[ Upstream commit c0ed1c14a72ca9ebacd51fb94a8aca488b0d361e ]
flow_cach_flush() might sleep but can be called from
atomic context via the xfrm garbage collector. So add
a flow_cache_flush_deferred() function and use this if
the xfrm garbage colector is invoked from within the
packet path.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Timo Teräs <timo.teras@iki.fi>
[ Upstream commit a76c0adf60f6ca5ff3481992e4ea0383776b24d2 ]
When checking whether a DATA chunk fits into the estimated rwnd a
full sizeof(struct sk_buff) is added to the needed chunk size. This
quickly exhausts the available rwnd space and leads to packets being
sent which are much below the PMTU limit. This can lead to much worse
performance.
The reason for this behaviour was to avoid putting too much memory
pressure on the receiver. The concept is not completely irational
because a Linux receiver does in fact clone an skb for each DATA chunk
delivered. However, Linux also reserves half the available socket
buffer space for data structures therefore usage of it is already
accounted for.
When proposing to change this the last time it was noted that this
behaviour was introduced to solve a performance issue caused by rwnd
overusage in combination with small DATA chunks.
Trying to reproduce this I found that with the sk_buff overhead removed,
the performance would improve significantly unless socket buffer limits
are increased.
The following numbers have been gathered using a patched iperf
supporting SCTP over a live 1 Gbit ethernet network. The -l option
was used to limit DATA chunk sizes. The numbers listed are based on
the average of 3 test runs each. Default values have been used for
sk_(r|w)mem.
Chunk
Size Unpatched No Overhead
4 15.2 Kbit [!] 12.2 Mbit [!]
8 35.8 Kbit [!] 26.0 Mbit [!]
16 95.5 Kbit [!] 54.4 Mbit [!]
32 106.7 Mbit 102.3 Mbit
64 189.2 Mbit 188.3 Mbit
128 331.2 Mbit 334.8 Mbit
256 537.7 Mbit 536.0 Mbit
512 766.9 Mbit 766.6 Mbit
1024 810.1 Mbit 808.6 Mbit
Signed-off-by: Thomas Graf <tgraf@redhat.com>
[ Upstream commit 2692ba61a82203404abd7dd2a027bda962861f74 ]
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
[ Upstream commit 3f1e6d3fd37bd4f25e5b19f1c7ca21850426c33f ]
gred_change_vq() is called under sch_tree_lock(sch).
This means a spinlock is held, and we are not allowed to sleep in this
context.
We might pre-allocate memory using GFP_KERNEL before taking spinlock,
but this is not suitable for stable material.
[ Upstream commit cd7816d14953c8af910af5bb92f488b0b277e29d ]
previous commit 3fb72f1e6e6165c5f495e8dc11c5bbd14c73385c
makes IP-Config wait for carrier on at least one network device.
Before waiting (predefined value 120s), check that at least one device
was successfully brought up. Otherwise (e.g. buggy bootloader
which does not set the MAC address) there is no point in waiting
for carrier.
Cc: Micha Nelissen <micha@neli.hopto.org>
Cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
[ Upstream commit 7838f2ce36b6ab5c13ef20b1857e3bbd567f1759 ]
Userspace may not provide TCA_OPTIONS, in fact tc currently does
so not do so if no arguments are specified on the command line.
Return EINVAL instead of panicing.
[ Upstream commit 9cef310fcdee12b49b8b4c96fd8f611c8873d284 ]
Received non stream protocol packets were calling llc_cmsg_rcv that used a
skb after that skb was released by sk_eat_skb. This caused received STP
packets to generate kernel panics.
Signed-off-by: Alexandru Juncu <ajuncu@ixiacom.com>
Signed-off-by: Kunjan Naik <knaik@ixiacom.com>
commit c25573b5134294c0be82bfaecc6d08136835b271 upstream.
Whenever we free a slot, we know that the resulting xprt->num_reqs will
be less than xprt->max_reqs, so we know that we can release at least one
backlogged rpc_task.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 15062e6a8524f5977f2cbdf6e3eb2f144262f74e upstream.
Emmanuel noticed that when mac80211 stops the queues
for aggregation that can leave a packet pending. This
packet will be given to the driver after the AMPDU
callback, but as a non-aggregated packet which messes
up the sequence number etc.
