When decnet is built as a module a simple:
echo 0.0 >/proc/sys/net/decnet/node_address
results in most of the sysctl entries under /proc/sys/net/decnet and
/proc/sys/net/decnet/conf disappearing.
For more details see http://www.spinics.net/lists/netdev/msg226123.html.
This change applies the same workaround used in
net/core/sysctl_net_core.c and net/ipv6/sysctl_net_ipv6.c of creating
a skeleton of decnet sysctl entries before doing anything else.
The problem first appeared in kernel 2.6.27. The later rewrite of
sysctl in kernel 3.4 restored the previous behavior and eliminated the
need for this workaround.
This patch was heavily inspired by a similar but more complex patch by
Larry Baker.
Reported-by: Larry Baker <baker@usgs.gov>
Acked-by: David Miller <davem@redhat.com>
commit a9a6b52ee1baa865283a91eb8d443ee91adfca56 upstream.
If the socket is full, we're better off just waiting until it empties,
or until the connection is broken. The reason why we generally don't
want to time out is that the call to xprt->ops->release_xprt() will
trigger a connection reset, which isn't helpful...
Let's make an exception for soft RPC calls, since they have to provide
timeout guarantees.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit e75bafbff2270993926abcc31358361db74a9bc2 upstream.
svc_age_temp_xprts expires xprts in a two-step process: first it takes
the sv_lock and moves the xprts to expire off their server-wide list
(sv_tempsocks or sv_permsocks) to a local list. Then it drops the
sv_lock and enqueues and puts each one.
I see no reason for this: svc_xprt_enqueue() will take sp_lock, but the
sv_lock and sp_lock are not otherwise nested anywhere (and documentation
at the top of this file claims it's correct to nest these with sp_lock
inside.)
Tested-by: Jason Tibbitts <tibbs@math.uh.edu>
Tested-by: Paweł Sikora <pawel.sikora@agmk.net>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ]
It looks like its possible to open thousands of TCP IPv6
sessions on a server, all landing in a single slot of TCP hash
table. Incoming packets have to lookup sockets in a very
long list.
We should hash all bits from foreign IPv6 addresses, using
a salt and hash mix, not a simple XOR.
inet6_ehashfn() can also separately use the ports, instead
of xoring them.
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
[ Upstream commit b531ed61a2a2a77eeb2f7c88b49aa5ec7d9880d8 ]
We should get 'type' and 'code' from the outer ICMP header.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
[ Upstream commit 547b4e718115eea74087e28d7fa70aec619200db ]
Spanning Tree Protocol packets should have always been marked as
control packets, this causes them to get queued in the high prirority
FIFO. As Radia Perlman mentioned in her LCA talk, STP dies if bridge
gets overloaded and can't communicate. This is a long-standing bug back
to the first versions of Linux bridge.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 6caab7b0544e83e6c160b5e80f5a4a7dd69545c7 ]
If lower layer driver leaves the ip header in the skb fragment, it needs to
be first pulled into skb->data before inspecting ip header length or ip version
number.
Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com>
[ Upstream commit 6731d2095bd4aef18027c72ef845ab1087c3ba63 ]
There are transients during normal FRTO procedure during which
the packets_in_flight can go to zero between write_queue state
updates and firing the resulting segments out. As FRTO processing
occurs during that window the check must be more precise to
not match "spuriously" :-). More specificly, e.g., when
packets_in_flight is zero but FLAG_DATA_ACKED is true the problematic
branch that set cwnd into zero would not be taken and new segments
might be sent out later.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Tested-by: Eric Dumazet <edumazet@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 2e5f421211ff76c17130b4597bc06df4eeead24f ]
Commit 9dc274151a548 (tcp: fix ABC in tcp_slow_start())
uncovered a bug in FRTO code :
tcp_process_frto() is setting snd_cwnd to 0 if the number
of in flight packets is 0.
As Neal pointed out, if no packet is in flight we lost our
chance to disambiguate whether a loss timeout was spurious.
