commit 76f273640134f3eb8257179cd5b3bc6ba5fe4a96 upstream.
If AP do not provide us supported rates before assiociation, send
all rates we are supporting instead of empty information element.
v1 -> v2: Add comment.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit bf988435bd5b53529f4408a8efb1f433f6ddfda9 upstream.
struct ethtool_rxnfc was originally defined in 2.6.27 for the
ETHTOOL_{G,S}RXFH command with only the cmd, flow_type and data
fields. It was then extended in 2.6.30 to support various additional
commands. These commands should have been defined to use a new
structure, but it is too late to change that now.
Since user-space may still be using the old structure definition
for the ETHTOOL_{G,S}RXFH commands, and since they do not need the
additional fields, only copy the originally defined fields to and
from user-space.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
commit db048b69037e7fa6a7d9e95a1271a50dc08ae233 upstream.
On a 32-bit machine, info.rule_cnt >= 0x40000000 leads to integer
overflow and the buffer may be smaller than needed. Since
ETHTOOL_GRXCLSRLALL is unprivileged, this can presumably be used for at
least denial of service.
commit 45e77d314585869dfe43c82679f7e08c9b35b898 upstream.
It can happen that there are no packets in queue while calling
tcp_xmit_retransmit_queue(). tcp_write_queue_head() then returns
NULL and that gets deref'ed to get sacked into a local var.
There is no work to do if no packets are outstanding so we just
exit early.
This oops was introduced by 08ebd1721ab8fd (tcp: remove tp->lost_out
guard to make joining diff nicer).
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Reported-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de>
Tested-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de>
commit 91a72a70594e5212c97705ca6a694bd307f7a26b upstream.
When configuring DMVPN (GRE + openNHRP) and a GRE remote
address is configured a kernel Oops is observed. The
obserseved Oops is caused by a NULL header_ops pointer
(neigh->dev->header_ops) in neigh_update_hhs() when
void (*update)(struct hh_cache*, const struct net_device*, const unsigned char *)
= neigh->dev->header_ops->cache_update;
is executed. The dev associated with the NULL header_ops is
the GRE interface. This patch guards against the
possibility that header_ops is NULL.
This Oops was first observed in kernel version 2.6.26.8.
Signed-off-by: Doug Kehn <rdkehn@yahoo.com>
commit 499031ac8a3df6738f6186ded9da853e8ea18253 upstream.
We should release dst if dst->error is set.
Bug introduced in 2.6.14 by commit e104411b82f5c
([XFRM]: Always release dst_entry on error in xfrm_lookup)
commit aea9d711f3d68c656ad31ab578ecfb0bb5cd7f97 upstream.
The code that hashes and unhashes connections from the connection table
is missing locking of the connection being modified, which opens up a
race condition and results in memory corruption when this race condition
is hit.
Here is what happens in pretty verbose form:
CPU 0 CPU 1
An active connection is terminated and
we schedule ip_vs_conn_expire() on this
CPU to expire this connection.
IRQ assignment is changed to this CPU,
but the expire timer stays scheduled on
the other CPU.
New connection from same ip:port comes
in right before the timer expires, we
find the inactive connection in our
connection table and get a reference to
it. We proper lock the connection in
tcp_state_transition() and read the
connection flags in set_tcp_state().
ip_vs_conn_expire() gets called, we
unhash the connection from our
connection table and remove the hashed
flag in ip_vs_conn_unhash(), without
proper locking!
While still holding proper locks we
write the connection flags in
set_tcp_state() and this sets the hashed
flag again.
ip_vs_conn_expire() fails to expire the
connection, because the other CPU has
incremented the reference count. We try
to re-insert the connection into our
connection table, but this fails in
ip_vs_conn_hash(), because the hashed
flag has been set by the other CPU. We
re-schedule execution of
ip_vs_conn_expire(). Now this connection
has the hashed flag set, but isn't
actually hashed in our connection table
and has a dangling list_head.
We drop the reference we held on the
connection and schedule the expire timer
for timeouting the connection on this
CPU. Further packets won't be able to
find this connection in our connection
table.
ip_vs_conn_expire() gets called again,
we think it's already hashed, but the
list_head is dangling and while removing
the connection from our connection table
we write to the memory location where
this list_head points to.
The result will probably be a kernel oops at some other point in time.
This race condition is pretty subtle, but it can be triggered remotely.
