[ Upstream commit bef1909ee3ed1ca39231b260a8d3b4544ecd0c8f ]
Fix to a problem observed when losing a FIN segment that does not
contain data. In such situations, TLP is unable to recover from
*any* tail loss and instead adds at least PTO ms to the
retransmission process, i.e., RTO = RTO + PTO.
Signed-off-by: Per Hurtig <per.hurtig@kau.se>
Acked-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit bdf6fa52f01b941d4a80372d56de465bdbbd1d23 ]
Currently association restarts do not take into consideration the
state of the socket. When a restart happens, the current assocation
simply transitions into established state. This creates a condition
where a remote system, through a the restart procedure, may create a
local association that is no way reachable by user. The conditions
to trigger this are as follows:
1) Remote does not acknoledge some data causing data to remain
outstanding.
2) Local application calls close() on the socket. Since data
is still outstanding, the association is placed in SHUTDOWN_PENDING
state. However, the socket is closed.
3) The remote tries to create a new association, triggering a restart
on the local system. The association moves from SHUTDOWN_PENDING
to ESTABLISHED. At this point, it is no longer reachable by
any socket on the local system.
This patch addresses the above situation by moving the newly ESTABLISHED
association into SHUTDOWN-SENT state and bundling a SHUTDOWN after
the COOKIE-ACK chunk. This way, the restarted associate immidiately
enters the shutdown procedure and forces the termination of the
unreachable association.
Reported-by: David Laight <David.Laight@aculab.com>
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 3be07244b7337760a3269d56b2f4a63e72218648 ]
In xmit path, we build a flowi6 which will be used for the output route lookup.
We are sending a GRE packet, neither IPv4 nor IPv6 encapsulated packet, thus the
protocol should be IPPROTO_GRE.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
Reported-by: Matthieu Ternisien d'Ouville <matthieu.tdo@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit b8c203b2d2fc961bafd53b41d5396bbcdec55998 ]
Currently we genarate a queueing route if we have matching policies
but can not resolve the states and the sysctl xfrm_larval_drop is
disabled. Here we assume that dst_output() is called to kill the
queued packets. Unfortunately this assumption is not true in all
cases, so it is possible that these packets leave the system unwanted.
We fix this by generating queueing routes only from the
route lookup functions, here we can guarantee a call to
dst_output() afterwards.
Fixes: a0073fe18e71 ("xfrm: Add a state resolution packet queue")
Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit f92ee61982d6da15a9e49664ecd6405a15a2ee56 ]
Currently we genarate a blackhole route route whenever we have
matching policies but can not resolve the states. Here we assume
that dst_output() is called to kill the balckholed packets.
Unfortunately this assumption is not true in all cases, so
We fix this by generating blackhole routes only from the
Fixes: 2774c131b1d ("xfrm: Handle blackhole route creation via afinfo.")
[ Upstream commit c095f248e63ada504dd90c90baae673ae10ee3fe ]
As Toshiaki Makita pointed out, the BRIDGE_INPUT_SKB_CB will
not be initialized in br_should_learn() as that function
is called only from br_handle_local_finish(). That is
an input handler for link-local ethernet traffic so it perfectly
correct to check br->vlan_enabled here.
Reported-by: Toshiaki Makita<toshiaki.makita1@gmail.com>
Fixes: 20adfa1 bridge: Check if vlan filtering is enabled only once.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
[ Upstream commit 20adfa1a81af00bf2027644507ad4fa9cd2849cf ]
The bridge code checks if vlan filtering is enabled on both
ingress and egress. When the state flip happens, it
is possible for the bridge to currently be forwarding packets
and forwarding behavior becomes non-deterministic. Bridge
may drop packets on some interfaces, but not others.
This patch solves this by caching the filtered state of the
packet into skb_cb on ingress. The skb_cb is guaranteed to
not be over-written between the time packet entres bridge
forwarding path and the time it leaves it. On egress, we
can then check the cached state to see if we need to
apply filtering information.
[ Upstream commit eed4d839b0cdf9d84b0a9bc63de90fd5e1e886fb ]
Use dst_entry held by sk_dst_get() to retrieve tunnel's PMTU.
The dst_mtu(__sk_dst_get(tunnel->sock)) call was racy. __sk_dst_get()
could return NULL if tunnel->sock->sk_dst_cache was reset just before the
call, thus making dst_mtu() dereference a NULL pointer:
[ 1937.661598] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 1937.664005] IP: [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] PGD daf0c067 PUD d9f93067 PMD 0
[ 1937.664005] Oops: 0000 [#1] SMP
[ 1937.664005] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6table_filter ip6_tables iptable_filter ip_tables ebtable_nat ebtables x_tables udp_tunnel pppoe pppox ppp_generic slhc deflate ctr twofish_generic twofish_x86_64_3way xts lrw gf128mul glue_helper twofish_x86_64 twofish_common blowfish_generic blowfish_x86_64 blowfish_common des_generic cbc xcbc rmd160 sha512_generic hmac crypto_null af_key xfrm_algo 8021q garp bridge stp llc tun atmtcp clip atm ext3 mbcache jbd iTCO_wdt coretemp kvm_intel iTCO_vendor_support kvm pcspkr evdev ehci_pci lpc_ich mfd_core i5400_edac edac_core i5k_amb shpchp button processor thermal_sys xfs crc32c_generic libcrc32c dm_mod usbhid sg hid sr_mod sd_mod cdrom crc_t10dif crct10dif_common ata_generic ahci ata_piix tg3 libahci libata uhci_hcd ptp ehci_hcd pps_core usbcore scsi_mod libphy usb_common [last unloaded: l2tp_core]
[ 1937.664005] CPU: 0 PID: 10022 Comm: l2tpstress Tainted: G O 3.17.0-rc1 #1
[ 1937.664005] Hardware name: HP ProLiant DL160 G5, BIOS O12 08/22/2008
[ 1937.664005] task: ffff8800d8fda790 ti: ffff8800c43c4000 task.ti: ffff8800c43c4000
[ 1937.664005] RIP: 0010:[<ffffffffa049db88>] [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP: 0018:ffff8800c43c7de8 EFLAGS: 00010282
[ 1937.664005] RAX: ffff8800da8a7240 RBX: ffff8800d8c64600 RCX: 000001c325a137b5
[ 1937.664005] RDX: 8c6318c6318c6320 RSI: 000000000000010c RDI: 0000000000000000
[ 1937.664005] RBP: ffff8800c43c7ea8 R08: 0000000000000000 R09: 0000000000000000
[ 1937.664005] R10: ffffffffa048e2c0 R11: ffff8800d8c64600 R12: ffff8800ca7a5000
[ 1937.664005] R13: ffff8800c439bf40 R14: 000000000000000c R15: 0000000000000009
