[ Upstream commit 4522a70db7aa5e77526a4079628578599821b193 ]
Use pskb_may_pull() to make sure the optional fields are in skb linear
parts, so we can safely read them later.
It's easy to reproduce the issue with a net driver that supports paged
skb data. Just create a L2TPv3 over IP tunnel and then generates some
network traffic.
Once reproduced, rx err in /sys/kernel/debug/l2tp/tunnels will increase.
Changes in v4:
1. s/l2tp_v3_pull_opt/l2tp_v3_ensure_opt_in_linear/
2. s/tunnel->version != L2TP_HDR_VER_2/tunnel->version == L2TP_HDR_VER_3/
3. Add 'Fixes' in commit messages.
Changes in v3:
1. To keep consistency, move the code out of l2tp_recv_common.
2. Use "net" instead of "net-next", since this is a bug fix.
Changes in v2:
1. Only fix L2TPv3 to make code simple.
To fix both L2TPv3 and L2TPv2, we'd better refactor l2tp_recv_common.
It's complicated to do so.
2. Reloading pointers after pskb_may_pull
Fixes: f7faffa3ff8e ("l2tp: Add L2TPv3 protocol support")
Fixes: 0d76751fad77 ("l2tp: Add L2TPv3 IP encapsulation (no UDP) support")
Fixes: a32e0eec7042 ("l2tp: introduce L2TPv3 IP encapsulation support for IPv6")
Signed-off-by: Jacob Wen <jian.w.wen@oracle.com>
Acked-by: Guillaume Nault <gnault@redhat.com>
commit 62e7b6a57c7b9bf3c6fd99418eeec05b08a85c38 upstream.
Remove l2specific_len dependency while building l2tpv3 header or
parsing the received frame since default L2-Specific Sublayer is
always four bytes long and we don't need to rely on a user supplied
value.
Moreover in l2tp netlink code there are no sanity checks to
enforce the relation between l2specific_len and l2specific_type,
so sending a malformed netlink message is possible to set
l2specific_type to L2TP_L2SPECTYPE_DEFAULT (or even
L2TP_L2SPECTYPE_NONE) and set l2specific_len to a value greater than
4 leaking memory on the wire and sending corrupted frames.
Reviewed-by: Guillaume Nault <g.nault@alphalink.fr>
Tested-by: Guillaume Nault <g.nault@alphalink.fr>
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit 2e6dc4d95110becfe0ff4c3d4749c33ea166e9e7 ]
This patch is to improve sctp stream reset events in 4 places:
1. In sctp_process_strreset_outreq(), the flag should always be set with
SCTP_STREAM_RESET_INCOMING_SSN instead of OUTGOING, as receiver's in
stream is reset here.
2. In sctp_process_strreset_outreq(), move up SCTP_STRRESET_ERR_WRONG_SSN
check, as the reset has to succeed after reconf_timer stops for the
in stream reset request retransmission.
3. In sctp_process_strreset_inreq(), no event should be sent, as no in
or out stream is reset here.
4. In sctp_process_strreset_resp(), SCTP_STREAM_RESET_INCOMING_SSN or
OUTGOING event should always be sent for stream reset requests, no
matter it fails or succeeds to process the request.
Fixes: 810544764536 ("sctp: implement receiver-side procedures for the Outgoing SSN Reset Request Parameter")
Fixes: 16e1a91965b0 ("sctp: implement receiver-side procedures for the Incoming SSN Reset Request Parameter")
Fixes: 11ae76e67a17 ("sctp: implement receiver-side procedures for the Reconf Response Parameter")
Reported-by: Ying Xu <yinxu@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 8220c870cb0f4eaa4e335c9645dbd9a1c461c1dd ]
This patch is to improve sctp stream adding events in 2 places:
1. In sctp_process_strreset_addstrm_out(), move up SCTP_MAX_STREAM
and in stream allocation failure checks, as the adding has to
succeed after reconf_timer stops for the in stream adding
3. In sctp_process_strreset_addstrm_in(), no event should be sent,
as no in or out stream is added here.
Fixes: 50a41591f110 ("sctp: implement receiver-side procedures for the Add Outgoing Streams Request Parameter")
Fixes: c5c4ebb3ab87 ("sctp: implement receiver-side procedures for the Add Incoming Streams Request Parameter")
[ Upstream commit 35edfdc77f683c8fd27d7732af06cf6489af60a5 ]
Assign a default net namespace to netdevs created by init_dummy_netdev().
Fixes a NULL pointer dereference caused by busy-polling a socket bound to
an iwlwifi wireless device, which bumps the per-net BUSYPOLLRXPACKETS stat
if napi_poll() received packets:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000190
IP: napi_busy_loop+0xd6/0x200
Call Trace:
sock_poll+0x5e/0x80
do_sys_poll+0x324/0x5a0
SyS_poll+0x6c/0xf0
do_syscall_64+0x6b/0x1f0
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
Fixes: 7db6b048da3b ("net: Commonize busy polling code to focus on napi_id instead of socket")
Signed-off-by: Josh Elsasser <jelsasser@appneta.com>
[ Upstream commit b0cf029234f9b18e10703ba5147f0389c382bccc ]
When an internally generated frame is handled by rose_xmit(),
rose_route_frame() is called:
if (!rose_route_frame(skb, NULL)) {
dev_kfree_skb(skb);
stats->tx_errors++;
return NETDEV_TX_OK;
We have the same code sequence in Net/Rom where an internally generated
frame is handled by nr_xmit() calling nr_route_frame(skb, NULL).
However, in this function NULL argument is tested while it is not in
rose_route_frame().
Then kernel panic occurs later on when calling ax25cmp() with a NULL
ax25_cb argument as reported many times and recently with syzbot.
We need to test if ax25 is NULL before using it.
Testing:
Built kernel with CONFIG_ROSE=y.
Signed-off-by: Bernard Pidoux <f6bvp@free.fr>
Acked-by: Dmitry Vyukov <dvyukov@google.com>
Reported-by: syzbot+1a2c456a1ea08fa5b5f7@syzkaller.appspotmail.com
Cc: Bernard Pidoux <f6bvp@free.fr>
Cc: linux-hams@vger.kernel.org
Cc: netdev@vger.kernel.org
[ Upstream commit 63346650c1a94a92be61a57416ac88c0a47c4327 ]
sk_reset_timer() and sk_stop_timer() properly handle
sock refcnt for timer function. Switching to them
could fix a refcounting bug reported by syzbot.
