[ Upstream commit a6f79d0f26704214b5b702bbac525cb72997f984 ]
PPPoL2TP sockets should comply with the standard send*() return values
(i.e. return number of bytes sent instead of 0 upon success).
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 55b92b7a11690bc377b5d373872a6b650ae88e64 ]
Copy user data after PPP framing header. This prevents erasure of the
added PPP header and avoids leaking two bytes of uninitialised memory
at the end of skb's data buffer.
[ Upstream commit 2dc85bf323515e59e15dfa858d1472bb25cad0fe ]
uaddr->sa_data is exactly of size 14, which is hard-coded here and
passed as a size argument to strncpy(). A device name can be of size
IFNAMSIZ (== 16), meaning we might leave the destination string
unterminated. Thus, use strlcpy() and also sizeof() while we're
at it. We need to memset the data area beforehand, since strlcpy
does not padd the remaining buffer with zeroes for user space, so
that we do not possibly leak anything.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 1abd165ed757db1afdefaac0a4bc8a70f97d258c ]
While stress testing sctp sockets, I hit the following panic:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
PGD 7cead067 PUD 7ce76067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: sctp(F) libcrc32c(F) [...]
CPU: 7 PID: 2950 Comm: acc Tainted: GF 3.10.0-rc2+ #1
Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
task: ffff88007ce0e0c0 ti: ffff88007b568000 task.ti: ffff88007b568000
RIP: 0010:[<ffffffffa0490c4e>] [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP: 0018:ffff88007b569e08 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff88007db78a00 RCX: dead000000200200
RDX: ffffffffa049fdb0 RSI: ffff8800379baf38 RDI: 0000000000000000
RBP: ffff88007b569e18 R08: ffff88007c230da0 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff880077990d00 R14: 0000000000000084 R15: ffff88007db78a00
FS: 00007fc18ab61700(0000) GS:ffff88007fc60000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000020 CR3: 000000007cf9d000 CR4: 00000000000007e0
Stack:
ffff88007b569e38 ffff88007db78a00 ffff88007b569e38 ffffffffa049fded
ffffffff81abf0c0 ffff88007db78a00 ffff88007b569e58 ffffffff8145b60e
0000000000000000 0000000000000000 ffff88007b569eb8 ffffffff814df36e
Call Trace:
[<ffffffffa049fded>] sctp_destroy_sock+0x3d/0x80 [sctp]
[<ffffffff8145b60e>] sk_common_release+0x1e/0xf0
[<ffffffff814df36e>] inet_create+0x2ae/0x350
[<ffffffff81455a6f>] __sock_create+0x11f/0x240
[<ffffffff81455bf0>] sock_create+0x30/0x40
[<ffffffff8145696c>] SyS_socket+0x4c/0xc0
[<ffffffff815403be>] ? do_page_fault+0xe/0x10
[<ffffffff8153cb32>] ? page_fault+0x22/0x30
[<ffffffff81544e02>] system_call_fastpath+0x16/0x1b
Code: 0c c9 c3 66 2e 0f 1f 84 00 00 00 00 00 e8 fb fe ff ff c9 c3 66 0f
1f 84 00 00 00 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 <48>
8b 47 20 48 89 fb c6 47 1c 01 c6 40 12 07 e8 9e 68 01 00 48
RIP [<ffffffffa0490c4e>] sctp_endpoint_free+0xe/0x40 [sctp]
RSP <ffff88007b569e08>
---[ end trace e0d71ec1108c1dd9 ]---
I did not hit this with the lksctp-tools functional tests, but with a
small, multi-threaded test program, that heavily allocates, binds,
listens and waits in accept on sctp sockets, and then randomly kills
some of them (no need for an actual client in this case to hit this).
Then, again, allocating, binding, etc, and then killing child processes.
This panic then only occurs when ``echo 1 > /proc/sys/net/sctp/auth_enable''
is set. The cause for that is actually very simple: in sctp_endpoint_init()
we enter the path of sctp_auth_init_hmacs(). There, we try to allocate
our crypto transforms through crypto_alloc_hash(). In our scenario,
it then can happen that crypto_alloc_hash() fails with -EINTR from
crypto_larval_wait(), thus we bail out and release the socket via
sk_common_release(), sctp_destroy_sock() and hit the NULL pointer
dereference as soon as we try to access members in the endpoint during
sctp_endpoint_free(), since endpoint at that time is still NULL. Now,
if we have that case, we do not need to do any cleanup work and just
leave the destruction handler.
