ping_v6_sendmsg currently returns 0 on success. It should return
the number of bytes written instead.
Bug: 9469865
Bug 1412141
Change-Id: I14aad6018f0c3fd92dad315bc3ade04c0b3982e0
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
(cherry picked from commit 5f0fd6105f491b8b435863e98f7e96d617e3da84)
Reviewed-on: http://git-master/r/336272
(cherry picked from commit 6d931659abae7575ee64b16e3c2f3ee8bd350dd1)
Reviewed-on: http://git-master/r/353233
Reviewed-by: Nitin Bindal <nbindal@nvidia.com>
Tested-by: Nitin Bindal <nbindal@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Bug: 9469865
Bug 1412141
Change-Id: I5e9db559d22e35d27fa1df948b70c70ed8b42115
(cherry picked from commit 3a018d2e8fc2910e5fb2077cde81cad659e2c7f9)
Reviewed-on: http://git-master/r/336271
(cherry picked from commit 71e8c301dce8ee85ee26eedb808b939084f14b45)
Reviewed-on: http://git-master/r/353232
[net-next commit c26d6b46da3ee86fa8a864347331e5513ca84c2b]
If we don't need scope id, we should initialize it to zero.
Same for ->sin6_flowinfo.
Bug 1412141
Change-Id: I74764edf3d0567f5ae094b2e83484cdfe05f6098
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
(cherry picked from commit 14e41a18688ec8d52ea3163f7898455b52365854)
Reviewed-on: http://git-master/r/336270
(cherry picked from commit 68f4261657194f51c9d954f259825c76a72a00e2)
Reviewed-on: http://git-master/r/353231
[backport of net-next 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67]
This adds the ability to send ICMPv6 echo requests without a
raw socket. The equivalent ability for ICMPv4 was added in
2011.
Instead of having separate code paths for IPv4 and IPv6, make
most of the code in net/ipv4/ping.c dual-stack and only add a
few IPv6-specific bits (like the protocol definition) to a new
net/ipv6/ping.c. Hopefully this will reduce divergence and/or
duplication of bugs in the future.
Caveats:
- Setting options via ancillary data (e.g., using IPV6_PKTINFO
to specify the outgoing interface) is not yet supported.
- There are no separate security settings for IPv4 and IPv6;
everything is controlled by /proc/net/ipv4/ping_group_range.
- The proc interface does not yet display IPv6 ping sockets
properly.
Tested with a patched copy of ping6 and using raw socket calls.
Compiles and works with all of CONFIG_IPV6={n,m,y}.
Bug 1412141
Change-Id: I0081b4654dd54b12c8f233e00e18943582aa2142
[lorenzo@google.com: backported to 3.4]
(cherry picked from commit 1f0675844e3b63a765e5bd32bc5af051ccd951c0)
Reviewed-on: http://git-master/r/336269
(cherry picked from commit 36c1b848f9c0cbcefa6fc731f84ae6ddc3536be6)
Reviewed-on: http://git-master/r/353230
Add cmdline into /proc/net/{tcp,tcp6,udp,udp6} files.
Get process's cmdline from a sock's corresponding inode pointer,
so that cmdline can't be used by Android active-standby app
to find the corresponding package name.
Resolve "BUG: scheduling while atomic" issue when
sk_get_waiting_task is being called.
Bug 1185001
Bug 1342554
Change-Id: Idc8651e4bb85b8a152dfade9689a719f7d72687d
(cherry picked from commit 5dcfe4f561bd8d1767e0938dfd7565b2b7718478)
Change-Id: I1673d56751a8a95b988b325b3857c8a5fe4c78ce
(cherry picked from commit 4516e7c330bb4c5da5020df0d2cc1cb5e9274d9f)
Signed-off-by: Chun Xu <chunx@nvidia.com>
Reviewed-on: http://git-master/r/336174
Reviewed-by: Harry Hong <hhong@nvidia.com>
Tested-by: Harry Hong <hhong@nvidia.com>
In the past it would always ignore interfaces with loopback addresses.
Now we just treat them like any other.
This also helps with writing tests that check for the presence
of the qtaguid module.
Bug 1343922
Change-Id: I55d31277056d24172d22d32ad26c47dc8c55250a
Signed-off-by: JP Abgrall <jpa@google.com>
Reviewed-on: http://git-master/r/270087
(cherry picked from commit 5d927cc305aa8d0c2e6af9fedda9f5b10d378e16)
Reviewed-on: http://git-master/r/272968
Reviewed-by: Jun Su <juns@nvidia.com>
Reviewed-by: Bibhay Ranjan <bibhayr@nvidia.com>
Tested-by: Bibhay Ranjan <bibhayr@nvidia.com>
Bug 1348440
Change-Id: If25c49f027dc2a69642f7ed4733e965962b2a5a2
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
[ Upstream commit 8cb3b9c3642c0263d48f31d525bcee7170eedc20 ]
The "pvc" struct has a hole after pvc.sap_family which is not cleared.
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit ff862a4668dd6dba962b1d2d8bd344afa6375683 ]
This is inspired by a5cc68f3d6 "af_key: fix info leaks in notify
messages". There are some struct members which don't get initialized
and could disclose small amounts of private information.
Acked-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit a0db856a95a29efb1c23db55c02d9f0ff4f0db48 ]
Make sure the reserved fields, and padding (if any), are
fully initialized.
Based upon a patch by Dan Carpenter and feedback from
Joe Perches.
