imx_3.10.y_android
arch/arm/boot/dts/Makefile
arch/arm/boot/dts/imx6sx.dtsi
arch/arm/mach-imx/clk-imx6sx.c
arch/arm/mach-imx/mach-imx6sx.c
drivers/dma/pxp/pxp_dma_v2.c
drivers/media/platform/mxc/capture/csi_v4l2_capture.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.h
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_command.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_vg.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_video_memory.c
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_eglplatform.h
drivers/pwm/pwm-imx.c
include/dt-bindings/clock/imx6sx-clock.h
Although the implementation probably needs a lot of work, this initial API
allows to implement software TSO in mvneta and mv643xx_eth drivers in a not
so intrusive way.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
imx_3.10.y_android
arch/arm/common/Kconfig
arch/arm/common/Makefile
arch/arm/mm/mmu.c
drivers/input/Kconfig
drivers/input/Makefile
drivers/input/evdev.c
drivers/input/keyreset.c
drivers/input/misc/gpio_event.c
drivers/of/fdt.c
drivers/staging/android/Kconfig
drivers/staging/android/Makefile
drivers/staging/android/ion/Kconfig
drivers/staging/android/ion/Makefile
drivers/staging/android/ion/ion.c
drivers/usb/gadget/android.c
drivers/usb/phy/Kconfig
drivers/usb/phy/Makefile
drivers/video/Kconfig
drivers/video/adf/adf.c
drivers/video/adf/adf_memblock.c
include/linux/keyreset.h
include/linux/mm_types.h
include/linux/wakelock.h
include/net/tcp.h
include/uapi/linux/prctl.h
include/video/adf_fbdev.h
kernel/cpu.c
kernel/futex.c
kernel/power/Kconfig
kernel/power/Makefile
kernel/power/wakeup_reason.c
kernel/sys.c
net/ipv4/ping.c
net/ipv4/sysctl_net_ipv4.c
net/ipv6/ping.c
net/ipv6/route.c
net/netfilter/xt_IDLETIMER.c
[ Upstream commit 13eb2ab2d33c57ebddc57437a7d341995fc9138c ]
When trying to delete a table >= 256 using iproute2 the local table
will be deleted.
The table id is specified as a netlink attribute when it needs more then
8 bits and iproute2 then sets the table field to RT_TABLE_UNSPEC (0).
Preconditions to matching the table id in the rule delete code
doesn't seem to take the "table id in netlink attribute" into condition
so the frh_get_table helper function never gets to do its job when
matching against current rule.
Use the helper function twice instead of peaking at the table value directly.
Originally reported at: http://bugs.debian.org/724783
Reported-by: Nicolas HICHER <nhicher@avencall.com>
Signed-off-by: Andreas Henriksson <andreas@fatal.se>
When using mark-based routing, sockets returned from accept()
may need to be marked differently depending on the incoming
connection request.
This is the case, for example, if different socket marks identify
different networks: a listening socket may want to accept
connections from all networks, but each connection should be
marked with the network that the request came in on, so that
subsequent packets are sent on the correct network.
This patch adds a sysctl to mark TCP sockets based on the fwmark
of the incoming SYN packet. If enabled, and an unmarked socket
receives a SYN, then the SYN packet's fwmark is written to the
connection's inet_request_sock, and later written back to the
accepted socket when the connection is established. If the
socket already has a nonzero mark, then the behaviour is the same
as it is today, i.e., the listening socket's fwmark is used.
Black-box tested using user-mode linux:
- IPv4/IPv6 SYN+ACK, FIN, etc. packets are routed based on the
mark of the incoming SYN packet.
- The socket returned by accept() is marked with the mark of the
- Tested with syncookies=1 and syncookies=2.
Change-Id: I26bc1eceefd2c588d73b921865ab70e4645ade57
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Currently, routing lookups used for Path PMTU Discovery in
absence of a socket or on unmarked sockets use a mark of 0.