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 534c877928a16ae5f9776436a497109639bf67dc ]
Commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f
"net IPv6 : Fix broken IPv6 routing table after loopback down-up"
forgot to assign rt6_info to the inet6_ifaddr.
When disable the net device, the rt6_info which allocated
in init_loopback will not be destroied in __ipv6_ifa_notify.
This will trigger the waring message below
[23527.916091] unregister_netdevice: waiting for tap0 to become free. Usage count = 1
Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com>
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and
a7526eb5d06b0084ef12d7b168d008fcf516caab ]
MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API --
it's a hack that steals a bit to indicate to other networking code
that a compat entry was used. So don't allow it from a non-compat
syscall.
This prevents an oops when running this code:
int main()
int s;
struct sockaddr_in addr;
struct msghdr *hdr;
char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096,
PROT_READ | PROT_WRITE,
MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0);
if (highpage == MAP_FAILED)
err(1, "mmap");
s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
if (s == -1)
err(1, "socket");
addr.sin_family = AF_INET;
addr.sin_port = htons(1);
addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK);
if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0)
err(1, "connect");
void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE;
printf("Evil address is %p\n", evil);
if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0)
err(1, "sendmmsg");
return 0;
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit a622260254ee481747cceaaa8609985b29a31565 ]
Daniel Petre reported crashes in icmp_dst_unreach() with following call
graph:
Daniel found a similar problem mentioned in
http://lkml.indiana.edu/hypermail/linux/kernel/1007.0/00961.html
And indeed this is the root cause : skb->cb[] contains data fooling IP
stack.
We must clear IPCB in ip_tunnel_xmit() sooner in case dst_link_failure()
is called. Or else skb->cb[] might contain garbage from GSO segmentation
layer.
A similar fix was tested on linux-3.9, but gre code was refactored in
linux-3.10. I'll send patches for stable kernels as well.
Many thanks to Daniel for providing reports, patches and testing !
Reported-by: Daniel Petre <daniel.petre@rcs-rds.ro>
[ Upstream commit 547669d483e5783d722772af1483fa474da7caf9 ]
commit 3853b5841c01a ("xps: Improvements in TX queue selection")
introduced ooo_okay flag, but the condition to set it is slightly wrong.
In our traces, we have seen ACK packets being received out of order,
and RST packets sent in response.
We should test if we have any packets still in host queue.
Cc: Tom Herbert <therbert@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 6b21e1b77d1a3d58ebfd513264c885695e8a0ba5 ]
The net/netlabel/netlabel_domainhash.c:netlbl_domhsh_add() function
does not properly validate new domain hash entries resulting in
potential problems when an administrator attempts to add an invalid
entry. One such problem, as reported by Vlad Halilov, is a kernel
BUG (found in netlabel_domainhash.c:netlbl_domhsh_audit_add()) when
adding an IPv6 outbound mapping with a CIPSO configuration.
This patch corrects this problem by adding the necessary validation
code to netlbl_domhsh_add() via the newly created
netlbl_domhsh_validate() function.
Ideally this patch should also be pushed to the currently active
-stable trees.
Reported-by: Vlad Halilov <vlad.halilov@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commit 284041ef21fdf2e0d216ab6b787bc9072b4eb58a ]
commit 0178b695fd6b4 ("ipv6: Copy cork options in ip6_append_data")
added some code duplication and bad error recovery, leading to potential
crash in ip6_cork_release() as kfree() could be called with garbage.
use kzalloc() to make sure this wont happen.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
[ Upstream commit 54d27fcb338bd9c42d1dfc5a39e18f6f9d373c2e ]
TCP md5 communications fail [1] for some devices, because sg/crypto code
assume page offsets are below PAGE_SIZE.
This was discovered using mlx4 driver [2], but I suspect loopback
might trigger the same bug now we use order-3 pages in tcp_sendmsg()
[1] Failure is giving following messages.
huh, entered softirq 3 NET_RX ffffffff806ad230 preempt_count 00000100,
exited with 00000101?
[2] mlx4 driver uses order-2 pages to allocate RX frags
Reported-by: Matt Schnall <mischnal@google.com>
Cc: Bernhard Beck <bbeck@google.com>
commit cb3b3152b2f5939d67005cff841a1ca748b19888 upstream.
