commit b1faf5666438090a4dc4fceac8502edc7788b7e3 upstream.
Correct sk_forward_alloc handling for error_queue would need to use a
backlog of frames that softirq handler could not deliver because socket
is owned by user thread. Or extend backlog processing to be able to
process normal and error packets.
Another possibility is to not use mem charge for error queue, this is
what I implemented in this patch.
Note: this reverts commit 29030374
(net: fix sk_forward_alloc corruptions), since we dont need to lock
socket anymore.
Cc: 单卫 <shanwei88@gmail.com>
commit 2903037400a26e7c0cc93ab75a7d62abfacdf485 upstream.
As David found out, sock_queue_err_skb() should be called with socket
lock hold, or we risk sk_forward_alloc corruption, since we use non
atomic operations to update this field.
This patch adds bh_lock_sock()/bh_unlock_sock() pair to three spots.
(BH already disabled)
1) skb_tstamp_tx()
2) Before calling ip_icmp_error(), in __udp4_lib_err()
3) Before calling ipv6_icmp_error(), in __udp6_lib_err()
Reported-by: Anton Blanchard <anton@samba.org>
commit 5fe46e9d733f19a880ef7e516002bd4c2b833e14 upstream.
If NFSv4 client send a request before connect, or the old connection was broken
because a ETIMEOUT error catched by call_status, ->send_request will return
ENOSOCK, but rpc layer can not deal with it, so make sure ->send_request can
translate ENOSOCK into ENOCONN.
Signed-off-by: Bian Naimeng <biannm@cn.fujitsu.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Chuck Lever <chuck.lever@oracle.com>
commit 2fefb8a09e7ed251ae8996e0c69066e74c5aa560 upstream.
There's no reason I can see that we need to call sv_shutdown between
closing the two lists of sockets.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 61c8504c428edcebf23b97775a129c5b393a302b upstream.
The pool_to and to_pool fields of the global svc_pool_map are freed on
shutdown, but are initialized in nfsd startup only in the
SVC_POOL_PERCPU and SVC_POOL_PERNODE cases.
They *are* initialized to zero on kernel startup. So as long as you use
only SVC_POOL_GLOBAL (the default), this will never be a problem.
You're also OK if you only ever use SVC_POOL_PERCPU or SVC_POOL_PERNODE.
However, the following sequence events leads to a double-free:
1. set SVC_POOL_PERCPU or SVC_POOL_PERNODE
2. start nfsd: both fields are initialized.
3. shutdown nfsd: both fields are freed.
4. set SVC_POOL_GLOBAL
5. start nfsd: the fields are left untouched.
6. shutdown nfsd: now we try to free them again.
Step 4 is actually unnecessary, since (for some bizarre reason), nfsd
automatically resets the pool mode to SVC_POOL_GLOBAL on shutdown.
commit 4203223a1aed862b4445fdcd260d6139603a51d9 upstream.
Fix the min and max bit lengths for AES-CTR (RFC3686) keys.
The number of bits in key spec is the key length (128/256)
plus 32 bits of nonce.
This change takes care of the "Invalid key length" errors
reported by setkey when specifying 288 bit keys for aes-ctr.
Signed-off-by: Tushar Gohad <tgohad@mvista.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Calvin Owens <jcalvinowens@gmail.com>
This one liner is part of upstream
commit 3701e51382a026cba10c60b03efabe534fba4ca4
Author: Jesse Gross <jesse@nicira.com>
vlan: Centralize handling of hardware acceleration.
The bulk of that commit is a rework of the hardware assisted vlan tagging
driver interface, and as such doesn't classify for -stable inclusion. The fix
that is needed is a part of that commit but can work independently of the
rest.
This patch can avoid panics on the 2.6.32.y -stable kernels and is in the same
spirit as mainline commits
66c46d7 gro: Reset dev pointer on reuse
6d152e2 gro: reset skb_iif on reuse
which are already in -stable.
For drivers using the vlan_gro_frags() interface, a packet with an invalid tci
leads to GRO_DROP and napi_reuse_skb(). The skb has to be sanitized before
being reused or we may send an skb with an invalid vlan_tci field up the stack
where it is not expected.
