The ->set_mac_address handlers expect a pointer to a
sockaddr which contains the MAC address, whereas
IFLA_ADDRESS provides just the MAC address itself.
So whip up a sockaddr to wrap around the netlink
attribute for the ->set_mac_address call.
Replace add_timer() by mod_timer() in dst_run_gc
in order to avoid BUG message.
CPU1 CPU2
dst_run_gc() entered dst_run_gc() entered
spin_lock(&dst_lock) .....
del_timer(&dst_gc_timer) fail to get lock
.... mod_timer() <--- puts
timer back
to the list
add_timer(&dst_gc_timer) <--- BUG because timer is in list already.
Found during OpenVZ internal testing.
At first we thought that it is OpenVZ specific as we
added dst_run_gc(0) call in dst_dev_event(),
but as Alexey pointed to me it is possible to trigger
this condition in mainstream kernel.
F.e. timer has fired on CPU2, but the handler was preeempted
by an irq before dst_lock is tried.
Meanwhile, someone on CPU1 adds an entry to gc list and
starts the timer.
If CPU2 was preempted long enough, this timer can expire
simultaneously with resuming timer handler on CPU1, arriving
exactly to the situation described.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
When pskb_trim has to defer to ___pksb_trim to trim the frag_list part of
the packet, the frag_list is not updated to reflect the trimming. This
will usually work fine until you hit something that uses the packet length
or tail from the frag_list.
Examples include esp_output and ip_fragment.
Another problem caused by this is that you can end up with a linear packet
with a frag_list attached.
It is possible to get away with this if we audit everything to make sure
that they always consult skb->len before going down onto frag_list. In
fact we can do the samething for the paged part as well to avoid copying
the data area of the skb. For now though, let's do the conservative fix
and update frag_list.
Many thanks to Marco Berizzi for helping me to track down this bug.
This 4-year old bug took 3 months to track down. Marco was very patient
indeed :)
We have seen a couple of __alloc_pages() failures due to
fragmentation, there is plenty of free memory but no large order pages
available. I think the problem is in sock_alloc_send_pskb(), the
gfp_mask includes __GFP_REPEAT but its never used/passed to the page
allocator. Shouldnt the gfp_mask be passed to alloc_skb() ?
Signed-off-by: Larry Woodman <lwoodman@redhat.com>
Since pskb_copy tacks on the non-linear bits from the original
skb, it needs to count them in the truesize field of the new skb.
This patch removes consideration of high memory when determining TCP
hash table sizes. Taking into account high memory results in tcp_mem
values that are too large.
Signed-off-by: John Heffner <jheffner@psc.edu>
During OpenVZ stress testing we found that UDP traffic with random src
can generate too much excessive rt hash growing leading finally to OOM
and kernel panics.
It was found that for 4GB i686 system (having 1048576 total pages and
225280 normal zone pages) kernel allocates the following route hash:
syslog: IP route cache hash table entries: 262144 (order: 8, 1048576
bytes) => ip_rt_max_size = 4194304 entries, i.e. max rt size is
4194304 * 256b = 1Gb of RAM > normal_zone
Attached the patch which removes HASH_HIGHMEM flag from
alloc_large_system_hash() call.
This bug was unknowingly fixed the GSO patches (or rather, its effect was
unknown at the time).
Thanks to Marco Berizzi's persistence which is documented in the thread
"ipsec tunnel asymmetrical mtu", we now know that it can have highly
non-obvious symptoms.
What happens is that uninitialised uso_size fields can cause packets to
be incorrectly identified as UFO, which means that it does not get
fragmented even if it's over the MTU.
The fix is simple enough.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
Module reference needs to be given back if message header
construction fails.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Return ENOENT if action module is unavailable
The TCA_ACT_KIND attribute is used without checking its
availability when dumping actions therefore leading to a
value of 0x4 being dereferenced.
The use of strcmp() in tc_lookup_action_n() isn't safe
when fed with string from an attribute without enforcing
proper NUL termination.
Both bugs can be triggered with malformed netlink message
and don't require any privileges.
