path: root/net
2018-03-11mpls, nospec: Sanitize array index in mpls_label_ok()Dan Williams
commit 3968523f855050b8195134da951b87c20bd66130 upstream. mpls_label_ok() validates that the 'platform_label' array index from a userspace netlink message payload is valid. Under speculation the mpls_label_ok() result may not resolve in the CPU pipeline until after the index is used to access an array element. Sanitize the index to zero to prevent userspace-controlled arbitrary out-of-bounds speculation, a precursor for a speculative execution side channel vulnerability. Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 4.4: - mpls_label_ok() doesn't take an extack parameter - Drop change in mpls_getroute()] Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11net: mpls: Pull common label check into helperDavid Ahern
commit b7b386f42f079b25b942c756820e36c6bd09b2ca upstream. mpls_route_add and mpls_route_del have the same checks on the label. Move to a helper. Avoid duplicate extack messages in the next patch. Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11sctp: verify size of a new chunk in _sctp_make_chunk()Alexey Kodanev
[ Upstream commit 07f2c7ab6f8d0a7e7c5764c4e6cc9c52951b9d9c ] When SCTP makes INIT or INIT_ACK packet the total chunk length can exceed SCTP_MAX_CHUNK_LEN which leads to kernel panic when transmitting these packets, e.g. the crash on sending INIT_ACK: [ 597.804948] skbuff: skb_over_panic: text:00000000ffae06e4 len:120168 put:120156 head:000000007aa47635 data:00000000d991c2de tail:0x1d640 end:0xfec0 dev:<NULL> ... [ 597.976970] ------------[ cut here ]------------ [ 598.033408] kernel BUG at net/core/skbuff.c:104! [ 600.314841] Call Trace: [ 600.345829] <IRQ> [ 600.371639] ? sctp_packet_transmit+0x2095/0x26d0 [sctp] [ 600.436934] skb_put+0x16c/0x200 [ 600.477295] sctp_packet_transmit+0x2095/0x26d0 [sctp] [ 600.540630] ? sctp_packet_config+0x890/0x890 [sctp] [ 600.601781] ? __sctp_packet_append_chunk+0x3b4/0xd00 [sctp] [ 600.671356] ? sctp_cmp_addr_exact+0x3f/0x90 [sctp] [ 600.731482] sctp_outq_flush+0x663/0x30d0 [sctp] [ 600.788565] ? sctp_make_init+0xbf0/0xbf0 [sctp] [ 600.845555] ? sctp_check_transmitted+0x18f0/0x18f0 [sctp] [ 600.912945] ? sctp_outq_tail+0x631/0x9d0 [sctp] [ 600.969936] sctp_cmd_interpreter.isra.22+0x3be1/0x5cb0 [sctp] [ 601.041593] ? sctp_sf_do_5_1B_init+0x85f/0xc30 [sctp] [ 601.104837] ? sctp_generate_t1_cookie_event+0x20/0x20 [sctp] [ 601.175436] ? sctp_eat_data+0x1710/0x1710 [sctp] [ 601.233575] sctp_do_sm+0x182/0x560 [sctp] [ 601.284328] ? sctp_has_association+0x70/0x70 [sctp] [ 601.345586] ? sctp_rcv+0xef4/0x32f0 [sctp] [ 601.397478] ? sctp6_rcv+0xa/0x20 [sctp] ... Here the chunk size for INIT_ACK packet becomes too big, mostly because of the state cookie (INIT packet has large size with many address parameters), plus additional server parameters. Later this chunk causes the panic in skb_put_data(): skb_packet_transmit() sctp_packet_pack() skb_put_data(nskb, chunk->skb->data, chunk->skb->len); 'nskb' (head skb) was previously allocated with packet->size from u16 'chunk->chunk_hdr->length'. As suggested by Marcelo we should check the chunk's length in _sctp_make_chunk() before trying to allocate skb for it and discard a chunk if its size bigger than SCTP_MAX_CHUNK_LEN. Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leinter@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11sctp: fix dst refcnt leak in sctp_v6_get_dst()Alexey Kodanev
[ Upstream commit 957d761cf91cdbb175ad7d8f5472336a4d54dbf2 ] When going through the bind address list in sctp_v6_get_dst() and the previously found address is better ('matchlen > bmatchlen'), the code continues to the next iteration without releasing currently held destination. Fix it by releasing 'bdst' before continue to the next iteration, and instead of introducing one more '!IS_ERR(bdst)' check for dst_release(), move the already existed one right after ip6_dst_lookup_flow(), i.e. we shouldn't proceed further if we get an error for the route lookup. Fixes: dbc2b5e9a09e ("sctp: fix src address selection if using secondary addresses for ipv6") Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11sctp: fix dst refcnt leak in sctp_v4_get_dstTommi Rantala
[ Upstream commit 4a31a6b19f9ddf498c81f5c9b089742b7472a6f8 ] Fix dst reference count leak in sctp_v4_get_dst() introduced in commit 410f03831 ("sctp: add routing output fallback"): When walking the address_list, successive ip_route_output_key() calls may return the same rt->dst with the reference incremented on each call. The code would not decrement the dst refcount when the dst pointer was identical from the previous iteration, causing the dst refcnt leak. Testcase: ip netns add TEST ip netns exec TEST ip link set lo up ip link add dummy0 type dummy ip link add dummy1 type dummy ip link add dummy2 type dummy ip link set dev dummy0 netns TEST ip link set dev dummy1 netns TEST ip link set dev dummy2 netns TEST ip netns exec TEST ip addr add 192.168.1.1/24 dev dummy0 ip netns exec TEST ip link set dummy0 up ip netns exec TEST ip addr add 192.168.1.2/24 dev dummy1 ip netns exec TEST ip link set dummy1 up ip netns exec TEST ip addr add 192.168.1.3/24 dev dummy2 ip netns exec TEST ip link set dummy2 up ip netns exec TEST sctp_test -H 192.168.1.2 -P 20002 -h 192.168.1.1 -p 20000 -s -B 192.168.1.3 ip netns del TEST In 4.4 and 4.9 kernels this results to: [ 354.179591] unregister_netdevice: waiting for lo to become free. Usage count = 1 [ 364.419674] unregister_netdevice: waiting for lo to become free. Usage count = 1 [ 374.663664] unregister_netdevice: waiting for lo to become free. Usage count = 1 [ 384.903717] unregister_netdevice: waiting for lo to become free. Usage count = 1 [ 395.143724] unregister_netdevice: waiting for lo to become free. Usage count = 1 [ 405.383645] unregister_netdevice: waiting for lo to become free. Usage count = 1 ... Fixes: 410f03831 ("sctp: add routing output fallback") Fixes: 0ca50d12f ("sctp: fix src address selection if using secondary addresses") Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com> Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11udplite: fix partial checksum initializationAlexey Kodanev