We should assume it was a proper loss.
Reported-by: Pasi Kärkkäinen <pasik@iki.fi>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
[ Upstream commit b5c37fe6e24eec194bb29d22fdd55d73bcc709bf ]
On sctp_endpoint_destroy, previously used sensitive keying material
should be zeroed out before the memory is returned, as we already do
with e.g. auth keys when released.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ]
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
[ Upstream commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 ]
Jamie Parsons reported a problem recently, in which the re-initalization of an
association (The duplicate init case), resulted in a loss of receive window
space. He tracked down the root cause to sctp_outq_teardown, which discarded
all the data on an outq during a re-initalization of the corresponding
association, but never reset the outq->outstanding_data field to zero. I wrote,
and he tested this fix, which does a proper full re-initalization of the outq,
fixing this problem, and hopefully future proofing us from simmilar issues down
the road.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netdev@vger.kernel.org
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 9665d5d62487e8e7b1f546c00e11107155384b9a ]
When releasing a packet socket, the routine packet_set_ring() is reused
to free rings instead of allocating them. But when calling it for the
first time, it fills req->tp_block_nr with the value of rb->pg_vec_len
which in the second invocation makes it bail out since req->tp_block_nr
is greater zero but req->tp_block_size is zero.
This patch solves the problem by passing a zeroed auto-variable to
packet_set_ring() upon each invocation from packet_release().
As far as I can tell, this issue exists even since 69e3c75 (net: TX_RING
and packet mmap), i.e. the original inclusion of TX ring support into
af_packet, but applies only to sockets with both RX and TX ring
allocated, which is probably why this was unnoticed all the time.
Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
Cc: Johann Baudy <johann.baudy@gnu-log.net>
Cc: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ]
They will be created at output, if ever needed. This avoids creating
empty neighbor entries when TPROXYing/Forwarding packets for addresses
that are not even directly reachable.
Note that IPv4 already handles it this way. No neighbor entries are
created for local input.
Tested by myself and customer.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
[ Upstream commit 604dfd6efc9b79bce432f2394791708d8e8f6efc ]
The return value of pktgen_add_device() is not checked, so
even if we fail to add some device, for example, non-exist one,
we still see "OK:...". This patch fixes it.
After this patch, I got:
# echo "add_device non-exist" > /proc/net/pktgen/kpktgend_0
-bash: echo: write error: No such device
# cat /proc/net/pktgen/kpktgend_0
Running:
Stopped:
Result: ERROR: can not add device non-exist
# echo "add_device eth0" > /proc/net/pktgen/kpktgend_0
Running:
Stopped: eth0
Result: OK: add_device=eth0
(Candidate for -stable)
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit c9be4a5c49cf51cc70a993f004c5bb30067a65ce ]
A regression is introduced by the following commit:
commit 4d52cfbef6266092d535237ba5a4b981458ab171
Author: Eric Dumazet <eric.dumazet@gmail.com>
Date: Tue Jun 2 00:42:16 2009 -0700
net: ipv4/ip_sockglue.c cleanups
Pure cleanups
but it is not a pure cleanup...
- if (val != -1 && (val < 1 || val>255))
+ if (val != -1 && (val < 0 || val > 255))
Since there is no reason provided to allow ttl=0, change it back.
Reported-by: nitin padalia <padalia.nitin@gmail.com>
Cc: nitin padalia <padalia.nitin@gmail.com>
commit aacde9ee45225f7e0b90960f479aef83c66bfdc0 upstream.
Since:
commit b23b025fe246f3acc2988eb6d400df34c27cb8ae
Author: Ben Greear <greearb@candelatech.com>
Date: Fri Feb 4 11:54:17 2011 -0800
mac80211: Optimize scans on current operating channel.
we do not disable PS while going back to operational channel (on
ieee80211_scan_state_suspend) and deffer that until scan finish.