I also noticed by looking at the code that if packets
are being processed while we clear the WANT_START bit,
they might see it cleared already and queue up on
tid_tx->pending. If the driver then rejects the new
aggregation session we leak the packet.
Fix both of these issues by changing this code to not
stop the queues at all. Instead, let packets queue up
on the tid_tx->pending queue instead of letting them
get to the driver, and add code to recover properly
in case the driver rejects the session.
(The patch looks large because it has to move two
functions to before their new use.)
Reported-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 72b36015ba43a3cca5303f5534d2c3e1899eae29 upstream.
Same fix as 731abb9cb2 for ipip and sit tunnel.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in
ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice
will now create a valid name, however the tunnel keeps a copy of the
name in the private parms structure. Fix this by copying the name back
after register_netdevice has successfully returned.
This shows up if you do a simple tunnel add, followed by a tunnel show:
$ sudo ip tunnel add mode ipip remote 10.2.20.211
$ ip tunnel
tunl0: ip/ip remote any local any ttl inherit nopmtudisc
tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit
$ sudo ip tunnel add mode sit remote 10.2.20.212
$ ip tunnel
sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16
sit%d: ioctl 89f8 failed: No such device
sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit
Signed-off-by: Ted Feng <artisdom@gmail.com>
[ Upstream commit 1ee5fa1e9970a16036e37c7b9d5ce81c778252fc ]
Le mercredi 30 novembre 2011 à 14:36 -0800, Stephen Hemminger a écrit :
> (Almost) nobody uses RED because they can't figure it out.
> According to Wikipedia, VJ says that:
> "there are not one, but two bugs in classic RED."
RED is useful for high throughput routers, I doubt many linux machines
act as such devices.
I was considering adding Adaptative RED (Sally Floyd, Ramakrishna
Gummadi, Scott Shender), August 2001
In this version, maxp is dynamic (from 1% to 50%), and user only have to
setup min_th (target average queue size)
(max_th and wq (burst in linux RED) are automatically setup)
By the way it seems we have a small bug in red_change()
if (skb_queue_empty(&sch->q))
red_end_of_idle_period(&q->parms);
First, if queue is empty, we should call
red_start_of_idle_period(&q->parms);
Second, since we dont use anymore sch->q, but q->qdisc, the test is
meaningless.
Oh well...
[PATCH] sch_red: fix red_change()
Now RED is classful, we must check q->qdisc->q.qlen, and if queue is empty,
we start an idle period, not end it.
[ Upstream commit f61759e6b831a55b89e584b198c3da325e2bc379 ]
__mkroute_output fails to work with the original tos
and uses value with stripped RTO_ONLINK bit. Make sure we put
the original TOS bits into rt_key_tos because it used to match
cached route.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit efbc368dcc6426d5430b9b8eeda944cf2cb74b8c,
incorporating a follow-on change to prevent an OOPS ]
Otherwise we won't notice the peer GENID change.
Reported-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit de68dca1816660b0d3ac89fa59ffb410007a143f ]
Now inetpeer is the place where we cache redirect information for ipv4
destinations, we must be able to invalidate informations when a route is
added/removed on host.
As inetpeer is not yet namespace aware, this patch adds a shared
redirect_genid, and a per inetpeer redirect_genid. This might be changed
later if inetpeer becomes ns aware.
Cache information for one inerpeer is valid as long as its
redirect_genid has the same value than global redirect_genid.
Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
[ Upstream commit 9cc20b268a5a14f5e57b8ad405a83513ab0d78dc ]
commit f39925dbde77 (ipv4: Cache learned redirect information in
inetpeer.) introduced a regression in ICMP redirect handling.
It assumed ipv4_dst_check() would be called because all possible routes
were attached to the inetpeer we modify in ip_rt_redirect(), but thats
not true.
commit 7cc9150ebe (route: fix ICMP redirect validation) tried to fix
this but solution was not complete. (It fixed only one route)
So we must lookup existing routes (including different TOS values) and
call check_peer_redir() on them.
