path: root/net
2009-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) ucc_geth: Fix oops when using fixed-link support dm9000: locking bugfix net: update dnet.c for bus_id removal dnet: DNET should depend on HAS_IOMEM dca: add missing copyright/license headers nl80211: Check that function pointer != NULL before using it sungem: missing net_device_ops be2net: fix to restore vlan ids into BE2 during a IF DOWN->UP cycle be2net: replenish when posting to rx-queue is starved in out of mem conditions bas_gigaset: correctly allocate USB interrupt transfer buffer smsc911x: reset last known duplex and carrier on open sh_eth: Fix mistake of the address of SH7763 sh_eth: Change handling of IRQ netns: oops in ip[6]_frag_reasm incrementing stats net: kfree(napi->skb) => kfree_skb net: fix sctp breakage ipv6: fix display of local and remote sit endpoints net: Document /proc/sys/net/core/netdev_budget tulip: fix crash on iface up with shirq debug virtio_net: Make virtio_net support carrier detection ...
2009-03-20nl80211: Check that function pointer != NULL before using itJouni Malinen
NL80211_CMD_GET_MESH_PARAMS and NL80211_CMD_SET_MESH_PARAMS handlers did not verify whether a function pointer is NULL (not supported by the driver) before trying to call the function. The former nl80211 command is available for unprivileged users, too, so this can potentially allow normal users to kill networking (or worse..) if mac80211 is built without CONFIG_MAC80211_MESH=y. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-18netns: oops in ip[6]_frag_reasm incrementing statsJorge Boncompte [DTI2]
dev can be NULL in ip[6]_frag_reasm for skb's coming from RAW sockets. Quagga's OSPFD sends fragmented packets on a RAW socket, when netfilter conntrack reassembles them on the OUTPUT path you hit this code path. You can test it with something like "hping2 -0 -d 2000 -f AA.BB.CC.DD" With help from Jarek Poplawski. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18net: kfree(napi->skb) => kfree_skbRoel Kluin
struct sk_buff pointers should be freed with kfree_skb. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18net: fix sctp breakageAl Viro
broken by commit 5e739d1752aca4e8f3e794d431503bfca3162df4; AFAICS should be -stable fodder as well... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Aced-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-18ipv6: fix display of local and remote sit endpointsBjørn Mork
This fixes the regressions cause by commit 1326c3d5a4b792a2b15877feb7fb691f8945d203 (v2.6.28-rc6-461-g23a12b1) broke the display of local and remote addresses of an SIT tunnel in iproute2. nt->parms is used by ipip6_tunnel_init() and therefore need to be initialized first. Tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12868 Reported-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-17Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2009-03-17gro: Fix legacy path napi_complete crashHerbert Xu
On the legacy netif_rx path, I incorrectly tried to optimise the napi_complete call by using __napi_complete before we reenable IRQs. This simply doesn't work since we need to flush the held GRO packets first. This patch fixes it by doing the obvious thing of reenabling IRQs first and then calling napi_complete. Reported-by: Frank Blaschka <blaschka@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-16mac80211: Fix panic on fragmentation with power savingJouni Malinen
It was possible to hit a kernel panic on NULL pointer dereference in dev_queue_xmit() when sending power save buffered frames to a STA that woke up from sleep. This happened when the buffered frame was requeued for transmission in ap_sta_ps_end(). In order to avoid the panic, copy the skb->dev and skb->iif values from the first fragment to all other fragments. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16lib80211: silence excessive crypto debugging messagesJohn W. Linville
When they were part of the now defunct ieee80211 component, these messages were only visible when special debugging settings were enabled. Let's mirror that with a new lib80211 debugging Kconfig option. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) r8169: revert "r8169: read MAC address from EEPROM on init (2nd attempt)" r8169: use hardware auto-padding. igb: remove ASPM L0s workaround netxen: remove old flash check. mv643xx_eth: fix unicast address filter corruption on mtu change xfrm: Fix xfrm_state_find() wrt. wildcard source address. emac: Fix clock control for 405EX and 405EXr chips ixgbe: fix multiple unicast address support via-velocity: Fix DMA mapping length errors on transmit. qlge: bugfix: Pad outbound frames smaller than 60 bytes. qlge: bugfix: Move netif_napi_del() to common call point. qlge: bugfix: Tell hw to strip vlan header. qlge: bugfix: Increase filter on inbound csum. dnet: replace obsolete *netif_rx_* functions with *napi_* net: Add be2net driver. dnet: Fix warnings on 64-bit. dnet: Dave DNET ethernet controller driver (updated) ipv6: Fix BUG when disabled ipv6 module is unloaded bnx2x: Using DMAE to initialize the chip bnx2x: Casting page alignment ...