Reported-and-tested-by: syzbot+defa700d16f1bd1b9a05@syzkaller.appspotmail.com
[ Upstream commit 91c524708de6207f59dd3512518d8a1c7b434ee3 ]
The size of L2TPv2 header with all optional fields is 14 bytes.
l2tp_udp_recv_core only moves 10 bytes to the linear part of a
skb. This may lead to l2tp_recv_common read data outside of a skb.
This patch make sure that there is at least 14 bytes in the linear
part of a skb to meet the maximum need of l2tp_udp_recv_core and
l2tp_recv_common. The minimum size of both PPP HDLC-like frame and
Ethernet frame is larger than 14 bytes, so we are safe to do so.
Also remove L2TP_HDR_SIZE_NOSEQ, it is unused now.
Fixes: fd558d186df2 ("l2tp: Split pppol2tp patch into separate l2tp and ppp parts")
Suggested-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit ef489749aae508e6f17886775c075f12ff919fb1 ]
skb->cb may contain data from previous layers (in an observed case
IPv4 with L3 Master Device). In the observed scenario, the data in
IPCB(skb)->frags was misinterpreted as IP6CB(skb)->frag_max_size,
eventually caused an unexpected IPv6 fragmentation in ip6_fragment()
through ip6_finish_output().
This patch clears IP6CB(skb), which potentially contains garbage data,
on the SRH ip4ip6 encapsulation.
Fixes: 32d99d0b6702 ("ipv6: sr: add support for ip4ip6 encapsulation")
Signed-off-by: Yohei Kanemaru <yohei.kanemaru@gmail.com>
[ Upstream commit c5ee066333ebc322a24a00a743ed941a0c68617e ]
IPv6 does not consider if the socket is bound to a device when binding
to an address. The result is that a socket can be bound to eth0 and then
bound to the address of eth1. If the device is a VRF, the result is that
a socket can only be bound to an address in the default VRF.
Resolve by considering the device if sk_bound_dev_if is set.
This problem exists from the beginning of git history.
Signed-off-by: David Ahern <dsahern@gmail.com>
ade446403bfb ("net: ipv4: do not handle duplicate fragments as
overlapping") was backported to many stable trees, but it had a problem
that was "accidentally" fixed by the upstream commit 0ff89efb5246 ("ip:
fail fast on IP defrag errors")
This is the fixup for that problem as we do not want the larger patch in
the older stable trees.
Fixes: ade446403bfb ("net: ipv4: do not handle duplicate fragments as overlapping")
Reported-by: Ivan Babrou <ivan@cloudflare.com>
Reported-by: Eric Dumazet <edumazet@google.com>
commit 93171ba6f1deffd82f381d36cb13177872d023f6 upstream.
Kyungtae Kim detected a potential integer overflow in bcm_[rx|tx]_setup()
when the conversion into ktime multiplies the given value with NSEC_PER_USEC
(1000).
Reference: https://marc.info/?l=linux-can&m=154732118819828&w=2
Add a check for the given tv_usec, so that the value stays below one second.
Additionally limit the tv_sec value to a reasonable value for CAN related
use-cases of 400 days and ensure all values to be positive.
Reported-by: Kyungtae Kim <kt0755@gmail.com>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: linux-stable <stable@vger.kernel.org> # >= 2.6.26
Tested-by: Kyungtae Kim <kt0755@gmail.com>
Acked-by: Andre Naujoks <nautsch2@gmail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
[ Upstream commit f6f2a4a2eb92bc73671204198bb2f8ab53ff59fb ]
Setting the low threshold to 0 has no effect on frags allocation,
we need to clear high_thresh instead.
The code was pre-existent to commit 648700f76b03 ("inet: frags:
use rhashtables for reassembly units"), but before the above,
such assignment had a different role: prevent concurrent eviction
from the worker and the netns cleanup helper.
Fixes: 648700f76b03 ("inet: frags: use rhashtables for reassembly units")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit 13d7f46386e060df31b727c9975e38306fa51e7a ]
TCP transmission with MSG_ZEROCOPY fails if the peer closes its end of
the connection and so transitions this socket to CLOSE_WAIT state.
Transmission in close wait state is acceptable. Other similar tests in
the stack (e.g., in FastOpen) accept both states. Relax this test, too.
Link: https://www.mail-archive.com/netdev@vger.kernel.org/msg276886.html
Link: https://www.mail-archive.com/netdev@vger.kernel.org/msg227390.html
Fixes: f214f915e7db ("tcp: enable MSG_ZEROCOPY")
Reported-by: Marek Majkowski <marek@cloudflare.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
CC: Yuchung Cheng <ycheng@google.com>
CC: Neal Cardwell <ncardwell@google.com>
CC: Soheil Hassas Yeganeh <soheil@google.com>
CC: Alexey Kodanev <alexey.kodanev@oracle.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit f97f4dd8b3bb9d0993d2491e0f22024c68109184 ]
IPv4 routing tables are flushed in two cases:
1. In response to events in the netdev and inetaddr notification chains
2. When a network namespace is being dismantled
In both cases only routes associated with a dead nexthop group are
flushed. However, a nexthop group will only be marked as dead in case it
is populated with actual nexthops using a nexthop device. This is not
the case when the route in question is an error route (e.g.,
'blackhole', 'unreachable').
Therefore, when a network namespace is being dismantled such routes are
not flushed and leaked [1].
To reproduce:
# ip netns add blue
# ip -n blue route add unreachable 192.0.2.0/24
# ip netns del blue
Fix this by not skipping error routes that are not marked with
RTNH_F_DEAD when flushing the routing tables.
To prevent the flushing of such routes in case #1, add a parameter to
fib_table_flush() that indicates if the table is flushed as part of
namespace dismantle or not.
Note that this problem does not exist in IPv6 since error routes are
associated with the loopback device.