Signed-off-by: Benjamin Poirier <bpoirier@suse.de>
Cc: Jesse Gross <jesse@nicira.com>
commit e007b857e88097c96c45620bf3b04a4e309053d1 upstream.
MAC addresses have a fixed length. The current
policy allows passing < ETH_ALEN bytes, which
might result in reading beyond the buffer.
Signed-off-by: Eliad Peller <eliad@wizery.com>
commit 24ca9a847791fd53d9b217330b15f3c285827a18 upstream.
By returning '0' instead of 'EAGAIN' when the tests in xs_nospace() fail
to find evidence of socket congestion, we are making the RPC engine believe
that the message was incorrectly sent and so it disconnects the socket
instead of just retrying.
The bug appears to have been introduced by commit
5e3771ce2d6a69e10fcc870cdf226d121d868491 (SUNRPC: Ensure that xs_nospace
return values are propagated).
Reported-by: Andrew Cooper <andrew.cooper3@citrix.com>
Tested-by: Andrew Cooper <andrew.cooper3@citrix.com>
commit 0587102cf9f427c185bfdeb2cef41e13ee0264b1 upstream
Again basically cut and paste
Convert the main driver set to use the hooks for GICOUNT
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit a9cf73ea7ff78f52662c8658d93c226effbbedde upstream.
At this point, skb->data points to skb_transport_header.
So, headroom check is wrong.
For some case:bridge(UFO is on) + eth device(UFO is off),
there is no enough headroom for IPv6 frag head.
But headroom check is always false.
This will bring about data be moved to there prior to skb->head,
when adding IPv6 frag header to skb.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream.
The sunrpc layer keeps a cache of recently used credentials and
'unx_match' is used to find the credential which matches the current
process.
However unx_match allows a match when the cached credential has extra
groups at the end of uc_gids list which are not in the process group list.
So if a process with a list of (say) 4 group accesses a file and gains
access because of the last group in the list, then another process
with the same uid and gid, and a gid list being the first tree of the
gids of the original process tries to access the file, it will be
granted access even though it shouldn't as the wrong rpc credential
will be used.
Signed-off-by: NeilBrown <neilb@suse.de>
commit 53b0f08042f04813cd1a7473dacd3edfacb28eb3 upstream.
Ben Pfaff reported a kernel oops and provided a test program to
reproduce it.
https://kerneltrap.org/mailarchive/linux-netdev/2010/5/21/6277805
tc_fill_qdisc() should not be called for builtin qdisc, or it
dereference a NULL pointer to get device ifindex.
Fix is to always use tc_qdisc_dump_ignore() before calling
tc_fill_qdisc().
Reported-by: Ben Pfaff <blp@nicira.com>
commit 57a27e1d6a3bb9ad4efeebd3a8c71156d6207536 upstream.
When one of the SSID's length passed in a scan or sched_scan request
is larger than 255, there will be an overflow in the u8 that is used
to store the length before checking. This causes the check to fail
and we overrun the buffer when copying the SSID.
Fix this by checking the nl80211 attribute length before copying it to
the struct.
This is a follow up for the previous commit
208c72f4fe44fe09577e7975ba0e7fa0278f3d03, which didn't fix the problem
entirely.
Reported-by: Ido Yariv <ido@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
commit 7ac28817536797fd40e9646452183606f9e17f71 upstream.
A remote user can provide a small value for the command size field in
the command header of an l2cap configuration request, resulting in an
integer underflow when subtracting the size of the configuration request
header. This results in copying a very large amount of data via
memcpy() and destroying the kernel heap. Check for underflow.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
commit 8d03e971cf403305217b8e62db3a2e5ad2d6263f upstream.
Structures "l2cap_conninfo" and "rfcomm_conninfo" have one padding
byte each. This byte in "cinfo" is copied to userspace uninitialized.
Signed-off-by: Filip Palian <filip.palian@pjwstk.edu.pl>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
commit 0b760113a3a155269a3fba93a409c640031dd68f upstream.