2009-03-16netfilter: conntrack: check for NEXTHDR_NONE before header sanity checkingChristoph Paasch
NEXTHDR_NONE doesn't has an IPv6 option header, so the first check for the length will always fail and results in a confusing message "too short" if debugging enabled. With this patch, we check for NEXTHDR_NONE before length sanity checkings are done. Signed-off-by: Christoph Paasch <christoph.paasch@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-16netfilter: conntrack: fix dropping packet after l4proto->packet()Christoph Paasch
We currently use the negative value in the conntrack code to encode the packet verdict in the error. As NF_DROP is equal to 0, inverting NF_DROP makes no sense and, as a result, no packets are ever dropped. Signed-off-by: Christoph Paasch <christoph.paasch@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-16netfilter: ctnetlink: fix crash during expectation creationPablo Neira Ayuso
This patch fixes a possible crash due to the missing initialization of the expectation class when nf_ct_expect_related() is called. Reported-by: BORBELY Zoltan <bozo@andrews.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-13xfrm: Fix xfrm_state_find() wrt. wildcard source address.David S. Miller
The change to make xfrm_state objects hash on source address broke the case where such source addresses are wildcarded. Fix this by doing a two phase lookup, first with fully specified source address, next using saddr wildcarded. Reported-by: Nicolas Dichtel <nicolas.dichtel@dev.6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-11SUNRPC: xprt_connect() don't abort the task if the transport isn't boundTrond Myklebust
If the transport isn't bound, then we should just return ENOTCONN, letting call_connect_status() and/or call_status() deal with retrying. Currently, we appear to abort all pending tasks with an EIO error. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11SUNRPC: Fix an Oops due to socket not set up yet...Trond Myklebust
We can Oops in both xs_udp_send_request() and xs_tcp_send_request() if the call to xs_sendpages() returns an error due to the socket not yet being set up. Deal with that situation by returning a new error: ENOTSOCK, so that we know to avoid dereferencing transport->sock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11ipv6: Fix BUG when disabled ipv6 module is unloadedJohn Dykstra
Do not try to "uninitialize" ipv6 if its initialization had been skipped because module parameter disable=1 had been specified. Reported-by: Thomas Backlund <tmb@mandriva.org> Signed-off-by: John Dykstra <john.dykstra1@gmail.com> Acked-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10SUNRPC: Tighten up the task locking rules in __rpc_execute()Trond Myklebust
We should probably not be testing any flags after we've cleared the RPC_TASK_RUNNING flag, since rpc_make_runnable() is then free to assign the rpc_task to another workqueue, which may then destroy it. We can fix any races with rpc_make_runnable() by ensuring that we only clear the RPC_TASK_RUNNING flag while holding the rpc_wait_queue->lock that the task is supposed to be sleeping on (and then checking whether or not the task really is sleeping). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-06cfg80211: test before subtraction on unsignedRoel Kluin
freq_diff is unsigned, so test before subtraction Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-04vlan: Fix vlan-in-vlan crashes.David S. Miller
As analyzed by Patrick McHardy, vlan needs to reset it's netdev_ops pointer in it's ->init() function but this leaves the compat method pointers stale. Add a netdev_resync_ops() and call it from the vlan code. Any other driver which changes ->netdev_ops after register_netdevice() will need to call this new function after doing so too. With help from Patrick McHardy. Tested-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04net: Fix missing dev->neigh_setup in register_netdevice().David S. Miller
2009-03-04pkt_sched: act_police: Fix a rate estimator test.Jarek Poplawski
A commit c1b56878fb68e9c14070939ea4537ad4db79ffae "tc: policing requires a rate estimator" introduced a test which invalidates previously working configs, based on examples from iproute2: doc/actions/actions-general. This is too rigorous: a rate estimator is needed only when police's "avrate" option is used. Reported-by: Joao Correia <joaomiguelcorreia@gmail.com> Diagnosed-by: John Dykstra <john.dykstra1@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04SCTP: change sctp_ctl_sock_init() to try IPv4 if IPv6 failsBrian Haley