[1]
unreferenced object 0xffff888066650338 (size 56):
comm "ip", pid 1206, jiffies 4294786063 (age 26.235s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 b0 1c 62 61 80 88 ff ff ..........ba....
e8 8b a1 64 80 88 ff ff 00 07 00 08 fe 00 00 00 ...d............
backtrace:
[<00000000856ed27d>] inet_rtm_newroute+0x129/0x220
[<00000000fcdfc00a>] rtnetlink_rcv_msg+0x397/0xa20
[<00000000cb85801a>] netlink_rcv_skb+0x132/0x380
[<00000000ebc991d2>] netlink_unicast+0x4c0/0x690
[<0000000014f62875>] netlink_sendmsg+0x929/0xe10
[<00000000bac9d967>] sock_sendmsg+0xc8/0x110
[<00000000223e6485>] ___sys_sendmsg+0x77a/0x8f0
[<000000002e94f880>] __sys_sendmsg+0xf7/0x250
[<00000000ccb1fa72>] do_syscall_64+0x14d/0x610
[<00000000ffbe3dae>] entry_SYSCALL_64_after_hwframe+0x49/0xbe
[<000000003a8b605b>] 0xffffffffffffffff
unreferenced object 0xffff888061621c88 (size 48):
6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
6b 6b 6b 6b 6b 6b 6b 6b d8 8e 26 5f 80 88 ff ff kkkkkkkk..&_....
backtrace:
[<00000000733609e3>] fib_table_insert+0x978/0x1500
Fixes: 8cced9eff1d4 ("[NETNS]: Enable routing configuration in non-initial namespace.")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 04a4af334b971814eedf4e4a413343ad3287d9a9 ]
For nested and variable attributes, the expected length of an attribute
is not known and marked by a negative number. This results in an OOB
read when the expected length is later used to check if the attribute is
all zeros. Fix this by using the actual length of the attribute rather
than the expected length.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit cd0c4e70fc0ccfa705cdf55efb27519ce9337a26 ]
Martin reported a set of filters don't work after changing
from reclassify to continue. Looking into the code, it
looks like skb protocol is not always fetched for each
iteration of the filters. But, as demonstrated by Martin,
TC actions could modify skb->protocol, for example act_vlan,
this means we have to refetch skb protocol in each iteration,
rather than using the one we fetch in the beginning of the loop.
This bug is _not_ introduced by commit 3b3ae880266d
("net: sched: consolidate tc_classify{,_compat}"), technically,
if act_vlan is the only action that modifies skb protocol, then
it is commit c7e2b9689ef8 ("sched: introduce vlan action") which
introduced this bug.
Reported-by: Martin Olsson <martin.olsson+netdev@sentorsecurity.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Jiri Pirko <jiri@resnulli.us>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit 6c57f0458022298e4da1729c67bd33ce41c14e7a ]
In certain cases, pskb_trim_rcsum() may change skb pointers.
Reinitialize header pointers afterwards to avoid potential
use-after-frees. Add a note in the documentation of
pskb_trim_rcsum(). Found by KASAN.
[ Upstream commit 28c1382fa28f2e2d9d0d6f25ae879b5af2ecbd03 ]
The skb header should be set to ethernet header before using
is_skb_forwardable. Because the ethernet header length has been
considered in is_skb_forwardable(including dev->hard_header_len
length).
To reproduce the issue:
1, add 2 ports on linux bridge br using following commands:
$ brctl addbr br
$ brctl addif br eth0
$ brctl addif br eth1
2, the MTU of eth0 and eth1 is 1500
3, send a packet(Data 1480, UDP 8, IP 20, Ethernet 14, VLAN 4)
from eth0 to eth1
So the expect result is packet larger than 1500 cannot pass through
eth0 and eth1. But currently, the packet passes through success, it
means eth1's MTU limit doesn't take effect.
Fixes: f6367b4660dd ("bridge: use is_skb_forwardable in forward path")
Cc: bridge@lists.linux-foundation.org
Cc: Nkolay Aleksandrov <nikolay@cumulusnetworks.com>
Cc: Roopa Prabhu <roopa@cumulusnetworks.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Yunjian Wang <wangyunjian@huawei.com>
[ Upstream commit 06aa151ad1fc74a49b45336672515774a678d78d ]
If same destination IP address config is already existing, that config is
just used. MAC address also should be same.
However, there is no MAC address checking routine.
So that MAC address checking routine is added.
test commands:
%iptables -A INPUT -p tcp -i lo -d 192.168.0.5 --dport 80 \
-j CLUSTERIP --new --hashmode sourceip \
--clustermac 01:00:5e:00:00:20 --total-nodes 2 --local-node 1
--clustermac 01:00:5e:00:00:21 --total-nodes 2 --local-node 1
After this patch, above commands are disallowed.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
[ Upstream commit 0fbe82e628c817e292ff588cd5847fc935e025f2 ]
after set SO_DONTROUTE to 1, the IP layer should not route packets if
the dest IP address is not in link scope. But if the socket has cached
the dst_entry, such packets would be routed until the sk_dst_cache
expires. So we should clean the sk_dst_cache when a user set
SO_DONTROUTE option. Below are server/client python scripts which
could reprodue this issue:
server side code:
import socket
import struct
import time
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(('0.0.0.0', 9000))
s.listen(1)
sock, addr = s.accept()
sock.setsockopt(socket.SOL_SOCKET, socket.SO_DONTROUTE, struct.pack('i', 1))
while True:
sock.send(b'foo')
time.sleep(1)
client side code:
import socket
import time
s.connect(('server_address', 9000))
while True:
data = s.recv(1024)
print(data)
Signed-off-by: yupeng <yupeng0921@gmail.com>
[ Upstream commit d4a7e9bb74b5aaf07b89f6531c080b1130bdf019 ]
I realized the last patch calls dev_get_by_index_rcu in a branch not
holding the rcu lock. Add the calls to rcu_read_lock and rcu_read_unlock.
Fixes: ec90ad334986 ("ipv6: Consider sk_bound_dev_if when binding a socket to a v4 mapped address")
[ Upstream commit f8c468e8537925e0c4607263f498a1b7c0c8982e ]
Commit dcda9b04713c ("mm, tree wide: replace __GFP_REPEAT by
__GFP_RETRY_MAYFAIL with more useful semantic") replaced __GFP_REPEAT in
alloc_skb_with_frags() with __GFP_RETRY_MAYFAIL when the allocation may
directly reclaim.
The previous behavior would require reclaim up to 1 << order pages for
skb aligned header_len of order > PAGE_ALLOC_COSTLY_ORDER before failing,
otherwise the allocations in alloc_skb() would loop in the page allocator
looking for memory. __GFP_RETRY_MAYFAIL makes both allocations failable
under memory pressure, including for the HEAD allocation.
This can cause, among many other things, write() to fail with ENOTCONN
during RPC when under memory pressure.
These allocations should succeed as they did previous to dcda9b04713c
even if it requires calling the oom killer and additional looping in the
page allocator to find memory. There is no way to specify the previous
behavior of __GFP_REPEAT, but it's unlikely to be necessary since the
previous behavior only guaranteed that 1 << order pages would be reclaimed
before failing for order > PAGE_ALLOC_COSTLY_ORDER. That reclaim is not
guaranteed to be contiguous memory, so repeating for such large orders is
usually not beneficial.