If the NLM daemon is killed on the NFS server, we can currently end up
hanging forever on an 'unlock' request, instead of aborting. Basically,
if the rpcbind request fails, or the server keeps returning garbage, we
really want to quit instead of retrying.
Tested-by: Vasily Averin <vvs@sw.ru>
commit bba14de98753cb6599a2dae0e520714b2153522d upstream.
Lower SCM_MAX_FD from 255 to 253 so that allocations for scm_fp_list are
halved. (commit f8d570a4 added two pointers in this structure)
scm_fp_dup() should not copy whole structure (and trigger kmemcheck
warnings), but only the used part. While we are at it, only allocate
needed size.
commit 7f81e25befdfb3272345a2e775f520e1d515fa20 upstream.
x25_find_listener does not check that the amount of call user data given
in the skb is big enough in per-socket comparisons, hence buffer
overreads may occur. Fix this by adding a check.
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Acked-by: Andrew Hendry <andrew.hendry@gmail.com>
commit 1b9ca0272ffae212e726380f66777b30a56ed7a5 upstream.
Incorrect variable was used in validating the akm_suites array from
NL80211_ATTR_AKM_SUITES. In addition, there was no explicit
validation of the array length (we only have room for
NL80211_MAX_NR_AKM_SUITES).
This can result in a buffer write overflow for stack variables with
arbitrary data from user space. The nl80211 commands using the affected
functionality require GENL_ADMIN_PERM, so this is only exposed to admin
users.
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
commit aa3d7eef398dd4f29045e9889b817d5161afe03e upstream.
During the association, the regulatory is updated by country IE
that reaps the previously found beacons. The impact is that
after a STA disconnects *or* when for any reason a regulatory
domain change happens the beacon hint flag is not cleared
therefore preventing future beacon hints to be learned.
This is important as a regulatory domain change or a restore
of regulatory settings would set back the passive scan and no-ibss
flags on the channel. This is the right place to do this given that
it covers any regulatory domain change.
Reviewed-by: Luis R. Rodriguez <mcgrof@gmail.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
commit c9ffb05ca5b5098d6ea468c909dd384d90da7d54 upstream.
msize represents the maximum PDU size that includes P9_IOHDRSZ.
Signed-off-by: Venkateswararao Jujjuri "<jvrao@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
commit 5034990e28efb2d232ee82443a9edd62defd17ba upstream.
free the fid even in case of failed clunk.
commit b85f7d92d7bd7e3298159e8b1eed8cb8cbbb0348 upstream.
There was a BUG_ON to protect against a bad id which could be dealt with
more gracefully.
Reported-by: Natalie Orlin <norlin@us.ibm.com>
commit d1dc7abf2fafa34b0ffcd070fd59405aa9c0a4d8 upstream.
Suppose that several linear skbs of the same flow were received by GRO. They
were thus merged into one skb with a frag_list. Then a new skb of the same flow
arrives, but it is a paged skb with data starting in its frags[].
Before adding the skb to the frag_list skb_gro_receive() will of course adjust
the skb to throw away the headers. It correctly modifies the page_offset and
size of the frag, but it leaves incorrect information in the skb:
->data_len is not decreased at all.
->len is decreased only by headlen, as if no change were done to the frag.
Later in a receiving process this causes skb_copy_datagram_iovec() to return
-EFAULT and this is seen in userspace as the result of the recv() syscall.
In practice the bug can be reproduced with the sfc driver. By default the
driver uses an adaptive scheme when it switches between using
napi_gro_receive() (with skbs) and napi_gro_frags() (with pages). The bug is
reproduced when under rx load with enough successful GRO merging the driver
decides to switch from the former to the latter.
Manual control is also possible, so reproducing this is easy with netcat:
- on machine1 (with sfc): nc -l 12345 > /dev/null
- on machine2: nc machine1 12345 < /dev/zero
- on machine1:
echo 1 > /sys/module/sfc/parameters/rx_alloc_method # use skbs
echo 2 > /sys/module/sfc/parameters/rx_alloc_method # use pages
- See that nc has quit suddenly.
