commit 8b66fee7f8ee18f9c51260e7a43ab37db5177a05 upstream.
syzbot reports following splat:
BUG: KMSAN: uninit-value in strlen+0x3b/0xa0 lib/string.c:486
CPU: 1 PID: 11057 Comm: syz-executor0 Not tainted 4.20.0-rc7+ #2
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:295
nla_put_string include/net/netlink.h:1154 [inline]
tipc_nl_compat_link_reset_stats+0x1f0/0x360 net/tipc/netlink_compat.c:760
__tipc_nl_compat_doit net/tipc/netlink_compat.c:311 [inline]
tipc_nl_compat_doit+0x3aa/0xaf0 net/tipc/netlink_compat.c:344
tipc_nl_compat_handle net/tipc/netlink_compat.c:1107 [inline]
tipc_nl_compat_recv+0x14d7/0x2760 net/tipc/netlink_compat.c:1210
genl_family_rcv_msg net/netlink/genetlink.c:601 [inline]
genl_rcv_msg+0x185f/0x1a60 net/netlink/genetlink.c:626
netlink_rcv_skb+0x444/0x640 net/netlink/af_netlink.c:2477
genl_rcv+0x63/0x80 net/netlink/genetlink.c:637
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0xf40/0x1020 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x127f/0x1300 net/netlink/af_netlink.c:1917
sock_sendmsg_nosec net/socket.c:621 [inline]
sock_sendmsg net/socket.c:631 [inline]
___sys_sendmsg+0xdb9/0x11b0 net/socket.c:2116
__sys_sendmsg net/socket.c:2154 [inline]
__do_sys_sendmsg net/socket.c:2163 [inline]
__se_sys_sendmsg+0x305/0x460 net/socket.c:2161
__x64_sys_sendmsg+0x4a/0x70 net/socket.c:2161
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
RIP: 0033:0x457ec9
Code: 6d b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f2557338c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457ec9
RDX: 0000000000000000 RSI: 00000000200001c0 RDI: 0000000000000003
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f25573396d4
R13: 00000000004cb478 R14: 00000000004d86c8 R15: 00000000ffffffff
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline]
kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158
kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176
kmsan_slab_alloc+0xe/0x10 mm/kmsan/kmsan_hooks.c:185
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2759 [inline]
__kmalloc_node_track_caller+0xe18/0x1030 mm/slub.c:4383
__kmalloc_reserve net/core/skbuff.c:137 [inline]
__alloc_skb+0x309/0xa20 net/core/skbuff.c:205
alloc_skb include/linux/skbuff.h:998 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline]
netlink_sendmsg+0xb82/0x1300 net/netlink/af_netlink.c:1892
The uninitialised access happened in tipc_nl_compat_link_reset_stats:
nla_put_string(skb, TIPC_NLA_LINK_NAME, name)
This is because name string is not validated before it's used.
Reported-by: syzbot+e01d94b5a4c266be6e4c@syzkaller.appspotmail.com
Signed-off-by: Ying Xue <ying.xue@windriver.com>
commit 400b8b9a2a17918f8ce00786f596f530e7f30d50 upstream.
The similar issue as fixed in Commit 4a2eb0c37b47 ("sctp: initialize
sin6_flowinfo for ipv6 addrs in sctp_inet6addr_event") also exists
in sctp_inetaddr_event, as Alexander noticed.
To fix it, allocate sctp_sockaddr_entry with kzalloc for both sctp
ipv4 and ipv6 addresses, as does in sctp_v4/6_copy_addrlist().
Reported-by: Alexander Potapenko <glider@google.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Reported-by: syzbot+ae0c70c0c2d40c51bb92@syzkaller.appspotmail.com
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
commit e2c8d550a973bb34fc28bc8d0ec996f84562fb8a upstream.
The [ip,ip6,arp]_tables use x_tables_info internally and the underlying
memory is already accounted to kmemcg. Do the same for ebtables. The
syzbot, by using setsockopt(EBT_SO_SET_ENTRIES), was able to OOM the
whole system from a restricted memcg, a potential DoS.
By accounting the ebt_table_info, the memory used for ebt_table_info can
be contained within the memcg of the allocating process. However the
lifetime of ebt_table_info is independent of the allocating process and
is tied to the network namespace. So, the oom-killer will not be able to
relieve the memory pressure due to ebt_table_info memory. The memory for
ebt_table_info is allocated through vmalloc. Currently vmalloc does not
handle the oom-killed allocating process correctly and one large
allocation can bypass memcg limit enforcement. So, with this patch,
at least the small allocations will be contained. For large allocations,
we need to fix vmalloc.
Reported-by: syzbot+7713f3aa67be76b1552c@syzkaller.appspotmail.com
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com>
commit 81c88b18de1f11f70c97f28ced8d642c00bb3955 upstream.
If we ignore the error we'll hit a null dereference a little later.
Reported-by: syzbot+4b98281f2401ab849f4b@syzkaller.appspotmail.com
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit e7c87bd6cc4ec7b0ac1ed0a88a58f8206c577488 upstream.
Syzkaller was able to construct a packet of negative length by
redirecting from bpf_prog_test_run_skb with BPF_PROG_TYPE_LWT_XMIT:
BUG: KASAN: slab-out-of-bounds in memcpy include/linux/string.h:345 [inline]
BUG: KASAN: slab-out-of-bounds in skb_copy_from_linear_data include/linux/skbuff.h:3421 [inline]
BUG: KASAN: slab-out-of-bounds in __pskb_copy_fclone+0x2dd/0xeb0 net/core/skbuff.c:1395
Read of size 4294967282 at addr ffff8801d798009c by task syz-executor2/12942
kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267
memcpy+0x23/0x50 mm/kasan/kasan.c:302
__pskb_copy include/linux/skbuff.h:1053 [inline]
pskb_copy include/linux/skbuff.h:2904 [inline]
skb_realloc_headroom+0xe7/0x120 net/core/skbuff.c:1539
ipip6_tunnel_xmit net/ipv6/sit.c:965 [inline]
sit_tunnel_xmit+0xe1b/0x30d0 net/ipv6/sit.c:1029
__netdev_start_xmit include/linux/netdevice.h:4325 [inline]
netdev_start_xmit include/linux/netdevice.h:4334 [inline]
xmit_one net/core/dev.c:3219 [inline]
dev_hard_start_xmit+0x295/0xc90 net/core/dev.c:3235
__dev_queue_xmit+0x2f0d/0x3950 net/core/dev.c:3805
dev_queue_xmit+0x17/0x20 net/core/dev.c:3838
__bpf_tx_skb net/core/filter.c:2016 [inline]
__bpf_redirect_common net/core/filter.c:2054 [inline]
__bpf_redirect+0x5cf/0xb20 net/core/filter.c:2061
____bpf_clone_redirect net/core/filter.c:2094 [inline]
bpf_clone_redirect+0x2f6/0x490 net/core/filter.c:2066
bpf_prog_41f2bcae09cd4ac3+0xb25/0x1000
The generated test constructs a packet with mac header, network
header, skb->data pointing to network header and skb->len 0.