Removing the setting of __GFP_RETRY_MAYFAIL to restore the previous
behavior, specifically not allowing alloc_skb() to fail for small orders
and oom kill if necessary rather than allowing RPCs to fail.
Fixes: dcda9b04713c ("mm, tree wide: replace __GFP_REPEAT by __GFP_RETRY_MAYFAIL with more useful semantic")
Signed-off-by: David Rientjes <rientjes@google.com>
[ Upstream commit ec90ad334986fa5856d11dd272f7f22fa86c55c4 ]
Similar to c5ee066333eb ("ipv6: Consider sk_bound_dev_if when binding a
socket to an address"), binding a socket to v4 mapped addresses needs to
consider if the socket is bound to a device.
This problem also exists from the beginning of git history.
commit 2753ca5d9009c180dbfd4c802c80983b4b6108d1 upstream.
BUG: KMSAN: uninit-value in tipc_nl_compat_doit+0x404/0xa10 net/tipc/netlink_compat.c:335
CPU: 0 PID: 4514 Comm: syz-executor485 Not tainted 4.16.0+ #87
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:53
kmsan_report+0x142/0x240 mm/kmsan/kmsan.c:1067
__msan_warning_32+0x6c/0xb0 mm/kmsan/kmsan_instr.c:683
tipc_nl_compat_recv+0x164b/0x2700 net/tipc/netlink_compat.c:1153
genl_family_rcv_msg net/netlink/genetlink.c:599 [inline]
genl_rcv_msg+0x1686/0x1810 net/netlink/genetlink.c:624
netlink_rcv_skb+0x378/0x600 net/netlink/af_netlink.c:2447
genl_rcv+0x63/0x80 net/netlink/genetlink.c:635
netlink_unicast_kernel net/netlink/af_netlink.c:1311 [inline]
netlink_unicast+0x166b/0x1740 net/netlink/af_netlink.c:1337
netlink_sendmsg+0x1048/0x1310 net/netlink/af_netlink.c:1900
sock_sendmsg_nosec net/socket.c:630 [inline]
sock_sendmsg net/socket.c:640 [inline]
___sys_sendmsg+0xec0/0x1310 net/socket.c:2046
__sys_sendmsg net/socket.c:2080 [inline]
SYSC_sendmsg+0x2a3/0x3d0 net/socket.c:2091
SyS_sendmsg+0x54/0x80 net/socket.c:2087
do_syscall_64+0x309/0x430 arch/x86/entry/common.c:287
RIP: 0033:0x43fda9
RSP: 002b:00007ffd0c184ba8 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 000000000043fda9
RDX: 0000000000000000 RSI: 0000000020023000 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 00000000004002c8 R09: 00000000004002c8
R10: 00000000004002c8 R11: 0000000000000213 R12: 00000000004016d0
R13: 0000000000401760 R14: 0000000000000000 R15: 0000000000000000
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:278 [inline]
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:188
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:314
kmsan_slab_alloc+0x11/0x20 mm/kmsan/kmsan.c:321
slab_post_alloc_hook mm/slab.h:445 [inline]
slab_alloc_node mm/slub.c:2737 [inline]
__kmalloc_node_track_caller+0xaed/0x11c0 mm/slub.c:4369
__kmalloc_reserve net/core/skbuff.c:138 [inline]
__alloc_skb+0x2cf/0x9f0 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:984 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1183 [inline]
netlink_sendmsg+0x9a6/0x1310 net/netlink/af_netlink.c:1875
In tipc_nl_compat_recv(), when the len variable returned by
nlmsg_attrlen() is 0, the message is still treated as a valid one,
which is obviously unresonable. When len is zero, it means the
message not only doesn't contain any valid TLV payload, but also
TLV header is not included. Under this stituation, tlv_type field
in TLV header is still accessed in tipc_nl_compat_dumpit() or
tipc_nl_compat_doit(), but the field space is obviously illegal.
Of course, it is not initialized.
Reported-by: syzbot+bca0dc46634781f08b38@syzkaller.appspotmail.com
Reported-by: syzbot+6bdb590321a7ae40c1a6@syzkaller.appspotmail.com
Signed-off-by: Ying Xue <ying.xue@windriver.com>
commit 974cb0e3e7c963ced06c4e32c5b2884173fa5e01 upstream.
syzbot reported:
BUG: KMSAN: uninit-value in __arch_swab32 arch/x86/include/uapi/asm/swab.h:10 [inline]
BUG: KMSAN: uninit-value in __fswab32 include/uapi/linux/swab.h:59 [inline]
BUG: KMSAN: uninit-value in tipc_nl_compat_name_table_dump+0x4a8/0xba0 net/tipc/netlink_compat.c:826
CPU: 0 PID: 6290 Comm: syz-executor848 Not tainted 4.19.0-rc8+ #70
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x306/0x460 lib/dump_stack.c:113
kmsan_report+0x1a2/0x2e0 mm/kmsan/kmsan.c:917
__msan_warning+0x7c/0xe0 mm/kmsan/kmsan_instr.c:500
__tipc_nl_compat_dumpit+0x59e/0xdb0 net/tipc/netlink_compat.c:205
tipc_nl_compat_dumpit+0x63a/0x820 net/tipc/netlink_compat.c:270
tipc_nl_compat_handle net/tipc/netlink_compat.c:1151 [inline]
tipc_nl_compat_recv+0x1402/0x2760 net/tipc/netlink_compat.c:1210
genl_family_rcv_msg net/netlink/genetlink.c:601 [inline]
genl_rcv_msg+0x185c/0x1a20 net/netlink/genetlink.c:626
netlink_rcv_skb+0x394/0x640 net/netlink/af_netlink.c:2454
genl_rcv+0x63/0x80 net/netlink/genetlink.c:637
netlink_unicast_kernel net/netlink/af_netlink.c:1317 [inline]
netlink_unicast+0x166d/0x1720 net/netlink/af_netlink.c:1343
netlink_sendmsg+0x1391/0x1420 net/netlink/af_netlink.c:1908
sock_sendmsg_nosec net/socket.c:621 [inline]
sock_sendmsg net/socket.c:631 [inline]
___sys_sendmsg+0xe47/0x1200 net/socket.c:2116
__sys_sendmsg net/socket.c:2154 [inline]
__do_sys_sendmsg net/socket.c:2163 [inline]
__se_sys_sendmsg+0x307/0x460 net/socket.c:2161
__x64_sys_sendmsg+0x4a/0x70 net/socket.c:2161
do_syscall_64+0xbe/0x100 arch/x86/entry/common.c:291
entry_SYSCALL_64_after_hwframe+0x63/0xe7
RIP: 0033:0x440179
Code: 18 89 d0 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 fb 13 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007ffecec49318 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 0000000000440179
RDX: 0000000000000000 RSI: 0000000020000100 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 0000000000000000 R09: 00000000004002c8
R10: 0000000000000000 R11: 0000000000000213 R12: 0000000000401a00
R13: 0000000000401a90 R14: 0000000000000000 R15: 0000000000000000
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:255 [inline]
kmsan_internal_poison_shadow+0xc8/0x1d0 mm/kmsan/kmsan.c:180
kmsan_kmalloc+0xa4/0x120 mm/kmsan/kmsan_hooks.c:104
kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan_hooks.c:113
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2727 [inline]
__kmalloc_node_track_caller+0xb43/0x1400 mm/slub.c:4360
__alloc_skb+0x422/0xe90 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:996 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1189 [inline]
netlink_sendmsg+0xcaf/0x1420 net/netlink/af_netlink.c:1883
We cannot take for granted the thing that the length of data contained
in TLV is longer than the size of struct tipc_name_table_query in
tipc_nl_compat_name_table_dump().