Reported-by: Ivan Zahariev <famzah@icdsoft.com>
CC: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 7cc9150ebe8ec06cafea9f1c10d92ddacf88d8ae ]
The commit f39925dbde7788cfb96419c0f092b086aa325c0f
(ipv4: Cache learned redirect information in inetpeer.)
removed some ICMP packet validations which are required by
RFC 1122, section 3.2.2.2:
A Redirect message SHOULD be silently discarded if the new
gateway address it specifies is not on the same connected
(sub-) net through which the Redirect arrived [INTRO:2,
Appendix A], or if the source of the Redirect is not the
current first-hop gateway for the specified destination (see
Section 3.3.1).
Signed-off-by: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 59445b6b1f90b97c4e28062b96306bacfa4fb170 ]
In func ipv4_dst_check,check_peer_pmtu should be called only when peer is updated.
So,if the peer is not updated in ip_rt_frag_needed,we can not inc __rt_peer_genid.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit f7e57044eeb1841847c24aa06766c8290c202583 ]
We need rcu_read_lock() protection before using dst_get_neighbour(), and
we must cache its value (pass it to __teql_resolve())
teql_master_xmit() is called under rcu_read_lock_bh() protection, its
not enough.
[ Upstream commit 218fa90f072e4aeff9003d57e390857f4f35513e ]
After commit f2c31e32b378 (fix NULL dereferences in check_peer_redir()),
dst_get_neighbour() should be guarded by rcu_read_lock() /
rcu_read_unlock() section.
Reported-by: Miles Lane <miles.lane@gmail.com>
[ Upstream commit b12f62efb8ec0b9523bdb6c2d412c07193086de9 ]
When opt->srr_is_hit is set skb_rtable(skb) has been updated for
'nexthop' and iph->daddr should always equals to skb_rtable->rt_dst
holds, We need update iph->daddr either.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
[ Upstream commit b7ea81a58adc123a4e980cb0eff9eb5c144b5dc7 ]
The AH4/6 ahash input callbacks read out the nexthdr field from the AH
header *after* they overwrite that header. This is obviously not going
to end well. Fix it up.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
[ Upstream commit 069294e813ed5f27f82613b027609bcda5f1b914 ]
The AH4/6 ahash output callbacks pass nexthdr to xfrm_output_resume
instead of the error code. This appears to be a copy+paste error from
the input case, where nexthdr is expected. This causes the driver to
continuously add AH headers to the datagram until either an allocation
fails and the packet is dropped or the ahash driver hits a synchronous
fallback and the resulting monstrosity is transmitted.
Correct this issue by simply passing the error code unadulterated.
commit 0bac71af6e66dc798bf07d0c0dd14ee5503362f9 upstream.
Johannes' patch for "cfg80211: fix regulatory NULL dereference"
broke user regulaotry hints and it did not address the fact that
last_request was left populated even if the previous regulatory
hint was stale due to the wiphy disappearing.
Fix user reguluatory hints by only bailing out if for those
regulatory hints where a request_wiphy is expected. The stale last_request
considerations are addressed through the previous fixes on last_request
where we reset the last_request to a static world regdom request upon
reset_regdomains(). In this case though we further enhance the effect
by simply restoring reguluatory settings completely.
Cc: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit a042994dd377d86bff9446ee76151ceb6267c9ba upstream.
There is a theoretical race that if hit will trigger
a crash. The race is between when we issue the first
regulatory hint, regulatory_hint_core(), gets processed
by the workqueue and between when the first device
gets registered to the wireless core. This is not easy
to reproduce but it was easy to do so through the
regulatory simulator I have been working on. This
is a port of the fix I implemented there [1].
[1] https://github.com/mcgrof/regsim/commit/a246ccf81f059cb662eee288aa13100f631e4cc8
Upstream commit d305a6557b2c4dca0110f05ffe745b1ef94adb80.
If addBA responses comes in just after addba_resp_timer has
expired mac80211 will still accept it and try to open the
aggregation session. This causes drivers to be confused and
in some cases even crash.
This patch fixes the race condition and makes sure that if
addba_resp_timer has expired addBA response is not longer
accepted and we do not try to open half-closed session.
Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com>
[some adjustments]
commit c72e8d335e2c6a309b6281f2abcf491f37b8b92b upstream.
The rates bitmap for internal scan requests shoud be filled,
otherwise there will be probe requests with zero rates supported.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
commit fa2da8cdae1dd64f78fc915ca1d1a4a93c71e7cb upstream.
