path: root/net
2013-05-11Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit changes from Eric Paris: "Al used to send pull requests every couple of years but he told me to just start pushing them to you directly. Our touching outside of core audit code is pretty straight forward. A couple of interface changes which hit net/. A simple argument bug calling audit functions in namei.c and the removal of some assembly branch prediction code on ppc" * git://git.infradead.org/users/eparis/audit: (31 commits) audit: fix message spacing printing auid Revert "audit: move kaudit thread start from auditd registration to kaudit init" audit: vfs: fix audit_inode call in O_CREAT case of do_last audit: Make testing for a valid loginuid explicit. audit: fix event coverage of AUDIT_ANOM_LINK audit: use spin_lock in audit_receive_msg to process tty logging audit: do not needlessly take a lock in tty_audit_exit audit: do not needlessly take a spinlock in copy_signal audit: add an option to control logging of passwords with pam_tty_audit audit: use spin_lock_irqsave/restore in audit tty code helper for some session id stuff audit: use a consistent audit helper to log lsm information audit: push loginuid and sessionid processing down audit: stop pushing loginid, uid, sessionid as arguments audit: remove the old depricated kernel interface audit: make validity checking generic audit: allow checking the type of audit message in the user filter audit: fix build break when AUDIT_DEBUG == 2 audit: remove duplicate export of audit_enabled Audit: do not print error when LSMs disabled ...
2013-05-10Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fixes from Bruce Fields: "Small fixes for two bugs and two warnings" * 'for-3.10' of git://linux-nfs.org/~bfields/linux: nfsd: fix oops when legacy_recdir_name_error is passed a -ENOENT error SUNRPC: fix decoding of optional gss-proxy xdr fields SUNRPC: Refactor gssx_dec_option_array() to kill uninitialized warning nfsd4: don't allow owner override on 4.1 CLAIM_FH opens
2013-05-09Merge tag 'nfs-for-3.10-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull more NFS client bugfixes from Trond Myklebust: - Ensure that we match the 'sec=' mount flavour against the server list - Fix the NFSv4 byte range locking in the presence of delegations - Ensure that we conform to the NFSv4.1 spec w.r.t. freeing lock stateids - Fix a pNFS data server connection race * tag 'nfs-for-3.10-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS4.1 Fix data server connection race NFSv3: match sec= flavor against server list NFSv4.1: Ensure that we free the lock stateid on the server NFSv4: Convert nfs41_free_stateid to use an asynchronous RPC call SUNRPC: Don't spam syslog with "Pseudoflavor not found" messages NFSv4.x: Fix handling of partially delegated locks
2013-05-08gso: Handle Trans-Ether-Bridging protocol in skb_network_protocol()Pravin B Shelar
Rather than having logic to calculate inner protocol in every tunnel gso handler move it to gso code. This simplifies code. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Cong Wang <amwang@redhat.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-07SUNRPC: fix decoding of optional gss-proxy xdr fieldsJ. Bruce Fields
The current code works, but sort of by accident: it obviously didn't intend the error return to be interpreted as "true". Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a small pile of fixes" 1) Fix race conditions in IP fragmentation LRU list handling, from Konstantin Khlebnikov. 2) vfree() is no longer verboten in interrupts, so deferring is pointless, from Al Viro. 3) Conversion from mutex to semaphore in netpoll left trylock test inverted, caught by Dan Carpenter. 4) 3c59x uses wrong base address when releasing regions, from Sergei Shtylyov. 5) Bounds checking in TIPC from Dan Carpenter. 6) Fastopen cookies should not be expired as aggressively as other TCP metrics. From Eric Dumazet. 7) Fix retrieval of MAC address in ibmveth, from Ben Herrenschmidt. 8) Don't use "u16" in virtio user headers, from Stephen Hemminger * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: tipc: potential divide by zero in tipc_link_recv_fragment() tipc: add a bounds check in link_recv_changeover_msg() net/usb: new driver for RTL8152 3c59x: fix freeing nonexistent resource on driver unload netpoll: inverted down_trylock() test rps_dev_flow_table_release(): no need to delay vfree() fib_trie: no need to delay vfree() net: frag, fix race conditions in LRU list maintenance tcp: do not expire TCP fastopen cookies net/eth/ibmveth: Fixup retrieval of MAC address virtio: don't expose u16 in userspace api