Redirecting to a sit0 through __bpf_redirect_no_mac pulls the
mac length, even though skb->data already is at skb->network_header.
bpf_prog_test_run_skb has already pulled it as LWT_XMIT !is_l2.
Update the offset calculation to pull only if skb->data differs
from skb->network_header, which is not true in this case.
The test itself can be run only from commit 1cf1cae963c2 ("bpf:
introduce BPF_PROG_TEST_RUN command"), but the same type of packets
with skb at network header could already be built from lwt xmit hooks,
so this fix is more relevant to that commit.
Also set the mac header on redirect from LWT_XMIT, as even after this
change to __bpf_redirect_no_mac that field is expected to be set, but
is not yet in ip_finish_output2.
Fixes: 3a0af8fd61f9 ("bpf: BPF for lightweight tunnel infrastructure")
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 4a06fa67c4da20148803525151845276cdb995c1 ]
Commit 2efd4fca703a ("ip: in cmsg IP(V6)_ORIGDSTADDR call
pskb_may_pull") avoided a read beyond the end of the skb linear
segment by calling pskb_may_pull.
That function can trigger a BUG_ON in pskb_expand_head if the skb is
shared, which it is when when peeking. It can also return ENOMEM.
Avoid both by switching to safer skb_header_pointer.
Fixes: 2efd4fca703a ("ip: in cmsg IP(V6)_ORIGDSTADDR call pskb_may_pull")
Suggested-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit d972f3dce8d161e2142da0ab1ef25df00e2f21a9 ]
'dev' is non NULL when the addr_len check triggers so it must goto a label
that does the dev_put otherwise dev will have a leaked refcount.
This bug causes the ib_ipoib module to become unloadable when using
systemd-network as it triggers this check on InfiniBand links.
Fixes: 99137b7888f4 ("packet: validate address length")
Reported-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Acked-by: Willem de Bruijn <willemb@google.com>
state
[ Upstream commit 4c84edc11b76590859b1e45dd676074c59602dc4 ]
When handling DNAT'ed packets on a bridge device, the neighbour cache entry
from lookup was used without checking its state. It means that a cache entry
in the NUD_STALE state will be used directly instead of entering the NUD_DELAY
state to confirm the reachability of the neighbor.
This problem becomes worse after commit 2724680bceee ("neigh: Keep neighbour
cache entries if number of them is small enough."), since all neighbour cache
entries in the NUD_STALE state will be kept in the neighbour table as long as
the number of cache entries does not exceed the value specified in gc_thresh1.
This commit validates the state of a neighbour cache entry before using
the entry.
Signed-off-by: JianJhen Chen <kchen@synology.com>
Reviewed-by: JinLin Chen <jlchen@synology.com>
[ Upstream commit 7d033c9f6a7fd3821af75620a0257db87c2b552a ]
This patch makes sure the flow label in the IPv6 header
forged in ipv6_local_error() is initialized.
BUG: KMSAN: kernel-infoleak in _copy_to_user+0x16b/0x1f0 lib/usercopy.c:32
CPU: 1 PID: 24675 Comm: syz-executor1 Not tainted 4.20.0-rc7+ #4
Call Trace:
kmsan_internal_check_memory+0x455/0xb00 mm/kmsan/kmsan.c:675
kmsan_copy_to_user+0xab/0xc0 mm/kmsan/kmsan_hooks.c:601
copy_to_user include/linux/uaccess.h:177 [inline]
move_addr_to_user+0x2e9/0x4f0 net/socket.c:227
___sys_recvmsg+0x5d7/0x1140 net/socket.c:2284
__sys_recvmsg net/socket.c:2327 [inline]
__do_sys_recvmsg net/socket.c:2337 [inline]
__se_sys_recvmsg+0x2fa/0x450 net/socket.c:2334
__x64_sys_recvmsg+0x4a/0x70 net/socket.c:2334
RIP: 0033:0x457ec9
RSP: 002b:00007f8750c06c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002f
RDX: 0000000000002000 RSI: 0000000020000400 RDI: 0000000000000005
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f8750c076d4
R13: 00000000004c4a60 R14: 00000000004d8140 R15: 00000000ffffffff
Uninit was stored to memory at:
kmsan_save_stack mm/kmsan/kmsan.c:219 [inline]
kmsan_internal_chain_origin+0x134/0x230 mm/kmsan/kmsan.c:439
__msan_chain_origin+0x70/0xe0 mm/kmsan/kmsan_instr.c:200
ipv6_recv_error+0x1e3f/0x1eb0 net/ipv6/datagram.c:475
udpv6_recvmsg+0x398/0x2ab0 net/ipv6/udp.c:335
inet_recvmsg+0x4fb/0x600 net/ipv4/af_inet.c:830
sock_recvmsg_nosec net/socket.c:794 [inline]
sock_recvmsg+0x1d1/0x230 net/socket.c:801
___sys_recvmsg+0x4d5/0x1140 net/socket.c:2278
ipv6_local_error+0x1a7/0x9e0 net/ipv6/datagram.c:334
__ip6_append_data+0x129f/0x4fd0 net/ipv6/ip6_output.c:1311
ip6_make_skb+0x6cc/0xcf0 net/ipv6/ip6_output.c:1775
udpv6_sendmsg+0x3f8e/0x45d0 net/ipv6/udp.c:1384
inet_sendmsg+0x54a/0x720 net/ipv4/af_inet.c:798
__sys_sendto+0x8c4/0xac0 net/socket.c:1788
__do_sys_sendto net/socket.c:1800 [inline]
__se_sys_sendto+0x107/0x130 net/socket.c:1796
__x64_sys_sendto+0x6e/0x90 net/socket.c:1796
Bytes 4-7 of 28 are uninitialized
Memory access of size 28 starts at ffff8881937bfce0
Data copied to user address 0000000020000000
commit 0aaa81377c5a01f686bcdb8c7a6929a7bf330c68 upstream.
Muyu Yu provided a POC where user root with CAP_NET_ADMIN can create a CAN
frame modification rule that makes the data length code a higher value than
the available CAN frame data size. In combination with a configured checksum
calculation where the result is stored relatively to the end of the data
(e.g. cgw_csum_xor_rel) the tail of the skb (e.g. frag_list pointer in
skb_shared_info) can be rewritten which finally can cause a system crash.
Michael Kubecek suggested to drop frames that have a DLC exceeding the
available space after the modification process and provided a patch that can
handle CAN FD frames too. Within this patch we also limit the length for the
checksum calculations to the maximum of Classic CAN data length (8).
CAN frames that are dropped by these additional checks are counted with the
CGW_DELETED counter which indicates misconfigurations in can-gw rules.
This fixes CVE-2019-3701.