Reported-by: syzbot+06e771a754829716a327@syzkaller.appspotmail.com
commit edf5ff04a45750ac8ce2435974f001dc9cfbf055 upstream.
syzbot reports following splat:
BUG: KMSAN: uninit-value in strlen+0x3b/0xa0 lib/string.c:486
CPU: 1 PID: 9306 Comm: syz-executor172 Not tainted 4.20.0-rc7+ #2
Google 01/01/2011
Call Trace:
dump_stack+0x173/0x1d0 lib/dump_stack.c:113
kmsan_report+0x12e/0x2a0 mm/kmsan/kmsan.c:613
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:313
nla_put_string include/net/netlink.h:1154 [inline]
__tipc_nl_compat_link_set net/tipc/netlink_compat.c:708 [inline]
tipc_nl_compat_link_set+0x929/0x1220 net/tipc/netlink_compat.c:744
__tipc_nl_compat_doit net/tipc/netlink_compat.c:311 [inline]
tipc_nl_compat_doit+0x3aa/0xaf0 net/tipc/netlink_compat.c:344
tipc_nl_compat_handle net/tipc/netlink_compat.c:1107 [inline]
tipc_nl_compat_recv+0x14d7/0x2760 net/tipc/netlink_compat.c:1210
genl_rcv_msg+0x185f/0x1a60 net/netlink/genetlink.c:626
netlink_rcv_skb+0x444/0x640 net/netlink/af_netlink.c:2477
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0xf40/0x1020 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x127f/0x1300 net/netlink/af_netlink.c:1917
___sys_sendmsg+0xdb9/0x11b0 net/socket.c:2116
__se_sys_sendmsg+0x305/0x460 net/socket.c:2161
do_syscall_64+0xbc/0xf0 arch/x86/entry/common.c:291
The uninitialised access happened in
nla_put_string(skb, TIPC_NLA_LINK_NAME, lc->name)
This is because lc->name string is not validated before it's used.
Reported-by: syzbot+d78b8a29241a195aefb8@syzkaller.appspotmail.com
commit 0762216c0ad2a2fccd63890648eca491f2c83d9a upstream.
syzbot reported:
BUG: KMSAN: uninit-value in strlen+0x3b/0xa0 lib/string.c:484
CPU: 1 PID: 6371 Comm: syz-executor652 Not tainted 4.19.0-rc8+ #70
Call Trace:
nla_put_string include/net/netlink.h:1011 [inline]
tipc_nl_compat_bearer_enable+0x238/0x7b0 net/tipc/netlink_compat.c:389
tipc_nl_compat_doit+0x39f/0xae0 net/tipc/netlink_compat.c:344
tipc_nl_compat_recv+0x147c/0x2760 net/tipc/netlink_compat.c:1107
RIP: 0033:0x440179
RSP: 002b:00007fffef7beee8 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
The root cause is that we don't validate whether bear name is a valid
string in tipc_nl_compat_bearer_enable().
Meanwhile, we also fix the same issue in the following functions:
tipc_nl_compat_bearer_disable()
tipc_nl_compat_link_stat_dump()
tipc_nl_compat_media_set()
tipc_nl_compat_bearer_set()
Reported-by: syzbot+b33d5cae0efd35dbfe77@syzkaller.appspotmail.com
commit 8b66fee7f8ee18f9c51260e7a43ab37db5177a05 upstream.
CPU: 1 PID: 11057 Comm: syz-executor0 Not tainted 4.20.0-rc7+ #2
Call Trace:
__msan_warning+0x82/0xf0 mm/kmsan/kmsan_instr.c:295
tipc_nl_compat_link_reset_stats+0x1f0/0x360 net/tipc/netlink_compat.c:760
RIP: 0033:0x457ec9
Code: 6d b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 3b b7 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f2557338c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457ec9
RDX: 0000000000000000 RSI: 00000000200001c0 RDI: 0000000000000003
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f25573396d4
R13: 00000000004cb478 R14: 00000000004d86c8 R15: 00000000ffffffff
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:204 [inline]
kmsan_internal_poison_shadow+0x92/0x150 mm/kmsan/kmsan.c:158
kmsan_kmalloc+0xa6/0x130 mm/kmsan/kmsan_hooks.c:176
kmsan_slab_alloc+0xe/0x10 mm/kmsan/kmsan_hooks.c:185
slab_alloc_node mm/slub.c:2759 [inline]
__kmalloc_node_track_caller+0xe18/0x1030 mm/slub.c:4383
__kmalloc_reserve net/core/skbuff.c:137 [inline]
__alloc_skb+0x309/0xa20 net/core/skbuff.c:205
alloc_skb include/linux/skbuff.h:998 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline]
netlink_sendmsg+0xb82/0x1300 net/netlink/af_netlink.c:1892
The uninitialised access happened in tipc_nl_compat_link_reset_stats:
nla_put_string(skb, TIPC_NLA_LINK_NAME, name)
This is because name string is not validated before it's used.
Reported-by: syzbot+e01d94b5a4c266be6e4c@syzkaller.appspotmail.com
commit 400b8b9a2a17918f8ce00786f596f530e7f30d50 upstream.
The similar issue as fixed in Commit 4a2eb0c37b47 ("sctp: initialize
sin6_flowinfo for ipv6 addrs in sctp_inet6addr_event") also exists
in sctp_inetaddr_event, as Alexander noticed.
