A new driver is implemented to actively manage the bluetooth module
power. bluesleep also tries to manage the power of the transport used.
Two signals (GPIOs) are used to manage the power events.
BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep.
HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/
activate the transport modules required for BT communication.
Bug 791669, 773186
(cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8)
Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15
Reviewed-on: http://git-master/r/19858
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
This improves compatbility with a lot of headset / chipset
combinations. Ideally this should not be needed.
Change-Id: I8b676701e12e416aa7d60801b9d353b15d102709
Signed-off-by: hyungseoung.yoo <hyungseoung.yoo@samsung.com>
Signed-off-by: Jaikumar Ganesh <jaikumarg@android.com>
Currently, calling tcp_nuke_addr to reset IPv6 connections
resets IPv4 connections as well, because all Android
framework sockets are dual-stack (i.e., IPv6) sockets, and
we don't check the source address to see if the connection
was in fact an IPv4 connection.
Fix this by checking the source address and not resetting
the connection if it's a mapped address.
Also slightly tweak the IPv4 code path, which doesn't check
for mapped addresses either. This was not causing any
problems because tcp_is_local normally always returns true
for LOOPBACK4_IPV6 (127.0.0.6), because the loopback
interface is configured as as 127.0.0.0/8. However,
checking explicitly for LOOPBACK4_IPV6 makes the code a bit
more robust.
Bug: 5535055
Change-Id: I4d6ed3497c5b8643c864783cf681f088cf6b8d2a
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
Because for now the xt_qtaguid module allows procs to use tags without
having /dev/xt_qtaguid open, there was a case where it would try
to delete a resources from a list that was proc specific.
But that resource was never added to that list which is only
used when /dev/xt_qtaguid has been opened by the proc.
Once our userspace is fully updated, we won't need those exceptions.
Change-Id: Idd4bfea926627190c74645142916e10832eb2504
Signed-off-by: JP Abgrall <jpa@google.com>
Since rx_bytes accounting does not include Ethernet Headers in
br_input.c, excluding ETH_HLEN on the transmit path for consistent
measurement of packet length on both the Tx and Rx chains.
The clean way would be for Rx to include the eth header, but the
skb len has already been adjusted by the time the br code sees the skb.
This is only a temporary workaround until we can completely ignore or
cleanly fix the skb->len handling.
Change-Id: I910de95a4686b2119da7f1f326e2154ef31f9972
Signed-off-by: Ashish Sharma <ashishsharma@google.com>
Change-Id: I3bf165c31f35a6c7dc212f23df5eefaeb8129d0d
When calling:
ipv6_find_hdr(skb, &thoff, -1, NULL)
on a fragmented packet, thoff would be left with a random
value causing callers to read random memory offsets with:
skb_header_pointer(skb, thoff, ...)
Now we force ipv6_find_hdr() to return a failure in this case.
Calling:
ipv6_find_hdr(skb, &thoff, -1, &fragoff)
will set fragoff as expected, and not return a failure.
Change-Id: Ib474e8a4267dd2b300feca325811330329684a88
In cases where the skb would have an sk_socket but no file, that skb
would not be counted at all. Assigning to uid 0 now.
Adding extra counters to track skb counts.
Change-Id: If049b4b525e1fbd5afc9c72b4a174c0a435f2ca7
* Crash fix
The delete command would delete a socket tag entry without removing it
from the proc_qtu_data { ..., sock_tag_list, }.
This in turn would cause an exiting process to crash while cleaning up
its matching proc_qtu_data.
* Added more aggressive tracking/cleanup of proc_qtu_data
This should allow one process to cleanup qtu_tag_data{} left around from
processes that didn't use resource tracking via /dev/xt_qtaguid.
* Debug printing tweaks
Better code inclusion/exclusion handling,
and extra debug out of full state.
Change-Id: I735965af2962ffcd7f3021cdc0068b3ab21245c2
Make the warning less scary.
Change-Id: I0276c5413e37ec991f24db57aeb90333fb1b5a65
There is a
/proc/net/xt_qtaguid/iface/<iface>/{rx_bytes,rx_packets,tx_bytes,...}
but for better convenience and to avoid getting overly stale net/dev stats
we now have
/proc/net/xt_qtaguid/iface_stat_all
which outputs lines of:
iface_name active rx_bytes rx_packets tx_bytes tx_packets
net_dev_rx_bytes net_dev_rx_packets net_dev_tx_bytes net_dev_tx_packets
Change-Id: I12cc10d2d123b86b56d4eb489b1d77b2ce72ebcf
Most net devs will not reset their stats when just going down/up,
unless a NETDEV_UNREGISTER was notified.
