be seen at: http://www.hamilton.ie/doug/vegaspatch/ Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: tproxy: fixe a possible read from an invalid location in the socket match zd1211rw: use unaligned safe memcmp() in-place of compare_ether_addr() mac80211: use unaligned safe memcmp() in-place of compare_ether_addr() ipw2200: fix netif_*_queue() removal regression iwlwifi: clean key table in iwl_clear_stations_table function tcp: tcp_vegas ssthresh bug fix can: omit received RTR frames for single ID filter lists ATM: CVE-2008-5079: duplicate listen() on socket corrupts the vcc table netx-eth: initialize per device spinlock tcp: make urg+gso work for real this time enc28j60: Fix sporadic packet loss (corrected again) hysdn: fix writing outside the field on 64 bits b1isa: fix b1isa_exit() to really remove registered capi controllers can: Fix CAN_(EFF|RTR)_FLAG handling in can_filter Phonet: do not dump addresses from other namespaces netlabel: Fix a potential NULL pointer dereference bnx2: Add workaround to handle missed MSI. xfrm: Fix kernel panic when flush and dump SPD entries
2008-12-07tproxy: fixe a possible read from an invalid location in the socket matchBalazs Scheidler
TIME_WAIT sockets need to be handled specially, and the socket match casted inet_timewait_sock instances to inet_sock, which are not compatible. Handle this special case by checking sk->sk_state. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-05Merge branch 'master' of ↵David S. Miller
2008-12-05mac80211: use unaligned safe memcmp() in-place of compare_ether_addr()Shaddy Baddah
After fixing zd1211rw: use unaligned safe memcmp() in-place of compare_ether_addr(), I started to see kernel log messages detailing unaligned access: Kernel unaligned access at TPC[100f7f44] sta_info_get+0x24/0x68 [mac80211] As with the aforementioned patch, the unaligned access was eminating from a compare_ether_addr() call. Concerned that whilst it was safe to assume that unalignment was the norm for the zd1211rw, and take preventative measures, it may not be the case or acceptable to use the easy fix of changing the call to memcmp(). My research however indicated that it was OK to do this, as there are a few instances where memcmp() is the preferred mechanism for doing mac address comparisons throughout the module. Signed-off-by: Shaddy Baddah <shaddy_baddah@hotmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-04tcp: tcp_vegas ssthresh bug fixDoug Leith
This patch fixes a bug in tcp_vegas.c. At the moment this code leaves ssthresh untouched. However, this means that the vegas congestion control algorithm is effectively unable to reduce cwnd below the ssthresh value (if the vegas update lowers the cwnd below ssthresh, then slow start is activated to raise it back up). One example where this matters is when during slow start cwnd overshoots the link capacity and a flow then exits slow start with ssthresh set to a value above where congestion avoidance would like to adjust it. Signed-off-by: Doug Leith <doug.leith@nuim.ie> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04can: omit received RTR frames for single ID filter listsOliver Hartkopp
Since commit d253eee20195b25e298bf162a6e72f14bf4803e5 the single CAN identifier filter lists handle only non-RTR CAN frames. So we need to omit the check of these filter lists when receiving RTR CAN frames. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04ATM: CVE-2008-5079: duplicate listen() on socket corrupts the vcc tableChas Williams
As reported by Hugo Dias that it is possible to cause a local denial of service attack by calling the svc_listen function twice on the same socket and reading /proc/net/atm/*vc Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03tcp: make urg+gso work for real this timeIlpo Järvinen
I should have noticed this earlier... :-) The previous solution to URG+GSO/TSO will cause SACK block tcp_fragment to do zig-zig patterns, or even worse, a steep downward slope into packet counting because each skb pcount would be truncated to pcount of 2 and then the following fragments of the later portion would restore the window again. Basically this reverts "tcp: Do not use TSO/GSO when there is urgent data" (33cf71cee1). It also removes some unnecessary code from tcp_current_mss that didn't work as intented either (could be that something was changed down the road, or it might have been broken since the dawn of time) because it only works once urg is already written while this bug shows up starting from ~64k before the urg point. The retransmissions already are split to mss sized chunks, so only new data sending paths need splitting in case they have a segment otherwise suitable for gso/tso. The actually check can be improved to be more narrow but since this is late -rc already, I'll postpone thinking the more fine-grained things. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03Merge branch 'for-2.6.28' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.28' of git://linux-nfs.org/~bfields/linux: NLM: client-side nlm_lookup_host() should avoid matching on srcaddr nfsd: use of unitialized list head on error exit in nfs4recover.c Add a reference to sunrpc in svc_addsock nfsd: clean up grace period on early exit