Reported-by: Muyu Yu <ieatmuttonchuan@gmail.com>
Reported-by: Marcus Meissner <meissner@suse.de>
Suggested-by: Michal Kubecek <mkubecek@suse.cz>
Tested-by: Muyu Yu <ieatmuttonchuan@gmail.com>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: linux-stable <stable@vger.kernel.org> # >= v3.2
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit d4b09acf924b84bae77cad090a9d108e70b43643 upstream.
if node have NFSv41+ mounts inside several net namespaces
it can lead to use-after-free in svc_process_common()
/* Setup reply header */
rqstp->rq_xprt->xpt_ops->xpo_prep_reply_hdr(rqstp); <<< HERE
svc_process_common() can use incorrect rqstp->rq_xprt,
its caller function bc_svc_process() takes it from serv->sv_bc_xprt.
The problem is that serv is global structure but sv_bc_xprt
is assigned per-netnamespace.
According to Trond, the whole "let's set up rqstp->rq_xprt
for the back channel" is nothing but a giant hack in order
to work around the fact that svc_process_common() uses it
to find the xpt_ops, and perform a couple of (meaningless
for the back channel) tests of xpt_flags.
All we really need in svc_process_common() is to be able to run
rqstp->rq_xprt->xpt_ops->xpo_prep_reply_hdr()
Bruce J Fields points that this xpo_prep_reply_hdr() call
is an awfully roundabout way just to do "svc_putnl(resv, 0);"
in the tcp case.
This patch does not initialiuze rqstp->rq_xprt in bc_svc_process(),
now it calls svc_process_common() with rqstp->rq_xprt = NULL.
To adjust reply header svc_process_common() just check
rqstp->rq_prot and calls svc_tcp_prep_reply_hdr() for tcp case.
To handle rqstp->rq_xprt = NULL case in functions called from
svc_process_common() patch intruduces net namespace pointer
svc_rqst->rq_bc_net and adjust SVC_NET() definition.
Some other function was also adopted to properly handle described case.
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: stable@vger.kernel.org
Fixes: 23c20ecd4475 ("NFS: callback up - users counting cleanup")
v2: - added lost extern svc_tcp_prep_reply_hdr()
- dropped trace_svc_process() changes
commit 574d356b7a02c7e1b01a1d9cba8a26b3c2888f45 upstream.
If the requested msize is too small (either from command line argument
or from the server version reply), we won't get any work done.
If it's *really* too small, nothing will work, and this got caught by
syzbot recently (on a new kmem_cache_create_usercopy() call)
Just set a minimum msize to 4k in both code paths, until someone
complains they have a use-case for a smaller msize.
We need to check in both mount option and server reply individually
because the msize for the first version request would be unchecked
with just a global check on clnt->msize.
Link: http://lkml.kernel.org/r/1541407968-31350-1-git-send-email-asmadeus@codewreck.org
Reported-by: syzbot+0c1d61e4db7db94102ca@syzkaller.appspotmail.com
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Latchesar Ionkov <lucho@ionkov.net>
commit b8be5674fa9a6f3677865ea93f7803c4212f3e10 upstream.
commit 4ecd55ea074217473f94cfee21bb72864d39f8d7 upstream.
After commit d202cce8963d, an expired cache_head can be removed from the
cache_detail's hash.
However, the expired cache_head may be waiting for a reply from a
previously submitted request. Such a cache_head has an increased
refcounter and therefore it won't be freed after cache_put(freeme).
Because the cache_head was removed from the hash it cannot be found
during cache_clean() and can be leaked forever, together with stalled
cache_request and other taken resources.
In our case we noticed it because an entry in the export cache was
holding a reference on a filesystem.
Fixes d202cce8963d ("sunrpc: never return expired entries in sunrpc_cache_lookup")
Cc: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Cc: stable@kernel.org # 2.6.35
Reviewed-by: NeilBrown <neilb@suse.com>
[ Upstream commit 34b1e0e9efe101822e83cc62d22443ed3867ae7a ]
mac80211 uses the frag list to build AMSDU. When freeing
the skb, it may not be really freed, since someone is still
holding a reference to it.
In that case, when TCP skb is being retransmitted, the
pointer to the frag list is being reused, while the data
in there is no longer valid.
Since we will never get frag list from the network stack,
as mac80211 doesn't advertise the capability, we can safely
free and nullify it before releasing the SKB.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit cf76785d30712d90185455e752337acdb53d2a5d ]
Ensure that we clear XPRT_CONNECTING before releasing the XPRT_LOCK so that
we don't have races between the (asynchronous) socket setup code and
tasks in xprt_connect().
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 542fbda0f08f1cbbc250f9e59f7537649651d0c8 ]
The dst entry might already have a zero refcount, waiting on rcu list
to be free'd. Using dst_hold() transitions its reference count to 1, and
next dst release will try to free it again -- resulting in a double free:
WARNING: CPU: 1 PID: 0 at include/net/dst.h:239 nf_xfrm_me_harder+0xe7/0x130 [nf_nat]
RIP: 0010:nf_xfrm_me_harder+0xe7/0x130 [nf_nat]
Code: 48 8b 5c 24 60 65 48 33 1c 25 28 00 00 00 75 53 48 83 c4 68 5b 5d 41 5c c3 85 c0 74 0d 8d 48 01 f0 0f b1 0a 74 86 85 c0 75 f3 <0f> 0b e9 7b ff ff ff 29 c6 31 d2 b9 20 00 48 00 4c 89 e7 e8 31 27
Call Trace:
nf_nat_ipv4_out+0x78/0x90 [nf_nat_ipv4]
nf_hook_slow+0x36/0xd0
ip_output+0x9f/0xd0
ip_forward+0x328/0x440
ip_rcv+0x8a/0xb0
Use dst_hold_safe instead and bail out if we cannot take a reference.
Fixes: a4c2fd7f7891 ("net: remove DST_NOCACHE flag")
Reported-by: Martin Zaharinov <micron10@gmail.com>
[ Upstream commit 708abf74dd87f8640871b814faa195fb5970b0e3 ]
In the error handling block, nla_nest_cancel(skb, atd) is called to
cancel the nest operation. But then, ipset_nest_end(skb, atd) is
unexpected called to end the nest operation. This patch calls the
ipset_nest_end only on the branch that nla_nest_cancel is not called.
Fixes: 45040978c899 ("netfilter: ipset: Fix set:list type crash when flush/dump set in parallel")
Signed-off-by: Pan Bian <bianpan2016@163.com>
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
[ Upstream commit 530aad77010b81526586dfc09130ec875cd084e4 ]
When adjusting sack block sequence numbers, skb_make_writable() gets
called to make sure tcp options are all in the linear area, and buffer
is not shared.
This can cause tcp header pointer to get reallocated, so we must
reaload it to avoid memory corruption.
This bug pre-dates git history.
Reported-by: Neel Mehta <nmehta@google.com>
Reported-by: Shane Huntley <shuntley@google.com>
Reported-by: Heather Adkins <argv@google.com>
the dst_entry.
[ Upstream commit 0152eee6fc3b84298bb6a79961961734e8afa5b8 ]
Since commit 222d7dbd258d ("net: prevent dst uses after free")
skb_dst_force() might clear the dst_entry attached to the skb.