But since we are allowed to send frames, we can send a frame to AP
without PM bit set, so disable PS on AP side. Then when we switch
to off-channel (in ieee80211_scan_state_resume) we do not enable PS.
Hence we are off-channel with PS disabled, frames are not buffered
by AP.
To fix remove offchannel_ps_disable argument and always enable PS when
going off-channel and disable it when going on-channel, like it was
before.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit 0a9ab9bdb3e891762553f667066190c1d22ad62b upstream.
The length parameter should be sizeof(req->name) - 1 because there is no
guarantee that string provided by userspace will contain the trailing
'\0'.
Can be easily reproduced by manually setting req->name to 128 non-zero
bytes prior to ioctl(HIDPCONNADD) and checking the device name setup on
input subsystem:
$ cat /sys/devices/pnp0/00\:04/tty/ttyS0/hci0/hci0\:1/input8/name
AAAAAA[...]AAAAAAAAf0:af:f0:af:f0:af
("f0:af:f0:af:f0:af" is the device bluetooth address, taken from "phys"
field in struct hid_device due to overflow.)
Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit dbccd791a3fbbdac12c33834b73beff3984988e9 upstream.
After sending reset command wait for its command complete event before
sending next command. Some chips sends CC event for command received
before reset if reset was send before chip replied with CC.
This is also required by specification that host shall not send
additional HCI commands before receiving CC for reset.
< HCI Command: Reset (0x03|0x0003) plen 0 [hci0] 18.404612
> HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.405850
Write Extended Inquiry Response (0x03|0x0052) ncmd 1
Status: Success (0x00)
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.406079
> HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.407864
Reset (0x03|0x0003) ncmd 1
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.408062
> HCI Event: Command Complete (0x0e) plen 12 [hci0] 18.408835
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
commit a56f992cdabc63f56b4b142885deebebf936ff76 upstream.
This is a very old bug, but there's nothing that prevents the
timer from running while the module is being removed when we
only do del_timer() instead of del_timer_sync().
The timer should normally not be running at this point, but
it's not clearly impossible (or we could just remove this.)
Tested-by: Ben Greear <greearb@candelatech.com>
commit a4b64fbe482c7766f7925f03067fc637716bfa3f upstream.
nlmsg_parse() might return an error, so test its return value before
potential random memory accesses.
Errors introduced in commit 115c9b81928 (rtnetlink: Fix problem with
buffer allocation)
Acked-by: Greg Rose <gregory.v.rose@intel.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
commit 115c9b81928360d769a76c632bae62d15206a94a upstream.
Implement a new netlink attribute type IFLA_EXT_MASK. The mask
is a 32 bit value that can be used to indicate to the kernel that
certain extended ifinfo values are requested by the user application.
At this time the only mask value defined is RTEXT_FILTER_VF to
indicate that the user wants the ifinfo dump to send information
about the VFs belonging to the interface.
This patch fixes a bug in which certain applications do not have
large enough buffers to accommodate the extra information returned
by the kernel with large numbers of SR-IOV virtual functions.
Those applications will not send the new netlink attribute with
the interface info dump request netlink messages so they will
not get unexpectedly large request buffers returned by the kernel.
Modifies the rtnl_calcit function to traverse the list of net
devices and compute the minimum buffer size that can hold the
info dumps of all matching devices based upon the filter passed
in via the new netlink attribute filter mask. If no filter
mask is sent then the buffer allocation defaults to NLMSG_GOODSIZE.
With this change it is possible to add yet to be defined netlink
attributes to the dump request which should make it fairly extensible
in the future.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
[bwh: Backported to 3.0:
- Adjust context
- Drop the change in do_setlink() that reverts commit f18da1456581
('net: RTNETLINK adjusting values of min_ifinfo_dump_size'), which
was never applied here]
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream.
The message size allocated for rtnl ifinfo dumps was limited to
a single page. This is not enough for additional interface info
available with devices that support SR-IOV and caused a bug in
which VF info would not be displayed if more than approximately
40 VFs were created per interface.
Implement a new function pointer for the rtnl_register service that will
calculate the amount of data required for the ifinfo dump and allocate
enough data to satisfy the request.
commit c6567ed1402c55e19b012e66a8398baec2a726f3 upstream.
