path: root/net
2009-05-18netlabel: Add new NetLabel KAPI interfaces for request_sock security attributesPaul Moore
[NOTE: based on 389fb800ac8be2832efedd19978a2b8ced37eb61 and 07feee8f812f7327a46186f7604df312c8c81962] This patch adds the netlbl_req_setattr() and netlbl_req_delattr() functions which can be used by LSMs to set and remove the NetLabel security attributes from request_sock objects used in incoming connection requests. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-18netlabel: Add CIPSO {set, del}attr request_sock functionsPaul Moore
[NOTE: based on 389fb800ac8be2832efedd19978a2b8ced37eb61] Add the cipso_v4_req_setattr() and cipso_v4_req_delattr() functions to set and delete the CIPSO security attributes on a request_sock used during a incoming connection request. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-18lsm: Relocate the IPv4 security_inet_conn_request() hooksPaul Moore
[NOTE: present in Linus' tree as 284904aa79466a4736f4c775fdbe5c7407fa136c] The current placement of the security_inet_conn_request() hooks do not allow individual LSMs to override the IP options of the connection's request_sock. This is a problem as both SELinux and Smack have the ability to use labeled networking protocols which make use of IP options to carry security attributes and the inability to set the IP options at the start of the TCP handshake is problematic. This patch moves the IPv4 security_inet_conn_request() hooks past the code where the request_sock's IP options are set/reset so that the LSM can safely manipulate the IP options as needed. This patch intentionally does not change the related IPv6 hooks as IPv6 based labeling protocols which use IPv6 options are not currently implemented, once they are we will have a better idea of the correct placement for the IPv6 hooks. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-08mac80211: fix basic rate bitmap calculationJohannes Berg
upstream commit: 7e0986c17f695952ce5d61ed793ce048ba90a661 "mac80211: fix basic rates setting from association response" introduced a copy/paste error. Unfortunately, this not just leads to wrong data being passed to the driver but is remotely exploitable for some hardware or driver combinations. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-05-08mac80211: Fix bug in getting rx status for frames pending in reorder bufferVasanthakumar Thiagarajan
upstream commit: b3631286aca3f54427ca0eb950981e9753866f6c Currently rx status for frames which are completed from reorder buffer is taken from it's cb area which is not always right, cb is not holding the rx status when driver uses mac80211's non-irq rx handler to pass it's received frames. This results in dropping almost all frames from reorder buffer when security is enabled by doing double decryption (first in hw, second in sw because of wrong rx status). This patch copies rx status into cb area before the frame is put into reorder buffer. After this patch, there is a significant improvement in throughput with ath9k + WPA2(AES). Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27gso: Fix support for linear packetsHerbert Xu
upstream commit: 2f181855a0b3c2b39314944add7b41c15647cf86 When GRO/frag_list support was added to GSO, I made an error which broke the support for segmenting linear GSO packets (GSO packets are normally non-linear in the payload). These days most of these packets are constructed by the tun driver, which prefers to allocate linear memory if possible. This is fixed in the latest kernel, but for 2.6.29 and earlier it is still the norm. Therefore this bug causes failures with GSO when used with tun in 2.6.29. Reported-by: James Huang <jamesclhuang@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27netfilter: {ip, ip6, arp}_tables: fix incorrect loop detectionPatrick McHardy
upstream commit: 1f9352ae2253a97b07b34dcf16ffa3b4ca12c558 Commit e1b4b9f ([NETFILTER]: {ip,ip6,arp}_tables: fix exponential worst-case search for loops) introduced a regression in the loop detection algorithm, causing sporadic incorrectly detected loops. When a chain has already been visited during the check, it is treated as having a standard target containing a RETURN verdict directly at the beginning in order to not check it again. The real target of the first rule is then incorrectly treated as STANDARD target and checked not to contain invalid verdicts. Fix by making sure the rule does actually contain a standard target. Based on patch by Francis Dupont <Francis_Dupont@isc.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27net/netrom: Fix socket lockingJean Delvare