The xfrm code doesn't expect this to happen, so we crash with
a NULL pointer dereference in this case.
Fix it by checking skb_dst(skb) for NULL after skb_dst_force()
and drop the packet in case the dst_entry was cleared. We also
move the skb_dst_force() to a codepath that is not used when
the transformation was offloaded, because in this case we
don't have a dst_entry attached to the skb.
The output and forwarding path was already fixed by
commit 9e1437937807 ("xfrm: Fix NULL pointer dereference when
skb_dst_force clears the dst_entry.")
Fixes: 222d7dbd258d ("net: prevent dst uses after free")
Reported-by: Jean-Philippe Menil <jpmenil@gmail.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit ca92e173ab34a4f7fc4128bd372bd96f1af6f507 ]
sadhcnt is reported by `ip -s xfrm state count` as "buckets count", not the
hash mask.
Fixes: 28d8909bc790 ("[XFRM]: Export SAD info.")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
[ Upstream commit 533555e5cbb6aa2d77598917871ae5b579fe724b ]
xfrm_output_one() does not return a error code when there is
no dst_entry attached to the skb, it is still possible crash
with a NULL pointer dereference in xfrm_output_resume(). Fix
it by return error code -EHOSTUNREACH.
Fixes: 9e1437937807 ("xfrm: Fix NULL pointer dereference when skb_dst_force clears the dst_entry.")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
commit 4cd273bb91b3001f623f516ec726c49754571b1a upstream.
(not in Linus's tree now, but in nf.git + linux-next.git already.)
age is signed integer, so result can be negative when the timestamps
have a large delta. In this case we want to discard the entry.
Instead of using age >= 2 || age < 0, just make it unsigned.
Fixes: b36e4523d4d56 ("netfilter: nf_conncount: fix garbage collection confirm race")
Reviewed-by: Shawn Bohrer <sbohrer@cloudflare.com>
[mfo: backport: use older file name, nf_conncount.c -> xt_connlimit.c]
Signed-off-by: Mauricio Faria de Oliveira <mfo@canonical.com>
commit b36e4523d4d56e2595e28f16f6ccf1cd6a9fc452 upstream.
Yi-Hung Wei and Justin Pettit found a race in the garbage collection scheme
used by nf_conncount.
When doing list walk, we lookup the tuple in the conntrack table.
If the lookup fails we remove this tuple from our list because
the conntrack entry is gone.
This is the common cause, but turns out its not the only one.
The list entry could have been created just before by another cpu, i.e. the
conntrack entry might not yet have been inserted into the global hash.
The avoid this, we introduce a timestamp and the owning cpu.
If the entry appears to be stale, evict only if:
1. The current cpu is the one that added the entry, or,
2. The timestamp is older than two jiffies
The second constraint allows GC to be taken over by other
cpu too (e.g. because a cpu was offlined or napi got moved to another
cpu).
We can't pretend the 'doubtful' entry wasn't in our list.
Instead, when we don't find an entry indicate via IS_ERR
that entry was removed ('did not exist' or withheld
('might-be-unconfirmed').
This most likely also fixes a xt_connlimit imbalance earlier reported by
Dmitry Andrianov.
Cc: Dmitry Andrianov <dmitry.andrianov@alertme.com>
Reported-by: Justin Pettit <jpettit@vmware.com>
Reported-by: Yi-Hung Wei <yihung.wei@gmail.com>
Acked-by: Yi-Hung Wei <yihung.wei@gmail.com>
[mfo: backport: refresh context lines and use older symbol/file names:
- nf_conncount.c -> xt_connlimit.c.
- nf_conncount_rb -> xt_connlimit_rb
- nf_conncount_tuple -> xt_connlimit_conn
- conncount_conn_cachep -> connlimit_conn_cachep]
commit 21ba8847f857028dc83a0f341e16ecc616e34740 upstream.
Currently, we use check_hlist() for garbage colleciton. However, we
use the ‘zone’ from the counted entry to query the existence of
existing entries in the hlist. This could be wrong when they are in
different zones, and this patch fixes this issue.
Fixes: e59ea3df3fc2 ("netfilter: xt_connlimit: honor conntrack zone if available")
Signed-off-by: Yi-Hung Wei <yihung.wei@gmail.com>
[mfo: backport: refresh context lines and use older symbol/file names, note hunk 5:
- hunk 5: remove check for non-NULL 'tuple', that isn't required as it's introduced
by upstream commit 35d8deb80 ("netfilter: conncount: Support count only use case")
which addresses nf_conncount_count() that does not exist yet -- it's introduced by
upstream commit 625c556118f3 ("netfilter: connlimit: split xt_connlimit into front
and backend"), a refactor change.
- nft_connlimit.c -> removed, not used/doesn't exist yet.]
commit 5e5cbc7b23eaf13e18652c03efbad5be6995de6a upstream.
This patch provides an interface to maintain the list of connections and
the lookup function to obtain the number of connections in the list.
- nf_conntrack_count.h: new file, add include guards.
- conncount_rb_cachep -> connlimit_rb_cachep
commit ce49480dba8666cba0106e8e31a942c9ce4c438a upstream.
Only stored, never read. This is a leftover from commit 7d08487777c8
("netfilter: connlimit: use rbtree for per-host conntrack obj storage"),
which added the rbtree node struct that stores the address instead.
- additionally, remove the add_hlist() 'addr' parameter that isn't used and removed
later upstream with commit 625c556118f3 ("netfilter: connlimit: split xt_connlimit
into front and backend") in the rename from 'xt_connlimit.c' to 'nf_conncount.c',
a big refactor, so do it here, while still here in this related patch.]
[ Upstream commit 3a0ed3e9619738067214871e9cb826fa23b2ddb9 ]
Al Viro mentioned (Message-ID
<20170626041334.GZ10672@ZenIV.linux.org.uk>)
that there is probably a race condition
lurking in accesses of sk_stamp on 32-bit machines.
sock->sk_stamp is of type ktime_t which is always an s64.
On a 32 bit architecture, we might run into situations of
unsafe access as the access to the field becomes non atomic.
Use seqlocks for synchronization.
This allows us to avoid using spinlocks for readers as
readers do not need mutual exclusion.
Another approach to solve this is to require sk_lock for all
modifications of the timestamps. The current approach allows
for timestamps to have their own lock: sk_stamp_lock.
This allows for the patch to not compete with already
existing critical sections, and side effects are limited
to the paths in the patch.
The addition of the new field maintains the data locality
optimizations from
commit 9115e8cd2a0c ("net: reorganize struct sock for better data
locality")
Note that all the instances of the sk_stamp accesses
are either through the ioctl or the syscall recvmsg.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
[ Upstream commit 78abe3d0dfad196959b1246003366e2610775ea6 ]
clcsock can be released while kernel_accept() references it in TCP
listen worker. Also, clcsock needs to wake up before released if TCP
fallback is used and the clcsock is blocked by accept. Add a lock to
safely release clcsock and call kernel_sock_shutdown() to wake up
clcsock from accept in smc_release().
