[ Upstream commit 4bcd4ec1017205644a2697bccbc3b5143f522f5f ]
We find that sysctl_tipc_rmem and named_timeout do not have the right minimum
setting. sysctl_tipc_rmem should be larger than zero, like sysctl_tcp_rmem.
And named_timeout as a timeout setting should be not less than zero.
Fixes: cc79dd1ba9c10 ("tipc: change socket buffer overflow control to respect sk_rcvbuf")
Fixes: a5325ae5b8bff ("tipc: add name distributor resiliency queue")
Signed-off-by: Jie Liu <liujie165@huawei.com>
Reported-by: Qiang Ning <ningqiang1@huawei.com>
Reviewed-by: Zhiqiang Liu <liuzhiqiang26@huawei.com>
Reviewed-by: Miaohe Lin <linmiaohe@huawei.com>
[ Upstream commit 737889efe9713a0f20a75fd0de952841d9275e6b ]
When checking the code with clang -Wsometimes-uninitialized we get the
following warning:
if (!tipc_link_is_establishing(l)) {
net/tipc/node.c:847:46: note: uninitialized use occurs here
tipc_bearer_xmit(n->net, bearer_id, &xmitq, maddr);
net/tipc/node.c:831:2: note: remove the 'if' if its condition is always
true
net/tipc/node.c:821:31: note: initialize the variable 'maddr' to silence
this warning
struct tipc_media_addr *maddr;
We fix this by initializing 'maddr' to NULL. For the matter of clarity,
we also test if 'xmitq' is non-empty before we use it and 'maddr'
further down in the function. It will never happen that 'xmitq' is non-
empty at the same time as 'maddr' is NULL, so this is a sufficient test.
Fixes: 598411d70f85 ("tipc: make resetting of links non-atomic")
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 3b02b0adc242a72b5e46019b6a9e4f84823592f6 ]
Call jhash_1word() for the 4-bytes key case from the insertion and
deactivation path, otherwise big endian arch set lookups fail.
Fixes: 446a8268b7f5 ("netfilter: nft_set_hash: add lookup variant for fixed size hashtable")
Reported-by: Florian Westphal <fw@strlen.de>
Tested-by: Florian Westphal <fw@strlen.de>
commit 12db3c8083fcab4270866a88191933f2d9f24f89 upstream.
In function __tipc_shutdown(), the timeout value passed to
tipc_wait_for_cond() is not jiffies.
This commit fixes it by converting that value from milliseconds
to jiffies.
Fixes: 365ad353c256 ("tipc: reduce risk of user starvation during link congestion")
Signed-off-by: Tung Nguyen <tung.q.nguyen@dektech.com.au>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
commit 24953de0a5e31dcca7e82c8a3c79abc2dfe8fb6e upstream.
Check if set_wiphy_params is assigned and return an error if not,
some drivers (e.g. virt_wifi where syzbot reported it) don't have
it.
Reported-by: syzbot+e8a797964a4180eb57d5@syzkaller.appspotmail.com
Reported-by: syzbot+34b582cf32c1db008f8e@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20200113125358.ac07f276efff.Ibd85ee1b12e47b9efb00a2adc5cd3fac50da791a@changeid
[ Upstream commit e176b1ba476cf36f723cfcc7a9e57f3cb47dec70 ]
When the packet pointed to by retransmit_skb_hint is unlinked by ACK,
retransmit_skb_hint will be set to NULL in tcp_clean_rtx_queue().
If packet loss is detected at this time, retransmit_skb_hint will be set
to point to the current packet loss in tcp_verify_retransmit_hint(),
then the packets that were previously marked lost but not retransmitted
due to the restriction of cwnd will be skipped and cannot be
retransmitted.
To fix this, when retransmit_skb_hint is NULL, retransmit_skb_hint can
be reset only after all marked lost packets are retransmitted
(retrans_out >= lost_out), otherwise we need to traverse from
tcp_rtx_queue_head in tcp_xmit_retransmit_queue().
Packetdrill to demonstrate:
// Disable RACK and set max_reordering to keep things simple
0 `sysctl -q net.ipv4.tcp_recovery=0`
+0 `sysctl -q net.ipv4.tcp_max_reordering=3`
// Establish a connection
+0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+.1 < S 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
+0 > S. 0:0(0) ack 1 <...>
+.01 < . 1:1(0) ack 1 win 257
+0 accept(3, ..., ...) = 4
// Send 8 data segments
+0 write(4, ..., 8000) = 8000
+0 > P. 1:8001(8000) ack 1
// Enter recovery and 1:3001 is marked lost
+.01 < . 1:1(0) ack 1 win 257 <sack 3001:4001,nop,nop>
+0 < . 1:1(0) ack 1 win 257 <sack 5001:6001 3001:4001,nop,nop>
+0 < . 1:1(0) ack 1 win 257 <sack 5001:7001 3001:4001,nop,nop>
// Retransmit 1:1001, now retransmit_skb_hint points to 1001:2001
+0 > . 1:1001(1000) ack 1
// 1001:2001 was ACKed causing retransmit_skb_hint to be set to NULL
+.01 < . 1:1(0) ack 2001 win 257 <sack 5001:8001 3001:4001,nop,nop>
// Now retransmit_skb_hint points to 4001:5001 which is now marked lost
// BUG: 2001:3001 was not retransmitted
+0 > . 2001:3001(1000) ack 1
Signed-off-by: Pengcheng Yang <yangpc@wangsu.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Tested-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit bd5874da57edd001b35cf28ae737779498c16a56 ]
DSA subsystem takes care of netdev statistics since commit 4ed70ce9f01c
("net: dsa: Refactor transmit path to eliminate duplication"), so
any accounting inside tagger callbacks is redundant and can lead to
messing up the stats.
This bug is present in Qualcomm tagger since day 0.
Fixes: cafdc45c949b ("net-next: dsa: add Qualcomm tag RX/TX handler")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Alexander Lobakin <alobakin@dlink.ru>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
commit 4cc4a1708903f404d2ca0dfde30e71e052c6cbc9 upstream.
The distributed arp table is using a DHT to store and retrieve MAC address
information for an IP address. This is done using unicast messages to
selected peers. The potential peers are looked up using the IP address and
the VID.
