path: root/net
2018-12-24rfkill-regulator: add dt supportTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 0487f174fa672b60c4fa491b43277b901bcf05d7) (cherry picked from commit 5969e2cf95894901633b48ac61c8fe44dc027b8c)
2018-12-12Merge tag 'v4.9.144' into 4.9-2.3.x-imxMarcel Ziswiler
This is the 4.9.144 stable release
2018-12-08libceph: check authorizer reply/challenge length before readingIlya Dryomov
commit 130f52f2b203aa0aec179341916ffb2e905f3afd upstream. Avoid scribbling over memory if the received reply/challenge is larger than the buffer supplied with the authorizer. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: weaken sizeof check in ceph_x_verify_authorizer_reply()Ilya Dryomov
commit f1d10e04637924f2b00a0fecdd2ca4565f5cfc3f upstream. Allow for extending ceph_x_authorize_reply in the future. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: implement CEPHX_V2 calculation modeIlya Dryomov
commit cc255c76c70f7a87d97939621eae04b600d9f4a1 upstream. Derive the signature from the entire buffer (both AES cipher blocks) instead of using just the first half of the first block, leaving out data_crc entirely. This addresses CVE-2018-1129. Link: http://tracker.ceph.com/issues/24837 Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> [bwh: Backported to 4.9: - Define and test the feature bit in the old way - Don't change any other feature bits in ceph_features.h] Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: add authorizer challengeIlya Dryomov
commit 6daca13d2e72bedaaacfc08f873114c9307d5aea upstream. When a client authenticates with a service, an authorizer is sent with a nonce to the service (ceph_x_authorize_[ab]) and the service responds with a mutation of that nonce (ceph_x_authorize_reply). This lets the client verify the service is who it says it is but it doesn't protect against a replay: someone can trivially capture the exchange and reuse the same authorizer to authenticate themselves. Allow the service to reject an initial authorizer with a random challenge (ceph_x_authorize_challenge). The client then has to respond with an updated authorizer proving they are able to decrypt the service's challenge and that the new authorizer was produced for this specific connection instance. The accepting side requires this challenge and response unconditionally if the client side advertises they have CEPHX_V2 feature bit. This addresses CVE-2018-1128. Link: http://tracker.ceph.com/issues/24836 Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: factor out encrypt_authorizer()Ilya Dryomov
commit 149cac4a50b0b4081b38b2f38de6ef71c27eaa85 upstream. Will be used for encrypting both the initial and updated authorizers. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: factor out __ceph_x_decrypt()Ilya Dryomov
commit c571fe24d243bfe7017f0e67fe800b3cc2a1d1f7 upstream. Will be used for decrypting the server challenge which is only preceded by ceph_x_encrypt_header. Drop struct_v check to allow for extending ceph_x_encrypt_header in the future. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: factor out __prepare_write_connect()Ilya Dryomov
commit c0f56b483aa09c99bfe97409a43ad786f33b8a5a upstream. Will be used for sending ceph_msg_connect with an updated authorizer, after the server challenges the initial authorizer. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: store ceph_auth_handshake pointer in ceph_connectionIlya Dryomov
commit 262614c4294d33b1f19e0d18c0091d9c329b544a upstream. We already copy authorizer_reply_buf and authorizer_reply_buf_len into ceph_connection. Factoring out __prepare_write_connect() requires two more: authorizer_buf and authorizer_buf_len. Store the pointer to the handshake in con->auth rather than piling on. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: no need to drop con->mutex for ->get_authorizer()Ilya Dryomov
commit b3bbd3f2ab19c8ca319003b4b51ce4c4ca74da06 upstream. ->get_authorizer(), ->verify_authorizer_reply(), ->sign_message() and ->check_message_signature() shouldn't be doing anything with or on the connection (like closing it or sending messages). Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08libceph: drop len argument of *verify_authorizer_reply()Ilya Dryomov
commit 0dde584882ade13dc9708d611fbf69b0ae8a9e48 upstream. The length of the reply is protocol-dependent - for cephx it's ceph_x_authorize_reply. Nothing sensible can be passed from the messenger layer anyway. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08tipc: use destination length for copy stringGuoqing Jiang
commit 29e270fc32192e7729057963ae7120663856c93e upstream. Got below warning with gcc 8.2 compiler. net/tipc/topsrv.c: In function ‘tipc_topsrv_start’: net/tipc/topsrv.c:660:2: warning: ‘strncpy’ specified bound depends on the length of the source argument [-Wstringop-overflow=] strncpy(srv->name, name, strlen(name) + 1); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ net/tipc/topsrv.c:660:27: note: length computed here strncpy(srv->name, name, strlen(name) + 1); ^~~~~~~~~~~~ So change it to correct length and use strscpy. Signed-off-by: Guoqing Jiang <gqjiang@suse.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-08ip_tunnel: Fix name string concatenate in __ip_tunnel_create()Sultan Alsawaf
commit 000ade8016400d93b4d7c89970d96b8c14773d45 upstream. By passing a limit of 2 bytes to strncat, strncat is limited to writing fewer bytes than what it's supposed to append to the name here. Since the bounds are checked on the line above this, just remove the string bounds checks entirely since they're unneeded. Signed-off-by: Sultan Alsawaf <sultanxda@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-05net: skb_scrub_packet(): Scrub offload_fwd_markPetr Machata
[ Upstream commit b5dd186d10ba59e6b5ba60e42b3b083df56df6f3 ] When a packet is trapped and the corresponding SKB marked as already-forwarded, it retains this marking even after it is forwarded across veth links into another bridge. There, since it ingresses the bridge over veth, which doesn't have offload_fwd_mark, it triggers a warning in nbp_switchdev_frame_mark(). Then nbp_switchdev_allowed_egress() decides not to allow egress from this bridge through another veth, because the SKB is already marked, and the mark (of 0) of course matches. Thus the packet is incorrectly blocked. Solve by resetting offload_fwd_mark() in skb_scrub_packet(). That function is called from tunnels and also from veth, and thus catches the cases where traffic is forwarded between bridges and transformed in a way that invalidates the marking. Fixes: 6bc506b4fb06 ("bridge: switchdev: Add forward mark support for stacked devices") Fixes: abf4bb6b63d0 ("skbuff: Add the offload_mr_fwd_mark field") Signed-off-by: Petr Machata <petrm@mellanox.com> Suggested-by: Ido Schimmel <idosch@mellanox.com> Acked-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-01net: ieee802154: 6lowpan: fix frag reassemblyAlexander Aring