[ 1937.664005] FS: 00007fd7f610f700(0000) GS:ffff88011a600000(0000) knlGS:0000000000000000
[ 1937.664005] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1937.664005] CR2: 0000000000000020 CR3: 00000000d9d75000 CR4: 00000000000027e0
[ 1937.664005] Stack:
[ 1937.664005] ffffffffa049da80 ffff8800d8fda790 000000000000005b ffff880000000009
[ 1937.664005] ffff8800daf3f200 0000000000000003 ffff8800c43c7e48 ffffffff81109b57
[ 1937.664005] ffffffff81109b0e ffffffff8114c566 0000000000000000 0000000000000000
[ 1937.664005] Call Trace:
[ 1937.664005] [<ffffffffa049da80>] ? pppol2tp_connect+0x235/0x41e [l2tp_ppp]
[ 1937.664005] [<ffffffff81109b57>] ? might_fault+0x9e/0xa5
[ 1937.664005] [<ffffffff81109b0e>] ? might_fault+0x55/0xa5
[ 1937.664005] [<ffffffff8114c566>] ? rcu_read_unlock+0x1c/0x26
[ 1937.664005] [<ffffffff81309196>] SYSC_connect+0x87/0xb1
[ 1937.664005] [<ffffffff813e56f7>] ? sysret_check+0x1b/0x56
[ 1937.664005] [<ffffffff8107590d>] ? trace_hardirqs_on_caller+0x145/0x1a1
[ 1937.664005] [<ffffffff81213dee>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[ 1937.664005] [<ffffffff8114c262>] ? spin_lock+0x9/0xb
[ 1937.664005] [<ffffffff813092b4>] SyS_connect+0x9/0xb
[ 1937.664005] [<ffffffff813e56d2>] system_call_fastpath+0x16/0x1b
[ 1937.664005] Code: 10 2a 84 81 e8 65 76 bd e0 65 ff 0c 25 10 bb 00 00 4d 85 ed 74 37 48 8b 85 60 ff ff ff 48 8b 80 88 01 00 00 48 8b b8 10 02 00 00 <48> 8b 47 20 ff 50 20 85 c0 74 0f 83 e8 28 89 83 10 01 00 00 89
[ 1937.664005] RIP [<ffffffffa049db88>] pppol2tp_connect+0x33d/0x41e [l2tp_ppp]
[ 1937.664005] RSP <ffff8800c43c7de8>
[ 1939.559375] ---[ end trace 82d44500f28f8708 ]---
Fixes: f34c4a35d879 ("l2tp: take PMTU from tunnel UDP socket")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 2ba5af42a7b59ef01f9081234d8855140738defd ]
When there are multiple vlan headers present in a received frame, the first
one is put into vlan_tci and protocol is set to ETH_P_8021Q. Anything in the
skb beyond the VLAN TPID may be still non-linear, including the inner TCI
and ethertype. While ovs_flow_extract takes care of IP and IPv6 headers, it
does nothing with ETH_P_8021Q. Later, if OVS_ACTION_ATTR_POP_VLAN is
executed, __pop_vlan_tci pulls the next vlan header into vlan_tci.
This leads to two things:
1. Part of the resulting ethernet header is in the non-linear part of the
skb. When eth_type_trans is called later as the result of
OVS_ACTION_ATTR_OUTPUT, kernel BUGs in __skb_pull. Also, __pop_vlan_tci
is in fact accessing random data when it reads past the TPID.
2. network_header points into the ethernet header instead of behind it.
mac_len is set to a wrong value (10), too.
Reported-by: Yulong Pei <ypei@redhat.com>
Signed-off-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit dc808110bb62b64a448696ecac3938902c92e1ab ]
af_packet can currently overwrite kernel memory by out of bound
accesses, because it assumed a [new] block can always hold one frame.
This is not generally the case, even if most existing tools do it right.
This patch clamps too long frames as API permits, and issue a one time
error on syslog.
[ 394.357639] tpacket_rcv: packet too big, clamped from 5042 to 3966. macoff=82
In this example, packet header tp_snaplen was set to 3966,
and tp_len was set to 5042 (skb->len)
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
Acked-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 0c9ab09223fe9922baeb22546c9a90d774a4bde6 ]
Fix TCP FRTO logic so that it always notices when snd_una advances,
indicating that any RTO after that point will be a new and distinct
loss episode.
Previously there was a very specific sequence that could cause FRTO to
fail to notice a new loss episode had started:
(1) RTO timer fires, enter FRTO and retransmit packet 1 in write queue
(2) receiver ACKs packet 1
(3) FRTO sends 2 more packets
(4) RTO timer fires again (should start a new loss episode)
The problem was in step (3) above, where tcp_process_loss() returned
early (in the spot marked "Step 2.b"), so that it never got to the
logic to clear icsk_retransmits. Thus icsk_retransmits stayed
non-zero. Thus in step (4) tcp_enter_loss() would see the non-zero
icsk_retransmits, decide that this RTO is not a new episode, and
decide not to cut ssthresh and remember the current cwnd and ssthresh
for undo.
There were two main consequences to the bug that we have
observed. First, ssthresh was not decreased in step (4). Second, when
there was a series of such FRTO (1-4) sequences that happened to be
followed by an FRTO undo, we would restore the cwnd and ssthresh from
before the entire series started (instead of the cwnd and ssthresh
from before the most recent RTO). This could result in cwnd and
ssthresh being restored to values much bigger than the proper values.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Fixes: e33099f96d99c ("tcp: implement RFC5682 F-RTO")
[ Upstream commit 4fab9071950c2021d846e18351e0f46a1cffd67b ]
Make sure we use the correct address-family-specific function for
handling MTU reductions from within tcp_release_cb().
Previously AF_INET6 sockets were incorrectly always using the IPv6
code path when sometimes they were handling IPv4 traffic and thus had
an IPv4 dst.
Diagnosed-by: Willem de Bruijn <willemb@google.com>
Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications")
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit bc8fc7b8f825ef17a0fb9e68c18ce94fa66ab337 ]
As of 4fddbf5d78 ("sit: strictly restrict incoming traffic to tunnel link device"),
when looking up a tunnel, tunnel's underlying interface (t->parms.link)
is verified to match incoming traffic's ingress device.
However the comparison was incorrectly based on skb->dev->iflink.
Instead, dev->ifindex should be used, which correctly represents the
interface from which the IP stack hands the ipip6 packets.
This allows setting up sit tunnels bound to vlan interfaces (otherwise
incoming ipip6 traffic on the vlan interface was dropped due to
ipip6_tunnel_lookup match failure).
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 0d5501c1c828fb97d02af50aa9d2b1a5498b94e4 ]
Currently the functionality to untag traffic on input resides
as part of the vlan module and is build only when VLAN support
is enabled in the kernel. When VLAN is disabled, the function
vlan_untag() turns into a stub and doesn't really untag the
packets. This seems to create an interesting interaction
between VMs supporting checksum offloading and some network drivers.