While the IP address is always stored in big endian byte order, this is not
the case of the VID. It can (depending on the host system) either be big
endian or little endian. The host must therefore always convert it to big
endian to ensure that all devices calculate the same peers for the same
lookup data.
Fixes: be1db4f6615b ("batman-adv: make the Distributed ARP Table vlan aware")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
commit 212e7f56605ef9688d0846db60c6c6ec06544095 upstream.
An earlier commit (1b789577f655060d98d20e,
"netfilter: arp_tables: init netns pointer in xt_tgchk_param struct")
fixed missing net initialization for arptables, but turns out it was
incomplete. We can get a very similar struct net NULL deref during
error unwinding:
general protection fault: 0000 [#1] PREEMPT SMP KASAN
RIP: 0010:xt_rateest_put+0xa1/0x440 net/netfilter/xt_RATEEST.c:77
xt_rateest_tg_destroy+0x72/0xa0 net/netfilter/xt_RATEEST.c:175
cleanup_entry net/ipv4/netfilter/arp_tables.c:509 [inline]
translate_table+0x11f4/0x1d80 net/ipv4/netfilter/arp_tables.c:587
do_replace net/ipv4/netfilter/arp_tables.c:981 [inline]
do_arpt_set_ctl+0x317/0x650 net/ipv4/netfilter/arp_tables.c:1461
Also init the netns pointer in xt_tgdtor_param struct.
Fixes: add67461240c1d ("netfilter: add struct net * to target parameters")
Reported-by: syzbot+91bdd8eece0f6629ec8b@syzkaller.appspotmail.com
commit c120959387efa51479056fd01dc90adfba7a590c upstream.
map->members is freed by ip_set_free() right before using it in
mtype_ext_cleanup() again. So we just have to move it down.
Reported-by: syzbot+4c3cc6dbe7259dbf9054@syzkaller.appspotmail.com
Fixes: 40cd63bf33b2 ("netfilter: ipset: Support extensions which need a per data destroy function")
Acked-by: Jozsef Kadlecsik <kadlec@netfilter.org>
commit 81c044fc3bdc5b7be967cd3682528ea94b58c06a upstream.
The fragments attached to a skb can be part of a compound page. In that case,
page_ref_inc will increment the refcount for the wrong page. Fix this by
using get_page instead, which calls page_ref_inc on the compound head and
also checks for overflow.
Fixes: 2b67f944f88c ("cfg80211: reuse existing page fragments in A-MSDU rx")
Cc: stable@vger.kernel.org
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Link: https://lore.kernel.org/r/20200113182107.20461-1-nbd@nbd.name
commit 9d7bf41fafa5b5ddd4c13eb39446b0045f0a8167 upstream.
Unlike the normal SIOCOUTQ, SIOCOUTQNSD was never handled in compat
mode. Add it to the common socket compat handler along with similar
ones.
Fixes: 2f4e1b397097 ("tcp: ioctl type SIOCOUTQNSD returns amount of data not sent")
Cc: Eric Dumazet <edumazet@google.com>
Cc: netdev@vger.kernel.org
commit 5f6beb9e0f633f3cc845cdd67973c506372931b4 upstream.
The af_unix protocol family has a custom ioctl command (inexplicibly
based on SIOCPROTOPRIVATE), but never had a compat_ioctl handler for
32-bit applications.
Since all commands are compatible here, add a trivial wrapper that
performs the compat_ptr() conversion for SIOCOUTQ/SIOCINQ. SIOCUNIXFILE
does not use the argument, but it doesn't hurt to also use compat_ptr()
here.
Fixes: ba94f3088b79 ("unix: add ioctl to open a unix socket file with O_PATH")
commit 13cb886c591f341a8759f175292ddf978ef903a1 upstream.
I've found that on occasion, "rmmod <dev>" will hang while if an NFS
is under load.
Ensure that ri_remove_done is initialized only just before the
transport is woken up to force a close. This avoids the completion
possibly getting initialized again while the CM event handler is
waiting for a wake-up.
Fixes: bebd031866ca ("xprtrdma: Support unplugging an HCA from under an NFS mount")
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 3ed0a1d563903bdb4b4c36c58c4d9c1bcb23a6e6 upstream.
The supervision frame is L2 frame.
When supervision frame is created, hsr module doesn't set network header.
If tap routine is enabled, dev_queue_xmit_nit() is called and it checks
network_header. If network_header pointer wasn't set(or invalid),
it resets network_header and warns.
In order to avoid unnecessary warning message, resetting network_header
is needed.
Test commands:
ip netns add nst
ip link add veth0 type veth peer name veth1
ip link add veth2 type veth peer name veth3
ip link set veth1 netns nst
ip link set veth3 netns nst
ip link set veth0 up
ip link set veth2 up
ip link add hsr0 type hsr slave1 veth0 slave2 veth2
ip a a 192.168.100.1/24 dev hsr0
ip link set hsr0 up
ip netns exec nst ip link set veth1 up
ip netns exec nst ip link set veth3 up
ip netns exec nst ip link add hsr1 type hsr slave1 veth1 slave2 veth3
ip netns exec nst ip a a 192.168.100.2/24 dev hsr1
ip netns exec nst ip link set hsr1 up
tcpdump -nei veth0
Splat looks like:
[ 175.852292][ C3] protocol 88fb is buggy, dev veth0
Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)")
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
commit 1d3ff0950e2b40dc861b1739029649d03f591820 upstream.
If dccp_feat_push_change fails, we forget free the mem
which is alloced by kmemdup in dccp_feat_clone_sp_val.
Fixes: e8ef967a54f4 ("dccp: Registration routines for changing feature values")
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 3e493173b7841259a08c5c8e5cbe90adb349da7e upstream.
The Layer 2 Update frame is used to update bridges when a station roams
to another AP even if that STA does not transmit any frames after the
reassociation. This behavior was described in IEEE Std 802.11F-2003 as
something that would happen based on MLME-ASSOCIATE.indication, i.e.,
before completing 4-way handshake. However, this IEEE trial-use
recommended practice document was published before RSN (IEEE Std
802.11i-2004) and as such, did not consider RSN use cases. Furthermore,
IEEE Std 802.11F-2003 was withdrawn in 2006 and as such, has not been
maintained amd should not be used anymore.