This patch ensures that we free the rpc_task after the cleanup callbacks
are done in order to avoid a deadlock problem that can be triggered if
the callback needs to wait for another workqueue item to complete.
Cc: Weston Andros Adamson <dros@netapp.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Bruce Fields <bfields@fieldses.org>
commit b9b5ef188e5a2222cfc16ef62a4703080750b451 upstream.
We need to cancel the hci_power_on work in order to avoid it run when we
try to free the hdev.
[ 1434.201149] ------------[ cut here ]------------
[ 1434.204998] WARNING: at lib/debugobjects.c:261 debug_print_object+0x8e/0xb0()
[ 1434.208324] ODEBUG: free active (active state 0) object type: work_struct hint: hci
_power_on+0x0/0x90
[ 1434.210386] Pid: 8564, comm: trinity-child25 Tainted: G W 3.7.0-rc5-next-
20121112-sasha-00018-g2f4ce0e #127
[ 1434.210760] Call Trace:
[ 1434.210760] [<ffffffff819f3d6e>] ? debug_print_object+0x8e/0xb0
[ 1434.210760] [<ffffffff8110b887>] warn_slowpath_common+0x87/0xb0
[ 1434.210760] [<ffffffff8110b911>] warn_slowpath_fmt+0x41/0x50
[ 1434.210760] [<ffffffff819f3d6e>] debug_print_object+0x8e/0xb0
[ 1434.210760] [<ffffffff8376b750>] ? hci_dev_open+0x310/0x310
[ 1434.210760] [<ffffffff83bf94e5>] ? _raw_spin_unlock_irqrestore+0x55/0xa0
[ 1434.210760] [<ffffffff819f3ee5>] __debug_check_no_obj_freed+0xa5/0x230
[ 1434.210760] [<ffffffff83785db0>] ? bt_host_release+0x10/0x20
[ 1434.210760] [<ffffffff819f4d15>] debug_check_no_obj_freed+0x15/0x20
[ 1434.210760] [<ffffffff8125eee7>] kfree+0x227/0x330
[ 1434.210760] [<ffffffff83785db0>] bt_host_release+0x10/0x20
[ 1434.210760] [<ffffffff81e539e5>] device_release+0x65/0xc0
[ 1434.210760] [<ffffffff819d3975>] kobject_cleanup+0x145/0x190
[ 1434.210760] [<ffffffff819d39cd>] kobject_release+0xd/0x10
[ 1434.210760] [<ffffffff819d33cc>] kobject_put+0x4c/0x60
[ 1434.210760] [<ffffffff81e548b2>] put_device+0x12/0x20
[ 1434.210760] [<ffffffff8376a334>] hci_free_dev+0x24/0x30
[ 1434.210760] [<ffffffff82fd8fe1>] vhci_release+0x31/0x60
[ 1434.210760] [<ffffffff8127be12>] __fput+0x122/0x250
[ 1434.210760] [<ffffffff811cab0d>] ? rcu_user_exit+0x9d/0xd0
[ 1434.210760] [<ffffffff8127bf49>] ____fput+0x9/0x10
[ 1434.210760] [<ffffffff81133402>] task_work_run+0xb2/0xf0
[ 1434.210760] [<ffffffff8106cfa7>] do_notify_resume+0x77/0xa0
[ 1434.210760] [<ffffffff83bfb0ea>] int_signal+0x12/0x17
[ 1434.210760] ---[ end trace a6d57fefbc8a8cc7 ]---
Reported-by: Sasha Levin <sasha.levin@oracle.com>
[ Upstream commit 354e4aa391ed50a4d827ff6fc11e0667d0859b25 ]
RFC 5961 5.2 [Blind Data Injection Attack].[Mitigation]
All TCP stacks MAY implement the following mitigation. TCP stacks
that implement this mitigation MUST add an additional input check to
any incoming segment. The ACK value is considered acceptable only if
it is in the range of ((SND.UNA - MAX.SND.WND) <= SEG.ACK <=
SND.NXT). All incoming segments whose ACK value doesn't satisfy the
above condition MUST be discarded and an ACK sent back.