It needs the IRQ assignment change or another circumstance where packets
coming from the same ip:port for the same service are being processed on
different CPUs. And it involves hitting the exact time at which
ip_vs_conn_expire() gets called. It can be avoided by making sure that
all packets from one connection are always processed on the same CPU and
can be made harder to exploit by changing the connection timeouts to
some custom values.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Acked-by: Simon Horman <horms@verge.net.au>
commit 1cb561f83793191cf86a2db3948d28f5f42df9ff upstream.
This fixes the problem introduced in commit
8404080568613d93ad7cf0a16dfb68 which broke mesh peer link establishment.
changes:
v2 Added missing break (Johannes)
v3 Broke original patch into two (Johannes)
Signed-off-by: Javier Cardona <javier@cozybit.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit f0b058b61711ebf5be94d6865ca7b2c259b71d37 upstream.
Use old supported rates, if AP do not provide supported rates
information element in a new managment frame.
commit b76ce56192bcf618013fb9aecd83488cffd645cc upstream.
If the attempt to read the calldir fails, then instead of storing the read
bytes, we currently discard them. This leads to a garbage final result when
upon re-entry to the same routine, we read the remaining bytes.
Fixes the regression in bugzilla number 16213. Please see
https://bugzilla.kernel.org/show_bug.cgi?id=16213
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 2e3219b5c8a2e44e0b83ae6e04f52f20a82ac0f2 upstream.
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809
sctp: Fix skb_over_panic resulting from multiple invalid \
parameter errors (CVE-2010-1173) (v4)
cause 'error cause' never be add the the ERROR chunk due to
some typo when check valid length in sctp_init_cause_fixed().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
commit d0021b252eaf65ca07ed14f0d66425dd9ccab9a6 upstream.
Fix TIPC to disallow sending to remote addresses prior to entering NET_MODE
user programs can oops the kernel by sending datagrams via AF_TIPC prior to
entering networked mode. The following backtrace has been observed:
ID: 13459 TASK: ffff810014640040 CPU: 0 COMMAND: "tipc-client"
[exception RIP: tipc_node_select_next_hop+90]
RIP: ffffffff8869d3c3 RSP: ffff81002d9a5ab8 RFLAGS: 00010202
RAX: 0000000000000001 RBX: 0000000000000001 RCX: 0000000000000001
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000001001001
RBP: 0000000001001001 R8: 0074736575716552 R9: 0000000000000000
R10: ffff81003fbd0680 R11: 00000000000000c8 R12: 0000000000000008
R13: 0000000000000001 R14: 0000000000000001 R15: ffff810015c6ca00
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
RIP: 0000003cbd8d49a3 RSP: 00007fffc84e0be8 RFLAGS: 00010206
RAX: 000000000000002c RBX: ffffffff8005d116 RCX: 0000000000000000
RDX: 0000000000000008 RSI: 00007fffc84e0c00 RDI: 0000000000000003
RBP: 0000000000000000 R8: 00007fffc84e0c10 R9: 0000000000000010
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 00007fffc84e0d10 R14: 0000000000000000 R15: 00007fffc84e0c30
ORIG_RAX: 000000000000002c CS: 0033 SS: 002b
What happens is that, when the tipc module in inserted it enters a standalone
node mode in which communication to its own address is allowed <0.0.0> but not
to other addresses, since the appropriate data structures have not been
allocated yet (specifically the tipc_net pointer). There is nothing stopping a
client from trying to send such a message however, and if that happens, we
attempt to dereference tipc_net.zones while the pointer is still NULL, and
explode. The fix is pretty straightforward. Since these oopses all arise from
the dereference of global pointers prior to their assignment to allocated
values, and since these allocations are small (about 2k total), lets convert
these pointers to static arrays of the appropriate size. All the accesses to
these bits consider 0/NULL to be a non match when searching, so all the lookups
still work properly, and there is no longer a chance of a bad dererence
anywhere. As a bonus, this lets us eliminate the setup/teardown routines for
those pointers, and elimnates the need to preform any locking around them to
prevent access while their being allocated/freed.
I've updated the tipc_net structure to behave this way to fix the exact reported
problem, and also fixed up the tipc_bearers and media_list arrays to fix an
obvious simmilar problem that arises from issuing tipc-config commands to
manipulate bearers/links prior to entering networked mode
I've tested this for a few hours by running the sanity tests and stress test
with the tipcutils suite, and nothing has fallen over. There have been a few
lockdep warnings, but those were there before, and can be addressed later, as
they didn't actually result in any deadlock.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Allan Stephens <allan.stephens@windriver.com>
CC: David S. Miller <davem@davemloft.net>
CC: tipc-discussion@lists.sourceforge.net
commit 5fa782c2f5ef6c2e4f04d3e228412c9b4a4c8809 upstream.
