[ Upstream commit d7591f0c41ce3e67600a982bab6989ef0f07b3ce ]
The three variants use same copy&pasted code, condense this into a
helper and use that.
Make sure info.name is 0-terminated.
[ Upstream commit 09d9686047dbbe1cf4faa558d3ecc4aae2046054 ]
This looks like refactoring, but its also a bug fix.
Problem is that the compat path (32bit iptables, 64bit kernel) lacks a few
sanity tests that are done in the normal path.
For example, we do not check for underflows and the base chain policies.
While its possible to also add such checks to the compat path, its more
copy&pastry, for instance we cannot reuse check_underflow() helper as
e->target_offset differs in the compat case.
Other problem is that it makes auditing for validation errors harder; two
places need to be checked and kept in sync.
At a high level 32 bit compat works like this:
1- initial pass over blob:
validate match/entry offsets, bounds checking
lookup all matches and targets
do bookkeeping wrt. size delta of 32/64bit structures
assign match/target.u.kernel pointer (points at kernel
implementation, needed to access ->compatsize etc.)
2- allocate memory according to the total bookkeeping size to
contain the translated ruleset
3- second pass over original blob:
for each entry, copy the 32bit representation to the newly allocated
memory. This also does any special match translations (e.g.
adjust 32bit to 64bit longs, etc).
4- check if ruleset is free of loops (chase all jumps)
5-first pass over translated blob:
call the checkentry function of all matches and targets.
The alternative implemented by this patch is to drop steps 3&4 from the
compat process, the translation is changed into an intermediate step
rather than a full 1:1 translate_table replacement.
In the 2nd pass (step #3), change the 64bit ruleset back to a kernel
representation, i.e. put() the kernel pointer and restore ->u.user.name .
This gets us a 64bit ruleset that is in the format generated by a 64bit
iptables userspace -- we can then use translate_table() to get the
'native' sanity checks.
This has two drawbacks:
1. we re-validate all the match and target entry structure sizes even
though compat translation is supposed to never generate bogus offsets.
2. we put and then re-lookup each match and target.
THe upside is that we get all sanity tests and ruleset validations
provided by the normal path and can remove some duplicated compat code.
iptables-restore time of autogenerated ruleset with 300k chains of form
-A CHAIN0001 -m limit --limit 1/s -j CHAIN0002
-A CHAIN0002 -m limit --limit 1/s -j CHAIN0003
shows no noticeable differences in restore times:
old: 0m30.796s
new: 0m31.521s
64bit: 0m25.674s
[ Upstream commit 0188346f21e6546498c2a0f84888797ad4063fc5 ]
Always returned 0.
[ Upstream commit 329a0807124f12fe1c8032f95d8a8eb47047fb0e ]
[ Upstream commit 7d3f843eed29222254c9feab481f55175a1afcc9 ]
[ Upstream commit 8dddd32756f6fe8e4e82a63361119b7e2384e02f ]
[ Upstream commit 7b7eba0f3515fca3296b8881d583f7c1042f5226 ]
Quoting John Stultz:
In updating a 32bit arm device from 4.6 to Linus' current HEAD, I
noticed I was having some trouble with networking, and realized that
/proc/net/ip_tables_names was suddenly empty.
Digging through the registration process, it seems we're catching on the:
if (strcmp(t->u.user.name, XT_STANDARD_TARGET) == 0 &&
target_offset + sizeof(struct xt_standard_target) != next_offset)
return -EINVAL;
Where next_offset seems to be 4 bytes larger then the
offset + standard_target struct size.
next_offset needs to be aligned via XT_ALIGN (so we can access all members
of ip(6)t_entry struct).
This problem didn't show up on i686 as it only needs 4-byte alignment for
u64, but iptables userspace on other 32bit arches does insert extra padding.
Reported-by: John Stultz <john.stultz@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Fixes: 7ed2abddd20cf ("netfilter: x_tables: check standard target size too")
[ Upstream commit 13631bfc604161a9d69cd68991dff8603edd66f9 ]
Validate that all matches (if any) add up to the beginning of
the target and that each match covers at least the base structure size.
The compat path should be able to safely re-use the function
as the structures only differ in alignment; added a
BUILD_BUG_ON just in case we have an arch that adds padding as well.
