This reverts commit c79c5ffdce14abb4de3878c5aa8c3c6e5093c69b.
As Jeff points out we can't break the user visible interface
like this, we need to add this into the reserved[] thing.
Clients will set their MTU to 1280 if they receive a
ICMPV6_PKT_TOOBIG message with an MTU less than 1280.
To allow encapsulating of packets over a 1280 link
we should always accept packets with a size of 1280
for forwarding even if the path has a lower MTU and
fragment the encapsulated packets afterwards.
In case a forwarded packet is not going to be encapsulated
a ICMPV6_PKT_TOOBIG msg will still be send by ip6_fragment()
with the correct MTU.
Signed-off-by: Ulrich Weber <uweber@astaro.com>
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
The drvinfo struct should include the number of strings that
get_rx_ntuple will return. It will be variable if an underlying
driver implements its own get_rx_ntuple routine, so userspace
needs to know how much data is coming.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
Use list_first_entry macro; no longer any need to use
'next' directly in list to find first entry.
This patch consists of a few minor cleanups to the SR-IOV
configurion code in rtnetlink.
- Remove unneccesary lock
- Remove unneccesary casts
- Return correct error code for no driver support
These changes are based on comments from Patrick McHardy
Signed-off-by: Mitch Williams <mitch.a.williams@intel.com>
packet_mc_add()
There is no point of accepting an address of smaller length than dev->addr_len
here. Therefore change this for stonger check.
RFC 4291 section 2.4 states that all uncategorized addresses
should be considered as Global Unicast.
This will remove IPV6_ADDR_RESERVED completely
and return IPV6_ADDR_UNICAST in ipv6_addr_type() instead.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/net/wireless/rt2x00/rt2800pci.c
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (41 commits)
HID: usbhid: initialize interface pointers early enough
HID: extend mask for BUTTON usage page
HID: hid-ntrig: Single touch mode tap
HID: hid-ntrig: multitouch cleanup and fix
HID: n-trig: remove unnecessary tool switching
HID: hid-ntrig add multi input quirk and clean up
HID: usbhid: introduce timeout for stuck ctrl/out URBs
HID: magicmouse: coding style and probe failure fixes
HID: remove MODULE_VERSION from new drivers
HID: fix up Kconfig entry for MagicMouse
HID: add a device driver for the Apple Magic Mouse.
HID: Export hid_register_report
HID: Support for MosArt multitouch panel
HID: add pressure support for the Stantum multitouch panel
HID: fixed bug in single-touch emulation on the stantum panel
HID: fix typo in error message
HID: add mapping for "AL Network Chat" usage
HID: use multi input quirk for TouchPack touchscreen
HID: make full-fledged hid-bus drivers properly selectable
HID: make Wacom modesetting failures non-fatal
Update rcu_dereference() primitives to use new lockdep-based
checking. The rcu_dereference() in __in6_dev_get() may be
protected either by rcu_read_lock() or RTNL, per Eric Dumazet.
The rcu_dereference() in __sk_free() is protected by the fact
that it is never reached if an update could change it. Check
for this by using rcu_dereference_check() to verify that the
struct sock's ->sk_wmem_alloc counter is zero.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-5-git-send-email-paulmck@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
Just pass in the entire repl struct. In case of a new table (e.g.
ip6t_register_table), the repldata has been previously filled with
table->name and table->size already (in ip6t_alloc_initial_table).
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
The macro is replaced by a list.h-like foreach loop. This makes
the code more inspectable.
the code much more inspectable.
Traffic (tcp) doesnot start on a vlan interface when gro is enabled.
Even the tcp handshake was not taking place.
This is because, the eth_type_trans call before the netif_receive_skb
in napi_gro_finish() resets the skb->dev to napi->dev from the previously
set vlan netdev interface. This causes the ip_route_input to drop the
incoming packet considering it as a packet coming from a martian source.
I could repro this on 2.6.32.7 (stable) and 2.6.33-rc7.