Ok, version 4
Change Notes:
1) Minor cleanups, from Vlads notes
Summary:
Hey-
Recently, it was reported to me that the kernel could oops in the
following way:
<5> kernel BUG at net/core/skbuff.c:91!
<5> invalid operand: 0000 [#1]
<5> Modules linked in: sctp netconsole nls_utf8 autofs4 sunrpc iptable_filter
ip_tables cpufreq_powersave parport_pc lp parport vmblock(U) vsock(U) vmci(U)
vmxnet(U) vmmemctl(U) vmhgfs(U) acpiphp dm_mirror dm_mod button battery ac md5
ipv6 uhci_hcd ehci_hcd snd_ens1371 snd_rawmidi snd_seq_device snd_pcm_oss
snd_mixer_oss snd_pcm snd_timer snd_page_alloc snd_ac97_codec snd soundcore
pcnet32 mii floppy ext3 jbd ata_piix libata mptscsih mptsas mptspi mptscsi
mptbase sd_mod scsi_mod
<5> CPU: 0
<5> EIP: 0060:[<c02bff27>] Not tainted VLI
<5> EFLAGS: 00010216 (2.6.9-89.0.25.EL)
<5> EIP is at skb_over_panic+0x1f/0x2d
<5> eax: 0000002c ebx: c033f461 ecx: c0357d96 edx: c040fd44
<5> esi: c033f461 edi: df653280 ebp: 00000000 esp: c040fd40
<5> ds: 007b es: 007b ss: 0068
<5> Process swapper (pid: 0, threadinfo=c040f000 task=c0370be0)
<5> Stack: c0357d96 e0c29478 00000084 00000004 c033f461 df653280 d7883180
e0c2947d
<5> 00000000 00000080 df653490 00000004 de4f1ac0 de4f1ac0 00000004
df653490
<5> 00000001 e0c2877a 08000800 de4f1ac0 df653490 00000000 e0c29d2e
00000004
<5> Call Trace:
<5> [<e0c29478>] sctp_addto_chunk+0xb0/0x128 [sctp]
<5> [<e0c2947d>] sctp_addto_chunk+0xb5/0x128 [sctp]
<5> [<e0c2877a>] sctp_init_cause+0x3f/0x47 [sctp]
<5> [<e0c29d2e>] sctp_process_unk_param+0xac/0xb8 [sctp]
<5> [<e0c29e90>] sctp_verify_init+0xcc/0x134 [sctp]
<5> [<e0c20322>] sctp_sf_do_5_1B_init+0x83/0x28e [sctp]
<5> [<e0c25333>] sctp_do_sm+0x41/0x77 [sctp]
<5> [<c01555a4>] cache_grow+0x140/0x233
<5> [<e0c26ba1>] sctp_endpoint_bh_rcv+0xc5/0x108 [sctp]
<5> [<e0c2b863>] sctp_inq_push+0xe/0x10 [sctp]
<5> [<e0c34600>] sctp_rcv+0x454/0x509 [sctp]
<5> [<e084e017>] ipt_hook+0x17/0x1c [iptable_filter]
<5> [<c02d005e>] nf_iterate+0x40/0x81
<5> [<c02e0bb9>] ip_local_deliver_finish+0x0/0x151
<5> [<c02e0c7f>] ip_local_deliver_finish+0xc6/0x151
<5> [<c02d0362>] nf_hook_slow+0x83/0xb5
<5> [<c02e0bb2>] ip_local_deliver+0x1a2/0x1a9
<5> [<c02e103e>] ip_rcv+0x334/0x3b4
<5> [<c02c66fd>] netif_receive_skb+0x320/0x35b
<5> [<e0a0928b>] init_stall_timer+0x67/0x6a [uhci_hcd]
<5> [<c02c67a4>] process_backlog+0x6c/0xd9
<5> [<c02c690f>] net_rx_action+0xfe/0x1f8
<5> [<c012a7b1>] __do_softirq+0x35/0x79
<5> [<c0107efb>] handle_IRQ_event+0x0/0x4f
<5> [<c01094de>] do_softirq+0x46/0x4d
Its an skb_over_panic BUG halt that results from processing an init chunk in
which too many of its variable length parameters are in some way malformed.