commit f18fa5de5ba7f1d6650951502bb96a6e4715a948 upstream. This patch initialize stack variables which are used in frag_lowpan_compare_key to zero. In my case there are padding bytes in the structures ieee802154_addr as well in frag_lowpan_compare_key. Otherwise the key variable contains random bytes. The result is that a compare of two keys by memcmp works incorrect. Fixes: 648700f76b03 ("inet: frags: use rhashtables for reassembly units") Signed-off-by: Alexander Aring <aring@mojatatu.com> Reported-by: Stefan Schmidt <stefan@osg.samsung.com> Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-01SUNRPC: Fix a bogus get/put in generic_key_to_expire()Trond Myklebust
[ Upstream commit e3d5e573a54dabdc0f9f3cb039d799323372b251 ] Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-12-01llc: do not use sk_eat_skb()Eric Dumazet
commit 604d415e2bd642b7e02c80e719e0396b9d4a77a6 upstream. syzkaller triggered a use-after-free [1], caused by a combination of skb_get() in llc_conn_state_process() and usage of sk_eat_skb() sk_eat_skb() is assuming the skb about to be freed is only used by the current thread. TCP/DCCP stacks enforce this because current thread holds the socket lock. llc_conn_state_process() wants to make sure skb does not disappear, and holds a reference on the skb it manipulates. But as soon as this skb is added to socket receive queue, another thread can consume it. This means that llc must use regular skb_unlink() and kfree_skb() so that both producer and consumer can safely work on the same skb. [1] BUG: KASAN: use-after-free in atomic_read include/asm-generic/atomic-instrumented.h:21 [inline] BUG: KASAN: use-after-free in refcount_read include/linux/refcount.h:43 [inline] BUG: KASAN: use-after-free in skb_unref include/linux/skbuff.h:967 [inline] BUG: KASAN: use-after-free in kfree_skb+0xb7/0x580 net/core/skbuff.c:655 Read of size 4 at addr ffff8801d1f6fba4 by task ksoftirqd/1/18 CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.19.0-rc8+ #295 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1c4/0x2b6 lib/dump_stack.c:113 print_address_description.cold.8+0x9/0x1ff mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412 check_memory_region_inline mm/kasan/kasan.c:260 [inline] check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267 kasan_check_read+0x11/0x20 mm/kasan/kasan.c:272 atomic_read include/asm-generic/atomic-instrumented.h:21 [inline] refcount_read include/linux/refcount.h:43 [inline] skb_unref include/linux/skbuff.h:967 [inline] kfree_skb+0xb7/0x580 net/core/skbuff.c:655 llc_sap_state_process+0x9b/0x550 net/llc/llc_sap.c:224 llc_sap_rcv+0x156/0x1f0 net/llc/llc_sap.c:297 llc_sap_handler+0x65e/0xf80 net/llc/llc_sap.c:438 llc_rcv+0x79e/0xe20 net/llc/llc_input.c:208 __netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913 __netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023 process_backlog+0x218/0x6f0 net/core/dev.c:5829 napi_poll net/core/dev.c:6249 [inline] net_rx_action+0x7c5/0x1950 net/core/dev.c:6315 __do_softirq+0x30c/0xb03 kernel/softirq.c:292 run_ksoftirqd+0x94/0x100 kernel/softirq.c:653 smpboot_thread_fn+0x68b/0xa00 kernel/smpboot.c:164 kthread+0x35a/0x420 kernel/kthread.c:246 ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:413 Allocated by task 18: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553 kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490 kmem_cache_alloc_node+0x144/0x730 mm/slab.c:3644 __alloc_skb+0x119/0x770 net/core/skbuff.c:193 alloc_skb include/linux/skbuff.h:995 [inline] llc_alloc_frame+0xbc/0x370 net/llc/llc_sap.c:54 llc_station_ac_send_xid_r net/llc/llc_station.c:52 [inline] llc_station_rcv+0x1dc/0x1420 net/llc/llc_station.c:111 llc_rcv+0xc32/0xe20 net/llc/llc_input.c:220 __netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913 __netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023 process_backlog+0x218/0x6f0 net/core/dev.c:5829 napi_poll net/core/dev.c:6249 [inline] net_rx_action+0x7c5/0x1950 net/core/dev.c:6315 __do_softirq+0x30c/0xb03 kernel/softirq.c:292 Freed by task 16383: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] __kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521 kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528 __cache_free mm/slab.c:3498 [inline] kmem_cache_free+0x83/0x290 mm/slab.c:3756 kfree_skbmem+0x154/0x230 net/core/skbuff.c:582 __kfree_skb+0x1d/0x20 net/core/skbuff.c:642 sk_eat_skb include/net/sock.h:2366 [inline] llc_ui_recvmsg+0xec2/0x1610 net/llc/af_llc.c:882 sock_recvmsg_nosec net/socket.c:794 [inline] sock_recvmsg+0xd0/0x110 net/socket.c:801 ___sys_recvmsg+0x2b6/0x680 net/socket.c:2278 __sys_recvmmsg+0x303/0xb90 net/socket.c:2390 do_sys_recvmmsg+0x181/0x1a0 net/socket.c:2466 __do_sys_recvmmsg net/socket.c:2484 [inline] __se_sys_recvmmsg net/socket.c:2480 [inline] __x64_sys_recvmmsg+0xbe/0x150 net/socket.c:2480 do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe The buggy address belongs to the object at ffff8801d1f6fac0 which belongs to the cache skbuff_head_cache of size 232 The buggy address is located 228 bytes inside of 232-byte region [ffff8801d1f6fac0, ffff8801d1f6fba8) The buggy address belongs to the page: page:ffffea000747dbc0 count:1 mapcount:0 mapping:ffff8801d9be7680 index:0xffff8801d1f6fe80 flags: 0x2fffc0000000100(slab) raw: 02fffc0000000100 ffffea0007346e88 ffffea000705b108 ffff8801d9be7680 raw: ffff8801d1f6fe80 ffff8801d1f6f0c0 000000010000000b 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8801d1f6fa80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb ffff8801d1f6fb00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb >ffff8801d1f6fb80: fb fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc ^ ffff8801d1f6fc00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ffff8801d1f6fc80: fb fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-01sctp: clear the transport of some out_chunk_list chunks in sctp_assoc_rm_peerXin Long
commit df132eff463873e14e019a07f387b4d577d6d1f9 upstream. If a transport is removed by asconf but there still are some chunks with this transport queuing on out_chunk_list, later an use-after-free issue will be caused when accessing this transport from these chunks in sctp_outq_flush(). This is an old bug, we fix it by clearing the transport of these chunks in out_chunk_list when removing a transport in sctp_assoc_rm_peer(). Reported-by: syzbot+56a40ceee5fb35932f4d@syzkaller.appspotmail.com Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-27libceph: fall back to sendmsg for slab pagesIlya Dryomov