With this fix, the traffic starts and the test runs fine on both vlan
and non-vlan interfaces.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Patrick McHardy <kaber@trash.net>
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
When we clone the SP, we should also clone the mark.
Useful for socket based SPs.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
A rule with a zero hit_count will always match.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: stable@kernel.org
e->index overflows e->stamps[] every ip_pkt_list_tot packets.
Consider the case when ip_pkt_list_tot==1; the first packet received is stored
in e->stamps[0] and e->index is initialized to 1. The next received packet
timestamp is then stored at e->stamps[1] in recent_entry_update(),
a buffer overflow because the maximum e->stamps[] index is 0.
Add ability for netlink userspace to manipulate the SPD
and manipulate the mark, retrieve it and get events with a defined
mark, etc.
Add ability for netlink userspace to manipulate the SAD
mark.
MIGRATE may be added later.
Allow mark to be used when doing SP lookup
pass mark to all SP lookups to prepare them for when we add code
to have them search.
Allow mark to be added to the SA lookup
pass mark to all SA lookups to prepare them for when we add code
Get rid of custom locking that was using wait queue, lock, and atomic
to basically build a queued mutex. Use RCU for read side.
Convert AF_PACKET to use RCU, eliminating one more reader/writer lock.
There is no need for a real sk_del_node_init_rcu(), because sk_del_node_init
is doing the equivalent thing to hlst_del_init_rcu already; but added
some comments to try and make that obvious.
The wireless sysfs methods like the rest of the networking sysfs
methods are removed with the rtnl_lock held and block until
the existing methods stop executing. So use rtnl_trylock
and restart_syscall so that the code continues to work.
Yuck. It turns out that when we restart sysctls we were restarting
with the values already changed. Which unfortunately meant that
the second time through we thought there was no change and skipped
all kinds of work, despite the fact that there was indeed a change.
I have fixed this the simplest way possible by restoring the changed
values when we restart the sysctl write.
One of my coworkers spotted this bug when after disabling forwarding
on an interface pings were still forwarded.
To see the effect make sure you have an empty SPD.
On window1 "ip xfrm mon" and on window2 issue "ip xfrm policy flush"
You get prompt back in window2 and you see the flush event on window1.
With this fix, you still get prompt on window1 but no event on window2.
Thanks to Alexey Dobriyan for finding a bug in earlier version
when using pfkey to do the flushing.
To see the effect make sure you have an empty SAD.
On window1 "ip xfrm mon" and on window2 issue "ip xfrm state flush"
RFC 2367 says flushing behavior should be:
1) user space -> kernel: flush
2) kernel: flush
3) kernel -> user space: flush event to ALL listeners
This is not realistic today in the presence of selinux policies
which may reject the flush etc. So we make the sequence become:
2) kernel: flush
3) kernel -> user space: flush response to originater from #1
4) if there were no errors then:
The most needed command from nl80211, which Wireless Extensions had,
is support for power save mode. Add a simple command to make it possible
to enable and disable power save via nl80211.
I was also planning about extending the interface, for example adding the
timeout value, but after thinking more about this I decided not to do it.
Basically there were three reasons:
Firstly, the parameters for power save are very much hardware dependent.
Trying to find a unified interface which would work with all hardware, and
still make sense to users, will be very difficult.
Secondly, IEEE 802.11 power save implementation in Linux is still in state
of flux. We have a long way to still to go and there is no way to predict
what kind of implementation we will have after few years. And because we
need to support nl80211 interface a long time, practically forever, adding
now parameters to nl80211 might create maintenance problems later on.
Third issue are the users. Power save parameters are mostly used for
debugging, so debugfs is better, more flexible, interface for this.
For example, wpa_supplicant currently doesn't configure anything related
to power save mode. It's better to strive that kernel can automatically
optimise the power save parameters, like with help of pm qos network
and other traffic parameters.