There has been code in place to check that the L2CAP length header
matches the amount of data received, but many PDU handlers have not been
checking that the data received actually matches that expected by the
specific PDU. This patch adds passing the length header to the specific
handler functions and ensures that those functions fail cleanly in the
case of an incorrect amount of data.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
[bwh: Backported to 3.2:
- Adjust context
- Move uses of *req below the new check in l2cap_connect_req]
commit c8aa22db0112f640ac6631347f850879c621840b upstream.
Since Eric's commit efe117ab8 ("Speedup ieee80211_remove_interfaces")
there's a bug in mac80211 when it unregisters with AP_VLAN interfaces
up. If the AP_VLAN interface was registered after the AP it belongs
to (which is the typical case) and then we get into this code path,
unregister_netdevice_many() will crash because it isn't prepared to
deal with interfaces being closed in the middle of it. Exactly this
happens though, because we iterate the list, find the AP master this
AP_VLAN belongs to and dev_close() the dependent VLANs. After this,
unregister_netdevice_many() won't pick up the fact that the AP_VLAN
is already down and will do it again, causing a crash.
commit c815797663b72e3ac1736f1886538152bc48e4af upstream.
If a P2P-Device is present and another virtual interface triggers
the connection work, the system crash because it tries to check
if the P2P-Device's netdev (which doesn't exist) is up. Skip any
wdevs that have no netdev to fix this.
Reported-by: YanBo <dreamfly281@gmail.com>
[bwh: Backported to 3.2: adjust context]
[ Upstream commit 84c4a9dfbf430861e7588d95ae3ff61535dca351 ]
We forget to call dev_put() on error path in xfrm6_fill_dst(),
its caller doesn't handle this.
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ]
We have seen multiple NULL dereferences in __inet6_lookup_established()
After analysis, I found that inet6_sk() could be NULL while the
check for sk_family == AF_INET6 was true.
Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP
and TCP stacks.
Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash
table, we no longer can clear pinet6 field.
This patch extends logic used in commit fcbdf09d9652c891
("net: fix nulls list corruptions in sk_prot_alloc")
TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method
to make sure we do not clear pinet6 field.
At socket clone phase, we do not really care, as cloning the parent (non
NULL) pinet6 is not adding a fatal race.
[ Upstream commit 8da3056c04bfc5f69f840ab038a38389e2de8189 ]
Jakub reported that it is fairly easy to trigger the BUG() macro
from user space with TPACKET_V3's RX_RING by just giving a wrong
header status flag. We already had a similar situation in commit
7f5c3e3a80e6654 (``af_packet: remove BUG statement in
tpacket_destruct_skb'') where this was the case in the TX_RING
side that could be triggered from user space. So really, don't use
BUG() or BUG_ON() unless there's really no way out, and i.e.
don't use it for consistency checking when there's user space
involved, no excuses, especially not if you're slapping the user
with WARN + dump_stack + BUG all at once. The two functions are
of concern:
prb_retire_current_block() [when block status != TP_STATUS_KERNEL]
prb_open_block() [when block_status != TP_STATUS_KERNEL]
Calls to prb_open_block() are guarded by ealier checks if block_status
is really TP_STATUS_KERNEL (racy!), but the first one BUG() is easily
triggable from user space. System behaves still stable after they are
removed. Also remove that yoda condition entirely, since it's already
guarded.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
[ Upstream commit 83401eb4990ff6af55aeed8f49681558544192e6 ]
A bridge should only send topology change notice if it is not
the root bridge. It is possible for message age timer to elect itself
as a new root bridge, and still have a topology change timer running
but waiting for bridge lock on other CPU.
Solve the race by checking if we are root bridge before continuing.
This was the root cause of the cases where br_send_tcn_bpdu would OOPS.
Reported-by: JerryKang <jerry.kang@samsung.com>
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 0dcffd09641f3abb21ac5cabc61542ab289d1a3c ]
Deal with changes in newer xtables while maintaining backward
compatibility. Thanks to Jan Engelhardt for suggestions.
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
commit f7a1dd6e3ad59f0cfd51da29dfdbfd54122c5916 upstream.
The reason for this patch is crash in kmemdup
caused by returning from get_callid with uniialized
matchoff and matchlen.