"return -err" and blindly inheriting the error code in the netlink
failure exception handler causes errors codes to be returned as
positive value therefore making them being ignored by the caller.
May lead to sending out incomplete netlink messages.
As reported by Mark Dowd <Mark_Dowd@McAfee.com>, ip6_tables is susceptible
to a fragmentation attack causing false negatives on extension header
matches.
When extension headers occur in the non-first fragment after the fragment
header (possibly with an incorrect nexthdr value in the fragment header)
a rule looking for this extension header will never match.
Drop fragments that are at offset 0 and don't contain the final protocol
header regardless of the ruleset, since this should not happen normally.
Since all extension headers are before the protocol header this makes sure
an extension header is either not present or in the first fragment, where
we can properly parse it.
With help from Yasuyuki KOZAKAI <yasuyuki.kozakai@toshiba.co.jp>.
to a fragmentation attack causing false negatives on protocol matches.
When the protocol header doesn't follow the fragment header immediately,
the fragment header contains the protocol number of the next extension
header. When the extension header and the protocol header are sent in
a second fragment a rule like "ip6tables .. -p udp -j DROP" will never
match.
This is a long standing bug that seems to have only recently become
apparent, presumably due to increasing use of NFS over TCP - many
distros seem to be making it the default.
The SK_CONN bit gets set when a listening socket may be ready
for an accept, just as SK_DATA is set when data may be available.
It is entirely possible for svc_tcp_accept to be called with neither
of these set. It doesn't happen often but there is a small race in
svc_sock_enqueue as SK_CONN and SK_DATA are tested outside the
spin_lock. They could be cleared immediately after the test and
before the lock is gained.
This normally shouldn't be a problem. The sockets are non-blocking so
trying to read() or accept() when ther is nothing to do is not a problem.
However: svc_tcp_recvfrom makes the decision "Should I accept() or
should I read()" based on whether SK_CONN is set or not. This usually
works but is not safe. The decision should be based on whether it is
a TCP_LISTEN socket or a TCP_CONNECTED socket.
Signed-off-by: Neil Brown <neilb@suse.de>
There's a bug in the seqfile handling for /proc/net/ip6_flowlabel, where,
after finding a flowlabel, the code will loop forever not finding any
further flowlabels, first traversing the rest of the hash bucket then just
looping.
This patch fixes the problem by breaking after the hash bucket has been
traversed.
Note that this bug can cause lockups and oopses, and is trivially invoked
by an unpriveleged user.
Signed-off-by: James Morris <jmorris@namei.org>
memcpy 4 bytes to address of auto unsigned long variable followed
by comparison with u32 is a bloody bad idea.
Prevents filters from being added if the first generated
handle already exists.
Signed-off-by: Kim Nordlund <kim.nordlund@nokia.com>
In clip_mkip(), skb->dev is dereferenced after clip_push(),
which frees up skb.
Advisory: AD_LAB-06009 (<adlab@venustech.com.cn>).
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch fixes RTNLGRP_IPV6_IFINFO netlink notifications. Issue
pointed out by Patrick McHardy <kaber@trash.net>.
Acked-by: Patrick McHardy <kaber@trash.net>
Mirror the bug fix from fill_packet_ipv4()
Signed-off-by: Chen-Li Tien <cltien@gmail.com>
Bug noticed by Remi Denis-Courmont <rdenis@simphalempin.com>.
With the recent fix, the callers of sctp_primitive_ABORT()
need to create an ABORT chunk and pass it as an argument rather
than msghdr that was passed earlier.
Adrian Bunk:
Ported to 2.6.16.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
The function pointers which were checked were for their get_* counterparts.
Typically a copy-paste typo.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Acked-by: Jeff Garzik <jeff@garzik.org>
Acked-by: David Miller <davem@davemloft.net>
The function ethtool_get_ufo was referring to ETHTOOL_GTSO instead of
ETHTOOL_GUFO.
Acked-by: Matthew Wilcox <matthew@wil.cx>
table->private might change because of ruleset changes, don't use it without
holding the lock.