[ Upstream commit 905a6f96a1b18e490a75f810d733ced93c39b0e5 ]
Otherwise we end up dereferencing the already freed net->ipv6.mrt pointer
which leads to a panic (from Srivatsa S. Bhat):
BUG: unable to handle kernel paging request at ffff882018552020
IP: [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
PGD 290a067 PUD 207ffe0067 PMD 207ff1d067 PTE 8000002018552060
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: ebtable_nat ebtables nfs fscache nf_conntrack_ipv4 nf_defrag_ipv4 ipt_REJECT xt_CHECKSUM iptable_mangle iptable_filter ip_tables nfsd lockd nfs_acl exportfs auth_rpcgss autofs4 sunrpc 8021q garp bridge stp llc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter
+ip6_tables ipv6 vfat fat vhost_net macvtap macvlan vhost tun kvm_intel kvm uinput iTCO_wdt iTCO_vendor_support cdc_ether usbnet mii microcode i2c_i801 i2c_core lpc_ich mfd_core shpchp ioatdma dca mlx4_core be2net wmi acpi_cpufreq mperf ext4 jbd2 mbcache dm_mirror dm_region_hash dm_log dm_mod
CPU: 0 PID: 7 Comm: kworker/u33:0 Not tainted 3.11.0-rc1-ea45e-a #4
Hardware name: IBM -[8737R2A]-/00Y2738, BIOS -[B2E120RUS-1.20]- 11/30/2012
Workqueue: netns cleanup_net
task: ffff8810393641c0 ti: ffff881039366000 task.ti: ffff881039366000
RIP: 0010:[<ffffffffa0366b02>] [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
RSP: 0018:ffff881039367bd8 EFLAGS: 00010286
RAX: ffff881039367fd8 RBX: ffff882018552000 RCX: dead000000200200
RDX: 0000000000000000 RSI: ffff881039367b68 RDI: ffff881039367b68
RBP: ffff881039367bf8 R08: ffff881039367b68 R09: 2222222222222222
R10: 2222222222222222 R11: 2222222222222222 R12: ffff882015a7a040
R13: ffff882014eb89c0 R14: ffff8820289e2800 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88103fc00000(0000) knlGS:0000000000000000
CR2: ffff882018552020 CR3: 0000000001c0b000 CR4: 00000000000407f0
Stack:
ffff881039367c18 ffff882014eb89c0 ffff882015e28c00 0000000000000000
ffff881039367c18 ffffffffa034d9d1 ffff8820289e2800 ffff882014eb89c0
ffff881039367c58 ffffffff815bdecb ffffffff815bddf2 ffff882014eb89c0
Call Trace:
[<ffffffffa034d9d1>] rawv6_close+0x21/0x40 [ipv6]
[<ffffffff815bdecb>] inet_release+0xfb/0x220
[<ffffffff815bddf2>] ? inet_release+0x22/0x220
[<ffffffffa032686f>] inet6_release+0x3f/0x50 [ipv6]
[<ffffffff8151c1d9>] sock_release+0x29/0xa0
[<ffffffff81525520>] sk_release_kernel+0x30/0x70
[<ffffffffa034f14b>] icmpv6_sk_exit+0x3b/0x80 [ipv6]
[<ffffffff8152fff9>] ops_exit_list+0x39/0x60
[<ffffffff815306fb>] cleanup_net+0xfb/0x1a0
[<ffffffff81075e3a>] process_one_work+0x1da/0x610
[<ffffffff81075dc9>] ? process_one_work+0x169/0x610
[<ffffffff81076390>] worker_thread+0x120/0x3a0
[<ffffffff81076270>] ? process_one_work+0x610/0x610
[<ffffffff8107da2e>] kthread+0xee/0x100
[<ffffffff8107d940>] ? __init_kthread_worker+0x70/0x70
[<ffffffff8162a99c>] ret_from_fork+0x7c/0xb0
Code: 20 48 89 5d e8 4c 89 65 f0 4c 89 6d f8 66 66 66 66 90 4c 8b 67 30 49 89 fd e8 db 3c 1e e1 49 8b 9c 24 90 08 00 00 48 85 db 74 06 <4c> 39 6b 20 74 20 bb f3 ff ff ff e8 8e 3c 1e e1 89 d8 4c 8b 65
RIP [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
RSP <ffff881039367bd8>
Reported-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Tested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
[ Upstream commit c5c7774d7eb4397891edca9ebdf750ba90977a69 ]
In commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86
(refactor sctp_outq_teardown to insure proper re-initalization)
we modified sctp_outq_teardown to use sctp_outq_init to fully re-initalize the
outq structure. Steve West recently asked me why I removed the q->error = 0
initalization from sctp_outq_teardown. I did so because I was operating under
the impression that sctp_outq_init would properly initalize that value for us,
but it doesn't. sctp_outq_init operates under the assumption that the outq
struct is all 0's (as it is when called from sctp_association_init), but using
it in __sctp_outq_teardown violates that assumption. We should do a memset in
sctp_outq_init to ensure that the entire structure is in a known state there
instead.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: "West, Steve (NSN - US/Fort Worth)" <steve.west@nsn.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: netdev@vger.kernel.org
CC: davem@davemloft.net
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 651e92716aaae60fc41b9652f54cb6803896e0da ]
Limit the min/max value passed to the
/proc/sys/net/ipv4/tcp_syn_retries.
Signed-off-by: Michal Tesar <mtesar@redhat.com>
commit 6b0f32745dcfba01d7be33acd1b40306c7a914c6 upstream.
The duplicate retransmission detection code in mac80211
erroneously attempts to do the check for every frame,
even frames that don't have a sequence control field or
that don't use it (QoS-Null frames.)
This is problematic because it causes the code to access
data beyond the end of the SKB and depending on the data
there will drop packets erroneously.
Correct the code to not do duplicate detection for such
frames.
I found this error while testing AP powersave, it lead
to retransmitted PS-Poll frames being dropped entirely
as the data beyond the end of the SKB was always zero.
commit a0ec570f4f69c4cb700d743a915096c2c8f56a99 upstream.
These two events were sent to the default network
namespace.
This caused AP mode in a non-default netns to not
work correctly. Mgmt tx status was multicasted to
a different (default) netns instead of the one the
AP was in.
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
[ Upstream commit 3e3aac497513c669e1c62c71e1d552ea85c1d974 ]
egress_priority_map[] hash table updates are protected by rtnl,
and we never remove elements until device is dismantled.
We have to make sure that before inserting an new element in hash table,
all its fields are committed to memory or else another cpu could
find corrupt values and crash.