Removing Zero check of matchlen since it's done by ct_sip_get_header()
BUG: unable to handle kernel paging request at ffff880457b5763f
IP: [<ffffffff810df7fc>] kmemdup+0x2e/0x35
PGD 27f6067 PUD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: xt_state xt_helper nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_mangle xt_connmark xt_conntrack ip6_tables nf_conntrack_ftp ip_vs_ftp nf_nat xt_tcpudp iptable_mangle xt_mark ip_tables x_tables ip_vs_rr ip_vs_lblcr ip_vs_pe_sip ip_vs nf_conntrack_sip nf_conntrack bonding igb i2c_algo_bit i2c_core
CPU 5
Pid: 0, comm: swapper/5 Not tainted 3.9.0-rc5+ #5 /S1200KP
RIP: 0010:[<ffffffff810df7fc>] [<ffffffff810df7fc>] kmemdup+0x2e/0x35
RSP: 0018:ffff8803fea03648 EFLAGS: 00010282
RAX: ffff8803d61063e0 RBX: 0000000000000003 RCX: 0000000000000003
RDX: 0000000000000003 RSI: ffff880457b5763f RDI: ffff8803d61063e0
RBP: ffff8803fea03658 R08: 0000000000000008 R09: 0000000000000011
R10: 0000000000000011 R11: 00ffffffff81a8a3 R12: ffff880457b5763f
R13: ffff8803d67f786a R14: ffff8803fea03730 R15: ffffffffa0098e90
FS: 0000000000000000(0000) GS:ffff8803fea00000(0000) knlGS:0000000000000000
CR2: ffff880457b5763f CR3: 0000000001a0c000 CR4: 00000000001407e0
Process swapper/5 (pid: 0, threadinfo ffff8803ee18c000, task ffff8803ee18a480)
Stack:
ffff8803d822a080 000000000000001c ffff8803fea036c8 ffffffffa000937a
ffffffff81f0d8a0 000000038135fdd5 ffff880300000014 ffff880300110000
ffffffff150118ac ffff8803d7e8a000 ffff88031e0118ac 0000000000000000
Call Trace:
<IRQ>
[<ffffffffa000937a>] ip_vs_sip_fill_param+0x13a/0x187 [ip_vs_pe_sip]
[<ffffffffa007b209>] ip_vs_sched_persist+0x2c6/0x9c3 [ip_vs]
[<ffffffff8107dc53>] ? __lock_acquire+0x677/0x1697
[<ffffffff8100972e>] ? native_sched_clock+0x3c/0x7d
[<ffffffff810649bc>] ? sched_clock_cpu+0x43/0xcf
[<ffffffffa007bb1e>] ip_vs_schedule+0x181/0x4ba [ip_vs]
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
commit a3c3cac5d31879cd9ae2de7874dc6544ca704aec upstream.
The lockless RPC_IS_QUEUED() test in __rpc_execute means that we need to
be careful about ordering the calls to rpc_test_and_set_running(task) and
rpc_clear_queued(task). If we get the order wrong, then we may end up
testing the RPC_TASK_RUNNING flag after __rpc_execute() has looped
and changed the state of the rpc_task.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 506026c3ec270e18402f0c9d33fee37482c23861 upstream.
rpc_make_runnable is not generally called with the queue lock held, unless
it's waking up a task that has been sitting on a waitqueue. This is safe
when the task has not entered the FSM yet, but the comments don't really
spell this out.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
[ Upstream commit 97599dc792b45b1669c3cdb9a4b365aad0232f65 ]
Commit 4a94445c9a5c (net: Use ip_route_input_noref() in input path)
added a bug in IP defragmentation handling, as non refcounted
dst could escape an RCU protected section.
Commit 64f3b9e203bd068 (net: ip_expire() must revalidate route) fixed
the case of timeouts, but not the general problem.
Tom Parkin noticed crashes in UDP stack and provided a patch,
but further analysis permitted us to pinpoint the root cause.
Before queueing a packet into a frag list, we must drop its dst,
as this dst has limited lifetime (RCU protected)
When/if a packet is finally reassembled, we use the dst of the very
last skb, still protected by RCU and valid, as the dst of the
reassembled packet.
Use same logic in IPv6, as there is no need to hold dst references.
Reported-by: Tom Parkin <tparkin@katalix.com>
Tested-by: Tom Parkin <tparkin@katalix.com>
[ Upstream commit c802d759623acbd6e1ee9fbdabae89159a513913 ]
sizeof() when applied to a pointer typed expression gives the size of the
pointer, not that of the pointed data.