Reported-by: syzbot+0bf2e01269f1274b4b03@syzkaller.appspotmail.com
Reported-by: syzbot+e3132895630f957306bc@syzkaller.appspotmail.com
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
[ Upstream commit fb83ed496b9a654f60cd1d58a0e1e79ec5694808 ]
When TIPC_NLA_UDP_REMOTE is an IPv6 mcast address but
TIPC_NLA_UDP_LOCAL is an IPv4 address, a NULL-ptr deref is triggered
as the UDP tunnel sock is initialized to IPv4 or IPv6 sock merely
based on the protocol in local address.
We should just error out when the remote address and local address
have different protocols.
Reported-by: syzbot+eb4da3a20fad2e52555d@syzkaller.appspotmail.com
Cc: Ying Xue <ying.xue@windriver.com>
Cc: Jon Maloy <jon.maloy@ericsson.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
[ Upstream commit 15ef70e286176165d28b0b8a969b422561a68dfc ]
lock_sock() must be used in process context to be race-free with
other lock_sock() callers, for example, tipc_release(). Otherwise
using the spinlock directly can't serialize a parallel tipc_release().
As it is blocking, we have to hold the sock refcnt before
rhashtable_walk_stop() and release it after rhashtable_walk_start().
Fixes: 07f6c4bc048a ("tipc: convert tipc reference table to use generic rhashtable")
[ Upstream commit a915b982d8f5e4295f64b8dd37ce753874867e88 ]
If a server side socket is bound to an address, but not in the listening
state yet, incoming connection requests should receive a reset control
packet in response. However, the function used to send the reset
silently drops the reset packet if the sending socket isn't bound
to a remote address (as is the case for a bound socket not yet in
the listening state). This change fixes this by using the src
of the incoming packet as destination for the reset packet in
this case.
Fixes: d021c344051a ("VSOCK: Introduce VM Sockets")
Reviewed-by: Adit Ranadive <aditr@vmware.com>
Reviewed-by: Vishnu Dasa <vdasa@vmware.com>
Signed-off-by: Jorgen Hansen <jhansen@vmware.com>
[ Upstream commit acb4a33e9856d5fa3384b87d3d8369229be06d31 ]
tipc_udp_xmit() drops the packet on error, there is no
need to drop it again.
Fixes: ef20cd4dd163 ("tipc: introduce UDP replicast")
Reported-and-tested-by: syzbot+eae585ba2cc2752d3704@syzkaller.appspotmail.com
[ Upstream commit f0c928d878e7d01b613c9ae5c971a6b1e473a938 ]
Alexei reported use after frees in inet_diag_dump_icsk() [1]
Because we use refcount_set() when various sockets are setup and
inserted into ehash, we also need to make sure inet_diag_dump_icsk()
wont race with the refcount_set() operations.
Jonathan Lemon sent a patch changing net_twsk_hashdance() but
other spots would need risky changes.
Instead, fix inet_diag_dump_icsk() as this bug came with
linux-4.10 only.
[1] Quoting Alexei :
First something iterating over sockets finds already freed tw socket:
refcount_t: increment on 0; use-after-free.
WARNING: CPU: 2 PID: 2738 at lib/refcount.c:153 refcount_inc+0x26/0x30
RIP: 0010:refcount_inc+0x26/0x30
RSP: 0018:ffffc90004c8fbc0 EFLAGS: 00010282
RAX: 000000000000002b RBX: 0000000000000000 RCX: 0000000000000000
RDX: ffff88085ee9d680 RSI: ffff88085ee954c8 RDI: ffff88085ee954c8
RBP: ffff88010ecbd2c0 R08: 0000000000000000 R09: 000000000000174c
R10: ffffffff81e7c5a0 R11: 0000000000000000 R12: 0000000000000000
R13: ffff8806ba9bf210 R14: ffffffff82304600 R15: ffff88010ecbd328
FS: 00007f81f5a7d700(0000) GS:ffff88085ee80000(0000) knlGS:0000000000000000
CR2: 00007f81e2a95000 CR3: 000000069b2eb006 CR4: 00000000003606e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
inet_diag_dump_icsk+0x2b3/0x4e0 [inet_diag] // sock_hold(sk); in net/ipv4/inet_diag.c:1002
? kmalloc_large_node+0x37/0x70
? __kmalloc_node_track_caller+0x1cb/0x260
? __alloc_skb+0x72/0x1b0
? __kmalloc_reserve.isra.40+0x2e/0x80
__inet_diag_dump+0x3b/0x80 [inet_diag]
netlink_dump+0x116/0x2a0
netlink_recvmsg+0x205/0x3c0
sock_read_iter+0x89/0xd0
__vfs_read+0xf7/0x140
vfs_read+0x8a/0x140
SyS_read+0x3f/0xa0
do_syscall_64+0x5a/0x100
then a minute later twsk timer fires and hits two bad refcnts
for this freed socket:
refcount_t: decrement hit 0; leaking memory.
WARNING: CPU: 31 PID: 0 at lib/refcount.c:228 refcount_dec+0x2e/0x40
Modules linked in:
RIP: 0010:refcount_dec+0x2e/0x40
RSP: 0018:ffff88085f5c3ea8 EFLAGS: 00010296
RAX: 000000000000002c RBX: ffff88010ecbd2c0 RCX: 000000000000083f
RDX: 0000000000000000 RSI: 00000000000000f6 RDI: 000000000000003f
RBP: ffffc90003c77280 R08: 0000000000000000 R09: 00000000000017d3
R10: ffffffff81e7c5a0 R11: 0000000000000000 R12: ffffffff82ad2d80
R13: ffffffff8182de00 R14: ffff88085f5c3ef8 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88085f5c0000(0000) knlGS:0000000000000000
CR2: 00007fbe42685250 CR3: 0000000002209001 CR4: 00000000003606e0
Call Trace:
<IRQ>
inet_twsk_kill+0x9d/0xc0 // inet_twsk_bind_unhash(tw, hashinfo);
call_timer_fn+0x29/0x110
run_timer_softirq+0x36b/0x3a0
refcount_t: underflow; use-after-free.
WARNING: CPU: 31 PID: 0 at lib/refcount.c:187 refcount_sub_and_test+0x46/0x50
RIP: 0010:refcount_sub_and_test+0x46/0x50
RSP: 0018:ffff88085f5c3eb8 EFLAGS: 00010296
RAX: 0000000000000026 RBX: ffff88010ecbd2c0 RCX: 000000000000083f
RBP: ffff88010ecbd358 R08: 0000000000000000 R09: 000000000000185b
R10: ffffffff81e7c5a0 R11: 0000000000000000 R12: ffff88010ecbd358
Call Trace:
<IRQ>
inet_twsk_put+0x12/0x20 // inet_twsk_put(tw);
Fixes: 67db3e4bfbc9 ("tcp: no longer hold ehash lock while calling tcp_get_info()")
Reported-by: Alexei Starovoitov <ast@kernel.org>
Cc: Jonathan Lemon <jonathan.lemon@gmail.com>
Acked-by: Jonathan Lemon <jonathan.lemon@gmail.com>
[ Upstream commit 4a2eb0c37b4759416996fbb4c45b932500cf06d3 ]
syzbot reported a kernel-infoleak, which is caused by an uninitialized
field(sin6_flowinfo) of addr->a.v6 in sctp_inet6addr_event().