The problem is in sctp_process_unk_param:
if (NULL == *errp)
*errp = sctp_make_op_error_space(asoc, chunk,
ntohs(chunk->chunk_hdr->length));
if (*errp) {
sctp_init_cause(*errp, SCTP_ERROR_UNKNOWN_PARAM,
WORD_ROUND(ntohs(param.p->length)));
sctp_addto_chunk(*errp,
WORD_ROUND(ntohs(param.p->length)),
param.v);
When we allocate an error chunk, we assume that the worst case scenario requires
that we have chunk_hdr->length data allocated, which would be correct nominally,
given that we call sctp_addto_chunk for the violating parameter. Unfortunately,
we also, in sctp_init_cause insert a sctp_errhdr_t structure into the error
chunk, so the worst case situation in which all parameters are in violation
requires chunk_hdr->length+(sizeof(sctp_errhdr_t)*param_count) bytes of data.
The result of this error is that a deliberately malformed packet sent to a
listening host can cause a remote DOS, described in CVE-2010-1173:
http://cve.mitre.org/cgi-bin/cvename.cgi?name=2010-1173
I've tested the below fix and confirmed that it fixes the issue. We move to a
strategy whereby we allocate a fixed size error chunk and ignore errors we don't
have space to report. Tested by me successfully
commit 254416aae70ab2e6b57fd79782c8a67196234d02 upstream.
Previously, cfg80211 had reported "0" for MCS (i.e. 802.11n) bitrates
through the wireless extensions interface. However, nl80211 was
converting MCS rates into a reasonable bitrate number. This patch moves
the nl80211 code to cfg80211 where it is now shared between both the
nl80211 interface and the wireless extensions interface.
Cc: Ben Hutchings <ben@decadent.org.uk>
commit a2c40249a36d0b4d76d1caf6bf806e4ae5b06e8a upstream.
Currently whenever rts thresold is set, every packet will use RTS
protection no matter its size exceeds the threshold or not. This is
due to a bug in the rts threshold check.
if (len > tx->local->hw.wiphy->rts_threshold) {
txrc.rts = rts = true;
Basically it is comparing an int (len) and a u32 (rts_threshold),
and the variable len is assigned as:
len = min_t(int, tx->skb->len + FCS_LEN,
tx->local->hw.wiphy->frag_threshold);
However, when frag_threshold is "-1", len is always "-1", which is
0xffffffff therefore rts is always set to true.
Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com>
commit d211e90e28a074447584729018a39910d691d1a8 upstream.
Commit e34e09401ee9888dd662b2fca5d607794a56daf2 incorrectly removed
use of ieee80211_has_protected() from the management frame case and in
practice, made this validation drop all Action frames when MFP is
enabled. This should have only been done for frames with Protected
field set to zero.
Signed-off-by: Jouni Malinen <j@w1.fi>
commit c2ef355bf3ef0b8006b96128726684fba47ac928 upstream.
I discovered that if EMBEDDED=y, one can accidentally build a mac80211 stack
and drivers w/ no rate control algorithm. For drivers like RTL8187 that don't
supply their own RC algorithms, this will cause ieee80211_register_hw to
fail (making the driver unusable).
This will tell kconfig to provide a warning if no rate control algorithms
have been selected. That'll at least warn the user; users that know that
their drivers supply a rate control algorithm can safely ignore the
warning, and those who don't know (or who expect to be using multiple
drivers) can select a default RC algorithm.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
commit ccc2d97cb7c798e785c9f198de243e2b59f7073b upstream.
commit 2783ef23 moved the initialisation of saddr and daddr after
pskb_may_pull() to avoid a potential data corruption. Unfortunately
also placing it after the short packet and bad checksum error paths,
where these variables are used for logging. The result is bogus
output like
[92238.389505] UDP: short packet: From 2.0.0.0:65535 23715/178 to 0.0.0.0:65535
Moving the saddr and daddr initialisation above the error paths, while still
keeping it after the pskb_may_pull() to keep the fix from commit 2783ef23.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 38ff3e6bb987ec583268da8eb22628293095d43b upstream.
This was just recently reported to me. When built as modules, the
dccp_probe module has a silent dependency on the dccp module. This
stems from the fact that the module_init routine of dccp_probe
registers a jprobe on the dccp_sendmsg symbol. Since the symbol is
only referenced as a text string (the .symbol_name field in the jprobe
struct) rather than the address of the symbol itself, depmod never
picks this dependency up, and so if you load the dccp_probe module
without the dccp module loaded, the register_jprobe call fails with an
-EINVAL, and the whole module load fails.