[ Upstream commit ce683e5f9d045e5d67d1312a42b359cb2ab2a13c ]
We're currently asserting that targetoff + targetsize <= nextoff.
Extend it to also check that targetoff is >= sizeof(xt_entry).
Since this is generic code, add an argument pointing to the start of the
match/target, we can then derive the base structure size from the delta.
We also need the e->elems pointer in a followup change to validate matches.
[ Upstream commit 7ed2abddd20cf8f6bd27f65bd218f26fa5bf7f44 ]
We have targets and standard targets -- the latter carries a verdict.
The ip/ip6tables validation functions will access t->verdict for the
standard targets to fetch the jump offset or verdict for chainloop
detection, but this happens before the targets get checked/validated.
Thus we also need to check for verdict presence here, else t->verdict
can point right after a blob.
Spotted with UBSAN while testing malformed blobs.
[ Upstream commit fc1221b3a163d1386d1052184202d5dc50d302d1 ]
32bit rulesets have different layout and alignment requirements, so once
more integrity checks get added to xt_check_entry_offsets it will reject
well-formed 32bit rulesets.
[ Upstream commit a08e4e190b866579896c09af59b3bdca821da2cd ]
The target size includes the size of the xt_entry_target struct.
[ Upstream commit aa412ba225dd3bc36d404c28cdc3d674850d80d0 ]
Once we add more sanity testing to xt_check_entry_offsets it
becomes relvant if we're expecting a 32bit 'config_compat' blob
or a normal one.
Since we already have a lot of similar-named functions (check_entry,
compat_check_entry, find_and_check_entry, etc.) and the current
incarnation is short just fold its contents into the callers.
[ Upstream commit 7d35812c3214afa5b37a675113555259cfd67b98 ]
Currently arp/ip and ip6tables each implement a short helper to check that
the target offset is large enough to hold one xt_entry_target struct and
that t->u.target_size fits within the current rule.
Unfortunately these checks are not sufficient.
To avoid adding new tests to all of ip/ip6/arptables move the current
checks into a helper, then extend this helper in followup patches.
[ Upstream commit 36472341017529e2b12573093cc0f68719300997 ]
When we see a jump also check that the offset gets us to beginning of
a rule (an ipt_entry).
The extra overhead is negible, even with absurd cases.
300k custom rules, 300k jumps to 'next' user chain:
[ plus one jump from INPUT to first userchain ]:
Before:
real 0m24.874s
user 0m7.532s
sys 0m16.076s
After:
real 0m27.464s
user 0m7.436s
sys 0m18.840s
[ Upstream commit f24e230d257af1ad7476c6e81a8dc3127a74204e ]
Ben Hawkes says:
In the mark_source_chains function (net/ipv4/netfilter/ip_tables.c) it
is possible for a user-supplied ipt_entry structure to have a large
next_offset field. This field is not bounds checked prior to writing a
counter value at the supplied offset.
Base chains enforce absolute verdict.
User defined chains are supposed to end with an unconditional return,
xtables userspace adds them automatically.
But if such return is missing we will move to non-existent next rule.
Reported-by: Ben Hawkes <hawkes@google.com>
[ Upstream commit 54d83fc74aa9ec72794373cb47432c5f7fb1a309 ]
Ben Hawkes says:
Problem is that mark_source_chains should not have been called --
the rule doesn't have a next entry, so its supposed to return
an absolute verdict of either ACCEPT or DROP.
However, the function conditional() doesn't work as the name implies.
It only checks that the rule is using wildcard address matching.
However, an unconditional rule must also not be using any matches
(no -m args).
The underflow validator only checked the addresses, therefore
passing the 'unconditional absolute verdict' test, while
mark_source_chains also tested for presence of matches, and thus
proceeeded to the next (not-existent) rule.
Unify this so that all the callers have same idea of 'unconditional rule'.
[ Upstream commit 6e94e0cfb0887e4013b3b930fa6ab1fe6bb6ba91 ]
Otherwise this function may read data beyond the ruleset blob.
[ Upstream commit bdf533de6968e9686df777dc178486f600c6e617 ]
We should check that e->target_offset is sane before
mark_source_chains gets called since it will fetch the target entry
for loop detection.
[ Upstream commit ce3cf4ec0305919fc69a972f6c2b2efd35d36abc ]
The v6 tcp stats scan do not provide TLP and ER timer information
correctly like the v4 version . This patch fixes that.