Introduced by commit 3ce5ef(netrom: fix info leak via msg_name in nr_recvmsg)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
[ Upstream commit 60085c3d009b0df252547adb336d1ccca5ce52ec ]
The code in set_orig_addr() does not initialize all of the members of
struct sockaddr_tipc when filling the sockaddr info -- namely the union
is only partly filled. This will make recv_msg() and recv_stream() --
the only users of this function -- leak kernel stack memory as the
msg_name member is a local variable in net/socket.c.
Additionally to that both recv_msg() and recv_stream() fail to update
the msg_namelen member to 0 while otherwise returning with 0, i.e.
"success". This is the case for, e.g., non-blocking sockets. This will
lead to a 128 byte kernel stack leak in net/socket.c.
Fix the first issue by initializing the memory of the union with
memset(0). Fix the second one by setting msg_namelen to 0 early as it
will be updated later if we're going to fill the msg_name member.
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Allan Stephens <allan.stephens@windriver.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
[ Upstream commit 4a184233f21645cf0b719366210ed445d1024d72 ]
The code in rose_recvmsg() does not initialize all of the members of
struct sockaddr_rose/full_sockaddr_rose when filling the sockaddr info.
Nor does it initialize the padding bytes of the structure inserted by
the compiler for alignment. This will lead to leaking uninitialized
kernel stack bytes in net/socket.c.
Fix the issue by initializing the memory used for sockaddr info with
memset(0).
[ Upstream commits 3ce5efad47b62c57a4f5c54248347085a750ce0e and
In case msg_name is set the sockaddr info gets filled out, as
requested, but the code fails to initialize the padding bytes of
struct sockaddr_ax25 inserted by the compiler for alignment. Also
the sax25_ndigis member does not get assigned, leaking four more
bytes.
Both issues lead to the fact that the code will leak uninitialized
Fix both issues by initializing the memory with memset(0).
[ Upstream commit c77a4b9cffb6215a15196ec499490d116dfad181 ]
For stream sockets the code misses to update the msg_namelen member
to 0 and therefore makes net/socket.c leak the local, uninitialized
sockaddr_storage variable to userland -- 128 bytes of kernel stack
memory. The msg_namelen update is also missing for datagram sockets
in case the socket is shutting down during receive.
Fix both issues by setting msg_namelen to 0 early. It will be
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
[ Upstream commit a5598bd9c087dc0efc250a5221e5d0e6f584ee88 ]
The current code does not fill the msg_name member in case it is set.
It also does not set the msg_namelen member to 0 and therefore makes
net/socket.c leak the local, uninitialized sockaddr_storage variable
to userland -- 128 bytes of kernel stack memory.
Fix that by simply setting msg_namelen to 0 as obviously nobody cared
about iucv_sock_recvmsg() not filling the msg_name in case it was set.
Cc: Ursula Braun <ursula.braun@de.ibm.com>
[ Upstream commit 5ae94c0d2f0bed41d6718be743985d61b7f5c47d ]
about irda_recvmsg_dgram() not filling the msg_name in case it was
set.
Cc: Samuel Ortiz <samuel@sortiz.org>
[ Upstream commit 2d6fbfe733f35c6b355c216644e08e149c61b271 ]
about caif_seqpkt_recvmsg() not filling the msg_name in case it was
set.
Cc: Sjur Braendeland <sjur.brandeland@stericsson.com>
[ Upstream commit e11e0455c0d7d3d62276a0c55d9dfbc16779d691 ]
If RFCOMM_DEFER_SETUP is set in the flags, rfcomm_sock_recvmsg() returns
early with 0 without updating the possibly set msg_namelen member. This,
in turn, leads to a 128 byte kernel stack leak in net/socket.c.
Fix this by updating msg_namelen in this case. For all other cases it
will be handled in bt_sock_stream_recvmsg().
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
[ Upstream commit 4683f42fde3977bdb4e8a09622788cc8b5313778 ]
In case the socket is already shutting down, bt_sock_recvmsg() returns
with 0 without updating msg_namelen leading to net/socket.c leaking the
local, uninitialized sockaddr_storage variable to userland -- 128 bytes
Fix this by moving the msg_namelen assignment in front of the shutdown
test.