upstream commit: cc29c70dd581f85ee7a3e7980fb031f90b90a2ab Patch "af_rose/x25: Sanity check the maximum user frame size" (commit 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9) from Alan Cox got locking wrong. If we bail out due to user frame size being too large, we must unlock the socket beforehand. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27af_rose/x25: Sanity check the maximum user frame sizeAlan Cox
upstream commit: 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9 CVE-2009-0795. Otherwise we can wrap the sizes and end up sending garbage. Closes #10423 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02cfg80211: fix incorrect assumption on last_request for 11dLuis R. Rodriguez
upstream commit: cc0b6fe88e99096868bdbacbf486c97299533b5a The incorrect assumption is the last regulatory request (last_request) is always a country IE when processing country IEs. Although this is true 99% of the time the first time this happens this could not be true. This fixes an oops in the branch check for the last_request when accessing drv_last_ie. The access was done under the assumption the struct won't be null. Note to stable: to port to 29 replace as follows, only 29 has country IE code: s|NL80211_REGDOM_SET_BY_COUNTRY_IE|REGDOM_SET_BY_COUNTRY_IE Cc: stable@kernel.org Reported-by: Quentin Armitage <Quentin@armitage.org.uk> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> [chrisw: backport to 2.6.29] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02cfg80211: force last_request to be set for OLD_REG if regdom is EULuis R. Rodriguez
upstream commit: 2e097dc65673ed421bbc2e49f52c125aa43a8ee6 Although EU is a bogus alpha2 we need to process the send request as our code depends on last_request being set. Cc: stable@kernel.org Reported-by: Quentin Armitage <Quentin@armitage.org.uk> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> [chrisw: backport to 2.6.29] Signed-off-by: Chris Wright <chrisw@sous-sol.org> Port-acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
2009-04-02xfrm: spin_lock() should be spin_unlock() in xfrm_state.cChuck Ebbert
[ Upstream commit 7d0b591c655ca0d72ebcbd242cf659a20a8995c5 ] spin_lock() should be spin_unlock() in xfrm_state_walk_done(). caused by: commit 12a169e7d8f4b1c95252d8b04ed0f1033ed7cfe2 "ipsec: Put dumpers on the dump list" Reported-by: Marc Milgram <mmilgram@redhat.com> Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02ipv6: Plug sk_buff leak in ipv6_rcv (net/ipv6/ip6_input.c)Jesper Nilsson
[ Upstream commit 71f6f6dfdf7c7a67462386d9ea05c1095a89c555 ] Commit 778d80be52699596bf70e0eb0761cf5e1e46088d (ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface) seems to have introduced a leak of sk_buff's for ipv6 traffic, at least in some configurations where idev is NULL, or when ipv6 is disabled via sysctl. The problem is that if the first condition of the if-statement returns non-NULL, it returns an skb with only one reference, and when the other conditions apply, execution jumps to the "out" label, which does not call kfree_skb for it. To plug this leak, change to use the "drop" label instead. (this relies on it being ok to call kfree_skb on NULL) This also allows us to avoid calling rcu_read_unlock here, and removes the only user of the "out" label. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02GRO: Disable GRO on legacy netif_rx pathHerbert Xu
[ Upstream commit 8f1ead2d1a626ed0c85b3d2c2046a49081d5933f ] When I fixed the GRO crash in the legacy receive path I used napi_complete to replace __napi_complete. Unfortunately they're not the same when NETPOLL is enabled, which may result in us not calling __napi_complete at all. What's more, we really do need to keep the __napi_complete call within the IRQ-off section since in theory an IRQ can occur in between and fill up the backlog to the maximum, causing us to lock up. Since we can't seem to find a fix that works properly right now, this patch reverts all the GRO support from the netif_rx path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02bridge: bad error handling when adding invalid ether addressStephen Hemminger
[ Upstream commit cda6d377ec6b2ee2e58d563d0bd7eb313e0165df ] This fixes an crash when empty bond device is added to a bridge. If an interface with invalid ethernet address (all zero) is added to a bridge, then bridge code detects it when setting up the forward databas entry. But the error unwind is broken, the bridge port object can get freed twice: once when ref count went to zeo, and once by kfree. Since object is never really accessible, just free it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02udp: Wrong locking code in udp seq_file infrastructureVitaly Mayatskikh