Fixes: 6ba8a3b19e76 ("tcp: Tail loss probe (TLP)")
Fixes: eed530b6c676 ("tcp: early retransmit")
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 03aaaa9b941e136757b55c4cf775aab6068dfd94 ]
The publication field of the old netlink API should contain the
publication key and not the publication reference.
Fixes: 44a8ae94fd55 (tipc: convert legacy nl name table dump to nl compat)
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 92964c79b357efd980812c4de5c1fd2ec8bb5520 ]
When we free cb->skb after a dump, we do it after releasing the
lock. This means that a new dump could have started in the time
being and we'll end up freeing their skb instead of ours.
This patch saves the skb and module before we unlock so we free
the right memory.
Fixes: 16b304f3404f ("netlink: Eliminate kmalloc in netlink dump operation.")
Reported-by: Baozeng Ding <sploving1@gmail.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 45e093ae2830cd1264677d47ff9a95a71f5d9f9c ]
Make sure the socket for which the user is listing publication exists
before parsing the socket netlink attributes.
Prior to this patch a call without any socket caused a NULL pointer
dereference in tipc_nl_publ_dump().
Tested-and-reported-by: Baozeng Ding <sploving1@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.cm>
[ Upstream commit 10a81980fc47e64ffac26a073139813d3f697b64 ]
In the very unlikely case __tcp_retransmit_skb() can not use the cloning
done in tcp_transmit_skb(), we need to refresh skb_mstamp before doing
the copy and transmit, otherwise TCP TS val will be an exact copy of
original transmit.
Fixes: 7faee5c0d514 ("tcp: remove TCP_SKB_CB(skb)->when")
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
[ Upstream commit 79e48650320e6fba48369fccf13fd045315b19b8 ]
Stack object "dte_facilities" is allocated in x25_rx_call_request(),
which is supposed to be initialized in x25_negotiate_facilities.
However, 5 fields (8 bytes in total) are not initialized. This
object is then copied to userland via copy_to_user, thus infoleak
occurs.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
[ Upstream commit 31ca0458a61a502adb7ed192bf9716c6d05791a5 ]
get_bridge_ifindices() is used from the old "deviceless" bridge ioctl
calls which aren't called with rtnl held. The comment above says that it is
called with rtnl but that is not really the case.
Here's a sample output from a test ASSERT_RTNL() which I put in
get_bridge_ifindices and executed "brctl show":
[ 957.422726] RTNL: assertion failed at net/bridge//br_ioctl.c (30)
[ 957.422925] CPU: 0 PID: 1862 Comm: brctl Tainted: G W O
4.6.0-rc4+ #157
[ 957.423009] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996),
BIOS 1.8.1-20150318_183358- 04/01/2014
[ 957.423009] 0000000000000000 ffff880058adfdf0 ffffffff8138dec5
0000000000000400
[ 957.423009] ffffffff81ce8380 ffff880058adfe58 ffffffffa05ead32
0000000000000001
[ 957.423009] 00007ffec1a444b0 0000000000000400 ffff880053c19130
0000000000008940
[ 957.423009] Call Trace:
[ 957.423009] [<ffffffff8138dec5>] dump_stack+0x85/0xc0
[ 957.423009] [<ffffffffa05ead32>]
br_ioctl_deviceless_stub+0x212/0x2e0 [bridge]
[ 957.423009] [<ffffffff81515beb>] sock_ioctl+0x22b/0x290
[ 957.423009] [<ffffffff8126ba75>] do_vfs_ioctl+0x95/0x700
[ 957.423009] [<ffffffff8126c159>] SyS_ioctl+0x79/0x90
[ 957.423009] [<ffffffff8163a4c0>] entry_SYSCALL_64_fastpath+0x23/0xc1
Since it only reads bridge ifindices, we can use rcu to safely walk the net
device list. Also remove the wrong rtnl comment above.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit dedc58e067d8c379a15a8a183c5db318201295bb ]
The peer may be expecting a reply having sent a request and then done a
shutdown(SHUT_WR), so tearing down the whole socket at this point seems
wrong and breaks for me with a client which does a SHUT_WR.
Looking at other socket family's stream_recvmsg callbacks doing a shutdown
here does not seem to be the norm and removing it does not seem to have
had any adverse effects that I can see.
I'm using Stefan's RFC virtio transport patches, I'm unsure of the impact
on the vmci transport.