[ Upstream commit ef3313e84acbf349caecae942ab3ab731471f1a1 ]
When msg_namelen is non-zero the sockaddr info gets filled out, as
requested, but the code fails to initialize the padding bytes of struct
sockaddr_ax25 inserted by the compiler for alignment. Additionally the
msg_namelen value is updated to sizeof(struct full_sockaddr_ax25) but is
not always filled up to this size.
[ Upstream commit 9b3e617f3df53822345a8573b6d358f6b9e5ed87 ]
about vcc_recvmsg() not filling the msg_name in case it was set.
[ Upstream commit 12fb3dd9dc3c64ba7d64cec977cca9b5fb7b1d4e ]
commit bd090dfc634d (tcp: tcp_replace_ts_recent() should not be called
from tcp_validate_incoming()) introduced a TS ecr bug in slow path
processing.
1 A > B P. 1:10001(10000) ack 1 <nop,nop,TS val 1001 ecr 200>
2 B < A . 1:1(0) ack 1 win 257 <sack 9001:10001,TS val 300 ecr 1001>
3 A > B . 1:1001(1000) ack 1 win 227 <nop,nop,TS val 1002 ecr 200>
4 A > B . 1001:2001(1000) ack 1 win 227 <nop,nop,TS val 1002 ecr 200>
(ecr 200 should be ecr 300 in packets 3 & 4)
Problem is tcp_ack() can trigger send of new packets (retransmits),
reflecting the prior TSval, instead of the TSval contained in the
currently processed incoming packet.
Fix this by calling tcp_replace_ts_recent() from tcp_ack() after the
checks, but before the actions.
Reported-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 586c31f3bf04c290dc0a0de7fc91d20aa9a5ee53 ]
For sensitive data like keying material, it is common practice to zero
out keys before returning the memory back to the allocator. Thus, use
kzfree instead of kfree.
[ Upstream commit 06848c10f720cbc20e3b784c0df24930b7304b93 ]
Fix to return a negative error code from the error handling
case instead of 0, as returned elsewhere in this function.
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit d66954a066158781ccf9c13c91d0316970fe57b6 ]
There is a bug in cookie_v4_check (net/ipv4/syncookies.c):
flowi4_init_output(&fl4, 0, sk->sk_mark, RT_CONN_FLAGS(sk),
RT_SCOPE_UNIVERSE, IPPROTO_TCP,
inet_sk_flowi_flags(sk),
(opt && opt->srr) ? opt->faddr : ireq->rmt_addr,
ireq->loc_addr, th->source, th->dest);
Here we do not respect sk->sk_bound_dev_if, therefore wrong dst_entry may be
taken. This dst_entry is used by new socket (get_cookie_sock ->
tcp_v4_syn_recv_sock), so its packets may take the wrong path.
Signed-off-by: Dmitry Popov <dp@highloadlab.com>
[ Upstream commit 88c5b5ce5cb57af6ca2a7cf4d5715fa320448ff9 ]
Signed-off-by: Michael Riesch <michael.riesch@omicron.at>
Cc: Jiri Benc <jbenc@redhat.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Acked-by: Mark Rustad <mark.d.rustad@intel.com>
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ]
Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code
to reset nf_trace in nf_reset(). This is wrong and unnecessary.
nf_reset() is used in the following cases:
- when passing packets up the the socket layer, at which point we want to
release all netfilter references that might keep modules pinned while
the packet is queued. nf_trace doesn't matter anymore at this point.
- when encapsulating or decapsulating IPsec packets. We want to continue
tracing these packets after IPsec processing.
- when passing packets through virtual network devices. Only devices on
that encapsulate in IPv4/v6 matter since otherwise nf_trace is not
used anymore. Its not entirely clear whether those packets should
be traced after that, however we've always done that.
- when passing packets through virtual network devices that make the
packet cross network namespace boundaries. This is the only cases
where we clearly want to reset nf_trace and is also what the
original patch intended to fix.
Add a new function nf_reset_trace() and use it in dev_forward_skb() to
fix this properly.
[ Upstream commit 0e82e7f6dfeec1013339612f74abc2cdd29d43d2 ]
It was reported that the following LSB test case failed
https://lsbbugs.linuxfoundation.org/attachment.cgi?id=2144 because we
were not coallescing unix stream messages when the application was
expecting us to.