2013-05-06tipc: potential divide by zero in tipc_link_recv_fragment()Dan Carpenter
The worry here is that fragm_sz could be zero since it comes from skb->data. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06tipc: add a bounds check in link_recv_changeover_msg()Dan Carpenter
The bearer_id here comes from skb->data and it can be a number from 0 to 7. The problem is that the ->links[] array has only 2 elements so I have added a range check. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph changes from Alex Elder: "This is a big pull. Most of it is culmination of Alex's work to implement RBD image layering, which is now complete (yay!). There is also some work from Yan to fix i_mutex behavior surrounding writes in cephfs, a sync write fix, a fix for RBD images that get resized while they are mapped, and a few patches from me that resolve annoying auth warnings and fix several bugs in the ceph auth code." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (254 commits) rbd: fix image request leak on parent read libceph: use slab cache for osd client requests libceph: allocate ceph message data with a slab allocator libceph: allocate ceph messages with a slab allocator rbd: allocate image object names with a slab allocator rbd: allocate object requests with a slab allocator rbd: allocate name separate from obj_request rbd: allocate image requests with a slab allocator rbd: use binary search for snapshot lookup rbd: clear EXISTS flag if mapped snapshot disappears rbd: kill off the snapshot list rbd: define rbd_snap_size() and rbd_snap_features() rbd: use snap_id not index to look up snap info rbd: look up snapshot name in names buffer rbd: drop obj_request->version rbd: drop rbd_obj_method_sync() version parameter rbd: more version parameter removal rbd: get rid of some version parameters rbd: stop tracking header object version rbd: snap names are pointer to constant data ...
2013-05-06netpoll: inverted down_trylock() testDan Carpenter
The return value is reversed from mutex_trylock(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06rps_dev_flow_table_release(): no need to delay vfree()Al Viro
The same story as with fib_trie patch - vfree() from RCU callbacks is legitimate now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06fib_trie: no need to delay vfree()Al Viro
Now that vfree() can be called from interrupt contexts, there's no need to play games with schedule_work() to escape calling vfree() from RCU callbacks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06net: frag, fix race conditions in LRU list maintenanceKonstantin Khlebnikov
This patch fixes race between inet_frag_lru_move() and inet_frag_lru_add() which was introduced in commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206 ("net: frag, move LRU list maintenance outside of rwlock") One cpu already added new fragment queue into hash but not into LRU. Other cpu found it in hash and tries to move it to the end of LRU. This leads to NULL pointer dereference inside of list_move_tail(). Another possible race condition is between inet_frag_lru_move() and inet_frag_lru_del(): move can happens after deletion. This patch initializes LRU list head before adding fragment into hash and inet_frag_lru_move() doesn't touches it if it's empty. I saw this kernel oops two times in a couple of days. [119482.128853] BUG: unable to handle kernel NULL pointer dereference at (null) [119482.132693] IP: [<ffffffff812ede89>] __list_del_entry+0x29/0xd0 [119482.136456] PGD 2148f6067 PUD 215ab9067 PMD 0 [119482.140221] Oops: 0000 [#1] SMP [119482.144008] Modules linked in: vfat msdos fat 8021q fuse nfsd auth_rpcgss nfs_acl nfs lockd sunrpc ppp_async ppp_generic bridge slhc stp llc w83627ehf