The call trace is as below:
BUG: KMSAN: kernel-infoleak in _copy_to_user+0x19a/0x230 lib/usercopy.c:33
CPU: 1 PID: 8164 Comm: syz-executor2 Not tainted 4.20.0-rc3+ #95
Google 01/01/2011
Call Trace:
dump_stack+0x32d/0x480 lib/dump_stack.c:113
kmsan_report+0x12c/0x290 mm/kmsan/kmsan.c:683
kmsan_internal_check_memory+0x32a/0xa50 mm/kmsan/kmsan.c:743
kmsan_copy_to_user+0x78/0xd0 mm/kmsan/kmsan_hooks.c:634
copy_to_user include/linux/uaccess.h:183 [inline]
sctp_getsockopt_local_addrs net/sctp/socket.c:5998 [inline]
sctp_getsockopt+0x15248/0x186f0 net/sctp/socket.c:7477
sock_common_getsockopt+0x13f/0x180 net/core/sock.c:2937
__sys_getsockopt+0x489/0x550 net/socket.c:1939
__do_sys_getsockopt net/socket.c:1950 [inline]
__se_sys_getsockopt+0xe1/0x100 net/socket.c:1947
__x64_sys_getsockopt+0x62/0x80 net/socket.c:1947
do_syscall_64+0xcf/0x110 arch/x86/entry/common.c:291
sin6_flowinfo is not really used by SCTP, so it will be fixed by simply
setting it to 0.
The issue exists since very beginning.
Thanks Alexander for the reproducer provided.
Reported-by: syzbot+ad5d327e6936a2e284be@syzkaller.appspotmail.com
[ Upstream commit 6b8d95f1795c42161dc0984b6863e95d6acf24ed ]
Validate packet socket address length if a length is given. Zero
length is equivalent to not setting an address.
Reported-by: Ido Schimmel <idosch@idosch.org>
[ Upstream commit 99137b7888f4058087895d035d81c6b2d31015c5 ]
Packet sockets with SOCK_DGRAM may pass an address for use in
dev_hard_header. Ensure that it is of sufficient length.
[ Upstream commit 7314f5480f3e37e570104dc5e0f28823ef849e72 ]
nr_find_socket(), nr_find_peer() and nr_find_listener() lock the
sock after finding it in the global list. However, the call path
requires BH disabled for the sock lock consistently.
Actually the locking is unnecessary at this point, we can just hold
the sock refcnt to make sure it is not gone after we unlock the global
list, and lock it later only when needed.
Reported-and-tested-by: syzbot+f621cda8b7e598908efa@syzkaller.appspotmail.com
[ Upstream commit ade446403bfb79d3528d56071a84b15351a139ad ]
Since commit 7969e5c40dfd ("ip: discard IPv4 datagrams with overlapping
segments.") IPv4 reassembly code drops the whole queue whenever an
overlapping fragment is received. However, the test is written in a way
which detects duplicate fragments as overlapping so that in environments
with many duplicate packets, fragmented packets may be undeliverable.
Add an extra test and for (potentially) duplicate fragment, only drop the
new fragment rather than the whole queue. Only starting offset and length
are checked, not the contents of the fragments as that would be too
expensive. For similar reason, linear list ("run") of a rbtree node is not
iterated, we only check if the new fragment is a subset of the interval
covered by existing consecutive fragments.
v2: instead of an exact check iterating through linear list of an rbtree
node, only check if the new fragment is subset of the "run" (suggested
by Eric Dumazet)
Fixes: 7969e5c40dfd ("ip: discard IPv4 datagrams with overlapping segments.")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit cbb49697d5512ce9e61b45ce75d3ee43d7ea5524 ]
xfrm6_policy_check() might have re-allocated skb->head, we need
to reload ipv6 header pointer.
sysbot reported :
BUG: KASAN: use-after-free in __ipv6_addr_type+0x302/0x32f net/ipv6/addrconf_core.c:40
Read of size 4 at addr ffff888191b8cb70 by task syz-executor2/1304
CPU: 0 PID: 1304 Comm: syz-executor2 Not tainted 4.20.0-rc7+ #356
Call Trace:
<IRQ>
dump_stack+0x244/0x39d lib/dump_stack.c:113
print_address_description.cold.7+0x9/0x1ff mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.8+0x242/0x309 mm/kasan/report.c:412
__asan_report_load4_noabort+0x14/0x20 mm/kasan/report.c:432
ipv6_addr_type include/net/ipv6.h:403 [inline]
ip6_tnl_get_cap+0x27/0x190 net/ipv6/ip6_tunnel.c:727
ip6_tnl_rcv_ctl+0xdb/0x2a0 net/ipv6/ip6_tunnel.c:757
vti6_rcv+0x336/0x8f3 net/ipv6/ip6_vti.c:321
xfrm6_ipcomp_rcv+0x1a5/0x3a0 net/ipv6/xfrm6_protocol.c:132
ip6_protocol_deliver_rcu+0x372/0x1940 net/ipv6/ip6_input.c:394
ip6_input_finish+0x84/0x170 net/ipv6/ip6_input.c:434
NF_HOOK include/linux/netfilter.h:289 [inline]
ip6_input+0xe9/0x600 net/ipv6/ip6_input.c:443
IPVS: ftp: loaded support on port[0] = 21
ip6_mc_input+0x514/0x11c0 net/ipv6/ip6_input.c:537
dst_input include/net/dst.h:450 [inline]
ip6_rcv_finish+0x17a/0x330 net/ipv6/ip6_input.c:76
ipv6_rcv+0x115/0x640 net/ipv6/ip6_input.c:272
__netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4973
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5083
process_backlog+0x24e/0x7a0 net/core/dev.c:5923
napi_poll net/core/dev.c:6346 [inline]
net_rx_action+0x7fa/0x19b0 net/core/dev.c:6412
__do_softirq+0x308/0xb7e kernel/softirq.c:292
do_softirq_own_stack+0x2a/0x40 arch/x86/entry/entry_64.S:1027
</IRQ>
do_softirq.part.14+0x126/0x160 kernel/softirq.c:337
do_softirq+0x19/0x20 kernel/softirq.c:340
netif_rx_ni+0x521/0x860 net/core/dev.c:4569
dev_loopback_xmit+0x287/0x8c0 net/core/dev.c:3576
ip6_finish_output2+0x193a/0x2930 net/ipv6/ip6_output.c:84
ip6_fragment+0x2b06/0x3850 net/ipv6/ip6_output.c:727
ip6_finish_output+0x6b7/0xc50 net/ipv6/ip6_output.c:152
NF_HOOK_COND include/linux/netfilter.h:278 [inline]
ip6_output+0x232/0x9d0 net/ipv6/ip6_output.c:171
dst_output include/net/dst.h:444 [inline]
ip6_local_out+0xc5/0x1b0 net/ipv6/output_core.c:176
ip6_send_skb+0xbc/0x340 net/ipv6/ip6_output.c:1727
ip6_push_pending_frames+0xc5/0xf0 net/ipv6/ip6_output.c:1747
rawv6_push_pending_frames net/ipv6/raw.c:615 [inline]
rawv6_sendmsg+0x3a3e/0x4b40 net/ipv6/raw.c:945
kobject: 'queues' (0000000089e6eea2): kobject_add_internal: parent: 'tunl0', set: '<NULL>'
kobject: 'queues' (0000000089e6eea2): kobject_uevent_env
inet_sendmsg+0x1a1/0x690 net/ipv4/af_inet.c:798
kobject: 'queues' (0000000089e6eea2): kobject_uevent_env: filter function caused the event to drop!