Sending out the Layer 2 Update frame immediately after association is
fine for open networks (and also when using SAE, FT protocol, or FILS
authentication when the station is actually authenticated by the time
association completes). However, it is not appropriate for cases where
RSN is used with PSK or EAP authentication since the station is actually
fully authenticated only once the 4-way handshake completes after
authentication and attackers might be able to use the unauthenticated
triggering of Layer 2 Update frame transmission to disrupt bridge
behavior.
Fix this by postponing transmission of the Layer 2 Update frame from
station entry addition to the point when the station entry is marked
authorized. Similarly, send out the VLAN binding update only if the STA
entry has already been authorized.
Signed-off-by: Jouni Malinen <jouni@codeaurora.org>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
commit 30ca1aa536211f5ac3de0173513a7a99a98a97f3 upstream.
Make ieee80211_send_layer2_update() a common function so other drivers
can re-use it.
Signed-off-by: Dedy Lansky <dlansky@codeaurora.org>
[bwh: Backported to 4.14 as dependency of commit 3e493173b784
"mac80211: Do not send Layer 2 Update frame before authorization"]
commit 3499e87ea0413ee5b2cc028f4c8ed4d424bc7f98 upstream.
clang inlines the dev_ethtool() more aggressively than gcc does, leading
to a larger amount of used stack space:
net/core/ethtool.c:2536:24: error: stack frame size of 1216 bytes in function 'dev_ethtool' [-Werror,-Wframe-larger-than=]
Marking the sub-functions that require the most stack space as
noinline_for_stack gives us reasonable behavior on all compilers.
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
Signed-off-by: Miles Chen <miles.chen@mediatek.com>
commit 22dad713b8a5ff488e07b821195270672f486eb2 upstream.
The set uadt functions assume lineno is never NULL, but it is in
case of ip_set_utest().
syzkaller managed to generate a netlink message that calls this with
LINENO attr present:
RIP: 0010:hash_mac4_uadt+0x1bc/0x470 net/netfilter/ipset/ip_set_hash_mac.c:104
Call Trace:
ip_set_utest+0x55b/0x890 net/netfilter/ipset/ip_set_core.c:1867
nfnetlink_rcv_msg+0xcf2/0xfb0 net/netfilter/nfnetlink.c:229
netlink_rcv_skb+0x177/0x450 net/netlink/af_netlink.c:2477
nfnetlink_rcv+0x1ba/0x460 net/netfilter/nfnetlink.c:563
pass a dummy lineno storage, its easier than patching all set
implementations.
This seems to be a day-0 bug.
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Reported-by: syzbot+34bd2369d38707f3f4a7@syzkaller.appspotmail.com
Fixes: a7b4f989a6294 ("netfilter: ipset: IP set core support")
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
commit 1b789577f655060d98d20ed0c6f9fbd469d6ba63 upstream.
We get crash when the targets checkentry function tries to make
use of the network namespace pointer for arptables.
When the net pointer got added back in 2010, only ip/ip6/ebtables were
changed to initialize it, so arptables has this set to NULL.
This isn't a problem for normal arptables because no existing
arptables target has a checkentry function that makes use of par->net.
However, direct users of the setsockopt interface can provide any
target they want as long as its registered for ARP or UNPSEC protocols.
syzkaller managed to send a semi-valid arptables rule for RATEEST target
which is enough to trigger NULL deref:
kasan: GPF could be caused by NULL-ptr deref or user memory access
RIP: xt_rateest_tg_checkentry+0x11d/0xb40 net/netfilter/xt_RATEEST.c:109
xt_check_target+0x283/0x690 net/netfilter/x_tables.c:1019
check_target net/ipv4/netfilter/arp_tables.c:399 [inline]
find_check_entry net/ipv4/netfilter/arp_tables.c:422 [inline]
translate_table+0x1005/0x1d70 net/ipv4/netfilter/arp_tables.c:572
do_replace net/ipv4/netfilter/arp_tables.c:977 [inline]
do_arpt_set_ctl+0x310/0x640 net/ipv4/netfilter/arp_tables.c:1456
Reported-by: syzbot+d7358a458d8a81aee898@syzkaller.appspotmail.com
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 9bbd917e0bec9aebdbd0c8dbc966caec15eb33e9 ]
There are few cases where the ndo_uninit() handler might be not
called if an error happens while device is initialized.
Since vlan_newlink() calls vlan_changelink() before
trying to register the netdevice, we need to make sure
vlan_dev_uninit() has been called at least once,
or we might leak allocated memory.
BUG: memory leak
unreferenced object 0xffff888122a206c0 (size 32):
comm "syz-executor511", pid 7124, jiffies 4294950399 (age 32.240s)
hex dump (first 32 bytes):
00 00 00 00 00 00 61 73 00 00 00 00 00 00 00 00 ......as........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<000000000eb3bb85>] kmemleak_alloc_recursive include/linux/kmemleak.h:43 [inline]
[<000000000eb3bb85>] slab_post_alloc_hook mm/slab.h:586 [inline]
[<000000000eb3bb85>] slab_alloc mm/slab.c:3320 [inline]
[<000000000eb3bb85>] kmem_cache_alloc_trace+0x145/0x2c0 mm/slab.c:3549
[<000000007b99f620>] kmalloc include/linux/slab.h:556 [inline]
[<000000007b99f620>] vlan_dev_set_egress_priority+0xcc/0x150 net/8021q/vlan_dev.c:194
[<000000007b0cb745>] vlan_changelink+0xd6/0x140 net/8021q/vlan_netlink.c:126
[<0000000065aba83a>] vlan_newlink+0x135/0x200 net/8021q/vlan_netlink.c:181
[<00000000fb5dd7a2>] __rtnl_newlink+0x89a/0xb80 net/core/rtnetlink.c:3305
[<00000000ae4273a1>] rtnl_newlink+0x4e/0x80 net/core/rtnetlink.c:3363
[<00000000decab39f>] rtnetlink_rcv_msg+0x178/0x4b0 net/core/rtnetlink.c:5424
[<00000000accba4ee>] netlink_rcv_skb+0x61/0x170 net/netlink/af_netlink.c:2477
[<00000000319fe20f>] rtnetlink_rcv+0x1d/0x30 net/core/rtnetlink.c:5442
[<00000000d51938dc>] netlink_unicast_kernel net/netlink/af_netlink.c:1302 [inline]
[<00000000d51938dc>] netlink_unicast+0x223/0x310 net/netlink/af_netlink.c:1328
[<00000000e539ac79>] netlink_sendmsg+0x2c0/0x570 net/netlink/af_netlink.c:1917
[<000000006250c27e>] sock_sendmsg_nosec net/socket.c:639 [inline]
[<000000006250c27e>] sock_sendmsg+0x54/0x70 net/socket.c:659
[<00000000e2a156d1>] ____sys_sendmsg+0x2d0/0x300 net/socket.c:2330
[<000000008c87466e>] ___sys_sendmsg+0x8a/0xd0 net/socket.c:2384
[<00000000110e3054>] __sys_sendmsg+0x80/0xf0 net/socket.c:2417
[<00000000d71077c8>] __do_sys_sendmsg net/socket.c:2426 [inline]
[<00000000d71077c8>] __se_sys_sendmsg net/socket.c:2424 [inline]
[<00000000d71077c8>] __x64_sys_sendmsg+0x23/0x30 net/socket.c:2424
Fixe: 07b5b17e157b ("[VLAN]: Use rtnl_link API")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 240ce7f6428ff5188b9eedc066e1e4d645b8635f ]
When a child Qdisc is removed from one of the PRIO Qdisc's bands, it is
replaced unconditionally by a NOOP qdisc. As a result, any traffic hitting
that band gets dropped. That is incorrect--no Qdisc was explicitly added
when PRIO was created, and after removal, none should have to be added
either.