Cc: Patrick McHardy <kaber@trash.net>
[ Upstream commit 110ecd69a9feea82a152bbf9b12aba57e6396883 ]
p9_release_pages() would attempt to dereference one value past the end of
pages[]. This would cause the following crashes:
[ 6293.171817] BUG: unable to handle kernel paging request at ffff8807c96f3000
[ 6293.174146] IP: [<ffffffff8412793b>] p9_release_pages+0x3b/0x60
[ 6293.176447] PGD 79c5067 PUD 82c1e3067 PMD 82c197067 PTE 80000007c96f3060
[ 6293.180060] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
[ 6293.180060] Modules linked in:
[ 6293.180060] CPU: 62 PID: 174043 Comm: modprobe Tainted: G W 3.10.0-next-20130710-sasha #3954
[ 6293.180060] task: ffff8807b803b000 ti: ffff880787dde000 task.ti: ffff880787dde000
[ 6293.180060] RIP: 0010:[<ffffffff8412793b>] [<ffffffff8412793b>] p9_release_pages+0x3b/0x60
[ 6293.214316] RSP: 0000:ffff880787ddfc28 EFLAGS: 00010202
[ 6293.214316] RAX: 0000000000000001 RBX: ffff8807c96f2ff8 RCX: 0000000000000000
[ 6293.222017] RDX: ffff8807b803b000 RSI: 0000000000000001 RDI: ffffea001c7e3d40
[ 6293.222017] RBP: ffff880787ddfc48 R08: 0000000000000000 R09: 0000000000000000
[ 6293.222017] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001
[ 6293.222017] R13: 0000000000000001 R14: ffff8807cc50c070 R15: ffff8807cc50c070
[ 6293.222017] FS: 00007f572641d700(0000) GS:ffff8807f3600000(0000) knlGS:0000000000000000
[ 6293.256784] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 6293.256784] CR2: ffff8807c96f3000 CR3: 00000007c8e81000 CR4: 00000000000006e0
[ 6293.256784] Stack:
[ 6293.256784] ffff880787ddfcc8 ffff880787ddfcc8 0000000000000000 ffff880787ddfcc8
[ 6293.256784] ffff880787ddfd48 ffffffff84128be8 ffff880700000002 0000000000000001
[ 6293.256784] ffff8807b803b000 ffff880787ddfce0 0000100000000000 0000000000000000
[ 6293.256784] Call Trace:
[ 6293.256784] [<ffffffff84128be8>] p9_virtio_zc_request+0x598/0x630
[ 6293.256784] [<ffffffff8115c610>] ? wake_up_bit+0x40/0x40
[ 6293.256784] [<ffffffff841209b1>] p9_client_zc_rpc+0x111/0x3a0
[ 6293.256784] [<ffffffff81174b78>] ? sched_clock_cpu+0x108/0x120
[ 6293.256784] [<ffffffff84122a21>] p9_client_read+0xe1/0x2c0
[ 6293.256784] [<ffffffff81708a90>] v9fs_file_read+0x90/0xc0
[ 6293.256784] [<ffffffff812bd073>] vfs_read+0xc3/0x130
[ 6293.256784] [<ffffffff811a78bd>] ? trace_hardirqs_on+0xd/0x10
[ 6293.256784] [<ffffffff812bd5a2>] SyS_read+0x62/0xa0
[ 6293.256784] [<ffffffff841a1a00>] tracesys+0xdd/0xe2
[ 6293.256784] Code: 66 90 48 89 fb 41 89 f5 48 8b 3f 48 85 ff 74 29 85 f6 74 25 45 31 e4 66 0f 1f 84 00 00 00 00 00 e8 eb 14 12 fd 41 ff c4 49 63 c4 <48> 8b 3c c3 48 85 ff 74 05 45 39 e5 75 e7 48 83 c4 08 5b 41 5c
[ 6293.256784] RIP [<ffffffff8412793b>] p9_release_pages+0x3b/0x60
[ 6293.256784] RSP <ffff880787ddfc28>
[ 6293.256784] ---[ end trace 50822ee72cd360fc ]---
[ Upstream commit 1eb4f758286884e7566627164bca4c4a16952a83 ]
We could end up expiring a route which is part of an ecmp route set. Doing
so would invalidate the rt->rt6i_nsiblings calculations and could provoke
the following panic:
[ 80.144667] ------------[ cut here ]------------
[ 80.145172] kernel BUG at net/ipv6/ip6_fib.c:733!
[ 80.145172] invalid opcode: 0000 [#1] SMP
[ 80.145172] Modules linked in: 8021q nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables
+snd_hda_intel snd_hda_codec snd_hwdep snd_seq snd_seq_device snd_pcm snd_page_alloc snd_timer virtio_balloon snd soundcore i2c_piix4 i2c_core virtio_net virtio_blk
[ 80.145172] CPU: 1 PID: 786 Comm: ping6 Not tainted 3.10.0+ #118
[ 80.145172] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 80.145172] task: ffff880117fa0000 ti: ffff880118770000 task.ti: ffff880118770000
[ 80.145172] RIP: 0010:[<ffffffff815f3b5d>] [<ffffffff815f3b5d>] fib6_add+0x75d/0x830
[ 80.145172] RSP: 0018:ffff880118771798 EFLAGS: 00010202
[ 80.145172] RAX: 0000000000000000 RBX: 0000000000000000 RCX: ffff88011350e480
[ 80.145172] RDX: ffff88011350e238 RSI: 0000000000000004 RDI: ffff88011350f738
[ 80.145172] RBP: ffff880118771848 R08: ffff880117903280 R09: 0000000000000001
[ 80.145172] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88011350f680
[ 80.145172] R13: ffff880117903280 R14: ffff880118771890 R15: ffff88011350ef90
[ 80.145172] FS: 00007f02b5127740(0000) GS:ffff88011fd00000(0000) knlGS:0000000000000000
[ 80.145172] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 80.145172] CR2: 00007f981322a000 CR3: 00000001181b1000 CR4: 00000000000006e0
[ 80.145172] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 80.145172] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 80.145172] Stack:
[ 80.145172] 0000000000000001 ffff880100000000 ffff880100000000 ffff880117903280
[ 80.145172] 0000000000000000 ffff880119a4cf00 0000000000000400 00000000000007fa
[ 80.145172] 0000000000000000 0000000000000000 0000000000000000 ffff88011350f680
[ 80.145172] Call Trace:
[ 80.145172] [<ffffffff815eeceb>] ? rt6_bind_peer+0x4b/0x90
[ 80.145172] [<ffffffff815ed985>] __ip6_ins_rt+0x45/0x70
[ 80.145172] [<ffffffff815eee35>] ip6_ins_rt+0x35/0x40
[ 80.145172] [<ffffffff815ef1e4>] ip6_pol_route.isra.44+0x3a4/0x4b0
[ 80.145172] [<ffffffff815ef34a>] ip6_pol_route_output+0x2a/0x30
[ 80.145172] [<ffffffff81616077>] fib6_rule_action+0xd7/0x210
[ 80.145172] [<ffffffff815ef320>] ? ip6_pol_route_input+0x30/0x30
[ 80.145172] [<ffffffff81553026>] fib_rules_lookup+0xc6/0x140
[ 80.145172] [<ffffffff81616374>] fib6_rule_lookup+0x44/0x80
[ 80.145172] [<ffffffff815edea3>] ip6_route_output+0x73/0xb0
[ 80.145172] [<ffffffff815dfdf3>] ip6_dst_lookup_tail+0x2c3/0x2e0
[ 80.145172] [<ffffffff813007b1>] ? list_del+0x11/0x40
[ 80.145172] [<ffffffff81082a4c>] ? remove_wait_queue+0x3c/0x50
[ 80.145172] [<ffffffff815dfe4d>] ip6_dst_lookup_flow+0x3d/0xa0
[ 80.145172] [<ffffffff815fda77>] rawv6_sendmsg+0x267/0xc20
[ 80.145172] [<ffffffff815a8a83>] inet_sendmsg+0x63/0xb0
[ 80.145172] [<ffffffff8128eb93>] ? selinux_socket_sendmsg+0x23/0x30
[ 80.145172] [<ffffffff815218d6>] sock_sendmsg+0xa6/0xd0
[ 80.145172] [<ffffffff81524a68>] SYSC_sendto+0x128/0x180
[ 80.145172] [<ffffffff8109825c>] ? update_curr+0xec/0x170
[ 80.145172] [<ffffffff81041d09>] ? kvm_clock_get_cycles+0x9/0x10
[ 80.145172] [<ffffffff810afd1e>] ? __getnstimeofday+0x3e/0xd0
[ 80.145172] [<ffffffff8152509e>] SyS_sendto+0xe/0x10
[ 80.145172] [<ffffffff8164efd9>] system_call_fastpath+0x16/0x1b
[ 80.145172] Code: fe ff ff 41 f6 45 2a 06 0f 85 ca fe ff ff 49 8b 7e 08 4c 89 ee e8 94 ef ff ff e9 b9 fe ff ff 48 8b 82 28 05 00 00 e9 01 ff ff ff <0f> 0b 49 8b 54 24 30 0d 00 00 40 00 89 83 14 01 00 00 48 89 53
[ 80.145172] RIP [<ffffffff815f3b5d>] fib6_add+0x75d/0x830
[ 80.145172] RSP <ffff880118771798>
[ 80.387413] ---[ end trace 02f20b7a8b81ed95 ]---
[ 80.390154] Kernel panic - not syncing: Fatal exception in interrupt
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 75a493e60ac4bbe2e977e7129d6d8cbb0dd236be ]
If the socket had an IPV6_MTU value set, ip6_append_data_mtu lost track
of this when appending the second frame on a corked socket. This results
in the following splat:
[37598.993962] ------------[ cut here ]------------
[37598.994008] kernel BUG at net/core/skbuff.c:2064!