The fix is pretty easy, we can just wrap the register_jprobe call in a
try_then_request_module call, which forces the dependency to get
satisfied prior to the probe registration.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: maximilian attems <max@stro.at>
commit b4bb5c3fd9333024044362df67e23e96158489ed upstream.
When the addba timer expires but has no work to do,
it should not affect the state machine. If it does,
TX will not see the successfully established and we
can also crash trying to re-establish the session.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
commit c0ce77b8323c1a0d4eeef97caf16c0ea971222a9 upstream.
Reinette found the reason for the warnings that
happened occasionally when a hw-offloaded scan
finished; her description of the problem:
mac80211 will defer the handling of scan requests if it is
busy with management work at the time. The scan requests
are deferred and run after the work has completed. When
this occurs there are currently two problems.
* The scan request for hardware scan is not fully populated
with the band and channels to scan not initialized.
* When the scan is queued the state is not correctly updated
to reflect that a scan is in progress. The problem here is
that when the driver completes the scan and calls
ieee80211_scan_completed() a warning will be triggered
since mac80211 was not aware that a scan was in progress.
The reason is that the queued scan work will start
the hw scan right away when the hw_scan_req struct
has already been allocated. However, in the first
pass it will not have been filled, which happens
at the same time as setting the bits. To fix this,
simply move the allocation after the pending work
test as well, so that the first iteration of the
scan work will call __ieee80211_start_scan() even
in the hardware scan case.
Bug-identified-by: Reinette Chatre <reinette.chatre@intel.com>
Cc: Chase Douglas <chase.douglas@canonical.com>
commit 301e99ce4a2f42a317129230fd42e6cd874c64b0 upstream.
One the changes in commit d7979ae4a "svc: Move close processing to a
single place" is:
err_delete:
- svc_delete_socket(svsk);
+ set_bit(SK_CLOSE, &svsk->sk_flags);
return -EAGAIN;
This is insufficient. The recvfrom methods must always call
svc_xprt_received on completion so that the socket gets re-queued if
there is any more work to do. This particular path did not make that
call because it actually destroyed the svsk, making requeue pointless.
When the svc_delete_socket was change to just set a bit, we should have
added a call to svc_xprt_received,
This is the problem that b0401d7253 attempted to fix, incorrectly.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 1b644b6e6f6160ae35ce4b52c2ca89ed3e356e18 upstream.
This reverts commit b0401d725334a94d57335790b8ac2404144748ee, which
moved svc_delete_xprt() outside of XPT_BUSY, and allowed it to be called
after svc_xpt_recived(), removing its last reference and destroying it
after it had already been queued for future processing.
commit f5822754ea006563e1bf0a1f43faaad49c0d8bb2 upstream.
This reverts commit b292cf9ce70d221c3f04ff62db5ab13d9a249ca8. The
commit that it attempted to patch up,
b0401d725334a94d57335790b8ac2404144748ee, was fundamentally wrong, and
will also be reverted.
commit dc83d6e27fa80babe31c80aa8568f125f72edf57 upstream.
For nfsd we provide users the option of mapping uid's to server-side
supplementary group lists. That makes sense for nfsd, but not
necessarily for other rpc users (such as the callback client).
So move that lookup to svcauth_unix_set_client, which is a
program-specific method.
commit 598856407d4e20ebb4de01a91a93d89325924d43 upstream.
Make sure, that TCP has a nonzero RTT estimation after three-way
handshake. Currently, a listening TCP has a value of 0 for srtt,
rttvar and rto right after the three-way handshake is completed
with TCP timestamps disabled.
This will lead to corrupt RTO recalculation and retransmission
flood when RTO is recalculated on backoff reversion as introduced
in "Revert RTO on ICMP destination unreachable"
(f1ecd5d9e7366609d640ff4040304ea197fbc618).
This behaviour can be provoked by connecting to a server which
"responds first" (like SMTP) and rejecting every packet after
the handshake with dest-unreachable, which will lead to softirq
load on the server (up to 30% per socket in some tests).
Thanks to Ilpo Jarvinen for providing debug patches and to
Denys Fedoryshchenko for reporting and testing.
Changes since v3: Removed bad characters in patchfile.
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de>
commit 74e2bd1fa3ae9695af566ad5a7a288898787b909 upstream.
When there is a need to restart/reconfig hw, tear down all the
aggregation queues and let the mac80211 and driver get in-sync to have
the opportunity to re-establish the aggregation queues again.