hwmon_vid snd_hda_codec_hdmi snd_hda_codec_realtek kvm_amd k10temp kvm snd_hda_intel snd_hda_codec edac_core radeon snd_hwdep ath9k snd_pcm ath9k_common snd_page_alloc ath9k_hw snd_timer snd soundcore drm_kms_helper ath ttm r8169 mii [119482.152692] CPU 3 [119482.152721] Pid: 20, comm: ksoftirqd/3 Not tainted 3.9.0-zurg-00001-g9f95269 #132 To Be Filled By O.E.M. To Be Filled By O.E.M./RS880D [119482.161478] RIP: 0010:[<ffffffff812ede89>] [<ffffffff812ede89>] __list_del_entry+0x29/0xd0 [119482.166004] RSP: 0018:ffff880216d5db58 EFLAGS: 00010207 [119482.170568] RAX: 0000000000000000 RBX: ffff88020882b9c0 RCX: dead000000200200 [119482.175189] RDX: 0000000000000000 RSI: 0000000000000880 RDI: ffff88020882ba00 [119482.179860] RBP: ffff880216d5db58 R08: ffffffff8155c7f0 R09: 0000000000000014 [119482.184570] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88020882ba00 [119482.189337] R13: ffffffff81c8d780 R14: ffff880204357f00 R15: 00000000000005a0 [119482.194140] FS: 00007f58124dc700(0000) GS:ffff88021fcc0000(0000) knlGS:0000000000000000 [119482.198928] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [119482.203711] CR2: 0000000000000000 CR3: 00000002155f0000 CR4: 00000000000007e0 [119482.208533] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [119482.213371] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [119482.218221] Process ksoftirqd/3 (pid: 20, threadinfo ffff880216d5c000, task ffff880216d3a9a0) [119482.223113] Stack: [119482.228004] ffff880216d5dbd8 ffffffff8155dcda 0000000000000000 ffff000200000001 [119482.233038] ffff8802153c1f00 ffff880000289440 ffff880200000014 ffff88007bc72000 [119482.238083] 00000000000079d5 ffff88007bc72f44 ffffffff00000002 ffff880204357f00 [119482.243090] Call Trace: [119482.248009] [<ffffffff8155dcda>] ip_defrag+0x8fa/0xd10 [119482.252921] [<ffffffff815a8013>] ipv4_conntrack_defrag+0x83/0xe0 [119482.257803] [<ffffffff8154485b>] nf_iterate+0x8b/0xa0 [119482.262658] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40 [119482.267527] [<ffffffff815448e4>] nf_hook_slow+0x74/0x130 [119482.272412] [<ffffffff8155c7f0>] ? inet_del_offload+0x40/0x40 [119482.277302] [<ffffffff8155d068>] ip_rcv+0x268/0x320 [119482.282147] [<ffffffff81519992>] __netif_receive_skb_core+0x612/0x7e0 [119482.286998] [<ffffffff81519b78>] __netif_receive_skb+0x18/0x60 [119482.291826] [<ffffffff8151a650>] process_backlog+0xa0/0x160 [119482.296648] [<ffffffff81519f29>] net_rx_action+0x139/0x220 [119482.301403] [<ffffffff81053707>] __do_softirq+0xe7/0x220 [119482.306103] [<ffffffff81053868>] run_ksoftirqd+0x28/0x40 [119482.310809] [<ffffffff81074f5f>] smpboot_thread_fn+0xff/0x1a0 [119482.315515] [<ffffffff81074e60>] ? lg_local_lock_cpu+0x40/0x40 [119482.320219] [<ffffffff8106d870>] kthread+0xc0/0xd0 [119482.324858] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40 [119482.329460] [<ffffffff816c32dc>] ret_from_fork+0x7c/0xb0 [119482.334057] [<ffffffff8106d7b0>] ? insert_kthread_work+0x40/0x40 [119482.338661] Code: 00 00 55 48 8b 17 48 b9 00 01 10 00 00 00 ad de 48 8b 47 08 48 89 e5 48 39 ca 74 29 48 b9 00 02 20 00 00 00 ad de 48 39 c8 74 7a <4c> 8b 00 4c 39 c7 75 53 4c 8b 42 08 4c 39 c7 75 2b 48 89 42 08 [119482.343787] RIP [<ffffffff812ede89>] __list_del_entry+0x29/0xd0 [119482.348675] RSP <ffff880216d5db58> [119482.353493] CR2: 0000000000000000 Oops happened on this path: ip_defrag() -> ip_frag_queue() -> inet_frag_lru_move() -> list_move_tail() -> __list_del_entry() Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Cc: Florian Westphal <fw@strlen.de> Cc: Eric Dumazet <edumazet@google.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-06SUNRPC: Refactor gssx_dec_option_array() to kill uninitialized warningGeert Uytterhoeven
net/sunrpc/auth_gss/gss_rpc_xdr.c: In function ‘gssx_dec_option_array’: net/sunrpc/auth_gss/gss_rpc_xdr.c:258: warning: ‘creds’ may be used uninitialized in this function Return early if count is zero, to make it clearer to the compiler (and the casual reviewer) that no more processing is done. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-05tcp: do not expire TCP fastopen cookiesEric Dumazet