Move tcp_send_challenge_ack() before tcp_ack() to avoid a forward
declaration.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Jerry Chu <hkchu@google.com>
[ Upstream commit bd090dfc634ddd711a5fbd0cadc6e0ab4977bcaf ]
We added support for RFC 5961 in latest kernels but TCP fails
to perform exhaustive check of ACK sequence.
We can update our view of peer tsval from a frame that is
later discarded by tcp_ack()
This makes timestamps enabled sessions vulnerable to injection of
a high tsval : peers start an ACK storm, since the victim
sends a dupack each time it receives an ACK from the other peer.
As tcp_validate_incoming() is called before tcp_ack(), we should
not peform tcp_replace_ts_recent() from it, and let callers do it
at the right time.
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Romain Francoise <romain@orebokech.com>
[ Upstream commit e371589917011efe6ff8c7dfb4e9e81934ac5855 ]
Followup of commit 0c24604b68fc (tcp: implement RFC 5961 4.2)
As reported by Vijay Subramanian, we should send a challenge ACK
instead of a dup ack if a SYN flag is set on a packet received out of
window.
This permits the ratelimiting to work as intended, and to increase
correct SNMP counters.
Suggested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Acked-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Cc: Kiran Kumar Kella <kkiran@broadcom.com>
[ Upstream commit 0c24604b68fc7810d429d6c3657b6f148270e528 ]
Implement the RFC 5691 mitigation against Blind
Reset attack using SYN bit.
Section 4.2 of RFC 5961 advises to send a Challenge ACK and drop
incoming packet, instead of resetting the session.
Add a new SNMP counter to count number of challenge acks sent
in response to SYN packets.
(netstat -s | grep TCPSYNChallenge)
Remove obsolete TCPAbortOnSyn, since we no longer abort a TCP session
because of a SYN flag.
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ]
Reset attack using RST bit.
Idea is to validate incoming RST sequence,
to match RCV.NXT value, instead of previouly accepted
window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND)
If sequence is in window but not an exact match, send
a "challenge ACK", so that the other part can resend an
RST with the appropriate sequence.
Add a new sysctl, tcp_challenge_ack_limit, to limit
number of challenge ACK sent per second.
Add a new SNMP counter to count number of challenge acks sent.
(netstat -s | grep TCPChallengeACK)
[ Upstream commit d2fe85da52e89b8012ffad010ef352a964725d5f ]
Fixed integer overflow in function htb_dequeue
Signed-off-by: Stefan Hasko <hasko.stevo@gmail.com>
[ Upstream commit 6e51fe7572590d8d86e93b547fab6693d305fd0d ]
Consider the following program, that sets the second argument to the
sendto() syscall incorrectly:
#include <string.h>
#include <arpa/inet.h>
#include <sys/socket.h>
int main(void)
int fd;
struct sockaddr_in sa;
fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/);
if (fd < 0)
return 1;
memset(&sa, 0, sizeof(sa));
sa.sin_family = AF_INET;
sa.sin_addr.s_addr = inet_addr("127.0.0.1");
sa.sin_port = htons(11111);
sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa));
return 0;
We get -ENOMEM:
$ strace -e sendto ./demo
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory)
Propagate the error code from sctp_user_addto_chunk(), so that we will
tell user space what actually went wrong:
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address)
Noticed while running Trinity (the syscall fuzzer).
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
fails
[ Upstream commit be364c8c0f17a3dd42707b5a090b318028538eb9 ]
Trinity (the syscall fuzzer) discovered a memory leak in SCTP,
reproducible e.g. with the sendto() syscall by passing invalid
user space pointer in the second argument:
#include <string.h>
int main(void)
int fd;
if (fd < 0)
return 1;
return 0;
As far as I can tell, the leak has been around since ~2003.