The problem was that the first send was before the socket was accepted
and thus sock->sk_socket was NULL in maybe_add_creds, and the second
send after the socket was accepted had a non-NULL value for sk->socket
and thus we could tell the credentials were not needed so we did not
bother.
The unnecessary credentials on the first message cause
unix_stream_recvmsg to start verifying that all messages had the same
credentials before coallescing and then the coallescing failed because
the second message had no credentials.
Ignoring credentials when we don't care in unix_stream_recvmsg fixes a
long standing pessimization which would fail to coallesce messages when
reading from a unix stream socket if the senders were different even if
we did not care about their credentials.
I have tested this and verified that the in the LSB test case mentioned
above that the messages do coallesce now, while the were failing to
coallesce without this change.
Reported-by: Karel Srot <ksrot@redhat.com>
Reported-by: Ding Tianhong <dingtianhong@huawei.com>
[ Upstream commit 4543fbefe6e06a9e40d9f2b28d688393a299f079 ]
A few drivers use dev_uc_sync/unsync to synchronize the
address lists from master down to slave/lower devices. In
some cases (bond/team) a single address list is synched down
to multiple devices. At the time of unsync, we have a leak
in these lower devices, because "synced" is treated as a
boolean and the address will not be unsynced for anything after
the first device/call.
Treat "synced" as a count (same as refcount) and allow all
unsync calls to work.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 25fb6ca4ed9cad72f14f61629b68dc03c0d9713f ]
IPv6 Routing table becomes broken once we do ifdown, ifup of the loopback(lo)
interface. After down-up, routes of other interface's IPv6 addresses through
'lo' are lost.
IPv6 addresses assigned to all interfaces are routed through 'lo' for internal
communication. Once 'lo' is down, those routing entries are removed from routing
table. But those removed entries are not being re-created properly when 'lo' is
brought up. So IPv6 addresses of other interfaces becomes unreachable from the
same machine. Also this breaks communication with other machines because of
NDISC packet processing failure.
This patch fixes this issue by reading all interface's IPv6 addresses and adding
them to IPv6 routing table while bringing up 'lo'.
==Testing==
Before applying the patch:
$ route -A inet6
Kernel IPv6 routing table
Destination Next Hop Flag Met Ref Use If
2000::20/128 :: U 256 0 0 eth0
fe80::/64 :: U 256 0 0 eth0
::/0 :: !n -1 1 1 lo
::1/128 :: Un 0 1 0 lo
2000::20/128 :: Un 0 1 0 lo
fe80::xxxx:xxxx:xxxx:xxxx/128 :: Un 0 1 0 lo
ff00::/8 :: U 256 0 0 eth0
$ sudo ifdown lo
$ sudo ifup lo
$ route -A inet6
After applying the patch:
$ route -A inet6
Kernel IPv6 routing
table
$ sudo ifdown lo
$ sudo ifup lo
$ route -A inet6
Signed-off-by: Balakumaran Kannan <Balakumaran.Kannan@ap.sony.com>
Signed-off-by: Maruthi Thotad <Maruthi.Thotad@ap.sony.com>
[ Upstream commit f0f6ee1f70c4eaab9d52cf7d255df4bd89f8d1c2 ]
currently cbq works incorrectly for limits > 10% real link bandwidth,
and practically does not work for limits > 50% real link bandwidth.
Below are results of experiments taken on 1 Gbit link
In shaper | Actual Result
100M | 108 Mbps
200M | 244 Mbps
300M | 412 Mbps
500M | 893 Mbps
This happen because of q->now changes incorrectly in cbq_dequeue():
when it is called before real end of packet transmitting,
L2T is greater than real time delay, q_now gets an extra boost
but never compensate it.
To fix this problem we prevent change of q->now until its synchronization
with real time.
Signed-off-by: Vasily Averin <vvs@openvz.org>
Reviewed-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
commit 990de49f74e772b6db5208457b7aa712a5f4db86 upstream.
When a full scan 2.4 and 5 GHz scan is scheduled, but then the 2.4 GHz
part of the scan disables a 5.2 GHz channel due to, e.g. receiving
country or frequency information, that 5.2 GHz channel might already
be in the list of channels to scan next. Then, when the driver checks
if it should do a passive scan, that will return false and attempt an
active scan. This is not only wrong but can also lead to the iwlwifi
device firmware crashing since it checks regulatory as well.