2008-12-03can: Fix CAN_(EFF|RTR)_FLAG handling in can_filterOliver Hartkopp
Due to a wrong safety check in af_can.c it was not possible to filter for SFF frames with a specific CAN identifier without getting the same selected CAN identifier from a received EFF frame also. This fix has a minimum (but user visible) impact on the CAN filter API and therefore the CAN version is set to a new date. Indeed the 'old' API is still working as-is. But when now setting CAN_(EFF|RTR)_FLAG in can_filter.can_mask you might get less traffic than before - but still the stuff that you expected to get for your defined filter ... Thanks to Kurt Van Dijck for pointing at this issue and for the review. Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03Phonet: do not dump addresses from other namespacesremi.denis-courmont@nokia
2008-12-03netlabel: Fix a potential NULL pointer dereferencePaul Moore
Fix a potential NULL pointer dereference seen when trying to remove a static label configuration with an invalid address/mask combination. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03xfrm: Fix kernel panic when flush and dump SPD entriesWei Yongjun
After flush the SPD entries, dump the SPD entries will cause kernel painc. Used the following commands to reproduct: - echo 'spdflush;' | setkey -c - echo 'spdadd 3ffe:501:ffff:ff01::/64 3ffe:501:ffff:ff04::/64 any -P out ipsec \ ah/tunnel/3ffe:501:ffff:ff00:200:ff:fe00:b0b0-3ffe:501:ffff:ff02:200:ff:fe00:a1a1/require;\ spddump;' | setkey -c - echo 'spdflush; spddump;' | setkey -c - echo 'spdadd 3ffe:501:ffff:ff01::/64 3ffe:501:ffff:ff04::/64 any -P out ipsec \ ah/tunnel/3ffe:501:ffff:ff00:200:ff:fe00:b0b0-3ffe:501:ffff:ff02:200:ff:fe00:a1a1/require;\ spddump;' | setkey -c This is because when flush the SPD entries, the SPD entry is not remove from the list. This patch fix the problem by remove the SPD entry from the list. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-26net: Fix soft lockups/OOM issues w/ unix garbage collectordann frazier
This is an implementation of David Miller's suggested fix in: https://bugzilla.redhat.com/show_bug.cgi?id=470201 It has been updated to use wait_event() instead of wait_event_interruptible(). Paraphrasing the description from the above report, it makes sendmsg() block while UNIX garbage collection is in progress. This avoids a situation where child processes continue to queue new FDs over a AF_UNIX socket to a parent which is in the exit path and running garbage collection on these FDs. This contention can result in soft lockups and oom-killing of unrelated processes. Signed-off-by: dann frazier <dannf@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-26Phonet: fix oops in phonet_address_del() on non-Phonet deviceRémi Denis-Courmont
A NULL dereference would occur when trying to delete an addres from a network device that does not have any Phonet address. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-26netfilter: ctnetlink: fix GFP_KERNEL allocation under spinlockPatrick McHardy
The previous fix for the conntrack creation race (netfilter: ctnetlink: fix conntrack creation race) missed a GFP_KERNEL allocation that is now performed while holding a spinlock. Switch to GFP_ATOMIC. Reported-and-tested-by: Zoltan Borbely <bozo@andrews.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: make skb_truesize_bug() call WARN()Arjan van de Ven
The truesize message check is important enough to make it print "BUG" to the user console... lets also make it important enough to spit a backtrace/module list etc so that kerneloops.org can track them. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25Merge branch 'master' of ↵David S. Miller
2008-11-25net/wireless/reg.c: fix bad WARN_ON in if statementIngo Molnar
fix: net/wireless/reg.c:348:29: error: macro "if" passed 2 arguments, but takes just 1 triggered by the branch-tracer. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-25mac80211 : Fix setting ad-hoc mode and non-ibss channelAbhijeet Kolekar
Patch fixes the kernel trace when user tries to set ad-hoc mode on non IBSS channel. e.g iwconfig wlan0 chan 36 mode ad-hoc Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-25rose: zero length frame filtering in af_rose.cBernard Pidoux
Since changeset e79ad711a0108475c1b3a03815527e7237020b08 from mainline, >From David S. Miller, empty packet can be transmitted on connected socket for datagram protocols. However, this patch broke a high level application using ROSE network protocol with connected datagram. Bulletin Board Stations perform bulletins forwarding between BBS stations via ROSE network using a forward protocol. Now, if for some reason, a buffer in the application software happens to be empty at a specific moment, ROSE sends an empty packet via unfiltered packet socket. When received, this ROSE packet introduces perturbations of data exchange of BBS forwarding, for the application message forwarding protocol is waiting for something else. We agree that a more careful programming of the application protocol would avoid this situation and we are willing to debug it. But, as an empty frame is no use and does not have any meaning for ROSE protocol, we may consider filtering zero length data both when sending and receiving socket data. The proposed patch repaired BBS data exchange through ROSE network that were broken since 2.6.22.11 kernel. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24bridge: netfilter: fix update_pmtu crash with GREHerbert Xu