TCP metric cache expires entries after one hour. This probably make sense for TCP RTT/RTTVAR/CWND, but not for TCP fastopen cookies. Its better to try previous cookie. If it appears to be obsolete, server will send us new cookie anyway. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Several routines do not use netdev_features_t to hold such bitmasks, fixes from Patrick McHardy and Bjørn Mork. 2) Update cpsw IRQ software state and the actual HW irq enabling in the correct order. From Mugunthan V N. 3) When sending tipc packets to multiple bearers, we have to make copies of the SKB rather than just giving the original SKB directly. Fix from Gerlando Falauto. 4) Fix race with bridging topology change timer, from Stephen Hemminger. 5) Fix TCPv6 segmentation handling in GRE and VXLAN, from Pravin B Shelar. 6) Endian bug in USB pegasus driver, from Dan Carpenter. 7) Fix crashes on MTU reduction in USB asix driver, from Holger Eitzenberger. 8) Don't allow the kernel to BUG() just because the user puts some crap in an AF_PACKET mmap() ring descriptor. Fix from Daniel Borkmann. 9) Don't use variable sized arrays on the stack in xen-netback, from Wei Liu. 10) Fix stats reporting and an unbalanced napi_disable() in be2net driver. From Somnath Kotur and Ajit Khaparde. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (25 commits) cxgb4: fix error recovery when t4_fw_hello returns a positive value sky2: Fix crash on receiving VLAN frames packet: tpacket_v3: do not trigger bug() on wrong header status asix: fix BUG in receive path when lowering MTU net: qmi_wwan: Add Telewell TW-LTE 4G usbnet: pegasus: endian bug in write_mii_word() vxlan: Fix TCPv6 segmentation. gre: Fix GREv4 TCPv6 segmentation. bridge: fix race with topology change timer tipc: pskb_copy() buffers when sending on more than one bearer tipc: tipc_bcbearer_send(): simplify bearer selection tipc: cosmetic: clean up comments and break a long line drivers: net: cpsw: irq not disabled in cpsw isr in particular sequence xen-netback: better names for thresholds xen-netback: avoid allocating variable size array on stack xen-netback: remove redundent parameter in netbk_count_requests be2net: Fix to fail probe if MSI-X enable fails for a VF be2net: avoid napi_disable() when it has not been enabled be2net: Fix firmware download for Lancer be2net: Fix to receive Multicast Packets when Promiscuous mode is enabled on certain devices ...
2013-05-03packet: tpacket_v3: do not trigger bug() on wrong header statusDaniel Borkmann
Jakub reported that it is fairly easy to trigger the BUG() macro from user space with TPACKET_V3's RX_RING by just giving a wrong header status flag. We already had a similar situation in commit 7f5c3e3a80e6654 (``af_packet: remove BUG statement in tpacket_destruct_skb'') where this was the case in the TX_RING side that could be triggered from user space. So really, don't use BUG() or BUG_ON() unless there's really no way out, and i.e. don't use it for consistency checking when there's user space involved, no excuses, especially not if you're slapping the user with WARN + dump_stack + BUG all at once. The two functions are of concern: prb_retire_current_block() [when block status != TP_STATUS_KERNEL] prb_open_block() [when block_status != TP_STATUS_KERNEL] Calls to prb_open_block() are guarded by ealier checks if block_status is really TP_STATUS_KERNEL (racy!), but the first one BUG() is easily triggable from user space. System behaves still stable after they are removed. Also remove that yoda condition entirely, since it's already guarded. Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03vxlan: Fix TCPv6 segmentation.Pravin B Shelar
This patch set correct skb->protocol so that inner packet can lookup correct gso handler. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03gre: Fix GREv4 TCPv6 segmentation.Pravin B Shelar
For ipv6 traffic, GRE can generate packet with strange GSO bits, e.g. ipv4 packet with SKB_GSO_TCPV6 flag set. Therefore following patch relaxes check in inet gso handler to allow such packet for segmentation. This patch also fixes wrong skb->protocol set that was done in gre_gso_segment() handler. Reported-by: Steinar H. Gunderson <sesse@google.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03bridge: fix race with topology change timerstephen hemminger