Stable-3.0 commit 42ab5316 (ipv4: fix redirect handling) was
backport of mainline commit 9cc20b26 from 3.2-rc3 where hh
member of struct dst_entry was already gone.
However, in 3.0 we still have it and we have to clean it as
well, otherwise it keeps pointing to the cleaned up (and
unusable) hh_cache entry and packets cannot be sent out.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
commit 81b401100c01d2357031e874689f89bd788d13cd upstream.
Set in the rx_ifindex to pass the correct interface index in the case of a
message timeout detection. Usually the rx_ifindex value is set at receive
time. But when no CAN frame has been received the RX_TIMEOUT notification
did not contain a valid value.
Reported-by: Andre Naujoks <nautsch2@googlemail.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit b78a4932f5fb11fadf41e69c606a33fa6787574c upstream.
The check whether the IBSS is active and can be removed should be
performed before deinitializing the fields used for the check/search.
Otherwise, the configured BSS will not be found and removed properly.
To make it more clear for the future, rename sdata->u.ibss to the
local pointer ifibss which is used within the checks.
This behaviour was introduced by
f3209bea110cade12e2b133da8b8499689cb0e2e
("mac80211: fix IBSS teardown race")
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Cc: Ignacy Gawedzki <i@lri.fr>
commit 38fe36a248ec3228f8e6507955d7ceb0432d2000 upstream.
ICMP tuples have id in src and type/code in dst.
So comparing src.u.all with dst.u.all will always fail here
and ip_xfrm_me_harder() is called for every ICMP packet,
even if there was no NAT.
Signed-off-by: Ulrich Weber <ulrich.weber@sophos.com>
commit 64f509ce71b08d037998e93dd51180c19b2f464c upstream.
Clients should not send such packets. By accepting them, we open
up a hole by wich ephemeral ports can be discovered in an off-path
attack.
See: "Reflection scan: an Off-Path Attack on TCP" by Jan Wrobel,
http://arxiv.org/abs/1201.2074
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 4a70bbfaef0361d27272629d1a250a937edcafe4 upstream.
We spare nothing by not validating the sequence number of dataless
ACK packets and enabling it makes harder off-path attacks.
[ Upstream commit baefa31db2f2b13a05d1b81bdf2d20d487f58b0a ]
In commit c445477d74ab3779 which adds aRFS to the kernel, the CPU
selected for RFS is not set correctly when CPU is changing.
This is causing OOO packets and probably other issues.
Signed-off-by: Tom Herbert <therbert@google.com>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
[ Upstream commit a652208e0b52c190e57f2a075ffb5e897fe31c3b ]
Check (ha->addr == dev->dev_addr) is always true because dev_addr_init()
sets this. Correct the check to behave properly on addr removal.
[ Upstream commit d4596bad2a713fcd0def492b1960e6d899d5baa8 ]
Cc: Stephen Hemminger <shemminger@vyatta.com>
[ Upstream commit 0c9f79be295c99ac7e4b569ca493d75fdcc19e4e ]
(1<<optname) is undefined behavior in C with a negative optname or
optname larger than 31. In those cases the result of the shift is
not necessarily zero (e.g., on x86).
This patch simplifies the code with a switch statement on optname.
It also allows the compiler to generate better code (e.g., using a
64-bit mask).
Signed-off-by: Xi Wang <xi.wang@gmail.com>
commit 43c771a1963ab461a2f194e3c97fded1d5fe262f upstream.
When in world roaming mode, allow 40 MHz to be used
on channels 12 and 13 so that an AP that is, e.g.,
using HT40+ on channel 9 (in the UK) can be used.