But some devs will not send out a NETDEV_UNREGISTER but still
reset their stats just before a NETDEV_UP.
Now we just track the dev stats during NETDEV_DOWN... just in case.
Then on NETDEV_UP we check the stats: if the device didn't do a
NETDEV_UNREGISTER and a prior NETDEV_DOWN captured stats, then we treat
it as an UNREGISTER and save the totals from the stashed values.
Added extra netdev event debugging.
Change-Id: Iec79e74bfd40269aa3e5892f161be71e09de6946
When a process doesn't have /dev/xt_qtaguid open, only warn once
instead of for every ctrl access.
Change-Id: I98a462a8731254ddc3bf6d2fefeef9823659b1f0
* Added global resource tracking based on tags.
- Can be put into passive mode via
/sys/modules/xt_qtaguid/params/tag_tracking_passive
- The number of socket tags per UID is now limited
- Adding /dev/xt_qtaguid that each process should open before starting
to tag sockets. A later change will make it a "must".
- A process should not create new tags unless it has the dev open.
A later change will make it a must.
- On qtaguid_resources release, the process' matching socket tag info
is deleted.
* Support run-time debug mask via /sys/modules parameter "debug_mask".
* split module into prettyprinting code, includes, main.
* Removed ptrdiff_t usage which didn't work in all cases.
Change-Id: I4a21d3bea55d23c1c3747253904e2a79f7d555d9
Change-Id: I6e8d838d91bebc28f4cd09dcb8b9f1de775be13d
Signed-off-by: jun.ho.lee <jun.ho.lee@samsung.com>
"cat /proc/net/xt_qtaguid/stats"
for a non-priviledged UID would output multiple twice its own stats.
The fix tweaks the way lines are counted.
Non-root:
idx iface acct_tag_hex uid_tag_int cnt_set ...
2 wlan0 0x0 10022 0 ...
3 wlan0 0x0 10022 1 ...
4 wlan0 0x3010000000000000 10022 0 ...
5 wlan0 0x3010000000000000 10022 1 ...
Root:
2 wlan0 0x0 0 0 ...
3 wlan0 0x0 0 1 ...
4 wlan0 0x0 1000 0 ...
12 wlan0 0x0 10022 0 ...
13 wlan0 0x0 10022 1 ...
18 wlan0 0x3010000000000000 10022 0 ...
19 wlan0 0x3010000000000000 10022 1 ...
Change-Id: I3cae1f4fee616bc897831350374656b0c718c45b
Commit 330605423c fixed l2cap conn establishment for non-ssp remote
devices by not setting HCI_CONN_ENCRYPT_PEND every time conn security
is tested (which was always returning failure on any subsequent
security checks).
However, this broke l2cap conn establishment for ssp remote devices
when an ACL link was already established at SDP-level security. This
fix ensures that encryption must be pending whenever authentication
is also pending.
Change-Id: I6876ea5134e90d1f3d0f84e8ed40b92977b3df64
Signed-off-by: Peter Hurley <peter@xxxxxxxxxxxxxxxxxx>
Turns out that some devices don't call the notifier chains
with NETDEV_UNREGISTER.
So now we only track up/down as the points for tracking
active/inactive transitions and saving the get_dev_stats().
Change-Id: I948755962b4c64150b4d04f294fb4889f151e42b
/proc/net/xt_qtaguid/ctrl will now show:
active tagged sockets: lines of "sock=%p tag=0x%llx (uid=%u)"
sockets_tagged, : the number of sockets successfully tagged.
sockets_untagged: the number of sockets successfully untagged.
counter_set_changes: ctrl counter set change requests.
delete_cmds: ctrl delete commands completed.
iface_events: number of NETDEV_* events handled.
match_found_sk: sk found in skbuff without ct assist.
match_found_sk_in_ct: the number of times the connection tracker found
a socket for us. This happens when the skbuff didn't have info.
match_found_sk_none: the number of times no sk could be determined
successfully looked up. This indicates we don't know who the
data actually belongs to. This could be unsolicited traffic.
Change-Id: I3a65613bb24852e1eea768ab0320a6a7073ab9be
sockfd_put() risks sleeping.
So when doing a delete ctrl command, defer the sockfd_put() and
kfree() to outside of the spinlock.
Change-Id: I5f8ab51d05888d885b2fbb035f61efa5b7abb88a
* Don't hold the sockets after tagging.
sockfd_lookup() does a get() on the associated file.
There was no matching put() so a closed socket could never be
freed.
* Don't rely on struct member order for tag_node
The structs that had a struct tag_node member would work with
the *_tree_* routines only because tag_node was 1st.