[ Upstream commit 15f35d49c93f4fa9875235e7bf3e3783d2dd7a1b ] Since UDP-Lite is always using checksum, the following path is triggered when calculating pseudo header for it: udp4_csum_init() or udp6_csum_init() skb_checksum_init_zero_check() __skb_checksum_validate_complete() The problem can appear if skb->len is less than CHECKSUM_BREAK. In this particular case __skb_checksum_validate_complete() also invokes __skb_checksum_complete(skb). If UDP-Lite is using partial checksum that covers only part of a packet, the function will return bad checksum and the packet will be dropped. It can be fixed if we skip skb_checksum_init_zero_check() and only set the required pseudo header checksum for UDP-Lite with partial checksum before udp4_csum_init()/udp6_csum_init() functions return. Fixes: ed70fcfcee95 ("net: Call skb_checksum_init in IPv4") Fixes: e4f45b7f40bd ("net: Call skb_checksum_init in IPv6") Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11netlink: ensure to loop over all netns in genlmsg_multicast_allns()Nicolas Dichtel
[ Upstream commit cb9f7a9a5c96a773bbc9c70660dc600cfff82f82 ] Nowadays, nlmsg_multicast() returns only 0 or -ESRCH but this was not the case when commit 134e63756d5f was pushed. However, there was no reason to stop the loop if a netns does not have listeners. Returns -ESRCH only if there was no listeners in all netns. To avoid having the same problem in the future, I didn't take the assumption that nlmsg_multicast() returns only 0 or -ESRCH. Fixes: 134e63756d5f ("genetlink: make netns aware") CC: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11net: ipv4: don't allow setting net.ipv4.route.min_pmtu below 68Sabrina Dubroca
[ Upstream commit c7272c2f1229125f74f22dcdd59de9bbd804f1c8 ] According to RFC 1191 sections 3 and 4, ICMP frag-needed messages indicating an MTU below 68 should be rejected: A host MUST never reduce its estimate of the Path MTU below 68 octets. and (talking about ICMP frag-needed's Next-Hop MTU field): This field will never contain a value less than 68, since every router "must be able to forward a datagram of 68 octets without fragmentation". Furthermore, by letting net.ipv4.route.min_pmtu be set to negative values, we can end up with a very large PMTU when (-1) is cast into u32. Let's also make ip_rt_min_pmtu a u32, since it's only ever compared to unsigned ints. Reported-by: Jianlin Shi <jishi@redhat.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Reviewed-by: Stefano Brivio <sbrivio@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11net: fix race on decreasing number of TX queuesJakub Kicinski
[ Upstream commit ac5b70198adc25c73fba28de4f78adcee8f6be0b ] netif_set_real_num_tx_queues() can be called when netdev is up. That usually happens when user requests change of number of channels/rings with ethtool -L. The procedure for changing the number of queues involves resetting the qdiscs and setting dev->num_tx_queues to the new value. When the new value is lower than the old one, extra care has to be taken to ensure ordering of accesses to the number of queues vs qdisc reset. Currently the queues are reset before new dev->num_tx_queues is assigned, leaving a window of time where packets can be enqueued onto the queues going down, leading to a likely crash in the drivers, since most drivers don't check if TX skbs are assigned to an active queue. Fixes: e6484930d7c7 ("net: allocate tx queues in register_netdevice") Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11ipv6 sit: work around bogus gcc-8 -Wrestrict warningArnd Bergmann
[ Upstream commit ca79bec237f5809a7c3c59bd41cd0880aa889966 ] gcc-8 has a new warning that detects overlapping input and output arguments in memcpy(). It triggers for sit_init_net() calling ipip6_tunnel_clone_6rd(), which is actually correct: net/ipv6/sit.c: In function 'sit_init_net': net/ipv6/sit.c:192:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict] The problem here is that the logic detecting the memcpy() arguments finds them to be the same, but the conditional that tests for the input and output of ipip6_tunnel_clone_6rd() to be identical is not a compile-time constant. We know that netdev_priv(t->dev) is the same as t for a tunnel device, and comparing "dev" directly here lets the compiler figure out as well that 'dev == sitn->fb_tunnel_dev' when called from sit_init_net(), so it no longer warns. This code is old, so Cc stable to make sure that we don't get the warning for older kernels built with new gcc. Cc: Martin Sebor <msebor@gmail.com> Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=83456 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11fib_semantics: Don't match route with mismatching tclassidStefano Brivio
[ Upstream commit a8c6db1dfd1b1d18359241372bb204054f2c3174 ] In fib_nh_match(), if output interface or gateway are passed in the FIB configuration, we don't have to check next hops of multipath routes to conclude whether we have a match or not. However, we might still have routes with different realms matching the same output interface and gateway configuration, and this needs to cause the match to fail. Otherwise the first route inserted in the FIB will match, regardless of the realms: # ip route add 1.1.1.1 dev eth0 table 1234 realms 1/2 # ip route append 1.1.1.1 dev eth0 table 1234 realms 3/4 # ip route list table 1234 1.1.1.1 dev eth0 scope link realms 1/2 1.1.1.1 dev eth0 scope link realms 3/4 # ip route del 1.1.1.1 dev ens3 table 1234 realms 3/4 # ip route list table 1234 1.1.1.1 dev ens3 scope link realms 3/4 whereas route with realms 3/4 should have been deleted instead. Explicitly check for fc_flow passed in the FIB configuration (this comes from RTA_FLOW extracted by rtm_to_fib_config()) and fail matching if it differs from nh_tclassid. The handling of RTA_FLOW for multipath routes later in fib_nh_match() is still needed, as we can have multiple RTA_FLOW attributes that need to be matched against the tclassid of each next hop. v2: Check that fc_flow is set before discarding the match, so that the user can still select the first matching rule by not specifying any realm, as suggested by David Ahern. Reported-by: Jianlin Shi <jishi@redhat.com> Signed-off-by: Stefano Brivio <sbrivio@redhat.com> Acked-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-11bridge: check brport attr show in brport_showXin Long
[ Upstream commit 1b12580af1d0677c3c3a19e35bfe5d59b03f737f ] Now br_sysfs_if file flush doesn't have attr show. To read it will cause kernel panic after users chmod u+r this file. Xiong found this issue when running the commands: ip link add br0 type bridge ip link add type veth ip link set veth0 master br0 chmod u+r /sys/devices/virtual/net/veth0/brport/flush timeout 3 cat /sys/devices/virtual/net/veth0/brport/flush kernel crashed with NULL a pointer dereference call trace. This patch is to fix it by return -EINVAL when brport_attr->show is null, just the same as the check for brport_attr->store in brport_store(). Fixes: 9cf637473c85 ("bridge: add sysfs hook to flush forwarding table") Reported-by: Xiong Zhou <xzhou@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-03sctp: make use of pre-calculated lenMarcelo Ricardo Leitner