Signed-off-by: Ian Campbell <ian.campbell@docker.com>
Cc: Stefan Hajnoczi <stefanha@redhat.com>
Cc: Claudio Imbrenda <imbrenda@linux.vnet.ibm.com>
Cc: Andy King <acking@vmware.com>
Cc: Dmitry Torokhov <dtor@vmware.com>
Cc: Jorgen Hansen <jhansen@vmware.com>
Cc: Adit Ranadive <aditr@vmware.com>
Cc: netdev@vger.kernel.org
[ Upstream commit 5f8e44741f9f216e33736ea4ec65ca9ac03036e6 ]
The stack object “map” has a total size of 32 bytes. Its last 4
bytes are padding generated by compiler. These padding bytes are
not initialized and sent out via “nla_put”.
[ Upstream commit b8670c09f37bdf2847cc44f36511a53afc6161fd ]
The stack object “info” has a total size of 12 bytes. Its last byte
is padding which is not initialized and leaked via “put_cmsg”.
[ Upstream commit 6071bd1aa13ed9e41824bafad845b7b7f4df5cfd ]
This was recently reported to me, and reproduced on the latest net kernel,
when attempting to run netperf from a host that had a netem qdisc attached
to the egress interface:
[ 788.073771] ---------------------[ cut here ]---------------------------
[ 788.096716] WARNING: at net/core/dev.c:2253 skb_warn_bad_offload+0xcd/0xda()
[ 788.129521] bnx2: caps=(0x00000001801949b3, 0x0000000000000000) len=2962
data_len=0 gso_size=1448 gso_type=1 ip_summed=3
[ 788.182150] Modules linked in: sch_netem kvm_amd kvm crc32_pclmul ipmi_ssif
ghash_clmulni_intel sp5100_tco amd64_edac_mod aesni_intel lrw gf128mul
glue_helper ablk_helper edac_mce_amd cryptd pcspkr sg edac_core hpilo ipmi_si
i2c_piix4 k10temp fam15h_power hpwdt ipmi_msghandler shpchp acpi_power_meter
pcc_cpufreq nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c
sd_mod crc_t10dif crct10dif_generic mgag200 syscopyarea sysfillrect sysimgblt
i2c_algo_bit drm_kms_helper ahci ata_generic pata_acpi ttm libahci
crct10dif_pclmul pata_atiixp tg3 libata crct10dif_common drm crc32c_intel ptp
serio_raw bnx2 r8169 hpsa pps_core i2c_core mii dm_mirror dm_region_hash dm_log
dm_mod
[ 788.465294] CPU: 16 PID: 0 Comm: swapper/16 Tainted: G W
------------ 3.10.0-327.el7.x86_64 #1
[ 788.511521] Hardware name: HP ProLiant DL385p Gen8, BIOS A28 12/17/2012
[ 788.542260] ffff880437c036b8 f7afc56532a53db9 ffff880437c03670
ffffffff816351f1
[ 788.576332] ffff880437c036a8 ffffffff8107b200 ffff880633e74200
ffff880231674000
[ 788.611943] 0000000000000001 0000000000000003 0000000000000000
ffff880437c03710
[ 788.647241] Call Trace:
[ 788.658817] <IRQ> [<ffffffff816351f1>] dump_stack+0x19/0x1b
[ 788.686193] [<ffffffff8107b200>] warn_slowpath_common+0x70/0xb0
[ 788.713803] [<ffffffff8107b29c>] warn_slowpath_fmt+0x5c/0x80
[ 788.741314] [<ffffffff812f92f3>] ? ___ratelimit+0x93/0x100
[ 788.767018] [<ffffffff81637f49>] skb_warn_bad_offload+0xcd/0xda
[ 788.796117] [<ffffffff8152950c>] skb_checksum_help+0x17c/0x190
[ 788.823392] [<ffffffffa01463a1>] netem_enqueue+0x741/0x7c0 [sch_netem]
[ 788.854487] [<ffffffff8152cb58>] dev_queue_xmit+0x2a8/0x570
[ 788.880870] [<ffffffff8156ae1d>] ip_finish_output+0x53d/0x7d0
The problem occurs because netem is not prepared to handle GSO packets (as it
uses skb_checksum_help in its enqueue path, which cannot manipulate these
frames).