[v2: Modified by Eric Dumazet to avoid advancing skb->data past the end
and to use a temporary variable.]
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
commit 0aa68271510ae2b221d4b60892103837be63afe4 upstream.
Currently we disallow GSO packets on the IPv6 forward path.
This patch fixes this.
Note that I discovered that our existing GSO MTU checks (e.g.,
IPv4 forwarding) are buggy in that they skip the check altogether,
when they really should be checking gso_size + header instead.
I have also been lazy here in that I haven't bothered to segment
the GSO packet by hand before generating an ICMP message. Someone
should add that to be 100% correct.
Reported-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Apollon Oikonomopoulos <apoikos@gmail.com>
Signed-off-by: Faidon Liambotis <paravoid@debian.org>
Fix broken backport for IPv6 tunnels in 2.6.32-longterm kernels.
upstream commit d5aa407f59f5b83d2c50ec88f5bf56d40f1f8978 ("tunnels: fix
netns vs proto registration ordering") , which was included in
2.6.32.44-longterm, was not backported correctly, and results in a NULL
pointer dereference in ip6_tunnel.c for longterm kernels >=2.6.32.44
Use [un]register_pernet_gen_device() instead of
[un]register_pernet_device() to fix it.
Signed-off-by: Stratos Psomadakis <psomas@gentoo.org>
Cc: Wolfgang Walter <wolfgang.walter@stwm.de>
Cc: Tim Gardner <tim.gardner@canonical.com>
Cc: Andy Whitcroft <apw@canonical.com>
commit fbe5e29ec1886967255e76946aaf537b8cc9b81e upstream.
This oops have been already fixed with commit
27141666b69f535a4d63d7bc6d9e84ee5032f82a
atm: [br2684] Fix oops due to skb->dev being NULL
It happens that if a packet arrives in a VC between the call to open it on
the hardware and the call to change the backend to br2684, br2684_regvcc
processes the packet and oopses dereferencing skb->dev because it is
NULL before the call to br2684_push().
but have been introduced again with commit
b6211ae7f2e56837c6a4849316396d1535606e90
atm: Use SKB queue and list helpers instead of doing it by-hand.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
commit a08af810cdc29d2ca930e8a869d3d01744c392d8 upstream.
Reported-by: Pascal Hambourg <pascal@plouf.fr.eu.org>
Signed-off-by: Chas Williams <chas@cmf.nrl.navy.mil>
Computers have become a lot faster since we compromised on the
partial MD4 hash which we use currently for performance reasons.
MD5 is a much safer choice, and is inline with both RFC1948 and
other ISS generators (OpenBSD, Solaris, etc.)
Furthermore, only having 24-bits of the sequence number be truly
unpredictable is a very serious limitation. So the periodic
regeneration and 8-bit counter have been removed. We compute and
use a full 32-bit sequence number.
For ipv6, DCCP was found to use a 32-bit truncated initial sequence
number (it needs 43-bits) and that is fixed here as well.
Reported-by: Dan Kaminsky <dan@doxpara.com>
Tested-by: Willy Tarreau <w@1wt.eu>
commit 2e302ebfeac04beb5a5d6af1ac583c6a1fb76d1a upstream.
in routed mode, we don't have a hardware address so netdev_ops doesnt
need to validate our hardware address via .ndo_validate_addr
Reported-by: Manuel Fuentes <mfuentes@agenciaefe.com>
Signed-off-by: Chas Williams - CONTRACTOR <chas@cmf.nrl.navy.mil>
Cc: Pascal Hambourg <pascal@plouf.fr.eu.org>
commit d5aa407f59f5b83d2c50ec88f5bf56d40f1f8978 upstream.
Same stuff as in ip_gre patch: receive hook can be called before netns
setup is done, oopsing in net_generic().
commit e924960dacdf85d118a98c7262edf2f99c3015cf upstream.
commit c2892f02712e9516d72841d5c019ed6916329794 upstream.
GRE protocol receive hook can be called right after protocol addition is done.