This causes PMTUD not to work when using routing based on
netfilter fwmark mangling and fwmark ip rules, such as:
iptables -j MARK --set-mark 17
ip rule add fwmark 17 lookup 100
This patch causes these route lookups to use the fwmark from the
received ICMP error when the fwmark_reflect sysctl is enabled.
This allows the administrator to make PMTUD work by configuring
appropriate fwmark rules to mark the inbound ICMP packets.
Black-box tested using user-mode linux by pointing different
fwmarks at routing tables egressing on different interfaces, and
using iptables mangling to mark packets inbound on each interface
with the interface's fwmark. ICMPv4 and ICMPv6 PMTU discovery
work as expected when mark reflection is enabled and fail when
it is disabled.
Change-Id: Id7fefb7ec1ff7f5142fba43db1960b050e0dfaec
Kernel-originated IP packets that have no user socket associated
with them (e.g., ICMP errors and echo replies, TCP RSTs, etc.)
are emitted with a mark of zero. Add a sysctl to make them have
the same mark as the packet they are replying to.
This allows an administrator that wishes to do so to use
mark-based routing, firewalling, etc. for these replies by
marking the original packets inbound.
Tested using user-mode linux:
- ICMP/ICMPv6 echo replies and errors.
- TCP RST packets (IPv4 and IPv6).
Change-Id: I6873d973196797bcf32e2e91976df647c7e8b85a
Currently, IPv6 router discovery always puts routes into
RT6_TABLE_MAIN. This causes problems for connection managers
that want to support multiple simultaneous network connections
and want control over which one is used by default (e.g., wifi
and wired).
To work around this connection managers typically take the routes
they prefer and copy them to static routes with low metrics in
the main table. This puts the burden on the connection manager
to watch netlink to see if the routes have changed, delete the
routes when their lifetime expires, etc.
Instead, this patch adds a per-interface sysctl to have the
kernel put autoconf routes into different tables. This allows
each interface to have its own autoconf table, and choosing the
default interface (or using different interfaces at the same
time for different types of traffic) can be done using
appropriate ip rules.
The sysctl behaves as follows:
- = 0: default. Put routes into RT6_TABLE_MAIN as before.
- > 0: manual. Put routes into the specified table.
- < 0: automatic. Add the absolute value of the sysctl to the
device's ifindex, and use that table.
The automatic mode is most useful in conjunction with
net.ipv6.conf.default.accept_ra_rt_table. A connection manager
or distribution could set it to, say, -100 on boot, and
thereafter just use IP rules.
Change-Id: I82d16e3737d9cdfa6489e649e247894d0d60cbb1
Change-Id: I5a61e0f9f22f193c51b1aafd270fb0642a2e0fab
Plug a group_info refcount leak in ping_init.
group_info is only needed during initialization and
the code failed to release the reference on exit.
While here move grabbing the reference to a place
where it is actually needed.
Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com>
Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com>
Signed-off-by: xiaoming wang <xiaoming.wang@intel.com>
e8430cbed3ef15fdb1ac26cfd020e010aa5f1c35
Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
Message notifications contains an additional timestamp field in nano seconds.
The expiry time for the timers are modified during suspend/resume.
If timer was supposed to expire while the system is suspended then a
notification is sent when it resumes with the timestamp of the scheduled expiry.
Removes the race condition for multiple work scheduled.
Bug: 13247811
Change-Id: I752c5b00225fe7085482819f975cc0eb5af89bff
Change-Id: I2adc517c0c51050ed601992fa0ea4de8f1449414
Signed-off-by: Greg Hackmann <ghackmann@google.com>
The default initial rwnd is hardcoded to 10.
Now we allow it to be controlled via
/proc/sys/net/ipv4/tcp_default_init_rwnd
which limits the values from 3 to 100
This is somewhat needed because ipv6 routes are
autoconfigured by the kernel.