As GRE tries to call the update_pmtu function on skb->dst and bridge supplies an skb->dst that has a NULL ops field, all is not well. This patch fixes this by giving the bridge device an ops field with an update_pmtu function. For the moment I've left all other fields blank but we can fill them in later should the need arise. Based on report and patch by Philip Craig. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24netfilter: ctnetlink: fix conntrack creation racePatrick McHardy
Conntrack creation through ctnetlink has two races: - the timer may expire and free the conntrack concurrently, causing an invalid memory access when attempting to put it in the hash tables - an identical conntrack entry may be created in the packet processing path in the time between the lookup and hash insertion Hold the conntrack lock between the lookup and insertion to avoid this. Reported-by: Zoltan Borbely <bozo@andrews.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24Add a reference to sunrpc in svc_addsockTom Tucker
The svc_addsock function adds transport instances without taking a reference on the sunrpc.ko module, however, the generic transport destruction code drops a reference when a transport instance is destroyed. Add a try_module_get call to the svc_addsock function for transport instances added by this function. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Tested-by: Jeff Moyer <jmoyer@redhat.com>
2008-11-21net: Fix memory leak in the proto_register functionCatalin Marinas
If the slub allocator is used, kmem_cache_create() may merge two or more kmem_cache's into one but the cache name pointer is not updated and kmem_cache_name() is no longer guaranteed to return the pointer passed to the former function. This patch stores the kmalloc'ed pointers in the corresponding request_sock_ops and timewait_sock_ops structures. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21tcp: Do not use TSO/GSO when there is urgent dataPetr Tesarik
This patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=12014 Since most (if not all) implementations of TSO and even the in-kernel software GSO do not update the urgent pointer when splitting a large segment, it is necessary to turn off TSO/GSO for all outgoing traffic with the URG pointer set. Looking at tcp_current_mss (and the preceding comment) I even think this was the original intention. However, this approach is insufficient, because TSO/GSO is turned off only for newly created frames, not for frames which were already pending at the arrival of a message with MSG_OOB set. These frames were created when TSO/GSO was enabled, so they may be large, and they will have the urgent pointer set in tcp_transmit_skb(). With this patch, such large packets will be fragmented again before going to the transmit routine. As a side note, at least the following NICs are known to screw up the urgent pointer in the TCP header when doing TSO: Intel 82566MM (PCI ID 8086:1049) Intel 82566DC (PCI ID 8086:104b) Intel 82541GI (PCI ID 8086:1076) Broadcom NetXtreme II BCM5708 (PCI ID 14e4:164c) Signed-off-by: Petr Tesarik <ptesarik@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20SUNRPC: Fix a performance regression in the RPC authentication codeTrond Myklebust
Fix a regression reported by Max Kellermann whereby kernel profiling showed that his clients were spending 45% of their time in rpcauth_lookup_credcache. It turns out that although his processes had identical uid/gid/groups, generic_match() was failing to detect this, because the task->group_info pointers were not shared. This again lead to the creation of a huge number of identical credentials at the RPC layer. The regression is fixed by comparing the contents of task->group_info if the actual pointers are not identical. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits) net: fix tiny output corruption of /proc/net/snmp6 atl2: don't request irq on resume if netif running ipv6: use seq_release_private for ip6mr.c /proc entries pkt_sched: fix missing check for packet overrun in qdisc_dump_stab() smc911x: Fix printf format typo in smc911x driver. asix: Fix asix-based cards connecting to 10/100Mbs LAN. mv643xx_eth: fix recycle check bound mv643xx_eth: fix the order of mdiobus_{unregister, free}() calls sh: sh_eth: Update to change of mii_bus TPROXY: supply a struct flowi->flags argument in inet_sk_rebuild_header() TPROXY: fill struct flowi->flags in udp_sendmsg() net: ipg.c fix bracing on endian swapping phylib: Fix auto-negotiation restart avoidance net: jme.c rxdesc.flags is __le16, other missing endian swaps phylib: fix phy name example in documentation net: Do not fire linkwatch events until the device is registered. phonet: fix compilation with gcc-3.4 ixgbe: fix compilation with gcc-3.4 pktgen: fix multiple queue warning net: fix ip_mr_init() error path ...