Fix PRIO by first attempting to create a default Qdisc and only falling
back to noop when that fails. This pattern of attempting to create an
invisible FIFO, using NOOP only as a fallback, is also seen in other
Qdiscs.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Petr Machata <petrm@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit eb8ef2a3c50092bb018077c047b8dba1ce0e78e3 ]
Both vlan_dev_change_flags() and vlan_dev_set_egress_priority()
can return an error. vlan_changelink() should not ignore them.
Fixes: 07b5b17e157b ("[VLAN]: Use rtnl_link API")
[ Upstream commit c9655008e7845bcfdaac10a1ed8554ec167aea88 ]
When we receive a D-SACK, where the sequence number satisfies:
undo_marker <= start_seq < end_seq <= prior_snd_una
we consider this is a valid D-SACK and tcp_is_sackblock_valid()
returns true, then this D-SACK is discarded as "old stuff",
but the variable first_sack_index is not marked as negative
in tcp_sacktag_write_queue().
If this D-SACK also carries a SACK that needs to be processed
(for example, the previous SACK segment was lost), this SACK
will be treated as a D-SACK in the following processing of
tcp_sacktag_write_queue(), which will eventually lead to
incorrect updates of undo_retrans and reordering.
Fixes: fd6dad616d4f ("[TCP]: Earlier SACK block verification & simplify access to them")
[ Upstream commit be7a7729207797476b6666f046d765bdf9630407 ]
This patch is to fix a memleak caused by no place to free cmd->obj.chunk
for the unprocessed SCTP_CMD_REPLY. This issue occurs when failing to
process a cmd while there're still SCTP_CMD_REPLY cmds on the cmd seq
with an allocated chunk in cmd->obj.chunk.
So fix it by freeing cmd->obj.chunk for each SCTP_CMD_REPLY cmd left on
the cmd seq when any cmd returns error. While at it, also remove 'nomem'
label.
Reported-by: syzbot+107c4aff5f392bf1517f@syzkaller.appspotmail.com
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit d9e15a2733067c9328fb56d98fe8e574fa19ec31 ]
As diagnosed by Florian :
If TCA_FQ_QUANTUM is set to 0x80000000, fq_deueue()
can loop forever in :
if (f->credit <= 0) {
f->credit += q->quantum;
goto begin;
... because f->credit is either 0 or -2147483648.
Let's limit TCA_FQ_QUANTUM to no more than 1 << 20 :
This max value should limit risks of breaking user setups
while fixing this bug.
Fixes: afe4fd062416 ("pkt_sched: fq: Fair Queue packet scheduler")
Diagnosed-by: Florian Westphal <fw@strlen.de>
Reported-by: syzbot+dc9071cc5a85950bdfce@syzkaller.appspotmail.com
[ Upstream commit af1c0e4e00f3cc76cb136ebf2e2c04e8b6446285 ]
When a frame with NULL DSAP is received, llc_station_rcv is called.
In turn, llc_stat_ev_rx_null_dsap_xid_c is called to check if it is a NULL
XID frame. The return statement of llc_stat_ev_rx_null_dsap_xid_c returns 1
when the incoming frame is not a NULL XID frame and 0 otherwise. Hence, a
NULL XID response is returned unexpectedly, e.g. when the incoming frame is
a NULL TEST command.
To fix the error, simply remove the conditional operator.
A similar error in llc_stat_ev_rx_null_dsap_test_c is also fixed.
Signed-off-by: Chan Shu Tak, Alex <alexchan@task.com.hk>
[ Upstream commit 6fc232db9e8cd50b9b83534de9cd91ace711b2d7 ]
In rfkill_register, the struct rfkill pointer is first derefernced
and then checked for NULL. This patch removes the BUG_ON and returns
an error to the caller in case rfkill is NULL.
Signed-off-by: Aditya Pakki <pakki001@umn.edu>
Link: https://lore.kernel.org/r/20191215153409.21696-1-pakki001@umn.edu
[ Upstream commit bffc124b6fe37d0ae9b428d104efb426403bb5c9 ]
Only NFTA_SET_ELEM_KEY and NFTA_SET_ELEM_FLAGS make sense for elements
whose NFT_SET_ELEM_INTERVAL_END flag is set on.
Fixes: 96518518cc41 ("netfilter: add nftables")
[ Upstream commit 18a110b022a5c02e7dc9f6109d0bd93e58ac6ebb ]
Curtis Taylor and Jon Maxwell reported and debugged a crash on 3.10
based kernel.
Crash occurs in ctnetlink_conntrack_events because net->nfnl socket is
NULL. The nfnl socket was set to NULL by netns destruction running on
another cpu.
The exiting network namespace calls the relevant destructors in the
following order:
1. ctnetlink_net_exit_batch
This nulls out the event callback pointer in struct netns.
