path: root/net
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-15pkt_sched: Rename PSCHED_US2NS and PSCHED_NS2USJarek Poplawski
Let's use TICKS instead of US, so PSCHED_TICKS2NS and PSCHED_NS2TICKS (like in PSCHED_TICKS_PER_SEC already) to avoid misleading. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15ipv4: Fix fib_trie rebalancingJarek Poplawski
While doing trie_rebalance(): resize(), inflate(), halve() RCU free tnodes before updating their parents. It depends on RCU delaying the real destruction, but if RCU readers start after call_rcu() and before parent update they could access freed memory. It is currently prevented with preempt_disable() on the update side, but it's not safe, except maybe classic RCU, plus it conflicts with memory allocations with GFP_KERNEL flag used from these functions. This patch explicitly delays freeing of tnodes by adding them to the list, which is flushed after the update is finished. Reported-by: Yan Zheng <zheng.yan@oracle.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-14Bluetooth: Fix Kconfig issue with RFKILL integrationMarcel Holtmann
Since the re-write of the RFKILL subsystem it is no longer good to just select RFKILL, but it is important to add a proper depends on rule. Based on a report by Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-14PIM-SM: namespace changesTom Goff
IPv4: - make PIM register vifs netns local - set the netns when a PIM register vif is created - make PIM available in all network namespaces (if CONFIG_IP_PIMSM_V2) by adding the protocol handler when multicast routing is initialized IPv6: - make PIM register vifs netns local - make PIM available in all network namespaces (if CONFIG_IPV6_PIMSM_V2) by adding the protocol handler when multicast routing is initialized Signed-off-by: Tom Goff <thomas.goff@boeing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13ipv4: update ARPD help textTimo Teräs
Removed the statements about ARP cache size as this config option does not affect it. The cache size is controlled by neigh_table gc thresholds. Remove also expiremental and obsolete markings as the API originally intended for arp caching is useful for implementing ARP-like protocols (e.g. NHRP) in user space and has been there for a long enough time. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use a deferred timer in rt_check_expireEric Dumazet
For the sake of power saver lovers, use a deferrable timer to fire rt_check_expire() As some big routers cache equilibrium depends on garbage collection done in time, we take into account elapsed time between two rt_check_expire() invocations to adjust the amount of slots we have to check. Based on an initial idea and patch from Tero Kristo Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-06-13x_tables: Convert printk to pr_errJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: conntrack: optional reliable conntrack event deliveryPablo Neira Ayuso
This patch improves ctnetlink event reliability if one broadcast listener has set the NETLINK_BROADCAST_ERROR socket option. The logic is the following: if an event delivery fails, we keep the undelivered events in the missed event cache. Once the next packet arrives, we add the new events (if any) to the missed events in the cache and we try a new delivery, and so on. Thus, if ctnetlink fails to deliver an event, we try to deliver them once we see a new packet. Therefore, we may lose state transitions but the userspace process gets in sync at some point. At worst case, if no events were delivered to userspace, we make sure that destroy events are successfully delivered. Basically, if ctnetlink fails to deliver the destroy event, we remove the conntrack entry from the hashes and we insert them in the dying list, which contains inactive entries. Then, the conntrack timer is added with an extra grace timeout of random32() % 15 seconds to trigger the event again (this grace timeout is tunable via /proc). The use of a limited random timeout value allows distributing the "destroy" resends, thus, avoiding accumulating lots "destroy" events at the same time. Event delivery may re-order but we can identify them by means of the tuple plus the conntrack ID. The maximum number of conntrack entries (active or inactive) is still handled by nf_conntrack_max. Thus, we may start dropping packets at some point if we accumulate a lot of inactive conntrack entries that did not successfully report the destroy event to userspace. During my stress tests consisting of setting a very small buffer of 2048 bytes for conntrackd and the NETLINK_BROADCAST_ERROR socket flag, and generating lots of very small connections, I noticed very few destroy entries on the fly waiting to be resend. A simple way to test this patch consist of creating a lot of entries, set a very small Netlink buffer in conntrackd (+ a patch which is not in the git tree to set the BROADCAST_ERROR flag) and invoke `conntrack -F'. For expectations, no changes are introduced in this patch. Currently, event delivery is only done for new expectations (no events from expectation expiration, removal and confirmation). In that case, they need a per-expectation event cache to implement the same idea that is exposed in this patch. This patch can be useful to provide reliable flow-accouting. We still have to add a new conntrack extension to store the creation and destroy time. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: conntrack: move helper destruction to nf_ct_helper_destroy()Pablo Neira Ayuso
This patch moves the helper destruction to a function that lives in nf_conntrack_helper.c. This new function is used in the patch to add ctnetlink reliable event delivery. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: conntrack: move event caching to conntrack extension infrastructurePablo Neira Ayuso
This patch reworks the per-cpu event caching to use the conntrack extension infrastructure. The main drawback is that we consume more memory per conntrack if event delivery is enabled. This patch is required by the reliable event delivery that follows to this patch. BTW, this patch allows you to enable/disable event delivery via /proc/sys/net/netfilter/nf_conntrack_events in runtime, although you can still disable event caching as compilation option. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: nf_conntrack: use mod_timer_pending() for conntrack refreshPatrick McHardy
Use mod_timer_pending() instead of atomic sequence of del_timer()/ add_timer(). mod_timer_pending() does not rearm an inactive timer, so we don't need the conntrack lock anymore to make sure we don't accidentally rearm a timer of a conntrack which is in the process of being destroyed. With this change, we don't need to take the global lock anymore at all, counter updates can be performed under the per-conntrack lock. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: nf_log: fix sleeping function called from invalid contextPatrick McHardy
Fix regression introduced by 17625274 "netfilter: sysctl support of logger choice": BUG: sleeping function called from invalid context at /mnt/s390test/linux-2.6-tip/arch/s390/include/asm/uaccess.h:234 in_atomic(): 1, irqs_disabled(): 0, pid: 3245, name: sysctl CPU: 1 Not tainted 2.6.30-rc8-tipjun10-02053-g39ae214 #1 Process sysctl (pid: 3245, task: 000000007f675da0, ksp: 000000007eb17cf0) 0000000000000000 000000007eb17be8 0000000000000002 0000000000000000 000000007eb17c88 000000007eb17c00 000000007eb17c00 0000000000048156 00000000003e2de8 000000007f676118 000000007eb17f10 0000000000000000 0000000000000000 000000007eb17be8 000000000000000d 000000007eb17c58 00000000003e2050 000000000001635c 000000007eb17be8 000000007eb17c30 Call Trace: (Ý<00000000000162e6>¨ show_trace+0x13a/0x148) Ý<00000000000349ea>¨ __might_sleep+0x13a/0x164 Ý<0000000000050300>¨ proc_dostring+0x134/0x22c Ý<0000000000312b70>¨ nf_log_proc_dostring+0xfc/0x188 Ý<0000000000136f5e>¨ proc_sys_call_handler+0xf6/0x118 Ý<0000000000136fda>¨ proc_sys_read+0x26/0x34 Ý<00000000000d6e9c>¨ vfs_read+0xac/0x158 Ý<00000000000d703e>¨ SyS_read+0x56/0x88 Ý<0000000000027f42>¨ sysc_noemu+0x10/0x16 Use the nf_log_mutex instead of RCU to fix this. Reported-and-tested-by: Maran Pakkirisamy <maranpsamy@in.ibm.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: fix network drivers ndo_start_xmit() return values (part 7)Patrick McHardy
Fix up ATM drivers that return an errno value to qdisc_restart(), causing qdisc_restart() to print a warning an requeue/retransmit the skb. - lec: condition can only be remedied by userspace, until that retransmissions Compile tested only. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-12trivial: Fix a typo in comment of addrconf_dad_start()Masatake YAMATO
Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: Fix paramater/parameter typo in dmesg and source commentsMartin Olsson
Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12virtio: find_vqs/del_vqs virtio operationsMichael S. Tsirkin
This replaces find_vq/del_vq with find_vqs/del_vqs virtio operations, and updates all drivers. This is needed for MSI support, because MSI needs to know the total number of vectors upfront. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ lguest/9p compile fixes)
2009-06-12virtio: add names to virtqueue struct, mapping from devices to queues.Rusty Russell
Add a linked list of all virtqueues for a virtio device: this helps for debugging and is also needed for upcoming interface change. Also, add a "name" field for clearer debug messages. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-11bridge: Simplify interface for ATM LANEMichał Mirosław