[ Upstream commit 30842f2989aacfaba3ccb39829b3417be9313dbe ] Reading zero bytes from /proc/net/udp or other similar files which use the same seq_file udp infrastructure panics kernel in that way: ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- read/1985 is trying to release lock (&table->hash[i].lock) at: [<ffffffff81321d83>] udp_seq_stop+0x27/0x29 but there are no more locks to release! other info that might help us debug this: 1 lock held by read/1985: #0: (&p->lock){--..}, at: [<ffffffff810eefb6>] seq_read+0x38/0x348 stack backtrace: Pid: 1985, comm: read Not tainted 2.6.29-rc8 #9 Call Trace: [<ffffffff81321d83>] ? udp_seq_stop+0x27/0x29 [<ffffffff8106dab9>] print_unlock_inbalance_bug+0xd6/0xe1 [<ffffffff8106db62>] lock_release_non_nested+0x9e/0x1c6 [<ffffffff810ef030>] ? seq_read+0xb2/0x348 [<ffffffff8106bdba>] ? mark_held_locks+0x68/0x86 [<ffffffff81321d83>] ? udp_seq_stop+0x27/0x29 [<ffffffff8106dde7>] lock_release+0x15d/0x189 [<ffffffff8137163c>] _spin_unlock_bh+0x1e/0x34 [<ffffffff81321d83>] udp_seq_stop+0x27/0x29 [<ffffffff810ef239>] seq_read+0x2bb/0x348 [<ffffffff810eef7e>] ? seq_read+0x0/0x348 [<ffffffff8111aedd>] proc_reg_read+0x90/0xaf [<ffffffff810d878f>] vfs_read+0xa6/0x103 [<ffffffff8106bfac>] ? trace_hardirqs_on_caller+0x12f/0x153 [<ffffffff810d88a2>] sys_read+0x45/0x69 [<ffffffff8101123a>] system_call_fastpath+0x16/0x1b BUG: scheduling while atomic: read/1985/0xffffff00 INFO: lockdep is turned off. Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table dm_multipath kvm ppdev snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep snd_seq_dummy snd_seq_oss snd_seq_midi_event arc4 snd_s eq ecb thinkpad_acpi snd_seq_device iwl3945 hwmon sdhci_pci snd_pcm_oss sdhci rfkill mmc_core snd_mixer_oss i2c_i801 mac80211 yenta_socket ricoh_mmc i2c_core iTCO_wdt snd_pcm iTCO_vendor_support rs rc_nonstatic snd_timer snd lib80211 cfg80211 soundcore snd_page_alloc video parport_pc output parport e1000e [last unloaded: scsi_wait_scan] Pid: 1985, comm: read Not tainted 2.6.29-rc8 #9 Call Trace: [<ffffffff8106b456>] ? __debug_show_held_locks+0x1b/0x24 [<ffffffff81043660>] __schedule_bug+0x7e/0x83 [<ffffffff8136ede9>] schedule+0xce/0x838 [<ffffffff810d7972>] ? fsnotify_access+0x5f/0x67 [<ffffffff810112d0>] ? sysret_careful+0xb/0x37 [<ffffffff8106be9c>] ? trace_hardirqs_on_caller+0x1f/0x153 [<ffffffff8137127b>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff810112f6>] sysret_careful+0x31/0x37 read[1985]: segfault at 7fffc479bfe8 ip 0000003e7420a180 sp 00007fffc479bfa0 error 6 Kernel panic - not syncing: Aiee, killing interrupt handler! udp_seq_stop() tries to unlock not yet locked spinlock. The lock was lost during splitting global udp_hash_lock to subsequent spinlocks. Signed-off by: Vitaly Mayatskikh <v.mayatskih@gmail.com> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-02netfilter: nf_conntrack_tcp: fix unaligned memory access in tcp_sackMark H. Weaver
[ Upstream commit 534f81a5068799799e264fd162e9488a129f98d4 ] This patch fixes an unaligned memory access in tcp_sack while reading sequence numbers from TCP selective acknowledgement options. Prior to applying this patch, upstream linux-2.6.27.20 was occasionally generating messages like this on my sparc64 system: [54678.532071] Kernel unaligned access at TPC[6b17d4] tcp_packet+0xcd4/0xd00 Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) ucc_geth: Fix oops when using fixed-link support dm9000: locking bugfix net: update dnet.c for bus_id removal dnet: DNET should depend on HAS_IOMEM dca: add missing copyright/license headers nl80211: Check that function pointer != NULL before using it sungem: missing net_device_ops be2net: fix to restore vlan ids into BE2 during a IF DOWN->UP cycle be2net: replenish when posting to rx-queue is starved in out of mem conditions bas_gigaset: correctly allocate USB interrupt transfer buffer smsc911x: reset last known duplex and carrier on open sh_eth: Fix mistake of the address of SH7763 sh_eth: Change handling of IRQ netns: oops in ip[6]_frag_reasm incrementing stats net: kfree(napi->skb) => kfree_skb net: fix sctp breakage ipv6: fix display of local and remote sit endpoints net: Document /proc/sys/net/core/netdev_budget tulip: fix crash on iface up with shirq debug virtio_net: Make virtio_net support carrier detection ...