[37598.994008] invalid opcode: 0000 [#1] SMP
[37598.994008] Modules linked in: tcp_lp uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_core videodev media vfat fat usb_storage fuse ebtable_nat xt_CHECKSUM bridge stp llc ipt_MASQUERADE nf_conntrack_netbios_ns nf_conntrack_broadcast ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat
+nf_nat_ipv4 nf_nat iptable_mangle nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i cxgb3 mdio libcxgbi ib_iser rdma_cm ib_addr iw_cm ib_cm ib_sa ib_mad ib_core iscsi_tcp libiscsi_tcp libiscsi
+scsi_transport_iscsi rfcomm bnep iTCO_wdt iTCO_vendor_support snd_hda_codec_conexant arc4 iwldvm mac80211 snd_hda_intel acpi_cpufreq mperf coretemp snd_hda_codec microcode cdc_wdm cdc_acm
[37598.994008] snd_hwdep cdc_ether snd_seq snd_seq_device usbnet mii joydev btusb snd_pcm bluetooth i2c_i801 e1000e lpc_ich mfd_core ptp iwlwifi pps_core snd_page_alloc mei cfg80211 snd_timer thinkpad_acpi snd tpm_tis soundcore rfkill tpm tpm_bios vhost_net tun macvtap macvlan kvm_intel kvm uinput binfmt_misc
+dm_crypt i915 i2c_algo_bit drm_kms_helper drm i2c_core wmi video
[37598.994008] CPU 0
[37598.994008] Pid: 27320, comm: t2 Not tainted 3.9.6-200.fc18.x86_64 #1 LENOVO 27744PG/27744PG
[37598.994008] RIP: 0010:[<ffffffff815443a5>] [<ffffffff815443a5>] skb_copy_and_csum_bits+0x325/0x330
[37598.994008] RSP: 0018:ffff88003670da18 EFLAGS: 00010202
[37598.994008] RAX: ffff88018105c018 RBX: 0000000000000004 RCX: 00000000000006c0
[37598.994008] RDX: ffff88018105a6c0 RSI: ffff88018105a000 RDI: ffff8801e1b0aa00
[37598.994008] RBP: ffff88003670da78 R08: 0000000000000000 R09: ffff88018105c040
[37598.994008] R10: ffff8801e1b0aa00 R11: 0000000000000000 R12: 000000000000fff8
[37598.994008] R13: 00000000000004fc R14: 00000000ffff0504 R15: 0000000000000000
[37598.994008] FS: 00007f28eea59740(0000) GS:ffff88023bc00000(0000) knlGS:0000000000000000
[37598.994008] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[37598.994008] CR2: 0000003d935789e0 CR3: 00000000365cb000 CR4: 00000000000407f0
[37598.994008] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[37598.994008] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[37598.994008] Process t2 (pid: 27320, threadinfo ffff88003670c000, task ffff88022c162ee0)
[37598.994008] Stack:
[37598.994008] ffff88022e098a00 ffff88020f973fc0 0000000000000008 00000000000004c8
[37598.994008] ffff88020f973fc0 00000000000004c4 ffff88003670da78 ffff8801e1b0a200
[37598.994008] 0000000000000018 00000000000004c8 ffff88020f973fc0 00000000000004c4
[37598.994008] Call Trace:
[37598.994008] [<ffffffff815fc21f>] ip6_append_data+0xccf/0xfe0
[37598.994008] [<ffffffff8158d9f0>] ? ip_copy_metadata+0x1a0/0x1a0
[37598.994008] [<ffffffff81661f66>] ? _raw_spin_lock_bh+0x16/0x40
[37598.994008] [<ffffffff8161548d>] udpv6_sendmsg+0x1ed/0xc10
[37598.994008] [<ffffffff812a2845>] ? sock_has_perm+0x75/0x90
[37598.994008] [<ffffffff815c3693>] inet_sendmsg+0x63/0xb0
[37598.994008] [<ffffffff812a2973>] ? selinux_socket_sendmsg+0x23/0x30
[37598.994008] [<ffffffff8153a450>] sock_sendmsg+0xb0/0xe0
[37598.994008] [<ffffffff810135d1>] ? __switch_to+0x181/0x4a0
[37598.994008] [<ffffffff8153d97d>] sys_sendto+0x12d/0x180
[37598.994008] [<ffffffff810dfb64>] ? __audit_syscall_entry+0x94/0xf0
[37598.994008] [<ffffffff81020ed1>] ? syscall_trace_enter+0x231/0x240
[37598.994008] [<ffffffff8166a7e7>] tracesys+0xdd/0xe2
[37598.994008] Code: fe 07 00 00 48 c7 c7 04 28 a6 81 89 45 a0 4c 89 4d b8 44 89 5d a8 e8 1b ac b1 ff 44 8b 5d a8 4c 8b 4d b8 8b 45 a0 e9 cf fe ff ff <0f> 0b 66 0f 1f 84 00 00 00 00 00 66 66 66 66 90 55 48 89 e5 48
[37598.994008] RIP [<ffffffff815443a5>] skb_copy_and_csum_bits+0x325/0x330
[37598.994008] RSP <ffff88003670da18>
[37599.007323] ---[ end trace d69f6a17f8ac8eee ]---
While there, also check if path mtu discovery is activated for this
socket. The logic was adapted from ip6_append_data when first writing
on the corked socket.
This bug was introduced with commit
0c1833797a5a6ec23ea9261d979aa18078720b74 ("ipv6: fix incorrect ipsec
fragment").
v2:
a) Replace IPV6_PMTU_DISC_DO with IPV6_PMTUDISC_PROBE.
b) Don't pass ipv6_pinfo to ip6_append_data_mtu (suggestion by Gao
feng, thanks!).
c) Change mtu to unsigned int, else we get a warning about
non-matching types because of the min()-macro type-check.