This patch changes FDB entry check for ATM LANE bridge integration. There's no point in holding a FDB entry around SKB building. br_fdb_get()/br_fdb_put() pair are changed into single br_fdb_test_addr() hook that checks if the addr has FDB entry pointing to other port to the one the request arrived on. FDB entry refcounting is removed as it's not used anywhere else. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11[PATCH] net core: Some interface flags not returned by SIOCGIFFLAGSJohn Dykstra
Commit b00055aacdb172c05067612278ba27265fcd05ce " [NET] core: add RFC2863 operstate" defined new interface flag values. Its documentation specified that these flags could be accessed from user space via SIOCGIFFLAGS. However, this does not work because the new flags do not fit in that ioctl's argument width. Change the documentation to match the code's behavior. Also change the source to explicitly show the truncation. This _should_ have no effect on executable code, and did not with gcc 4.2.4 generating x86 code. A new ioctl could be defined to return all interface flags to user space. However, since this has been broken for three years with no one complaining, there doesn't seem much need. They are still accessible via netlink. Reported-by: "Fredrik Arnerup" <fredrik.arnerup@edgeware.tv> Signed-off-by: John Dykstra <john.dykstra1@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11Merge branch 'master' of ↵David S. Miller
2009-06-11Merge branch 'linux-2.6.31.y' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/inaky/wimax
2009-06-12netfilter: ip_tables: fix build errorPatrick McHardy
Fix build error introduced by commit bb70dfa5 (netfilter: xtables: consolidate comefrom debug cast access): net/ipv4/netfilter/ip_tables.c: In function 'ipt_do_table': net/ipv4/netfilter/ip_tables.c:421: error: 'comefrom' undeclared (first use in this function) net/ipv4/netfilter/ip_tables.c:421: error: (Each undeclared identifier is reported only once net/ipv4/netfilter/ip_tables.c:421: error: for each function it appears in.) Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-11wimax: fix warning caused by not checking retval of rfkill_set_hw_state()Inaky Perez-Gonzalez
Caused by an API update. The return value can be safely ignored, as there is notthing we can do with it. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com>
2009-06-11netfilter: nf_ct_tcp: fix up build after mergePatrick McHardy
Replace the last occurence of tcp_lock by the per-conntrack lock. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-11Merge branch 'master' of ↵Patrick McHardy
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6
2009-06-11neigh: fix state transition INCOMPLETE->FAILED via Netlink requestTimo Teras
The current code errors out the INCOMPLETE neigh entry skb queue only from the timer if maximum probes have been attempted and there has been no reply. This also causes the transtion to FAILED state. However, the neigh entry can be also updated via Netlink to inform that the address is unavailable. Currently, neigh_update() just stops the timers and leaves the pending skb's unreleased. This results that the clean up code in the timer callback is never called, preventing also proper garbage collection. This fixes neigh_update() to process the pending skb queue immediately if INCOMPLETE -> FAILED state transtion occurs due to a Netlink request. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11net: No more expensive sock_hold()/sock_put() on each txEric Dumazet
One of the problem with sock memory accounting is it uses a pair of sock_hold()/sock_put() for each transmitted packet. This slows down bidirectional flows because the receive path also needs to take a refcount on socket and might use a different cpu than transmit path or transmit completion path. So these two atomic operations also trigger cache line bounces. We can see this in tx or tx/rx workloads (media gateways for example), where sock_wfree() can be in top five functions in profiles. We use this sock_hold()/sock_put() so that sock freeing is delayed until all tx packets are completed. As we also update sk_wmem_alloc, we could offset sk_wmem_alloc by one unit at init time, until sk_free() is called. Once sk_free() is called, we atomic_dec_and_test(sk_wmem_alloc) to decrement initial offset and atomicaly check if any packets are in flight. skb_set_owner_w() doesnt call sock_hold() anymore sock_wfree() doesnt call sock_put() anymore, but check if sk_wmem_alloc reached 0 to perform the final freeing. Drawback is that a skb->truesize error could lead to unfreeable sockets, or even worse, prematurely calling __sk_free() on a live socket. Nice speedups on SMP. tbench for example, going from 2691 MB/s to 2711 MB/s on my 8 cpu dev machine, even if tbench was not really hitting sk_refcnt contention point. 5 % speedup on a UDP transmit workload (depends on number of flows), lowering TX completion cpu usage. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11ieee802154: Use '%Zu' printf format for size_t.David S. Miller