Need to wait until driver re-establish all the station information before tear
down the aggregation queues, driver(at least iwlwifi driver) will reject the
stop aggregation queue request if station is not ready. But also need to make
sure the aggregation queues are tear down before waking up the queues, so
mac80211 will not sending frames with aggregation bit set.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 7236fe29fd72d17074574ba312e7f1bb9d10abaa upstream.
"mac80211: fix skb buffering issue" still left a race
between enabling the hardware queues and the virtual
interface queues. In hindsight it's totally obvious
that enabling the netdev queues for a hardware queue
when the hardware queue is enabled is wrong, because
it could well possible that we can fill the hw queue
with packets we already have pending. Thus, we must
only enable the netdev queues once all the pending
packets have been processed and sent off to the device.
In testing, I haven't been able to trigger this race
condition, but it's clearly there, possibly only when
aggregation is being enabled.
commit c2c77ec83bdad17fb688557b5b3fdc36661dd1c6 upstream.
Added very simple check that req buffer has enough space to
fit configuration parameters. Shall be enough to reject packets
with configuration size more than req buffer.
Crash trace below
[ 6069.659393] Unable to handle kernel paging request at virtual address 02000205
[ 6069.673034] Internal error: Oops: 805 [#1] PREEMPT
[ 6069.727172] PC is at l2cap_add_conf_opt+0x70/0xf0 [l2cap]
[ 6069.732604] LR is at l2cap_recv_frame+0x1350/0x2e78 [l2cap]
[ 6070.030303] Backtrace:
[ 6070.032806] [<bf1c2880>] (l2cap_add_conf_opt+0x0/0xf0 [l2cap]) from
[<bf1c6624>] (l2cap_recv_frame+0x1350/0x2e78 [l2cap])
[ 6070.043823] r8:dc5d3100 r7:df2a91d6 r6:00000001 r5:df2a8000 r4:00000200
[ 6070.050659] [<bf1c52d4>] (l2cap_recv_frame+0x0/0x2e78 [l2cap]) from
[<bf1c8408>] (l2cap_recv_acldata+0x2bc/0x350 [l2cap])
[ 6070.061798] [<bf1c814c>] (l2cap_recv_acldata+0x0/0x350 [l2cap]) from
[<bf0037a4>] (hci_rx_task+0x244/0x478 [bluetooth])
[ 6070.072631] r6:dc647700 r5:00000001 r4:df2ab740
[ 6070.077362] [<bf003560>] (hci_rx_task+0x0/0x478 [bluetooth]) from
[<c006b9fc>] (tasklet_action+0x78/0xd8)
[ 6070.087005] [<c006b984>] (tasklet_action+0x0/0xd8) from [<c006c160>]
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
Acked-by: Gustavo F. Padovan <gustavo@padovan.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 101545f6fef4a0a3ea8daf0b5b880df2c6a92a69 upstream.
When creating a high number of Bluetooth sockets (L2CAP, SCO
and RFCOMM) it is possible to scribble repeatedly on arbitrary
pages of memory. Ensure that the content of these sysfs files is
always less than one page. Even if this means truncating. The
files in question are scheduled to be moved over to debugfs in
the future anyway.
Based on initial patches from Neil Brown and Linus Torvalds
Reported-by: Neil Brown <neilb@suse.de>
commit e15276a4b220c54db665cf46a92bd9ceb9aeb052 upstream.
The current mac80211 implementation enables power save if there
is no Tx traffic for a specific timeout. Hence, PS is triggered
even if there is a continuous Rx only traffic(like UDP) going on.
This makes the drivers to wait on the tim bit in the next beacon
to awake which leads to redundant sleep-wake cycles.
Fix this by restarting the dynamic ps timer on receiving every
data packet.
Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit 375177bf35efc08e1bd37bbda4cc0c8cc4db8500 upstream.
Even if the null data frame is not acked by the AP, mac80211
goes into power save. This might lead to loss of frames
from the AP.
Prevent this by restarting dynamic_ps_timer when ack is not
received for null data frames.
Cc: Johannes Berg <johannes@sipsolutions.net>
commit ef1691504c83ba3eb636c0cfd3ed33f7a6d0b4ee upstream.
Commit 8ccb92ad (netfilter: xt_recent: fix false match) fixed supposedly
false matches in rules using a zero hit_count. As it turns out there is
nothing false about these matches and people are actually using entries
with a hit_count of zero to make rules dependant on addresses inserted
manually through /proc.
Since this slipped past the eyes of three reviewers, instead of
reverting the commit in question, this patch explicitly checks
for a hit_count of zero to make the intentions more clear.
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Tested-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
commit f1f0abe192a72e75d7c59972e30784d043fd8d73 upstream.