2008-11-20net: fix tiny output corruption of /proc/net/snmp6Alexey Dobriyan
Because "name" is static, it can be occasionally be filled with somewhat garbage if two processes read /proc/net/snmp6. Also, remove useless casts and "-1" -- snprintf() correctly terminates it's output. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20ipv6: use seq_release_private for ip6mr.c /proc entriesBenjamin Thery
In ip6mr.c, /proc entries /proc/net/ip6_mr_cache and /proc/net/ip6_mr_vif are opened with seq_open_private(), thus seq_release_private() should be used to release them. Should fix a small memory leak. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20pkt_sched: fix missing check for packet overrun in qdisc_dump_stab()Patrick McHardy
nla_nest_start() might return NULL, causing a NULL pointer dereference. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'master' of ↵David S. Miller
2008-11-20TPROXY: supply a struct flowi->flags argument in inet_sk_rebuild_header()Balazs Scheidler
inet_sk_rebuild_header() does a new route lookup if the dst_entry associated with a socket becomes stale. However inet_sk_rebuild_header() didn't use struct flowi->flags, causing the route lookup to fail for foreign-bound IP_TRANSPARENT sockets, causing an error state to be set for the sockets in question. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20TPROXY: fill struct flowi->flags in udp_sendmsg()Balazs Scheidler
udp_sendmsg() didn't fill struct flowi->flags, which means that the route lookup would fail for non-local IPs even if the IP_TRANSPARENT sockopt was set. This prevents sendto() to work properly for UDP sockets, whereas bind(foreign-ip) + connect() + send() worked fine. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19reintroduce accept4Ulrich Drepper
Introduce a new accept4() system call. The addition of this system call matches analogous changes in 2.6.27 (dup3(), evenfd2(), signalfd4(), inotify_init1(), epoll_create1(), pipe2()) which added new system calls that differed from analogous traditional system calls in adding a flags argument that can be used to access additional functionality. The accept4() system call is exactly the same as accept(), except that it adds a flags bit-mask argument. Two flags are initially implemented. (Most of the new system calls in 2.6.27 also had both of these flags.) SOCK_CLOEXEC causes the close-on-exec (FD_CLOEXEC) flag to be enabled for the new file descriptor returned by accept4(). This is a useful security feature to avoid leaking information in a multithreaded program where one thread is doing an accept() at the same time as another thread is doing a fork() plus exec(). More details here: http://udrepper.livejournal.com/20407.html "Secure File Descriptor Handling", Ulrich Drepper). The other flag is SOCK_NONBLOCK, which causes the O_NONBLOCK flag to be enabled on the new open file description created by accept4(). (This flag is merely a convenience, saving the use of additional calls fcntl(F_GETFL) and fcntl (F_SETFL) to achieve the same result. Here's a test program. Works on x86-32. Should work on x86-64, but I (mtk) don't have a system to hand to test with. It tests accept4() with each of the four possible combinations of SOCK_CLOEXEC and SOCK_NONBLOCK set/clear in 'flags', and verifies that the appropriate flags are set on the file descriptor/open file description returned by accept4(). I tested Ulrich's patch in this thread by applying against 2.6.28-rc2, and it passes according to my test program. /* test_accept4.c Copyright (C) 2008, Linux Foundation, written by Michael Kerrisk <mtk.manpages@gmail.com> Licensed under the GNU GPLv2 or later. */ #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> #include <sys/socket.h> #include <netinet/in.h> #include <stdlib.