Reported-by: Eddie Chapman <eddie@ehuk.net>
Tested-by: Eddie Chapman <eddie@ehuk.net>
Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
[ Upstream commit 60713a0ca7fd6651b951cc1b4dbd528d1fc0281b ]
As documented in RFC4861 (Neighbor Discovery for IP version 6) 7.2.6.,
unsolicited neighbour advertisements should be sent to the all-nodes
multicast address.
[ Upstream commit 789336360e0a2aeb9750c16ab704a02cbe035e9e ]
When creating an L2TPv3 Ethernet session, if register_netdev() should fail for
any reason (for example, automatic naming for "l2tpeth%d" interfaces hits the
32k-interface limit), the netdev is freed in the error path. However, the
l2tp_eth_sess structure's dev pointer is left uncleared, and this results in
l2tp_eth_delete() then attempting to unregister the same netdev later in the
session teardown. This results in an oops.
To avoid this, clear the session dev pointer in the error path.
Signed-off-by: Tom Parkin <tparkin@katalix.com>
[ Upstream commit 8f363b77ee4fbf7c3bbcf5ec2c5ca482d396d664 ]
Reading TCP stats when using TCP Illinois congestion control algorithm
can cause a divide by zero kernel oops.
The division by zero occur in tcp_illinois_info() at:
do_div(t, ca->cnt_rtt);
where ca->cnt_rtt can become zero (when rtt_reset is called)
Steps to Reproduce:
1. Register tcp_illinois:
# sysctl -w net.ipv4.tcp_congestion_control=illinois
2. Monitor internal TCP information via command "ss -i"
# watch -d ss -i
3. Establish new TCP conn to machine
Either it fails at the initial conn, or else it needs to wait
for a loss or a reset.
This is only related to reading stats. The function avg_delay() also
performs the same divide, but is guarded with a (ca->cnt_rtt > 0) at its
calling point in update_params(). Thus, simply fix tcp_illinois_info().
Function tcp_illinois_info() / get_info() is called without
socket lock. Thus, eliminate any race condition on ca->cnt_rtt
by using a local stack variable. Simply reuse info.tcpv_rttcnt,
as its already set to ca->cnt_rtt.
Function avg_delay() is not affected by this race condition, as
its called with the socket lock.
Cc: Petr Matousek <pmatouse@redhat.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
[ Upstream commit 14edd87dc67311556f1254a8f29cf4dd6cb5b7d1 ]
Commit a02e4b7dae4551(Demark default hoplimit as zero) only changes the
hoplimit checking condition and default value in ip6_dst_hoplimit, not
zeros all hoplimit default value.
Keep the zeroing ip6_template_metrics[RTAX_HOPLIMIT - 1] to force it as
const, cause as a37e6e344910(net: force dst_default_metrics to const
section)
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
[ Upstream commit a3374c42aa5f7237e87ff3b0622018636b0c847e ]
tcp_ioctl() tries to take into account if tcp socket received a FIN
to report correct number bytes in receive queue.
But its flaky because if the application ate the last skb,
we return 1 instead of 0.
Correct way to detect that FIN was received is to test SOCK_DONE.
Reported-by: Elliot Hughes <enh@google.com>
Cc: Tom Herbert <therbert@google.com>
[ Upstream commit 6d772ac5578f711d1ce7b03535d1c95bffb21dff ]
On some suspend/resume operations involving wimax device, we have
noticed some intermittent memory corruptions in netlink code.
Stéphane Marchesin tracked this corruption in netlink_update_listeners()
and suggested a patch.
It appears netlink_release() should use kfree_rcu() instead of kfree()
for the listeners structure as it may be used by other cpus using RCU
protection.
netlink_release() must set to NULL the listeners pointer when
it is about to be freed.
Also have to protect netlink_update_listeners() and
netlink_has_listeners() if listeners is NULL.
Add a nl_deref_protected() lockdep helper to properly document which
locks protects us.
Reported-by: Jonathan Kliegman <kliegs@google.com>
Cc: Stéphane Marchesin <marcheu@google.com>
Cc: Sam Leffler <sleffler@google.com>