2009-03-20nl80211: Check that function pointer != NULL before using itJouni Malinen
NL80211_CMD_GET_MESH_PARAMS and NL80211_CMD_SET_MESH_PARAMS handlers did not verify whether a function pointer is NULL (not supported by the driver) before trying to call the function. The former nl80211 command is available for unprivileged users, too, so this can potentially allow normal users to kill networking (or worse..) if mac80211 is built without CONFIG_MAC80211_MESH=y. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-18netns: oops in ip[6]_frag_reasm incrementing statsJorge Boncompte [DTI2]
dev can be NULL in ip[6]_frag_reasm for skb's coming from RAW sockets. Quagga's OSPFD sends fragmented packets on a RAW socket, when netfilter conntrack reassembles them on the OUTPUT path you hit this code path. You can test it with something like "hping2 -0 -d 2000 -f AA.BB.CC.DD" With help from Jarek Poplawski. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18net: kfree(napi->skb) => kfree_skbRoel Kluin
struct sk_buff pointers should be freed with kfree_skb. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18net: fix sctp breakageAl Viro
broken by commit 5e739d1752aca4e8f3e794d431503bfca3162df4; AFAICS should be -stable fodder as well... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Aced-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18ipv6: fix display of local and remote sit endpointsBjørn Mork
This fixes the regressions cause by commit 1326c3d5a4b792a2b15877feb7fb691f8945d203 (v2.6.28-rc6-461-g23a12b1) broke the display of local and remote addresses of an SIT tunnel in iproute2. nt->parms is used by ipip6_tunnel_init() and therefore need to be initialized first. Tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12868 Reported-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-17Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2009-03-17gro: Fix legacy path napi_complete crashHerbert Xu
On the legacy netif_rx path, I incorrectly tried to optimise the napi_complete call by using __napi_complete before we reenable IRQs. This simply doesn't work since we need to flush the held GRO packets first. This patch fixes it by doing the obvious thing of reenabling IRQs first and then calling napi_complete. Reported-by: Frank Blaschka <blaschka@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16mac80211: Fix panic on fragmentation with power savingJouni Malinen
It was possible to hit a kernel panic on NULL pointer dereference in dev_queue_xmit() when sending power save buffered frames to a STA that woke up from sleep. This happened when the buffered frame was requeued for transmission in ap_sta_ps_end(). In order to avoid the panic, copy the skb->dev and skb->iif values from the first fragment to all other fragments. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16lib80211: silence excessive crypto debugging messagesJohn W. Linville
When they were part of the now defunct ieee80211 component, these messages were only visible when special debugging settings were enabled. Let's mirror that with a new lib80211 debugging Kconfig option. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) r8169: revert "r8169: read MAC address from EEPROM on init (2nd attempt)" r8169: use hardware auto-padding. igb: remove ASPM L0s workaround netxen: remove old flash check. mv643xx_eth: fix unicast address filter corruption on mtu change xfrm: Fix xfrm_state_find() wrt. wildcard source address. emac: Fix clock control for 405EX and 405EXr chips ixgbe: fix multiple unicast address support via-velocity: Fix DMA mapping length errors on transmit. qlge: bugfix: Pad outbound frames smaller than 60 bytes. qlge: bugfix: Move netif_napi_del() to common call point. qlge: bugfix: Tell hw to strip vlan header. qlge: bugfix: Increase filter on inbound csum. dnet: replace obsolete *netif_rx_* functions with *napi_* net: Add be2net driver. dnet: Fix warnings on 64-bit. dnet: Dave DNET ethernet controller driver (updated) ipv6: Fix BUG when disabled ipv6 module is unloaded bnx2x: Using DMAE to initialize the chip bnx2x: Casting page alignment ...