sock_sendmsg+0xd5/0x120 net/socket.c:631
sock_write_iter+0x35e/0x5c0 net/socket.c:900
call_write_iter include/linux/fs.h:1857 [inline]
new_sync_write fs/read_write.c:474 [inline]
__vfs_write+0x6b8/0x9f0 fs/read_write.c:487
kobject: 'rx-0' (00000000e2d902d9): kobject_add_internal: parent: 'queues', set: 'queues'
kobject: 'rx-0' (00000000e2d902d9): kobject_uevent_env
vfs_write+0x1fc/0x560 fs/read_write.c:549
ksys_write+0x101/0x260 fs/read_write.c:598
kobject: 'rx-0' (00000000e2d902d9): fill_kobj_path: path = '/devices/virtual/net/tunl0/queues/rx-0'
__do_sys_write fs/read_write.c:610 [inline]
__se_sys_write fs/read_write.c:607 [inline]
__x64_sys_write+0x73/0xb0 fs/read_write.c:607
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
kobject: 'tx-0' (00000000443b70ac): kobject_add_internal: parent: 'queues', set: 'queues'
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x457669
Code: fd b3 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 cb b3 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f9bd200bc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457669
RDX: 000000000000058f RSI: 00000000200033c0 RDI: 0000000000000003
kobject: 'tx-0' (00000000443b70ac): kobject_uevent_env
RBP: 000000000072bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f9bd200c6d4
R13: 00000000004c2dcc R14: 00000000004da398 R15: 00000000ffffffff
Allocated by task 1304:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553
__do_kmalloc_node mm/slab.c:3684 [inline]
__kmalloc_node_track_caller+0x50/0x70 mm/slab.c:3698
__kmalloc_reserve.isra.41+0x41/0xe0 net/core/skbuff.c:140
__alloc_skb+0x155/0x760 net/core/skbuff.c:208
kobject: 'tx-0' (00000000443b70ac): fill_kobj_path: path = '/devices/virtual/net/tunl0/queues/tx-0'
alloc_skb include/linux/skbuff.h:1011 [inline]
__ip6_append_data.isra.49+0x2f1a/0x3f50 net/ipv6/ip6_output.c:1450
ip6_append_data+0x1bc/0x2d0 net/ipv6/ip6_output.c:1619
rawv6_sendmsg+0x15ab/0x4b40 net/ipv6/raw.c:938
___sys_sendmsg+0x7fd/0x930 net/socket.c:2116
__sys_sendmsg+0x11d/0x280 net/socket.c:2154
__se_sys_sendmsg net/socket.c:2161 [inline]
__x64_sys_sendmsg+0x78/0xb0 net/socket.c:2161
kobject: 'gre0' (00000000cb1b2d7b): kobject_add_internal: parent: 'net', set: 'devices'
Freed by task 1304:
__kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kfree+0xcf/0x230 mm/slab.c:3817
skb_free_head+0x93/0xb0 net/core/skbuff.c:553
pskb_expand_head+0x3b2/0x10d0 net/core/skbuff.c:1498
__pskb_pull_tail+0x156/0x18a0 net/core/skbuff.c:1896
pskb_may_pull include/linux/skbuff.h:2188 [inline]
_decode_session6+0xd11/0x14d0 net/ipv6/xfrm6_policy.c:150
__xfrm_decode_session+0x71/0x140 net/xfrm/xfrm_policy.c:3272
kobject: 'gre0' (00000000cb1b2d7b): kobject_uevent_env
__xfrm_policy_check+0x380/0x2c40 net/xfrm/xfrm_policy.c:3322
__xfrm_policy_check2 include/net/xfrm.h:1170 [inline]
xfrm_policy_check include/net/xfrm.h:1175 [inline]
xfrm6_policy_check include/net/xfrm.h:1185 [inline]
vti6_rcv+0x4bd/0x8f3 net/ipv6/ip6_vti.c:316
kobject: 'gre0' (00000000cb1b2d7b): fill_kobj_path: path = '/devices/virtual/net/gre0'
The buggy address belongs to the object at ffff888191b8cac0
which belongs to the cache kmalloc-512 of size 512
The buggy address is located 176 bytes inside of
512-byte region [ffff888191b8cac0, ffff888191b8ccc0)
The buggy address belongs to the page:
page:ffffea000646e300 count:1 mapcount:0 mapping:ffff8881da800940 index:0x0
flags: 0x2fffc0000000200(slab)
raw: 02fffc0000000200 ffffea0006eaaa48 ffffea00065356c8 ffff8881da800940
raw: 0000000000000000 ffff888191b8c0c0 0000000100000006 0000000000000000
page dumped because: kasan: bad access detected
kobject: 'queues' (000000005fd6226e): kobject_add_internal: parent: 'gre0', set: '<NULL>'
Memory state around the buggy address:
ffff888191b8ca00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff888191b8ca80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
>ffff888191b8cb00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff888191b8cb80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff888191b8cc00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Fixes: 0d3c703a9d17 ("ipv6: Cleanup IPv6 tunnel receive path")
Fixes: ed1efb2aefbb ("ipv6: Add support for IPsec virtual tunnel interfaces")
Cc: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit fb24274546310872eeeaf3d1d53799d8414aa0f2 ]
syzbot reported the use of uninitialized udp6_addr::sin6_scope_id.
We can just set ::sin6_scope_id to zero, as tunnels are unlikely
to use an IPv6 address that needs a scope id and there is no
interface to bind in this context.
For net-next, it looks different as we have cfg->bind_ifindex there
so we can probably call ipv6_iface_scope_id().
Same for ::sin6_flowinfo, tunnels don't use it.
Fixes: 8024e02879dd ("udp: Add udp_sock_create for UDP tunnels to open listener socket")
Reported-by: syzbot+c56449ed3652e6720f30@syzkaller.appspotmail.com
[ Upstream commit 40c3ff6d5e0809505a067dd423c110c5658c478c ]
Packet sockets may call dev_header_parse with NULL daddr. Make
lowpan_header_ops.create fail.