Fix kernel panic on various SMP machines. The culprit is a null
ub->skb in ulog_send(). If ulog_timer() has already been scheduled on
one CPU and is spinning on the lock, and ipt_ulog_packet() flushes the
queue on another CPU by calling ulog_send() right before it exits,
there will be no skbuff when ulog_timer() acquires the lock and calls
ulog_send(). Cancelling the timer in ulog_send() doesn't help because
it has already been scheduled and is running on the first CPU.
Similar problem exists in ebt_ulog.c and nfnetlink_log.c.
Signed-off-by: Mark Huang <mlhuang@cs.princeton.edu>
Right now, every time we increase our rwnd by more then MTU bytes, we
trigger a SACK. When processing large messages, this will generate a
SACK for almost every other SCTP fragment. However since we are freeing
the entire message at the same time, we might as well collapse the SACK
generation to 1.
Signed-off-by: Tsutomu Fujii <t-fujii@nb.jp.nec.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
When using ASSOCINFO socket option, we need to limit the number of
maximum association retransmissions to be no greater than the sum
of all the path retransmissions. This is specified in Section 7.1.2
of the SCTP socket API draft.
However, we only do this if the association has multiple paths. If
there is only one path, the protocol stack will use the
assoc_max_retrans setting when trying to retransmit packets.
In the event that our entire receive buffer is full with a series of
chunks that represent a single gap-ack, and then we accept a chunk
(or chunks) that fill in the gap between the ctsn and the first gap,
we renege chunks from the end of the buffer, which effectively does
nothing but move our gap to the end of our received tsn stream. This
does little but move our missing tsns down stream a little, and, if the
sender is sending sufficiently large retransmit frames, the result is a
perpetual slowdown which can never be recovered from, since the only
chunk that can be accepted to allow progress in the tsn stream necessitates
that a new gap be created to make room for it. This leads to a constant
need for retransmits, and subsequent receiver stalls. The fix I've come up
with is to deliver the frame without reneging if we have a full receive
buffer and the receiving sockets sk_receive_queue is empty(indicating that
the receive buffer is being blocked by a missing tsn).
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Make SCTP handle broadcast properly
sctp_make_abort_user() now takes the msg_len along with the msg
so that we don't have to recalculate the bytes in iovec.
It also uses memcpy_fromiovec() so that we don't go beyond the
length allocated.
It is good to have this fix even if verify_iovec() is fixed to
return error on overflow.
ieee80211_crypt_tkip will not work without CRC32.
LD .tmp_vmlinux1
net/built-in.o: In function `ieee80211_tkip_encrypt':
net/ieee80211/ieee80211_crypt_tkip.c:349: undefined reference to `crc32_le'
Reported by Toralf Foerster <toralf.foerster@gmx.de>
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
CONFIG_IPV6_PRIVACY
We need to update hiscore.rule even if we don't enable CONFIG_IPV6_PRIVACY,
because we have more less significant rule; longest match.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Two additional labels (RFC 3484, sec. 10.3) for IPv6 addreses
are defined to make a distinction between global unicast
addresses and Unique Local Addresses (fc00::/7, RFC 4193) and
Teredo (2001::/32, RFC 4380). It is necessary to avoid attempts
of connection that would either fail (eg. fec0:: to 2001:feed::)
or be sub-optimal (2001:0:: to 2001:feed::).
Signed-off-by: $,1 aukasz Stelmach <stlman@poczta.fm>
chunks [CVE-2006-2934]
When a packet without any chunks is received, the newconntrack variable
in sctp_packet contains an out of bounds value that is used to look up an
pointer from the array of timeouts, which is then dereferenced, resulting
in a crash. Make sure at least a single chunk is present.
Problem noticed by George A. Theall <theall@tenablesecurity.com>
Fix endless loop in the SCTP match similar to those already fixed in the
SCTP conntrack helper (was CVE-2006-1527).
It appears that sockaddr_in.sin_zero is not zeroed during
getsockopt(...SO_ORIGINAL_DST...) operation. This can lead
to an information leak (CVE-2006-1343).
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
CVE-2006-2444 - Potential remote DoS in SNMP NAT helper.