If netns stuff is not yet initialized, we're going to oops in
net_generic().
This is remotely oopsable if ip_gre is compiled as module and packet
comes at unfortunate moment of module loading.
[dannf: backported to Debian's 2.6.32]
commit ebc63e531cc6a457595dd110b07ac530eae788c3 upstream.
After commit 3262c816a3d7fb1eaabce633caa317887ed549ae "[PATCH] knfsd:
split svc_serv into pools", svc_delete_xprt (then svc_delete_socket) no
longer removed its xpt_ready (then sk_ready) field from whatever list it
was on, noting that there was no point since the whole list was about to
be destroyed anyway.
That was mostly true, but forgot that a few svc_xprt_enqueue()'s might
still be hanging around playing with the about-to-be-destroyed list, and
could get themselves into trouble writing to freed memory if we left
this xprt on the list after freeing it.
(This is actually functionally identical to a patch made first by Ben
Greear, but with more comments.)
Cc: gnb@fmeh.org
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Ben Greear <greearb@candelatech.com>
commit 676b58c27475a9defccc025fea1cbd2b141ee539 upstream.
A panic was observed when the device is failed to resume properly,
and there are no running interfaces. ieee80211_reconfig tries
to restart STA timers on unassociated state.
commit 0c03150e7ea8f7fcd03cfef29385e0010b22ee92 upstream.
A bridge topology with three systems:
| A(2) |--| B(1) |
| C(3) |
What is supposed to happen:
* bridge with the lowest ID is elected root (for example: B)
* C detects that A->C is higher cost path and puts in blocking state
What happens. Bridge with lowest id (B) is elected correctly as
root and things start out fine initially. But then config BPDU
doesn't get transmitted from A -> C. Because of that
the link from A-C is transistioned to the forwarding state.
The root cause of this is that the configuration messages
is generated with bogus message age, and dropped before
sending.
In the standardmessage_age is supposed to be:
the time since the generation of the Configuration BPDU by
the Root that instigated the generation of this Configuration BPDU.
Reimplement this by recording the timestamp (age + jiffies) when
recording config information. The old code incorrectly used the time
elapsed on the ageing timer which was incorrect.
See also:
https://bugzilla.vyatta.com/show_bug.cgi?id=7164
commit ec0dd267bf7d08cb30e321e45a75fd40edd7e528 upstream.
Because struct rpcbind_args *map was declared static, if two
threads entered this method at the same time, the values
assigned to map could be sent two two differen tasks.
This could cause all sorts of problems, include use-after-free
and double-free of memory.
Fix this by removing the static declaration so that the map
pointer is on the stack.
Signed-off-by: Ben Greear <greearb@candelatech.com>
commit b55c59892e1f3b6c7d4b9ccffb4263e1486fb990 upstream.
Since rpc_killall_tasks may modify the rpc_task's tk_action field
without any locking, we need to be careful when dereferencing it.
[ Upstream commit 9cfaa8def1c795a512bc04f2aec333b03724ca2e ]
Consider this scenario: When the size of the first received udp packet
is bigger than the receive buffer, MSG_TRUNC bit is set in msg->msg_flags.
However, if checksum error happens and this is a blocking socket, it will
goto try_again loop to receive the next packet. But if the size of the
next udp packet is smaller than receive buffer, MSG_TRUNC flag should not
be set, but because MSG_TRUNC bit is not cleared in msg->msg_flags before
receive the next packet, MSG_TRUNC is still set, which is wrong.
Fix this problem by clearing MSG_TRUNC flag when starting over for a
new packet.
Signed-off-by: Xufeng Zhang <xufeng.zhang@windriver.com>
[ Upstream commit 32c90254ed4a0c698caa0794ebb4de63fcc69631 ]
udpv6_recvmsg() function is not using the correct variable to determine
whether or not the socket is in non-blocking operation, this will lead
to unexpected behavior when a UDP checksum error occurs.