commit 7e241f647dc7087a0401418a187f3f5b527cc690 upstream. skb_can_coalesce() allows coalescing neighboring slab objects into a single frag: return page == skb_frag_page(frag) && off == frag->page_offset + skb_frag_size(frag); ceph_tcp_sendpage() can be handed slab pages. One example of this is XFS: it passes down sector sized slab objects for its metadata I/O. If the kernel client is co-located on the OSD node, the skb may go through loopback and pop on the receive side with the exact same set of frags. When tcp_recvmsg() attempts to copy out such a frag, hardened usercopy complains because the size exceeds the object's allocated size: usercopy: kernel memory exposure attempt detected from ffff9ba917f20a00 (kmalloc-512) (1024 bytes) Although skb_can_coalesce() could be taught to return false if the resulting frag would cross a slab object boundary, we already have a fallback for non-refcounted pages. Utilize it for slab pages too. Cc: stable@vger.kernel.org # 4.8+ Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-27SUNRPC: drop pointless static qualifier in xdr_get_next_encode_buffer()YueHaibing
[ Upstream commit 025911a5f4e36955498ed50806ad1b02f0f76288 ] There is no need to have the '__be32 *p' variable static since new value always be assigned before use it. Signed-off-by: YueHaibing <yuehaibing@huawei.com> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-27netfilter: xt_IDLETIMER: add sysfs filename checking routineTaehee Yoo
[ Upstream commit 54451f60c8fa061af9051a53be9786393947367c ] When IDLETIMER rule is added, sysfs file is created under /sys/class/xt_idletimer/timers/ But some label name shouldn't be used. ".", "..", "power", "uevent", "subsystem", etc... So that sysfs filename checking routine is needed. test commands: %iptables -I INPUT -j IDLETIMER --timeout 1 --label "power" splat looks like: [95765.423132] sysfs: cannot create duplicate filename '/devices/virtual/xt_idletimer/timers/power' [95765.433418] CPU: 0 PID: 8446 Comm: iptables Not tainted 4.19.0-rc6+ #20 [95765.449755] Call Trace: [95765.449755] dump_stack+0xc9/0x16b [95765.449755] ? show_regs_print_info+0x5/0x5 [95765.449755] sysfs_warn_dup+0x74/0x90 [95765.449755] sysfs_add_file_mode_ns+0x352/0x500 [95765.449755] sysfs_create_file_ns+0x179/0x270 [95765.449755] ? sysfs_add_file_mode_ns+0x500/0x500 [95765.449755] ? idletimer_tg_checkentry+0x3e5/0xb1b [xt_IDLETIMER] [95765.449755] ? rcu_read_lock_sched_held+0x114/0x130 [95765.449755] ? __kmalloc_track_caller+0x211/0x2b0 [95765.449755] ? memcpy+0x34/0x50 [95765.449755] idletimer_tg_checkentry+0x4e2/0xb1b [xt_IDLETIMER] [ ... ] Fixes: 0902b469bd25 ("netfilter: xtables: idletimer target implementation") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-27netfilter: ipset: actually allow allowable CIDR 0 in hash:net,port,netEric Westbrook
[ Upstream commit 886503f34d63e681662057448819edb5b1057a97 ] Allow /0 as advertised for hash:net,port,net sets. For "hash:net,port,net", ipset(8) says that "either subnet is permitted to be a /0 should you wish to match port between all destinations." Make that statement true. Before: # ipset create cidrzero hash:net,port,net # ipset add cidrzero 0.0.0.0/0,12345,0.0.0.0/0 ipset v6.34: The value of the CIDR parameter of the IP address is invalid # ipset create cidrzero6 hash:net,port,net family inet6 # ipset add cidrzero6 ::/0,12345,::/0 ipset v6.34: The value of the CIDR parameter of the IP address is invalid After: # ipset create cidrzero hash:net,port,net # ipset add cidrzero 0.0.0.0/0,12345,0.0.0.0/0 # ipset test cidrzero 192.168.205.129,12345,172.16.205.129 192.168.205.129,tcp:12345,172.16.205.129 is in set cidrzero. # ipset create cidrzero6 hash:net,port,net family inet6 # ipset add cidrzero6 ::/0,12345,::/0 # ipset test cidrzero6 fe80::1,12345,ff00::1 fe80::1,tcp:12345,ff00::1 is in set cidrzero6. See also: https://bugzilla.kernel.org/show_bug.cgi?id=200897 https://github.com/ewestbrook/linux/commit/df7ff6efb0934ab6acc11f003ff1a7580d6c1d9c Signed-off-by: Eric Westbrook <linux@westbrook.io> Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-23Revert "ipv6: set rt6i_protocol properly in the route when it is installed"Greg Kroah-Hartman
This reverts commit 23e983e27aaff6357bb851d91b593d83a9a6552c which is commit b91d532928dff2141ea9c107c3e73104d9843767 upstream. It breaks the Android networking test suite, which works fine with the backported patch in 4.14. So something must be off for 4.9 for this patch, so just revert it. Cc: Jianlin Shi <jishi@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Xin Long <lucien.xin@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-23ipv6: Fix PMTU updates for UDP/raw sockets in presence of VRFDavid Ahern
[ Upstream commit 7ddacfa564870cdd97275fd87decb6174abc6380 ] Preethi reported that PMTU discovery for UDP/raw applications is not working in the presence of VRF when the socket is not bound to a device. The problem is that ip6_sk_update_pmtu does not consider the L3 domain of the skb device if the socket is not bound. Update the function to set oif to the L3 master device if relevant. Fixes: ca254490c8df ("net: Add VRF support to IPv6 stack") Reported-by: Preethi Ramachandra <preethir@juniper.net> Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-23inet: frags: better deal with smp racesEric Dumazet
[ Upstream commit 0d5b9311baf27bb545f187f12ecfd558220c607d ] Multiple cpus might attempt to insert a new fragment in rhashtable, if for example RPS is buggy, as reported by 배석진 in https://patchwork.ozlabs.org/patch/994601/ We use rhashtable_lookup_get_insert_key() instead of rhashtable_insert_fast() to let cpus losing the race free their own inet_frag_queue and use the one that was inserted by another cpu. Fixes: 648700f76b03 ("inet: frags: use rhashtables for reassembly units") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: 배석진 <soukjin.bae@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-23sctp: not allow to set asoc prsctp_enable by sockoptXin Long
[ Upstream commit cc3ccf26f0649089b3a34a2781977755ea36e72c ] As rfc7496#section4.5 says about SCTP_PR_SUPPORTED: This socket option allows the enabling or disabling of the negotiation of PR-SCTP support for future associations. For existing associations, it allows one to query whether or not PR-SCTP support was negotiated on a particular association. It means only sctp sock's prsctp_enable can be set. Note that for the limitation of SCTP_{CURRENT|ALL}_ASSOC, we will add it when introducing SCTP_{FUTURE|CURRENT|ALL}_ASSOC for linux sctp in another patchset. v1->v2: - drop the params.assoc_id check as Neil suggested. Fixes: 28aa4c26fce2 ("sctp: add SCTP_PR_SUPPORTED on sctp sockopt") Reported-by: Ying Xu <yinxu@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-23net-gro: reset skb->pkt_type in napi_reuse_skb()Eric Dumazet