Bridge multicast snooping of ICMPv6 would incorrectly report a checksum problem
when used with Ethernet devices like sky2 that use CHECKSUM_COMPLETE.
When bytes are removed from skb, the computed checksum needs to be adjusted.
Tested-by: Martin Volf <martin.volf.42@gmail.com>
commit 2a1e0fd175dcfd72096ba9291d31e3b1b5342e60 upstream.
When a packet is supposed to sent be as an a-MPDU, mac80211 sets
IEEE80211_TX_CTL_AMPDU to let the driver know. On the other
hand, mac80211 configures the driver for aggregration with the
ampdu_action callback.
There is race between these two mechanisms since the following
scenario can occur when the BA agreement is torn down:
Tx softIRQ drv configuration
check OPERATIONAL bit
Set the TX_CTL_AMPDU bit in the packet
clear OPERATIONAL bit
stop Tx AGG
Pass Tx packet to the driver.
In that case the driver would get a packet with TX_CTL_AMPDU set
although it has already been notified that the BA session has been
torn down.
To fix this, we need to synchronize all the Qdisc activity after we
cleared the OPERATIONAL bit. After that step, all the following
packets will be buffered until the driver reports it is ready to get
new packets for this RA / TID. This buffering allows not to run into
another race that would send packets with TX_CTL_AMPDU unset while
the driver hasn't been requested to tear down the BA session yet.
This race occurs in practice and iwlwifi complains with a WARN_ON
when it happens.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 24f50a9d165745fd0701c6e089d35f58a229ea69 upstream.
Nikolay noticed (by code review) that mac80211 can
attempt to stop an aggregation session while it is
already being stopped. So to fix it, check whether
stop is already being done and bail out if so.
Also move setting the STOPPING state into the lock
so things are properly atomic.
Reported-by: Nikolay Martynov <mar.kolya@gmail.com>
commit de3584bd62d87b4c250129fbc46ca52c80330add upstream.
By the time userspace returns with a response to
the regulatory domain request, the wiphy causing
the request might have gone away. If this is so,
reject the update but mark the request as having
been processed anyway.
Cc: Luis R. Rodriguez <lrodriguez@qca.qualcomm.com>
commit e007b857e88097c96c45620bf3b04a4e309053d1 upstream.
MAC addresses have a fixed length. The current
policy allows passing < ETH_ALEN bytes, which
might result in reading beyond the buffer.
Signed-off-by: Eliad Peller <eliad@wizery.com>
commit 24ca9a847791fd53d9b217330b15f3c285827a18 upstream.
By returning '0' instead of 'EAGAIN' when the tests in xs_nospace() fail
to find evidence of socket congestion, we are making the RPC engine believe
that the message was incorrectly sent and so it disconnects the socket
instead of just retrying.
The bug appears to have been introduced by commit
5e3771ce2d6a69e10fcc870cdf226d121d868491 (SUNRPC: Ensure that xs_nospace
return values are propagated).
Reported-by: Andrew Cooper <andrew.cooper3@citrix.com>
Tested-by: Andrew Cooper <andrew.cooper3@citrix.com>
commit 93840ac40bb0d0f177ef8af74e64671be67e8c37 upstream.
Function tt_response_fill_table() actually uses a tt_local_entry pointer to
iterate either over the local or the global table entries (it depends on the
what hash table is passed as argument). To iterate over such entries the
hlist_for_each_entry_rcu() macro has to access their "hash_entry" field which
MUST be at the same position in both the tt_global/local_entry structures.
Reported-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Antonio Quartulli <ordex@autistici.org>
Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
commit 6e8014947d6469df1566e9e253805557c5c0e4e0 upstream.
After removing the batman-adv module, the hash may be already gone
when tt_global_del_orig() tries to clean the hash. This patch adds
a sanity check to avoid this.
Tested-by: Alexey Fisher <bug-track@fisher-privat.net>
commit 531027fcddbcf81c9937dd04f08a7e8f11fd47d2 upstream.
struct tt_global_entry holds a reference to an orig_node which must be
decremented before deallocating the structure.
commit 9d8523931f7f5eb8900077f0da0fbe6b8ad0010b upstream.
In the TT_RESPONSE packet, the number of carried entries is not correctly set.