Acked-by: Gao feng <gaofeng@cn.fujitsu.com>
pending data
[ Upstream commit 8822b64a0fa64a5dd1dfcf837c5b0be83f8c05d1 ]
We accidentally call down to ip6_push_pending_frames when uncorking
pending AF_INET data on a ipv6 socket. This results in the following
splat (from Dave Jones):
skbuff: skb_under_panic: text:ffffffff816765f6 len:48 put:40 head:ffff88013deb6df0 data:ffff88013deb6dec tail:0x2c end:0xc0 dev:<NULL>
kernel BUG at net/core/skbuff.c:126!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in: dccp_ipv4 dccp 8021q garp bridge stp dlci mpoa snd_seq_dummy sctp fuse hidp tun bnep nfnetlink scsi_transport_iscsi rfcomm can_raw can_bcm af_802154 appletalk caif_socket can caif ipt_ULOG x25 rose af_key pppoe pppox ipx phonet irda llc2 ppp_generic slhc p8023 psnap p8022 llc crc_ccitt atm bluetooth
+netrom ax25 nfc rfkill rds af_rxrpc coretemp hwmon kvm_intel kvm crc32c_intel snd_hda_codec_realtek ghash_clmulni_intel microcode pcspkr snd_hda_codec_hdmi snd_hda_intel snd_hda_codec snd_hwdep usb_debug snd_seq snd_seq_device snd_pcm e1000e snd_page_alloc snd_timer ptp snd pps_core soundcore xfs libcrc32c
CPU: 2 PID: 8095 Comm: trinity-child2 Not tainted 3.10.0-rc7+ #37
task: ffff8801f52c2520 ti: ffff8801e6430000 task.ti: ffff8801e6430000
RIP: 0010:[<ffffffff816e759c>] [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP: 0018:ffff8801e6431de8 EFLAGS: 00010282
RAX: 0000000000000086 RBX: ffff8802353d3cc0 RCX: 0000000000000006
RDX: 0000000000003b90 RSI: ffff8801f52c2ca0 RDI: ffff8801f52c2520
RBP: ffff8801e6431e08 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000001 R12: ffff88022ea0c800
R13: ffff88022ea0cdf8 R14: ffff8802353ecb40 R15: ffffffff81cc7800
FS: 00007f5720a10740(0000) GS:ffff880244c00000(0000) knlGS:0000000000000000
CR2: 0000000005862000 CR3: 000000022843c000 CR4: 00000000001407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000600
Stack:
ffff88013deb6dec 000000000000002c 00000000000000c0 ffffffff81a3f6e4
ffff8801e6431e18 ffffffff8159a9aa ffff8801e6431e90 ffffffff816765f6
ffffffff810b756b 0000000700000002 ffff8801e6431e40 0000fea9292aa8c0
Call Trace:
[<ffffffff8159a9aa>] skb_push+0x3a/0x40
[<ffffffff816765f6>] ip6_push_pending_frames+0x1f6/0x4d0
[<ffffffff810b756b>] ? mark_held_locks+0xbb/0x140
[<ffffffff81694919>] udp_v6_push_pending_frames+0x2b9/0x3d0
[<ffffffff81694660>] ? udplite_getfrag+0x20/0x20
[<ffffffff8162092a>] udp_lib_setsockopt+0x1aa/0x1f0
[<ffffffff811cc5e7>] ? fget_light+0x387/0x4f0
[<ffffffff816958a4>] udpv6_setsockopt+0x34/0x40
[<ffffffff815949f4>] sock_common_setsockopt+0x14/0x20
[<ffffffff81593c31>] SyS_setsockopt+0x71/0xd0
[<ffffffff816f5d54>] tracesys+0xdd/0xe2
Code: 00 00 48 89 44 24 10 8b 87 d8 00 00 00 48 89 44 24 08 48 8b 87 e8 00 00 00 48 c7 c7 c0 04 aa 81 48 89 04 24 31 c0 e8 e1 7e ff ff <0f> 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55 48 89 e5 0f 0b 55
RIP [<ffffffff816e759c>] skb_panic+0x63/0x65
RSP <ffff8801e6431de8>
This patch adds a check if the pending data is of address family AF_INET
and directly calls udp_push_ending_frames from udp_v6_push_pending_frames
if that is the case.
This bug was found by Dave Jones with trinity.
(Also move the initialization of fl6 below the AF_INET check, even if
not strictly necessary.)
Cc: Dave Jones <davej@redhat.com>
[ Upstream commit e1558a93b61962710733dc8c11a2bc765607f1cd ]
Add missing .owner of struct pppox_proto. This prevents the
module from being removed from underneath its users.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
[ Upstream commit 8965779d2c0e6ab246c82a405236b1fb2adae6b2, with
some bits from commit b7b1bfce0bb68bd8f6e62a28295922785cc63781
("ipv6: split duplicate address detection and router solicitation timer")
to get the __ipv6_get_lladdr() used by this patch. ]
dingtianhong reported the following deadlock detected by lockdep:
[ INFO: possible circular locking dependency detected ]
3.4.24.05-0.1-default #1 Not tainted
ksoftirqd/0/3 is trying to acquire lock:
(&ndev->lock){+.+...}, at: [<ffffffff8147f804>] ipv6_get_lladdr+0x74/0x120
but task is already holding lock:
(&mc->mca_lock){+.+...}, at: [<ffffffff8149d130>] mld_send_report+0x40/0x150
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&mc->mca_lock){+.+...}:
[<ffffffff810a8027>] validate_chain+0x637/0x730
[<ffffffff810a8417>] __lock_acquire+0x2f7/0x500
[<ffffffff810a8734>] lock_acquire+0x114/0x150
[<ffffffff814f691a>] rt_spin_lock+0x4a/0x60
[<ffffffff8149e4bb>] igmp6_group_added+0x3b/0x120
[<ffffffff8149e5d8>] ipv6_mc_up+0x38/0x60
[<ffffffff81480a4d>] ipv6_find_idev+0x3d/0x80
[<ffffffff81483175>] addrconf_notify+0x3d5/0x4b0
[<ffffffff814fae3f>] notifier_call_chain+0x3f/0x80
[<ffffffff81073471>] raw_notifier_call_chain+0x11/0x20
[<ffffffff813d8722>] call_netdevice_notifiers+0x32/0x60
[<ffffffff813d92d4>] __dev_notify_flags+0x34/0x80
[<ffffffff813d9360>] dev_change_flags+0x40/0x70
[<ffffffff813ea627>] do_setlink+0x237/0x8a0
[<ffffffff813ebb6c>] rtnl_newlink+0x3ec/0x600
[<ffffffff813eb4d0>] rtnetlink_rcv_msg+0x160/0x310
[<ffffffff814040b9>] netlink_rcv_skb+0x89/0xb0
[<ffffffff813eb357>] rtnetlink_rcv+0x27/0x40
[<ffffffff81403e20>] netlink_unicast+0x140/0x180
[<ffffffff81404a9e>] netlink_sendmsg+0x33e/0x380
[<ffffffff813c4252>] sock_sendmsg+0x112/0x130
[<ffffffff813c537e>] __sys_sendmsg+0x44e/0x460
[<ffffffff813c5544>] sys_sendmsg+0x44/0x70
[<ffffffff814feab9>] system_call_fastpath+0x16/0x1b
-> #0 (&ndev->lock){+.+...}:
[<ffffffff810a798e>] check_prev_add+0x3de/0x440
[<ffffffff814f6c82>] rt_read_lock+0x42/0x60
[<ffffffff8149b036>] mld_newpack+0xb6/0x160
[<ffffffff8149b18b>] add_grhead+0xab/0xc0
[<ffffffff8149d03b>] add_grec+0x3ab/0x460
[<ffffffff8149d14a>] mld_send_report+0x5a/0x150
[<ffffffff8149f99e>] igmp6_timer_handler+0x4e/0xb0
[<ffffffff8105705a>] call_timer_fn+0xca/0x1d0
[<ffffffff81057b9f>] run_timer_softirq+0x1df/0x2e0
[<ffffffff8104e8c7>] handle_pending_softirqs+0xf7/0x1f0
[<ffffffff8104ea3b>] __do_softirq_common+0x7b/0xf0
[<ffffffff8104f07f>] __thread_do_softirq+0x1af/0x210
[<ffffffff8104f1c1>] run_ksoftirqd+0xe1/0x1f0
[<ffffffff8106c7de>] kthread+0xae/0xc0
[<ffffffff814fff74>] kernel_thread_helper+0x4/0x10
actually we can just hold idev->lock before taking pmc->mca_lock,
and avoid taking idev->lock again when iterating idev->addr_list,
since the upper callers of mld_newpack() already take
read_lock_bh(&idev->lock).