There are some drivers that do not allow the user to change
tx-vlan-offload feature of the driver. These drivers also seem
to assume that any VLAN-tagged traffic they transmit will
have the vlan information in the vlan_tci and not in the vlan
header already in the skb. When transmitting skbs that already
have tagged data with partial checksum set, the checksum doesn't
appear to be updated correctly by the card thus resulting in a
failure to establish TCP connections.
The following is a packet trace taken on the receiver where a
sender is a VM with a VLAN configued. The host VM is running on
doest not have VLAN support and the outging interface on the
host is tg3:
10:12:43.503055 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27243,
offset 0, flags [DF], proto TCP (6), length 60)
10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect
-> 0x48d9), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294837885 ecr 0,nop,wscale 7], length 0
10:12:44.505556 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27244,
-> 0x44ee), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294838888 ecr 0,nop,wscale 7], length 0
This connection finally times out.
I've only access to the TG3 hardware in this configuration thus have
only tested this with TG3 driver. There are a lot of other drivers
that do not permit user changes to vlan acceleration features, and
I don't know if they all suffere from a similar issue.
The patch attempt to fix this another way. It moves the vlan header
stipping code out of the vlan module and always builds it into the
kernel network core. This way, even if vlan is not supported on
a virtualizatoin host, the virtual machines running on top of such
host will still work with VLANs enabled.
CC: Patrick McHardy <kaber@trash.net>
CC: Nithin Nayak Sujir <nsujir@broadcom.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Jiri Pirko <jiri@resnulli.us>
Acked-by: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 945a36761fd7877660f630bbdeb4ff9ff80d1935 ]
Commit 1d8faf48c74b8 ("net/core: Add VF link state control") added new
attribute to IFLA_VF_INFO group in rtnl_fill_ifinfo but did not adjust size
of the allocated memory in if_nlmsg_size/rtnl_vfinfo_size. As the result, we
may trigger warnings in rtnl_getlink and similar functions when many VF
links are enabled, as the information does not fit into the allocated skb.
Fixes: 1d8faf48c74b8 ("net/core: Add VF link state control")
[ Upstream commit 4e48ed883c72e78c5a910f8831ffe90c9b18f0ec ]
netlink doesn't set any network header offset thus when the skb is
being passed to tap devices via dev_queue_xmit_nit(), it emits klog
false positives due to it being unset like:
[ 124.990397] protocol 0000 is buggy, dev nlmon0
[ 124.990411] protocol 0000 is buggy, dev nlmon0
So just reset the network header before passing to the device; for
packet sockets that just means nothing will change - mac and net
offset hold the same value just as before.
Reported-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
commit bd8c78e78d5011d8111bc2533ee73b13a3bd6c42 upstream.
In testmode and vendor command reply/event SKBs we use the
skb cb data to store nl80211 parameters between allocation
and sending. This causes the code for CONFIG_NETLINK_MMAP
to get confused, because it takes ownership of the skb cb
data when the SKB is handed off to netlink, and it doesn't
explicitly clear it.
Clear the skb cb explicitly when we're done and before it
gets passed to netlink to avoid this issue.
Reported-by: Assaf Azulay <assaf.azulay@intel.com>
Reported-by: David Spinadel <david.spinadel@intel.com>
commit bb512ad0732232f1d2693bb68f31a76bed8f22ae upstream.
This reverts commit 24aa11ab8ae03292d38ec0dbd9bc2ac49fe8a6dd.
That commit was wrong since it uses data that hasn't even been set
up yet, but might be a hold-over from a previous connection.
Additionally, it seems like a driver-specific workaround that
shouldn't have been in mac80211 to start with.
Fixes: 24aa11ab8ae0 ("mac80211: disable uAPSD if all ACs are under ACM")
Reviewed-by: Luciano Coelho <luciano.coelho@intel.com>
commit eb90b0c734ad793d5f5bf230a9e9a4dcc48df8aa upstream.
commit fc604767613b6d2036cdc35b660bc39451040a47
("ipvs: changes for local real server") from 2.6.37
introduced DNAT support to local real server but the
IPv6 LOCAL_OUT handler ip_vs_local_reply6() is
registered incorrectly as IPv4 hook causing any outgoing
IPv4 traffic to be dropped depending on the IP header values.
Chris tracked down the problem to CONFIG_IP_VS_IPV6=y
Bug report: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1349768
Reported-by: Chris J Arges <chris.j.arges@canonical.com>
Tested-by: Chris J Arges <chris.j.arges@canonical.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit 76f084bc10004b3050b2cff9cfac29148f1f6088 upstream.
Previously, only the four high bits of the tclass were maintained in the
ipv6 case. This matches the behavior of ipv4, though whether or not we
should reflect ECN bits may be up for debate.
Signed-off-by: Alex Gartrell <agartrell@fb.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
commit 2627b7e15c5064ddd5e578e4efd948d48d531a3f upstream.
commit 8f4e0a18682d91 ("IPVS netns exit causes crash in conntrack")
added second ip_vs_conn_drop_conntrack call instead of just adding
the needed check. As result, the first call still can cause
crash on netns exit. Remove it.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
commit 73c3d4812b4c755efeca0140f606f83772a39ce4 upstream.
We preallocate a few of the message types we get back from the mon. If we
get a larger message than we are expecting, fall back to trying to allocate
a new one instead of blindly using the one we have.
Signed-off-by: Sage Weil <sage@redhat.com>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
commit c27a3e4d667fdcad3db7b104f75659478e0c68d8 upstream.
We hard code cephx auth ticket buffer size to 256 bytes. This isn't
enough for any moderate setups and, in case tickets themselves are not
encrypted, leads to buffer overflows (ceph_x_decrypt() errors out, but
ceph_decode_copy() doesn't - it's just a memcpy() wrapper). Since the
buffer is allocated dynamically anyway, allocated it a bit later, at
the point where we know how much is going to be needed.
Fixes: http://tracker.ceph.com/issues/8979
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit 597cda357716a3cf8d994cb11927af917c8d71fa upstream.
Add a helper for processing individual cephx auth tickets. Needed for
the next commit, which deals with allocating ticket buffers. (Most of
the diff here is whitespace - view with git diff -b).
commit 5f740d7e1531099b888410e6bab13f68da9b1a4d upstream.
Determining ->last_piece based on the value of ->page_offset + length
is incorrect because length here is the length of the entire message.
->last_piece set to false even if page array data item length is <=
PAGE_SIZE, which results in invalid length passed to
ceph_tcp_{send,recv}page() and causes various asserts to fire.