A bridge should only send topology change notice if it is not the root bridge. It is possible for message age timer to elect itself as a new root bridge, and still have a topology change timer running but waiting for bridge lock on other CPU. Solve the race by checking if we are root bridge before continuing. This was the root cause of the cases where br_send_tcn_bpdu would OOPS. Reported-by: JerryKang <jerry.kang@samsung.com> Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03tipc: pskb_copy() buffers when sending on more than one bearerGerlando Falauto
When sending packets, TIPC bearers use skb_clone() before writing their hardware header. This will however NOT copy the data buffer. So when the same packet is sent over multiple bearers (to reach multiple nodes), the same socket buffer data will be treated by multiple tipc_media drivers which will write their own hardware header through dev_hard_header(). Most of the time this is not a problem, because by the time the packet is processed by the second media, it has already been sent over the first one. However, when the first transmission is delayed (e.g. because of insufficient bandwidth or through a shaper), the next bearer will overwrite the hardware header, resulting in the packet being sent: a) with the wrong source address, when bearers of the same type, e.g. ethernet, are involved b) with a completely corrupt header, or even dropped, when bearers of different types are involved. So when the same socket buffer is to be sent multiple times, send a pskb_copy() instead (from the second instance on), and release it afterwards (the bearer will skb_clone() it anyway). Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-03tipc: tipc_bcbearer_send(): simplify bearer selectionGerlando Falauto
2013-05-03tipc: cosmetic: clean up comments and break a long lineGerlando Falauto
2013-05-03Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from J Bruce Fields: "Highlights include: - Some more DRC cleanup and performance work from Jeff Layton - A gss-proxy upcall from Simo Sorce: currently krb5 mounts to the server using credentials from Active Directory often fail due to limitations of the svcgssd upcall interface. This replacement lifts those limitations. The existing upcall is still supported for backwards compatibility. - More NFSv4.1 support: at this point, if a user with a current client who upgrades from 4.0 to 4.1 should see no regressions. In theory we do everything a 4.1 server is required to do. Patches for a couple minor exceptions are ready for 3.11, and with those and some more testing I'd like to turn 4.1 on by default in 3.11." Fix up semantic conflict as per Stephen Rothwell and linux-next: Commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication") adds two new users of "PDE(inode)->data", but we're supposed to use "PDE_DATA(inode)" instead since commit d9dda78bad87 ("procfs: new helper - PDE_DATA(inode)"). The old PDE() macro is no longer available since commit c30480b92cf4 ("proc: Make the PROC_I() and PDE() macros internal to procfs") * 'for-3.10' of git://linux-nfs.org/~bfields/linux: (60 commits) NFSD: SECINFO doesn't handle unsupported pseudoflavors correctly NFSD: Simplify GSS flavor encoding in nfsd4_do_encode_secinfo() nfsd: make symbol nfsd_reply_cache_shrinker static svcauth_gss: fix error return code in rsc_parse() nfsd4: don't remap EISDIR errors in rename svcrpc: fix gss-proxy to respect user namespaces SUNRPC: gssp_procedures[] can be static SUNRPC: define {create,destroy}_use_gss_proxy_proc_entry in !PROC case nfsd4: better error return to indicate SSV non-support nfsd: fix EXDEV checking in rename SUNRPC: Use gssproxy upcall for server RPCGSS authentication. SUNRPC: Add RPC based upcall mechanism for RPCGSS auth SUNRPC: conditionally return endtime from import_sec_context SUNRPC: allow disabling idle timeout SUNRPC: attempt AF_LOCAL connect on setup nfsd: Decode and send 64bit time values nfsd4: put_client_renew_locked can be static nfsd4: remove unused macro nfsd4: remove some useless code nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKED ...