Change sctp_ctl_sock_init() to try IPv4 if IPv6 socket registration fails. Required if the IPv6 module is loaded with "disable=1", else SCTP will fail to load. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04IPv6: add "disable" module parameter support to ipv6.koBrian Haley
Add "disable" module parameter support to ipv6.ko by specifying "disable=1" on module load. We just do the minimum of initializing inetsw6[] so calls from other modules to inet6_register_protosw() won't OOPs, then bail out. No IPv6 addresses or sockets can be created as a result, and a reboot is required to enable IPv6. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03net: fix tokenring licenseMeelis Roos
Currently, modular tokenring ("tr") lacks a license and fails to load: tr: module license 'unspecified' taints kernel. tr: Unknown symbol proc_net_fops_create Beacuse of this, no tokenring driver can load if it depends on modular tr. Fix this by adding GPL module license as it is in the kernel. With this fix, tr module loads fine and tms380 driver also loads. Well, it does'nt work but that's a different bug. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netlink: invert error code in netlink_set_err()Pablo Neira Ayuso
The callers of netlink_set_err() currently pass a negative value as parameter for the error code. However, sk->sk_err wants a positive error value. Without this patch, skb_recv_datagram() called by netlink_recvmsg() may return a positive value to report an error. Another choice to fix this is to change callers to pass a positive error value, but this seems a bit inconsistent and error prone to me. Indeed, the callers of netlink_set_err() assumed that the (usual) negative value for error codes was fine before this patch :). This patch also includes some documentation in docbook format for netlink_set_err() to avoid this sort of confusion. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netns: Remove net_aliveEric W. Biederman
It turns out that net_alive is unnecessary, and the original problem that led to it being added was simply that the icmp code thought it was a network device and wound up being unable to handle packets while there were still packets in the network namespace. Now that icmp and tcp have been fixed to properly register themselves this problem is no longer present and we have a stronger guarantee that packets will not arrive in a network namespace then that provided by net_alive in netif_receive_skb. So remove net_alive allowing packet reception run a little faster. Additionally document the strong reason why network namespace cleanup is safe so that if something happens again someone else will have a chance of figuring it out. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03tcp: Like icmp use register_pernet_subsysEric W. Biederman
To remove the possibility of packets flying around when network devices are being cleaned up use reisger_pernet_subsys instead of register_pernet_device. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netns: Fix icmp shutdown.Eric W. Biederman
Recently I had a kernel panic in icmp_send during a network namespace cleanup. There were packets in the arp queue that failed to be sent and we attempted to generate an ICMP host unreachable message, but failed because icmp_sk_exit had already been called. The network devices are removed from a network namespace and their arp queues are flushed before we do attempt to shutdown subsystems so this error should have been impossible. It turns out icmp_init is using register_pernet_device instead of register_pernet_subsys. Which resulted in icmp being shut down while we still had the possibility of packets in flight, making a nasty NULL pointer deference in interrupt context possible. Changing this to register_pernet_subsys fixes the problem in my testing. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03netns: fix addrconf_ifdown kernel panicDaniel Lezcano
When a network namespace is destroyed the network interfaces are all unregistered, making addrconf_ifdown called by the netdevice notifier. In the other hand, the addrconf exit method does a loop on the network devices and does addrconf_ifdown on each of them. But the ordering of the netns subsystem is not right because it uses the register_pernet_device instead of register_pernet_subsys. If we handle the loopback as any network device, we can safely use register_pernet_subsys. But if we use register_pernet_subsys, the addrconf exit method will do exactly what was already done with the unregistering of the network devices. So in definitive, this code is pointless. I removed the netns addrconf exit method and moved the code to the addrconf cleanup function. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-03ipv6: Fix sysctl unregistration deadlockStephen Hemminger