# cat pages-cursor-init.sh
#!/bin/bash
rbd create --size 10 --image-format 2 foo
FOO_DEV=$(rbd map foo)
dd if=/dev/urandom of=$FOO_DEV bs=1M &>/dev/null
rbd snap create foo@snap
rbd snap protect foo@snap
rbd clone foo@snap bar
# rbd_resize calls librbd rbd_resize(), size is in bytes
./rbd_resize bar $(((4 << 20) + 512))
rbd resize --size 10 bar
BAR_DEV=$(rbd map bar)
# trigger a 512-byte copyup -- 512-byte page array data item
dd if=/dev/urandom of=$BAR_DEV bs=1M count=1 seek=5
The problem exists only in ceph_msg_data_pages_cursor_init(),
ceph_msg_data_pages_advance() does the right thing. The size_t cast is
unnecessary.
Reviewed-by: Alex Elder <elder@linaro.org>
commit 32333edb82fb2009980eefc5518100068147ab82 upstream.
The commits 08c30aca9e698faddebd34f81e1196295f9dc063 "Bluetooth: Remove
RFCOMM session refcnt" and 8ff52f7d04d9cc31f1e81dcf9a2ba6335ed34905
"Bluetooth: Return RFCOMM session ptrs to avoid freed session"
allow rfcomm_recv_ua and rfcomm_session_close to delete the session
(and free the corresponding socket) and propagate NULL session pointer
to the upper callers.
Additional fix is required to terminate the loop in rfcomm_process_rx
function to avoid use of freed 'sk' memory.
The issue is only reproducible with kernel option CONFIG_PAGE_POISONING
enabled making freed memory being changed and filled up with fixed char
value used to unmask use-after-free issues.
Signed-off-by: Vignesh Raman <Vignesh_Raman@mentor.com>
Signed-off-by: Vitaly Kuzmichev <Vitaly_Kuzmichev@mentor.com>
Acked-by: Dean Jenkins <Dean_Jenkins@mentor.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 093facf3634da1b0c2cc7ed106f1983da901bbab upstream.
If the current process is exiting, lingering on socket close will make
it unkillable, so we should avoid it.
Reproducer:
#include <sys/types.h>
#include <sys/socket.h>
#define BTPROTO_L2CAP 0
#define BTPROTO_SCO 2
#define BTPROTO_RFCOMM 3
int main()
int fd;
struct linger ling;
fd = socket(PF_BLUETOOTH, SOCK_STREAM, BTPROTO_RFCOMM);
//or: fd = socket(PF_BLUETOOTH, SOCK_DGRAM, BTPROTO_L2CAP);
//or: fd = socket(PF_BLUETOOTH, SOCK_SEQPACKET, BTPROTO_SCO);
ling.l_onoff = 1;
ling.l_linger = 1000000000;
setsockopt(fd, SOL_SOCKET, SO_LINGER, &ling, sizeof(ling));
return 0;
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 5c0a0fc81f4dc786b42c4fc9c7c72ba635406ab5 upstream.
tipc_msg_build() calls skb_copy_to_linear_data_offset() to copy data
from user space to kernel space. However, the latter function does
in its turn call memcpy() to perform the actual copying. This poses
an obvious security and robustness risk, since memcpy() never makes
any validity check on the pointer it is copying from.
To correct this, we the replace the offending function call with
a call to memcpy_fromiovecend(), which uses copy_from_user() to
perform the copying.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
commit 448cd2e248732326632957e52ea9c44729affcb2 upstream.
In case of beacon_loss with IEEE80211_HW_CONNECTION_MONITOR
device, mac80211 probes the ap (and disconnects on timeout)
but ignores the ack.
If we already got an ack, there's no reason to continue
disconnecting. this can help devices that supports
IEEE80211_HW_CONNECTION_MONITOR only partially (e.g. take
care of keep alives, but does not probe the ap.
In case the device wants to disconnect without probing,
it can just call ieee80211_connection_loss.
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
[ Upstream commit 757efd32d5ce31f67193cc0e6a56e4dffcc42fb1 ]
Dave reported following splat, caused by improper use of
IP_INC_STATS_BH() in process context.
BUG: using __this_cpu_add() in preemptible [00000000] code: trinity-c117/14551
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 3 PID: 14551 Comm: trinity-c117 Not tainted 3.16.0+ #33
ffffffff9ec898f0 0000000047ea7e23 ffff88022d32f7f0 ffffffff9e7ee207
0000000000000003 ffff88022d32f818 ffffffff9e397eaa ffff88023ee70b40
ffff88022d32f970 ffff8801c026d580 ffff88022d32f828 ffffffff9e397ee3
Call Trace:
[<ffffffff9e7ee207>] dump_stack+0x4e/0x7a
[<ffffffff9e397eaa>] check_preemption_disabled+0xfa/0x100
[<ffffffff9e397ee3>] __this_cpu_preempt_check+0x13/0x20
[<ffffffffc0839872>] sctp_packet_transmit+0x692/0x710 [sctp]
[<ffffffffc082a7f2>] sctp_outq_flush+0x2a2/0xc30 [sctp]
[<ffffffff9e0d985c>] ? mark_held_locks+0x7c/0xb0
[<ffffffff9e7f8c6d>] ? _raw_spin_unlock_irqrestore+0x5d/0x80
[<ffffffffc082b99a>] sctp_outq_uncork+0x1a/0x20 [sctp]
[<ffffffffc081e112>] sctp_cmd_interpreter.isra.23+0x1142/0x13f0 [sctp]
[<ffffffffc081c86b>] sctp_do_sm+0xdb/0x330 [sctp]
[<ffffffff9e0b8f1b>] ? preempt_count_sub+0xab/0x100
[<ffffffffc083b350>] ? sctp_cname+0x70/0x70 [sctp]
[<ffffffffc08389ca>] sctp_primitive_ASSOCIATE+0x3a/0x50 [sctp]
[<ffffffffc083358f>] sctp_sendmsg+0x88f/0xe30 [sctp]
[<ffffffff9e0d673a>] ? lock_release_holdtime.part.28+0x9a/0x160
[<ffffffff9e0d62ce>] ? put_lock_stats.isra.27+0xe/0x30
[<ffffffff9e73b624>] inet_sendmsg+0x104/0x220
[<ffffffff9e73b525>] ? inet_sendmsg+0x5/0x220
[<ffffffff9e68ac4e>] sock_sendmsg+0x9e/0xe0
[<ffffffff9e1c0c09>] ? might_fault+0xb9/0xc0
[<ffffffff9e1c0bae>] ? might_fault+0x5e/0xc0
[<ffffffff9e68b234>] SYSC_sendto+0x124/0x1c0
[<ffffffff9e0136b0>] ? syscall_trace_enter+0x250/0x330
[<ffffffff9e68c3ce>] SyS_sendto+0xe/0x10
[<ffffffff9e7f9be4>] tracesys+0xdd/0xe2
This is a followup of commits f1d8cba61c3c4b ("inet: fix possible
seqlock deadlocks") and 7f88c6b23afbd315 ("ipv6: fix possible seqlock
deadlock in ip6_finish_output2")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit 06ebb06d49486676272a3c030bfeef4bd969a8e6 ]
Check for cases when the caller requests 0 bytes instead of running off
and dereferencing potentially invalid iovecs.