2013-05-03SUNRPC: Don't spam syslog with "Pseudoflavor not found" messagesTrond Myklebust
Just convert those messages to dprintk()s so that they can be used when debugging. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - XTS mode optimisation for twofish/cast6/camellia/aes on x86 - AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia - SSSE3/AVX/AVX2 optimisations for sha256/sha512 - Added driver for SAHARA2 crypto accelerator - Fix for GMAC when used in non-IPsec secnarios - Added generic CMAC implementation (including IPsec glue) - IP update for crypto/atmel - Support for more than one device in hwrng/timeriomem - Added Broadcom BCM2835 RNG driver - Misc fixes * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits) crypto: caam - fix job ring cleanup code crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher crypto: tcrypt - add async cipher speed tests for blowfish crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2 crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86 crypto: aesni_intel - add more optimized XTS mode for x86-64 crypto: x86/camellia-aesni-avx - add more optimized XTS code crypto: cast6-avx: use new optimized XTS code crypto: x86/twofish-avx - use optimized XTS code crypto: x86 - add more optimized XTS-mode for serpent-avx xfrm: add rfc4494 AES-CMAC-96 support crypto: add CMAC support to CryptoAPI crypto: testmgr - add empty test vectors for null ciphers crypto: testmgr - add AES GMAC test vectors crypto: gcm - fix rfc4543 to handle async crypto correctly crypto: gcm - make GMAC work when dst and src are different hwrng: timeriomem - added devicetree hooks ...
2013-05-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio & lguest updates from Rusty Russell: "Lots of virtio work which wasn't quite ready for last merge window. Plus I dived into lguest again, reworking the pagetable code so we can move the switcher page: our fixmaps sometimes take more than 2MB now..." Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename. Hopefully correctly resolved. * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits) caif_virtio: Remove bouncing email addresses lguest: improve code readability in lg_cpu_start. virtio-net: fill only rx queues which are being used lguest: map Switcher below fixmap. lguest: cache last cpu we ran on. lguest: map Switcher text whenever we allocate a new pagetable. lguest: don't share Switcher PTE pages between guests. lguest: expost switcher_pages array (as lg_switcher_pages). lguest: extract shadow PTE walking / allocating. lguest: make check_gpte et. al return bool. lguest: assume Switcher text is a single page. lguest: rename switcher_page to switcher_pages. lguest: remove RESERVE_MEM constant. lguest: check vaddr not pgd for Switcher protection. lguest: prepare to make SWITCHER_ADDR a variable. virtio: console: replace EMFILE with EBUSY for already-open port virtio-scsi: reset virtqueue affinity when doing cpu hotplug virtio-scsi: introduce multiqueue support virtio-scsi: push vq lock/unlock into virtscsi_vq_done virtio-scsi: pass struct virtio_scsi to virtqueue completion function ...
2013-05-02net: vlan,ethtool: netdev_features_t is more than 32 bitBjørn Mork
Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-02net: use netdev_features_t in skb_needs_linearize()Patrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-02libceph: use slab cache for osd client requestsAlex Elder
Create a slab cache to manage allocation of ceph_osdc_request structures. This resolves: http://tracker.ceph.com/issues/3926 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-02libceph: allocate ceph message data with a slab allocatorAlex Elder
Create a slab cache to manage ceph_msg_data structure allocation. This is part of: http://tracker.ceph.com/issues/3926 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-02libceph: allocate ceph messages with a slab allocatorAlex Elder
Create a slab cache to manage ceph_msg structure allocation. This is part of: http://tracker.ceph.com/issues/3926 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: create source file "net/ceph/snapshot.c"Alex Elder
This creates a new source file "net/ceph/snapshot.c" to contain utility routines related to ceph snapshot contexts. The main motivation was to define ceph_create_snap_context() as a common way to create these structures, but I've moved the definitions of ceph_get_snap_context() and ceph_put_snap_context() there too. (The benefit of inlining those is very small, and I'd rather keep this collection of functions together.) Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: fix byte order mismatchAlex Elder
A WATCH op includes an object version. The version that's supplied is incorrectly byte-swapped osd_req_op_watch_init() where it's first assigned (it's been this way since that code was first added). The result is that the version sent to the osd is wrong, because that value gets byte-swapped again in osd_req_encode_op(). This is the source of a sparse warning related to improper byte order in the assignment. The approach of using the version to avoid a race is deprecated (see http://tracker.ceph.com/issues/3871), and the watch parameter is no longer even examined by the osd. So fix the assignment in osd_req_op_watch_init() so it no longer does the byte swap. This resolves: http://tracker.ceph.com/issues/3847 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: support pages for class request dataAlex Elder