Fix memory corruption caused by snmp_trap_decode:
- When snmp_trap_decode fails before the id and address are allocated,
the pointers contain random memory, but are freed by the caller
(snmp_parse_mangle).
- When snmp_trap_decode fails after allocating just the ID, it tries
to free both address and ID, but the address pointer still contains
random memory. The caller frees both ID and random memory again.
- When snmp_trap_decode fails after allocating both, it frees both,
and the callers frees both again.
The corruption can be triggered remotely when the ip_nat_snmp_basic
module is loaded and traffic on port 161 or 162 is NATed.
Found by multiple testcases of the trap-app and trap-enc groups of the
PROTOS c06-snmpv1 testsuite.
If SCTP receives a badly formatted HB-ACK chunk, it is possible
that we may access invalid memory and potentially have a buffer
overflow. We should really make sure that the chunk format is
what we expect, before attempting to touch the data.
(CVE-2006-0039)
Solar Designer found a race condition in do_add_counters(). The beginning
of paddc is supposed to be the same as tmp which was sanity-checked
above, but it might not be the same in reality. In case the integer
overflow and/or the race condition are triggered, paddc->num_counters
might not match the allocation size for paddc. If the check below
(t->private->number != paddc->num_counters) nevertheless passes (perhaps
this requires the race condition to be triggered), IPT_ENTRY_ITERATE()
would read kernel memory beyond the allocation size, potentially causing
an oops or leaking sensitive data (e.g., passwords from host system or
from another VPS) via counter increments. This requires CAP_NET_ADMIN.
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=191698
Cc: Solar Designer <solar@openwall.com>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Patrick McHardy <kaber@trash.net>
(chrisw: rebase of Kirill's patch to 2.6.16.16)
DATA. (CVE-2006-2274)
There is a rare situation that causes lksctp to go into infinite recursion
and crash the system. The trigger is a packet that contains at least the
first two DATA fragments of a message bundled together. The recursion is
triggered when the user data buffer is smaller that the full data message.
The problem is that we clone the skb for every fragment in the message.
When reassembling the full message, we try to link skbs from the "first
fragment" clone using the frag_list. However, since the frag_list is shared
between two clones in this rare situation, we end up setting the frag_list
pointer of the second fragment to point to itself. This causes
sctp_skb_pull() to potentially recurse indefinitely.
Proposed solution is to make a copy of the skb when attempting to link
things using frag_list.
Signed-off-by: Vladislav Yasevich <vladsilav.yasevich@hp.com>
(CVE-2006-2275)
This patch fixes a deadlock situation in the receive path by allowing
temporary spillover of the receive buffer.
- If the chunk we receive has a tsn that immediately follows the ctsn,
accept it even if we run out of receive buffer space and renege data with
higher TSNs.
- Once we accept one chunk in a packet, accept all the remaining chunks
even if we run out of receive buffer space.
Acked-by: Mark Butler <butlerm@middle.net>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
(CVE-2006-2271)
Discard an unexpected chunk in CLOSED state rather can calling BUG().
(CVE-2006-2272)
Use pskb_pull() to handle incoming COOKIE_ECHO and HEARTBEAT chunks that
are received as skb's with fragment list.
[NETFILTER]: SCTP conntrack: fix infinite loop
fix infinite loop in the SCTP-netfilter code: check SCTP chunk size to
guarantee progress of for_each_sctp_chunk(). (all other uses of
for_each_sctp_chunk() are preceded by do_basic_checks(), so this fix
should be complete.)
Based on patch from Ingo Molnar <mingo@elte.hu>
[IPV6] XFRM: Fix decoding session with preceding extension header(s).
We did not correctly decode session with preceding extension
header(s). This was because we had already pulled preceding
headers, skb->nh.raw + 40 + 1 - skb->data was minus, and
pskb_may_pull() failed.
We now have IP6CB(skb)->nhoff and skb->h.raw, and we can
start parsing / decoding upper layer protocol from current
position.
Tracked down by Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>
and tested by Kazunori Miyazawa <kazunori@miyazawa.org>.