See "An Argument for Increasing TCP's Initial Congestion Window"
in https://developers.google.com/speed/articles/tcp_initcwnd_paper.pdf
Change-Id: I386b2a9d62de0ebe05c1ebe1b4bd91b314af5c54
Signed-off-by: JP Abgrall <jpa@google.com>
net/ipv4/tcp_input.c
Reverted Change-Id: Iaeca5dd2d7878c0733923ae03309a2a7b86979ca
Change-Id: I0e0a4f60ec14330d8d8d1c5a508fa058d9919e07
Signed-off-by: Ashish Sharma <ashishsharma@google.com>
(cherry picked from commit e0a4e5b0e808d718dd9af500c5754118fc3935db)
A plain read() on a socket does set msg->msg_name to NULL. So check for
NULL pointer first.
[Backport of net-next cf970c002d270c36202bd5b9c2804d3097a52da0]
Bug: 12780426
Change-Id: I3df76aca2fa56478b9a33c404f7b1f0940475ef7
[net-next commit a1bdc45580fc19e968b32ad27cd7e476a4aa58f6]
Bug: 12800827
Change-Id: I93d897e5043dc89bc99f111c89ef4f8b1fa1885d
[net-next commit fbfe80c890a1dc521d0b629b870e32fcffff0da5]
ping_v6_sendmsg currently returns 0 on success. It should return
the number of bytes written instead.
Bug: 12800827
Change-Id: I7ed17dc61afbb68a84908e67e44db976ec812bad
[net-next commit c26d6b46da3ee86fa8a864347331e5513ca84c2b]
If we don't need scope id, we should initialize it to zero.
Same for ->sin6_flowinfo.
Bug: 12800827
Change-Id: Ic19792cee3f5dc30237562cf48e6bdf49817c96e
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
[net-next commit 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67]
This adds the ability to send ICMPv6 echo requests without a
raw socket. The equivalent ability for ICMPv4 was added in
2011.
Instead of having separate code paths for IPv4 and IPv6, make
most of the code in net/ipv4/ping.c dual-stack and only add a
few IPv6-specific bits (like the protocol definition) to a new
net/ipv6/ping.c. Hopefully this will reduce divergence and/or
duplication of bugs in the future.
Caveats:
- Setting options via ancillary data (e.g., using IPV6_PKTINFO
to specify the outgoing interface) is not yet supported.
- There are no separate security settings for IPv4 and IPv6;
everything is controlled by /proc/net/ipv4/ping_group_range.
- The proc interface does not yet display IPv6 ping sockets
properly.
Tested with a patched copy of ping6 and using raw socket calls.
Compiles and works with all of CONFIG_IPV6={n,m,y}.
Bug: 12800827
Change-Id: I718cd9931823873ab44df22e8a66e12d6a0a6eb1
Change-Id: I15b21230d52479d008a00d9e2191dda020f00925
Stop using obsolete procfs api.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
- Stop using obsolete create_proc_entry api.
- Use proc_set_user instead of directly accessing the private structure.
Convert to use seq_read
Since (41063e9 ipv4: Early TCP socket demux), skb's can have an sk which
is not a struct sock but the smaller struct inet_timewait_sock without an
sk->sk_socket. Now we bypass sk_state == TCP_TIME_WAIT
Avoid waking up every thread sleeping in read call on an AF_UNIX
socket during suspend and resume by calling a freezable blocking
call. Previous patches modified the freezer to avoid sending
wakeups to threads that are blocked in freezable blocking calls.
This call was selected to be converted to a freezable call because
it doesn't hold any locks or release any resources when interrupted
that might be needed by another freezing task or a kernel driver
during suspend, and is a common site where idle userspace tasks are
blocked.
Change-Id: I788246a76780ea892659526e70be018b18f646c4
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Colin Cross <ccross@android.com>
NFS calls the freezable helpers with locks held, which is unsafe
and will cause lockdep warnings when 6aa9707 "lockdep: check
that no locks held at freeze time" is reapplied (it was reverted
in dbf520a). NFS shouldn't be doing this, but it has
long-running syscalls that must hold a lock but also shouldn't
block suspend. Until NFS freeze handling is rewritten to use a
signal to exit out of the critical section, add new *_unsafe
versions of the helpers that will not run the lockdep test when
6aa9707 is reapplied, and call them from NFS.