To fix it, allocate sctp_sockaddr_entry with kzalloc for both sctp
ipv4 and ipv6 addresses, as does in sctp_v4/6_copy_addrlist().
Reported-by: Alexander Potapenko <glider@google.com>
Reported-by: syzbot+ae0c70c0c2d40c51bb92@syzkaller.appspotmail.com
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
commit e2c8d550a973bb34fc28bc8d0ec996f84562fb8a upstream.
The [ip,ip6,arp]_tables use x_tables_info internally and the underlying
memory is already accounted to kmemcg. Do the same for ebtables. The
syzbot, by using setsockopt(EBT_SO_SET_ENTRIES), was able to OOM the
whole system from a restricted memcg, a potential DoS.
By accounting the ebt_table_info, the memory used for ebt_table_info can
be contained within the memcg of the allocating process. However the
lifetime of ebt_table_info is independent of the allocating process and
is tied to the network namespace. So, the oom-killer will not be able to
relieve the memory pressure due to ebt_table_info memory. The memory for
ebt_table_info is allocated through vmalloc. Currently vmalloc does not
handle the oom-killed allocating process correctly and one large
allocation can bypass memcg limit enforcement. So, with this patch,
at least the small allocations will be contained. For large allocations,
we need to fix vmalloc.
Reported-by: syzbot+7713f3aa67be76b1552c@syzkaller.appspotmail.com
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Reviewed-by: Kirill Tkhai <ktkhai@virtuozzo.com>
commit 81c88b18de1f11f70c97f28ced8d642c00bb3955 upstream.
If we ignore the error we'll hit a null dereference a little later.
Reported-by: syzbot+4b98281f2401ab849f4b@syzkaller.appspotmail.com
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit e7c87bd6cc4ec7b0ac1ed0a88a58f8206c577488 upstream.
Syzkaller was able to construct a packet of negative length by
redirecting from bpf_prog_test_run_skb with BPF_PROG_TYPE_LWT_XMIT:
BUG: KASAN: slab-out-of-bounds in memcpy include/linux/string.h:345 [inline]
BUG: KASAN: slab-out-of-bounds in skb_copy_from_linear_data include/linux/skbuff.h:3421 [inline]
BUG: KASAN: slab-out-of-bounds in __pskb_copy_fclone+0x2dd/0xeb0 net/core/skbuff.c:1395
Read of size 4294967282 at addr ffff8801d798009c by task syz-executor2/12942
kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x13e/0x1b0 mm/kasan/kasan.c:267
memcpy+0x23/0x50 mm/kasan/kasan.c:302
__pskb_copy include/linux/skbuff.h:1053 [inline]
pskb_copy include/linux/skbuff.h:2904 [inline]
skb_realloc_headroom+0xe7/0x120 net/core/skbuff.c:1539
ipip6_tunnel_xmit net/ipv6/sit.c:965 [inline]
sit_tunnel_xmit+0xe1b/0x30d0 net/ipv6/sit.c:1029
__netdev_start_xmit include/linux/netdevice.h:4325 [inline]
netdev_start_xmit include/linux/netdevice.h:4334 [inline]
xmit_one net/core/dev.c:3219 [inline]
dev_hard_start_xmit+0x295/0xc90 net/core/dev.c:3235
__dev_queue_xmit+0x2f0d/0x3950 net/core/dev.c:3805
dev_queue_xmit+0x17/0x20 net/core/dev.c:3838
__bpf_tx_skb net/core/filter.c:2016 [inline]
__bpf_redirect_common net/core/filter.c:2054 [inline]
__bpf_redirect+0x5cf/0xb20 net/core/filter.c:2061
____bpf_clone_redirect net/core/filter.c:2094 [inline]
bpf_clone_redirect+0x2f6/0x490 net/core/filter.c:2066
bpf_prog_41f2bcae09cd4ac3+0xb25/0x1000
The generated test constructs a packet with mac header, network
header, skb->data pointing to network header and skb->len 0.
Redirecting to a sit0 through __bpf_redirect_no_mac pulls the
mac length, even though skb->data already is at skb->network_header.
bpf_prog_test_run_skb has already pulled it as LWT_XMIT !is_l2.
Update the offset calculation to pull only if skb->data differs
from skb->network_header, which is not true in this case.
The test itself can be run only from commit 1cf1cae963c2 ("bpf:
introduce BPF_PROG_TEST_RUN command"), but the same type of packets
with skb at network header could already be built from lwt xmit hooks,
so this fix is more relevant to that commit.
Also set the mac header on redirect from LWT_XMIT, as even after this
change to __bpf_redirect_no_mac that field is expected to be set, but
is not yet in ip_finish_output2.
Fixes: 3a0af8fd61f9 ("bpf: BPF for lightweight tunnel infrastructure")
Reported-by: syzbot <syzkaller@googlegroups.com>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 4a06fa67c4da20148803525151845276cdb995c1 ]
Commit 2efd4fca703a ("ip: in cmsg IP(V6)_ORIGDSTADDR call
pskb_may_pull") avoided a read beyond the end of the skb linear
segment by calling pskb_may_pull.
That function can trigger a BUG_ON in pskb_expand_head if the skb is
shared, which it is when when peeking. It can also return ENOMEM.
Avoid both by switching to safer skb_header_pointer.
Fixes: 2efd4fca703a ("ip: in cmsg IP(V6)_ORIGDSTADDR call pskb_may_pull")
Suggested-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit d972f3dce8d161e2142da0ab1ef25df00e2f21a9 ]
'dev' is non NULL when the addr_len check triggers so it must goto a label
that does the dev_put otherwise dev will have a leaked refcount.
This bug causes the ib_ipoib module to become unloadable when using
systemd-network as it triggers this check on InfiniBand links.
Fixes: 99137b7888f4 ("packet: validate address length")
Reported-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Acked-by: Willem de Bruijn <willemb@google.com>
state
[ Upstream commit 4c84edc11b76590859b1e45dd676074c59602dc4 ]
When handling DNAT'ed packets on a bridge device, the neighbour cache entry
from lookup was used without checking its state. It means that a cache entry
in the NUD_STALE state will be used directly instead of entering the NUD_DELAY
state to confirm the reachability of the neighbor.
This problem becomes worse after commit 2724680bceee ("neigh: Keep neighbour
cache entries if number of them is small enough."), since all neighbour cache
entries in the NUD_STALE state will be kept in the neighbour table as long as
the number of cache entries does not exceed the value specified in gc_thresh1.