Fixes: 87a93e4eceb4 ("ieee802154: change needed headroom/tailroom")
Acked-by: Alexander Aring <aring@mojatatu.com>
[ Upstream commit 8e1da73acded4751a93d4166458a7e640f37d26c ]
Add napi_disable routine in gro_cells_destroy since starting from
commit c42858eaf492 ("gro_cells: remove spinlock protecting receive
queues") gro_cell_poll and gro_cells_destroy can run concurrently on
napi_skbs list producing a kernel Oops if the tunnel interface is
removed while gro_cell_poll is running. The following Oops has been
triggered removing a vxlan device while the interface is receiving
traffic
[ 5628.948853] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
[ 5628.949981] PGD 0 P4D 0
[ 5628.950308] Oops: 0002 [#1] SMP PTI
[ 5628.950748] CPU: 0 PID: 9 Comm: ksoftirqd/0 Not tainted 4.20.0-rc6+ #41
[ 5628.952940] RIP: 0010:gro_cell_poll+0x49/0x80
[ 5628.955615] RSP: 0018:ffffc9000004fdd8 EFLAGS: 00010202
[ 5628.956250] RAX: 0000000000000000 RBX: ffffe8ffffc08150 RCX: 0000000000000000
[ 5628.957102] RDX: 0000000000000000 RSI: ffff88802356bf00 RDI: ffffe8ffffc08150
[ 5628.957940] RBP: 0000000000000026 R08: 0000000000000000 R09: 0000000000000000
[ 5628.958803] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000040
[ 5628.959661] R13: ffffe8ffffc08100 R14: 0000000000000000 R15: 0000000000000040
[ 5628.960682] FS: 0000000000000000(0000) GS:ffff88803ea00000(0000) knlGS:0000000000000000
[ 5628.961616] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5628.962359] CR2: 0000000000000008 CR3: 000000000221c000 CR4: 00000000000006b0
[ 5628.963188] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 5628.964034] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 5628.964871] Call Trace:
[ 5628.965179] net_rx_action+0xf0/0x380
[ 5628.965637] __do_softirq+0xc7/0x431
[ 5628.966510] run_ksoftirqd+0x24/0x30
[ 5628.966957] smpboot_thread_fn+0xc5/0x160
[ 5628.967436] kthread+0x113/0x130
[ 5628.968283] ret_from_fork+0x3a/0x50
[ 5628.968721] Modules linked in:
[ 5628.969099] CR2: 0000000000000008
[ 5628.969510] ---[ end trace 9d9dedc7181661fe ]---
[ 5628.970073] RIP: 0010:gro_cell_poll+0x49/0x80
[ 5628.972965] RSP: 0018:ffffc9000004fdd8 EFLAGS: 00010202
[ 5628.973611] RAX: 0000000000000000 RBX: ffffe8ffffc08150 RCX: 0000000000000000
[ 5628.974504] RDX: 0000000000000000 RSI: ffff88802356bf00 RDI: ffffe8ffffc08150
[ 5628.975462] RBP: 0000000000000026 R08: 0000000000000000 R09: 0000000000000000
[ 5628.976413] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000040
[ 5628.977375] R13: ffffe8ffffc08100 R14: 0000000000000000 R15: 0000000000000040
[ 5628.978296] FS: 0000000000000000(0000) GS:ffff88803ea00000(0000) knlGS:0000000000000000
[ 5628.979327] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 5628.980044] CR2: 0000000000000008 CR3: 000000000221c000 CR4: 00000000000006b0
[ 5628.980929] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 5628.981736] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 5628.982409] Kernel panic - not syncing: Fatal exception in interrupt
[ 5628.983307] Kernel Offset: disabled
Fixes: c42858eaf492 ("gro_cells: remove spinlock protecting receive queues")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit c433570458e49bccea5c551df628d058b3526289 ]
There are multiple issues here:
1. After freeing dev->ax25_ptr, we need to set it to NULL otherwise
we may use a dangling pointer.
2. There is a race between ax25_setsockopt() and device notifier as
reported by syzbot. Close it by holding RTNL lock.
3. We need to test if dev->ax25_ptr is NULL before using it.
Reported-and-tested-by: syzbot+ae6bb869cbed29b29040@syzkaller.appspotmail.com
[ Upstream commit 69d2c86766da2ded2b70281f1bf242cb0d58a778 ]
vr.mifi is indirectly controlled by user-space, hence leading to
a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
net/ipv6/ip6mr.c:1845 ip6mr_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
net/ipv6/ip6mr.c:1919 ip6mr_compat_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
Fix this by sanitizing vr.mifi before using it to index mrt->vif_table'
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[ Upstream commit 5648451e30a0d13d11796574919a359025d52cce ]
vr.vifi is indirectly controlled by user-space, hence leading to
net/ipv4/ipmr.c:1616 ipmr_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
net/ipv4/ipmr.c:1690 ipmr_compat_ioctl() warn: potential spectre issue 'mrt->vif_table' [r] (local cap)
Fix this by sanitizing vr.vifi before using it to index mrt->vif_table'
[ Upstream commit 0a9a4304f3614e25d9de9b63502ca633c01c0d70 ]
If an asynchronous connection attempt completes while another task is
in xprt_connect(), then the call to rpc_sleep_on() could end up
racing with the call to xprt_wake_pending_tasks().
So add a second test of the connection state after we've put the
task to sleep and set the XPRT_CONNECTING flag, when we know that there
can be no asynchronous connection attempts still in progress.
Fixes: 0b9e79431377d ("SUNRPC: Move the test for XPRT_CONNECTING into...")
[ Upstream commit 911a26484c33e10de6237228ca1d7293548e9f49 ]
Commit c470bdc1aaf3 ("mac80211: don't WARN on bad WMM parameters from
buggy APs") handled cases where an AP reports a zeroed WMM
IE. However, the condition that checks the validity accessed the wrong
index in the ieee80211_tx_queue_params array, thus wrongly deducing
that the parameters are invalid. Fix it.
Fixes: c470bdc1aaf3 ("mac80211: don't WARN on bad WMM parameters from buggy APs")
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
[ Upstream commit c470bdc1aaf36669e04ba65faf1092b2d1c6cabe ]
Apparently, some APs are buggy enough to send a zeroed
WMM IE. Don't WARN on this since this is not caused by a bug
on the client's system.
This aligns the condition of the WARNING in drv_conf_tx
with the validity check in ieee80211_sta_wmm_params.
We will now pick the default values whenever we get
a zeroed WMM IE.
This has been reported here:
https://bugzilla.kernel.org/show_bug.cgi?id=199161
Fixes: f409079bb678 ("mac80211: sanity check CW_min/CW_max towards driver")
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[ Upstream commit 0b8d9073539e217f79ec1bff65eb205ac796723d ]
Fix wraparound bug which could lead to memory exhaustion when adding an
x.x.x.x-255.255.255.255 range to any hash:*net* types.
Fixes Netfilter's bugzilla id #1212, reported by Thomas Schwark.
Fixes: 48596a8ddc46 ("netfilter: ipset: Fix adding an IPv4 range containing more than 2^31 addresses")