In practice the likley result of holding the lock while freezing
is that a second task blocked on the lock will never freeze,
aborting suspend, but it is possible to manufacture a case using
the cgroup freezer, the lock, and the suspend freezer to create
a deadlock. Silencing the lockdep warning here will allow
problems to be found in other drivers that may have a more
serious deadlock risk, and prevent new problems from being added.
Change-Id: Ia17d32cdd013a6517bdd5759da900970a4427170
Acked-by: Pavel Machek <pavel@ucw.cz>
Some of the printks are in the packet handling path.
We now ratelimit the very unlikely errors to avoid
kmsg spamming.
Removed bluetooth checks for AID_NET_BT and AID_NET_BT_ADMIN
which are not useful anymore.
This is in preparation for getting rid of all the AID_* gids.
In the past it would always ignore interfaces with loopback addresses.
Now we just treat them like any other.
This also helps with writing tests that check for the presence
of the qtaguid module.
In the past the iface_stat_fmt would only show global bytes/packets
for the skb-based numbers.
For stall detection in userspace, distinguishing tcp vs other protocols
makes it easier.
Now we report
ifname total_skb_rx_bytes total_skb_rx_packets total_skb_tx_bytes
total_skb_tx_packets {rx,tx}_{tcp,udp,ohter}_{bytes,packets}
Bug: 6818637
qtaguid limits what can be done with /ctrl and /stats based on group
membership.
This changes removes AID_NET_BW_STATS and AID_NET_BW_ACCT, and picks
up the groups from the gid of the matching proc entry files.
Change-Id: I42e477adde78a12ed5eb58fbc0b277cdaadb6f94
If create_if_tag_stat fails to allocate memory (GFP_ATOMIC) the
following will happen:
qtaguid: iface_stat: tag stat alloc failed
kernel BUG at xt_qtaguid.c:1482!
Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com>
qtudev_open() could return with a uid_tag_data_tree_lock held
when an kzalloc(..., GFP_ATOMIC) would fail.
Very unlikely to get triggered AND survive the mayhem of running out of mem.
In the past, a process could only see its own stats (uid-based summary,
and details).
Now we allow any process to see other UIDs uid-based stats, but still
hide the detailed stats.
Change-Id: I7666961ed244ac1d9359c339b048799e5db9facc
qtaguid tracks the device stats by monitoring when it goes up and down,
then it gets the dev_stats().
But devs don't correctly report stats (either they don't count headers
symmetrically between rx/tx, or they count internal control messages).
Now qtaguid counts the rx/tx bytes/packets during raw:prerouting and
mangle:postrouting (nat is not available in ipv6).
The results are in
/proc/net/xt_qtaguid/iface_stat_fmt
which outputs a format line (bash expansion):
ifname total_skb_{rx,tx}_{bytes,packets}
Added event counters for pre/post handling.
Added extra ctrl_*() pid/uid debugging.
Change-Id: Id84345d544ad1dd5f63e3842cab229e71d339297
Send notifications when the label becomes active after an idle period.
Send netlink message notifications in addition to sysfs notifications.
Using a uevent with
subsystem=xt_idletimer
INTERFACE=...
STATE={active,inactive}
This is backport from common android-3.0
commit: beb914e987cbbd368988d2b94a6661cb907c4d5a
with uevent support instead of a new netlink message type.
Change-Id: I31677ef00c94b5f82c8457e5bf9e5e584c23c523
When updating the stats for a given uid it would incorrectly assume
IPV4 and pick up the wrong protocol when IPV6.
Change-Id: Iea4a635012b4123bf7aa93809011b7b2040bb3d5
There was a case that might have seemed like new_tag_stat was not
initialized and actually used.
Added comment explaining why it was impossible, and a BUG()
in case the logic gets changed.
Change-Id: I1eddd1b6f754c08a3bf89f7e9427e5dce1dfb081
Since rx_bytes accounting does not include Ethernet Headers in
br_input.c, excluding ETH_HLEN on the transmit path for consistent
measurement of packet length on both the Tx and Rx chains.
The clean way would be for Rx to include the eth header, but the
skb len has already been adjusted by the time the br code sees the skb.