[ Upstream commit fcdfe3a7fa4cb74391d42b6a26dc07c20dab1d82 ]
When performing segmentation, the mac_len value is copied right
out of the original skb. However, this value is not always set correctly
(like when the packet is VLAN-tagged) and we'll end up copying a bad
value.
One way to demonstrate this is to configure a VM which tags
packets internally and turn off VLAN acceleration on the forwarding
bridge port. The packets show up corrupt like this:
16:18:24.985548 52:54:00:ab:be:25 > 52:54:00:26:ce:a3, ethertype 802.1Q
(0x8100), length 1518: vlan 100, p 0, ethertype 0x05e0,
0x0000: 8cdb 1c7c 8cdb 0064 4006 b59d 0a00 6402 ...|...d@.....d.
0x0010: 0a00 6401 9e0d b441 0a5e 64ec 0330 14fa ..d....A.^d..0..
0x0020: 29e3 01c9 f871 0000 0101 080a 000a e833)....q.........3
0x0030: 000f 8c75 6e65 7470 6572 6600 6e65 7470 ...unetperf.netp
0x0040: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
0x0050: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
0x0060: 6572 6600 6e65 7470 6572 6600 6e65 7470 erf.netperf.netp
This also leads to awful throughput as GSO packets are dropped and
cause retransmissions.
The solution is to set the mac_len using the values already available
in then new skb. We've already adjusted all of the header offset, so we
might as well correctly figure out the mac_len using skb_reset_mac_len().
After this change, packets are segmented correctly and performance
is restored.
CC: Eric Dumazet <edumazet@google.com>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 1be9a950c646c9092fb3618197f7b6bfb50e82aa ]
Jason reported an oops caused by SCTP on his ARM machine with
SCTP authentication enabled:
Internal error: Oops: 17 [#1] ARM
CPU: 0 PID: 104 Comm: sctp-test Not tainted 3.13.0-68744-g3632f30c9b20-dirty #1
task: c6eefa40 ti: c6f52000 task.ti: c6f52000
PC is at sctp_auth_calculate_hmac+0xc4/0x10c
LR is at sg_init_table+0x20/0x38
pc : [<c024bb80>] lr : [<c00f32dc>] psr: 40000013
sp : c6f538e8 ip : 00000000 fp : c6f53924
r10: c6f50d80 r9 : 00000000 r8 : 00010000
r7 : 00000000 r6 : c7be4000 r5 : 00000000 r4 : c6f56254
r3 : c00c8170 r2 : 00000001 r1 : 00000008 r0 : c6f1e660
Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005397f Table: 06f28000 DAC: 00000015
Process sctp-test (pid: 104, stack limit = 0xc6f521c0)
Stack: (0xc6f538e8 to 0xc6f54000)
Backtrace:
[<c024babc>] (sctp_auth_calculate_hmac+0x0/0x10c) from [<c0249af8>] (sctp_packet_transmit+0x33c/0x5c8)
[<c02497bc>] (sctp_packet_transmit+0x0/0x5c8) from [<c023e96c>] (sctp_outq_flush+0x7fc/0x844)
[<c023e170>] (sctp_outq_flush+0x0/0x844) from [<c023ef78>] (sctp_outq_uncork+0x24/0x28)
[<c023ef54>] (sctp_outq_uncork+0x0/0x28) from [<c0234364>] (sctp_side_effects+0x1134/0x1220)
[<c0233230>] (sctp_side_effects+0x0/0x1220) from [<c02330b0>] (sctp_do_sm+0xac/0xd4)
[<c0233004>] (sctp_do_sm+0x0/0xd4) from [<c023675c>] (sctp_assoc_bh_rcv+0x118/0x160)
[<c0236644>] (sctp_assoc_bh_rcv+0x0/0x160) from [<c023d5bc>] (sctp_inq_push+0x6c/0x74)
[<c023d550>] (sctp_inq_push+0x0/0x74) from [<c024a6b0>] (sctp_rcv+0x7d8/0x888)
While we already had various kind of bugs in that area
ec0223ec48a9 ("net: sctp: fix sctp_sf_do_5_1D_ce to verify if
we/peer is AUTH capable") and b14878ccb7fa ("net: sctp: cache
auth_enable per endpoint"), this one is a bit of a different
kind.
Giving a bit more background on why SCTP authentication is
needed can be found in RFC4895:
SCTP uses 32-bit verification tags to protect itself against
blind attackers. These values are not changed during the
lifetime of an SCTP association.
Looking at new SCTP extensions, there is the need to have a
method of proving that an SCTP chunk(s) was really sent by
the original peer that started the association and not by a
malicious attacker.
To cause this bug, we're triggering an INIT collision between
peers; normal SCTP handshake where both sides intent to
authenticate packets contains RANDOM; CHUNKS; HMAC-ALGO
parameters that are being negotiated among peers:
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
RFC4895 says that each endpoint therefore knows its own random
number and the peer's random number *after* the association
has been established. The local and peer's random number along
with the shared key are then part of the secret used for
calculating the HMAC in the AUTH chunk.
Now, in our scenario, we have 2 threads with 1 non-blocking
SEQ_PACKET socket each, setting up common shared SCTP_AUTH_KEY
and SCTP_AUTH_ACTIVE_KEY properly, and each of them calling
sctp_bindx(3), listen(2) and connect(2) against each other,
thus the handshake looks similar to this, e.g.:
<--------- INIT[RANDOM; CHUNKS; HMAC-ALGO] -----------
-------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] -------->
Since such collisions can also happen with verification tags,
the RFC4895 for AUTH rather vaguely says under section 6.1:
In case of INIT collision, the rules governing the handling
of this Random Number follow the same pattern as those for
the Verification Tag, as explained in Section 5.2.4 of
RFC 2960 [5]. Therefore, each endpoint knows its own Random
Number and the peer's Random Number after the association
In RFC2960, section 5.2.4, we're eventually hitting Action B:
B) In this case, both sides may be attempting to start an
association at about the same time but the peer endpoint
started its INIT after responding to the local endpoint's
INIT. Thus it may have picked a new Verification Tag not
being aware of the previous Tag it had sent this endpoint.
The endpoint should stay in or enter the ESTABLISHED
state but it MUST update its peer's Verification Tag from
the State Cookie, stop any init or cookie timers that may
running and send a COOKIE ACK.
In other words, the handling of the Random parameter is the
same as behavior for the Verification Tag as described in
Action B of section 5.2.4.
Looking at the code, we exactly hit the sctp_sf_do_dupcook_b()
case which triggers an SCTP_CMD_UPDATE_ASSOC command to the
side effect interpreter, and in fact it properly copies over
peer_{random, hmacs, chunks} parameters from the newly created
association to update the existing one.
Also, the old asoc_shared_key is being released and based on
the new params, sctp_auth_asoc_init_active_key() updated.