[ Upstream commit 33d9a2c72f086cbf1087b2fd2d1a15aa9df14a7f ] eth_type_trans() assumes initial value for skb->pkt_type is PACKET_HOST. This is indeed the value right after a fresh skb allocation. However, it is possible that GRO merged a packet with a different value (like PACKET_OTHERHOST in case macvlan is used), so we need to make sure napi->skb will have pkt_type set back to PACKET_HOST. Otherwise, valid packets might be dropped by the stack because their pkt_type is not PACKET_HOST. napi_reuse_skb() was added in commit 96e93eab2033 ("gro: Add internal interfaces for VLAN"), but this bug always has been there. Fixes: 96e93eab2033 ("gro: Add internal interfaces for VLAN") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-23ip_tunnel: don't force DF when MTU is lockedSabrina Dubroca
[ Upstream commit 16f7eb2b77b55da816c4e207f3f9440a8cafc00a ] The various types of tunnels running over IPv4 can ask to set the DF bit to do PMTU discovery. However, PMTU discovery is subject to the threshold set by the net.ipv4.route.min_pmtu sysctl, and is also disabled on routes with "mtu lock". In those cases, we shouldn't set the DF bit. This patch makes setting the DF bit conditional on the route's MTU locking state. This issue seems to be older than git history. Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reviewed-by: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-23flow_dissector: do not dissect l4 ports for fragments배석진
[ Upstream commit 62230715fd2453b3ba948c9d83cfb3ada9169169 ] Only first fragment has the sport/dport information, not the following ones. If we want consistent hash for all fragments, we need to ignore ports even for first fragment. This bug is visible for IPv6 traffic, if incoming fragments do not have a flow label, since skb_get_hash() will give different results for first fragment and following ones. It is also visible if any routing rule wants dissection and sport or dport. See commit 5e5d6fed3741 ("ipv6: route: dissect flow in input path if fib rules need it") for details. [edumazet] rewrote the changelog completely. Fixes: 06635a35d13d ("flow_dissect: use programable dissector in skb_flow_dissect and friends") Signed-off-by: 배석진 <soukjin.bae@samsung.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-21sunrpc: correct the computation for page_ptr when truncatingFrank Sorenson
commit 5d7a5bcb67c70cbc904057ef52d3fcfeb24420bb upstream. When truncating the encode buffer, the page_ptr is getting advanced, causing the next page to be skipped while encoding. The page is still included in the response, so the response contains a page of bogus data. We need to adjust the page_ptr backwards to ensure we encode the next page into the correct place. We saw this triggered when concurrent directory modifications caused nfsd4_encode_direct_fattr() to return nfserr_noent, and the resulting call to xdr_truncate_encode() corrupted the READDIR reply. Signed-off-by: Frank Sorenson <sorenson@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-21netfilter: conntrack: fix calculation of next bucket number in early_dropVasily Khoruzhick
commit f393808dc64149ccd0e5a8427505ba2974a59854 upstream. If there's no entry to drop in bucket that corresponds to the hash, early_drop() should look for it in other buckets. But since it increments hash instead of bucket number, it actually looks in the same bucket 8 times: hsize is 16k by default (14 bits) and hash is 32-bit value, so reciprocal_scale(hash, hsize) returns the same value for hash..hash+7 in most cases. Fix it by increasing bucket number instead of hash and rename _hash to bucket to avoid future confusion. Fixes: 3e86638e9a0b ("netfilter: conntrack: consider ct netns in early_drop logic") Cc: <stable@vger.kernel.org> # v4.7+ Signed-off-by: Vasily Khoruzhick <vasilykh@arista.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-219p: clear dangling pointers in p9stat_freeDominique Martinet
[ Upstream commit 62e3941776fea8678bb8120607039410b1b61a65 ] p9stat_free is more of a cleanup function than a 'free' function as it only frees the content of the struct; there are chances of use-after-free if it is improperly used (e.g. p9stat_free called twice as it used to be possible to) Clearing dangling pointers makes the function idempotent and safer to use. Link: http://lkml.kernel.org/r/1535410108-20650-2-git-send-email-asmadeus@codewreck.org Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr> Reported-by: syzbot+d4252148d198410b864f@syzkaller.appspotmail.com Signed-off-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13nfsd: Fix an Oops in free_session()Trond Myklebust
commit bb6ad5572c0022e17e846b382d7413cdcf8055be upstream. In call_xpt_users(), we delete the entry from the list, but we do not reinitialise it. This triggers the list poisoning when we later call unregister_xpt_user() in nfsd4_del_conns(). Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13net/ipv4: defensive cipso option parsingStefan Nuernberger
commit 076ed3da0c9b2f88d9157dbe7044a45641ae369e upstream. commit 40413955ee26 ("Cipso: cipso_v4_optptr enter infinite loop") fixed a possible infinite loop in the IP option parsing of CIPSO. The fix assumes that ip_options_compile filtered out all zero length options and that no other one-byte options beside IPOPT_END and IPOPT_NOOP exist. While this assumption currently holds true, add explicit checks for zero length and invalid length options to be safe for the future. Even though ip_options_compile should have validated the options, the introduction of new one-byte options can still confuse this code without the additional checks. Signed-off-by: Stefan Nuernberger <snu@amazon.com> Cc: David Woodhouse <dwmw@amazon.co.uk> Cc: Simon Veith <sveith@amazon.de> Cc: stable@vger.kernel.org Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13cgroup, netclassid: add a preemption point to write_classidMichal Hocko
[ Upstream commit a90e90b7d55e789c71d85b946ffb5c1ab2f137ca ] We have seen a customer complaining about soft lockups on !PREEMPT kernel config with 4.4 based kernel [1072141.435366] NMI watchdog: BUG: soft lockup - CPU#21 stuck for 22s! [systemd:1] [1072141.444090] Modules linked in: mpt3sas raid_class binfmt_misc af_packet 8021q garp mrp stp llc xfs libcrc32c bonding iscsi_ibft iscsi_boot_sysfs msr ext4 crc16 jbd2 mbcache cdc_ether usbnet mii joydev hid_generic usbhid intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp crct10dif_pclmul crc32_pclmul ghash_clmulni_intel ipmi_ssif mgag200 i2c_algo_bit ttm ipmi_devintf drbg ixgbe drm_kms_helper vxlan ansi_cprng ip6_udp_tunnel drm aesni_intel udp_tunnel aes_x86_64 iTCO_wdt syscopyarea ptp xhci_pci lrw iTCO_vendor_support pps_core gf128mul ehci_pci glue_helper sysfillrect mdio pcspkr sb_edac ablk_helper cryptd ehci_hcd sysimgblt xhci_hcd fb_sys_fops edac_core mei_me lpc_ich ses usbcore enclosure dca mfd_core ipmi_si mei i2c_i801 scsi_transport_sas usb_common ipmi_msghandler shpchp fjes wmi processor button acpi_pad btrfs xor raid6_pq sd_mod crc32c_intel megaraid_sas sg dm_multipath dm_mod scsi_dh_rdac scsi_dh_emc scsi_dh_alua scsi_mod md_mod autofs4 [1072141.444146] Supported: Yes [1072141.444149] CPU: 21 PID: 1 Comm: systemd Not tainted 4.4.121-92.80-default #1 [1072141.444150] Hardware name: LENOVO Lenovo System x3650 M5 -[5462P4U]- -[5462P4U]-/01GR451, BIOS -[TCE136H-2.70]- 06/13/2018 [1072141.444151] task: ffff880191bd0040 ti: ffff880191bd4000 task.ti: ffff880191bd4000 [1072141.444153] RIP: 0010:[<ffffffff815229f9>] [<ffffffff815229f9>] update_classid_sock+0x29/0x40 [1072141.444157] RSP: 0018:ffff880191bd7d58 EFLAGS: 00000286 [1072141.444158] RAX: ffff883b177cb7c0 RBX: 0000000000000000 RCX: 0000000000000000 [1072141.444159] RDX: 00000000000009c7 RSI: ffff880191bd7d5c RDI: ffff8822e29bb200 [1072141.444160] RBP: ffff883a72230980 R08: 0000000000000101 R09: 0000000000000000 [1072141.444161] R10: 0000000000000008 R11: f000000000000000 R12: ffffffff815229d0 [1072141.444162] R13: 0000000000000000 R14: ffff881fd0a47ac0 R15: ffff880191bd7f28 [1072141.444163] FS: 00007f3e2f1eb8c0(0000) GS:ffff882000340000(0000) knlGS:0000000000000000 [1072141.444164] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [1072141.444165] CR2: 00007f3e2f200000 CR3: 0000001ffea4e000 CR4: 00000000001606f0 [1072141.444166] Stack: [1072141.444166] ffffffa800000246 00000000000009c7 ffffffff8121d583 ffff8818312a05c0 [1072141.444168] ffff8818312a1100 ffff880197c3b280 ffff881861422858 ffffffffffffffea [1072141.444170] ffffffff81522b1c ffffffff81d0ca20 ffff8817fa17b950 ffff883fdd8121e0 [1072141.444171] Call Trace: [1072141.444179] [<ffffffff8121d583>] iterate_fd+0x53/0x80 [1072141.444182] [<ffffffff81522b1c>] write_classid+0x4c/0x80 [1072141.444187] [<ffffffff8111328b>] cgroup_file_write+0x9b/0x100 [1072141.444193] [<ffffffff81278bcb>] kernfs_fop_write+0x11b/0x150 [1072141.444198] [<ffffffff81201566>] __vfs_write+0x26/0x100 [1072141.444201] [<ffffffff81201bed>] vfs_write+0x9d/0x190 [1072141.444203] [<ffffffff812028c2>] SyS_write+0x42/0xa0 [1072141.444207] [<ffffffff815f58c3>] entry_SYSCALL_64_fastpath+0x1e/0xca [1072141.445490] DWARF2 unwinder stuck at entry_SYSCALL_64_fastpath+0x1e/0xca If a cgroup has many tasks with many open file descriptors then we would end up in a large loop without any rescheduling point throught the operation. Add cond_resched once per task. Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-13xfrm: policy: use hlist rcu variants on insertFlorian Westphal
[ Upstream commit 9dffff200fd178f11dd50eb1fd8ccd0650c9284e ] bydst table/list lookups use rcu, so insertions must use rcu versions. Fixes: a7c44247f704e ("xfrm: policy: make xfrm_policy_lookup_bytype lockless") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <sashal@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10ip6_tunnel: Fix encapsulation layoutStefano Brivio
[ Upstream commit d4d576f5ab7edcb757bb33e6a5600666a0b1232d ] Commit 058214a4d1df ("ip6_tun: Add infrastructure for doing encapsulation") added the ip6_tnl_encap() call in ip6_tnl_xmit(), before the call to ipv6_push_frag_opts() to append the IPv6 Tunnel Encapsulation Limit option (option 4, RFC 2473, par. 5.1) to the outer IPv6 header. As long as the option didn't actually end up in generated packets, this wasn't an issue. Then commit 89a23c8b528b ("ip6_tunnel: Fix missing tunnel encapsulation limit option") fixed sending of this option, and the resulting layout, e.g. for FoU, is: .-------------------.------------.----------.-------------------.----- - - | Outer IPv6 Header | UDP header | Option 4 | Inner IPv6 Header | Payload '-------------------'------------'----------'-------------------'----- - - Needless to say, FoU and GUE (at least) won't work over IPv6. The option is appended by default, and I couldn't find a way to disable it with the current iproute2. Turn this into a more reasonable: .-------------------.----------.------------.-------------------.----- - - | Outer IPv6 Header | Option 4 | UDP header | Inner IPv6 Header | Payload '-------------------'----------'------------'-------------------'----- - - With this, and with 84dad55951b0 ("udp6: fix encap return code for resubmitting"), FoU and GUE work again over IPv6. Fixes: 058214a4d1df ("ip6_tun: Add infrastructure for doing encapsulation") Signed-off-by: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10rtnetlink: Disallow FDB configuration for non-Ethernet deviceIdo Schimmel
[ Upstream commit da71577545a52be3e0e9225a946e5fd79cfab015 ] When an FDB entry is configured, the address is validated to have the length of an Ethernet address, but the device for which the address is configured can be of any type. The above can result in the use of uninitialized memory when the address is later compared against existing addresses since 'dev->addr_len' is used and it may be greater than ETH_ALEN, as with ip6tnl devices. Fix this by making sure that FDB entries are only configured for Ethernet devices. BUG: KMSAN: uninit-value in memcmp+0x11d/0x180 lib/string.c:863 CPU: 1 PID: 4318 Comm: syz-executor998 Not tainted 4.19.0-rc3+ #49 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x14b/0x190 lib/dump_stack.c:113 kmsan_report+0x183/0x2b0 mm/kmsan/kmsan.c:956 __msan_warning+0x70/0xc0 mm/kmsan/kmsan_instr.c:645 memcmp+0x11d/0x180 lib/string.c:863 dev_uc_add_excl+0x165/0x7b0 net/core/dev_addr_lists.c:464 ndo_dflt_fdb_add net/core/rtnetlink.c:3463 [inline] rtnl_fdb_add+0x1081/0x1270 net/core/rtnetlink.c:3558 rtnetlink_rcv_msg+0xa0b/0x1530 net/core/rtnetlink.c:4715 netlink_rcv_skb+0x36e/0x5f0 net/netlink/af_netlink.c:2454 rtnetlink_rcv+0x50/0x60 net/core/rtnetlink.c:4733 netlink_unicast_kernel net/netlink/af_netlink.c:1317 [inline] netlink_unicast+0x1638/0x1720 net/netlink/af_netlink.c:1343 netlink_sendmsg+0x1205/0x1290 net/netlink/af_netlink.c:1908 sock_sendmsg_nosec net/socket.c:621 [inline] sock_sendmsg net/socket.c:631 [inline] ___sys_sendmsg+0xe70/0x1290 net/socket.c:2114 __sys_sendmsg net/socket.c:2152 [inline] __do_sys_sendmsg net/socket.c:2161 [inline] __se_sys_sendmsg+0x2a3/0x3d0 net/socket.c:2159 __x64_sys_sendmsg+0x4a/0x70 net/socket.c:2159 do_syscall_64+0xb8/0x100 arch/x86/entry/common.c:291 entry_SYSCALL_64_after_hwframe+0x63/0xe7 RIP: 0033:0x440ee9 Code: e8 cc ab 02 00 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 bb 0a fc ff c3 66 2e 0f 1f 84 00 00 00 00 RSP: 002b:00007fff6a93b518 EFLAGS: 00000213 ORIG_RAX: 000000000000002e RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 0000000000440ee9 RDX: 0000000000000000 RSI: 0000000020000240 RDI: 0000000000000003 RBP: 0000000000000000 R08: 00000000004002c8 R09: 00000000004002c8 R10: 00000000004002c8 R11: 0000000000000213 R12: 000000000000b4b0 R13: 0000000000401ec0 R14: 0000000000000000 R15: 0000000000000000 Uninit was created at: kmsan_save_stack_with_flags mm/kmsan/kmsan.c:256 [inline] kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:181 kmsan_kmalloc+0x98/0x100 mm/kmsan/kmsan_hooks.c:91 kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan_hooks.c:100 slab_post_alloc_hook mm/slab.h:446 [inline] slab_alloc_node mm/slub.c:2718 [inline] __kmalloc_node_track_caller+0x9e7/0x1160 