This leads to a wrong interpretation of the packet payload on the receiver side
causing random entries to be added to the global translation table. Therefore
the latter gets always corrupted, triggering a table recovery all the time.
commit 31901264511cf20c5ed33b8649a3ca9ce28df60b upstream.
Currently the counter of tt_local_entry structures (tt_local_num) is incremented
each time the tt_local_reset_flags() is invoked causing the node to send wrong
TT_REPONSE packets containing a copy of non-initialised memory thus corrupting
other nodes global translation table and making higher level communication
impossible.
Reported-by: Junkeun Song <jun361@gmail.com>
Acked-by: Junkeun Song <jun361@gmail.com>
commit 731abb9cb27aef6013ce60808a04e04a545f3f4e upstream.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in ip6_tnl_create
because register_netdevice will now create a valid name. This works for the
net_device itself.
However the tunnel keeps a copy of the name in the parms structure for the
ip6_tnl associated with the tunnel. parms.name is set by copying the net_device
name in ip6_tnl_dev_init_gen. That function is called from ip6_tnl_dev_init in
ip6_tnl_create, but it is done before register_netdevice is called so the name
is set to a bogus value in the parms.name structure.
[root@localhost ~]# ip -6 tunnel add remote fec0::100 local fec0::200
[root@localhost ~]# ip -6 tunnel show
ip6tnl0: ipv6/ipv6 remote :: local :: encaplimit 0 hoplimit 0 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
ip6tnl%d: ipv6/ipv6 remote fec0::100 local fec0::200 encaplimit 4 hoplimit 64 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
[root@localhost ~]#
Fix this by moving the strcpy out of ip6_tnl_dev_init_gen, and calling it after
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
commit 58ebacc66bd11be2327edcefc79de94bd6f5bb4a upstream.
Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added
the .uevent() callback for the regulatory device used during
the platform device registration. The change was done to account
for queuing up udev change requests through udevadm triggers.
The change also meant that upon regulatory core exit we will now
send a uevent() but the uevent() callback, reg_device_uevent(),
also accessed last_request. Right before commiting device suicide
we free'd last_request but never set it to NULL so
platform_device_unregister() would lead to bogus kernel paging
request. Fix this and also simply supress uevents right before
we commit suicide as they are pointless.
This fix is required for kernels >= v2.6.39
$ git describe --contains 4d9d88d1
v2.6.39-rc1~468^2~25^2^2~21
The impact of not having this present is that a bogus paging
access may occur (only read) upon cfg80211 unload time. You
may also get this BUG complaint below. Although Johannes
could not reproduce the issue this fix is theoretically correct.
mac80211_hwsim: unregister radios
mac80211_hwsim: closing netlink
BUG: unable to handle kernel paging request at ffff88001a06b5ab
IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
CPU 0
Modules linked in: cfg80211(-) [last unloaded: mac80211]
Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs
RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286
RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc
RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0
RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff
R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0
R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001
FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0
Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780)
Stack:
ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2
000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820
ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189
Call Trace:
[<ffffffff812ff7e5>] dev_uevent+0xc5/0x170
[<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490
[<ffffffff81040189>] ? sub_preempt_count+0x29/0x60
[<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90
[<ffffffff81305307>] ? devres_release_all+0x27/0x60
[<ffffffff8124206b>] kobject_uevent+0xb/0x10
[<ffffffff812fee27>] device_del+0x157/0x1b0
[<ffffffff8130377d>] platform_device_del+0x1d/0x90
[<ffffffff81303b76>] platform_device_unregister+0x16/0x30
[<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211]
[<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211]
[<ffffffff8109a84c>] sys_delete_module+0x16c/0x220
[<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120
[<ffffffff814cba02>] system_call_fastpath+0x16/0x1b
Code: <all your base are belong to me>
RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211]
RSP <ffff88001c5f9d58>
---[ end trace 147c5099a411e8c0 ]---
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Cc: Scott James Remnant <keybuk@google.com>
commit 6c7394197af90f6a332180e33f5d025d3037d883 upstream.
Since the NL80211_ATTR_HT_CAPABILITY attribute is
used as a struct, it needs a minimum, not maximum
length. Enforce that properly. Not doing so could
potentially lead to reading after the buffer.
commit 5b2bbf75a24d6b06afff6de0eb4819413fd81971 upstream.
ieee80211_probereq_get() can return NULL in
which case we should clean up & return NULL
in ieee80211_build_probe_req() as well.
commit f8d1ccf15568268c76f913b45ecdd33134387f1a upstream.