2009-03-03net: Avoid race between network down and sysfsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sctp: fix kernel panic with ERROR chunk containing too many error causesWei Yongjun
If ERROR chunk is received with too many error causes in ESTABLISHED state, the kernel get panic. This is because sctp limit the max length of cmds to 14, but while ERROR chunk is received, one error cause will add around 2 cmds by sctp_add_cmd_sf(). So many error causes will fill the limit of cmds and panic. This patch fixed the problem. This bug can be test by SCTP Conformance Test Suite <http://networktest.sourceforge.net/>. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02sctp: fix crash during module unloadVlad Yasevich
An extra list_del() during the module load failure and unload resulted in a crash with a list corruption. Now sctp can be unloaded again. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-01tcp: fix retrans_out leaksIlpo Järvinen
There's conflicting assumptions in shifting, the caller assumes that dupsack results in S'ed skbs (or a part of it) for sure but never gave a hint to tcp_sacktag_one when dsack is actually in use. Thus DSACK retrans_out -= pcount was not taken and the counter became out of sync. Remove obstacle from that information flow to get DSACKs accounted in tcp_sacktag_one as expected. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Tested-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-01netpoll: Add drop checks to all entry pointsHerbert Xu
The netpoll entry checks are required to ensure that we don't receive normal packets when invoked via netpoll. Unfortunately it only ever worked for the netif_receive_skb/netif_rx entry points. The VLAN (and subsequently GRO) entry point didn't have the check and therefore can trigger all sorts of weird problems. This patch adds the netpoll check to all entry points. I'm still uneasy with receiving at all under netpoll (which apparently is only used by the out-of-tree kdump code). The reason is it is perfectly legal to receive all data including headers into highmem if netpoll is off, but if you try to do that with netpoll on and someone gets a printk in an IRQ handler you're going to get a nice BUG_ON. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-27pkt_sched: sch_drr: Fix oops in drr_change_class.Jarek Poplawski
drr_change_class lacks a check for NULL of tca[TCA_OPTIONS], so oops is possible. Reported-by: Denys Fedoryschenko <denys@visp.net.lb> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26ipv6: don't use tw net when accounting for recycled twPavel Emelyanov
We already have a valid net in that place, but this is not just a cleanup - the tw pointer can be NULL there sometimes, thus causing an oops in NET_NS=y case. The same place in ipv4 code already works correctly using existing net, rather than tw's one. The bug exists since 2.6.27. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24tcp_scalable: Update malformed & dead urlJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24Merge branch 'master' of ↵David S. Miller
2009-02-24netfilter: xt_recent: fix proc-file addition/removal of IPv4 addressesJosef Drexler
Fix regression introduded by commit 079aa88 (netfilter: xt_recent: IPv6 support): From http://bugzilla.kernel.org/show_bug.cgi?id=12753: Problem Description: An uninitialized buffer causes IPv4 addresses added manually (via the +IP command to the proc interface) to never match any packets. Similarly, the -IP command fails to remove IPv4 addresses. Details: In the function recent_entry_lookup, the xt_recent module does comparisons of the entire nf_inet_addr union value, both for IPv4 and IPv6 addresses. For addresses initialized from actual packets the remaining 12 bytes not occupied by the IPv4 are zeroed so this works correctly. However when setting the nf_inet_addr addr variable in the recent_mt_proc_write function, only the IPv4 bytes are initialized and the remaining 12 bytes contain garbage. Hence addresses added in this way never match any packets, unless these uninitialized 12 bytes happened to be zero by coincidence. Similarly, addresses cannot consistently be removed using the proc interface due to mismatch of the garbage bytes (although it will sometimes work to remove an address that was added manually). Reading the /proc/net/xt_recent/ entries hides this problem because this only uses the first 4 bytes when displaying IPv4 addresses. Steps to reproduce: $ iptables -I INPUT -m recent --rcheck -j LOG $ echo +169.254.156.239 > /proc/net/xt_recent/DEFAULT $ cat /proc/net/xt_recent/DEFAULT src=169.254.156.239 ttl: 0 last_seen: 119910 oldest_pkt: 1 119910 [At this point no packets from 169.254.156.239 are being logged.] $ iptables -I INPUT -s 169.254.156.239 -m recent --set $ cat /proc/net/xt_recent/DEFAULT src=169.254.156.239 ttl: 0 last_seen: 119910 oldest_pkt: 1 119910 src=169.254.156.239 ttl: 255 last_seen: 126184 oldest_pkt: 4 125434, 125684, 125934, 126184 [At this point, adding the address via an iptables rule, packets are being logged correctly.] $ echo -169.254.156.239 > /proc/net/xt_recent/DEFAULT $ cat /proc/net/xt_recent/DEFAULT src=169.254.156.239 ttl: 0 last_seen: 119910 oldest_pkt: 1 119910 src=169.254.156.239 ttl: 255 last_seen: 126992 oldest_pkt: 10 125434, 125684, 125934, 126184, 126434, 126684, 126934, 126991, 126991, 126992 $ echo -169.254.156.239 > /proc/net/xt_recent/DEFAULT $ cat /proc/net/xt_recent/DEFAULT src=169.254.156.239 ttl: 0 last_seen: 119910 oldest_pkt: 1 119910 src=169.254.156.239 ttl: 255 last_seen: 126992 oldest_pkt: 10 125434, 125684, 125934, 126184, 126434, 126684, 126934, 126991, 126991, 126992 [Removing the address via /proc interface failed evidently.] Possible solutions: - initialize the addr variable in recent_mt_proc_write - compare only 4 bytes for IPv4 addresses in recent_entry_lookup Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: amend the fix for SO_BSDCOMPAT gsopt infoleak netns: build fix for net_alloc_generic
2009-02-23net: amend the fix for SO_BSDCOMPAT gsopt infoleakEugene Teo
The fix for CVE-2009-0676 (upstream commit df0bca04) is incomplete. Note that the same problem of leaking kernel memory will reappear if someone on some architecture uses struct timeval with some internal padding (for example tv_sec 64-bit and tv_usec 32-bit) --- then, you are going to leak the padded bytes to userspace. Signed-off-by: Eugene Teo <eugeneteo@kernel.sg> Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-23netns: build fix for net_alloc_genericClemens Noss
net_alloc_generic was defined in #ifdef CONFIG_NET_NS, but used unconditionally. Move net_alloc_generic out of #ifdef. Signed-off-by: Clemens Noss <cnoss@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: netns: fix double free at netns creation veth : add the set_mac_address capability sunlance: Beyond ARRAY_SIZE of ib->btx_ring sungem: another error printed one too early ISDN: fix sc/shmem printk format warning SMSC: timeout reaches -1 smsc9420: handle magic field of ethtool_eeprom sundance: missing parentheses? smsc9420: fix another postfixed timeout wimax/i2400m: driver loads firmware v1.4 instead of v1.3 vlan: Update skb->mac_header in __vlan_put_tag(). cxgb3: Add support for PCI ID 0x35. tcp: remove obsoleted comment about different passes TG3: &&/|| confusion ATM: misplaced parentheses? net/mv643xx: don't disable the mib timer too early and lock properly net/mv643xx: use GFP_ATOMIC while atomic atl1c: Atheros L1C Gigabit Ethernet driver net: Kill skb_truesize_check(), it only catches false-positives. net: forcedeth: Fix wake-on-lan regression
2009-02-23cipso: Fix documentation commentPaul Moore
The CIPSO protocol engine incorrectly stated that the FIPS-188 specification could be found in the kernel's Documentation directory. This patch corrects that by removing the comment and directing users to the FIPS-188 documented hosted online. For the sake of completeness I've also included a link to the CIPSO draft specification on the NetLabel website. Thanks to Randy Dunlap for spotting the error and letting me know. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-22netns: fix double free at netns creationDaniel Lezcano
This patch fix a double free when a network namespace fails. The previous code does a kfree of the net_generic structure when one of the init subsystem initialization fails. The 'setup_net' function does kfree(ng) and returns an error. The caller, 'copy_net_ns', call net_free on error, and this one calls kfree(net->gen), making this pointer freed twice. This patch make the code symetric, the net_alloc does the net_generic allocation and the net_free frees the net_generic. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18tcp: remove obsoleted comment about different passesIlpo Järvinen
This is obsolete since the passes got combined. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