__rpc_lookup_create() can return ERR_PTR(-ENOMEM).
commit cdead7cf12896c0e50a8be2e52de52c364603095 upstream.
The function alloc_enc_pages() currently fails to release the pointer
rqstp->rq_enc_pages in the error path.
Acked-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 485f1eff73a7b932fd3abb0dfcf804e1a1f59025 upstream.
With the commit 9e726b17422bade75fba94e625cd35fd1353e682 the
rfcomm_session_put() gets accidentially called from a timeout
callback and results in this:
BUG: sleeping function called from invalid context at net/core/sock.c:1897
in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper
Pid: 0, comm: swapper Tainted: P 2.6.32 #31
Call Trace:
<IRQ> [<ffffffff81036455>] __might_sleep+0xf8/0xfa
[<ffffffff8138ef1d>] lock_sock_nested+0x29/0xc4
[<ffffffffa03921b3>] lock_sock+0xb/0xd [l2cap]
[<ffffffffa03948e6>] l2cap_sock_shutdown+0x1c/0x76 [l2cap]
[<ffffffff8106adea>] ? clockevents_program_event+0x75/0x7e
[<ffffffff8106bea2>] ? tick_dev_program_event+0x37/0xa5
[<ffffffffa0394967>] l2cap_sock_release+0x27/0x67 [l2cap]
[<ffffffff8138c971>] sock_release+0x1a/0x67
[<ffffffffa03d2492>] rfcomm_session_del+0x34/0x53 [rfcomm]
[<ffffffffa03d24c5>] rfcomm_session_put+0x14/0x16 [rfcomm]
[<ffffffffa03d28b4>] rfcomm_session_timeout+0xe/0x1a [rfcomm]
[<ffffffff810554a8>] run_timer_softirq+0x1e2/0x29a
[<ffffffffa03d28a6>] ? rfcomm_session_timeout+0x0/0x1a [rfcomm]
[<ffffffff8104e0f6>] __do_softirq+0xfe/0x1c5
[<ffffffff8100e8ce>] ? timer_interrupt+0x1a/0x21
[<ffffffff8100cc4c>] call_softirq+0x1c/0x28
[<ffffffff8100e05b>] do_softirq+0x33/0x6b
[<ffffffff8104daf6>] irq_exit+0x36/0x85
[<ffffffff8100d7a9>] do_IRQ+0xa6/0xbd
[<ffffffff8100c493>] ret_from_intr+0x0/0xa
<EOI> [<ffffffff812585b3>] ? acpi_idle_enter_bm+0x269/0x294
[<ffffffff812585a9>] ? acpi_idle_enter_bm+0x25f/0x294
[<ffffffff81373ddc>] ? cpuidle_idle_call+0x97/0x107
[<ffffffff8100aca0>] ? cpu_idle+0x53/0xaa
[<ffffffff81429006>] ? rest_init+0x7a/0x7c
[<ffffffff8177bc8c>] ? start_kernel+0x389/0x394
[<ffffffff8177b29c>] ? x86_64_start_reservations+0xac/0xb0
[<ffffffff8177b384>] ? x86_64_start_kernel+0xe4/0xeb
To fix this, the rfcomm_session_put() needs to be moved out of
rfcomm_session_timeout() into rfcomm_process_sessions(). In that
context it is perfectly fine to sleep and disconnect the socket.
Tested-by: David John <davidjon@xenontk.org>
commit 9fcfe0c83c3b04a759cde6b8c5f961237f17808b upstream.
This can, for instance, happen if the user specifies a link local IPv6
address.
commit ab1b18f70a007ea6caeb007d269abb75b131a410 upstream.
The 'struct svc_deferred_req's on the xpt_deferred queue do not
own a reference to the owning xprt. This is seen in svc_revisit
which is where things are added to this queue. dr->xprt is set to
NULL and the reference to the xprt it put.
So when this list is cleaned up in svc_delete_xprt, we mustn't
put the reference.
Also, replace the 'for' with a 'while' which is arguably
simpler and more likely to compile efficiently.
Cc: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 8ccb92ad41cb311e52ad1b1fe77992c7f47a3b63 upstream.
A rule with a zero hit_count will always match.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 2c08522e5d2f0af2d6f05be558946dcbf8173683 upstream.
e->index overflows e->stamps[] every ip_pkt_list_tot packets.