[ Upstream commit c76f97c99ae6d26d14c7f0e50e074382bfbc9f98 ] Some sockopt handling functions were calculating the length of the buffer to be written to userspace and then calculating it again when actually writing the buffer, which could lead to some write not using an up-to-date length. This patch updates such places to just make use of the len variable. Also, replace some sizeof(type) to sizeof(var). Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-03mac80211: mesh: drop frames appearing to be from usJohannes Berg
[ Upstream commit 736a80bbfda709fb3631f5f62056f250a38e5804 ] If there are multiple mesh stations with the same MAC address, they will both get confused and start throwing warnings. Obviously in this case nothing can actually work anyway, so just drop frames that look like they're from ourselves early on. Reported-by: Gui Iribarren <gui@altermundi.net> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-03ipv6: icmp6: Allow icmp messages to be looped backBrendan McGrath
[ Upstream commit 588753f1eb18978512b1c9b85fddb457d46f9033 ] One example of when an ICMPv6 packet is required to be looped back is when a host acts as both a Multicast Listener and a Multicast Router. A Multicast Router will listen on address ff02::16 for MLDv2 messages. Currently, MLDv2 messages originating from a Multicast Listener running on the same host as the Multicast Router are not being delivered to the Multicast Router. This is due to dst.input being assigned the default value of dst_discard. This results in the packet being looped back but discarded before being delivered to the Multicast Router. This patch sets dst.input to ip6_input to ensure a looped back packet is delivered to the Multicast Router. Signed-off-by: Brendan McGrath <redmcg@redmandi.dyndns.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28cfg80211: fix cfg80211_beacon_dupArnd Bergmann
commit bee92d06157fc39d5d7836a061c7d41289a55797 upstream. gcc-8 warns about some obviously incorrect code: net/mac80211/cfg.c: In function 'cfg80211_beacon_dup': net/mac80211/cfg.c:2896:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict] From the context, I conclude that we want to copy from beacon into new_beacon, as we do in the rest of the function. Cc: stable@vger.kernel.org Fixes: 73da7d5bab79 ("mac80211: add channel switch command and beacon callbacks") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28ip_tunnel: fix preempt warning in ip tunnel creation/updatingPaolo Abeni
commit f27337e16f2d0e52a8d05ea599ed13cd266ac291 upstream. After the commit e09acddf873b ("ip_tunnel: replace dst_cache with generic implementation"), a preemption debug warning is triggered on ip4 tunnels updating; the dst cache helper needs to be invoked in unpreemptible context. We don't need to load the cache on tunnel update, so this commit fixes the warning replacing the load with a dst cache reset, which is preempt safe. Fixes: e09acddf873b ("ip_tunnel: replace dst_cache with generic implementation") Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paolo Abeni <pabeni@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28ip_tunnel: replace dst_cache with generic implementationPaolo Abeni
commit e09acddf873bf775b208b452a4c3a3fd26fa9427 upstream. The current ip_tunnel cache implementation is prone to a race that will cause the wrong dst to be cached on cuncurrent dst cache miss and ip tunnel update via netlink. Replacing with the generic implementation fix the issue. Signed-off-by: Paolo Abeni <pabeni@redhat.com> Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-28netfilter: drop outermost socket lock in getsockopt()Paolo Abeni
commit 01ea306f2ac2baff98d472da719193e738759d93 upstream. The Syzbot reported a possible deadlock in the netfilter area caused by rtnl lock, xt lock and socket lock being acquired with a different order on different code paths, leading to the following backtrace: Reviewed-by: Xin Long <lucien.xin@gmail.com> ====================================================== WARNING: possible circular locking dependency detected 4.15.0+ #301 Not tainted ------------------------------------------------------ syzkaller233489/4179 is trying to acquire lock: (rtnl_mutex){+.+.}, at: [<0000000048e996fd>] rtnl_lock+0x17/0x20 net/core/rtnetlink.c:74 but task is already holding lock: (&xt[i].mutex){+.+.}, at: [<00000000328553a2>] xt_find_table_lock+0x3e/0x3e0 net/netfilter/x_tables.c:1041 which lock already depends on the new lock. === Since commit 3f34cfae1230 ("netfilter: on sockopt() acquire sock lock only in the required scope"), we already acquire the socket lock in the innermost scope, where needed. In such commit I forgot to remove the outer-most socket lock from the getsockopt() path, this commit addresses the issues dropping it now. v1 -> v2: fix bad subj, added relavant 'fixes' tag Fixes: 22265a5c3c10 ("netfilter: xt_TEE: resolve oif using netdevice notifiers") Fixes: 202f59afd441 ("netfilter: ipt_CLUSTERIP: do not hold dev") Fixes: 3f34cfae1230 ("netfilter: on sockopt() acquire sock lock only in the required scope") Reported-by: syzbot+ddde1c7b7ff7442d7f2d@syzkaller.appspotmail.com Suggested-by: Florian Westphal <fw@strlen.de> Signed-off-by: Paolo Abeni <pabeni@redhat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net: dst_cache_per_cpu_dst_set() can be staticWu Fengguang
commit b73f96fcb49ec90c2f837719893e7b25fcdf08d8 upstream. Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25nl80211: Sanitize array index in parse_txq_paramsDan Williams
(cherry picked from commit 259d8c1e984318497c84eef547bbb6b1d9f4eb05) Wireless drivers rely on parse_txq_params to validate that txq_params->ac is less than NL80211_NUM_ACS by the time the low-level driver's ->conf_tx() handler is called. Use a new helper, array_index_nospec(), to sanitize txq_params->ac with respect to speculation. I.e. ensure that any speculation into ->conf_tx() handlers is done with a value of txq_params->ac that is within the bounds of [0, NL80211_NUM_ACS). Reported-by: Christian Lamparter <chunkeey@gmail.com> Reported-by: Elena Reshetova <elena.reshetova@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Johannes Berg <johannes@sipsolutions.net> Cc: linux-arch@vger.kernel.org Cc: kernel-hardening@lists.openwall.com Cc: gregkh@linuxfoundation.org Cc: linux-wireless@vger.kernel.org Cc: torvalds@linux-foundation.org Cc: "David S. Miller" <davem@davemloft.net> Cc: alan@linux.intel.com Link: https://lkml.kernel.org/r/151727419584.33451.7700736761686184303.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> [jwang: cherry pick to 4.4] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25ipv4: ipconfig: avoid unused ic_proto_used symbolArnd Bergmann