2009-06-10Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-06-10cfg80211: fix rfkill locking problemJohannes Berg
rfkill currently requires a global lock within the rfkill_register() function, and holds that lock over calls to the set_block() methods. This means that we cannot hold a lock around rfkill_register() that we also require in set_block(), directly or indirectly. Fix cfg80211 to register rfkill outside the block locked by its global lock. Much of what cfg80211 does in the locked block doesn't need to be locked anyway. Reported-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: disable PS while probing APJohannes Berg
When associated, but probing the AP because we detected beacon loss, we need to disable powersave to be able to receive the probe response. Change the code to do that by checking whether we're trying to probe when determining the possibility of going into PS, and recalculate the PS ability at the necessary spots. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: disable moving between PS modes during scanLuis R. Rodriguez
We don't want to trigger moving between PS mode during scan, because then we will sometimes end up sending nullfunc frames during scan. We're supposed to only send one prior to scan and after scan. This fixes an oops which occured due to an assert in ath9k: http://marc.info/?l=linux-wireless&m=124277331319024 The assert was happening because the rate control algorithm figures it should find at least one valid dual stream or single stream rate. Since we allow mac80211 to send nullfunc frames during scan and dynamic PS was enabled at times we ended up trying to send nullfunc frames for the target sta on the wrong band for which we have no valid rate to communicate with it. This breaks the assumptions in rate control. We determine we also need to disable moving between PS modes when not associated so lets just add that now as well, and we should not have a ps_sdata when that interface cannot actually go into PS because it's not associated. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: clean up return value of __ieee80211_parse_tx_radiotapJohannes Berg
The return type has more than two values, but it can validly only ever return TX_DROP and TX_CONTINUE, so use a bool instead of ieee80211_tx_result. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: don't use master netdev nameJohannes Berg
Always use the wiphy name instead. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: Fix the way ADDBA request count being modifiedVasanthakumar Thiagarajan
addba_req_num[tid] is supposed to have the count of consecutive addba request attempts on 'tid' which failed. This count is checked against a retry threshold (3 times) before starting the addba negotiation. This patch fixes the way this addba count is incremented/reset and thereby avoids indefinite addba attempts. Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10cfg80211: fix for duplicate response for driver reg requestLuis R. Rodriguez
As Pavel puts userspace can be stupid and should not cause kernel crashes. In this case Pavel was able to find a crash here but unable to reproduce. Either way lets deal with this. This should fix: ------------[ cut here ]------------ kernel BUG at /home/proski/src/linux-2.6/net/wireless/reg.c:2132! Oops: Exception in kernel mode, sig: 5 [#1] PowerMac Modules linked in: ath5k ath [last unloaded: scsi_wait_scan] NIP: c02f3eac LR: c02f3d08 CTR: 00000000 REGS: ef107aa0 TRAP: 0700 Not tainted (2.6.30-rc8-wl) MSR: 00029032 <EE,ME,CE,IR,DR> CR: 88002442 XER: 20000000 TASK = ef84acb0[834] 'crda' THREAD: ef106000 GPR00: ef953840 ef107b50 ef84acb0 ef1380bc 00000006 c035a5c8 ef107b90 c035a5c8 GPR08: 00080005 efb68980 c0445628 ef130004 28002422 10019ce0 10012d3c 00000001 GPR16: 1070b2ac 00000005 48023558 1070b380 4802304c 00000000 ef107ddc c035a5c8 GPR24: ef107b78 c0443350 ef8bcb00 00000005 ef138080 c04a6a70 c04a0000 ef8bcb00 NIP [c02f3eac] set_regdom+0x4c4/0x4ec LR [c02f3d08] set_regdom+0x320/0x4ec Call Trace: [ef107b50] [c02f3d08] set_regdom+0x320/0x4ec (unreliable) [ef107b70] [c02f9d10] nl80211_set_reg+0x140/0x2d0 [ef107bc0] [c02aa2b8] genl_rcv_msg+0x204/0x228 [ef107c10] [c02a97cc] netlink_rcv_skb+0xe8/0x10c [ef107c30] [c02aa094] genl_rcv+0x3c/0x5c [ef107c40] [c02a9050] netlink_unicast+0x308/0x36c [ef107c80] [c02a92bc] netlink_sendmsg+0x208/0x2f0 [ef107cd0] [c0282048] sock_sendmsg+0xac/0xe4 [ef107db0] [c02822b4] sys_sendmsg+0x234/0x2d8 [ef107f00] [c0283a88] sys_socketcall+0x108/0x258 [ef107f40] [c0012790] ret_from_syscall+0x0/0x38 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: don't impose global states on resume (just restore the previous states)Alan Jenkins