This commit validates the state of a neighbour cache entry before using
the entry.
Signed-off-by: JianJhen Chen <kchen@synology.com>
Reviewed-by: JinLin Chen <jlchen@synology.com>
[ Upstream commit 7d033c9f6a7fd3821af75620a0257db87c2b552a ]
This patch makes sure the flow label in the IPv6 header
forged in ipv6_local_error() is initialized.
BUG: KMSAN: kernel-infoleak in _copy_to_user+0x16b/0x1f0 lib/usercopy.c:32
CPU: 1 PID: 24675 Comm: syz-executor1 Not tainted 4.20.0-rc7+ #4
Call Trace:
kmsan_internal_check_memory+0x455/0xb00 mm/kmsan/kmsan.c:675
kmsan_copy_to_user+0xab/0xc0 mm/kmsan/kmsan_hooks.c:601
copy_to_user include/linux/uaccess.h:177 [inline]
move_addr_to_user+0x2e9/0x4f0 net/socket.c:227
___sys_recvmsg+0x5d7/0x1140 net/socket.c:2284
__sys_recvmsg net/socket.c:2327 [inline]
__do_sys_recvmsg net/socket.c:2337 [inline]
__se_sys_recvmsg+0x2fa/0x450 net/socket.c:2334
__x64_sys_recvmsg+0x4a/0x70 net/socket.c:2334
RIP: 0033:0x457ec9
RSP: 002b:00007f8750c06c78 EFLAGS: 00000246 ORIG_RAX: 000000000000002f
RDX: 0000000000002000 RSI: 0000000020000400 RDI: 0000000000000005
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f8750c076d4
R13: 00000000004c4a60 R14: 00000000004d8140 R15: 00000000ffffffff
Uninit was stored to memory at:
kmsan_save_stack mm/kmsan/kmsan.c:219 [inline]
kmsan_internal_chain_origin+0x134/0x230 mm/kmsan/kmsan.c:439
__msan_chain_origin+0x70/0xe0 mm/kmsan/kmsan_instr.c:200
ipv6_recv_error+0x1e3f/0x1eb0 net/ipv6/datagram.c:475
udpv6_recvmsg+0x398/0x2ab0 net/ipv6/udp.c:335
inet_recvmsg+0x4fb/0x600 net/ipv4/af_inet.c:830
sock_recvmsg_nosec net/socket.c:794 [inline]
sock_recvmsg+0x1d1/0x230 net/socket.c:801
___sys_recvmsg+0x4d5/0x1140 net/socket.c:2278
ipv6_local_error+0x1a7/0x9e0 net/ipv6/datagram.c:334
__ip6_append_data+0x129f/0x4fd0 net/ipv6/ip6_output.c:1311
ip6_make_skb+0x6cc/0xcf0 net/ipv6/ip6_output.c:1775
udpv6_sendmsg+0x3f8e/0x45d0 net/ipv6/udp.c:1384
inet_sendmsg+0x54a/0x720 net/ipv4/af_inet.c:798
__sys_sendto+0x8c4/0xac0 net/socket.c:1788
__do_sys_sendto net/socket.c:1800 [inline]
__se_sys_sendto+0x107/0x130 net/socket.c:1796
__x64_sys_sendto+0x6e/0x90 net/socket.c:1796
Bytes 4-7 of 28 are uninitialized
Memory access of size 28 starts at ffff8881937bfce0
Data copied to user address 0000000020000000
commit 0aaa81377c5a01f686bcdb8c7a6929a7bf330c68 upstream.
Muyu Yu provided a POC where user root with CAP_NET_ADMIN can create a CAN
frame modification rule that makes the data length code a higher value than
the available CAN frame data size. In combination with a configured checksum
calculation where the result is stored relatively to the end of the data
(e.g. cgw_csum_xor_rel) the tail of the skb (e.g. frag_list pointer in
skb_shared_info) can be rewritten which finally can cause a system crash.
Michael Kubecek suggested to drop frames that have a DLC exceeding the
available space after the modification process and provided a patch that can
handle CAN FD frames too. Within this patch we also limit the length for the
checksum calculations to the maximum of Classic CAN data length (8).
CAN frames that are dropped by these additional checks are counted with the
CGW_DELETED counter which indicates misconfigurations in can-gw rules.
This fixes CVE-2019-3701.
Reported-by: Muyu Yu <ieatmuttonchuan@gmail.com>
Reported-by: Marcus Meissner <meissner@suse.de>
Suggested-by: Michal Kubecek <mkubecek@suse.cz>
Tested-by: Muyu Yu <ieatmuttonchuan@gmail.com>
Cc: linux-stable <stable@vger.kernel.org> # >= v3.2
commit d4b09acf924b84bae77cad090a9d108e70b43643 upstream.
if node have NFSv41+ mounts inside several net namespaces
it can lead to use-after-free in svc_process_common()
/* Setup reply header */
rqstp->rq_xprt->xpt_ops->xpo_prep_reply_hdr(rqstp); <<< HERE
svc_process_common() can use incorrect rqstp->rq_xprt,
its caller function bc_svc_process() takes it from serv->sv_bc_xprt.
The problem is that serv is global structure but sv_bc_xprt
is assigned per-netnamespace.
According to Trond, the whole "let's set up rqstp->rq_xprt
for the back channel" is nothing but a giant hack in order
to work around the fact that svc_process_common() uses it
to find the xpt_ops, and perform a couple of (meaningless
for the back channel) tests of xpt_flags.
All we really need in svc_process_common() is to be able to run
rqstp->rq_xprt->xpt_ops->xpo_prep_reply_hdr()
Bruce J Fields points that this xpo_prep_reply_hdr() call
is an awfully roundabout way just to do "svc_putnl(resv, 0);"
in the tcp case.
This patch does not initialiuze rqstp->rq_xprt in bc_svc_process(),
now it calls svc_process_common() with rqstp->rq_xprt = NULL.
To adjust reply header svc_process_common() just check
rqstp->rq_prot and calls svc_tcp_prep_reply_hdr() for tcp case.
To handle rqstp->rq_xprt = NULL case in functions called from
svc_process_common() patch intruduces net namespace pointer
svc_rqst->rq_bc_net and adjust SVC_NET() definition.
Some other function was also adopted to properly handle described case.
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: stable@vger.kernel.org
Fixes: 23c20ecd4475 ("NFS: callback up - users counting cleanup")
v2: - added lost extern svc_tcp_prep_reply_hdr()
- dropped trace_svc_process() changes
commit 574d356b7a02c7e1b01a1d9cba8a26b3c2888f45 upstream.