commit 52b79e2bdf92b07b37c805c50811eaf69a33683d upstream. When CONFIG_PROC_FS, CONFIG_IP_PNP_BOOTP, CONFIG_IP_PNP_DHCP and CONFIG_IP_PNP_RARP are all disabled, we get a warning about the ic_proto_used variable being unused: net/ipv4/ipconfig.c:146:12: error: 'ic_proto_used' defined but not used [-Werror=unused-variable] This avoids the warning, by making the definition conditional on whether a dynamic IP configuration protocol is configured. If not, we know that the value is always zero, so we can optimize away the variable and all code that depends on it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netfilter: ipvs: avoid unused variable warningsArnd Bergmann
commit f6ca9f46f6615c3a87529550058d1b468c0cad89 upstream. The proc_create() and remove_proc_entry() functions do not reference their arguments when CONFIG_PROC_FS is disabled, so we get a couple of warnings about unused variables in IPVS: ipvs/ip_vs_app.c:608:14: warning: unused variable 'net' [-Wunused-variable] ipvs/ip_vs_ctl.c:3950:14: warning: unused variable 'net' [-Wunused-variable] ipvs/ip_vs_ctl.c:3994:14: warning: unused variable 'net' [-Wunused-variable] This removes the local variables and instead looks them up separately for each use, which obviously avoids the warning. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 4c50a8ce2b63 ("netfilter: ipvs: avoid unused variable warning") Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25xfrm: Fix stack-out-of-bounds with misconfigured transport mode policies.Steffen Klassert
[ Upstream commit 732706afe1cc46ef48493b3d2b69c98f36314ae4 ] On policies with a transport mode template, we pass the addresses from the flowi to xfrm_state_find(), assuming that the IP addresses (and address family) don't change during transformation. Unfortunately our policy template validation is not strict enough. It is possible to configure policies with transport mode template where the address family of the template does not match the selectors address family. This lead to stack-out-of-bound reads because we compare arddesses of the wrong family. Fix this by refusing such a configuration, address family can not change on transport mode. We use the assumption that, on transport mode, the first templates address family must match the address family of the policy selector. Subsequent transport mode templates must mach the address family of the previous template. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net_sched: red: Avoid illegal valuesNogah Frankel
[ Upstream commit 8afa10cbe281b10371fee5a87ab266e48d71a7f9 ] Check the qmin & qmax values doesn't overflow for the given Wlog value. Check that qmin <= qmax. Fixes: a783474591f2 ("[PKT_SCHED]: Generic RED layer") Signed-off-by: Nogah Frankel <nogahf@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25dn_getsockoptdecnet: move nf_{get/set}sockopt outside sock lockPaolo Abeni
commit dfec091439bb2acf763497cfc58f2bdfc67c56b7 upstream. After commit 3f34cfae1238 ("netfilter: on sockopt() acquire sock lock only in the required scope"), the caller of nf_{get/set}sockopt() must not hold any lock, but, in such changeset, I forgot to cope with DECnet. This commit addresses the issue moving the nf call outside the lock, in the dn_{get,set}sockopt() with the same schema currently used by ipv4 and ipv6. Also moves the unhandled sockopts of the end of the main switch statements, to improve code readability. Reported-by: Petr Vandrovec <petr@vandrovec.name> BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198791#c2 Fixes: 3f34cfae1238 ("netfilter: on sockopt() acquire sock lock only in the required scope") Signed-off-by: Paolo Abeni <pabeni@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25Make DST_CACHE a silent config optionDave Jones
commit 9b246841f4041f85265dec5f769c017fc36a0d33 upstream. commit 911362c70d ("net: add dst_cache support") added a new kconfig option that gets selected by other networking options. It seems the intent wasn't to offer this as a user-selectable option given the lack of help text, so this patch converts it to a silent option. Signed-off-by: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Paolo Abeni <pabeni@redhat.com> Cc: <manojboopathi@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net: avoid skb_warn_bad_offload on IS_ERRWillem de Bruijn
commit 8d74e9f88d65af8bb2e095aff506aa6eac755ada upstream. skb_warn_bad_offload warns when packets enter the GSO stack that require skb_checksum_help or vice versa. Do not warn on arbitrary bad packets. Packet sockets can craft many. Syzkaller was able to demonstrate another one with eth_type games. In particular, suppress the warning when segmentation returns an error, which is for reasons other than checksum offload. See also commit 36c92474498a ("net: WARN if skb_checksum_help() is called on skb requiring segmentation") for context on this warning. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netfilter: xt_RATEEST: acquire xt_rateest_mutex for hash insertCong Wang
commit 7dc68e98757a8eccf8ca7a53a29b896f1eef1f76 upstream. rateest_hash is supposed to be protected by xt_rateest_mutex, and, as suggested by Eric, lookup and insert should be atomic, so we should acquire the xt_rateest_mutex once for both. So introduce a non-locking helper for internal use and keep the locking one for external. Reported-by: <syzbot+5cb189720978275e4c75@syzkaller.appspotmail.com> Fixes: 5859034d7eb8 ("[NETFILTER]: x_tables: add RATEEST target") Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Reviewed-by: Florian Westphal <fw@strlen.de> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netfilter: on sockopt() acquire sock lock only in the required scopePaolo Abeni