Consider a non-blocking udp receive scenario: when udpv6_recvmsg() is
called by sock_common_recvmsg(), MSG_DONTWAIT bit of flags variable in
udpv6_recvmsg() is cleared by "flags & ~MSG_DONTWAIT" in this call:
err = sk->sk_prot->recvmsg(iocb, sk, msg, size, flags & MSG_DONTWAIT,
flags & ~MSG_DONTWAIT, &addr_len);
i.e. with udpv6_recvmsg() getting these values:
int noblock = flags & MSG_DONTWAIT
int flags = flags & ~MSG_DONTWAIT
So, when udp checksum error occurs, the execution will go to
csum_copy_err, and then the problem happens:
csum_copy_err:
if (flags & MSG_DONTWAIT)
return -EAGAIN;
goto try_again;
But it will always go to try_again as MSG_DONTWAIT has been cleared
from flags at call time -- only noblock contains the original value
of MSG_DONTWAIT, so the test should be:
if (noblock)
return -EAGAIN;
This is also consistent with what the ipv4/udp code does.
[ Upstream commit d0733d2e29b652b2e7b1438ececa732e4eed98eb ]
Check against mistakenly passing in IPv6 addresses (which would result
in an INADDR_ANY bind) or similar incompatible sockaddrs.
Signed-off-by: Marcus Meissner <meissner@suse.de>
Cc: Reinhard Max <max@suse.de>
[ Upstream commit 13fcb7bd322164c67926ffe272846d4860196dc6 ]
In 2.6.27, commit 393e52e33c6c2 (packet: deliver VLAN TCI to userspace)
added a small information leak.
Add padding field and make sure its zeroed before copy to user.
CC: Patrick McHardy <kaber@trash.net>
[ Upstream commit 6c4a5cb219520c7bc937ee186ca53f03733bd09f ]
A mis-configured filter can spam the logs with lots of stack traces.
Rate-limit the warnings and add printout of the bogus filter information.
Original-patch-by: Ben Greear <greearb@candelatech.com>
[ Upstream commit eeb1497277d6b1a0a34ed36b97e18f2bd7d6de0d ]
A malicious user or buggy application can inject code and trigger an
infinite loop in inet_diag_bc_audit()
Also make sure each instruction is aligned on 4 bytes boundary, to avoid
unaligned accesses.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
commit 5afa9133cfe67f1bfead6049a9640c9262a7101c upstream.
Fix a couple of instances where we were exiting the RPC client on
arbitrary signals. We should only do so on fatal signals.
commit 1ed2f73d90fb49bcf5704aee7e9084adb882bfc5 upstream.
The mask indicates the bits one wants to zero out, so it needs to be
inverted before applying to the original TOS field.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
commit 4319cc0cf5bb894b7368008cdf6dd20eb8868018 upstream.
The IPv6 header is not zeroed out in alloc_skb so we must initialize
it properly unless we want to see IPv6 packets with random TOS fields
floating around. The current implementation resets the flow label
but this could be changed if deemed necessary.
We stumbled upon this issue when trying to apply a mangle rule to
the RST packet generated by the REJECT target module.
commit 208c72f4fe44fe09577e7975ba0e7fa0278f3d03 upstream.
In both trigger_scan and sched_scan operations, we were checking for
the SSID length before assigning the value correctly. Since the
memory was just kzalloc'ed, the check was always failing and SSID with
over 32 characters were allowed to go through.
This was causing a buffer overflow when copying the actual SSID to the
proper place.
This bug has been there since 2.6.29-rc4.
single fragment
commit 9e2dcf72023d1447f09c47d77c99b0c49659e5ce upstream.
When an ICMPV6_PKT_TOOBIG message is received with a MTU below 1280,
all further packets include a fragment header.
Unlike regular defragmentation, conntrack also needs to "reassemble"
those fragments in order to obtain a packet without the fragment
header for connection tracking. Currently nf_conntrack_reasm checks
whether a fragment has either IP6_MF set or an offset != 0, which
makes it ignore those fragments.
Remove the invalid check and make reassembly handle fragment queues
containing only a single fragment.
Reported-and-tested-by: Ulrich Weber <uweber@astaro.com>