mm/slub.c:4351 __kmalloc_reserve net/core/skbuff.c:138 [inline] __alloc_skb+0x2f5/0x9e0 net/core/skbuff.c:206 alloc_skb include/linux/skbuff.h:996 [inline] netlink_alloc_large_skb net/netlink/af_netlink.c:1189 [inline] netlink_sendmsg+0xb49/0x1290 net/netlink/af_netlink.c:1883 sock_sendmsg_nosec net/socket.c:621 [inline] sock_sendmsg net/socket.c:631 [inline] ___sys_sendmsg+0xe70/0x1290 net/socket.c:2114 __sys_sendmsg net/socket.c:2152 [inline] __do_sys_sendmsg net/socket.c:2161 [inline] __se_sys_sendmsg+0x2a3/0x3d0 net/socket.c:2159 __x64_sys_sendmsg+0x4a/0x70 net/socket.c:2159 do_syscall_64+0xb8/0x100 arch/x86/entry/common.c:291 entry_SYSCALL_64_after_hwframe+0x63/0xe7 v2: * Make error message more specific (David) Fixes: 090096bf3db1 ("net: generic fdb support for drivers without ndo_fdb_<op>") Signed-off-by: Ido Schimmel <idosch@mellanox.com> Reported-and-tested-by: syzbot+3a288d5f5530b901310e@syzkaller.appspotmail.com Reported-and-tested-by: syzbot+d53ab4e92a1db04110ff@syzkaller.appspotmail.com Cc: Vlad Yasevich <vyasevich@gmail.com> Cc: David Ahern <dsahern@gmail.com> Reviewed-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10net: fix pskb_trim_rcsum_slow() with odd trim offsetDimitris Michailidis
[ Upstream commit d55bef5059dd057bd077155375c581b49d25be7e ] We've been getting checksum errors involving small UDP packets, usually 59B packets with 1 extra non-zero padding byte. netdev_rx_csum_fault() has been complaining that HW is providing bad checksums. Turns out the problem is in pskb_trim_rcsum_slow(), introduced in commit 88078d98d1bb ("net: pskb_trim_rcsum() and CHECKSUM_COMPLETE are friends"). The source of the problem is that when the bytes we are trimming start at an odd address, as in the case of the 1 padding byte above, skb_checksum() returns a byte-swapped value. We cannot just combine this with skb->csum using csum_sub(). We need to use csum_block_sub() here that takes into account the parity of the start address and handles the swapping. Matches existing code in __skb_postpull_rcsum() and esp_remove_trailer(). Fixes: 88078d98d1bb ("net: pskb_trim_rcsum() and CHECKSUM_COMPLETE are friends") Signed-off-by: Dimitris Michailidis <dmichail@google.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10net: drop skb on failure in ip_check_defrag()Cong Wang
[ Upstream commit 7de414a9dd91426318df7b63da024b2b07e53df5 ] Most callers of pskb_trim_rcsum() simply drop the skb when it fails, however, ip_check_defrag() still continues to pass the skb up to stack. This is suspicious. In ip_check_defrag(), after we learn the skb is an IP fragment, passing the skb to callers makes no sense, because callers expect fragments are defrag'ed on success. So, dropping the skb when we can't defrag it is reasonable. Note, prior to commit 88078d98d1bb, this is not a big problem as checksum will be fixed up anyway. After it, the checksum is not correct on failure. Found this during code review. Fixes: 88078d98d1bb ("net: pskb_trim_rcsum() and CHECKSUM_COMPLETE are friends") Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10ethtool: fix a privilege escalation bugWenwen Wang
[ Upstream commit 58f5bbe331c566f49c9559568f982202a278aa78 ] In dev_ethtool(), the eth command 'ethcmd' is firstly copied from the use-space buffer 'useraddr' and checked to see whether it is ETHTOOL_PERQUEUE. If yes, the sub-command 'sub_cmd' is further copied from the user space. Otherwise, 'sub_cmd' is the same as 'ethcmd'. Next, according to 'sub_cmd', a permission check is enforced through the function ns_capable(). For example, the permission check is required if 'sub_cmd' is ETHTOOL_SCOALESCE, but it is not necessary if 'sub_cmd' is ETHTOOL_GCOALESCE, as suggested in the comment "Allow some commands to be done by anyone". The following execution invokes different handlers according to 'ethcmd'. Specifically, if 'ethcmd' is ETHTOOL_PERQUEUE, ethtool_set_per_queue() is called. In ethtool_set_per_queue(), the kernel object 'per_queue_opt' is copied again from the user-space buffer 'useraddr' and 'per_queue_opt.sub_command' is used to determine which operation should be performed. Given that the buffer 'useraddr' is in the user space, a malicious user can race to change the sub-command between the two copies. In particular, the attacker can supply ETHTOOL_PERQUEUE and ETHTOOL_GCOALESCE to bypass the permission check in dev_ethtool(). Then before ethtool_set_per_queue() is called, the attacker changes ETHTOOL_GCOALESCE to ETHTOOL_SCOALESCE. In this way, the attacker can bypass the permission check and execute ETHTOOL_SCOALESCE. This patch enforces a check in ethtool_set_per_queue() after the second copy from 'useraddr'. If the sub-command is different from the one obtained in the first copy in dev_ethtool(), an error code EINVAL will be returned. Fixes: f38d138a7da6 ("net/ethtool: support set coalesce per queue") Signed-off-by: Wenwen Wang <wang6495@umn.edu> Reviewed-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10sctp: fix race on sctp_id2asocMarcelo Ricardo Leitner
[ Upstream commit b336decab22158937975293aea79396525f92bb3 ] syzbot reported an use-after-free involving sctp_id2asoc. Dmitry Vyukov helped to root cause it and it is because of reading the asoc after it was freed: CPU 1 CPU 2 (working on socket 1) (working on socket 2) sctp_association_destroy sctp_id2asoc spin lock grab the asoc from idr spin unlock spin lock remove asoc from idr spin unlock free(asoc) if asoc->base.sk != sk ... [*] This can only be hit if trying to fetch asocs from different sockets. As we have a single IDR for all asocs, in all SCTP sockets, their id is unique on the system. An application can try to send stuff on an id that matches on another socket, and the if in [*] will protect from such usage. But it didn't consider that as that asoc may belong to another socket, it may be freed in parallel (read: under another socket lock). We fix it by moving the checks in [*] into the protected region. This fixes it because the asoc cannot be freed while the lock is held. Reported-by: syzbot+c7dd55d7aec49d48e49a@syzkaller.appspotmail.com Acked-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10net: udp: fix handling of CHECKSUM_COMPLETE packetsSean Tranchetti