Add the ability to provide an array of pages as outbound request data for object class method calls. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: fix two messenger bugsAlex Elder
This patch makes four small changes in the ceph messenger. While getting copyup functionality working I found two bugs in the messenger. Existing paths through the code did not trigger these problems, but they're fixed here: - In ceph_msg_data_pagelist_cursor_init(), the cursor's last_piece field was being checked against the length supplied. This was OK until this commit: ccba6d98 libceph: implement multiple data items in a message That commit changed the cursor init routines to allow lengths to be supplied that exceeded the size of the current data item. Because of this, we have to use the assigned cursor resid field rather than the provided length in determining whether the cursor points to the last piece of a data item. - In ceph_msg_data_add_pages(), a BUG_ON() was erroneously catching attempts to add page data to a message if the message already had data assigned to it. That was OK until that same commit, at which point it was fine for messages to have multiple data items. It slipped through because that BUG_ON() call was present twice in that function. (You can never be too careful.) In addition two other minor things are changed: - In ceph_msg_data_cursor_init(), the local variable "data" was getting assigned twice. - In ceph_msg_data_advance(), it was assumed that the type-specific advance routine would set new_piece to true after it advanced past the last piece. That may have been fine, but since we check for that case we might as well set it explicitly in ceph_msg_data_advance(). This resolves: http://tracker.ceph.com/issues/4762 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: support raw data requestsAlex Elder
Allow osd request ops that aren't otherwise structured (not class, extent, or watch ops) to specify "raw" data to be used to hold incoming data for the op. Make use of this capability for the osd STAT op. Prefix the name of the private function osd_req_op_init() with "_", and expose a new function by that (earlier) name whose purpose is to initialize osd ops with (only) implied data. For now we'll just support the use of a page array for an osd op with incoming raw data. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: clean up osd data field access functionsAlex Elder
There are a bunch of functions defined to encapsulate getting the address of a data field for a particular op in an osd request. They're all defined the same way, so create a macro to take the place of all of them. Two of these are used outside the osd client code, so preserve them (but convert them to use the new macro internally). Stop exporting the ones that aren't used elsewhere. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: kill off osd data write_request parametersAlex Elder
In the incremental move toward supporting distinct data items in an osd request some of the functions had "write_request" parameters to indicate, basically, whether the data belonged to in_data or the out_data. Now that we maintain the data fields in the op structure there is no need to indicate the direction, so get rid of the "write_request" parameters. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: change how "safe" callback is usedAlex Elder
An osd request currently has two callbacks. They inform the initiator of the request when we've received confirmation for the target osd that a request was received, and when the osd indicates all changes described by the request are durable. The only time the second callback is used is in the ceph file system for a synchronous write. There's a race that makes some handling of this case unsafe. This patch addresses this problem. The error handling for this callback is also kind of gross, and this patch changes that as well. In ceph_sync_write(), if a safe callback is requested we want to add the request on the ceph inode's unsafe items list. Because items on this list must have their tid set (by ceph_osd_start_request()), the request added *after* the call to that function returns. The problem with this is that there's a race between starting the request and adding it to the unsafe items list; the request may already be complete before ceph_sync_write() even begins to put it on the list. To address this, we change the way the "safe" callback is used. Rather than just calling it when the request is "safe", we use it to notify the initiator the bounds (start and end) of the period during which the request is *unsafe*. So the initiator gets notified just before the request gets sent to the osd (when it is "unsafe"), and again when it's known the results are durable (it's no longer unsafe). The first call will get made in __send_request(), just before the request message gets sent to the messenger for the first time. That function is only called by __send_queued(), which is always called with the osd client's request mutex held. We then have this callback function insert the request on the ceph inode's unsafe list when we're told the request is unsafe. This will avoid the race because this call will be made under protection of the osd client's request mutex. It also nicely groups the setup and cleanup of the state associated with managing unsafe requests. The name of the "safe" callback field is changed to "unsafe" to better reflect its new purpose. It has a Boolean "unsafe" parameter to indicate whether the request is becoming unsafe or is now safe. Because the "msg" parameter wasn't used, we drop that. This resolves the original problem reportedin: http://tracker.ceph.com/issues/4706 Reported-by: Yan, Zheng <zheng.z.yan@intel.com> Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Yan, Zheng <zheng.z.yan@intel.com> Reviewed-by: Sage Weil <sage@inktank.com>