2009-03-16netfilter: conntrack: check for NEXTHDR_NONE before header sanity checkingChristoph Paasch
NEXTHDR_NONE doesn't has an IPv6 option header, so the first check for the length will always fail and results in a confusing message "too short" if debugging enabled. With this patch, we check for NEXTHDR_NONE before length sanity checkings are done. Signed-off-by: Christoph Paasch <christoph.paasch@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-16netfilter: conntrack: fix dropping packet after l4proto->packet()Christoph Paasch
We currently use the negative value in the conntrack code to encode the packet verdict in the error. As NF_DROP is equal to 0, inverting NF_DROP makes no sense and, as a result, no packets are ever dropped. Signed-off-by: Christoph Paasch <christoph.paasch@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-16netfilter: ctnetlink: fix crash during expectation creationPablo Neira Ayuso
This patch fixes a possible crash due to the missing initialization of the expectation class when nf_ct_expect_related() is called. Reported-by: BORBELY Zoltan <bozo@andrews.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-13xfrm: Fix xfrm_state_find() wrt. wildcard source address.David S. Miller
The change to make xfrm_state objects hash on source address broke the case where such source addresses are wildcarded. Fix this by doing a two phase lookup, first with fully specified source address, next using saddr wildcarded. Reported-by: Nicolas Dichtel <nicolas.dichtel@dev.6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-11SUNRPC: xprt_connect() don't abort the task if the transport isn't boundTrond Myklebust
If the transport isn't bound, then we should just return ENOTCONN, letting call_connect_status() and/or call_status() deal with retrying. Currently, we appear to abort all pending tasks with an EIO error. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11SUNRPC: Fix an Oops due to socket not set up yet...Trond Myklebust
We can Oops in both xs_udp_send_request() and xs_tcp_send_request() if the call to xs_sendpages() returns an error due to the socket not yet being set up. Deal with that situation by returning a new error: ENOTSOCK, so that we know to avoid dereferencing transport->sock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11ipv6: Fix BUG when disabled ipv6 module is unloadedJohn Dykstra
Do not try to "uninitialize" ipv6 if its initialization had been skipped because module parameter disable=1 had been specified. Reported-by: Thomas Backlund <tmb@mandriva.org> Signed-off-by: John Dykstra <john.dykstra1@gmail.com> Acked-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10SUNRPC: Tighten up the task locking rules in __rpc_execute()Trond Myklebust
We should probably not be testing any flags after we've cleared the RPC_TASK_RUNNING flag, since rpc_make_runnable() is then free to assign the rpc_task to another workqueue, which may then destroy it. We can fix any races with rpc_make_runnable() by ensuring that we only clear the RPC_TASK_RUNNING flag while holding the rpc_wait_queue->lock that the task is supposed to be sleeping on (and then checking whether or not the task really is sleeping). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-06cfg80211: test before subtraction on unsignedRoel Kluin
freq_diff is unsigned, so test before subtraction Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-04vlan: Fix vlan-in-vlan crashes.David S. Miller
As analyzed by Patrick McHardy, vlan needs to reset it's netdev_ops pointer in it's ->init() function but this leaves the compat method pointers stale. Add a netdev_resync_ops() and call it from the vlan code. Any other driver which changes ->netdev_ops after register_netdevice() will need to call this new function after doing so too. With help from Patrick McHardy. Tested-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04net: Fix missing dev->neigh_setup in register_netdevice().David S. Miller
2009-03-04pkt_sched: act_police: Fix a rate estimator test.Jarek Poplawski
A commit c1b56878fb68e9c14070939ea4537ad4db79ffae "tc: policing requires a rate estimator" introduced a test which invalidates previously working configs, based on examples from iproute2: doc/actions/actions-general. This is too rigorous: a rate estimator is needed only when police's "avrate" option is used. Reported-by: Joao Correia <joaomiguelcorreia@gmail.com> Diagnosed-by: John Dykstra <john.dykstra1@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04SCTP: change sctp_ctl_sock_init() to try IPv4 if IPv6 failsBrian Haley