The solution I think is to simply segment the skb in a simmilar fashion to the
way we do in __dev_queue_xmit (via validate_xmit_skb), with some minor changes.
When we decide to corrupt an skb, if the frame is GSO, we segment it, corrupt
the first segment, and enqueue the remaining ones.
tested successfully by myself on the latest net kernel, to which this applies
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Jamal Hadi Salim <jhs@mojatatu.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netem@lists.linux-foundation.org
CC: eric.dumazet@gmail.com
CC: stephen@networkplumber.org
[ Upstream commit bdf17661f63a79c3cb4209b970b1cc39e34f7543 ]
Similarly, we need to update backlog too when we update qlen.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 431e3a8e36a05a37126f34b41aa3a5a6456af04e ]
We saw qlen!=0 but backlog==0 on our production machine:
qdisc htb 1: dev eth0 root refcnt 2 r2q 10 default 1 direct_packets_stat 0 ver 3.17
Sent 172680457356 bytes 222469449 pkt (dropped 0, overlimits 123575834 requeues 0)
backlog 0b 72p requeues 0
The problem is we only count qlen for HTB qdisc but not backlog.
We need to update backlog too when we update qlen, so that we
can at least know the average packet length.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 2ccccf5fb43ff62b2b96cc58d95fc0b3596516e4 ]
When the bottom qdisc decides to, for example, drop some packet,
it calls qdisc_tree_decrease_qlen() to update the queue length
for all its ancestors, we need to update the backlog too to
keep the stats on root qdisc accurate.
[ Upstream commit 86a7996cc8a078793670d82ed97d5a99bb4e8496 ]
Remove nearly duplicated code and prepare for the following patch.
[ Upstream commit 391a20333b8393ef2e13014e6e59d192c5594471 ]
After commit fbd40ea0180a ("ipv4: Don't do expensive useless work
during inetdev destroy.") when deleting an interface,
fib_del_ifaddr() can be executed without any primary address
present on the dead interface.
The above is safe, but triggers some "bug: prim == NULL" warnings.
This commit avoids warning if the in_dev is dead
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit b4f70527f052b0c00be4d7cac562baa75b212df5 ]
When using masked actions the ipv6_proto field of an action
to set IPv6 fields may be zero rather than the prevailing protocol
which will result in skipping checksum recalculation.
This patch resolves the problem by relying on the protocol
in the flow key rather than that in the set field action.
Fixes: 83d2b9ba1abc ("net: openvswitch: Support masked set actions.")
Cc: Jarno Rajahalme <jrajahalme@nicira.com>
Signed-off-by: Simon Horman <simon.horman@netronome.com>
[ Upstream commit 3dcd493fbebfd631913df6e2773cc295d3bf7d22 ]
A failure in validate_xmit_skb_list() triggered an unconditional call
to dev_requeue_skb with skb=NULL. This slowly grows the queue
discipline's qlen count until all traffic through the queue stops.
We take the optimistic approach and continue running the queue after a
failure since it is unknown if later packets also will fail in the
validate path.
Fixes: 55a93b3ea780 ("qdisc: validate skb without holding lock")
Signed-off-by: Lars Persson <larper@axis.com>
[ Upstream commit 309cf37fe2a781279b7675d4bb7173198e532867 ]
Because we miss to wipe the remainder of i->addr[] in packet_mc_add(),
pdiag_put_mclist() leaks uninitialized heap bytes via the
PACKET_DIAG_MCLIST netlink attribute.
Fix this by explicitly memset(0)ing the remaining bytes in i->addr[].
Fixes: eea68e2f1a00 ("packet: Report socket mclist info via diag module")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Pavel Emelyanov <xemul@virtuozzo.com>
[ Upstream commit d6d5e999e5df67f8ec20b6be45e2229455ee3699 ]
For local routes that require a particular output interface we do not want
to cache the result. Caching the result causes incorrect behaviour when
there are multiple source addresses on the interface. The end result
being that if the intended recipient is waiting on that interface for the
packet he won't receive it because it will be delivered on the loopback
interface and the IP_PKTINFO ipi_ifindex will be set to the loopback
interface as well.
This can be tested by running a program such as "dhcp_release" which
attempts to inject a packet on a particular interface so that it is
received by another program on the same board. The receiving process
should see an IP_PKTINFO ipi_ifndex value of the source interface
(e.g., eth1) instead of the loopback interface (e.g., lo). The packet
will still appear on the loopback interface in tcpdump but the important
aspect is that the CMSG info is correct.