commit 3f34cfae1238848fd53f25e5c8fd59da57901f4b upstream. Syzbot reported several deadlocks in the netfilter area caused by rtnl lock and socket lock being acquired with a different order on different code paths, leading to backtraces like the following one: ====================================================== WARNING: possible circular locking dependency detected 4.15.0-rc9+ #212 Not tainted ------------------------------------------------------ syzkaller041579/3682 is trying to acquire lock: (sk_lock-AF_INET6){+.+.}, at: [<000000008775e4dd>] lock_sock include/net/sock.h:1463 [inline] (sk_lock-AF_INET6){+.+.}, at: [<000000008775e4dd>] do_ipv6_setsockopt.isra.8+0x3c5/0x39d0 net/ipv6/ipv6_sockglue.c:167 but task is already holding lock: (rtnl_mutex){+.+.}, at: [<000000004342eaa9>] rtnl_lock+0x17/0x20 net/core/rtnetlink.c:74 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (rtnl_mutex){+.+.}: __mutex_lock_common kernel/locking/mutex.c:756 [inline] __mutex_lock+0x16f/0x1a80 kernel/locking/mutex.c:893 mutex_lock_nested+0x16/0x20 kernel/locking/mutex.c:908 rtnl_lock+0x17/0x20 net/core/rtnetlink.c:74 register_netdevice_notifier+0xad/0x860 net/core/dev.c:1607 tee_tg_check+0x1a0/0x280 net/netfilter/xt_TEE.c:106 xt_check_target+0x22c/0x7d0 net/netfilter/x_tables.c:845 check_target net/ipv6/netfilter/ip6_tables.c:538 [inline] find_check_entry.isra.7+0x935/0xcf0 net/ipv6/netfilter/ip6_tables.c:580 translate_table+0xf52/0x1690 net/ipv6/netfilter/ip6_tables.c:749 do_replace net/ipv6/netfilter/ip6_tables.c:1165 [inline] do_ip6t_set_ctl+0x370/0x5f0 net/ipv6/netfilter/ip6_tables.c:1691 nf_sockopt net/netfilter/nf_sockopt.c:106 [inline] nf_setsockopt+0x67/0xc0 net/netfilter/nf_sockopt.c:115 ipv6_setsockopt+0x115/0x150 net/ipv6/ipv6_sockglue.c:928 udpv6_setsockopt+0x45/0x80 net/ipv6/udp.c:1422 sock_common_setsockopt+0x95/0xd0 net/core/sock.c:2978 SYSC_setsockopt net/socket.c:1849 [inline] SyS_setsockopt+0x189/0x360 net/socket.c:1828 entry_SYSCALL_64_fastpath+0x29/0xa0 -> #0 (sk_lock-AF_INET6){+.+.}: lock_acquire+0x1d5/0x580 kernel/locking/lockdep.c:3914 lock_sock_nested+0xc2/0x110 net/core/sock.c:2780 lock_sock include/net/sock.h:1463 [inline] do_ipv6_setsockopt.isra.8+0x3c5/0x39d0 net/ipv6/ipv6_sockglue.c:167 ipv6_setsockopt+0xd7/0x150 net/ipv6/ipv6_sockglue.c:922 udpv6_setsockopt+0x45/0x80 net/ipv6/udp.c:1422 sock_common_setsockopt+0x95/0xd0 net/core/sock.c:2978 SYSC_setsockopt net/socket.c:1849 [inline] SyS_setsockopt+0x189/0x360 net/socket.c:1828 entry_SYSCALL_64_fastpath+0x29/0xa0 other info that might help us debug this: Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(rtnl_mutex); lock(sk_lock-AF_INET6); lock(rtnl_mutex); lock(sk_lock-AF_INET6); *** DEADLOCK *** 1 lock held by syzkaller041579/3682: #0: (rtnl_mutex){+.+.}, at: [<000000004342eaa9>] rtnl_lock+0x17/0x20 net/core/rtnetlink.c:74 The problem, as Florian noted, is that nf_setsockopt() is always called with the socket held, even if the lock itself is required only for very tight scopes and only for some operation. This patch addresses the issues moving the lock_sock() call only where really needed, namely in ipv*_getorigdst(), so that nf_setsockopt() does not need anymore to acquire both locks. Fixes: 22265a5c3c10 ("netfilter: xt_TEE: resolve oif using netdevice notifiers") Reported-by: syzbot+a4c2dc980ac1af699b36@syzkaller.appspotmail.com Suggested-by: Florian Westphal <fw@strlen.de> Signed-off-by: Paolo Abeni <pabeni@redhat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netfilter: ipt_CLUSTERIP: fix out-of-bounds accesses in clusterip_tg_check()Dmitry Vyukov
commit 1a38956cce5eabd7b74f94bab70265e4df83165e upstream. Commit 136e92bbec0a switched local_nodes from an array to a bitmask but did not add proper bounds checks. As the result clusterip_config_init_nodelist() can both over-read ipt_clusterip_tgt_info.local_nodes and over-write clusterip_config.local_nodes. Add bounds checks for both. Fixes: 136e92bbec0a ("[NETFILTER] CLUSTERIP: use a bitmap to store node responsibility data") Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netfilter: x_tables: avoid out-of-bounds reads in xt_request_find_{match|target}Eric Dumazet
commit da17c73b6eb74aad3c3c0654394635675b623b3e upstream. It looks like syzbot found its way into netfilter territory. Issue here is that @name comes from user space and might not be null terminated. Out-of-bound reads happen, KASAN is not happy. v2 added similar fix for xt_request_find_target(), as Florian advised. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25netfilter: x_tables: fix int overflow in xt_alloc_table_info()Dmitry Vyukov
commit 889c604fd0b5f6d3b8694ade229ee44124de1127 upstream. syzkaller triggered OOM kills by passing ipt_replace.size = -1 to IPT_SO_SET_REPLACE. The root cause is that SMP_ALIGN() in xt_alloc_table_info() causes int overflow and the size check passes when it should not. SMP_ALIGN() is no longer needed leftover. Remove SMP_ALIGN() call in xt_alloc_table_info(). Reported-by: syzbot+4396883fa8c4f64e0175@syzkaller.appspotmail.com Signed-off-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25xfrm: check id proto in validate_tmpl()Cong Wang
commit 6a53b7593233ab9e4f96873ebacc0f653a55c3e1 upstream. syzbot reported a kernel warning in xfrm_state_fini(), which indicates that we have entries left in the list net->xfrm.state_all whose proto is zero. And xfrm_id_proto_match() doesn't consider them as a match with IPSEC_PROTO_ANY in this case. Proto with value 0 is probably not a valid value, at least verify_newsa_info() doesn't consider it valid either. This patch fixes it by checking the proto value in validate_tmpl() and rejecting invalid ones, like what iproute2 does in xfrm_xfrmproto_getbyname(). Reported-by: syzbot <syzkaller@googlegroups.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25xfrm: Fix stack-out-of-bounds read on socket policy lookup.Steffen Klassert
commit ddc47e4404b58f03e98345398fb12d38fe291512 upstream. When we do tunnel or beet mode, we pass saddr and daddr from the template to xfrm_state_find(), this is ok. On transport mode, we pass the addresses from the flowi, assuming that the IP addresses (and address family) don't change during transformation. This assumption is wrong in the IPv4 mapped IPv6 case, packet is IPv4 and template is IPv6. Fix this by catching address family missmatches of the policy and the flow already before we do the lookup. Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25cfg80211: check dev_set_name() return valueJohannes Berg