[ Upstream commit db4f1be3ca9b0ef7330763d07bf4ace83ad6f913 ] Current handling of CHECKSUM_COMPLETE packets by the UDP stack is incorrect for any packet that has an incorrect checksum value. udp4/6_csum_init() will both make a call to __skb_checksum_validate_complete() to initialize/validate the csum field when receiving a CHECKSUM_COMPLETE packet. When this packet fails validation, skb->csum will be overwritten with the pseudoheader checksum so the packet can be fully validated by software, but the skb->ip_summed value will be left as CHECKSUM_COMPLETE so that way the stack can later warn the user about their hardware spewing bad checksums. Unfortunately, leaving the SKB in this state can cause problems later on in the checksum calculation. Since the the packet is still marked as CHECKSUM_COMPLETE, udp_csum_pull_header() will SUBTRACT the checksum of the UDP header from skb->csum instead of adding it, leaving us with a garbage value in that field. Once we try to copy the packet to userspace in the udp4/6_recvmsg(), we'll make a call to skb_copy_and_csum_datagram_msg() to checksum the packet data and add it in the garbage skb->csum value to perform our final validation check. Since the value we're validating is not the proper checksum, it's possible that the folded value could come out to 0, causing us not to drop the packet. Instead, we believe that the packet was checksummed incorrectly by hardware since skb->ip_summed is still CHECKSUM_COMPLETE, and we attempt to warn the user with netdev_rx_csum_fault(skb->dev); Unfortunately, since this is the UDP path, skb->dev has been overwritten by skb->dev_scratch and is no longer a valid pointer, so we end up reading invalid memory. This patch addresses this problem in two ways: 1) Do not use the dev pointer when calling netdev_rx_csum_fault() from skb_copy_and_csum_datagram_msg(). Since this gets called from the UDP path where skb->dev has been overwritten, we have no way of knowing if the pointer is still valid. Also for the sake of consistency with the other uses of netdev_rx_csum_fault(), don't attempt to call it if the packet was checksummed by software. 2) Add better CHECKSUM_COMPLETE handling to udp4/6_csum_init(). If we receive a packet that's CHECKSUM_COMPLETE that fails verification (i.e. skb->csum_valid == 0), check who performed the calculation. It's possible that the checksum was done in software by the network stack earlier (such as Netfilter's CONNTRACK module), and if that says the checksum is bad, we can drop the packet immediately instead of waiting until we try and copy it to userspace. Otherwise, we need to mark the SKB as CHECKSUM_NONE, since the skb->csum field no longer contains the full packet checksum after the call to __skb_checksum_validate_complete(). Fixes: e6afc8ace6dd ("udp: remove headers from UDP packets before queueing") Fixes: c84d949057ca ("udp: copy skb->truesize in the first cache line") Cc: Sam Kumar <samanthakumar@google.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Sean Tranchetti <stranche@codeaurora.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10net: socket: fix a missing-check bugWenwen Wang
[ Upstream commit b6168562c8ce2bd5a30e213021650422e08764dc ] In ethtool_ioctl(), the ioctl command 'ethcmd' is checked through a switch statement to see whether it is necessary to pre-process the ethtool structure, because, as mentioned in the comment, the structure ethtool_rxnfc is defined with padding. If yes, a user-space buffer 'rxnfc' is allocated through compat_alloc_user_space(). One thing to note here is that, if 'ethcmd' is ETHTOOL_GRXCLSRLALL, the size of the buffer 'rxnfc' is partially determined by 'rule_cnt', which is actually acquired from the user-space buffer 'compat_rxnfc', i.e., 'compat_rxnfc->rule_cnt', through get_user(). After 'rxnfc' is allocated, the data in the original user-space buffer 'compat_rxnfc' is then copied to 'rxnfc' through copy_in_user(), including the 'rule_cnt' field. However, after this copy, no check is re-enforced on 'rxnfc->rule_cnt'. So it is possible that a malicious user race to change the value in the 'compat_rxnfc->rule_cnt' between these two copies. Through this way, the attacker can bypass the previous check on 'rule_cnt' and inject malicious data. This can cause undefined behavior of the kernel and introduce potential security risk. This patch avoids the above issue via copying the value acquired by get_user() to 'rxnfc->rule_cn', if 'ethcmd' is ETHTOOL_GRXCLSRLALL. Signed-off-by: Wenwen Wang <wang6495@umn.edu> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10net: sched: gred: pass the right attribute to gred_change_table_def()Jakub Kicinski
[ Upstream commit 38b4f18d56372e1e21771ab7b0357b853330186c ] gred_change_table_def() takes a pointer to TCA_GRED_DPS attribute, and expects it will be able to interpret its contents as struct tc_gred_sopt. Pass the correct gred attribute, instead of TCA_OPTIONS. This bug meant the table definition could never be changed after Qdisc was initialized (unless whatever TCA_OPTIONS contained both passed netlink validation and was a valid struct tc_gred_sopt...). Old behaviour: $ ip link add type dummy $ tc qdisc replace dev dummy0 parent root handle 7: \ gred setup vqs 4 default 0 $ tc qdisc replace dev dummy0 parent root handle 7: \ gred setup vqs 4 default 0 RTNETLINK answers: Invalid argument Now: $ ip link add type dummy $ tc qdisc replace dev dummy0 parent root handle 7: \ gred setup vqs 4 default 0 $ tc qdisc replace dev dummy0 parent root handle 7: \ gred setup vqs 4 default 0 $ tc qdisc replace dev dummy0 parent root handle 7: \ gred setup vqs 4 default 0 Fixes: f62d6b936df5 ("[PKT_SCHED]: GRED: Use central VQ change procedure") Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10net/ipv6: Fix index counter for unicast addresses in in6_dump_addrsDavid Ahern
[ Upstream commit 4ba4c566ba8448a05e6257e0b98a21f1a0d55315 ] The loop wants to skip previously dumped addresses, so loops until current index >= saved index. If the message fills it wants to save the index for the next address to dump - ie., the one that did not fit in the current message. Currently, it is incrementing the index counter before comparing to the saved index, and then the saved index is off by 1 - it assumes the current address is going to fit in the message. Change the index handling to increment only after a succesful dump. Fixes: 502a2ffd7376a ("ipv6: convert idev_list to list macros") Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10llc: set SOCK_RCU_FREE in llc_sap_add_socket()Cong Wang
[ Upstream commit 5a8e7aea953bdb6d4da13aff6f1e7f9c62023499 ] WHen an llc sock is added into the sk_laddr_hash of an llc_sap, it is not marked with SOCK_RCU_FREE. This causes that the sock could be freed while it is still being read by __llc_lookup_established() with RCU read lock. sock is refcounted, but with RCU read lock, nothing prevents the readers getting a zero refcnt. Fix it by setting SOCK_RCU_FREE in llc_sap_add_socket(). Reported-by: syzbot+11e05f04c15e03be5254@syzkaller.appspotmail.com Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10ipv6/ndisc: Preserve IPv6 control buffer if protocol error handlers are calledStefano Brivio