2. nfnetlink_net_exit_batch
This nulls net->nfnl socket and frees it.
3. nf_conntrack_cleanup_net_list
This removes all remaining conntrack entries.
This is order is correct. The only explanation for the crash so ar is:
cpu1: conntrack is dying, eviction occurs:
-> nf_ct_delete()
-> nf_conntrack_event_report \
-> nf_conntrack_eventmask_report
-> notify->fcn() (== ctnetlink_conntrack_events).
cpu1: a. fetches rcu protected pointer to obtain ctnetlink event callback.
b. gets interrupted.
cpu2: runs netns exit handlers:
a runs ctnetlink destructor, event cb pointer set to NULL.
b runs nfnetlink destructor, nfnl socket is closed and set to NULL.
cpu1: c. resumes and trips over NULL net->nfnl.
Problem appears to be that ctnetlink_net_exit_batch only prevents future
callers of nf_conntrack_eventmask_report() from obtaining the callback.
It doesn't wait of other cpus that might have already obtained the
callbacks address.
I don't see anything in upstream kernels that would prevent similar
crash: We need to wait for all cpus to have exited the event callback.
Fixes: 9592a5c01e79dbc59eb56fa ("netfilter: ctnetlink: netns support")
[ Upstream commit c305c6ae79e2ce20c22660ceda94f0d86d639a82 ]
KCSAN reported a data-race [1]
While we can use READ_ONCE() on the read sides,
we need to make sure hh->hh_len is written last.
[1]
BUG: KCSAN: data-race in eth_header_cache / neigh_resolve_output
write to 0xffff8880b9dedcb8 of 4 bytes by task 29760 on cpu 0:
eth_header_cache+0xa9/0xd0 net/ethernet/eth.c:247
neigh_hh_init net/core/neighbour.c:1463 [inline]
neigh_resolve_output net/core/neighbour.c:1480 [inline]
neigh_resolve_output+0x415/0x470 net/core/neighbour.c:1470
neigh_output include/net/neighbour.h:511 [inline]
ip6_finish_output2+0x7a2/0xec0 net/ipv6/ip6_output.c:116
__ip6_finish_output net/ipv6/ip6_output.c:142 [inline]
__ip6_finish_output+0x2d7/0x330 net/ipv6/ip6_output.c:127
ip6_finish_output+0x41/0x160 net/ipv6/ip6_output.c:152
NF_HOOK_COND include/linux/netfilter.h:294 [inline]
ip6_output+0xf2/0x280 net/ipv6/ip6_output.c:175
dst_output include/net/dst.h:436 [inline]
NF_HOOK include/linux/netfilter.h:305 [inline]
ndisc_send_skb+0x459/0x5f0 net/ipv6/ndisc.c:505
ndisc_send_ns+0x207/0x430 net/ipv6/ndisc.c:647
rt6_probe_deferred+0x98/0xf0 net/ipv6/route.c:615
process_one_work+0x3d4/0x890 kernel/workqueue.c:2269
worker_thread+0xa0/0x800 kernel/workqueue.c:2415
kthread+0x1d4/0x200 drivers/block/aoe/aoecmd.c:1253
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:352
read to 0xffff8880b9dedcb8 of 4 bytes by task 29572 on cpu 1:
neigh_resolve_output net/core/neighbour.c:1479 [inline]
neigh_resolve_output+0x113/0x470 net/core/neighbour.c:1470
Reported by Kernel Concurrency Sanitizer on:
CPU: 1 PID: 29572 Comm: kworker/1:4 Not tainted 5.4.0-rc6+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Workqueue: events rt6_probe_deferred
[ Upstream commit f0308fb0708078d6c1d8a4d533941a7a191af634 ]
If an ICMP packet comes in on the UDP socket backing an AF_RXRPC socket as
the UDP socket is being shut down, rxrpc_error_report() may get called to
deal with it after sk_user_data on the UDP socket has been cleared, leading
to a NULL pointer access when this local endpoint record gets accessed.
Fix this by just returning immediately if sk_user_data was NULL.
The oops looks like the following:
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
RIP: 0010:rxrpc_error_report+0x1bd/0x6a9
Call Trace:
? sock_queue_err_skb+0xbd/0xde
? __udp4_lib_err+0x313/0x34d
icmp_unreach+0x1ee/0x207
icmp_rcv+0x25b/0x28f
ip_protocol_deliver_rcu+0x95/0x10e
ip_local_deliver+0xe9/0x148
__netif_receive_skb_one_core+0x52/0x6e
process_backlog+0xdc/0x177
net_rx_action+0xf9/0x270
__do_softirq+0x1b6/0x39a
? smpboot_register_percpu_thread+0xce/0xce
run_ksoftirqd+0x1d/0x42
smpboot_thread_fn+0x19e/0x1b3
kthread+0xf1/0xf6
? kthread_delayed_work_timer_fn+0x83/0x83
ret_from_fork+0x24/0x30
Fixes: 17926a79320a ("[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel both")
Reported-by: syzbot+611164843bd48cc2190c@syzkaller.appspotmail.com
commit d088337c38a5cd8f0230fbf2d514ff7672f9d0d3 upstream.
In the implementation of hci_connect_le_scan() when conn is added via
hci_conn_add(), if hci_explicit_conn_params_set() fails the allocated
memory for conn is leaked. Use hci_conn_del() to release it.
Fixes: f75113a26008 ("Bluetooth: add hci_connect_le_scan")
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit df66499a1fab340c167250a5743931dc50d5f0fa upstream.
We used to take a lock in amp_physical_cfm() but then we moved it to
the caller function. Unfortunately the unlock on this error path was
overlooked so it leads to a double unlock.
Fixes: a514b17fab51 ("Bluetooth: Refactor locking in amp_physical_cfm")
[ Upstream commit ebfcd8955c0b52eb793bcbc9e71140e3d0cdb228 ]
The socket read/write helpers only look at the file O_NONBLOCK. not
the iocb IOCB_NOWAIT flag. This breaks users like preadv2/pwritev2
and io_uring that rely on not having the file itself marked nonblocking,
but rather the iocb itself.