* Improve debug messages
Provide info on who the caller is. Use unsigned int for uid.
* Only process NETDEV_UP events.
* Pacifier: disable netfilter matching. Leave .../stats header.
Change-Id: Iccb8ae3cca9608210c417597287a2391010dff2c
* Allow tracking interfaces that only have an ipv6 address.
Deal with ipv6 notifier chains that do NETDEV_UP without the rtnl_lock()
* Allow root all access to procfs ctrl/stats.
To disable all checks:
echo 0 > /sys/module/xt_qtaguid/parameters/ctrl_write_gid
echo 0 > /sys/module/xt_qtaguid/parameters/stats_readall_gid
* Add CDEBUG define to enable pr_debug output specific to
procfs ctrl/stats access.
Change-Id: I9a469511d92fe42734daff6ea2326701312a161b
* Added support for sets of counters.
By default set 0 is active.
Userspace can control which set is active for a given UID by
writing to .../ctrl
s <set_num> <uid>
Changing the active set is only permitted for processes in the
AID_NET_BW_ACCT group.
The active set tracking is reset when the uid tag is deleted with
the .../ctrl command
d 0 <uid>
* New output format for the proc .../stats
- Now has cnt_set in the list.
idx iface acct_tag_hex uid_tag_int cnt_set rx_bytes rx_packets tx_bytes tx_packets rx_tcp_packets rx_tcp_bytes rx_udp_packets rx_udp_bytes rx_other_packets rx_other_bytes tx_tcp_packets tx_tcp_bytes tx_udp_packets tx_udp_bytes tx_other_packets tx_other_bytes
2 rmnet0 0x0 1000 0 27729 29 1477 27 27501 26 228 3 0 0 1249 24 228 3 0 0
2 rmnet0 0x0 1000 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
3 rmnet0 0x0 10005 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
3 rmnet0 0x0 10005 1 46407 57 8008 64 46407 57 0 0 0 0 8008 64 0 0 0 0
6 rmnet0 0x7fff000100000000 10005 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
6 rmnet0 0x7fff000100000000 10005 1 27493 24 1564 22 27493 24 0 0 0 0 1564 22 0 0 0 0
* Refactored for proc stats output code.
* Silenced some of the per packet debug output.
* Reworded some of the debug messages.
* Replaced all the spin_lock_irqsave/irqrestore with *_bh():
netfilter handling is done in softirq.
Change-Id: Ibe89f9d754579fd97335617186c614b43333cfd3
Update the code to handle some of the differences between
RFC 3041 and RFC 4941, which obsoletes it. Also a couple
of janitorial fixes.
- Allow router advertisements to increase the lifetime of
temporary addresses. This was not allowed by RFC 3041,
but is specified by RFC 4941. It is useful when RA
lifetimes are lower than TEMP_{VALID,PREFERRED}_LIFETIME:
in this case, the previous code would delete or deprecate
addresses prematurely.
- Change the default of MAX_RETRY to 3 per RFC 4941.
- Add a comment to clarify that the preferred and valid
lifetimes in inet6_ifaddr are relative to the timestamp.
- Shorten lines to 80 characters in a couple of places.
Change-Id: I4da097664d4b1de7c1cebf410895319601c7f1cc
This would cause log spam to the point of slowing down the system.
Change-Id: I5655f0207935004b0198f43ad0d3c9ea25466e4e
* uid handling
- Limit UID impersonation to processes with a gid in AID_NET_BW_ACCT.
This affects socket tagging, and data removal.
- Limit stats lookup to own uid or the process gid is in AID_NET_BW_STATS.
This affects stats lookup.
* allow pacifying the module
Setting passive to Y/y will make the module return immediately on
external stimulus.
No more stats and silent success on ctrl writes.
Mainly used when one suspects this module of misbehaving.
Change-Id: I83990862d52a9b0922aca103a0f61375cddeb7c4
* Add a new ctrl command to delete stored data.
d <acct_tag> [<uid>]
The uid will default to the running process's.
The accounting tag can be 0, in which case all counters and socket tags
associated with the uid will be cleared.
* Simplify the ctrl command handling at the expense of duplicate code.
This should make it easier to maintain.
* /proc/net/xt_qtaguid/stats now returns more stats
{rx,tx}_{bytes,packets}
{rx,tx}_{tcp,udp,other}_{bytes,packets}
the {rx,tx}_{bytes,packets} are the totals.
* re-tagging will now allow changing the uid.
Change-Id: I9594621543cefeab557caa3d68a22a3eb320466d
This uses the NETLINK NETLINK_NFLOG family to log a single message
when the quota limit is reached.