Reported-by: dingtianhong <dingtianhong@huawei.com>
Cc: dingtianhong <dingtianhong@huawei.com>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Tested-by: Ding Tianhong <dingtianhong@huawei.com>
Tested-by: Chen Weilong <chenweilong@huawei.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 4ccb93ce7439b63c31bc7597bfffd13567fa483d ]
Two of the x25 ioctl cases have error paths that break out of the function without
unlocking the socket, leading to this warning:
[ BUG: lock held when returning to user space! ]
3.10.0-rc7+ #36 Not tainted
trinity-child2/31407 is leaving the kernel with locks still held!
1 lock held by trinity-child2/31407:
#0: (sk_lock-AF_X25){+.+.+.}, at: [<ffffffffa024b6da>] x25_ioctl+0x8a/0x740 [x25]
Signed-off-by: Dave Jones <davej@redhat.com>
[ Upstream commit c9ab4d85de222f3390c67aedc9c18a50e767531e ]
There is a race in neighbour code, because neigh_destroy() uses
skb_queue_purge(&neigh->arp_queue) without holding neighbour lock,
while other parts of the code assume neighbour rwlock is what
protects arp_queue
Convert all skb_queue_purge() calls to the __skb_queue_purge() variant
Use __skb_queue_head_init() instead of skb_queue_head_init()
to make clear we do not use arp_queue.lock
And hold neigh->lock in neigh_destroy() to close the race.
Reported-by: Joe Jin <joe.jin@oracle.com>
[ Upstream commit a5cc68f3d63306d0d288f31edfc2ae6ef8ecd887 ]
key_notify_sa_flush() and key_notify_policy_flush() miss to initialize
the sadb_msg_reserved member of the broadcasted message and thereby
leak 2 bytes of heap memory to listeners. Fix that.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit a963a37d384d71ad43b3e9e79d68d42fbe0901f3 ]
It's possible to use AF_INET6 sockets and to connect to an IPv4
destination. After this, socket dst cache is a pointer to a rtable,
not rt6_info.
ip6_sk_dst_check() should check the socket dst cache is IPv6, or else
various corruptions/crashes can happen.
Dave Jones can reproduce immediate crash with
trinity -q -l off -n -c sendmsg -c connect
With help from Hannes Frederic Sowa
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit a881ae1f625c599b460cc8f8a7fcb1c438f699ad ]
If we disable all of the net interfaces, and enable
un-lo interface before lo interface, we already allocated
the addrconf dst in ipv6_add_addr. So we shouldn't allocate
it again when we enable lo interface.
Otherwise the message below will be triggered.
unregister_netdevice: waiting for sit1 to become free. Usage count = 1
This problem is introduced by commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
"net IPv6 : Fix broken IPv6 routing table after loopback down-up"
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit c0353c7b5da4cbd2ab8227e84bbc9c79890f24ce ]
MD5 key lookups on a given TCP socket were being performed
incorrectly. This fix alters parameter inputs to the MD5
lookup function tcp_md5_do_lookup, which is called by functions
tcp_md5_do_add and tcp_md5_do_del. Specifically, the change now
inputs the correct address and address family required to make
a proper lookup.
Signed-off-by: Aydin Arik <aydin.arik@alliedtelesis.co.nz>
[ Upstream commit 32de868cbc6bee010d2cee95b5071b25ecbec8c3 ]
General Queries (the one with the Multicast Address field
set to zero / '::') are supposed to have a Maximum Response Delay
of [Query Response Interval], while for Multicast-Address-Specific
Queries it is [Last Listener Query Interval] - not the other way
round. (see RFC2710, section 7.3+7.8)
Signed-off-by: Linus Lüssing <linus.luessing@web.de>
printk arguments not in correct order
___func__ is the char *
Change-Id: I7c39e64dcb20026ac015942380dbd523f198cd5e
Signed-off-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/246607
Reviewed-by: WK Tsai <wtsai@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Eric Miao <emiao@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
commit 2cb33cac622afde897aa02d3dcd9fbba8bae839e upstream.
A malicious monitor can craft an auth reply message that could cause a
NULL function pointer dereference in the client's kernel.
To prevent this, the auth_none protocol handler needs an empty
ceph_auth_client_ops->build_request() function.
CVE-2013-1059
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Chanam Park <chanam.park@hkpco.kr>
Reviewed-by: Seth Arnold <seth.arnold@canonical.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Change-Id: I413bd2f981702462efc31b92239ab4fa53dde48b
Reviewed-on: http://git-master/r/245093
SCAN_ABORT will produce a warning that it is not used in
the switch statements. The code is handled by a
KConfig option. Use that option in the include file.
Change-Id: I86f5aa2c305df49544ef4aa5e86622e2eedfab2a
Reviewed-on: http://git-master/r/245083
Reviewed-by: Wei Ni <wni@nvidia.com>
Change-Id: Ib862e0c63309b5fb57636a413747e414bca4cda4
Reviewed-on: http://git-master/r/245336
u8 *nfc_llcp_general_bytes(struct nfc_dev *dev, size_t *general_bytes_len);
prototype did not match static inline.
static inline used u8* rather then size_t*. Change static inline
Change-Id: Ia35d1230c530636b39f5ffe5a514daa5022ab467
Reviewed-on: http://git-master/r/245328
commit 300b962e5244a1ea010df7e88595faa0085b461d upstream.
If a too small MTU value is set with ioctl(HCISETACLMTU) or by a bogus
controller, memory corruption happens due to a memcpy() call with
negative length.