[ Upstream commit ee1abcf689353f36d9322231b4320926096bdee0 ] Commit a61bbcf28a8c ("[NET]: Store skb->timestamp as offset to a base timestamp") introduces a neighbour control buffer and zeroes it out in ndisc_rcv(), as ndisc_recv_ns() uses it. Commit f2776ff04722 ("[IPV6]: Fix address/interface handling in UDP and DCCP, according to the scoping architecture.") introduces the usage of the IPv6 control buffer in protocol error handlers (e.g. inet6_iif() in present-day __udp6_lib_err()). Now, with commit b94f1c0904da ("ipv6: Use icmpv6_notify() to propagate redirect, instead of rt6_redirect()."), we call protocol error handlers from ndisc_redirect_rcv(), after the control buffer is already stolen and some parts are already zeroed out. This implies that inet6_iif() on this path will always return zero. This gives unexpected results on UDP socket lookup in __udp6_lib_err(), as we might actually need to match sockets for a given interface. Instead of always claiming the control buffer in ndisc_rcv(), do that only when needed. Fixes: b94f1c0904da ("ipv6: Use icmpv6_notify() to propagate redirect, instead of rt6_redirect().") Signed-off-by: Stefano Brivio <sbrivio@redhat.com> Reviewed-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-11-10ipv6: mcast: fix a use-after-free in inet6_mc_checkEric Dumazet
[ Upstream commit dc012f3628eaecfb5ba68404a5c30ef501daf63d ] syzbot found a use-after-free in inet6_mc_check [1] The problem here is that inet6_mc_check() uses rcu and read_lock(&iml->sflock) So the fact that ip6_mc_leave_src() is called under RTNL and the socket lock does not help us, we need to acquire iml->sflock in write mode. In the future, we should convert all this stuff to RCU. [1] BUG: KASAN: use-after-free in ipv6_addr_equal include/net/ipv6.h:521 [inline] BUG: KASAN: use-after-free in inet6_mc_check+0xae7/0xb40 net/ipv6/mcast.c:649 Read of size 8 at addr ffff8801ce7f2510 by task syz-executor0/22432 CPU: 1 PID: 22432 Comm: syz-executor0 Not tainted 4.19.0-rc7+ #280 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0x1c4/0x2b4 lib/dump_stack.c:113 print_address_description.cold.8+0x9/0x1ff mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:354 [inline] kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412 __asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433 ipv6_addr_equal include/net/ipv6.h:521 [inline] inet6_mc_check+0xae7/0xb40 net/ipv6/mcast.c:649 __raw_v6_lookup+0x320/0x3f0 net/ipv6/raw.c:98 ipv6_raw_deliver net/ipv6/raw.c:183 [inline] raw6_local_deliver+0x3d3/0xcb0 net/ipv6/raw.c:240 ip6_input_finish+0x467/0x1aa0 net/ipv6/ip6_input.c:345 NF_HOOK include/linux/netfilter.h:289 [inline] ip6_input+0xe9/0x600 net/ipv6/ip6_input.c:426 ip6_mc_input+0x48a/0xd20 net/ipv6/ip6_input.c:503 dst_input include/net/dst.h:450 [inline] ip6_rcv_finish+0x17a/0x330 net/ipv6/ip6_input.c:76 NF_HOOK include/linux/netfilter.h:289 [inline] ipv6_rcv+0x120/0x640 net/ipv6/ip6_input.c:271 __netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913 __netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023 netif_receive_skb_internal+0x12c/0x620 net/core/dev.c:5126 napi_frags_finish net/core/dev.c:5664 [inline] napi_gro_frags+0x75a/0xc90 net/core/dev.c:5737 tun_get_user+0x3189/0x4250 drivers/net/tun.c:1923 tun_chr_write_iter+0xb9/0x154 drivers/net/tun.c:1968 call_write_iter include/linux/fs.h:1808 [inline] do_iter_readv_writev+0x8b0/0xa80 fs/read_write.c:680 do_iter_write+0x185/0x5f0 fs/read_write.c:959 vfs_writev+0x1f1/0x360 fs/read_write.c:1004 do_writev+0x11a/0x310 fs/read_write.c:1039 __do_sys_writev fs/read_write.c:1112 [inline] __se_sys_writev fs/read_write.c:1109 [inline] __x64_sys_writev+0x75/0xb0 fs/read_write.c:1109 do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x457421 Code: 75 14 b8 14 00 00 00 0f 05 48 3d 01 f0 ff ff 0f 83 34 b5 fb ff c3 48 83 ec 08 e8 1a 2d 00 00 48 89 04 24 b8 14 00 00 00 0f 05 <48> 8b 3c 24 48 89 c2 e8 63 2d 00 00 48 89 d0 48 83 c4 08 48 3d 01 RSP: 002b:00007f2d30ecaba0 EFLAGS: 00000293 ORIG_RAX: 0000000000000014 RAX: ffffffffffffffda RBX: 000000000000003e RCX: 0000000000457421 RDX: 0000000000000001 RSI: 00007f2d30ecabf0 RDI: 00000000000000f0 RBP: 0000000020000500 R08: 00000000000000f0 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000293 R12: 00007f2d30ecb6d4 R13: 00000000004c4890 R14: 00000000004d7b90 R15: 00000000ffffffff Allocated by task 22437: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553 __do_kmalloc mm/slab.c:3718 [inline] __kmalloc+0x14e/0x760 mm/slab.c:3727 kmalloc include/linux/slab.h:518 [inline] sock_kmalloc+0x15a/0x1f0 net/core/sock.c:1983 ip6_mc_source+0x14dd/0x1960 net/ipv6/mcast.c:427 do_ipv6_setsockopt.isra.9+0x3afb/0x45d0 net/ipv6/ipv6_sockglue.c:743 ipv6_setsockopt+0xbd/0x170 net/ipv6/ipv6_sockglue.c:933 rawv6_setsockopt+0x59/0x140 net/ipv6/raw.c:1069 sock_common_setsockopt+0x9a/0xe0 net/core/sock.c:3038 __sys_setsockopt+0x1ba/0x3c0 net/socket.c:1902 __do_sys_setsockopt net/socket.c:1913 [inline] __se_sys_setsockopt net/socket.c:1910 [inline] __x64_sys_setsockopt+0xbe/0x150 net/socket.c:1910 do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe Freed by task 22430: save_stack+0x43/0xd0 mm/kasan/kasan.c:448 set_track mm/kasan/kasan.c:460 [inline] __kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521 kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528 __cache_free mm/slab.c:3498 [inline] kfree+0xcf/0x230 mm/slab.c:3813 __sock_kfree_s net/core/sock.c:2004 [inline] sock_kfree_s+0x29/0x60 net/core/sock.c:2010 ip6_mc_leave_src+0x11a/0x1d0 net/ipv6/mcast.c:2448 __ipv6_sock_mc_close+0x20b/0x4e0 net/ipv6/mcast.c:310 ipv6_sock_mc_close+0x158/0x1d0 net/ipv6/mcast.c:328 inet6_release+0x40/0x70 net/ipv6/af_inet6.c:452 __sock_release+0xd7/0x250 net/socket.c:579 sock_close+0x19/0x20 net/socket.c:1141 __fput+0x385/0xa30 fs/file_table.c:278 ____fput+0x15/0x20 fs/file_table.c:309 task_work_run+0x1e8/0x2a0 kernel/task_work.c:113 tracehook_notify_resume include/linux/tracehook.h:193 [inline] exit_to_usermode_loop+0x318/0x380 arch/x86/entry/common.c:166 prepare_exit_to_usermode arch/x86/entry/common.c:197 [inline] syscall_return_slowpath arch/x86/entry/common.c:268 [inline] do_syscall_64+0x6be/0x820 arch/x86/entry/common.c:293 entry_SYSCALL_64_after_hwframe+0x49/0xbe The buggy address belongs to the object at ffff8801ce7f2500 which belongs to the cache kmalloc-192 of size 192 The buggy address is located 16 bytes inside of 192-byte region [ffff8801ce7f2500, ffff8801ce7f25c0) The buggy address belongs to the page: page:ffffea000739fc80 count:1 mapcount:0 mapping:ffff8801da800040 index:0x0 flags: 0x2fffc0000000100(slab) raw: 02fffc0000000100 ffffea0006f6e548 ffffea000737b948 ffff8801da800040 raw: 0000000000000000 ffff8801ce7f2000 0000000100000010 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8801ce7f2400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ffff8801ce7f2480: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc >ffff8801ce7f2500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ^ ffff8801ce7f2580: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc ffff8801ce7f2600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