It uses the same packet type as ipt_ULOG, but
- never copies skb data,
- uses 112 as the event number (ULOG's +1)
It doesn't log if the module param "event_num" is 0.
Change-Id: I6f31736b568bb31a4ff0b9ac2ee58380e6b675ca
The xt_quota2 came from
http://sourceforge.net/projects/xtables-addons/develop
It needed tweaking for it to compile within the kernel tree.
Fixed kmalloc() and create_proc_entry() invocations within
a non-interruptible context.
Removed useless copying of current quota back to the iptable's
struct matchinfo:
- those are per CPU: they will change randomly based on which
cpu gets to update the value.
- they prevent matching a rule: e.g.
-A chain -m quota2 --name q1 --quota 123
can't be followed by
-D chain -m quota2 --name q1 --quota 123
as the 123 will be compared to the struct matchinfo's quota member.
Change-Id: I021d3b743db3b22158cc49acb5c94d905b501492
The original xt_quota in the kernel is plain broken:
- counts quota at a per CPU level
(was written back when ubiquitous SMP was just a dream)
- provides no way to count across IPV4/IPV6.
This patch is the original unaltered code from:
at commit e84391ce665cef046967f796dd91026851d6bbf3
Change-Id: I19d49858840effee9ecf6cff03c23b45a97efdeb
This patch adds support for disconnecting the link when SMP procedure
takes more than 30 seconds.
SMP begins when either the Pairing Request command is sent or the
Pairing Response is received, and it ends when the link is encrypted
(or terminated). Vol 3, Part H Section 3.4.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
This time the symptom is caused by tagging the same socket twice
without untagging it in between.
This would cause it to not unlock, and return.
When processing args passed to the procfs ctrl, if the tag was
invalid it would exit without releasing the spin_lock...
Bye bye scheduling.
Change-Id: Ic1480ae9d37bba687586094cf6d0274db9c5b28a
(This is a direct cherry-pick from 2.6.39: I3b925802)
Fixed procreader for /proc/net/xt_qtaguid/ctrl: it would just
fill the output with the same entry.
Simplify the **start handling.
Change-Id: I3b92580228f2b57795bb2d0d6197fc95ab6be552
(This is a direct cherry pick from 2.6.39: Id2a9912b)
* xt_socket_get_sk() returns invalid sockets when the sk_state is TCP_TIME_WAIT.
Added detection of time-wait.
* Added more constrained usage: qtaguid insures that xt_socket_get*_sk() is
not invoked for unexpected hooks or protocols (but I have not seen those
active at the point where the returned sk is bad).
Change-Id: Id2a9912bb451a3e59d012fc55bbbd40fbb90693f
ip_route_output_key can return an ERR_PTR, don't dereference it.
Change-Id: I6b86a451b2bdb33873d79b3cf90c11dbe72bc081
Signed-off-by: Colin Cross <ccross@android.com>
Allow the REJECT --reject-with icmp*blabla to also set the matching error
locally on the socket affected by the reject.
This allows the process to see an error almost as if it received it
via ICMP.
It avoids the local process who's ingress packet is rejected to have to
wait for a pseudo-eternity until some timeout kicks in.
Ideally, this should be enabled with a new iptables flag similar to
--reject-with-sock-err
For now it is enabled with CONFIG_IP*_NF_TARGET_REJECT_SKERR option.
Change-Id: I649a4fd5940029ec0b3233e5abb205da6984891e
This module allows tracking stats at the socket level for given UIDs.
It replaces xt_owner.
If the --uid-owner is not specified, it will just count stats based on
who the skb belongs to. This will even happen on incoming skbs as it
looks into the skb via xt_socket magic to see who owns it.
If an skb is lost, it will be assigned to uid=0.
To control what sockets of what UIDs are tagged by what, one uses:
echo t $sock_fd $accounting_tag $the_billed_uid \
So whenever an skb belongs to a sock_fd, it will be accounted against
$the_billed_uid
and matching stats will show up under the uid with the given
$accounting_tag.
Because the number of allocations for the stats structs is not that big:
~500 apps * 32 per app
we'll just do it atomic. This avoids walking lists many times, and
the fancy worker thread handling. Slabs will grow when needed later.
It use netdevice and inetaddr notifications instead of hooks in the core dev
code to track when a device comes and goes. This removes the need for
exposed iface_stat.h.
Put procfs dirs in /proc/net/xt_qtaguid/
ctrl
stats
iface_stat/<iface>/...
The uid stats are obtainable in ./stats.
Change-Id: I01af4fd91c8de651668d3decb76d9bdc1e343919
The socket matching function has some nifty logic to get the struct sock
from the skb or from the connection tracker.