Fix this crash on either incoming or outgoing connections with a MTU
smaller than L2CAP_HDR_SIZE + L2CAP_CMD_HDR_SIZE:
[ 46.885433] BUG: unable to handle kernel paging request at f56ad000
[ 46.888037] IP: [<c03d94cd>] memcpy+0x1d/0x40
[ 46.888037] *pdpt = 0000000000ac3001 *pde = 00000000373f8067 *pte = 80000000356ad060
[ 46.888037] Oops: 0002 [#1] SMP DEBUG_PAGEALLOC
[ 46.888037] Modules linked in: hci_vhci bluetooth virtio_balloon i2c_piix4 uhci_hcd usbcore usb_common
[ 46.888037] CPU: 0 PID: 1044 Comm: kworker/u3:0 Not tainted 3.10.0-rc1+ #12
[ 46.888037] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 46.888037] Workqueue: hci0 hci_rx_work [bluetooth]
[ 46.888037] task: f59b15b0 ti: f55c4000 task.ti: f55c4000
[ 46.888037] EIP: 0060:[<c03d94cd>] EFLAGS: 00010212 CPU: 0
[ 46.888037] EIP is at memcpy+0x1d/0x40
[ 46.888037] EAX: f56ac1c0 EBX: fffffff8 ECX: 3ffffc6e EDX: f55c5cf2
[ 46.888037] ESI: f55c6b32 EDI: f56ad000 EBP: f55c5c68 ESP: f55c5c5c
[ 46.888037] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 46.888037] CR0: 8005003b CR2: f56ad000 CR3: 3557d000 CR4: 000006f0
[ 46.888037] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 46.888037] DR6: ffff0ff0 DR7: 00000400
[ 46.888037] Stack:
[ 46.888037] fffffff8 00000010 00000003 f55c5cac f8c6a54c ffffffff f8c69eb2 00000000
[ 46.888037] f4783cdc f57f0070 f759c590 1001c580 00000003 0200000a 00000000 f5a88560
[ 46.888037] f5ba2600 f5a88560 00000041 00000000 f55c5d90 f8c6f4c7 00000008 f55c5cf2
[ 46.888037] Call Trace:
[ 46.888037] [<f8c6a54c>] l2cap_send_cmd+0x1cc/0x230 [bluetooth]
[ 46.888037] [<f8c69eb2>] ? l2cap_global_chan_by_psm+0x152/0x1a0 [bluetooth]
[ 46.888037] [<f8c6f4c7>] l2cap_connect+0x3f7/0x540 [bluetooth]
[ 46.888037] [<c019b37b>] ? trace_hardirqs_off+0xb/0x10
[ 46.888037] [<c01a0ff8>] ? mark_held_locks+0x68/0x110
[ 46.888037] [<c064ad20>] ? mutex_lock_nested+0x280/0x360
[ 46.888037] [<c064b9d9>] ? __mutex_unlock_slowpath+0xa9/0x150
[ 46.888037] [<c01a118c>] ? trace_hardirqs_on_caller+0xec/0x1b0
[ 46.888037] [<c064ad08>] ? mutex_lock_nested+0x268/0x360
[ 46.888037] [<c01a125b>] ? trace_hardirqs_on+0xb/0x10
[ 46.888037] [<f8c72f8d>] l2cap_recv_frame+0xb2d/0x1d30 [bluetooth]
[ 46.888037] [<f8c754f1>] l2cap_recv_acldata+0x2a1/0x320 [bluetooth]
[ 46.888037] [<f8c491d8>] hci_rx_work+0x518/0x810 [bluetooth]
[ 46.888037] [<f8c48df2>] ? hci_rx_work+0x132/0x810 [bluetooth]
[ 46.888037] [<c0158979>] process_one_work+0x1a9/0x600
[ 46.888037] [<c01588fb>] ? process_one_work+0x12b/0x600
[ 46.888037] [<c015922e>] ? worker_thread+0x19e/0x320
[ 46.888037] [<c0159187>] worker_thread+0xf7/0x320
[ 46.888037] [<c0159090>] ? rescuer_thread+0x290/0x290
[ 46.888037] [<c01602f8>] kthread+0xa8/0xb0
[ 46.888037] [<c0656777>] ret_from_kernel_thread+0x1b/0x28
[ 46.888037] [<c0160250>] ? flush_kthread_worker+0x120/0x120
[ 46.888037] Code: c3 90 8d 74 26 00 e8 63 fc ff ff eb e8 90 55 89 e5 83 ec 0c 89 5d f4 89 75 f8 89 7d fc 3e 8d 74 26 00 89 cb 89 c7 c1 e9 02 89 d6 <f3> a5 89 d9 83 e1 03 74 02 f3 a4 8b 5d f4 8b 75 f8 8b 7d fc 89
[ 46.888037] EIP: [<c03d94cd>] memcpy+0x1d/0x40 SS:ESP 0068:f55c5c5c
[ 46.888037] CR2: 00000000f56ad000
[ 46.888037] ---[ end trace 0217c1f4d78714a9 ]---
Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
[ Upstream commit a6f79d0f26704214b5b702bbac525cb72997f984 ]
PPPoL2TP sockets should comply with the standard send*() return values
(i.e. return number of bytes sent instead of 0 upon success).
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 55b92b7a11690bc377b5d373872a6b650ae88e64 ]
Copy user data after PPP framing header. This prevents erasure of the
added PPP header and avoids leaking two bytes of uninitialised memory
at the end of skb's data buffer.
[ Upstream commit 2dc85bf323515e59e15dfa858d1472bb25cad0fe ]
uaddr->sa_data is exactly of size 14, which is hard-coded here and
passed as a size argument to strncpy(). A device name can be of size
IFNAMSIZ (== 16), meaning we might leave the destination string
unterminated. Thus, use strlcpy() and also sizeof() while we're
at it. We need to memset the data area beforehand, since strlcpy
does not padd the remaining buffer with zeroes for user space, so
that we do not possibly leak anything.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 1abd165ed757db1afdefaac0a4bc8a70f97d258c ]
While stress testing sctp sockets, I hit the following panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
PGD 7cead067 PUD 7ce76067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: sctp(F) libcrc32c(F) [...]