Acked-by: David Miller <davem@davemloft.net>
[ Upstream commit 1f85e6267caca44b30c54711652b0726fadbb131 ]
Backport of commit fdfc5c8594c2 ("tcp: remove empty skb from
write queue in error cases") in linux-4.14 stable triggered
various bugs. One of them has been fixed in commit ba2ddb43f270
("tcp: Don't dequeue SYN/FIN-segments from write-queue"), but
we still have crashes in some occasions.
Root-cause is that when tcp_sendmsg() has allocated a fresh
skb and could not append a fragment before being blocked
in sk_stream_wait_memory(), tcp_write_xmit() might be called
and decide to send this fresh and empty skb.
Sending an empty packet is not only silly, it might have caused
many issues we had in the past with tp->packets_out being
out of sync.
Fixes: c65f7f00c587 ("[TCP]: Simplify SKB data portion allocation with NETIF_F_SG.")
Cc: Christoph Paasch <cpaasch@apple.com>
Cc: Jason Baron <jbaron@akamai.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
commit 8dbd76e79a16b45b2ccb01d2f2e08dbf64e71e40 upstream.
Michal Kubecek and Firo Yang did a very nice analysis of crashes
happening in __inet_lookup_established().
Since a TCP socket can go from TCP_ESTABLISH to TCP_LISTEN
(via a close()/socket()/listen() cycle) without a RCU grace period,
I should not have changed listeners linkage in their hash table.
They must use the nulls protocol (Documentation/RCU/rculist_nulls.txt),
so that a lookup can detect a socket in a hash list was moved in
another one.
Since we added code in commit d296ba60d8e2 ("soreuseport: Resolve
merge conflict for v4/v6 ordering fix"), we have to add
hlist_nulls_add_tail_rcu() helper.
Fixes: 3b24d854cb35 ("tcp/dccp: do not touch listener sk_refcnt under synflood")
Reported-by: Michal Kubecek <mkubecek@suse.cz>
Reported-by: Firo Yang <firo.yang@suse.com>
Link: https://lore.kernel.org/netdev/20191120083919.GH27852@unicorn.suse.cz/
[stable-4.14: we also need to update code in __inet_lookup_listener() and
inet6_lookup_listener() which has been removed in 5.0-rc1.]
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit 4d42df46d6372ece4cb4279870b46c2ea7304a47 ]
When do IPv6 tunnel PMTU update and calls __ip6_rt_update_pmtu() in the end,
we should not call dst_confirm_neigh() as there is no two-way communication.
v5: No change.
v4: No change.
v3: Do not remove dst_confirm_neigh, but add a new bool parameter in
dst_ops.update_pmtu to control whether we should do neighbor confirm.
Also split the big patch to small ones for each area.
v2: Remove dst_confirm_neigh in __ip6_rt_update_pmtu.
Reviewed-by: Guillaume Nault <gnault@redhat.com>
Acked-by: David Ahern <dsahern@gmail.com>
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit 8247a79efa2f28b44329f363272550c1738377de ]
Although vti and vti6 are immune to this problem because they are IFF_NOARP
interfaces, as Guillaume pointed. There is still no sense to confirm neighbour
here.
v5: Update commit description.
v4: No change.
[ Upstream commit 7a1592bcb15d71400a98632727791d1e68ea0ee8 ]
When do tunnel PMTU update and calls __ip6_rt_update_pmtu() in the end,
v5: No Change.
v4: Update commit description
Fixes: 0dec879f636f ("net: use dst_confirm_neigh for UDP, RAW, ICMP, L2TP")
Tested-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit 675d76ad0ad5bf41c9a129772ef0aba8f57ea9a7 ]
When we do ipv6 gre pmtu update, we will also do neigh confirm currently.
This will cause the neigh cache be refreshed and set to REACHABLE before
xmit.
But if the remote mac address changed, e.g. device is deleted and recreated,
we will not able to notice this and still use the old mac address as the neigh
cache is REACHABLE.
Fix this by disable neigh confirm when do pmtu update
v5: No change.
v4: No change.
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit bd085ef678b2cc8c38c105673dfe8ff8f5ec0c57 ]
The MTU update code is supposed to be invoked in response to real
networking events that update the PMTU. In IPv6 PMTU update function
__ip6_rt_update_pmtu() we called dst_confirm_neigh() to update neighbor
confirmed time.
But for tunnel code, it will call pmtu before xmit, like:
- tnl_update_pmtu()
- skb_dst_update_pmtu()
- ip6_rt_update_pmtu()
- __ip6_rt_update_pmtu()
- dst_confirm_neigh()
If the tunnel remote dst mac address changed and we still do the neigh
confirm, we will not be able to update neigh cache and ping6 remote
will failed.
So for this ip_tunnel_xmit() case, _EVEN_ if the MTU is changed, we
should not be invoking dst_confirm_neigh() as we have no evidence
of successful two-way communication at this point.
On the other hand it is also important to keep the neigh reachability fresh
for TCP flows, so we cannot remove this dst_confirm_neigh() call.
To fix the issue, we have to add a new bool parameter for dst_ops.update_pmtu
to choose whether we should do neigh update or not. I will add the parameter
in this patch and set all the callers to true to comply with the previous
way, and fix the tunnel code one by one on later patches.
v5: No change.
v4: No change.
Suggested-by: David Miller <davem@davemloft.net>
[ Upstream commit feed8a4fc9d46c3126fb9fcae0e9248270c6321a ]
When the size of the receive buffer for a socket is close to 2^31 when
computing if we have enough space in the buffer to copy a packet from
the queue to the buffer we might hit an integer overflow.
When an user set net.core.rmem_default to a value close to 2^31 UDP
packets are dropped because of this overflow. This can be visible, for
instance, with failure to resolve hostnames.
This can be fixed by casting sk_rcvbuf (which is an int) to unsigned
int, similarly to how it is done in TCP.
Signed-off-by: Antonio Messina <amessina@google.com>
commit bbab7ef235031f6733b5429ae7877bfa22339712 upstream.
This code reads two global variables without protection
of a lock. We need READ_ONCE()/WRITE_ONCE() pairs to
avoid load/store-tearing and better document the intent.