Change sctp_ctl_sock_init() to try IPv4 if IPv6 socket registration fails. Required if the IPv6 module is loaded with "disable=1", else SCTP will fail to load. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04IPv6: add "disable" module parameter support to ipv6.koBrian Haley
Add "disable" module parameter support to ipv6.ko by specifying "disable=1" on module load. We just do the minimum of initializing inetsw6[] so calls from other modules to inet6_register_protosw() won't OOPs, then bail out. No IPv6 addresses or sockets can be created as a result, and a reboot is required to enable IPv6. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03net: fix tokenring licenseMeelis Roos
Currently, modular tokenring ("tr") lacks a license and fails to load: tr: module license 'unspecified' taints kernel. tr: Unknown symbol proc_net_fops_create Beacuse of this, no tokenring driver can load if it depends on modular tr. Fix this by adding GPL module license as it is in the kernel. With this fix, tr module loads fine and tms380 driver also loads. Well, it does'nt work but that's a different bug. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netlink: invert error code in netlink_set_err()Pablo Neira Ayuso
The callers of netlink_set_err() currently pass a negative value as parameter for the error code. However, sk->sk_err wants a positive error value. Without this patch, skb_recv_datagram() called by netlink_recvmsg() may return a positive value to report an error. Another choice to fix this is to change callers to pass a positive error value, but this seems a bit inconsistent and error prone to me. Indeed, the callers of netlink_set_err() assumed that the (usual) negative value for error codes was fine before this patch :). This patch also includes some documentation in docbook format for netlink_set_err() to avoid this sort of confusion. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netns: Remove net_aliveEric W. Biederman
It turns out that net_alive is unnecessary, and the original problem that led to it being added was simply that the icmp code thought it was a network device and wound up being unable to handle packets while there were still packets in the network namespace. Now that icmp and tcp have been fixed to properly register themselves this problem is no longer present and we have a stronger guarantee that packets will not arrive in a network namespace then that provided by net_alive in netif_receive_skb. So remove net_alive allowing packet reception run a little faster. Additionally document the strong reason why network namespace cleanup is safe so that if something happens again someone else will have a chance of figuring it out. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03tcp: Like icmp use register_pernet_subsysEric W. Biederman
To remove the possibility of packets flying around when network devices are being cleaned up use reisger_pernet_subsys instead of register_pernet_device. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netns: Fix icmp shutdown.Eric W. Biederman
Recently I had a kernel panic in icmp_send during a network namespace cleanup. There were packets in the arp queue that failed to be sent and we attempted to generate an ICMP host unreachable message, but failed because icmp_sk_exit had already been called. The network devices are removed from a network namespace and their arp queues are flushed before we do attempt to shutdown subsystems so this error should have been impossible. It turns out icmp_init is using register_pernet_device instead of register_pernet_subsys. Which resulted in icmp being shut down while we still had the possibility of packets in flight, making a nasty NULL pointer deference in interrupt context possible. Changing this to register_pernet_subsys fixes the problem in my testing. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netns: fix addrconf_ifdown kernel panicDaniel Lezcano
When a network namespace is destroyed the network interfaces are all unregistered, making addrconf_ifdown called by the netdevice notifier. In the other hand, the addrconf exit method does a loop on the network devices and does addrconf_ifdown on each of them. But the ordering of the netns subsystem is not right because it uses the register_pernet_device instead of register_pernet_subsys. If we handle the loopback as any network device, we can safely use register_pernet_subsys. But if we use register_pernet_subsys, the addrconf exit method will do exactly what was already done with the unregistering of the network devices. So in definitive, this code is pointless. I removed the netns addrconf exit method and moved the code to the addrconf cleanup function. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03ipv6: Fix sysctl unregistration deadlockStephen Hemminger