CPU: 7 PID: 2950 Comm: acc Tainted: GF 3.10.0-rc2+ #1
Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
task: ffff88007ce0e0c0 ti: ffff88007b568000 task.ti: ffff88007b568000
RIP: 0010:[<ffffffffa0490c4e>] [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP: 0018:ffff88007b569e08 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff88007db78a00 RCX: dead000000200200
RDX: ffffffffa049fdb0 RSI: ffff8800379baf38 RDI: 0000000000000000
RBP: ffff88007b569e18 R08: ffff88007c230da0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880077990d00 R14: 0000000000000084 R15: ffff88007db78a00
FS: 00007fc18ab61700(0000) GS:ffff88007fc60000(0000) knlGS:0000000000000000
CR2: 0000000000000020 CR3: 000000007cf9d000 CR4: 00000000000007e0
Stack:
ffff88007b569e38 ffff88007db78a00 ffff88007b569e38 ffffffffa049fded
ffffffff81abf0c0 ffff88007db78a00 ffff88007b569e58 ffffffff8145b60e
0000000000000000 0000000000000000 ffff88007b569eb8 ffffffff814df36e
Call Trace:
[<ffffffffa049fded>] sctp_destroy_sock+0x3d/0x80 [sctp]
[<ffffffff8145b60e>] sk_common_release+0x1e/0xf0
[<ffffffff814df36e>] inet_create+0x2ae/0x350
[<ffffffff81455a6f>] __sock_create+0x11f/0x240
[<ffffffff81455bf0>] sock_create+0x30/0x40
[<ffffffff8145696c>] SyS_socket+0x4c/0xc0
[<ffffffff815403be>] ? do_page_fault+0xe/0x10
[<ffffffff8153cb32>] ? page_fault+0x22/0x30
[<ffffffff81544e02>] system_call_fastpath+0x16/0x1b
Code: 0c c9 c3 66 2e 0f 1f 84 00 00 00 00 00 e8 fb fe ff ff c9 c3 66 0f
1f 84 00 00 00 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 <48>
8b 47 20 48 89 fb c6 47 1c 01 c6 40 12 07 e8 9e 68 01 00 48
RIP [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP <ffff88007b569e08>
---[ end trace e0d71ec1108c1dd9 ]---
I did not hit this with the lksctp-tools functional tests, but with a
small, multi-threaded test program, that heavily allocates, binds,
listens and waits in accept on sctp sockets, and then randomly kills
some of them (no need for an actual client in this case to hit this).
Then, again, allocating, binding, etc, and then killing child processes.
This panic then only occurs when ``echo 1 > /proc/sys/net/sctp/auth_enable''
is set. The cause for that is actually very simple: in sctp_endpoint_init()
we enter the path of sctp_auth_init_hmacs(). There, we try to allocate
our crypto transforms through crypto_alloc_hash(). In our scenario,
it then can happen that crypto_alloc_hash() fails with -EINTR from
crypto_larval_wait(), thus we bail out and release the socket via
sk_common_release(), sctp_destroy_sock() and hit the NULL pointer
dereference as soon as we try to access members in the endpoint during
sctp_endpoint_free(), since endpoint at that time is still NULL. Now,
if we have that case, we do not need to do any cleanup work and just
leave the destruction handler.
[ Upstream commit 534c877928a16ae5f9776436a497109639bf67dc ]
Commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
forgot to assign rt6_info to the inet6_ifaddr.
When disable the net device, the rt6_info which allocated
in init_loopback will not be destroied in __ipv6_ifa_notify.
This will trigger the waring message below
[23527.916091] unregister_netdevice: waiting for tap0 to become free. Usage count = 1
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit a622260254ee481747cceaaa8609985b29a31565 ]
Daniel Petre reported crashes in icmp_dst_unreach() with following call
graph:
Daniel found a similar problem mentioned in
http://lkml.indiana.edu/hypermail/linux/kernel/1007.0/00961.html
And indeed this is the root cause : skb->cb[] contains data fooling IP
stack.
We must clear IPCB in ip_tunnel_xmit() sooner in case dst_link_failure()
is called. Or else skb->cb[] might contain garbage from GSO segmentation
layer.
A similar fix was tested on linux-3.9, but gre code was refactored in
linux-3.10. I'll send patches for stable kernels as well.
Many thanks to Daniel for providing reports, patches and testing !
Reported-by: Daniel Petre <daniel.petre@rcs-rds.ro>
[ Upstream commit 547669d483e5783d722772af1483fa474da7caf9 ]
commit 3853b5841c01a ("xps: Improvements in TX queue selection")
introduced ooo_okay flag, but the condition to set it is slightly wrong.
In our traces, we have seen ACK packets being received out of order,
and RST packets sent in response.
We should test if we have any packets still in host queue.
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 35f079ebbc860dcd1cca70890c9c8d59c1145525 ]
This patch is a fix for a bug triggering newly_acked_sacked < 0
in tcp_ack(.).
The bug is triggered by sacked_out decreasing relative to prior_sacked,
but packets_out remaining the same as pior_packets. This is because the
snapshot of prior_packets is taken after tcp_sacktag_write_queue() while
prior_sacked is captured before tcp_sacktag_write_queue(). The problem
is: tcp_sacktag_write_queue (tcp_match_skb_to_sack() -> tcp_fragment)
adjusts the pcount for packets_out and sacked_out (MSS change or other
reason). As a result, this delta in pcount is reflected in
(prior_sacked - sacked_out) but not in (prior_packets - packets_out).
This patch does the following:
1) initializes prior_packets at the start of tcp_ack() so as to
capture the delta in packets_out created by tcp_fragment.
2) introduces a new "previous_packets_out" variable that snapshots
packets_out right before tcp_clean_rtx_queue, so pkts_acked can be
correctly computed as before.
3) Computes pkts_acked using previous_packets_out, and computes
newly_acked_sacked using prior_packets.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 6b21e1b77d1a3d58ebfd513264c885695e8a0ba5 ]
The net/netlabel/netlabel_domainhash.c:netlbl_domhsh_add() function
does not properly validate new domain hash entries resulting in
potential problems when an administrator attempts to add an invalid
entry. One such problem, as reported by Vlad Halilov, is a kernel
BUG (found in netlabel_domainhash.c:netlbl_domhsh_audit_add()) when
adding an IPv6 outbound mapping with a CIPSO configuration.
This patch corrects this problem by adding the necessary validation
code to netlbl_domhsh_add() via the newly created
netlbl_domhsh_validate() function.
Ideally this patch should also be pushed to the currently active
-stable trees.
Reported-by: Vlad Halilov <vlad.halilov@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit 284041ef21fdf2e0d216ab6b787bc9072b4eb58a ]
commit 0178b695fd6b4 ("ipv6: Copy cork options in ip6_append_data")
added some code duplication and bad error recovery, leading to potential
crash in ip6_cork_release() as kfree() could be called with garbage.
use kzalloc() to make sure this wont happen.
[ Upstream commit 54d27fcb338bd9c42d1dfc5a39e18f6f9d373c2e ]
TCP md5 communications fail [1] for some devices, because sg/crypto code
assume page offsets are below PAGE_SIZE.
This was discovered using mlx4 driver [2], but I suspect loopback
might trigger the same bug now we use order-3 pages in tcp_sendmsg()
[1] Failure is giving following messages.
huh, entered softirq 3 NET_RX ffffffff806ad230 preempt_count 00000100,
exited with 00000101?
[2] mlx4 driver uses order-2 pages to allocate RX frags
Reported-by: Matt Schnall <mischnal@google.com>
Cc: Bernhard Beck <bbeck@google.com>
commit e9966076cdd952e19f2dd4854cd719be0d7cbebc upstream.
The auth code is called from a variety of contexts, include the mon_client
(protected by the monc's mutex) and the messenger callbacks (currently
protected by nothing). Avoid chaos by protecting all auth state with a
mutex. Nothing is blocking, so this should be simple and lightweight.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
commit 27859f9773e4a0b2042435b13400ee2c891a61f4 upstream.
Use wrapper functions that check whether the auth op exists so that callers
do not need a bunch of conditional checks. Simplifies the external
interface.