This is only a temporary workaround until we can completely ignore or
cleanly fix the skb->len handling.
Change-Id: I910de95a4686b2119da7f1f326e2154ef31f9972
When calling:
ipv6_find_hdr(skb, &thoff, -1, NULL)
on a fragmented packet, thoff would be left with a random
value causing callers to read random memory offsets with:
skb_header_pointer(skb, thoff, ...)
Now we force ipv6_find_hdr() to return a failure in this case.
Calling:
ipv6_find_hdr(skb, &thoff, -1, &fragoff)
will set fragoff as expected, and not return a failure.
Change-Id: Ib474e8a4267dd2b300feca325811330329684a88
The xt_quota2 came from
http://sourceforge.net/projects/xtables-addons/develop
It needed tweaking for it to compile within the kernel tree.
Fixed kmalloc() and create_proc_entry() invocations within
a non-interruptible context.
Removed useless copying of current quota back to the iptable's
struct matchinfo:
- those are per CPU: they will change randomly based on which
cpu gets to update the value.
- they prevent matching a rule: e.g.
-A chain -m quota2 --name q1 --quota 123
can't be followed by
-D chain -m quota2 --name q1 --quota 123
as the 123 will be compared to the struct matchinfo's quota member.
Use the NETLINK NETLINK_NFLOG family to log a single message
when the quota limit is reached.
It uses the same packet type as ipt_ULOG, but
- never copies skb data,
- uses 112 as the event number (ULOG's +1)
It doesn't log if the module param "event_num" is 0.
Change-Id: I021d3b743db3b22158cc49acb5c94d905b501492
The original xt_quota in the kernel is plain broken:
- counts quota at a per CPU level
(was written back when ubiquitous SMP was just a dream)
- provides no way to count across IPV4/IPV6.
This patch is the original unaltered code from:
at commit e84391ce665cef046967f796dd91026851d6bbf3
Change-Id: I19d49858840effee9ecf6cff03c23b45a97efdeb
Allow the REJECT --reject-with icmp*blabla to also set the matching error
locally on the socket affected by the reject.
This allows the process to see an error almost as if it received it
via ICMP.
It avoids the local process who's ingress packet is rejected to have to
wait for a pseudo-eternity until some timeout kicks in.
Ideally, this should be enabled with a new iptables flag similar to
--reject-with-sock-err
For now it is enabled with CONFIG_IP*_NF_TARGET_REJECT_SKERR option.
Change-Id: I649a4fd5940029ec0b3233e5abb205da6984891e
This module allows tracking stats at the socket level for given UIDs.
It replaces xt_owner.
If the --uid-owner is not specified, it will just count stats based on
who the skb belongs to. This will even happen on incoming skbs as it
looks into the skb via xt_socket magic to see who owns it.
If an skb is lost, it will be assigned to uid=0.
To control what sockets of what UIDs are tagged by what, one uses:
echo t $sock_fd $accounting_tag $the_billed_uid \
> /proc/net/xt_qtaguid/ctrl
So whenever an skb belongs to a sock_fd, it will be accounted against
$the_billed_uid
and matching stats will show up under the uid with the given
$accounting_tag.
Because the number of allocations for the stats structs is not that big:
~500 apps * 32 per app
we'll just do it atomic. This avoids walking lists many times, and
the fancy worker thread handling. Slabs will grow when needed later.
It use netdevice and inetaddr notifications instead of hooks in the core dev
code to track when a device comes and goes. This removes the need for
exposed iface_stat.h.
Put procfs dirs in /proc/net/xt_qtaguid/
ctrl
stats
iface_stat/<iface>/...
The uid stats are obtainable in ./stats.
Change-Id: I01af4fd91c8de651668d3decb76d9bdc1e343919
The socket matching function has some nifty logic to get the struct sock
from the skb or from the connection tracker.
We export this so other xt_* can use it, similarly to ho how
xt_socket uses nf_tproxy_get_sock.
Change-Id: I11c58f59087e7f7ae09e4abd4b937cd3370fa2fd
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