Consider the case when ip_pkt_list_tot==1; the first packet received is stored
in e->stamps[0] and e->index is initialized to 1. The next received packet
timestamp is then stored at e->stamps[1] in recent_entry_update(),
a buffer overflow because the maximum e->stamps[] index is 0.
commit 76dadd76c265a0cdb5a76aa4eef03fcc9639b388 upstream.
We use scm_send and scm_recv on both unix domain and
netlink sockets, but only unix domain sockets support
everything required for file descriptor passing,
so error if someone attempts to pass file descriptors
over netlink sockets.
[ Upstream commit c92b544bd5d8e7ed7d81c77bbecab6df2a95aa53 ]
The commit 0b5ccb2(title:ipv6: reassembly: use seperate reassembly queues for
conntrack and local delivery) has broken the saddr&&daddr member of
nf_ct_frag6_queue when creating new queue. And then hash value
generated by nf_hashfn() was not equal with that generated by fq_find().
So, a new received fragment can't be inserted to right queue.
The patch fixes the bug with adding member of user to nf_ct_frag6_queue structure.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Acked-by: Patrick McHardy <kaber@trash.net>
[ Upstream commit c6b471e6454c0e1c6d756672841cbaeae7c949f8 ]
Currently we treat IGMPv3 reports as if it were an IGMPv2/v1 report.
This is broken as IGMPv3 reports are formatted differently. So we
end up suppressing a bogus multicast group (which should be harmless
as long as the leading reserved field is zero).
In fact, IGMPv3 does not allow membership report suppression so
we should simply ignore IGMPv3 membership reports as a host.
This patch does exactly that. I kept the case statement for it
so people won't accidentally add it back thinking that we overlooked
this case.
[ Upstream commit e76b69cc0133952c98aa1ad6330cacacd269fd64 ]
Traffic (tcp) doesnot start on a vlan interface when gro is enabled.
Even the tcp handshake was not taking place.
This is because, the eth_type_trans call before the netif_receive_skb
in napi_gro_finish() resets the skb->dev to napi->dev from the previously
set vlan netdev interface. This causes the ip_route_input to drop the
incoming packet considering it as a packet coming from a martian source.
I could repro this on 2.6.32.7 (stable) and 2.6.33-rc7.
With this fix, the traffic starts and the test runs fine on both vlan
and non-vlan interfaces.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Patrick McHardy <kaber@trash.net>
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
[ Upstream commit b8afe6416101549e877f8470f2a160df69676166 ]
The wireless sysfs methods like the rest of the networking sysfs
methods are removed with the rtnl_lock held and block until
the existing methods stop executing. So use rtnl_trylock
and restart_syscall so that the code continues to work.
[ Upstream commit 88af182e389097997c5e2a0b42285b3522796759 ]
Yuck. It turns out that when we restart sysctls we were restarting
with the values already changed. Which unfortunately meant that
the second time through we thought there was no change and skipped
all kinds of work, despite the fact that there was indeed a change.
I have fixed this the simplest way possible by restoring the changed
values when we restart the sysctl write.
One of my coworkers spotted this bug when after disabling forwarding
on an interface pings were still forwarded.
commit 3dc1de0bf23816ed557ac8addf680cd5ee57e805 upstream.
Make addba_resp_timer aware the HT_AGG_STATE_REQ_STOP_BA_MSK mask
so that when ___ieee80211_stop_tx_ba_session() is issued the timer
will quit. Otherwise when suspend happens before the timer expired,
the timer handler will be called immediately after resume and
messes up driver status.
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
commit 0da780c269957783d341fc3559e6b4c9912af7b4 upstream.
We only reply to probe request if either the requested SSID is the
broadcast SSID or if the requested SSID matches our own SSID. This
latter case was not properly handled since we were replying to different
SSID with the same length as our own SSID.
Signed-off-by: Benoit Papillault <benoit.papillault@free.fr>
commit 1b3f720bf033fde1fbb6231f9b156b918c5f68d8 upstream.
Add missing try_to_freeze() to one of the pktgen_thread_worker() code
paths so that it doesn't block suspend/hibernation.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=15006
Reported-and-tested-by: Ciprian Dorin Craciun <ciprian.craciun@gmail.com>
commit 2fc1b5dd99f66d93ffc23fd8df82d384c1a354c8 upstream.
Kernel bugzilla #15239
On some workloads, it is quite possible to get a huge dst list to
process in dst_gc_task(), and trigger soft lockup detection.
Fix is to call cond_resched(), as we run in process context.
Reported-by: Pawel Staszewski <pstaszewski@itcare.pl>
Tested-by: Pawel Staszewski <pstaszewski@itcare.pl>