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #define PORT_NUM 33333 #define die(msg) do { perror(msg); exit(EXIT_FAILURE); } while (0) /**********************************************************************/ /* The following is what we need until glibc gets a wrapper for accept4() */ /* Flags for socket(), socketpair(), accept4() */ #ifndef SOCK_CLOEXEC #define SOCK_CLOEXEC O_CLOEXEC #endif #ifndef SOCK_NONBLOCK #define SOCK_NONBLOCK O_NONBLOCK #endif #ifdef __x86_64__ #define SYS_accept4 288 #elif __i386__ #define USE_SOCKETCALL 1 #define SYS_ACCEPT4 18 #else #error "Sorry -- don't know the syscall # on this architecture" #endif static int accept4(int fd, struct sockaddr *sockaddr, socklen_t *addrlen, int flags) { printf("Calling accept4(): flags = %x", flags); if (flags != 0) { printf(" ("); if (flags & SOCK_CLOEXEC) printf("SOCK_CLOEXEC"); if ((flags & SOCK_CLOEXEC) && (flags & SOCK_NONBLOCK)) printf(" "); if (flags & SOCK_NONBLOCK) printf("SOCK_NONBLOCK"); printf(")"); } printf("\n"); #if USE_SOCKETCALL long args[6]; args[0] = fd; args[1] = (long) sockaddr; args[2] = (long) addrlen; args[3] = flags; return syscall(SYS_socketcall, SYS_ACCEPT4, args); #else return syscall(SYS_accept4, fd, sockaddr, addrlen, flags); #endif } /**********************************************************************/ static int do_test(int lfd, struct sockaddr_in *conn_addr, int closeonexec_flag, int nonblock_flag) { int connfd, acceptfd; int fdf, flf, fdf_pass, flf_pass; struct sockaddr_in claddr; socklen_t addrlen; printf("=======================================\n"); connfd = socket(AF_INET, SOCK_STREAM, 0); if (connfd == -1) die("socket"); if (connect(connfd, (struct sockaddr *) conn_addr, sizeof(struct sockaddr_in)) == -1) die("connect"); addrlen = sizeof(struct sockaddr_in); acceptfd = accept4(lfd, (struct sockaddr *) &claddr, &addrlen, closeonexec_flag | nonblock_flag); if (acceptfd == -1) { perror("accept4()"); close(connfd); return 0; } fdf = fcntl(acceptfd, F_GETFD); if (fdf == -1) die("fcntl:F_GETFD"); fdf_pass = ((fdf & FD_CLOEXEC) != 0) == ((closeonexec_flag & SOCK_CLOEXEC) != 0); printf("Close-on-exec flag is %sset (%s); ", (fdf & FD_CLOEXEC) ? "" : "not ", fdf_pass ? "OK" : "failed"); flf = fcntl(acceptfd, F_GETFL); if (flf == -1) die("fcntl:F_GETFD"); flf_pass = ((flf & O_NONBLOCK) != 0) == ((nonblock_flag & SOCK_NONBLOCK) !=0); printf("nonblock flag is %sset (%s)\n", (flf & O_NONBLOCK) ? "" : "not ", flf_pass ? "OK" : "failed"); close(acceptfd); close(connfd); printf("Test result: %s\n", (fdf_pass && flf_pass) ? "PASS" : "FAIL"); return fdf_pass && flf_pass; } static int create_listening_socket(int port_num) { struct sockaddr_in svaddr; int lfd; int optval; memset(&svaddr, 0, sizeof(struct sockaddr_in)); svaddr.sin_family = AF_INET; svaddr.sin_addr.s_addr = htonl(INADDR_ANY); svaddr.sin_port = htons(port_num); lfd = socket(AF_INET, SOCK_STREAM, 0); if (lfd == -1) die("socket"); optval = 1; if (setsockopt(lfd, SOL_SOCKET, SO_REUSEADDR, &optval, sizeof(optval)) == -1) die("setsockopt"); if (bind(lfd, (struct sockaddr *) &svaddr, sizeof(struct sockaddr_in)) == -1) die("bind"); if (listen(lfd, 5) == -1) die("listen"); return lfd; } int main(int argc, char *argv[]) { struct sockaddr_in conn_addr; int lfd; int port_num; int passed; passed = 1; port_num = (argc > 1) ? atoi(argv[1]) : PORT_NUM; memset(&conn_addr, 0, sizeof(struct sockaddr_in)); conn_addr.sin_family = AF_INET; conn_addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); conn_addr.sin_port = htons(port_num); lfd = create_listening_socket(port_num); if (!do_test(lfd, &conn_addr, 0, 0)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, 0)) passed = 0; if (!do_test(lfd, &conn_addr, 0, SOCK_NONBLOCK)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, SOCK_NONBLOCK)) passed = 0; close(lfd); exit(passed ? EXIT_SUCCESS : EXIT_FAILURE); } [mtk.manpages@gmail.com: rewrote changelog, updated test program] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19net: Do not fire linkwatch events until the device is registered.David S. Miller
Several device drivers try to do things like netif_carrier_off() before register_netdev() is invoked. This is bogus, but too many drivers do this to fix them all up in one go. Reported-by: Folkert van Heusden <folkert@vanheusden.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19phonet: fix compilation with gcc-3.4Alexey Dobriyan