However, the issue observed in this case is that the previous
asoc->peer.auth_capable was 0, and has *not* been updated, so
that instead of creating a new secret, we're doing an early
return from the function sctp_auth_asoc_init_active_key()
leaving asoc->asoc_shared_key as NULL. However, we now have to
authenticate chunks from the updated chunk list (e.g. COOKIE-ACK).
That in fact causes the server side when responding with ...
<------------------ AUTH; COOKIE-ACK -----------------
... to trigger a NULL pointer dereference, since in
sctp_packet_transmit(), it discovers that an AUTH chunk is
being queued for xmit, and thus it calls sctp_auth_calculate_hmac().
Since the asoc->active_key_id is still inherited from the
endpoint, and the same as encoded into the chunk, it uses
asoc->asoc_shared_key, which is still NULL, as an asoc_key
and dereferences it in ...
crypto_hash_setkey(desc.tfm, &asoc_key->data[0], asoc_key->len)
... causing an oops. All this happens because sctp_make_cookie_ack()
called with the *new* association has the peer.auth_capable=1
and therefore marks the chunk with auth=1 after checking
sctp_auth_send_cid(), but it is *actually* sent later on over
the then *updated* association's transport that didn't initialize
its shared key due to peer.auth_capable=0. Since control chunks
in that case are not sent by the temporary association which
are scheduled for deletion, they are issued for xmit via
SCTP_CMD_REPLY in the interpreter with the context of the
*updated* association. peer.auth_capable was 0 in the updated
association (which went from COOKIE_WAIT into ESTABLISHED state),
since all previous processing that performed sctp_process_init()
was being done on temporary associations, that we eventually
throw away each time.
The correct fix is to update to the new peer.auth_capable
value as well in the collision case via sctp_assoc_update(),
so that in case the collision migrated from 0 -> 1,
sctp_auth_asoc_init_active_key() can properly recalculate
the secret. This therefore fixes the observed server panic.
Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing")
Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Tested-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 1f74e613ded11517db90b2bd57e9464d9e0fb161 ]
In vegas we do a multiplication of the cwnd and the rtt. This
may overflow and thus their result is stored in a u64. However, we first
need to cast the cwnd so that actually 64-bit arithmetic is done.
Then, we need to do do_div to allow this to be used on 32-bit arches.
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Doug Leith <doug.leith@nuim.ie>
Fixes: 8d3a564da34e (tcp: tcp_vegas cong avoid fix)
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
[ Upstream commit 45a07695bc64b3ab5d6d2215f9677e5b8c05a7d0 ]
In veno we do a multiplication of the cwnd and the rtt. This
A first attempt at fixing 76f1017757aa0 ([TCP]: TCP Veno congestion
control) was made by 159131149c2 (tcp: Overflow bug in Vegas), but it
failed to add the required cast in tcp_veno_cong_avoid().
Fixes: 76f1017757aa0 ([TCP]: TCP Veno congestion control)
[ Upstream commit 40eea803c6b2cfaab092f053248cbeab3f368412 ]
Sasha's report:
> While fuzzing with trinity inside a KVM tools guest running the latest -next
> kernel with the KASAN patchset, I've stumbled on the following spew:
> [ 4448.949424] ==================================================================
> [ 4448.951737] AddressSanitizer: user-memory-access on address 0
> [ 4448.952988] Read of size 2 by thread T19638:
> [ 4448.954510] CPU: 28 PID: 19638 Comm: trinity-c76 Not tainted 3.16.0-rc4-next-20140711-sasha-00046-g07d3099-dirty #813
> [ 4448.956823] ffff88046d86ca40 0000000000000000 ffff880082f37e78 ffff880082f37a40
> [ 4448.958233] ffffffffb6e47068 ffff880082f37a68 ffff880082f37a58 ffffffffb242708d
> [ 4448.959552] 0000000000000000 ffff880082f37a88 ffffffffb24255b1 0000000000000000
> [ 4448.961266] Call Trace:
> [ 4448.963158] dump_stack (lib/dump_stack.c:52)
> [ 4448.964244] kasan_report_user_access (mm/kasan/report.c:184)
> [ 4448.965507] __asan_load2 (mm/kasan/kasan.c:352)
> [ 4448.966482] ? netlink_sendmsg (net/netlink/af_netlink.c:2339)
> [ 4448.967541] netlink_sendmsg (net/netlink/af_netlink.c:2339)
> [ 4448.968537] ? get_parent_ip (kernel/sched/core.c:2555)
> [ 4448.970103] sock_sendmsg (net/socket.c:654)
> [ 4448.971584] ? might_fault (mm/memory.c:3741)
> [ 4448.972526] ? might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3740)
> [ 4448.973596] ? verify_iovec (net/core/iovec.c:64)
> [ 4448.974522] ___sys_sendmsg (net/socket.c:2096)
> [ 4448.975797] ? put_lock_stats.isra.13 (./arch/x86/include/asm/preempt.h:98 kernel/locking/lockdep.c:254)
> [ 4448.977030] ? lock_release_holdtime (kernel/locking/lockdep.c:273)
> [ 4448.978197] ? lock_release_non_nested (kernel/locking/lockdep.c:3434 (discriminator 1))
> [ 4448.979346] ? check_chain_key (kernel/locking/lockdep.c:2188)
> [ 4448.980535] __sys_sendmmsg (net/socket.c:2181)
> [ 4448.981592] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600)
> [ 4448.982773] ? trace_hardirqs_on (kernel/locking/lockdep.c:2607)
> [ 4448.984458] ? syscall_trace_enter (arch/x86/kernel/ptrace.c:1500 (discriminator 2))
> [ 4448.985621] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2600)
> [ 4448.986754] SyS_sendmmsg (net/socket.c:2201)
> [ 4448.987708] tracesys (arch/x86/kernel/entry_64.S:542)
> [ 4448.988929] ==================================================================
This reports means that we've come to netlink_sendmsg() with msg->msg_name == NULL and msg->msg_namelen > 0.
After this report there was no usual "Unable to handle kernel NULL pointer dereference"
and this gave me a clue that address 0 is mapped and contains valid socket address structure in it.
This bug was introduced in f3d3342602f8bcbf37d7c46641cb9bca7618eb1c
(net: rework recvmsg handler msg_name and msg_namelen logic).
Commit message states that:
"Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address."
But in fact this affects sendto when address 0 is mapped and contains
socket address structure in it. In such case copy-in address will succeed,
verify_iovec() function will successfully exit with msg->msg_namelen > 0
and msg->msg_name == NULL.
This patch fixes it by setting msg_namelen to 0 if msg_name == NULL.
Cc: Eric Dumazet <edumazet@google.com>
Cc: <stable@vger.kernel.org>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
[ Upstream commit 04ca6973f7c1a0d8537f2d9906a0cf8e69886d75 ]
In "Counting Packets Sent Between Arbitrary Internet Hosts", Jeffrey and
Jedidiah describe ways exploiting linux IP identifier generation to
infer whether two machines are exchanging packets.