commit 59b179b48ce2a6076448a44531242ac2b3f6cef2 upstream. syzbot reported a warning from rfkill_alloc(), and after a while I think that the reason is that it was doing fault injection and the dev_set_name() failed, leaving the name NULL, and we didn't check the return value and got to rfkill_alloc() with a NULL name. Since we really don't want a NULL name, we ought to check the return value. Fixes: fb28ad35906a ("net: struct device - replace bus_id with dev_name(), dev_set_name()") Reported-by: syzbot+1ddfb3357e1d7bb5b5d3@syzkaller.appspotmail.com Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net: replace dst_cache ip6_tunnel implementation with the generic onePaolo Abeni
commit 607f725f6f7d5ec3759fbc16224afb60e2152a5b upstream. This also fix a potential race into the existing tunnel code, which could lead to the wrong dst to be permanenty cached: CPU1: CPU2: <xmit on ip6_tunnel> <cache lookup fails> dst = ip6_route_output(...) <tunnel params are changed via nl> dst_cache_reset() // no effect, // the cache is empty dst_cache_set() // the wrong dst // is permanenty stored // into the cache With the new dst implementation the above race is not possible since the first cache lookup after dst_cache_reset will fail due to the timestamp check Signed-off-by: Paolo Abeni <pabeni@redhat.com> Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Manoj Boopathi Raj <manojboopathi@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25net: add dst_cache supportPaolo Abeni
commit 911362c70df5b766c243dc297fadeaced786ffd8 upstream. This patch add a generic, lockless dst cache implementation. The need for lock is avoided updating the dst cache fields only in per cpu scope, and requiring that the cache manipulation functions are invoked with the local bh disabled. The refresh_ts and reset_ts fields are used to ensure the cache consistency in case of cuncurrent cache update (dst_cache_set*) and reset operation (dst_cache_reset). Consider the following scenario: CPU1: CPU2: <cache lookup with emtpy cache: it fails> <get dst via uncached route lookup> <related configuration changes> dst_cache_reset() dst_cache_set() The dst entry set passed to dst_cache_set() should not be used for later dst cache lookup, because it's obtained using old configuration values. Since the refresh_ts is updated only on dst_cache lookup, the cached value in the above scenario will be discarded on the next lookup. Signed-off-by: Paolo Abeni <pabeni@redhat.com> Suggested-and-acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Manoj Boopathi Raj <manojboopathi@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16dccp: CVE-2017-8824: use-after-free in DCCP codeMohamed Ghannam
commit 69c64866ce072dea1d1e59a0d61e0f66c0dffb76 upstream. Whenever the sock object is in DCCP_CLOSED state, dccp_disconnect() must free dccps_hc_tx_ccid and dccps_hc_rx_ccid and set to NULL. Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16netfilter: nf_queue: Make the queue_handler pernetEric W. Biederman
commit dc3ee32e96d74dd6c80eed63af5065cb75899299 upstream. Florian Weber reported: > Under full load (unshare() in loop -> OOM conditions) we can > get kernel panic: > > BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 > IP: [<ffffffff81476c85>] nfqnl_nf_hook_drop+0x35/0x70 > [..] > task: ffff88012dfa3840 ti: ffff88012dffc000 task.ti: ffff88012dffc000 > RIP: 0010:[<ffffffff81476c85>] [<ffffffff81476c85>] nfqnl_nf_hook_drop+0x35/0x70 > RSP: 0000:ffff88012dfffd80 EFLAGS: 00010206 > RAX: 0000000000000008 RBX: ffffffff81add0c0 RCX: ffff88013fd80000 > [..] > Call Trace: > [<ffffffff81474d98>] nf_queue_nf_hook_drop+0x18/0x20 > [<ffffffff814738eb>] nf_unregister_net_hook+0xdb/0x150 > [<ffffffff8147398f>] netfilter_net_exit+0x2f/0x60 > [<ffffffff8141b088>] ops_exit_list.isra.4+0x38/0x60 > [<ffffffff8141b652>] setup_net+0xc2/0x120 > [<ffffffff8141bd09>] copy_net_ns+0x79/0x120 > [<ffffffff8106965b>] create_new_namespaces+0x11b/0x1e0 > [<ffffffff810698a7>] unshare_nsproxy_namespaces+0x57/0xa0 > [<ffffffff8104baa2>] SyS_unshare+0x1b2/0x340 > [<ffffffff81608276>] entry_SYSCALL_64_fastpath+0x1e/0xa8 > Code: 65 00 48 89 e5 41 56 41 55 41 54 53 83 e8 01 48 8b 97 70 12 00 00 48 98 49 89 f4 4c 8b 74 c2 18 4d 8d 6e 08 49 81 c6 88 00 00 00 <49> 8b 5d 00 48 85 db 74 1a 48 89 df 4c 89 e2 48 c7 c6 90 68 47 > The simple fix for this requires a new pernet variable for struct nf_queue that indicates when it is safe to use the dynamically allocated nf_queue state. As we need a variable anyway make nf_register_queue_handler and nf_unregister_queue_handler pernet. This allows the existing logic of when it is safe to use the state from the nfnetlink_queue module to be reused with no changes except for making it per net. The syncrhonize_rcu from nf_unregister_queue_handler is moved to a new function nfnl_queue_net_exit_batch so that the worst case of having a syncrhonize_rcu in the pernet exit path is not experienced in batch mode. Reported-by: Florian Westphal <fw@strlen.de> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16tcp: release sk_frag.page in tcp_disconnectLi RongQing
[ Upstream commit 9b42d55a66d388e4dd5550107df051a9637564fc ] socket can be disconnected and gets transformed back to a listening socket, if sk_frag.page is not released, which will be cloned into a new socket by sk_clone_lock, but the reference count of this page is increased, lead to a use after free or double free issue Signed-off-by: Li RongQing <lirongqing@baidu.com> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16net: igmp: add a missing rcu locking sectionEric Dumazet
[ Upstream commit e7aadb27a5415e8125834b84a74477bfbee4eff5 ] Newly added igmpv3_get_srcaddr() needs to be called under rcu lock. Timer callbacks do not ensure this locking. ============================= WARNING: suspicious RCU usage 4.15.0+ #200 Not tainted ----------------------------- ./include/linux/inetdevice.h:216 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 2, debug_locks = 1 3 locks held by syzkaller616973/4074: #0: (&mm->mmap_sem){++++}, at: [<00000000bfce669e>] __do_page_fault+0x32d/0xc90 arch/x86/mm/fault.c:1355 #1: ((&im->timer)){+.-.}, at: [<00000000619d2f71>] lockdep_copy_map include/linux/lockdep.h:178 [inline] #1: ((&im->timer)){+.-.}, at: [<00000000619d2f71>] call_timer_fn+0x1c6/0x820 kernel/time/timer.c:1316 #2: (&(&im->lock)->rlock){+.-.}, at: [<000000005f833c5c>] spin_lock_bh include/linux/spinlock.h:315 [inline] #2: (&(&im->lock)->rlock){+.-.