2013-05-01libceph: make method call data be a separate data itemAlex Elder
Right now the data for a method call is specified via a pointer and length, and it's copied--along with the class and method name--into a pagelist data item to be sent to the osd. Instead, encode the data in a data item separate from the class and method names. This will allow large amounts of data to be supplied to methods without copying. Only rbd uses the class functionality right now, and when it really needs this it will probably need to use a page array rather than a page list. But this simple implementation demonstrates the functionality on the osd client, and that's enough for now. This resolves: http://tracker.ceph.com/issues/4104 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: add, don't set data for a messageAlex Elder
Change the names of the functions that put data on a pagelist to reflect that we're adding to whatever's already there rather than just setting it to the one thing. Currently only one data item is ever added to a message, but that's about to change. This resolves: http://tracker.ceph.com/issues/2770 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: implement multiple data items in a messageAlex Elder
This patch adds support to the messenger for more than one data item in its data list. A message data cursor has two more fields to support this: - a count of the number of bytes left to be consumed across all data items in the list, "total_resid" - a pointer to the head of the list (for validation only) The cursor initialization routine has been split into two parts: the outer one, which initializes the cursor for traversing the entire list of data items; and the inner one, which initializes the cursor to start processing a single data item. When a message cursor is first initialized, the outer initialization routine sets total_resid to the length provided. The data pointer is initialized to the first data item on the list. From there, the inner initialization routine finishes by setting up to process the data item the cursor points to. Advancing the cursor consumes bytes in total_resid. If the resid field reaches zero, it means the current data item is fully consumed. If total_resid indicates there is more data, the cursor is advanced to point to the next data item, and then the inner initialization routine prepares for using that. (A check is made at this point to make sure we don't wrap around the front of the list.) The type-specific init routines are modified so they can be given a length that's larger than what the data item can support. The resid field is initialized to the smaller of the provided length and the length of the entire data item. When total_resid reaches zero, we're done. This resolves: http://tracker.ceph.com/issues/3761 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: replace message data pointer with listAlex Elder
In place of the message data pointer, use a list head which links through message data items. For now we only support a single entry on that list. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: have cursor point to dataAlex Elder
Rather than having a ceph message data item point to the cursor it's associated with, have the cursor point to a data item. This will allow a message cursor to be used for more than one data item. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: move cursor into messageAlex Elder
A message will only be processing a single data item at a time, so there's no need for each data item to have its own cursor. Move the cursor embedded in the message data structure into the message itself. To minimize the impact, keep the data->cursor field, but make it be a pointer to the cursor in the message. Move the definition of ceph_msg_data above ceph_msg_data_cursor so the cursor can point to the data without a forward definition rather than vice-versa. This and the upcoming patches are part of: http://tracker.ceph.com/issues/3761 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: record bio lengthAlex Elder
The bio is the only data item type that doesn't record its full length. Fix that. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: skip message if too big to receiveAlex Elder
We know the length of our message buffers. If we get a message that's too long, just dump it and ignore it. If skip was set then con->in_msg won't be valid, so be careful not to dereference a null pointer in the process. This resolves: http://tracker.ceph.com/issues/4664 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: fix possible CONFIG_BLOCK build problemAlex Elder
This patch: 15a0d7b libceph: record message data length did not enclose some bio-specific code inside CONFIG_BLOCK as it should have. Fix that. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
2013-05-01libceph: kill off osd request r_data_in and r_data_outAlex Elder
Finally! Convert the osd op data pointers into real structures, and make the switch over to using them instead of having all ops share the in and/or out data structures in the osd request. Set up a new function to traverse the set of ops and release any data associated with them (pages). This and the patches leading up to it resolve: http://tracker.ceph.com/issues/4657 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