With commit 73f156a6e8c1 ("inetpeer: get rid of ip_id_count"), we
changed IP id generation, but this does not really prevent this
side-channel technique.
This patch adds a random amount of perturbation so that IP identifiers
for a given destination [1] are no longer monotonically increasing after
an idle period.
Note that prandom_u32_max(1) returns 0, so if generator is used at most
once per jiffy, this patch inserts no hole in the ID suite and do not
increase collision probability.
This is jiffies based, so in the worst case (HZ=1000), the id can
rollover after ~65 seconds of idle time, which should be fine.
We also change the hash used in __ip_select_ident() to not only hash
on daddr, but also saddr and protocol, so that ICMP probes can not be
used to infer information for other protocols.
For IPv6, adds saddr into the hash as well, but not nexthdr.
If I ping the patched target, we can see ID are now hard to predict.
21:57:11.008086 IP (...)
A > target: ICMP echo request, seq 1, length 64
21:57:11.010752 IP (... id 2081 ...)
target > A: ICMP echo reply, seq 1, length 64
21:57:12.013133 IP (...)
A > target: ICMP echo request, seq 2, length 64
21:57:12.015737 IP (... id 3039 ...)
target > A: ICMP echo reply, seq 2, length 64
21:57:13.016580 IP (...)
A > target: ICMP echo request, seq 3, length 64
21:57:13.019251 IP (... id 3437 ...)
target > A: ICMP echo reply, seq 3, length 64
[1] TCP sessions uses a per flow ID generator not changed by this patch.
Reported-by: Jeffrey Knockel <jeffk@cs.unm.edu>
Reported-by: Jedidiah R. Crandall <crandall@cs.unm.edu>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Hannes Frederic Sowa <hannes@redhat.com>
[ Upstream commit 73f156a6e8c1074ac6327e0abd1169e95eb66463 ]
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
commit 3cf521f7dc87c031617fd47e4b7aa2593c2f3daf upstream.
The l2tp [get|set]sockopt() code has fallen back to the UDP functions
for socket option levels != SOL_PPPOL2TP since day one, but that has
never actually worked, since the l2tp socket isn't an inet socket.
As David Miller points out:
"If we wanted this to work, it'd have to look up the tunnel and then
use tunnel->sk, but I wonder how useful that would be"
Since this can never have worked so nobody could possibly have depended
on that functionality, just remove the broken code and return -EINVAL.
Acked-by: James Chapman <jchapman@katalix.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
commit 08b9939997df30e42a228e1ecb97f99e9c8ea84e upstream.
This reverts commit 277d916fc2e959c3f106904116bb4f7b1148d47a as it was
at least breaking iwlwifi by setting the IEEE80211_TX_CTL_NO_PS_BUFFER
flag in all kinds of interface modes, not only for AP mode where it is
appropriate.
To avoid reintroducing the original problem, explicitly check for probe
request frames in the multicast buffering code.
Fixes: 277d916fc2e9 ("mac80211: move "bufferable MMPDU" check to fix AP mode scan")
commit 8c26d458394be44e135d1c6bd4557e1c4e1a0535 upstream.
tsc can be NULL (mac80211 currently always passes NULL),
resulting in NULL-dereference. check before copying it.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[ Upstream commit 10ec9472f05b45c94db3c854d22581a20b97db41 ]
There is a benign buffer overflow in ip_options_compile spotted by
AddressSanitizer[1] :
Its benign because we always can access one extra byte in skb->head
(because header is followed by struct skb_shared_info), and in this case
this byte is not even used.
[28504.910798] ==================================================================
[28504.912046] AddressSanitizer: heap-buffer-overflow in ip_options_compile
[28504.913170] Read of size 1 by thread T15843:
[28504.914026] [<ffffffff81802f91>] ip_options_compile+0x121/0x9c0
[28504.915394] [<ffffffff81804a0d>] ip_options_get_from_user+0xad/0x120
[28504.916843] [<ffffffff8180dedf>] do_ip_setsockopt.isra.15+0x8df/0x1630
[28504.918175] [<ffffffff8180ec60>] ip_setsockopt+0x30/0xa0
[28504.919490] [<ffffffff8181e59b>] tcp_setsockopt+0x5b/0x90
[28504.920835] [<ffffffff8177462f>] sock_common_setsockopt+0x5f/0x70
[28504.922208] [<ffffffff817729c2>] SyS_setsockopt+0xa2/0x140
[28504.923459] [<ffffffff818cfb69>] system_call_fastpath+0x16/0x1b
[28504.924722]
[28504.925106] Allocated by thread T15843:
[28504.925815] [<ffffffff81804995>] ip_options_get_from_user+0x35/0x120
[28504.926884] [<ffffffff8180dedf>] do_ip_setsockopt.isra.15+0x8df/0x1630
[28504.927975] [<ffffffff8180ec60>] ip_setsockopt+0x30/0xa0
[28504.929175] [<ffffffff8181e59b>] tcp_setsockopt+0x5b/0x90
[28504.930400] [<ffffffff8177462f>] sock_common_setsockopt+0x5f/0x70
[28504.931677] [<ffffffff817729c2>] SyS_setsockopt+0xa2/0x140
[28504.932851] [<ffffffff818cfb69>] system_call_fastpath+0x16/0x1b
[28504.934018]
[28504.934377] The buggy address ffff880026382828 is located 0 bytes to the right
[28504.934377] of 40-byte region [ffff880026382800, ffff880026382828)
[28504.937144]
[28504.937474] Memory state around the buggy address:
[28504.938430] ffff880026382300: ........ rrrrrrrr rrrrrrrr rrrrrrrr
[28504.939884] ffff880026382400: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.941294] ffff880026382500: .....rrr rrrrrrrr rrrrrrrr rrrrrrrr
[28504.942504] ffff880026382600: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.943483] ffff880026382700: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28504.944511] >ffff880026382800: .....rrr rrrrrrrr rrrrrrrr rrrrrrrr
[28504.945573] ^
[28504.946277] ffff880026382900: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.094949] ffff880026382a00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.096114] ffff880026382b00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.097116] ffff880026382c00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.098472] ffff880026382d00: ffffffff rrrrrrrr rrrrrrrr rrrrrrrr
[28505.099804] Legend:
[28505.100269] f - 8 freed bytes
[28505.100884] r - 8 redzone bytes
[28505.101649] . - 8 allocated bytes
[28505.102406] x=1..7 - x allocated bytes + (8-x) redzone bytes
[28505.103637] ==================================================================
[1] https://code.google.com/p/address-sanitizer/wiki/AddressSanitizerForKernel
[ Upstream commit 84a7c0b1db1c17d5ded8d3800228a608e1070b40 ]
dns_query() credulously assumes that keys are null-terminated and
returns a copy of a memory block that is off by one.