}, at: [<000000005f833c5c>] igmpv3_send_report+0x98/0x5b0 net/ipv4/igmp.c:600 stack backtrace: CPU: 0 PID: 4074 Comm: syzkaller616973 Not tainted 4.15.0+ #200 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: <IRQ> __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 lockdep_rcu_suspicious+0x123/0x170 kernel/locking/lockdep.c:4592 __in_dev_get_rcu include/linux/inetdevice.h:216 [inline] igmpv3_get_srcaddr net/ipv4/igmp.c:329 [inline] igmpv3_newpack+0xeef/0x12e0 net/ipv4/igmp.c:389 add_grhead.isra.27+0x235/0x300 net/ipv4/igmp.c:432 add_grec+0xbd3/0x1170 net/ipv4/igmp.c:565 igmpv3_send_report+0xd5/0x5b0 net/ipv4/igmp.c:605 igmp_send_report+0xc43/0x1050 net/ipv4/igmp.c:722 igmp_timer_expire+0x322/0x5c0 net/ipv4/igmp.c:831 call_timer_fn+0x228/0x820 kernel/time/timer.c:1326 expire_timers kernel/time/timer.c:1363 [inline] __run_timers+0x7ee/0xb70 kernel/time/timer.c:1666 run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692 __do_softirq+0x2d7/0xb85 kernel/softirq.c:285 invoke_softirq kernel/softirq.c:365 [inline] irq_exit+0x1cc/0x200 kernel/softirq.c:405 exiting_irq arch/x86/include/asm/apic.h:541 [inline] smp_apic_timer_interrupt+0x16b/0x700 arch/x86/kernel/apic/apic.c:1052 apic_timer_interrupt+0xa9/0xb0 arch/x86/entry/entry_64.S:938 Fixes: a46182b00290 ("net: igmp: Use correct source address on IGMPv3 reports") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-16ip6mr: fix stale iteratorNikolay Aleksandrov
[ Upstream commit 4adfa79fc254efb7b0eb3cd58f62c2c3f805f1ba ] When we dump the ip6mr mfc entries via proc, we initialize an iterator with the table to dump but we don't clear the cache pointer which might be initialized from a prior read on the same descriptor that ended. This can result in lock imbalance (an unnecessary unlock) leading to other crashes and hangs. Clear the cache pointer like ipmr does to fix the issue. Thanks for the reliable reproducer. Here's syzbot's trace: WARNING: bad unlock balance detected! 4.15.0-rc3+ #128 Not tainted syzkaller971460/3195 is trying to release lock (mrt_lock) at: [<000000006898068d>] ipmr_mfc_seq_stop+0xe1/0x130 net/ipv6/ip6mr.c:553 but there are no more locks to release! other info that might help us debug this: 1 lock held by syzkaller971460/3195: #0: (&p->lock){+.+.}, at: [<00000000744a6565>] seq_read+0xd5/0x13d0 fs/seq_file.c:165 stack backtrace: CPU: 1 PID: 3195 Comm: syzkaller971460 Not tainted 4.15.0-rc3+ #128 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 print_unlock_imbalance_bug+0x12f/0x140 kernel/locking/lockdep.c:3561 __lock_release kernel/locking/lockdep.c:3775 [inline] lock_release+0x5f9/0xda0 kernel/locking/lockdep.c:4023 __raw_read_unlock include/linux/rwlock_api_smp.h:225 [inline] _raw_read_unlock+0x1a/0x30 kernel/locking/spinlock.c:255 ipmr_mfc_seq_stop+0xe1/0x130 net/ipv6/ip6mr.c:553 traverse+0x3bc/0xa00 fs/seq_file.c:135 seq_read+0x96a/0x13d0 fs/seq_file.c:189 proc_reg_read+0xef/0x170 fs/proc/inode.c:217 do_loop_readv_writev fs/read_write.c:673 [inline] do_iter_read+0x3db/0x5b0 fs/read_write.c:897 compat_readv+0x1bf/0x270 fs/read_write.c:1140 do_compat_preadv64+0xdc/0x100 fs/read_write.c:1189 C_SYSC_preadv fs/read_write.c:1209 [inline] compat_SyS_preadv+0x3b/0x50 fs/read_write.c:1203 do_syscall_32_irqs_on arch/x86/entry/common.c:327 [inline] do_fast_syscall_32+0x3ee/0xf9d arch/x86/entry/common.c:389 entry_SYSENTER_compat+0x51/0x60 arch/x86/entry/entry_64_compat.S:125 RIP: 0023:0xf7f73c79 RSP: 002b:00000000e574a15c EFLAGS: 00000292 ORIG_RAX: 000000000000014d RAX: ffffffffffffffda RBX: 000000000000000f RCX: 0000000020a3afb0 RDX: 0000000000000001 RSI: 0000000000000067 RDI: 0000000000000000 RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 BUG: sleeping function called from invalid context at lib/usercopy.c:25 in_atomic(): 1, irqs_disabled(): 0, pid: 3195, name: syzkaller971460 INFO: lockdep is turned off. CPU: 1 PID: 3195 Comm: syzkaller971460 Not tainted 4.15.0-rc3+ #128 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 ___might_sleep+0x2b2/0x470 kernel/sched/core.c:6060 __might_sleep+0x95/0x190 kernel/sched/core.c:6013 __might_fault+0xab/0x1d0 mm/memory.c:4525 _copy_to_user+0x2c/0xc0 lib/usercopy.c:25 copy_to_user include/linux/uaccess.h:155 [inline] seq_read+0xcb4/0x13d0 fs/seq_file.c:279 proc_reg_read+0xef/0x170 fs/proc/inode.c:217 do_loop_readv_writev fs/read_write.c:673 [inline] do_iter_read+0x3db/0x5b0 fs/read_write.c:897 compat_readv+0x1bf/0x270 fs/read_write.c:1140 do_compat_preadv64+0xdc/0x100 fs/read_write.c:1189 C_SYSC_preadv fs/read_write.c:1209 [inline] compat_SyS_preadv+0x3b/0x50 fs/read_write.c:1203 do_syscall_32_irqs_on arch/x86/entry/common.c:327 [inline] do_fast_syscall_32+0x3ee/0xf9d arch/x86/entry/common.c:389 entry_SYSENTER_compat+0x51/0x60 arch/x86/entry/entry_64_compat.S:125 RIP: 0023:0xf7f73c79 RSP: 002b:00000000e574a15c EFLAGS: 00000292 ORIG_RAX: 000000000000014d RAX: ffffffffffffffda RBX: 000000000000000f RCX: 0000000020a3afb0 RDX: 0000000000000001 RSI: 0000000000000067 RDI: 0000000000000000 RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 WARNING: CPU: 1 PID: 3195 at lib/usercopy.c:26 _copy_to_user+0xb5/0xc0 lib/usercopy.c:26 Reported-by: syzbot <bot+eceb3204562c41a438fa1f2335e0fe4f6886d669@syzkaller.appspotmail.com> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03SUNRPC: Allow connect to return EHOSTUNREACHTrond Myklebust
[ Upstream commit 4ba161a793d5f43757c35feff258d9f20a082940 ] Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03mac80211: fix the update of path metric for RANN frameChun-Yeow Yeoh
[ Upstream commit fbbdad5edf0bb59786a51b94a9d006bc8c2da9a2 ] The previous path metric update from RANN frame has not considered the own link metric toward the transmitting mesh STA. Fix this. Reported-by: Michael65535 Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03openvswitch: fix the incorrect flow action alloc sizezhangliping
[ Upstream commit 67c8d22a73128ff910e2287567132530abcf5b71 ] If we want to add a datapath flow, which has more than 500 vxlan outputs' action, we will get the following error reports: openvswitch: netlink: Flow action size 32832 bytes exceeds max openvswitch: netlink: Flow action size 32832 bytes exceeds max openvswitch: netlink: Actions may not be safe on all matching packets ... ... It seems that we can simply enlarge the MAX_ACTIONS_BUFSIZE to fix it, but this is not the root cause. For example, for a vxlan output action, we need about 60 bytes for the nlattr, but after it is converted to the flow action, it only occupies 24 bytes. This means that we can still support more than 1000 vxlan output actions for a single datapath flow under the the current 32k max limitation. So even if the nla_len(attr) is larger than MAX_ACTIONS_BUFSIZE, we shouldn't report EINVAL and keep it move on, as the judgement can be done by the reserve_sfa_size. Signed-off-by: zhangliping <zhangliping02@baidu.com> Acked-by: Pravin B Shelar <pshelar@ovn.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03bpf: fix 32-bit divide by zeroAlexei Starovoitov