KCSAN reported :
BUG: KCSAN: data-race in icmp_global_allow / icmp_global_allow
read to 0xffffffff861a8014 of 4 bytes by task 11201 on cpu 0:
icmp_global_allow+0x36/0x1b0 net/ipv4/icmp.c:254
icmpv6_global_allow net/ipv6/icmp.c:184 [inline]
icmpv6_global_allow net/ipv6/icmp.c:179 [inline]
icmp6_send+0x493/0x1140 net/ipv6/icmp.c:514
icmpv6_send+0x71/0xb0 net/ipv6/ip6_icmp.c:43
ip6_link_failure+0x43/0x180 net/ipv6/route.c:2640
dst_link_failure include/net/dst.h:419 [inline]
vti_xmit net/ipv4/ip_vti.c:243 [inline]
vti_tunnel_xmit+0x27f/0xa50 net/ipv4/ip_vti.c:279
__netdev_start_xmit include/linux/netdevice.h:4420 [inline]
netdev_start_xmit include/linux/netdevice.h:4434 [inline]
xmit_one net/core/dev.c:3280 [inline]
dev_hard_start_xmit+0xef/0x430 net/core/dev.c:3296
__dev_queue_xmit+0x14c9/0x1b60 net/core/dev.c:3873
dev_queue_xmit+0x21/0x30 net/core/dev.c:3906
neigh_direct_output+0x1f/0x30 net/core/neighbour.c:1530
ip6_finish_output2+0x7a6/0xec0 net/ipv6/ip6_output.c:116
ip6_local_out+0x74/0x90 net/ipv6/output_core.c:179
write to 0xffffffff861a8014 of 4 bytes by task 11183 on cpu 1:
icmp_global_allow+0x174/0x1b0 net/ipv4/icmp.c:272
CPU: 1 PID: 11183 Comm: syz-executor.2 Not tainted 5.4.0-rc3+ #0
Fixes: 4cdf507d5452 ("icmp: add a global rate limitation")
commit 71685eb4ce80ae9c49eff82ca4dd15acab215de9 upstream.
We need to explicitely forbid read/store tearing in inet_peer_gc()
and inet_putpeer().
The following syzbot report reminds us about inet_putpeer()
running without a lock held.
BUG: KCSAN: data-race in inet_putpeer / inet_putpeer
write to 0xffff888121fb2ed0 of 4 bytes by interrupt on cpu 0:
inet_putpeer+0x37/0xa0 net/ipv4/inetpeer.c:240
ip4_frag_free+0x3d/0x50 net/ipv4/ip_fragment.c:102
inet_frag_destroy_rcu+0x58/0x80 net/ipv4/inet_fragment.c:228
__rcu_reclaim kernel/rcu/rcu.h:222 [inline]
rcu_do_batch+0x256/0x5b0 kernel/rcu/tree.c:2157
rcu_core+0x369/0x4d0 kernel/rcu/tree.c:2377
rcu_core_si+0x12/0x20 kernel/rcu/tree.c:2386
__do_softirq+0x115/0x33f kernel/softirq.c:292
invoke_softirq kernel/softirq.c:373 [inline]
irq_exit+0xbb/0xe0 kernel/softirq.c:413
exiting_irq arch/x86/include/asm/apic.h:536 [inline]
smp_apic_timer_interrupt+0xe6/0x280 arch/x86/kernel/apic/apic.c:1137
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:830
native_safe_halt+0xe/0x10 arch/x86/kernel/paravirt.c:71
arch_cpu_idle+0x1f/0x30 arch/x86/kernel/process.c:571
default_idle_call+0x1e/0x40 kernel/sched/idle.c:94
cpuidle_idle_call kernel/sched/idle.c:154 [inline]
do_idle+0x1af/0x280 kernel/sched/idle.c:263
write to 0xffff888121fb2ed0 of 4 bytes by interrupt on cpu 1:
run_ksoftirqd+0x46/0x60 kernel/softirq.c:603
smpboot_thread_fn+0x37d/0x4a0 kernel/smpboot.c:165
CPU: 1 PID: 16 Comm: ksoftirqd/1 Not tainted 5.4.0-rc3+ #0
Fixes: 4b9d9be839fd ("inetpeer: remove unused list")
commit 5604285839aaedfb23ebe297799c6e558939334d upstream.
syzbot is kind enough to remind us we need to call skb_may_pull()
BUG: KMSAN: uninit-value in br_nf_forward_arp+0xe61/0x1230 net/bridge/br_netfilter_hooks.c:665
CPU: 1 PID: 11631 Comm: syz-executor.1 Not tainted 5.4.0-rc8-syzkaller #0
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x220 lib/dump_stack.c:118
kmsan_report+0x128/0x220 mm/kmsan/kmsan_report.c:108
__msan_warning+0x64/0xc0 mm/kmsan/kmsan_instr.c:245
nf_hook_entry_hookfn include/linux/netfilter.h:135 [inline]
nf_hook_slow+0x18b/0x3f0 net/netfilter/core.c:512
nf_hook include/linux/netfilter.h:260 [inline]
NF_HOOK include/linux/netfilter.h:303 [inline]
__br_forward+0x78f/0xe30 net/bridge/br_forward.c:109
br_flood+0xef0/0xfe0 net/bridge/br_forward.c:234
br_handle_frame_finish+0x1a77/0x1c20 net/bridge/br_input.c:162
nf_hook_bridge_pre net/bridge/br_input.c:245 [inline]
br_handle_frame+0xfb6/0x1eb0 net/bridge/br_input.c:348
__netif_receive_skb_core+0x20b9/0x51a0 net/core/dev.c:4830
__netif_receive_skb_one_core net/core/dev.c:4927 [inline]
__netif_receive_skb net/core/dev.c:5043 [inline]
process_backlog+0x610/0x13c0 net/core/dev.c:5874
napi_poll net/core/dev.c:6311 [inline]
net_rx_action+0x7a6/0x1aa0 net/core/dev.c:6379
__do_softirq+0x4a1/0x83a kernel/softirq.c:293
do_softirq_own_stack+0x49/0x80 arch/x86/entry/entry_64.S:1091
</IRQ>
do_softirq kernel/softirq.c:338 [inline]
__local_bh_enable_ip+0x184/0x1d0 kernel/softirq.c:190
local_bh_enable+0x36/0x40 include/linux/bottom_half.h:32
rcu_read_unlock_bh include/linux/rcupdate.h:688 [inline]
__dev_queue_xmit+0x38e8/0x4200 net/core/dev.c:3819
dev_queue_xmit+0x4b/0x60 net/core/dev.c:3825
packet_snd net/packet/af_packet.c:2959 [inline]
packet_sendmsg+0x8234/0x9100 net/packet/af_packet.c:2984
sock_sendmsg_nosec net/socket.c:637 [inline]
sock_sendmsg net/socket.c:657 [inline]