Once rfkill-input is disabled, the "global" states will only be used as default initial states. Since the states will always be the same after resume, we shouldn't generate events on resume. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: remove set_global_sw_stateAlan Jenkins
rfkill_set_global_sw_state() (previously rfkill_set_default()) will no longer be exported by the rewritten rfkill core. Instead, platform drivers which can provide persistent soft-rfkill state across power-down/reboot should indicate their initial state by calling rfkill_set_sw_state() before registration. Otherwise, they will be initialized to a default value during registration by a set_block call. We remove existing calls to rfkill_set_sw_state() which happen before registration, since these had no effect in the old model. If these drivers do have persistent state, the calls can be put back (subject to testing :-). This affects hp-wmi and acer-wmi. Drivers with persistent state will affect the global state only if rfkill-input is enabled. This is required, otherwise booting with wireless soft-blocked and pressing the wireless-toggle key once would have no apparent effect. This special case will be removed in future along with rfkill-input, in favour of a more flexible userspace daemon (see Documentation/feature-removal-schedule.txt). Now rfkill_global_states[n].def is only used to preserve global states over EPO, it is renamed to ".sav". Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: do not pass PS frames out of mac80211 againJohannes Berg
In order to handle powersave frames properly we had needed to pass these out to the device queues again, and introduce the skb->requeue bit. This, however, also has unnecessary overhead by needing to 'clean up' already tried frames, and this clean-up code is also buggy when software encryption is used. Instead of sending the frames via the master netdev queue again, simply put them into the pending queue. This also fixes a problem where frames for that particular station could be reordered when some were still on the software queues and older ones are re-injected into the software queue after them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: remove input KconfigJohannes Berg
Now that we added the ioctl, there's no need to ask the user to configure this. We will keep it enabled for now, and eventually swap the default to n. Also let embedded users select it only if they need it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: print events when input handler is disabled/enabledJohannes Berg
It is useful for debugging when we know if something disabled the in-kernel rfkill input handler. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211 : fix unaligned rx skbmatthieu castet
mac80211 is checking is the skb is aligned on 32 bit boundary. But it is checking against ethernet header, whereas Linux expect IP header aligned. And ethernet ether size is 6*2+2=14, so aligning ethernet header make IP header unaligned. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: fix minstrel single-rate memory corruptionBob Copeland
The minstrel rate controller periodically looks up rate indexes in a sampling table. When accessing a specific row and column, minstrel correctly does a bounds check which, on the surface, appears to handle the case where mi->n_rates < 2. However, mi->sample_idx is actually defined as an unsigned, so the right hand side is taken to be a huge positive number when negative, and the check will always fail. Consequently, the RC will overrun the array and cause random memory corruption when communicating with a peer that has only a single rate. The max value of mi->sample_idx is around 25 so casting to int should have no ill effects. Without the change, uptime is a few minutes under load with an AP that has a single hard-coded rate, and both the AP and STA could potentially crash. With the change, both lasted 12 hours with a steady load. Thanks to Ognjen Maric for providing the single-rate clue so I could reproduce this. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=12490 on the regression list (also http://bugzilla.kernel.org/show_bug.cgi?id=13000). Cc: stable@kernel.org Reported-by: Sergey S. Kostyliov <rathamahata@gmail.com> Reported-by: Ognjen Maric <ognjen.maric@gmail.com> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