[ upstream commit 68fda450a7df51cff9e5a4d4a4d9d0d5f2589153 ] due to some JITs doing if (src_reg == 0) check in 64-bit mode for div/mod operations mask upper 32-bits of src register before doing the check Fixes: 622582786c9e ("net: filter: x86: internal BPF JIT") Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.") Reported-by: syzbot+48340bb518e88849e2e3@syzkaller.appspotmail.com Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03bpf: introduce BPF_JIT_ALWAYS_ON configAlexei Starovoitov
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ] The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715. A quote from goolge project zero blog: "At this point, it would normally be necessary to locate gadgets in the host kernel code that can be used to actually leak data by reading from an attacker-controlled location, shifting and masking the result appropriately and then using the result of that as offset to an attacker-controlled address for a load. But piecing gadgets together and figuring out which ones work in a speculation context seems annoying. So instead, we decided to use the eBPF interpreter, which is built into the host kernel - while there is no legitimate way to invoke it from inside a VM, the presence of the code in the host kernel's text section is sufficient to make it usable for the attack, just like with ordinary ROP gadgets." To make attacker job harder introduce BPF_JIT_ALWAYS_ON config option that removes interpreter from the kernel in favor of JIT-only mode. So far eBPF JIT is supported by: x64, arm64, arm32, sparc64, s390, powerpc64, mips64 The start of JITed program is randomized and code page is marked as read-only. In addition "constant blinding" can be turned on with net.core.bpf_jit_harden v2->v3: - move __bpf_prog_ret0 under ifdef (Daniel) v1->v2: - fix init order, test_bpf and cBPF (Daniel's feedback) - fix offloaded bpf (Jakub's feedback) - add 'return 0' dummy in case something can invoke prog->bpf_func - retarget bpf tree. For bpf-next the patch would need one extra hunk. It will be sent when the trees are merged back to net-next Considered doing: int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT; but it seems better to land the patch as-is and in bpf-next remove bpf_jit_enable global variable from all JITs, consolidate in one place and remove this jit_init() function. Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31net: tcp: close sock if net namespace is exitingDan Streetman
[ Upstream commit 4ee806d51176ba7b8ff1efd81f271d7252e03a1d ] When a tcp socket is closed, if it detects that its net namespace is exiting, close immediately and do not wait for FIN sequence. For normal sockets, a reference is taken to their net namespace, so it will never exit while the socket is open. However, kernel sockets do not take a reference to their net namespace, so it may begin exiting while the kernel socket is still open. In this case if the kernel socket is a tcp socket, it will stay open trying to complete its close sequence. The sock's dst(s) hold a reference to their interface, which are all transferred to the namespace's loopback interface when the real interfaces are taken down. When the namespace tries to take down its loopback interface, it hangs waiting for all references to the loopback interface to release, which results in messages like: unregister_netdevice: waiting for lo to become free. Usage count = 1 These messages continue until the socket finally times out and closes. Since the net namespace cleanup holds the net_mutex while calling its registered pernet callbacks, any new net namespace initialization is blocked until the current net namespace finishes exiting. After this change, the tcp socket notices the exiting net namespace, and closes immediately, releasing its dst(s) and their reference to the loopback interface, which lets the net namespace continue exiting. Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1711407 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=97811 Signed-off-by: Dan Streetman <ddstreet@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31flow_dissector: properly cap thoff fieldEric Dumazet
[ Upstream commit d0c081b49137cd3200f2023c0875723be66e7ce5 ] syzbot reported yet another crash [1] that is caused by insufficient validation of DODGY packets. Two bugs are happening here to trigger the crash. 1) Flow dissection leaves with incorrect thoff field. 2) skb_probe_transport_header() sets transport header to this invalid thoff, even if pointing after skb valid data. 3) qdisc_pkt_len_init() reads out-of-bound data because it trusts tcp_hdrlen(skb) Possible fixes : - Full flow dissector validation before injecting bad DODGY packets in the stack. This approach was attempted here : https://patchwork.ozlabs.org/patch/ 861874/ - Have more robust functions in the core. This might be needed anyway for stable versions. This patch fixes the flow dissection issue. [1] CPU: 1 PID: 3144 Comm: syzkaller271204 Not tainted 4.15.0-rc4-mm1+ #49 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:17 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:53 print_address_description+0x73/0x250 mm/kasan/report.c:256 kasan_report_error mm/kasan/report.c:355 [inline] kasan_report+0x23b/0x360 mm/kasan/report.c:413 __asan_report_load2_noabort+0x14/0x20 mm/kasan/report.c:432 __tcp_hdrlen include/linux/tcp.h:35 [inline] tcp_hdrlen include/linux/tcp.h:40 [inline] qdisc_pkt_len_init net/core/dev.c:3160 [inline] __dev_queue_xmit+0x20d3/0x2200 net/core/dev.c:3465 dev_queue_xmit+0x17/0x20 net/core/dev.c:3554 packet_snd net/packet/af_packet.c:2943 [inline] packet_sendmsg+0x3ad5/0x60a0 net/packet/af_packet.c:2968 sock_sendmsg_nosec net/socket.c:628 [inline] sock_sendmsg+0xca/0x110 net/socket.c:638 sock_write_iter+0x31a/0x5d0 net/socket.c:907 call_write_iter include/linux/fs.h:1776 [inline] new_sync_write fs/read_write.c:469 [inline] __vfs_write+0x684/0x970 fs/read_write.c:482 vfs_write+0x189/0x510 fs/read_write.c:544 SYSC_write fs/read_write.c:589 [inline] SyS_write+0xef/0x220 fs/read_write.c:581 entry_SYSCALL_64_fastpath+0x1f/0x96 Fixes: 34fad54c2537 ("net: __skb_flow_dissect() must cap its return value") Fixes: a6e544b0a88b ("flow_dissector: Jump to exit code in __skb_flow_dissect") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