__sys_sendto+0xc44/0xc70 net/socket.c:1952
__do_sys_sendto net/socket.c:1964 [inline]
__se_sys_sendto+0x107/0x130 net/socket.c:1960
__x64_sys_sendto+0x6e/0x90 net/socket.c:1960
do_syscall_64+0xb6/0x160 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x45a679
Code: ad b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b6 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f0a3c9e5c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000000006 RCX: 000000000045a679
RDX: 000000000000000e RSI: 0000000020000200 RDI: 0000000000000003
RBP: 000000000075bf20 R08: 00000000200000c0 R09: 0000000000000014
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f0a3c9e66d4
R13: 00000000004c8ec1 R14: 00000000004dfe28 R15: 00000000ffffffff
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:149 [inline]
kmsan_internal_poison_shadow+0x5c/0x110 mm/kmsan/kmsan.c:132
kmsan_slab_alloc+0x97/0x100 mm/kmsan/kmsan_hooks.c:86
slab_alloc_node mm/slub.c:2773 [inline]
__kmalloc_node_track_caller+0xe27/0x11a0 mm/slub.c:4381
__kmalloc_reserve net/core/skbuff.c:141 [inline]
__alloc_skb+0x306/0xa10 net/core/skbuff.c:209
alloc_skb include/linux/skbuff.h:1049 [inline]
alloc_skb_with_frags+0x18c/0xa80 net/core/skbuff.c:5662
sock_alloc_send_pskb+0xafd/0x10a0 net/core/sock.c:2244
packet_alloc_skb net/packet/af_packet.c:2807 [inline]
packet_snd net/packet/af_packet.c:2902 [inline]
packet_sendmsg+0x63a6/0x9100 net/packet/af_packet.c:2984
Fixes: c4e70a87d975 ("netfilter: bridge: rename br_netfilter.c to br_netfilter_hooks.c")
Reviewed-by: Florian Westphal <fw@strlen.de>
commit e608f631f0ba5f1fc5ee2e260a3a35d13107cbfe upstream.
syzbot reported following splat:
BUG: KASAN: vmalloc-out-of-bounds in size_entry_mwt net/bridge/netfilter/ebtables.c:2063 [inline]
BUG: KASAN: vmalloc-out-of-bounds in compat_copy_entries+0x128b/0x1380 net/bridge/netfilter/ebtables.c:2155
Read of size 4 at addr ffffc900004461f4 by task syz-executor267/7937
CPU: 1 PID: 7937 Comm: syz-executor267 Not tainted 5.5.0-rc1-syzkaller #0
compat_do_replace+0x344/0x720 net/bridge/netfilter/ebtables.c:2249
compat_do_ebt_set_ctl+0x22f/0x27e net/bridge/netfilter/ebtables.c:2333
Because padding isn't considered during computation of ->buf_user_offset,
"total" is decremented by fewer bytes than it should.
Therefore, the first part of
if (*total < sizeof(*entry) || entry->next_offset < sizeof(*entry))
will pass, -- it should not have. This causes oob access:
entry->next_offset is past the vmalloced size.
Reject padding and check that computed user offset (sum of ebt_entry
structure plus all individual matches/watchers/targets) is same
value that userspace gave us as the offset of the next entry.
Reported-by: syzbot+f68108fed972453a0ad4@syzkaller.appspotmail.com
Fixes: 81e675c227ec ("netfilter: ebtables: add CONFIG_COMPAT support")
[ Upstream commit 0b9173f4688dfa7c5d723426be1d979c24ce3d51 ]
Bridge packets that are forwarded have skb->dst == NULL and get
dropped by the check introduced by
b60a77386b1d4868f72f6353d35dabe5fbe981f2 (net: make skb_dst_force
return true when dst is refcounted).
To fix this we check skb_dst() before skb_dst_force(), so we don't
drop skb packet with dst == NULL. This holds also for skb at the
PRE_ROUTING hook so we remove the second check.
Fixes: b60a77386b1d ("net: make skb_dst_force return true when dst is refcounted")
Signed-off-by: Marco Oliverio <marco.oliverio@tanaza.com>
Signed-off-by: Rocco Folino <rocco.folino@tanaza.com>
Acked-by: Florian Westphal <fw@strlen.de>
[ Upstream commit 1148f9adbe71415836a18a36c1b4ece999ab0973 ]
proc_dointvec_minmax_bpf_restricted() has been firstly introduced
in commit 2e4a30983b0f ("bpf: restrict access to core bpf sysctls")
under CONFIG_HAVE_EBPF_JIT. Then, this ifdef has been removed in
ede95a63b5e8 ("bpf: add bpf_jit_limit knob to restrict unpriv
allocations"), because a new sysctl, bpf_jit_limit, made use of it.
Finally, this parameter has become long instead of integer with
fdadd04931c2 ("bpf: fix bpf_jit_limit knob for PAGE_SIZE >= 64K")
and thus, a new proc_dolongvec_minmax_bpf_restricted() has been
added.
With this last change, we got back to that
proc_dointvec_minmax_bpf_restricted() is used only under
CONFIG_HAVE_EBPF_JIT, but the corresponding ifdef has not been
brought back.
So, in configurations like CONFIG_BPF_JIT=y && CONFIG_HAVE_EBPF_JIT=n
since v4.20 we have:
CC net/core/sysctl_net_core.o
net/core/sysctl_net_core.c:292:1: warning: ‘proc_dointvec_minmax_bpf_restricted’ defined but not used [-Wunused-function]
292 | proc_dointvec_minmax_bpf_restricted(struct ctl_table *table, int write,
Suppress this by guarding it with CONFIG_HAVE_EBPF_JIT again.
Fixes: fdadd04931c2 ("bpf: fix bpf_jit_limit knob for PAGE_SIZE >= 64K")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Link: https://lore.kernel.org/bpf/20191218091821.7080-1-alobakin@dlink.ru