Later on, when we have better understanding of power save, we can extend
this command with more features, if there's a need for that.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
single fragment
When an ICMPV6_PKT_TOOBIG message is received with a MTU below 1280,
all further packets include a fragment header.
Unlike regular defragmentation, conntrack also needs to "reassemble"
those fragments in order to obtain a packet without the fragment
header for connection tracking. Currently nf_conntrack_reasm checks
whether a fragment has either IP6_MF set or an offset != 0, which
makes it ignore those fragments.
Remove the invalid check and make reassembly handle fragment queues
containing only a single fragment.
Reported-and-tested-by: Ulrich Weber <uweber@astaro.com>
commit 3bc38712e3a6e059 (handle NF_STOP and unknown verdicts in
nf_reinject) was a partial fix to packet leaks.
If user asks NF_STOLEN status, we must free the skb as well.
Reported-by: Afi Gjermund <afigjermund@gmail.com>
Signed-off-by: Eric DUmazet <eric.dumazet@gmail.com>
This patch fixes a bug that triggers an assertion if you create
a conntrack entry with a helper and netfilter debugging is enabled.
Basically, we hit the assertion because the confirmation flag is
set before the conntrack extensions are added. To fix this, we
move the extension addition before the aforementioned flag is
set.
This patch also removes the possibility of setting a helper for
existing conntracks. This operation would also trigger the
assertion since we are not allowed to add new extensions for
existing conntracks. We know noone that could benefit from
this operation sanely.
Thanks to Eric Dumazet for initial posting a preliminary patch
to address this issue.
Reported-by: David Ramblewski <David.Ramblewski@atosorigin.com>
XFRMINHDRERROR counter is ambigous when validating forwarding
path. It makes it tricky to debug when you have both in and fwd
validation.
This patch enables fast retransmissions after one dupACK for
TCP if the stream is identified as thin. This will reduce
latencies for thin streams that are not able to trigger fast
retransmissions due to high packet interarrival time. This
mechanism is only active if enabled by iocontrol or syscontrol
and the stream is identified as thin.
Signed-off-by: Andreas Petlund <apetlund@simula.no>
This patch will make TCP use only linear timeouts if the
stream is thin. This will help to avoid the very high latencies
that thin stream suffer because of exponential backoff. This
and the stream is identified as thin. A maximum of 6 linear
timeouts is tried before exponential backoff is resumed.
Make remaining netlink policies as const.
Fixup coding style where needed.
Dunno, what was the idea, it wasn't used for a long time.
ICMP6 MIB statistics was per-netns for quite a time.
The lock used in unix_state_lock() is a spin_lock not reader-writer.
As reported by Randy Dunlap <randy.dunlap@oracle.com>, compilation
of nf_defrag_ipv4 fails with:
include/net/netfilter/nf_conntrack.h:94: error: field 'ct_general' has incomplete type
include/net/netfilter/nf_conntrack.h:178: error: 'const struct sk_buff' has no member named 'nfct'
include/net/netfilter/nf_conntrack.h:185: error: implicit declaration of function 'nf_conntrack_put'
include/net/netfilter/nf_conntrack.h:294: error: 'const struct sk_buff' has no member named 'nfct'
net/ipv4/netfilter/nf_defrag_ipv4.c:45: error: 'struct sk_buff' has no member named 'nfct'
net/ipv4/netfilter/nf_defrag_ipv4.c:46: error: 'struct sk_buff' has no member named 'nfct'
net/nf_conntrack.h must not be included with NF_CONNTRACK=n, add a
few #ifdefs. Long term the header file should be fixed to be usable
even with NF_CONNTRACK=n.
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Enhance IPVS to load balance SCTP transport protocol packets. This is done
based on the SCTP rfc 4960. All possible control chunks have been taken
care. The state machine used in this code looks some what lengthy. I tried
to make the state machine easy to understand.
Signed-off-by: Venkata Mohan Reddy Koppula <mohanreddykv@gmail.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