Signed-off-by: Manuel Schölling <manuel.schoelling@gmx.de>
[ Upstream commit 8f2e5ae40ec193bc0a0ed99e95315c3eebca84ea ]
While working on some other SCTP code, I noticed that some
structures shared with user space are leaking uninitialized
stack or heap buffer. In particular, struct sctp_sndrcvinfo
has a 2 bytes hole between .sinfo_flags and .sinfo_ppid that
remains unfilled by us in sctp_ulpevent_read_sndrcvinfo() when
putting this into cmsg. But also struct sctp_remote_error
contains a 2 bytes hole that we don't fill but place into a skb
through skb_copy_expand() via sctp_ulpevent_make_remote_error().
Both structures are defined by the IETF in RFC6458:
* Section 5.3.2. SCTP Header Information Structure:
The sctp_sndrcvinfo structure is defined below:
struct sctp_sndrcvinfo {
uint16_t sinfo_stream;
uint16_t sinfo_ssn;
uint16_t sinfo_flags;
<-- 2 bytes hole -->
uint32_t sinfo_ppid;
uint32_t sinfo_context;
uint32_t sinfo_timetolive;
uint32_t sinfo_tsn;
uint32_t sinfo_cumtsn;
sctp_assoc_t sinfo_assoc_id;
* 6.1.3. SCTP_REMOTE_ERROR:
A remote peer may send an Operation Error message to its peer.
This message indicates a variety of error conditions on an
association. The entire ERROR chunk as it appears on the wire
is included in an SCTP_REMOTE_ERROR event. Please refer to the
SCTP specification [RFC4960] and any extensions for a list of
possible error formats. An SCTP error notification has the
following format:
struct sctp_remote_error {
uint16_t sre_type;
uint16_t sre_flags;
uint32_t sre_length;
uint16_t sre_error;
sctp_assoc_t sre_assoc_id;
uint8_t sre_data[];
Fix this by setting both to 0 before filling them out. We also
have other structures shared between user and kernel space in
SCTP that contains holes (e.g. struct sctp_paddrthlds), but we
copy that buffer over from user space first and thus don't need
to care about it in that cases.
While at it, we can also remove lengthy comments copied from
the draft, instead, we update the comment with the correct RFC
number where one can look it up.
[ Upstream commit 999417549c16dd0e3a382aa9f6ae61688db03181 ]
If the 'next' pointer of the last fragment buffer in a message is not
zeroed before reassembly, we risk ending up with a corrupt message,
since the reassembly function itself isn't doing this.
Currently, when a buffer is retrieved from the deferred queue of the
broadcast link, the next pointer is not cleared, with the result as
described above.
This commit corrects this, and thereby fixes a bug that may occur when
long broadcast messages are transmitted across dual interfaces. The bug
has been present since 40ba3cdf542a469aaa9083fa041656e59b109b90 ("tipc:
message reassembly using fragment chain")
This commit should be applied to both net and net-next.
[ Upstream commit ac30ef832e6af0505b6f0251a6659adcfa74975e ]
netlink_dump() returns a negative errno value on error. Until now,
netlink_recvmsg() directly recorded that negative value in sk->sk_err, but
that's wrong since sk_err takes positive errno values. (This manifests as
userspace receiving a positive return value from the recv() system call,
falsely indicating success.) This bug was introduced in the commit that
started checking the netlink_dump() return value, commit b44d211 (netlink:
handle errors from netlink_dump()).
Multithreaded Netlink dumps are one way to trigger this behavior in
practice, as described in the commit message for the userspace workaround
posted here:
http://openvswitch.org/pipermail/dev/2014-June/042339.html
This commit also fixes the same bug in netlink_poll(), introduced in commit
cd1df525d (netlink: add flow control for memory mapped I/O).
Signed-off-by: Ben Pfaff <blp@nicira.com>
[ Upstream commit 36beddc272c111689f3042bf3d10a64d8a805f93 ]
Setting just skb->sk without taking its reference and setting a
destructor is invalid. However, in the places where this was done, skb
is used in a way not requiring skb->sk setting. So dropping the setting
of skb->sk.
Thanks to Eric Dumazet <eric.dumazet@gmail.com> for correct solution.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79441
Reported-by: Ed Martin <edman007@edman007.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
[ Upstream commit 6e08d5e3c8236e7484229e46fdf92006e1dd4c49 ]
The undo code assumes that, upon entering loss recovery, TCP
1) always retransmit something
2) the retransmission never fails locally (e.g., qdisc drop)
so undo_marker is set in tcp_enter_recovery() and undo_retrans is
incremented only when tcp_retransmit_skb() is successful.
When the assumption is broken because TCP's cwnd is too small to
retransmit or the retransmit fails locally. The next (DUP)ACK
would incorrectly revert the cwnd and the congestion state in
tcp_try_undo_dsack() or tcp_may_undo(). Subsequent (DUP)ACKs
may enter the recovery state. The sender repeatedly enter and
(incorrectly) exit recovery states if the retransmits continue to
fail locally while receiving (DUP)ACKs.
The fix is to initialize undo_retrans to -1 and start counting on
the first retransmission. Always increment undo_retrans even if the
retransmissions fail locally because they couldn't cause DSACKs to
undo the cwnd reduction.
[ Upstream commit 52ad353a5344f1f700c5b777175bdfa41d3cd65a ]
The problem was triggered by these steps:
1) create socket, bind and then setsockopt for add mc group.
mreq.imr_multiaddr.s_addr = inet_addr("255.0.0.37");
mreq.imr_interface.s_addr = inet_addr("192.168.1.2");
setsockopt(sockfd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq));
2) drop the mc group for this socket.
mreq.imr_interface.s_addr = inet_addr("0.0.0.0");
setsockopt(sockfd, IPPROTO_IP, IP_DROP_MEMBERSHIP, &mreq, sizeof(mreq));
3) and then drop the socket, I found the mc group was still used by the dev:
netstat -g
Interface RefCnt Group
eth2 1 255.0.0.37
Normally even though the IP_DROP_MEMBERSHIP return error, the mc group still need
to be released for the netdev when drop the socket, but this process was broken when
route default is NULL, the reason is that:
The ip_mc_leave_group() will choose the in_dev by the imr_interface.s_addr, if input addr
is NULL, the default route dev will be chosen, then the ifindex is got from the dev,
then polling the inet->mc_list and return -ENODEV, but if the default route dev is NULL,
the in_dev and ifIndex is both NULL, when polling the inet->mc_list, the mc group will be
released from the mc_list, but the dev didn't dec the refcnt for this mc group, so
when dropping the socket, the mc_list is NULL and the dev still keep this group.
v1->v2: According Hideaki's suggestion, we should align with IPv6 (RFC3493) and BSDs,
so I add the checking for the in_dev before polling the mc_list, make sure when
we remove the mc group, dec the refcnt to the real dev which was using the mc address.
The problem would never happened again.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