Fix this by not setting the channel flags to just disabled but rather
OR'ing in the disabled flag. That way, even if the race happens, the
channel will be scanned passively which is still (mostly) correct.
commit 83f1b4ba917db5dc5a061a44b3403ddb6e783494 upstream.
Commit 257b5358b32f ("scm: Capture the full credentials of the scm
sender") changed the credentials passing code to pass in the effective
uid/gid instead of the real uid/gid.
Obviously this doesn't matter most of the time (since normally they are
the same), but it results in differences for suid binaries when the wrong
uid/gid ends up being used.
This just undoes that (presumably unintentional) part of the commit.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[bwh: Backported to 3.2: scm_set_cred() does user namespace conversion
of euid/egid using cred_to_ucred(). Add and use cred_real_to_ucred() to
do the same thing for real uid/gid.]
commit 3480a2125923e4b7a56d79efc76743089bf273fc upstream.
Memory allocated by kmem_cache_alloc() should be freed using
kmem_cache_free(), not kfree().
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit 00cfec37484761a44a3b6f4675a54caa618210ae ]
commit 35d48903e97819 (bonding: fix rx_handler locking) added a race
in bonding driver, reported by Steven Rostedt who did a very good
diagnosis :
<quoting Steven>
I'm currently debugging a crash in an old 3.0-rt kernel that one of our
customers is seeing. The bug happens with a stress test that loads and
unloads the bonding module in a loop (I don't know all the details as
I'm not the one that is directly interacting with the customer). But the
bug looks to be something that may still be present and possibly present
in mainline too. It will just be much harder to trigger it in mainline.
In -rt, interrupts are threads, and can schedule in and out just like
any other thread. Note, mainline now supports interrupt threads so this
may be easily reproducible in mainline as well. I don't have the ability
to tell the customer to try mainline or other kernels, so my hands are
somewhat tied to what I can do.
But according to a core dump, I tracked down that the eth irq thread
crashed in bond_handle_frame() here:
slave = bond_slave_get_rcu(skb->dev);
bond = slave->bond; <--- BUG
the slave returned was NULL and accessing slave->bond caused a NULL
pointer dereference.
Looking at the code that unregisters the handler:
void netdev_rx_handler_unregister(struct net_device *dev)
ASSERT_RTNL();
RCU_INIT_POINTER(dev->rx_handler, NULL);
RCU_INIT_POINTER(dev->rx_handler_data, NULL);
Which is basically:
dev->rx_handler = NULL;
dev->rx_handler_data = NULL;
And looking at __netif_receive_skb() we have:
rx_handler = rcu_dereference(skb->dev->rx_handler);
if (rx_handler) {
if (pt_prev) {
ret = deliver_skb(skb, pt_prev, orig_dev);
pt_prev = NULL;
switch (rx_handler(&skb)) {
My question to all of you is, what stops this interrupt from happening
while the bonding module is unloading? What happens if the interrupt
triggers and we have this:
CPU0 CPU1
rx_handler = skb->dev->rx_handler
netdev_rx_handler_unregister() {
rx_handler()
bond_handle_frame() {
slave = skb->dev->rx_handler;
bond = slave->bond; <-- NULL pointer dereference!!!
What protection am I missing in the bond release handler that would
prevent the above from happening?
</quoting Steven>
We can fix bug this in two ways. First is adding a test in
bond_handle_frame() and others to check if rx_handler_data is NULL.
A second way is adding a synchronize_net() in
netdev_rx_handler_unregister() to make sure that a rcu protected reader
has the guarantee to see a non NULL rx_handler_data.
The second way is better as it avoids an extra test in fast path.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Paul E. McKenney <paulmck@us.ibm.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
[ Upstream commit 1c4a154e5253687c51123956dfcee9e9dfa8542d ]
Erik Hugne's errata proposal (Errata ID: 3480) to RFC4291 has been
verified: http://www.rfc-editor.org/errata_search.php?eid=3480
We have to check for pkt_type and loopback flag because either the
packets are allowed to travel over the loopback interface (in which case
pkt_type is PACKET_HOST and IFF_LOOPBACK flag is set) or they travel
over a non-loopback interface back to us (in which case PACKET_TYPE is
PACKET_LOOPBACK and IFF_LOOPBACK flag is not set).
Cc: Erik Hugne <erik.hugne@ericsson.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