When receiving failed PLCP frames is enabled, there
won't be a rate pointer when we add the radiotap
header and thus the kernel will crash. Fix this by
not assuming the rate pointer is always valid. It's
still always valid for frames that have good PLCP
though, and that is checked & enforced.
This was broken by my
commit fc88518916793af8ad6a02e05ff254d95c36d875
Author: Johannes Berg <johannes.berg@intel.com>
Date: Fri Jul 30 13:23:12 2010 +0200
mac80211: don't check rates on PLCP error frames
where I removed the check in this case but didn't
take into account that the rate info would be used.
Reported-by: Xiaokang Qin <xiaokang.qin@intel.com>
commit 05cb91085760ca378f28fc274fbf77fc4fd9886c upstream.
Only AID values 1-2007 are valid, but some APs have been
found to send random bogus values, in the reported case an
AP that was sending the AID field value 0xffff, an AID of
0x3fff (16383).
There isn't much we can do but disable powersave since
there's no way it can work properly in this case.
Reported-by: Bill C Riemers <briemers@redhat.com>
commit 6911bf0453e0d6ea8eb694a4ce67a68d071c538e upstream.
When going back on-channel, we should reconfigure
the hw iff the hardware is not already configured
to the operational channel.
commit eaa7af2ae582c9a8c51b374c48d5970b748a5ce2 upstream.
The offchannel code is currently broken - we should
remain_off_channel if the work was started, and
the work's channel and channel_type are the same
as local->tmp_channel and local->tmp_channel_type.
However, if wk->chan_type and local->tmp_channel_type
coexist (e.g. have the same channel type), we won't
remain_off_channel.
This behavior was introduced by commit da2fd1f
("mac80211: Allow work items to use existing
channel type.")
Tested-by: Ben Greear <greearb@candelatech.com>
commit dc6f55e9f8dac4b6479be67c5c9128ad37bb491f upstream.
The sunrpc layer keeps a cache of recently used credentials and
'unx_match' is used to find the credential which matches the current
process.
However unx_match allows a match when the cached credential has extra
groups at the end of uc_gids list which are not in the process group list.
So if a process with a list of (say) 4 group accesses a file and gains
access because of the last group in the list, then another process
with the same uid and gid, and a gid list being the first tree of the
gids of the original process tries to access the file, it will be
granted access even though it shouldn't as the wrong rpc credential
will be used.
Signed-off-by: NeilBrown <neilb@suse.de>
[ Upstream commit b0691c8ee7c28a72748ff32e91b165ec12ae4de6 ]
[ Upstream commit 7011687f0f2f12cc348f6a693fafe63d89167eac ]
in func icmp6_dst_alloc,dst_metric_set call ipv6_cow_metrics to set metric.
ipv6_cow_metrics may will call rt6_bind_peer to set rt6_info->rt6i_peer.
So,we should move ipv6_addr_copy before dst_metric_set to make sure rt6_bind_peer success.
[ Upstream commit b73233960a59ee66e09d642f13d0592b13651e94 ]
There is bug in commit 5e2b61f(ipv4: Remove flowi from struct rtable).
It makes xfrm4_fill_dst() modify wrong data structure.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Reported-by: Kim Phillips <kim.phillips@freescale.com>
commit da92b194cc36b5dc1fbd85206aeeffd80bee0c39 upstream.
The pair of functions,
* skb_clone_tx_timestamp()
* skb_complete_tx_timestamp()
were designed to allow timestamping in PHY devices. The first
function, called during the MAC driver's hard_xmit method, identifies
PTP protocol packets, clones them, and gives them to the PHY device
driver. The PHY driver may hold onto the packet and deliver it at a
later time using the second function, which adds the packet to the
socket's error queue.
As pointed out by Johannes, nothing prevents the socket from
disappearing while the cloned packet is sitting in the PHY driver
awaiting a timestamp. This patch fixes the issue by taking a reference
on the socket for each such packet. In addition, the comments
regarding the usage of these function are expanded to highlight the
rule that PHY drivers must use skb_complete_tx_timestamp() to release
the packet, in order to release the socket reference, too.
These functions first appeared in v2.6.36.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