We export this so other xt_* can use it, similarly to ho how
xt_socket uses nf_tproxy_get_sock.
Change-Id: I11c58f59087e7f7ae09e4abd4b937cd3370fa2fd
__u16 sco_pkt_type is introduced to struct sockaddr_sco. It allows bitwise
selection of SCO/eSCO packet types. Currently those bits are:
0x0001 HV1 may be used.
0x0002 HV2 may be used.
0x0004 HV3 may be used.
0x0008 EV3 may be used.
0x0010 EV4 may be used.
0x0020 EV5 may be used.
0x0040 2-EV3 may be used.
0x0080 3-EV3 may be used.
0x0100 2-EV5 may be used.
0x0200 3-EV5 may be used.
This is similar to the Packet Type parameter in the HCI Setup Synchronous
Connection Command, except that we are not reversing the logic on the EDR bits.
This makes the use of sco_pkt_tpye forward portable for the use case of
white-listing packet types, which we expect will be the primary use case.
If sco_pkt_type is zero, or userspace uses the old struct sockaddr_sco,
then the default behavior is to allow all packet types.
Packet type selection is just a request made to the Bluetooth chipset, and
it is up to the link manager on the chipset to negiotiate and decide on the
actual packet types used. Furthermore, when a SCO/eSCO connection is eventually
made there is no way for the host stack to determine which packet type was used
(however it is possible to get the link type of SCO or eSCO).
sco_pkt_type is ignored for incoming SCO connections. It is possible
to add this in the future as a parameter to the Accept Synchronous Connection
Command, however its a little trickier because the kernel does not
currently preserve sockaddr_sco data between userspace calls to accept().
The most common use for sco_pkt_type will be to white-list only SCO packets,
which can be done with the hci.h constant SCO_ESCO_MASK.
This patch is motivated by broken Bluetooth carkits such as the Motorolo
HF850 (it claims to support eSCO, but will actually reject eSCO connections
after 5 seconds) and the 2007/2008 Infiniti G35/37 (fails to route audio
if a 2-EV5 packet type is negiotiated). With this patch userspace can maintain
a list of compatible packet types to workaround remote devices such as these.
Based on a patch by Marcel Holtmann.
Rebased to 2.6.39.
Change-Id: Ide1c89574fa4f6f1b9218282e1af17051eb86315
Signed-off-by: Nick Pelly <npelly@google.com>
Change-Id: I247b8dc2e32bb83e731209928600e92892dd042c
On Linux, when an interface goes down all its IPv6
addresses are deleted, so relying on knowing the previous
IPv6 addresses on the interface is brittle. Instead,
support nuking all sockets that are bound to IP addresses
that are not configured and up on the system. This
behaviour is triggered by specifying the unspecified
address (:: or 0.0.0.0). If an IP address is specified, the
behaviour is unchanged, except the ioctl now supports IPv6
as well as IPv4.
When enabled, tracks the frequency of network transmissions
(inbound and outbound) and buckets them accordingly.
Buckets are determined by time between network activity.
Each bucket represents the number of network transmisions that were
N sec or longer apart. Where N is defined as 1 << bucket index.
This network pattern tracking is particularly useful for wireless
networks (ie: 3G) where batching network activity closely together
is more power efficient than far apart.
New file: /proc/net/stat/activity
output:
Min Bucket(sec) Count
1 7
2 0
4 1
8 0
16 0
32 2
64 1
128 0
Change-Id: I4c4cd8627b872a55f326b1715c51bc3bdd6e8d92
Signed-off-by: Mike Chan <mike@android.com>
This provides userspace debugging tools access to ACL flow control state.
This is to support the Motorola HF850 carkit which reports the error code 0x10
for an eSCO attempt, even though it advertises eSCO support. Here is the
hcidump:
2009-09-22 15:40:24.492391 < HCI Command: Setup Synchronous Connection
(0x01|0x0028) plen 17
handle 1 voice setting 0x0060
2009-09-22 15:40:24.493002 > HCI Event: Command Status (0x0f) plen 4
Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1
2009-09-22 15:40:30.594869 > HCI Event: Synchronous Connect Complete (0x2c)
plen 17
status 0x10 handle 257 bdaddr 00:50:CD:20:C6:84 type eSCO
Error: Connection Accept Timeout Exceeded
With this patch we will retry with a SCO connection, which succeeds.
Unfortunately the Moto HF850 also takes 5 seconds to return the error for the
eSCO attempt, so it will still take 5 seconds to fallback to SCO with this
patch.
This fixes a bug where shutdown() and close() on a rfcomm socket during ACL
connection would not cause HCI Create Connection Cancel.