Sample dhcp_release command line:
dhcp_release eth1 192.168.204.222 02:11:33:22:44:66
Signed-off-by: Allain Legacy <allain.legacy@windriver.com>
Signed off-by: Chris Friesen <chris.friesen@windriver.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit a36a0d4008488fa545c74445d69eaf56377d5d4e ]
In particular, make sure we check for decnet private presence
for loopback devices.
[ Upstream commit d1a65f1741bfd9c69f9e4e2ad447a89b6810427d ]
_batadv_update_route rcu_derefences orig_ifinfo->router outside of a
spinlock protected region to print some information messages to the debug
log. But this pointer is not checked again when the new pointer is assigned
in the spinlock protected region. Thus is can happen that the value of
orig_ifinfo->router changed in the meantime and thus the reference counter
of the wrong router gets reduced after the spinlock protected region.
Just rcu_dereferencing the value of orig_ifinfo->router inside the spinlock
protected region (which also set the new pointer) is enough to get the
correct old router object.
Fixes: e1a5382f978b ("batman-adv: Make orig_node->router an rcu protected pointer")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Antonio Quartulli <a@unstable.cc>
[ Upstream commit c4fdb6cff2aa0ae740c5f19b6f745cbbe786d42f ]
When removing a single interface while a broadcast or ogm packet is
still pending then we will free the forward packet without releasing the
queue slots again.
This patch is supposed to fix this issue.
Fixes: 6d5808d4ae1b ("batman-adv: Add missing hardif_free_ref in forw_packet_free")
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
[sven@narfation.org: fix conflicts with current version]
[ Upstream commit c78296665c3d81f040117432ab9e1cb125521b0c ]
The encapsulated ethernet and VLAN header may be outside the received
ethernet frame. Thus the skb buffer size has to be checked before it can be
parsed to find out if it encapsulates another batman-adv packet.
Fixes: 420193573f11 ("batman-adv: softif bridge loop avoidance")
[ Upstream commit f719e3754ee2f7275437e61a6afd520181fdd43b ]
Jiri Bohac is reporting for a problem where the attempt
to reschedule existing connection to another real server
needs proper redirect for the conntrack used by the IPVS
connection. For example, when IPVS connection is created
to NAT-ed real server we alter the reply direction of
conntrack. If we later decide to select different real
server we can not alter again the conntrack. And if we
expire the old connection, the new connection is left
without conntrack.
So, the only way to redirect both the IPVS connection and
the Netfilter's conntrack is to drop the SYN packet that
hits existing connection, to wait for the next jiffie
to expire the old connection and its conntrack and to rely
on client's retransmission to create new connection as
usually.
Jiri Bohac provided a fix that drops all SYNs on rescheduling,
I extended his patch to do such drops only for connections
that use conntrack. Here is the original report from Jiri Bohac:
Since commit dc7b3eb900aa ("ipvs: Fix reuse connection if real server
is dead"), new connections to dead servers are redistributed
immediately to new servers. The old connection is expired using
ip_vs_conn_expire_now() which sets the connection timer to expire
immediately.
However, before the timer callback, ip_vs_conn_expire(), is run
to clean the connection's conntrack entry, the new redistributed
connection may already be established and its conntrack removed
instead.
Fix this by dropping the first packet of the new connection
instead, like we do when the destination server is not available.
The timer will have deleted the old conntrack entry long before
the first packet of the new connection is retransmitted.
Fixes: dc7b3eb900aa ("ipvs: Fix reuse connection if real server is dead")
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit 7617a24f83b5d67f4dab1844956be1cebc44aec8 ]
The IPVS SIP persistence engine is not able to parse the SIP header
"Call-ID" when such header is inserted in the first positions of
the SIP message.
When IPVS is configured with "--pe sip" option, like for example:
ipvsadm -A -u 1.2.3.4:5060 -s rr --pe sip -p 120 -o
some particular messages (see below for details) do not create entries
in the connection template table, which can be listed with:
ipvsadm -Lcn --persistent-conn
Problematic SIP messages are SIP responses having "Call-ID" header
positioned just after message first line:
SIP/2.0 200 OK
[Call-ID header here]
[rest of the headers]
When "Call-ID" header is positioned down (after a few other headers)
it is correctly recognized.