If the requested msize is too small (either from command line argument
or from the server version reply), we won't get any work done.
If it's *really* too small, nothing will work, and this got caught by
syzbot recently (on a new kmem_cache_create_usercopy() call)
Just set a minimum msize to 4k in both code paths, until someone
complains they have a use-case for a smaller msize.
We need to check in both mount option and server reply individually
because the msize for the first version request would be unchecked
with just a global check on clnt->msize.
Link: http://lkml.kernel.org/r/1541407968-31350-1-git-send-email-asmadeus@codewreck.org
Reported-by: syzbot+0c1d61e4db7db94102ca@syzkaller.appspotmail.com
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Latchesar Ionkov <lucho@ionkov.net>
commit b8be5674fa9a6f3677865ea93f7803c4212f3e10 upstream.
commit 4ecd55ea074217473f94cfee21bb72864d39f8d7 upstream.
After commit d202cce8963d, an expired cache_head can be removed from the
cache_detail's hash.
However, the expired cache_head may be waiting for a reply from a
previously submitted request. Such a cache_head has an increased
refcounter and therefore it won't be freed after cache_put(freeme).
Because the cache_head was removed from the hash it cannot be found
during cache_clean() and can be leaked forever, together with stalled
cache_request and other taken resources.
In our case we noticed it because an entry in the export cache was
holding a reference on a filesystem.
Fixes d202cce8963d ("sunrpc: never return expired entries in sunrpc_cache_lookup")
Cc: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Cc: stable@kernel.org # 2.6.35
Reviewed-by: NeilBrown <neilb@suse.com>
[ Upstream commit 34b1e0e9efe101822e83cc62d22443ed3867ae7a ]
mac80211 uses the frag list to build AMSDU. When freeing
the skb, it may not be really freed, since someone is still
holding a reference to it.
In that case, when TCP skb is being retransmitted, the
pointer to the frag list is being reused, while the data
in there is no longer valid.
Since we will never get frag list from the network stack,
as mac80211 doesn't advertise the capability, we can safely
free and nullify it before releasing the SKB.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
[ Upstream commit cf76785d30712d90185455e752337acdb53d2a5d ]
Ensure that we clear XPRT_CONNECTING before releasing the XPRT_LOCK so that
we don't have races between the (asynchronous) socket setup code and
tasks in xprt_connect().
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Tested-by: Chuck Lever <chuck.lever@oracle.com>
[ Upstream commit 542fbda0f08f1cbbc250f9e59f7537649651d0c8 ]
The dst entry might already have a zero refcount, waiting on rcu list
to be free'd. Using dst_hold() transitions its reference count to 1, and
next dst release will try to free it again -- resulting in a double free:
WARNING: CPU: 1 PID: 0 at include/net/dst.h:239 nf_xfrm_me_harder+0xe7/0x130 [nf_nat]
RIP: 0010:nf_xfrm_me_harder+0xe7/0x130 [nf_nat]
Code: 48 8b 5c 24 60 65 48 33 1c 25 28 00 00 00 75 53 48 83 c4 68 5b 5d 41 5c c3 85 c0 74 0d 8d 48 01 f0 0f b1 0a 74 86 85 c0 75 f3 <0f> 0b e9 7b ff ff ff 29 c6 31 d2 b9 20 00 48 00 4c 89 e7 e8 31 27
Call Trace:
nf_nat_ipv4_out+0x78/0x90 [nf_nat_ipv4]
nf_hook_slow+0x36/0xd0
ip_output+0x9f/0xd0
ip_forward+0x328/0x440
ip_rcv+0x8a/0xb0
Use dst_hold_safe instead and bail out if we cannot take a reference.
Fixes: a4c2fd7f7891 ("net: remove DST_NOCACHE flag")
Reported-by: Martin Zaharinov <micron10@gmail.com>
[ Upstream commit 708abf74dd87f8640871b814faa195fb5970b0e3 ]
In the error handling block, nla_nest_cancel(skb, atd) is called to
cancel the nest operation. But then, ipset_nest_end(skb, atd) is
unexpected called to end the nest operation. This patch calls the
ipset_nest_end only on the branch that nla_nest_cancel is not called.
Fixes: 45040978c899 ("netfilter: ipset: Fix set:list type crash when flush/dump set in parallel")
Signed-off-by: Pan Bian <bianpan2016@163.com>
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
[ Upstream commit 530aad77010b81526586dfc09130ec875cd084e4 ]
When adjusting sack block sequence numbers, skb_make_writable() gets
called to make sure tcp options are all in the linear area, and buffer
is not shared.
This can cause tcp header pointer to get reallocated, so we must
reaload it to avoid memory corruption.
This bug pre-dates git history.
Reported-by: Neel Mehta <nmehta@google.com>
Reported-by: Shane Huntley <shuntley@google.com>
Reported-by: Heather Adkins <argv@google.com>
the dst_entry.
[ Upstream commit 0152eee6fc3b84298bb6a79961961734e8afa5b8 ]
Since commit 222d7dbd258d ("net: prevent dst uses after free")
skb_dst_force() might clear the dst_entry attached to the skb.
The xfrm code doesn't expect this to happen, so we crash with
a NULL pointer dereference in this case.
Fix it by checking skb_dst(skb) for NULL after skb_dst_force()
and drop the packet in case the dst_entry was cleared. We also
move the skb_dst_force() to a codepath that is not used when
the transformation was offloaded, because in this case we
don't have a dst_entry attached to the skb.
The output and forwarding path was already fixed by
commit 9e1437937807 ("xfrm: Fix NULL pointer dereference when
skb_dst_force clears the dst_entry.")
Fixes: 222d7dbd258d ("net: prevent dst uses after free")
Reported-by: Jean-Philippe Menil <jpmenil@gmail.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit ca92e173ab34a4f7fc4128bd372bd96f1af6f507 ]
sadhcnt is reported by `ip -s xfrm state count` as "buckets count", not the
hash mask.
Fixes: 28d8909bc790 ("[XFRM]: Export SAD info.")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
[ Upstream commit 533555e5cbb6aa2d77598917871ae5b579fe724b ]
xfrm_output_one() does not return a error code when there is
no dst_entry attached to the skb, it is still possible crash
with a NULL pointer dereference in xfrm_output_resume(). Fix
it by return error code -EHOSTUNREACH.
Fixes: 9e1437937807 ("xfrm: Fix NULL pointer dereference when skb_dst_force clears the dst_entry.")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