CC [M] net/phonet/af_phonet.o net/phonet/af_phonet.c: In function `pn_socket_create': net/phonet/af_phonet.c:38: sorry, unimplemented: inlining failed in call to 'phonet_proto_put': function body not available net/phonet/af_phonet.c:99: sorry, unimplemented: called from here make[3]: *** [net/phonet/af_phonet.o] Error 1 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19pktgen: fix multiple queue warningRobert Olsson
As number of TX queues in unrelated to number of CPU's we remove this test and just make sure nxtq never gets exceeded. Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19net: fix ip_mr_init() error pathBenjamin Thery
Similarly to IPv6 ip6_mr_init() (fixed last week), the order of cleanup operations in the error/exit section of ip_mr_init() is completely inversed. It should be the other way around. Also a del_timer() is missing in the error path. I should have guessed last week that this same error existed in ipmr.c too, as ip6mr.c is largely inspired by ipmr.c. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18mac80211: remove ieee80211_notify_macJohannes Berg
Before ieee80211_notify_mac() was added, it was presented with the use case of using it to tell mac80211 that the association may have been lost because the firmware crashed/reset. Since then, it has also been used by iwlwifi to (slightly) speed up re-association after resume, a workaround around the fact that mac80211 has no suspend/resume handling yet. It is also not used by any other drivers, so clearly it cannot be necessary for "good enough" suspend/resume. Unfortunately, the callback suffers from a severe problem: It only works for station mode. If suspend/resume happens while in IBSS or any other mode (but station), then the callback is pointless. Recently, it has created a number of locking issues, first because it required rtnl locking rather than RCU due to calling sleeping functions within the critical section, and now because it's called by iwlwifi from the mac80211 workqueue that may not use the rtnl because it is flushed under rtnl. (cf. http://bugzilla.kernel.org/show_bug.cgi?id=12046) I think, therefore, that we should take a step back, remove it entirely for now and add the small feature it provided properly. For suspend and resume we will need to introduce new hooks, and for the case where the firmware was reset the driver will probably simply just pretend it has done a suspend/resume cycle to get mac80211 to reprogram the hardware completely, not just try to connect to the current AP again in station mode. When doing so, we will need to take into account locking issues and possibly defer to schedule_work from within mac80211 for the resume operation, while the suspend operation must be done directly. Proper suspend/resume should also not necessarily try to reconnect to the current AP, the time spent in suspend may have been short enough to not be disconnected from the AP, mac80211 will detect that the AP went out of range quickly if it did, and if the association is lost then the AP will disassoc as soon as a data frame is sent. We might also take into account WWOL then, and have mac80211 program the hardware into such a mode where it is available and requested. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-16rtnetlink: propagate error from dev_change_flags in do_setlink()Johannes Berg
Unlike ifconfig, iproute doesn't report an error when setting an interface up fails: (example: put wireless network mac80211 interface into repeater mode with iwconfig but do not set a peer MAC address, it should fail with -ENOLINK) without patch: # ip link set wlan0 up ; echo $? 0 # with patch: # ip link set wlan0 up ; echo $? RTNETLINK answers: Link has been severed 2 # Propagate the return value from dev_change_flags() to fix this. Signed-off-by: Patrick McHardy <kaber@trash.net> Tested-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