This is due to the data offset used in get_callid function call inside
ip_vs_pe_sip.c file: since dptr already points to the start of the
SIP message, the value of dataoff should be initially 0.
Otherwise the header is searched starting from some bytes after the
first character of the SIP message.
Fixes: 758ff0338722 ("IPVS: sip persistence engine")
Signed-off-by: Marco Angaroni <marcoangaroni@gmail.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit a6ab1e8126d205238defbb55d23661a3a5c6a0d8 ]
sunrpc_cache_pipe_upcall() can detect a race if CACHE_PENDING is no longer
set. In this case it aborts the queuing of the upcall.
However it has already taken a new counted reference on "h" and
doesn't "put" it, even though it frees the data structure holding the reference.
So let's delay the "cache_get" until we know we need it.
Fixes: f9e1aedc6c79 ("sunrpc/cache: remove races with queuing an upcall.")
Signed-off-by: NeilBrown <neilb@suse.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
[ Upstream commit 2a58d42c1e018ad514d4e23fd33fb2ded95d3ee6 ]
The driver can access the queue simultanously
while mac80211 tears down the interface. Without
spinlock protection this could lead to corrupting
sk_buff_head and subsequently to an invalid
pointer dereference.
Fixes: ba8c3d6f16a1 ("mac80211: add an intermediate software queue implementation")
Signed-off-by: Michal Kazior <michal.kazior@tieto.com>
[ Upstream commit cf44012810ccdd8fd947518e965cb04b7b8498be ]
The ieee80211_queue_stopped() expects hw queue
number but it was given raw WMM AC number instead.
This could cause frame drops and problems with
traffic in some cases - most notably if driver
doesn't map AC numbers to queue numbers 1:1 and
uses ieee80211_stop_queues() and
ieee80211_wake_queue() only without ever calling
ieee80211_wake_queues().
On ath10k it was possible to hit this problem in
the following case:
1. wlan0 uses queue 0
(ath10k maps queues per vif)
2. offchannel uses queue 15
3. queues 1-14 are unused
4. ieee80211_stop_queues()
5. ieee80211_wake_queue(q=0)
6. ieee80211_wake_queue(q=15)
(other queues are not woken up because both
driver and mac80211 know other queues are
unused)
7. ieee80211_rx_h_mesh_fwding()
8. ieee80211_select_queue_80211() returns 2
9. ieee80211_queue_stopped(q=2) returns true
10. frame is dropped (oops!)
Fixes: d3c1597b8d1b ("mac80211: fix forwarded mesh frame queue mapping")
[ Upstream commit d321cd014e51baab475efbdec468255b9e0ec822 ]
When joining IBSS a full scan should be initiated in order to search
for existing cell, unless the fixed_channel parameter was set.
A default channel to create the IBSS on if no cell was found is
provided as well.
However - a scan is initiated only on the default channel provided
regardless of whether ifibss->fixed_channel is set or not, with the
obvious result of the cell not joining existing IBSS cell that is
on another channel.
Fixes: 76bed0f43b27 ("mac80211: IBSS fix scan request")
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[ Upstream commit 0ef049dc1167fe834d0ad5d63f89eddc5c70f6e4 ]
When CONFIG_OPTIMIZE_INLINING is set, the sta_info_insert_finish
function consumes more stack than normally, exceeding the
1024 byte limit on ARM:
net/mac80211/sta_info.c: In function 'sta_info_insert_finish':
net/mac80211/sta_info.c:561:1: error: the frame size of 1080 bytes is larger than 1024 bytes [-Werror=frame-larger-than=]
It turns out that there are two functions that put a 'struct station_info'
on the stack: __sta_info_destroy_part2 and sta_info_insert_finish, and
this structure alone requires up to 792 bytes.
Hoping that both are called rarely enough, this replaces the
on-stack structure with a dynamic allocation, which unfortunately
requires some suboptimal error handling for out-of-memory.
The __sta_info_destroy_part2 function is actually affected by the
stack usage twice because it calls cfg80211_del_sta_sinfo(), which
has another instance of struct station_info on its stack.
Fixes: 98b6218388e3 ("mac80211/cfg80211: add station events")
Fixes: 6f7a8d26e266 ("mac80211: send statistics with delete station event")
